[FAQ] [参考译文] [常见问题解答] TI-API:v2备货报价 API 错误代码和含义(第1部分、共2部分)
Guru**** 540980 points
https://e2e.ti.com/support/enterprise-automation-integration-group/enterprise-automation-integration/f/enterprise-automation-integration-forum/1219995/faq-ti-api-v2-backlog-quote-api-error-codes-and-meanings-part-1-of-2
器件型号:TI-API
v2报价 API 错误代码意味着什么?
    场景 错误详细信息 补救步骤
    缺少 endCustomerCompanyName 或 endCustomerNumber
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0001",
    			"type": "ERROR",
    			"reason": "Missing endCustomerCompanyName or endCustomerNumber",
    			"message": "endCustomerCompanyName or endCustomerNumber cannot be null or empty.  Enter either a valid endCustomerCompanyName or endCustomerNumber and resubmit request."
    缺少 endCustomerCompanyName 或 endCustomerNumber,且不能为空。 输入有效的 endCustomerCompanyName 或 endCustomerNumber、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    缺少数量
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0002",
    			"type": "ERROR",
    			"reason": "Missing quantity",
    			"message": "quantity cannot be null or empty.  Enter a valid quantity number for each line item and resubmit request."
    数量缺失、不能为空或为空。 输入每个行项目的有效数量号、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    缺少 tiSoldToAccountNumber
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0003",
    			"type": "ERROR",
    			"reason": "Missing tiSoldToAccountNumber",
    			"message": "tiSoldToAccountNumber cannot be null or empty. Contact TI API Support https://api-portal.ti.com/support for assistance."
    缺少 tiSoldToAccountNumber、且不能为空。 如需帮助、请联系 TI API 支持 api-portal.ti.com/support。
    customerQuoteNumber 无效
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0004",
    			"type": "ERROR",
    			"reason": "Invalid customerQuoteNumber",
    			"message": " Line Item {n}: customerQuoteNumber cannot exceed 35 characters in length.  Enter a valid customerQuoteNumber up to 35 characters and resubmit request."
    customerQuoteNumber 超过了最大长度35个字符。 输入不超过35个字符的有效 customerQuoteNumber、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    无效的 quoteReason
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0005",
    			"type": "ERROR",
    			"reason": "Invalid quoteReason",
    			"message": "quoteReason is not valid. Enter a valid 2-character for quoteReason and resubmit request. See https://e2e.ti.com/f/1/t/1213304 for more details."
    quoteReason 无效。 为 quoteReason 输入有效的2个字符、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    缺少 tiSoldToAccountNumber 或 soldToAccountNumber 或其无效
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0006",
    			"type": "ERROR",
    			"reason": "Missing or invalid tiSoldToAccountNumber or soldToAccountNumber",
    			"message": "Line Item {n}:  tiSoldToAccountNumber or soldToAccountNumber cannot be null or empty or is not valid.  Enter a valid tiSoldToAccountNumber (up to 10 characters) or soldToAccountNumber (up to 20 characters) and resubmit request."
    tiSoldToAccountNumber 或 soldToAccountNumber 缺失、不能为空或无效。 输入有效的 tiSoldToAccountNumber (1-10个字符)或 soldToAccountNumber (1-20个字符)并重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    联系人名称无效
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0007",
    			"type": "ERROR",
    			"reason": "Invalid contactName",
    			"message": "Line Item {n}: contactName is not valid.  Enter a valid contactName up to 40 characters and resubmit request."
    contactName 超过40个字符的最大长度。 输入不超过40个字符的有效联系人姓名、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    联系人电子邮件地址无效
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0008",
    			"type": "ERROR",
    			"reason": "Invalid contactEmailAddress",
    			"message": "Line Item {n}: contactEmailAddress cannot exceed 75 characters in length. Enter a valid contactEmailAddress up to 75 characters and resubmit request."
    contactEmailAddress 超过75个字符的最大长度。 输入不超过75个字符的有效联系人电子邮件地址、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    联系人电话号码无效
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0009",
    			"type": "ERROR",
    			"reason": "Invalid contactPhoneNumber",
    			"message": "Line Item {n}: contactPhoneNumber cannot exceed 30 characters in length.  Enter a valid contactPhoneNumber up to 30 characters and resubmit request."
    contactPhoneNumber 超过30个字符的最大长度。 输入不超过30个字符的有效 contactPhoneNumber、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    缺少或无效的 endCustomerCompanyName 和 endCustomerNumber
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0010",
    			"type": "ERROR",
    			"reason": "Missing or invalid endCustomerCompanyName and endCustomerNumber",
    			"message": "Line Item {n}: endCustomerCompanyName or endCustomerNumber cannot be null or empty or is not valid.  Enter a valid endCustomerCompanyName (up to 52 characters) or endCustomerNumber (up to 10 characters) and resubmit request."
    提供有效的 EndCustomerCompanyName (1-52个字符)或 endCustomerNumber (1-10个字符)并重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    customerLineItemNumber 无效
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0011",
    			"type": "ERROR",
    			"reason": "Invalid customerLineItemNumber",
    			"message": "Line Item {n}: customerLineItemNumber cannot exceed 10 characters in length.  Enter a valid customerLineItemNumber up to 10 characters and resubmit request."
    customerLineItemNumber 超过10个字符的最大长度。 输入不超过10个字符的有效 customerLineItemNumber、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    无效的竞争对手当前代码
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0012",
    			"type": "ERROR",
    			"reason": "Invalid competitorCurrencyCode",
    			"message": "Line Item {n}: competitorCurrencyCode cannot exceed 5 characters in length.  Enter a valid competitorCurrencyCode up to 5 characters and resubmit request."
    competitorCurrencyCode 超过5个字符的最大长度。 输入不超过5个字符的有效竞争对手当前代码,然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    无效的竞争对手 UnitPrice
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0013",
    			"type": "ERROR",
    			"reason": "Invalid competitorUnitPrice",
    			"message": "Line Item {n}: competitorUnitPrice cannot exceed 19 characters in length.  Enter a valid competitorUnitPrice up to 19 characters and resubmit request."
    competitorUnitPrice 超过19个字符的最大长度。 输入不超过19个字符的有效竞争对手 UnitPrice,然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    无效的竞争对手部件号
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0014",
    			"type": "ERROR",
    			"reason": "Invalid competitorPartNumber",
    			"message": "Line Item {n}: competitorPartNumber cannot exceed 40 characters in length.  Enter a valid competitorPartNumber up to 40 characters and resubmit request."
    competitorPartNumber 超过最大长度40个字符。 输入不超过40个字符的有效竞争对手零件号、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    无效的竞争对手名称
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0015",
    			"type": "ERROR",
    			"reason": "Invalid competitorName",
    			"message": "Line Item {n}: competitorName cannot exceed 40 characters in length.  Enter a valid competitorName up to 40 characters and resubmit request."
    competitorName 超过40个字符的最大长度。 输入不超过40个字符的有效竞争对手名称,然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    重新申请的单位价格无效
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0016",
    			"type": "ERROR",
    			"reason": "Invalid requestedUnitPrice",
    			"message": "Line Item {n}: requestedUnitPrice cannot exceed 19 characters in length.  Enter a valid requestedUnitPrice up to 19 characters and resubmit request."
    所需单位的最大长度超过19个字符。 输入不超过19个字符的有效要求单位,然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    数量无效
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0017",
    			"type": "ERROR",
    			"reason": "Invalid quantity",
    			"message": "Line Item {n}: quantity cannot exceed 13 characters in length.  Enter a valid quantity up to 13 characters and resubmit request."
    数量超过13个字符的最大长度。 输入不超过13个字符的有效数量、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    无效的 customerPartNumber
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0018",
    			"type": "ERROR",
    			"reason": "Invalid customerPartNumber",
    			"message": "Line Item {n}: customerPartNumber cannot exceed 40 characters in length. Enter a valid customerPartNumber up to 40 characters and resubmit request."
    customerPartNumber 超过最大长度40个字符。 输入不超过40个字符的有效定制器零件号、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    无效的 tiPart 编号
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0019",
    			"type": "ERROR",
    			"reason": "Invalid tiPartNumber",
    			"message": "Line Item {n}: tiPartNumber cannot exceed 40 characters in length.  Enter a valid tiPartNumber up to 40 characters and resubmit request."
    tiPartNumber 超过了最大长度40个字符。 输入不超过40个字符的有效 tiPartNumber、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    重新申请的 UnitPriceCurrencyCode 无效
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0027",
    			"type": "ERROR",
    			" reason ": "Invalid requestedUnitPriceCurrencyCode",
    			"message": " requestedUnitPriceCurrencyCodecannot exceed 5 characters in length. Enter a valid requestedUnitPriceCurrencyCode up to 5 characters and resubmit request."
    要求的 UnitPriceCurrencyCode 超过5个字符的最大长度。 输入不超过5个字符的有效要求 UnitPriceCurrencyCode、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    发生系统错误
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0500",
    			"type": "ERROR",
    			"reason": "System error occurred",
    			"message": "System error has occurred. Contact TI API Support  https://api-portal.ti.com/support "
    发生系统错误。 联系 TI API 支持 api-portal.ti.com/support 以了解有关错误消息、错误代码、API 端点和遇到的任何其他错误等任何详细信息。
    无效的竞争单元单价格式
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0028",
    			"type": "ERROR",
    			"reason": "Invalid format for competitorUnitPrice",
    			"message": "Line Item {n}: competitorUnitPrice format should include a decimal point (.) as a separator and should not exceed five decimal places.
    输入有效的竞争对手 UnitPrice 以包括一个小数点且不超过五位小数。 重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    重新申请单位价格格式无效
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0029",
    			"type": "ERROR",
    			"reason": "Invalid format for requestedUnitPrice",
    			"message": "Line Item {n}: requestedUnitPrice format should include a decimal point (.) as a separator and should not exceed five decimal places.
    输入有效的要求单位价格以包括一个小数点且不超过五位小数。 重新提交申请。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    无效的 endCustomerNumber 格式
    	"errors": [
    			"errorCode": "ERR-BKG-QUOTE-API-0030",
    			"type": "ERROR",
    			"reason": "Invalid format for endCustomerNumber ",
    			"message": "Line Item {n}: endCustomerNumber must be numeric and not exceed 10 digit.  Enter a valid endCustomerNumber and resubmit request."
    输入有效的 EndCustomerNumber 为数字,不超过10位。 如果需要更多帮助、请联系 TI API 支持 api-portal.ti.com/support
    View v2备货报价 API 错误代码和含义(第2部分、共2部分)
