https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1185459/run_app_tidl-sh
主题中讨论的其他器件:TDA4VM尊敬的 TI:
我正在尝试在开发板上运行深度学习演示应用、但在我完成初始化并运行`。/run_app_tidl.sh`命令后遇到以下错误。
谢谢!APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=4) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 1700.626298 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 1700.626344 s: VX_ZONE_INIT:Enabled 1700.626350 s: VX_ZONE_ERROR:Enabled 1700.626355 s: VX_ZONE_WARNING:Enabled 1700.626906 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! 1700.626956 s: VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!! 1701.119075 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1 1701.119126 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed. 1701.119134 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 1701.119140 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core 1701.119146 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 1701.119154 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 1701.119168 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed 1701.119174 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed app_tidl: ERROR: Verifying graph ... Failed !!! 1701.119950 s: VX_ZONE_INIT:[tivxHostDeInitLocal:100] De-Initialization Done for HOST !!! [C7x_1 ] 1701.118842 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:686] Network version - 0x20210723, Expected version - 0x20220823 1701.124307 s: VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!! APP: Deinit ... !!! REMOTE_SERVICE: Deinit ... !!! REMOTE_SERVICE: Deinit ... Done !!! IPC: Deinit ... !!! IPC: DeInit ... Done !!! MEM: Deinit ... !!! DDR_SHARED_MEM: Alloc's: 14 alloc's of 22869351 bytes DDR_SHARED_MEM: Free's : 14 free's of 22869351 bytes DDR_SHARED_MEM: Open's : 0 allocs of 0 bytes DDR_SHARED_MEM: Total size: 536870912 bytes MEM: Deinit ... Done !!! APP: Deinit ... Done !!! ``` I didn't find any promising solution on the forum. Is there any help? The related logs (boot log and init log) are attached behind. Thank you for the help. * boot log: ```shell U-Boot SPL 2021.01 (Nov 16 2022 - 12:32:08 +0800) Model: Texas Instruments K3 J721E SoC EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -19 Board: J721EX-PM1-SOM rev E2 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -19 Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.6(release):v2.7-rc0-dirty NOTICE: BL31: Built : 09:18:58, Aug 30 2022 I/TC: I/TC: OP-TEE version: 3.17.0-125-g15a746d28 (gcc version 9.2.1 20191025 (GNU Too lchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Tue Aug 30 09: 19:19 UTC 2022 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check optee.readthedocs.io/.../ porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2021.01 (Nov 16 2022 - 12:32:08 +0800) Model: Texas Instruments K3 J721E SoC EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -19 Board: J721EX-PM1-SOM rev E2 SYSFW ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.04.01 (Jolly Jellyfi') EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -19 Trying to boot from MMC2 U-Boot 2021.01 (Nov 16 2022 - 12:32:08 +0800) SoC: J721E SR1.1 GP Model: Texas Instruments K3 J721E SoC EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -19 Board: J721EX-PM1-SOM rev E2 DRAM: 4 GiB Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from FAT... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA8 0100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -19 Net: eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 13 ms (36.1 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 14 ms (0 Bytes/s) Already setup. GPIO: 'gpio@22_17' not found Command 'gpio' failed: Error -22 GPIO: 'gpio@22_16' not found Command 'gpio' failed: Error -22 k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work 921012 bytes read in 127 ms (6.9 MiB/s) Load Remote Processor 2 with data@addr=0x82000000 921012 bytes: Success! 297900 bytes read in 90 ms (3.2 MiB/s) Load Remote Processor 3 with data@addr=0x82000000 297900 bytes: Success! Failed to load '/lib/firmware/j7-main-r5f1_0-fw' Failed to load '/lib/firmware/j7-main-r5f1_1-fw' 1469172 bytes read in 164 ms (8.5 MiB/s) Load Remote Processor 6 with data@addr=0x82000000 1469172 bytes: Success! 1469172 bytes read in 159 ms (8.8 MiB/s) Load Remote Processor 7 with data@addr=0x82000000 1469172 bytes: Success! 12980176 bytes read in 320 ms (38.7 MiB/s) Load Remote Processor 8 with data@addr=0x82000000 12980176 bytes: Success! 18455040 bytes read in 2546 ms (6.9 MiB/s) 105530 bytes read in 36 ms (2.8 MiB/s) 11671 bytes read in 47 ms (242.2 KiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008fee3000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.120-g95b90aa828 (hhw3516496@fdt-comp-07) (aarc h64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architectur e 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Mon Oct 31 15:30:51 CS T 2022 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a00 00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, s ize 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a010000 0, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a10 00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, s ize 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a110000 0, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a20 00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, s ize 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a210000 0, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a40 00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, s ize 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a410000 0, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a60 00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, s ize 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a610000 0, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a70 00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, s ize 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a710000 0, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a80 00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, s ize 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a810000 0, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a90 00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, s ize 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a910000 0, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, s ize 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa0 00000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, s ize 79 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa10000 0, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, s ize 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b200000 0, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, c ompatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, s ize 192 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-l o@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, s ize 8 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-qu eues@e4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, s ize 24 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-bu ffers@e4800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, s ize 624 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-h i@880000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff] [ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff] [ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff] [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff] [ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff] [ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] cma: Reserved 400 MiB at 0x00000000e7000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmi o32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi .u-boot),256k(ospi.env),1m(ospi.sysfw),256k(ospi.env.backup),57088k@8m(ospi.root fs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m (hbmc.u-boot),256k(hbmc.env),1m(hbmc.sysfw),-@8m(hbmc.rootfs) root=PARTUUID=5209 e87d-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes , linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e80000 0] (64MB) [ 0.000000] Memory: 1828084K/4194304K available (10816K kernel code, 1126K rw data, 4184K rodata, 1792K init, 431K bss, 1956620K reserved, 409600K cma-reserve d) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jif fies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->1 9 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat , esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008a7030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a704000 0 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 43980 46511102ns [ 0.008414] Console: colour dummy device 80x25 [ 0.012978] Calibrating delay loop (skipped), value calculated using timer fr equency.. 400.00 BogoMIPS (lpj=800000) [ 0.023649] pid_max: default: 32768 minimum: 301 [ 0.028403] LSM: Security Framework initializing [ 0.033161] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, line ar) [ 0.040739] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049521] rcu: Hierarchical SRCU implementation. [ 0.054569] Platform MSI: msi-controller@1820000 domain created [ 0.060801] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@ 1820000 domain created [ 0.070104] EFI services will not be available. [ 0.074833] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.088098] Detected PIPT I-cache on CPU1 [ 0.088122] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.088133] GICv3: CPU1: using allocated LPI pending table @0x00000008a705000 0 [ 0.088169] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.088219] smp: Brought up 1 node, 2 CPUs [ 0.117563] SMP: Total of 2 processors activated. [ 0.122367] CPU features: detected: 32-bit EL0 Support [ 0.127622] CPU features: detected: CRC32 instructions [ 0.141481] CPU: All CPU(s) started at EL2 [ 0.145679] alternatives: patching kernel code [ 0.150692] devtmpfs: initialized [ 0.159617] KASLR disabled due to lack of seed [ 0.164263] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma x_idle_ns: 7645041785100000 ns [ 0.174225] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.187001] pinctrl core: initialized pinctrl subsystem [ 0.192649] DMI not present or invalid. [ 0.196891] NET: Registered protocol family 16 [ 0.202115] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.209428] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allo cations [ 0.217483] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic al locations [ 0.225787] thermal_sys: Registered thermal governor 'step_wise' [ 0.225789] thermal_sys: Registered thermal governor 'power_allocator' [ 0.232368] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.246002] ASID allocator initialised with 65536 entries [ 0.266923] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.273779] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.280625] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.287471] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.294941] cryptd: max_cpu_qlen set to 1000 [ 0.300943] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6 402f] Detected [ 0.309741] vsys_3v3: supplied by evm_12v0 [ 0.314095] vsys_5v0: supplied by evm_12v0 [ 0.318790] iommu: Default domain type: Translated [ 0.323964] SCSI subsystem initialized [ 0.328066] mc: Linux media interface: v0.10 [ 0.332443] videodev: Linux video capture interface: v2.00 [ 0.338076] pps_core: LinuxPPS API ver. 1 registered [ 0.343147] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it> [ 0.352485] PTP clock support registered [ 0.356510] EDAC MC: Ver: 3.0.0 [ 0.360267] FPGA manager framework [ 0.363774] Advanced Linux Sound Architecture Driver Initialized. [ 0.370367] clocksource: Switched to clocksource arch_sys_counter [ 0.376690] VFS: Disk quotas dquot_6.6.0 [ 0.380721] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.390305] Carveout Heap: Exported 512 MiB at 0x00000000b8000000 [ 0.396595] NET: Registered protocol family 2 [ 0.401326] IP idents hash table entries: 65536 (order: 7, 524288 bytes, line ar) [ 0.409911] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 3276 8 bytes, linear) [ 0.418663] TCP established hash table entries: 32768 (order: 6, 262144 bytes , linear) [ 0.426863] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linea r) [ 0.434664] TCP: Hash tables configured (established 32768 bind 32768) [ 0.441452] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.448344] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.455742] NET: Registered protocol family 1 [ 0.460470] RPC: Registered named UNIX socket transport module. [ 0.466533] RPC: Registered udp transport module. [ 0.471338] RPC: Registered tcp transport module. [ 0.476140] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.482724] PCI: CLS 0 bytes, default 64 [ 0.487097] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counte rs available [ 0.497395] Initialise system trusted keyrings [ 0.502024] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.510212] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.516413] NFS: Registering the id_resolver key type [ 0.521637] Key type id_resolver registered [ 0.525909] Key type id_legacy registered [ 0.530032] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.536881] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering ... [ 0.544517] 9p: Installing v9fs 9p2000 file system support [ 0.569408] Key type asymmetric registered [ 0.573594] Asymmetric key parser 'x509' registered [ 0.578590] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 43) [ 0.586149] io scheduler mq-deadline registered [ 0.590774] io scheduler kyber registered [ 0.596283] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.602485] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.611075] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.617335] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.625217] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.633325] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00 001faf) [ 0.641588] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.648669] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.657214] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to w ired irqs [ 0.670299] brd: module loaded [ 0.676718] loop: module loaded [ 0.680295] sysfs: cannot create duplicate filename '/devices/platform/dma_bu f_phys' [ 0.688224] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.120-g95b90aa828 #1 [ 0.695511] Hardware name: Texas Instruments K3 J721E SoC (DT) [ 0.701468] Call trace: [ 0.703970] dump_backtrace+0x0/0x1a0 [ 0.707706] show_stack+0x18/0x68 [ 0.711091] dump_stack+0xd0/0x12c [ 0.714561] sysfs_warn_dup+0x60/0x80 [ 0.718295] sysfs_create_dir_ns+0xe0/0xf8 [ 0.722478] kobject_add_internal+0x98/0x288 [ 0.726834] kobject_add+0x94/0x100 [ 0.730394] device_add+0xe0/0x740 [ 0.733864] platform_device_add+0x100/0x238 [ 0.738221] platform_device_register_full+0xcc/0x150 [ 0.743380] dma_buf_phys_init+0x6c/0x9c [ 0.747382] do_one_initcall+0x54/0x1b8 [ 0.751295] kernel_init_freeable+0x220/0x2a0 [ 0.755745] kernel_init+0x14/0x114 [ 0.759302] ret_from_fork+0x10/0x34 [ 0.762963] kobject_add_internal failed for dma_buf_phys with -EEXIST, don't try to register things with the same name in the same directory. [ 0.776173] megasas: 07.714.04.00-rc1 [ 0.781723] tun: Universal TUN/TAP device driver, 1.6 [ 0.787154] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.793567] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.799643] sky2: driver version 1.30 [ 0.803950] VFIO - User Level meta-driver version: 0.3 [ 0.809690] i2c /dev entries driver [ 0.813966] sdhci: Secure Digital Host Controller Interface driver [ 0.820288] sdhci: Copyright(c) Pierre Ossman [ 0.824997] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.831322] ledtrig-cpu: registered to indicate activity on CPUs [ 0.837654] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.844858] optee: probing for conduit method. [ 0.849419] optee: revision 3.17 (15a746d2) [ 0.849557] optee: dynamic shared memory is enabled E/TC:1 0 std_entry_with_parg:234 Bad arg address 0x8a807a000 [ 0.864359] optee: initialized driver [ 0.869344] NET: Registered protocol family 17 [ 0.873967] 9pnet: Installing 9P2000 support [ 0.878371] Key type dns_resolver registered [ 0.882835] Loading compiled-in X.509 certificates [ 0.892763] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.899099] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.907346] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.4.1--v08.0 4.01 (Jolly Jellyfi') [ 0.966689] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 0.974433] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 0.980529] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 0.986605] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [ 0.992657] omap_i2c 2020000.i2c: bus 3 rev0.12 at 400 kHz [ 0.998958] pca953x 4-0020: supply vcc not found, using dummy regulator [ 1.005785] pca953x 4-0020: using no AI [ 1.031046] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz [ 1.037139] omap_i2c 2040000.i2c: bus 5 rev0.12 at 100 kHz [ 1.043170] omap_i2c 2050000.i2c: bus 6 rev0.12 at 100 kHz [ 1.049590] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interr upt Router 137 domain created [ 1.059568] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 13 1 domain created [ 1.068380] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrup t Router 213 domain created [ 1.078252] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator d omain 209 created [ 1.098844] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 1.106518] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 1.114794] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 1.123073] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.131910] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 1.139586] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 1.147861] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 1.156139] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.164940] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 1.172612] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 1.180888] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 1.189163] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.198411] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, g p-rings[96,20] sci-dev-id:235 [ 1.208282] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 1.215045] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies: 64 [ 1.224136] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 1.234289] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 1.241047] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies: 64 [ 1.248984] printk: console [ttyS2] disabled [ 1.253378] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 28, base_baud = 30 00000) is a 8250 [ 1.262120] printk: console [ttyS2] enabled [ 1.262120] printk: console [ttyS2] enabled [ 1.270556] printk: bootconsole [ns16550a0] disabled [ 1.270556] printk: bootconsole [ns16550a0] disabled [ 1.281068] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 29, base_baud = 30 00000) is a 8250 [ 1.290029] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 30, base_baud = 30 00000) is a 8250 [ 1.299805] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd -hba-supply regulator, assuming enabled [ 1.310320] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc -supply regulator, assuming enabled [ 1.320472] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc q-supply regulator, assuming enabled [ 1.330709] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc q2-supply regulator, assuming enabled [ 1.341902] scsi host0: ufshcd [ 1.348887] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.363673] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0 [ 1.394374] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1 000000 [ 1.399780] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2 [ 1.402391] mdio_bus 46000f00.mdio: MDIO device at address 1 is missing. [ 1.413657] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Re gulator capability was not set, actvIccLevel=0 [ 1.420351] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss ver sion 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.431557] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 030 0 PQ: 0 ANSI: 6 [ 1.453037] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 030 0 PQ: 0 ANSI: 6 [ 1.461861] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not foun d [ 1.461897] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add _val:4 pps:0 [ 1.578741] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.578927] mmc0: CQHCI version 5.10 [ 1.595126] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 1.601993] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 1.608832] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 1.615675] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 1.622497] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 1.626943] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64 -bit [ 1.640060] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 1.647549] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 1.655628] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 1.663706] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.672389] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 1.679877] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 1.687955] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 1.696034] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.704619] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 1.712110] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 1.720189] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 1.722243] mmc0: Command Queue Engine enabled [ 1.728270] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 1.732699] mmc0: new HS200 MMC card at address 0001 [ 1.746225] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 1.750886] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 1.751146] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 1.756916] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 1.771304] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237: 0) [ 1.780092] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 1.782976] mmcblk0: p1 p2 [ 1.794527] spi-nor spi0.0: mt35xu512aba (65536 Kbytes) [ 1.799759] 8 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 1.806356] Creating 8 MTD partitions on "47040000.spi.0": [ 1.811828] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.817773] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.823461] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.829252] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.834773] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 1.840455] 0x0000007c0000-0x000000800000 : "ospi.env.backup" [ 1.846599] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.852373] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.861128] spi-nor spi1.0: unrecognized JEDEC id bytes: 00 00 00 00 00 00 [ 1.868006] spi-nor: probe of spi1.0 failed with error -2 [ 1.874133] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 1.918387] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1 000000 [ 1.926367] mdio_bus 46000f00.mdio: MDIO device at address 1 is missing. [ 1.933087] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss ver sion 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 1.946802] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 1.953784] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1. 4 [ 1.960992] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 1.967356] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:50000 0000, add_val:1 pps:0 [ 1.977592] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 1.990612] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 1.990772] mmc1: CQHCI version 5.10 [ 1.998098] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 2.009733] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 2.017813] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.026495] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 2.033986] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 2.042064] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 2.050145] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.058728] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 2.066216] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 2.074293] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 2.082372] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.091439] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 2.098932] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 2.107011] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 2.115096] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.123908] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 2.131402] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 2.139478] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 2.147556] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.156133] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 2.163626] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 2.171705] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 2.179781] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.188362] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present ! [ 2.195650] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present ! [ 2.203882] debugfs: Directory 'pd:242' with parent 'pm_genpd' already presen t! [ 2.211199] debugfs: Directory 'pd:241' with parent 'pm_genpd' already presen t! [ 2.218504] debugfs: Directory 'pd:240' with parent 'pm_genpd' already presen t! [ 2.225814] debugfs: Directory 'pd:239' with parent 'pm_genpd' already presen t! [ 2.234030] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 2.241564] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 2.249061] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 2.257146] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 2.265235] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.273905] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 2.281399] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 2.289484] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 2.297568] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.306192] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 2.313686] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 2.321769] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 2.329867] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.350268] ALSA device list: [ 2.353232] No soundcards found. [ 3.059047] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64 -bit [ 3.067420] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 3.074997] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 3.083085] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 3.091174] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.099606] Waiting for root device PARTUUID=5209e87d-02... [ 3.099852] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 3.112663] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 3.120757] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 3.128897] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.137616] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 3.145167] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 3.153256] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 3.161373] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.193045] mmc1: new SDXC card at address b368 [ 3.197932] mmcblk1: mmc1:b368 NCard 58.2 GiB [ 3.206963] mmcblk1: p1 p2 [ 3.210849] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 3.218336] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 3.226414] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 3.234495] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.243088] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 3.250594] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 3.258674] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 3.266750] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.275330] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 3.282822] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 3.290899] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 3.298979] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 5.255042] EXT4-fs (mmcblk1p2): warning: mounting fs with errors, running e2 fsck is recommended [ 5.285338] EXT4-fs (mmcblk1p2): recovery complete [ 5.310541] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. O pts: (null) [ 5.318654] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 5.383686] devtmpfs: mounted [ 5.387526] Freeing unused kernel memory: 1792K [ 5.392153] Run /sbin/init as init process [ 7.134884] systemd[1]: System time before build time, advancing clock. [ 7.665494] NET: Registered protocol family 10 [ 7.670447] Segment Routing with IPv6 [ 7.888198] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT - SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +AC L +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=h ybrid) [ 7.909937] systemd[1]: Detected architecture arm64. Welcome to Arago 2021.09! [ 7.981169] systemd[1]: Set hostname to <j7-evm>. [ 10.019143] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= re ferences a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly. [ 10.391711] random: systemd: uninitialized urandom read (16 bytes read) [ 10.398465] systemd[1]: system-getty.slice: unit configures an IP firewall, b ut the local system does not support BPF/cgroup firewalling. [ 10.410793] systemd[1]: (This warning is only shown for the first unit using IP firewalling.) [ 10.420749] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 10.442452] random: systemd: uninitialized urandom read (16 bytes read) [ 10.449783] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 10.470455] random: systemd: uninitialized urandom read (16 bytes read) [ 10.477187] systemd[1]: Started Dispatch Password Requests to Console Directo ry Watch. [ OK ] Started Dispatch Password …ts to Console Directory Watch. [ 10.502498] systemd[1]: Started Forward Password Requests to Wall Directory W atch. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ 10.526494] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 10.542429] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 10.562426] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 10.578430] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 10.622955] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 10.646468] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 10.687195] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 10.710670] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 10.828441] systemd[1]: Condition check resulted in Journal Audit Socket bein g skipped. [ 10.836809] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 10.858717] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 10.874746] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 10.898638] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 10.918561] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 10.940576] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 10.956970] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 10.980638] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 11.037709] systemd[1]: Mounting Temporary Directory (/tmp)... Mounting Temporary Directory (/tmp)... [ 11.060744] systemd[1]: Starting Create list of static device nodes for the c urrent kernel... Starting Create list of st…odes for the current kernel... [ 11.088580] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 11.142443] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 11.162623] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 11.174765] systemd[1]: Starting Journal Service... Starting Journal Service... [ 11.403857] urandom_read_iter: 22 callbacks suppressed [ 11.403860] random: systemd: uninitialized urandom read (16 bytes read) [ 11.417722] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 11.434572] random: systemd: uninitialized urandom read (16 bytes read) [ 11.443482] systemd[1]: Starting Remount Root and Kernel File Systems... Starting Remount Root and Kernel File Systems... [ 11.466592] random: systemd: uninitialized urandom read (16 bytes read) [ 11.475472] systemd[1]: Starting udev Coldplug all Devices... Starting udev Coldplug all Devices... [ 11.494014] systemd[1]: Mounted Huge Pages File System. [ OK ] Mounted Huge Pages File System. [ 11.518952] systemd[1]: Mounted POSIX Message Queue File System. [ OK ] Mounted POSIX Message Queue File System. [ 11.543024] systemd[1]: Mounted Kernel Debug File System. [ OK ] Mounted Kernel Debug File System 11.553321] EXT4-fs (mmcblk1p2): re-m ounted. Opts: (null) m. [ 11.571762] systemd[1]: Mounted Temporary Directory (/tmp). [ OK ] Mounted Temporary Directory (/tmp). [ 11.599713] systemd[1]: Started Create list of static device nodes for the cu rrent kernel. [ OK ] Started Create list of sta… nodes for the current kernel. [ 11.623886] systemd[1]: Started Remount Root and Kernel File Systems. [ OK ] Started Remount Root and Kernel File Systems. [ 11.951584] cryptodev: loading out-of-tree module taints kernel. [ 11.958432] cryptodev: driver 1.10 loaded. [ 12.001253] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 12.009787] systemd[1]: Condition check resulted in Create System Users being skipped. [ 12.019922] systemd[1]: Starting Create Static Device Nodes in /dev... Starting Create Static Device Nodes in /dev... [ 12.043007] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star…progress communication helper. Starting Flush Journal to Persistent Storage... [ 12.345594] systemd-journald[167]: Received client request to flush runtime j ournal. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Load Kernel Modules. [ 12.474996] urandom_read_iter: 16 callbacks suppressed [ 12.475000] random: systemd: uninitialized urandom read (16 bytes read) Mounting Kernel Configuration File System.[ 12.493049] random: system d-journal: uninitialized urandom read (16 bytes read) .. [ 12.510557] random: systemd: uninitialized urandom read (16 bytes read) Starting Apply Kernel Variables... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started RPC Bind. [ OK ] Started udev Coldplug all Devices. Starting udev Wait for Complete Device Initialization... [ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... Starting udev Kernel Device Manager... [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Create Volatile Files and Directories. [FAILED] Failed to start Network Time Synchronization. See 'systemctl status systemd-timesyncd.service' for details. [ 13.494648] urandom_read_iter: 17 callbacks suppressed [ 13.494652] random: systemd: uninitialized urandom read (16 bytes read) [ OK ] Reached target System Time Set. [ OK ] Reached target System Time Synchronized. Starting Update UTMP about System Boot/Shutdown... [ OK ] Stopped Network Time Synchronization. [FAILED] Failed to start Network Time Synchronization. See 'systemctl status systemd-timesyncd.service' for details. [ OK ] Stopped Network Time Synchronization. [FAILED] Failed to start Network Time Synchronization. See 'systemctl status systemd-timesyncd.service' for details. [ OK ] Stopped Network Time Synchronization. [FAILED] Failed to start Network Time Synchronization. See 'systemctl status systemd-timesyncd.service' for details. [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Stopped Network Time Synchronization. [FAILED] Failed to start Network Time Synchronization. See 'systemctl status systemd-timesyncd.service' for details. [ OK ] Stopped Network Time Synchronization. [FAILED] Failed to start Network Time Synchronization. See 'systemctl status systemd-timesyncd.service' for details. [ OK ] Started udev Kernel Device Manager. [ 14.192052] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 14.201495] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 14.214430] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 14.224589] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.238993] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 14.250482] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 14.259465] CAN device driver interface [ 14.263334] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 14.271454] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.282925] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 14.291040] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 14.302418] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 14.310562] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.319699] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 14.330424] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 14.338531] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 14.347979] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.484954] m_can_platform 2701000.can: m_can device registered (irq=42, vers ion=32) [ 14.494627] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 14.502122] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 14.512888] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 14.521044] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.533970] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 14.543275] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 14.554432] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 14.562595] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.575448] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 14.586492] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 14.594591] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 14.602712] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.614970] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 14.623385] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 14.634408] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 14.644214] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.657165] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 14.664671] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 14.682410] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 14.695386] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.711463] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 14.722579] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 14.730530] m_can_platform 2721000.can: m_can device registered (irq=44, vers ion=32) [ 14.734870] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 14.751995] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.766606] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 14.779971] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 14.794759] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 14.809890] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.831972] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 14.840783] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 14.854946] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 14.856044] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision -apps-c66-dma-memory@a9000000 [ 14.869890] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.889758] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 14.897400] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode [ 14.902089] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 14.921452] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 14.936019] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 14.948501] remoteproc remoteproc0: 4d80800000.dsp is available [ 14.955087] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 14.967146] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 14.986417] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 14.998319] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.015053] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 15.034418] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 15.043716] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 15.057909] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.070572] remoteproc remoteproc0: attaching to 4d80800000.dsp [ 15.094702] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode [ 15.130799] remoteproc0#vdev0buffer: assigned reserved memory node vision-ap ps-c66-dma-memory@a9000000 [ 15.160671] virtio_rpmsg_bus virtio0: rpmsg host is online [ 15.166219] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 15.179070] remoteproc0#vdev0buffer: registered virtio0 (type 7) [ 15.185320] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 15.195811] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 15.203906] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 15.214421] remoteproc remoteproc0: remote processor 4d80800000.dsp is now at tached [ 15.218413] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.234968] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 15.243283] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision -apps-c66-dma-memory@a8000000 [ 15.246423] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 15.252961] random: crng init done [ 15.264400] random: 15 urandom warning(s) missed due to ratelimiting [ 15.264632] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 15.280716] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.294654] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 15.302192] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 15.303165] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode [ 15.310294] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 15.327800] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.337042] remoteproc remoteproc1: 4d81800000.dsp is available [ 15.343145] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 15.350658] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 15.358482] remoteproc remoteproc1: attaching to 4d81800000.dsp [ 15.358802] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 15.374443] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.383721] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 15.390510] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode [ 15.391229] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 15.406229] remoteproc1#vdev0buffer: assigned reserved memory node vision-ap ps-c66-dma-memory@a8000000 [ 15.406643] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 15.424646] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.430732] virtio_rpmsg_bus virtio1: rpmsg host is online [ 15.434308] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 15.444313] remoteproc1#vdev0buffer: registered virtio1 (type 7) [ 15.451689] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 15.453093] remoteproc remoteproc1: remote processor 4d81800000.dsp is now at tached [ 15.459203] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 15.467096] platform 41000000.r5f: R5F core may have been powered on by a dif ferent host, programmed state (0) != actual state (1) [ 15.486680] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 15.494389] platform 41000000.r5f: configured R5F for IPC-only mode [ 15.497722] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.501214] platform 41000000.r5f: assigned reserved memory node vision-apps- r5f-dma-memory@a0000000 [ 15.521359] remoteproc remoteproc2: 41000000.r5f is available [ 15.527199] remoteproc remoteproc2: attaching to 41000000.r5f [ 15.533138] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 15.533143] platform 41000000.r5f: R5F core initialized in IPC-only mode [ 15.546419] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 15.547321] remoteproc2#vdev0buffer: assigned reserved memory node vision-ap ps-r5f-dma-memory@a0000000 [ 15.562393] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 15.565079] virtio_rpmsg_bus virtio2: rpmsg host is online [ 15.573580] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-a pps-c71-dma-memory@aa000000 [ 15.578324] remoteproc2#vdev0buffer: registered virtio2 (type 7) [ 15.587782] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.593885] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd [ 15.603103] remoteproc remoteproc2: remote processor 41000000.r5f is now atta ched [ 15.609758] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe [ 15.624242] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 15.634269] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode [ 15.638451] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 15.641220] remoteproc remoteproc3: 64800000.dsp is available [ 15.654763] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 15.655796] remoteproc remoteproc3: attaching to 64800000.dsp [ 15.668775] remoteproc remoteproc3: unsupported resource 65538 [ 15.670433] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.674705] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode [ 15.689718] platform 5c00000.r5f: configured R5F for IPC-only mode [ 15.696075] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 15.696293] platform 5c00000.r5f: assigned reserved memory node vision-apps-r 5f-dma-memory@a2000000 [ 15.710416] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 15.712891] remoteproc3#vdev0buffer: assigned reserved memory node vision-ap ps-c71-dma-memory@aa000000 [ 15.720738] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 15.739627] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains [ 15.739818] remoteproc remoteproc4: 5c00000.r5f is available [ 15.749706] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.765091] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 15.772678] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 15.773679] virtio_rpmsg_bus virtio3: rpmsg host is online [ 15.780943] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 15.786291] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 15.794350] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.811819] remoteproc remoteproc4: attaching to 5c00000.r5f [ 15.817683] platform 5c00000.r5f: R5F core initialized in IPC-only mode [ 15.824346] remoteproc4#vdev0buffer: assigned reserved memory node vision-ap ps-r5f-dma-memory@a2000000 [ 15.824765] PVR_K: 196: Read BVNC 22.104.208.318 from HW device registers [ 15.833853] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 15.848120] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 15.856225] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 15.862693] virtio_rpmsg_bus virtio4: rpmsg host is online [ 15.864392] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.877653] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 15.884051] remoteproc4#vdev0buffer: registered virtio4 (type 7) [ 15.891325] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 15.898868] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 15.907024] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 15.920416] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.938514] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 15.950002] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 15.966420] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 15.981557] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 15.995779] remoteproc3#vdev0buffer: registered virtio3 (type 7) [ 16.002077] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 16.009619] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 16.022444] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 16.038414] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.050509] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 16.058098] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 16.066218] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 16.074412] remoteproc remoteproc4: remote processor 5c00000.r5f is now attac hed [ 16.081849] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.090313] PVR_K: 196: RGX Device registered with BVNC 22.104.208.318 [ 16.098091] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 16.105866] remoteproc remoteproc3: remote processor 64800000.dsp is now atta ched [ 16.113387] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 16.121580] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 16.129690] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.129831] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0 [ 16.146722] platform 5d00000.r5f: configured R5F for IPC-only mode [ 16.153068] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 16.153091] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 16.153101] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 16.153111] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.161285] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 16.161308] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 16.161317] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 16.161327] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.162567] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 16.162587] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 16.162596] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 16.162605] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.170470] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for in ternal alloc [ 16.219029] platform 5d00000.r5f: assigned reserved memory node vision-apps-r 5f-dma-memory@a4000000 [ 16.280223] img_enc 4200000.video-encoder: encoder registered as /dev/video0 [ 16.282897] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 16.287522] remoteproc remoteproc5: 5d00000.r5f is available [ 16.300931] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 16.309884] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 16.320629] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.331298] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 16.338853] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 16.339597] img_dec 4300000.video-decoder: decoder registered as /dev/video1 [ 16.354085] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 16.370426] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.382626] remoteproc remoteproc5: attaching to 5d00000.r5f [ 16.382659] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 16.399656] platform 5d00000.r5f: R5F core initialized in IPC-only mode [ 16.406435] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 16.410414] remoteproc5#vdev0buffer: assigned reserved memory node vision-ap ps-r5f-dma-memory@a4000000 [ 16.422392] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 16.438444] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.443248] virtio_rpmsg_bus virtio5: rpmsg host is online [ 16.454747] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 16.470453] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 16.482766] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 16.498646] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.514827] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 [ 16.522114] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 16.534983] remoteproc5#vdev0buffer: registered virtio5 (type 7) [ 16.541136] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 16.550429] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 16.566690] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.583283] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd [ 16.590482] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 16.598173] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15 [ 16.606404] remoteproc remoteproc5: remote processor 5d00000.r5f is now attac hed [ 16.608533] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 16.622759] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe [ 16.632108] platform 5e00000.r5f: configured R5F for remoteproc mode [ 16.632161] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 16.646992] platform 5e00000.r5f: assigned reserved memory node vision-apps-r 5f-dma-memory@a6000000 [ 16.648592] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.662866] remoteproc remoteproc6: 5e00000.r5f is available [ 16.664775] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 16.678443] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-f w failed with error -2 [ 16.678961] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 16.690409] remoteproc remoteproc6: powering up 5e00000.r5f [ 16.695596] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 16.709369] platform 5f00000.r5f: configured R5F for remoteproc mode [ 16.710264] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.715763] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-f w failed with error -2 [ 16.724404] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 16.740649] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 16.746427] remoteproc remoteproc6: request_firmware failed: -2 [ 16.748810] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 16.755424] platform 5f00000.r5f: assigned reserved memory node vision-apps-r 5f-dma-memory@a7000000 [ 16.762756] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.780973] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 16.788562] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 16.790498] remoteproc remoteproc7: 5f00000.r5f is available [ 16.796663] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 16.810433] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.818983] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15 [ 16.819556] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-f w failed with error -2 [ 16.826203] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe [ 16.842796] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 [ 16.846405] remoteproc remoteproc7: powering up 5f00000.r5f [ 16.852072] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe [ 16.862419] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-f w failed with error -2 [ 16.863101] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ 16.879994] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ 16.882707] remoteproc remoteproc7: request_firmware failed: -2 [ 16.888282] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ 16.906827] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 16.918061] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 16.933342] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 16.948960] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 16.961811] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 16.971519] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 16.981108] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 16.990612] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 17.006623] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 17.014649] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 17.024594] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 17.033691] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 17.515066] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 17.523823] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 17.537005] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 17.550490] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 17.562526] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 17.570136] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 17.580592] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 17.589639] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 17.600625] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 17.610054] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 17.618764] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 17.634509] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.387771] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 18.397726] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 18.408864] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 18.418711] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.434594] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 18.442159] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 18.451041] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 18.461892] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.476840] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 18.484343] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 18.496855] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 18.505502] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.515450] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 18.526947] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 18.536051] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 18.544470] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.553846] remoteproc remoteproc8: b034000.pru is available [ 18.560296] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 18.562228] remoteproc remoteproc9: b004000.rtu is available [ 18.567806] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 18.576795] remoteproc remoteproc10: b00a000.txpru is available [ 18.581546] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 18.589075] remoteproc remoteproc11: b038000.pru is available [ 18.597294] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.603829] remoteproc remoteproc12: b006000.rtu is available [ 18.611241] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 18.617842] remoteproc remoteproc13: b00c000.txpru is available [ 18.623456] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 18.630481] remoteproc remoteproc14: b134000.pru is available [ 18.637444] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 18.645102] remoteproc remoteproc15: b104000.rtu is available [ 18.651266] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.659028] remoteproc remoteproc16: b10a000.txpru is available [ 18.666748] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 18.672419] remoteproc remoteproc17: b138000.pru is available [ 18.678759] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 18.686570] remoteproc remoteproc18: b106000.rtu is available [ 18.692488] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 18.700175] remoteproc remoteproc19: b10c000.txpru is available [ 18.706320] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.734561] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 18.746434] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 18.762433] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 18.782444] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.795896] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 18.811180] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 18.824425] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 18.840156] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.856849] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 18.870596] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 18.883307] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 18.896261] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 18.910320] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 18.921146] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 18.931911] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 18.945830] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 19.295294] usbcore: registered new interface driver usbfs [ 19.300820] usbcore: registered new interface driver hub [ 19.306167] usbcore: registered new device driver usb [ 19.387590] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [ 19.395747] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 19.403335] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 19.414981] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 19.423123] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 19.447414] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: Starting Start psplash boot splash screen.[ 19.455559] j721e-pcie 291 0000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 .. [ 19.469168] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 19.469180] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 19.486495] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [FAILED] Failed to start Network Time Sync[ 19.494005] j721e-pcie 2920000.pcie : IO 0x4400001000..0x4400010fff -> 0x0000001000 hronization. [ 19.494015] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 19.494024] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 19.495092] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: See 'systemctl status systemd-timesyncd.service' for details. [ 19.533654] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 19.547080] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 19.555178] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star…progress communication helper. [ OK ] Created slice system-systemd\x2dfsck.slice. [ OK ] Found device /dev/mmcblk0p2. Starting File System Check on /dev/mmcblk0p2... [ OK ] Found device /dev/mmcblk0p1. Starting File System Check on /dev/mmcblk0p1... [ OK ] Started File System Check on /dev/mmcblk0p1. Mounting /run/media/mmcblk0p1... [ OK ] Mounted /run/media/mmcblk0p1. [ 20.661466] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 20.668987] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 20.681743] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 20.689868] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 20.698751] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 20.706330] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 20.714417] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 20.722502] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 20.731792] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 20.739297] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 20.747395] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 20.755486] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 20.764531] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 20.772029] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 20.780120] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 20.788205] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 21.167444] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 21.172956] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus nu mber 1 [ 21.180701] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010 [ 21.190117] xhci-hcd xhci-hcd.2.auto: irq 644, io mem 0x06410000 [ 21.196305] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc dDevice= 5.10 [ 21.204562] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 21.211773] usb usb1: Product: xHCI Host Controller [ 21.216654] usb usb1: Manufacturer: Linux 5.10.120-g95b90aa828 xhci-hcd [ 21.223257] usb usb1: SerialNumber: xhci-hcd.2.auto [ 21.228407] hub 1-0:1.0: USB hub found [ 21.232189] hub 1-0:1.0: 1 port detected [ 21.236426] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 21.242045] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 21.242588] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus nu mber 2 [ 21.249535] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 21.257661] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 21.265290] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 21.272289] usb usb2: We don't know the algorithms for LPM for this host, dis abling LPM. [ 21.279868] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 21.288412] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc dDevice= 5.10 [ 21.304534] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber= 1 [ 21.304563] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 21.311751] usb usb2: Product: xHCI Host Controller [ 21.319797] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 21.324100] usb usb2: Manufacturer: Linux 5.10.120-g95b90aa828 xhci-hcd [ 21.332521] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 21.339421] usb usb2: SerialNumber: xhci-hcd.2.auto [ 21.347314] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 21.352286] hub 2-0:1.0: USB hub found [ 21.363882] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 21.363937] hub 2-0:1.0: 1 port detected [ 21.372078] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 21.383861] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 21.392361] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 21.402545] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 21.411846] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 21.421398] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 21.430071] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ OK ] Started File System Check on /dev/m[ 21.439641] j721e-pcie 2900000.pc ie: host bridge /bus@100000/pcie@2900000 ranges: mcblk0p2. [ 21.451579] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 Mounting /run/media/mmcblk0p2...[ 21.468702] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 21.478920] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 21.488709] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 21.496676] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 21.505267] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 21.513486] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 21.514359] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O pts: (null) [ 21.526397] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ OK ] Mounted /run/media/mmcblk0p2. [ 21.682702] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcd Device= 1.00 [ 21.690872] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1 [ 21.697998] usb 1-1: SerialNumber: 96070871A7A1 [ 21.703039] hub 1-1:1.0: USB hub found [ 21.706827] hub 1-1:1.0: 4 ports detected [ 21.711982] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ran ges: [ 21.719525] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0 x0000001000 [ 21.727628] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0 x0000011000 [ 21.735735] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 21.745200] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ran ges: [ 21.752730] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0 x0010001000 [ 21.760849] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0 x0010011000 [ 21.770648] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 21.779832] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ran ges: [ 21.787369] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0 x0018001000 [ 21.795463] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0 x0018011000 [ 21.803562] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ OK ] Found device /dev/mmcblk1p1. [ OK ] Started udev Wait for Complete Device Initialization. [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Reached target System Initialization. [ OK ] Started Daily rotation of log files. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API. [ OK ] Listening on dropbear.socket. Starting Reboot and dump vmcore via kexec... Starting File System Check on /dev/mmcblk1p1... [ OK ] Listening on Docker Socket for the API. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. Starting Save/Restore Sound Card State... [ OK ] Started Job spooling tools. [ OK ] Started Periodic Command Scheduler. [ OK ] Started D-Bus System Message Bus. Starting Print notice about GPLv3 packages... Starting set host name as per compatible name... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting Telephony service... Starting Update pmic regis…fety feature on power rails... Starting rc.pvr.service... Starting startwlanap... Starting startwlansta... [ OK ] Started TEE Supplicant. Starting Update weston ini… based on the platform name... [ OK ] Started Reboot and dump vmcore via kexec. E/TC:1 0 std_entry_with_parg:234 Bad arg address 0x8ab15f000 [ OK ] Started File System Check on /dev/mmcblk1p1. [ OK ] Started Save/Restore Sound Card State. [ OK ] Started set host name as per compatible name. [ OK ] Started IPv6 Packet Filtering Framework. [ OK ] Started IPv4 Packet Filtering Framework. [ OK ] Started Update pmic regist…safety feature on power rails. [ OK ] Started rc.pvr.service. [ OK ] Started startwlanap. [ OK ] Started startwlansta. [ OK ] Started Update weston ini …ge based on the platform name. [ OK ] Started Telephony service. [ OK ] Reached target Network (Pre). [ OK ] Reached target Sound Card. Mounting /run/media/mmcblk1p1... Starting Network Service... Starting weston.service... [ OK ] Started weston.service. Starting DEMO... Starting telnetd.service... [ OK ] Started telnetd.service. [ OK ] Started DEMO. [ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch. [ 28.252629] Bluetooth: Core ver 2.22 [ 28.262434] NET: Registered protocol family 31 [ 28.266939] Bluetooth: HCI device and connection manager initialized [ 28.273297] Bluetooth: HCI socket layer initialized [ 28.286378] Bluetooth: L2CAP socket layer initialized [ 28.291484] Bluetooth: SCO socket layer initialized [ OK ] Started Network Service. Starting Wait for Network to be Configured... [FAILED] Failed to start Network Name Resolution. See 'systemctl status systemd-resolved.service' for details. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... Starting Enable and configure wl18xx bluetooth stack... [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Simple Network Ma…ent Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Stopped Network Name Resolution. [FAILED] Failed to start Network Name Resolution. See 'systemctl status systemd-resolved.service' for details. [ OK ] Started Enable and configure wl18xx bluetooth stack. [ OK ] Stopped Network Name Resolution. [FAILED] Failed to start Network Name Resolution. See 'systemctl status systemd-resolved.service' for details. [ OK ] Stopped Network Name Resolution. [FAILED] Failed to start Network Name Resolution. See 'systemctl status systemd-resolved.service' for details. [ OK ] Stopped Network Name Resolution. [FAILED] Failed to start Network Name Resolution. See 'systemctl status systemd-resolved.service' for details. [ OK ] Stopped Network Name Resolution. [FAILED] Failed to start Network Name Resolution. See 'systemctl status systemd-resolved.service' for details. [ OK ] Started Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Started Serial Getty on ttyS3. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ OK ] Mounted /run/media/mmcblk1p1. [ OK ] Started Avahi mDNS/DNS-SD Stack. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project j7-evm ttyS2 Arago 2021.09 j7-evm ttyS2 j7-evm login: *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gstreamer1.0-libav-dev gstreamer1.0-libav gzip less libasm1 libbfd libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp-dev libgmp10 libgmpxx4 libidn2-0 libidn2-dev libmpc3 libmpfr6 libreadline-dev libreadline8 libunistring-dev libunistring2 m4-dev m4 make nettle-dev nettle parted python3-rfc3987 python3-strict-rfc3339 tar which zeromq If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well ``` * `source /opt/vision_apps/vision_apps_init.sh` log ```shell root@j7-evm:~# [MCU2_0] 3.632855 s: CIO: Init ... Done !!! [MCU2_0] 3.632924 s: ### CPU Frequency = 1000000000 Hz [MCU2_0] 3.632965 s: APP: Init ... !!! [MCU2_0] 3.632989 s: SCICLIENT: Init ... !!! [MCU2_0] 3.633238 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [MCU2_0] 3.633286 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_0] 3.633317 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 3.633351 s: SCICLIENT: Init ... Done !!! [MCU2_0] 3.633377 s: UDMA: Init ... !!! [MCU2_0] 3.634768 s: UDMA: Init ... Done !!! [MCU2_0] 3.634831 s: MEM: Init ... !!! [MCU2_0] 3.634874 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!! [MCU2_0] 3.634948 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!! [MCU2_0] 3.635009 s: MEM: Init ... Done !!! [MCU2_0] 3.635035 s: IPC: Init ... !!! [MCU2_0] 3.635097 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 3.635144 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 24.270730 s: IPC: HLOS is ready !!! [MCU2_0] 24.286157 s: IPC: Init ... Done !!! [MCU2_0] 24.286224 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 24.866830 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 24.867058 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 24.868740 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 24.868801 s: [HHW]ETHFW: Init ... !!! [MCU2_0] 24.873799 s: [HHW]appEthFwInit-init pin [MCU2_0] 24.873862 s: FVID2: Init ... !!! [MCU2_0] 24.874014 s: FVID2: Init ... Done !!! [MCU2_0] 24.874077 s: DSS: Init ... !!! [MCU2_0] 24.874108 s: DSS: Display type is eDP !!! [MCU2_0] 24.874135 s: DSS: M2M Path is enabled !!! [MCU2_0] 24.874162 s: DSS: SoC init ... !!! [MCU2_0] 24.874188 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2 [MCU2_0] 24.874473 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.874513 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2 [MCU2_0] 24.874771 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.874812 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2 [MCU2_0] 24.875061 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.875096 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11 [MCU2_0] 24.875319 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 24.875358 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18 [MCU2_0] 24.875552 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 24.875593 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2 [MCU2_0] 24.875748 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 24.875786 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000 [MCU2_0] 24.876885 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success [MCU2_0] 24.876925 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0 [MCU2_0] 24.877184 s: SCICLIENT: Sciclient_pmModuleClkRequest success [MCU2_0] 24.877219 s: DSS: SoC init ... Done !!! [MCU2_0] 24.877245 s: DSS: Board init ... !!! [MCU2_0] 24.877270 s: DSS: Board init ... Done !!! [MCU2_0] 24.911374 s: DSS: Init ... Done !!! [MCU2_0] 24.911443 s: VHWA: VPAC Init ... !!! [MCU2_0] 24.911476 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 24.911704 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.911750 s: VHWA: LDC Init ... !!! [MCU2_0] 24.915242 s: VHWA: LDC Init ... Done !!! [MCU2_0] 24.915306 s: VHWA: MSC Init ... !!! [MCU2_0] 24.927258 s: VHWA: MSC Init ... Done !!! [MCU2_0] 24.927352 s: VHWA: NF Init ... !!! [MCU2_0] 24.929186 s: VHWA: NF Init ... Done !!! [MCU2_0] 24.929244 s: VHWA: VISS Init ... !!! [MCU2_0] 24.940104 s: VHWA: VISS Init ... Done !!! [MCU2_0] 24.940167 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 24.940212 s: VX_ZONE_INIT:Enabled [MCU2_0] 24.940244 s: VX_ZONE_ERROR:Enabled [MCU2_0] 24.940270 s: VX_ZONE_WARNING:Enabled [MCU2_0] 24.941469 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU2-0 [MCU2_0] 24.941738 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_NF [MCU2_0] 24.941961 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_LDC1 [MCU2_0] 24.942174 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_MSC1 [MCU2_0] 24.942385 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_MSC2 [MCU2_0] 24.942688 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_VISS1 [MCU2_0] 24.942941 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE1 [MCU2_0] 24.943202 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE2 [MCU2_0] 24.943469 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DISPLAY1 [MCU2_0] 24.943752 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DISPLAY2 [MCU2_0] 24.944073 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CSITX [MCU2_0] 24.944372 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE3 [MCU2_0] 24.944652 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE4 [MCU2_0] 24.944918 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE5 [MCU2_0] 24.945189 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE6 [MCU2_0] 24.945451 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE7 [MCU2_0] 24.945729 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE8 [MCU2_0] 24.945984 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M1 [MCU2_0] 24.946231 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M2 [MCU2_0] 24.946476 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M3 [MCU2_0] 24.946731 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M4 [MCU2_0] 24.946791 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [MCU2_0] 24.946827 s: APP: OpenVX Target kernel init ... !!! [MCU2_0] 24.969162 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_0] 24.969220 s: CSI2RX: Init ... !!! [MCU2_0] 24.969246 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 24.969394 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.969433 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2 [MCU2_0] 24.969604 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.969647 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2 [MCU2_0] 24.969805 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.969840 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2 [MCU2_0] 24.969943 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.969976 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2 [MCU2_0] 24.970068 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.970815 s: CSI2RX: Init ... Done !!! [MCU2_0] 24.970873 s: CSI2TX: Init ... !!! [MCU2_0] 24.970900 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 24.971020 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.971058 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2 [MCU2_0] 24.971213 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.971247 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2 [MCU2_0] 24.971391 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 24.971997 s: CSI2TX: Init ... Done !!! [MCU2_0] 24.972048 s: ISS: Init ... !!! [MCU2_0] 24.972086 s: IssSensor_Init ... Done !!! [MCU2_0] 24.972164 s: IttRemoteServer_Init ... Done !!! [MCU2_0] 24.972204 s: VISS REMOTE SERVICE: Init ... !!! [MCU2_0] 24.972271 s: VISS REMOTE SERVICE: Init ... Done !!! [MCU2_0] 24.972306 s: UDMA Copy: Init ... !!! [MCU2_0] 24.974118 s: UDMA Copy: Init ... Done !!! [MCU2_0] 24.974220 s: APP: Init ... Done !!! [MCU2_0] 24.974253 s: APP: Run ... !!! [MCU2_0] 24.974279 s: IPC: Starting echo test ... [MCU2_0] 24.977249 s: APP: Run ... Done !!! [MCU2_0] 24.978790 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 24.978914 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 24.979018 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_0] 24.979118 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 3.734364 s: CIO: Init ... Done !!! [MCU2_1] 3.734433 s: ### CPU Frequency = 1000000000 Hz [MCU2_1] 3.734475 s: APP: Init ... !!! [MCU2_1] 3.734501 s: SCICLIENT: Init ... !!! [MCU2_1] 3.734765 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [MCU2_1] 3.734812 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_1] 3.734846 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 3.734883 s: SCICLIENT: Init ... Done !!! [MCU2_1] 3.734926 s: UDMA: Init ... !!! [MCU2_1] 3.736350 s: UDMA: Init ... Done !!! [MCU2_1] 3.736409 s: MEM: Init ... !!! [MCU2_1] 3.736453 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!! [MCU2_1] 3.736529 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!! [MCU2_1] 3.736591 s: MEM: Init ... Done !!! [MCU2_1] 3.736619 s: IPC: Init ... !!! [MCU2_1] 3.736683 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 3.736739 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 24.851293 s: IPC: HLOS is ready !!! [MCU2_1] 24.866712 s: IPC: Init ... Done !!! [MCU2_1] 24.866778 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 24.866828 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 24.866867 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 24.868743 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 24.868807 s: FVID2: Init ... !!! [MCU2_1] 24.868880 s: FVID2: Init ... Done !!! [MCU2_1] 24.868925 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 24.868955 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 24.869533 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 24.869576 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 24.870028 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 24.870064 s: VHWA: DOF Init ... !!! [MCU2_1] 24.880050 s: VHWA: DOF Init ... Done !!! [MCU2_1] 24.880115 s: VHWA: SDE Init ... !!! [MCU2_1] 24.882764 s: VHWA: SDE Init ... Done !!! [MCU2_1] 24.882822 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 24.882871 s: VX_ZONE_INIT:Enabled [MCU2_1] 24.882913 s: VX_ZONE_ERROR:Enabled [MCU2_1] 24.882946 s: VX_ZONE_WARNING:Enabled [MCU2_1] 24.884145 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DMPAC_SDE [MCU2_1] 24.884398 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DMPAC_DOF [MCU2_1] 24.884638 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU2-1 [MCU2_1] 24.884696 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [MCU2_1] 24.884734 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 24.885042 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 24.885089 s: UDMA Copy: Init ... !!! [MCU2_1] 24.886875 s: UDMA Copy: Init ... Done !!! [MCU2_1] 24.886951 s: APP: Init ... Done !!! [MCU2_1] 24.886984 s: APP: Run ... !!! [MCU2_1] 24.887009 s: IPC: Starting echo test ... [MCU2_1] 24.889672 s: APP: Run ... Done !!! [MCU2_1] 24.890855 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 24.890987 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 24.891091 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 24.978064 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [C6x_1 ] 3.998690 s: CIO: Init ... Done !!! [C6x_1 ] 3.998714 s: ### CPU Frequency = 1350000000 Hz [C6x_1 ] 3.998724 s: APP: Init ... !!! [C6x_1 ] 3.998732 s: SCICLIENT: Init ... !!! [C6x_1 ] 3.998954 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [C6x_1 ] 3.998966 s: SCICLIENT: DMSC FW revision 0x8 [C6x_1 ] 3.998975 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 3.998985 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 3.998994 s: UDMA: Init ... !!! [C6x_1 ] 4.000499 s: UDMA: Init ... Done !!! [C6x_1 ] 4.000519 s: MEM: Init ... !!! [C6x_1 ] 4.000532 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!! [C6x_1 ] 4.000550 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 4.000565 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!! [C6x_1 ] 4.000581 s: MEM: Init ... Done !!! [C6x_1 ] 4.000589 s: IPC: Init ... !!! [C6x_1 ] 4.000608 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 4.000622 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 23.568693 s: IPC: HLOS is ready !!! [C6x_1 ] 23.572416 s: IPC: Init ... Done !!! [C6x_1 ] 23.572442 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 24.866827 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 24.866843 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 24.867491 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 24.867529 s: VX_ZONE_INIT:Enabled [C6x_1 ] 24.867542 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 24.867552 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 24.868330 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C6x_1 ] 24.868345 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 24.868679 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 24.868698 s: UDMA Copy: Init ... !!! [C6x_1 ] 24.872415 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 24.872434 s: APP: Init ... Done !!! [C6x_1 ] 24.872442 s: APP: Run ... !!! [C6x_1 ] 24.872451 s: IPC: Starting echo test ... [C6x_1 ] 24.873630 s: APP: Run ... Done !!! [C6x_1 ] 24.873972 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[.] C7X_1[P] [C6x_1 ] 24.874163 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 24.890206 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 24.977921 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_2 ] 4.184800 s: CIO: Init ... Done !!! [C6x_2 ] 4.184824 s: ### CPU Frequency = 1350000000 Hz [C6x_2 ] 4.184835 s: APP: Init ... !!! [C6x_2 ] 4.184842 s: SCICLIENT: Init ... !!! [C6x_2 ] 4.185053 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [C6x_2 ] 4.185065 s: SCICLIENT: DMSC FW revision 0x8 [C6x_2 ] 4.185074 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 4.185084 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 4.185093 s: UDMA: Init ... !!! [C6x_2 ] 4.186602 s: UDMA: Init ... Done !!! [C6x_2 ] 4.186622 s: MEM: Init ... !!! [C6x_2 ] 4.186635 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!! [C6x_2 ] 4.186653 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 4.186668 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!! [C6x_2 ] 4.186684 s: MEM: Init ... Done !!! [C6x_2 ] 4.186693 s: IPC: Init ... !!! [C6x_2 ] 4.186713 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 4.186728 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 23.838776 s: IPC: HLOS is ready !!! [C6x_2 ] 23.842493 s: IPC: Init ... Done !!! [C6x_2 ] 23.842518 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 24.866827 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 24.866843 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 24.867502 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 24.867538 s: VX_ZONE_INIT:Enabled [C6x_2 ] 24.867552 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 24.867562 s: VX_ZONE_WARNING:Enabled [C6x_2 ] 24.868346 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C6x_2 ] 24.868361 s: APP: OpenVX Target kernel init ... !!! [C6x_2 ] 24.868697 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 24.868717 s: UDMA Copy: Init ... !!! [C6x_2 ] 24.872559 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 24.872580 s: APP: Init ... Done !!! [C6x_2 ] 24.872589 s: APP: Run ... !!! [C6x_2 ] 24.872599 s: IPC: Starting echo test ... [C6x_2 ] 24.873850 s: APP: Run ... Done !!! [C6x_2 ] 24.874172 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 24.874206 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 24.890230 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 24.977948 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 4.529748 s: CIO: Init ... Done !!! [C7x_1 ] 4.529763 s: ### CPU Frequency = 1000000000 Hz [C7x_1 ] 4.529774 s: APP: Init ... !!! [C7x_1 ] 4.529781 s: SCICLIENT: Init ... !!! [C7x_1 ] 4.530008 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [C7x_1 ] 4.530022 s: SCICLIENT: DMSC FW revision 0x8 [C7x_1 ] 4.530032 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 4.530043 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 4.530051 s: UDMA: Init ... !!! [C7x_1 ] 4.531228 s: UDMA: Init ... Done !!! [C7x_1 ] 4.531240 s: MEM: Init ... !!! [C7x_1 ] 4.531250 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!! [C7x_1 ] 4.531271 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 4.531288 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!! [C7x_1 ] 4.531306 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 4.531323 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!! [C7x_1 ] 4.531341 s: MEM: Init ... Done !!! [C7x_1 ] 4.531349 s: IPC: Init ... !!! [C7x_1 ] 4.531363 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 4.531376 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 24.181720 s: IPC: HLOS is ready !!! [C7x_1 ] 24.183723 s: IPC: Init ... Done !!! [C7x_1 ] 24.183737 s: APP: Syncing with 5 CPUs ... !!! [C7x_1 ] 24.866829 s: APP: Syncing with 5 CPUs ... Done !!! [C7x_1 ] 24.866846 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 24.866993 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 24.867015 s: VX_ZONE_INIT:Enabled [C7x_1 ] 24.867025 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 24.867035 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 24.867185 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1 [C7x_1 ] 24.867250 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2 [C7x_1 ] 24.867379 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3 [C7x_1 ] 24.867449 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4 [C7x_1 ] 24.867513 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5 [C7x_1 ] 24.867581 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6 [C7x_1 ] 24.867717 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7 [C7x_1 ] 24.867785 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8 [C7x_1 ] 24.867806 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C7x_1 ] 24.867819 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 24.868001 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 24.868015 s: APP: Init ... Done !!! [C7x_1 ] 24.868024 s: APP: Run ... !!! [C7x_1 ] 24.868032 s: IPC: Starting echo test ... [C7x_1 ] 24.868193 s: APP: Run ... Done !!! [C7x_1 ] 24.873954 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s] [C7x_1 ] 24.874177 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 24.890248 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 24.977992 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] ``` * run `./run_app_tidl.sh` log ```shell APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=4) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 1700.626298 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 1700.626344 s: VX_ZONE_INIT:Enabled 1700.626350 s: VX_ZONE_ERROR:Enabled 1700.626355 s: VX_ZONE_WARNING:Enabled 1700.626906 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! 1700.626956 s: VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!! 1701.119075 s: VX_ZONE_ERROR:[ownContextSendCmd:814] Command ack message returned failure cmd_status: -1 1701.119126 s: VX_ZONE_ERROR:[ownContextSendCmd:850] tivxEventWait() failed. 1701.119134 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode 1701.119140 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core 1701.119146 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel 1701.119154 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl:1:1 ... failed !!! 1701.119168 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed 1701.119174 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed app_tidl: ERROR: Verifying graph ... Failed !!! 1701.119950 s: VX_ZONE_INIT:[tivxHostDeInitLocal:100] De-Initialization Done for HOST !!! [C7x_1 ] 1701.118842 s: VX_ZONE_ERROR:[tivxKernelTIDLCreate:686] Network version - 0x20210723, Expected version - 0x20220823 1701.124307 s: VX_ZONE_INIT:[tivxDeInitLocal:193] De-Initialization Done !!! APP: Deinit ... !!! REMOTE_SERVICE: Deinit ... !!! REMOTE_SERVICE: Deinit ... Done !!! IPC: Deinit ... !!! IPC: DeInit ... Done !!! MEM: Deinit ... !!! DDR_SHARED_MEM: Alloc's: 14 alloc's of 22869351 bytes DDR_SHARED_MEM: Free's : 14 free's of 22869351 bytes DDR_SHARED_MEM: Open's : 0 allocs of 0 bytes DDR_SHARED_MEM: Total size: 536870912 bytes MEM: Deinit ... Done !!! APP: Deinit ... Done !!! ```
