[参考译文] CC2640R2F:配置 ADC 时遇到问题
Guru**** 2609955 points
Other Parts Discussed in Thread: CC2640R2F
https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1204115/cc2640r2f-trouble-configuring-adc
器件型号:CC2640R2F
我正在学习 GUI Composer ADC 应用程序教程 、现在很难判断要从哪个引脚读取 ADC 值。  在示例代码中,传递给 ADC_Open()函数的是 Board_ADC0。  当我查看 Board.h 文件并深入到适合我的板的 ADC0时、它显示了这一点
该引脚似乎未映射到任何物理引脚。  我查看了数据表、并看到 ADC 引脚位于何处
但是、引脚36与电路板图上的引脚不匹配
    您好、Charlie。
    DIO23低于3.3V。 不会针对 CC2640R2F Launchpad 更新上图。 可能这不是 CC2640R2F Launchpad。
    在 CC2640R2_LAUNCHXL.h 上枚举 CC2640R2_LAUNCHXL_ADCName
     *  @def    CC2640R2_LAUNCHXL_ADCName
     *  @brief  Enum of ADCs
    typedef enum CC2640R2_LAUNCHXL_ADCName {
        CC2640R2_LAUNCHXL_ADC0 = 0,
        CC2640R2_LAUNCHXL_ADC1,
        CC2640R2_LAUNCHXL_ADC2,
        CC2640R2_LAUNCHXL_ADC3,
        CC2640R2_LAUNCHXL_ADC4,
        CC2640R2_LAUNCHXL_ADC5,
        CC2640R2_LAUNCHXL_ADC6,
        CC2640R2_LAUNCHXL_ADC7,
        CC2640R2_LAUNCHXL_ADCDCOUPL,
        CC2640R2_LAUNCHXL_ADCVSS,
        CC2640R2_LAUNCHXL_ADCVDDS,
        CC2640R2_LAUNCHXL_ADCCOUNT
    } CC2640R2_LAUNCHXL_ADCName;
    上述对 CCC26XX_HWAttrs adcCC26xxHWAttrs [CC2640R2_LAUNCHXL_ADCCOUNT ](CC2640R2_LAUNCHXL.c)的枚举引用
     *  =============================== ADC ===============================
    #include <ti/drivers/ADC.h>
    #include <ti/drivers/adc/ADCCC26XX.h>
    ADCCC26XX_Object adcCC26xxObjects[CC2640R2_LAUNCHXL_ADCCOUNT];
    const ADCCC26XX_HWAttrs adcCC26xxHWAttrs[CC2640R2_LAUNCHXL_ADCCOUNT] = {
            .adcDIO              = CC2640R2_LAUNCHXL_DIO23_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO7,
            .refSource           = ADCCC26XX_FIXED_REFERENCE,
            .samplingDuration    = ADCCC26XX_SAMPLING_DURATION_2P7_US,
            .inputScalingEnabled = true,
            .triggerSource       = ADCCC26XX_TRIGGER_MANUAL,
            .returnAdjustedVal   = false
            .adcDIO              = CC2640R2_LAUNCHXL_DIO24_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO6,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO25_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO5,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO26_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO4,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO27_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO3,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO28_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO2,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO29_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO1,
            .adcDIO              = CC2640R2_LAUNCHXL_DIO30_ANALOG,
            .adcCompBInput       = ADC_COMPB_IN_AUXIO0,
            .samplingDuration    = ADCCC26XX_SAMPLING_DURATION_10P9_MS,
            .adcDIO              = PIN_UNASSIGNED,
            .adcCompBInput       = ADC_COMPB_IN_DCOUPL,
            .adcCompBInput       = ADC_COMPB_IN_VSS,
            .adcCompBInput       = ADC_COMPB_IN_VDDS,
    CC2640R2_LAUNCHXL_ADC0 = CC2640R2_LAUNCHXL_DIO23_ANALOG = IOID_23
    我建议您只需调试 adcsinglechchannel 示例程序、以查看读取 ADC 值。
    -kel
