我从事的是 PROCESSOR-SDK-RTOS-J721E 08.05.00.11.
我正在尝试 修改 APP_tidl_od_cam 显示 4个摄像头流的马赛克视图。 摄像机流媒体已通过验证 APP_MULTI_CAM 。 我只是希望能够同时查看所有4个摄像头流。 为此,我修改了 APP_tidl_od_cam App 保留最起码的 区块、并 禁用所有其他功能。 该应用程序构建良好。 不过、我在运行时观察到以下错误。 注意: 日志中会显示一些额外的调试打印内容、用于跟踪和隔离违规代码的位置。
U-Boot SPL 2021.01-g7996ed51f1 (Dec 18 2022 - 07:47:20 +0000) Model: Texas Instruments K3 J721E SoC Board: rev SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar') i2c_write: error waiting for data ACK (status=0x116) read error from device: 41c864bc register: x! Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.7(release):v2.7.0-359-g1309c6c805-dirty NOTICE: BL31: Built : 07:46:16, Dec 18 2022 I/TC: I/TC: OP-TEE version: 3.19.0 (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #1 Sun Dec 18 07:46:21 UTC 2022 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check optee.readthedocs.io/.../porting_guidelines.html I/TC: Primary CPU initializing I/TC: SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar') I/TC: HUK Initialized I/TC: Activated SA2UL device I/TC: Fixing SA2UL firewall owner for GP device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2021.01-g7996ed51f1 (Dec 18 2022 - 07:46:35 +0000) Model: Texas Instruments K3 J721E SoC Board: rev SYSFW ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar') ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 Trying to boot from MMC2 U-Boot 2021.01-g7996ed51f1 (Dec 18 2022 - 07:46:35 +0000) SoC: J721E SR1.0 GP Model: Texas Instruments K3 J721E SoC Board: rev DRAM: 4 GiB Flash: 0 Bytes MMC: sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from FAT... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA00101 cpsw_ver: 0x6BA80100 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000 Unidentified board claims in eeprom header ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 ti_i2c_eeprom_am6_get: Ignoring record id 255 cdns,sierra serdes@5000000: sierra probed Net: eth0: ethernet@46000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 Failed to load 'boot.scr' 483 bytes read in 8 ms (58.6 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 11 ms (0 Bytes/s) Already setup. gpio: pin gpio@22_17 (gpio 281) value is 1 gpio: pin gpio@22_16 (gpio 280) value is 0 k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work k3_r5f_rproc r5f@41400000: Core 2 is already in use. No rproc commands work 1404280 bytes read in 69 ms (19.4 MiB/s) Load Remote Processor 2 with data@addr=0x82000000 1404280 bytes: Success! 302028 bytes read in 24 ms (12 MiB/s) Load Remote Processor 3 with data@addr=0x82000000 302028 bytes: Success! Failed to load '/lib/firmware/j7-main-r5f1_0-fw' Failed to load '/lib/firmware/j7-main-r5f1_1-fw' 1325844 bytes read in 68 ms (18.6 MiB/s) Load Remote Processor 6 with data@addr=0x82000000 1325844 bytes: Success! 1325844 bytes read in 67 ms (18.9 MiB/s) Load Remote Processor 7 with data@addr=0x82000000 1325844 bytes: Success! 12849160 bytes read in 214 ms (57.3 MiB/s) Load Remote Processor 8 with data@addr=0x82000000 12849160 bytes: Success! 18608640 bytes read in 777 ms (22.8 MiB/s) 111990 bytes read in 14 ms (7.6 MiB/s) 11545 bytes read in 11 ms (1 MiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 000000008fee1000, end 000000008fffffff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 5.10.153-g90c3a58fd2 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchai2 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 96 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@ac000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 95 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@b2100000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 192 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4000000, size 8 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000e4800000, size 24 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e4800000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 624 MiB [ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x00000000b7ffffff] [ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff] [ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000e5ffffff] [ 0.000000] node 0: [mem 0x00000000e6000000-0x00000000ffffffff] [ 0.000000] node 0: [mem 0x0000000880000000-0x00000008a6ffffff] [ 0.000000] node 0: [mem 0x00000008a7000000-0x00000008ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff] [ 0.000000] cma: Reserved 400 MiB at 0x00000000e7000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.2 [ 0.000000] percpu: Embedded 22 pages/cpu s50008 r8192 d31912 u90112 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: detected: EL2 vector hardening [ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.000000] CPU features: detected: Spectre-BHB [ 0.000000] CPU features: detected: ARM erratum 1742098 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),1m(ospi.sysfw),256t [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x000000009a800000-0x000000009e800000] (64MB) [ 0.000000] Memory: 1811504K/4194304K available (10880K kernel code, 1148K rwdata, 4212K rodata, 1792K init, 432K bss, 1973200K reserved, 409600K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 960 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8a7800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000008a7030000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008a7040000 [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008421] Console: colour dummy device 80x25 [ 0.012984] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023655] pid_max: default: 32768 minimum: 301 [ 0.028410] LSM: Security Framework initializing [ 0.033167] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.040747] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.049535] rcu: Hierarchical SRCU implementation. [ 0.054587] Platform MSI: msi-controller@1820000 domain created [ 0.060848] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created [ 0.070156] EFI services will not be available. [ 0.074892] smp: Bringing up secondary CPUs ... I/TC: Secondary CPU 1 initializing I/TC: Secondary CPU 1 switching to normal world boot [ 0.088173] Detected PIPT I-cache on CPU1 [ 0.088198] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.088209] GICv3: CPU1: using allocated LPI pending table @0x00000008a7050000 [ 0.088244] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.088301] smp: Brought up 1 node, 2 CPUs [ 0.117646] SMP: Total of 2 processors activated. [ 0.122451] CPU features: detected: 32-bit EL0 Support [ 0.127705] CPU features: detected: CRC32 instructions [ 0.141654] CPU: All CPU(s) started at EL2 [ 0.145850] alternatives: patching kernel code [ 0.150882] devtmpfs: initialized [ 0.160156] KASLR disabled due to lack of seed [ 0.164805] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.174769] futex hash table entries: 512 (order: 3, 32768 bytes, linear) [ 0.187788] pinctrl core: initialized pinctrl subsystem [ 0.193450] DMI not present or invalid. [ 0.197694] NET: Registered protocol family 16 [ 0.202932] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations [ 0.210252] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.218318] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.226613] thermal_sys: Registered thermal governor 'step_wise' [ 0.226615] thermal_sys: Registered thermal governor 'power_allocator' [ 0.233203] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.246837] ASID allocator initialised with 65536 entries [ 0.270591] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.277446] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.284292] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.291138] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.298594] cryptd: max_cpu_qlen set to 1000 [ 0.304672] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected [ 0.313498] vsys_3v3: supplied by evm_12v0 [ 0.317859] vsys_5v0: supplied by evm_12v0 [ 0.322611] iommu: Default domain type: Translated [ 0.327781] SCSI subsystem initialized [ 0.331913] mc: Linux media interface: v0.10 [ 0.336290] videodev: Linux video capture interface: v2.00 [ 0.341927] pps_core: LinuxPPS API ver. 1 registered [ 0.346998] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.356336] PTP clock support registered [ 0.360358] EDAC MC: Ver: 3.0.0 [ 0.364150] FPGA manager framework [ 0.367658] Advanced Linux Sound Architecture Driver Initialized. [ 0.374262] clocksource: Switched to clocksource arch_sys_counter [ 0.380584] VFS: Disk quotas dquot_6.6.0 [ 0.384614] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 0.394211] Carveout Heap: Exported 512 MiB at 0x00000000b8000000 [ 0.400502] NET: Registered protocol family 2 [ 0.405243] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.413829] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 0.422588] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 0.430792] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 0.438605] TCP: Hash tables configured (established 32768 bind 32768) [ 0.445403] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.452295] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 0.459697] NET: Registered protocol family 1 [ 0.464416] RPC: Registered named UNIX socket transport module. [ 0.470473] RPC: Registered udp transport module. [ 0.475287] RPC: Registered tcp transport module. [ 0.480091] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.486674] PCI: CLS 0 bytes, default 64 [ 0.491059] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 0.501462] Initialise system trusted keyrings [ 0.506090] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 0.514304] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.520529] NFS: Registering the id_resolver key type [ 0.525704] Key type id_resolver registered [ 0.529979] Key type id_legacy registered [ 0.534103] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.540952] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 0.548595] 9p: Installing v9fs 9p2000 file system support [ 0.573460] Key type asymmetric registered [ 0.577646] Asymmetric key parser 'x509' registered [ 0.582643] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243) [ 0.590201] io scheduler mq-deadline registered [ 0.594826] io scheduler kyber registered [ 0.600504] pinctrl-single 4301c000.pinctrl: 94 pins, size 376 [ 0.606690] pinctrl-single 11c000.pinctrl: 173 pins, size 692 [ 0.615519] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.621785] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.628130] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.634546] debugfs: Directory '31010000.pat' with parent 'regmap' already present! [ 0.642543] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.648961] debugfs: Directory '31011000.pat' with parent 'regmap' already present! [ 0.656896] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages [ 0.663314] debugfs: Directory '31012000.pat' with parent 'regmap' already present! [ 0.671245] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.677571] debugfs: Directory '31013000.pat' with parent 'regmap' already present! [ 0.685515] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages [ 0.691838] debugfs: Directory '31014000.pat' with parent 'regmap' already present! [ 0.701511] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.709750] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.718035] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq [ 0.725120] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq [ 0.733754] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs [ 0.747050] brd: module loaded [ 0.753547] loop: module loaded [ 0.757377] megasas: 07.714.04.00-rc1 [ 0.763180] tun: Universal TUN/TAP device driver, 1.6 [ 0.768650] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 0.775059] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.781136] sky2: driver version 1.30 [ 0.785511] VFIO - User Level meta-driver version: 0.3 [ 0.791297] i2c /dev entries driver [ 0.795778] sdhci: Secure Digital Host Controller Interface driver [ 0.802101] sdhci: Copyright(c) Pierre Ossman [ 0.806832] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.813225] ledtrig-cpu: registered to indicate activity on CPUs [ 0.819566] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 0.826941] optee: probing for conduit method. [ 0.831496] optee: revision 3.19 (afacf356) [ 0.831629] optee: dynamic shared memory is enabled [ 0.841094] optee: initialized driver [ 0.846283] NET: Registered protocol family 17 [ 0.850895] 9pnet: Installing 9P2000 support [ 0.855293] Key type dns_resolver registered [ 0.859746] Loading compiled-in X.509 certificates [ 0.870004] k3-ringacc 2b800000.ringacc: Failed to get MSI domain [ 0.876361] k3-ringacc 3c000000.ringacc: Failed to get MSI domain [ 0.885567] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar') [ 0.953065] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 0.960883] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 0.967001] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 0.973431] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz [ 0.979906] pca953x 3-0020: supply vcc not found, using dummy regulator [ 0.986724] pca953x 3-0020: using no AI [ 1.015117] pca953x 3-0022: supply vcc not found, using dummy regulator [ 1.021926] pca953x 3-0022: using AI [ 1.026199] gpio-480 (CTRL_PM_I2C_OE): hogged as output/high [ 1.032173] gpio-481 (MCASP/TRACE_MUX_S0): hogged as output/low [ 1.038415] gpio-482 (MCASP/TRACE_MUX_S1): hogged as output/high [ 1.044908] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 1.054502] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz [ 1.060817] pca953x 5-0020: supply vcc not found, using dummy regulator [ 1.067637] pca953x 5-0020: using no AI [ 1.094935] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz [ 1.101056] omap_i2c 2040000.i2c: bus 6 rev0.12 at 100 kHz [ 1.107058] omap_i2c 2050000.i2c: bus 7 rev0.12 at 100 kHz [ 1.113498] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created [ 1.123484] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created [ 1.132298] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created [ 1.142171] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created [ 1.161846] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges: [ 1.169550] j721e-pcie 2900000.pcie: IO 0x0010001000..0x0010010fff -> 0x0010001000 [ 1.177826] j721e-pcie 2900000.pcie: MEM 0x0010011000..0x0017ffffff -> 0x0010011000 [ 1.186102] j721e-pcie 2900000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 2.202441] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00 [ 2.208863] pci_bus 0000:00: root bus resource [bus 00-ff] [ 2.214476] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 2.224167] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 2.231222] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400 [ 2.237361] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 2.247309] pci 0000:00:00.0: supports D1 [ 2.251404] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 2.257292] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit] [ 2.264319] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs) [ 2.276389] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 2.286465] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01 [ 2.293238] pci 0000:00:00.0: BAR 7: assigned [mem 0x10400000-0x113fffff 64bit] [ 2.300711] pci 0000:00:00.0: PCI bridge to [bus 01] [ 2.306016] pcieport 0000:00:00.0: PME: Signaling with IRQ 61 [ 2.312412] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges: [ 2.320080] j721e-pcie 2910000.pcie: IO 0x0018001000..0x0018010fff -> 0x0018001000 [ 2.328356] j721e-pcie 2910000.pcie: MEM 0x0018011000..0x001fffffff -> 0x0018011000 [ 2.336635] j721e-pcie 2910000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 3.347856] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00 [ 3.354274] pci_bus 0001:00: root bus resource [bus 00-ff] [ 3.359881] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff]) [ 3.369749] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff] [ 3.376793] pci 0001:00:00.0: [104c:b00d] type 01 class 0x060400 [ 3.382931] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 3.392861] pci 0001:00:00.0: supports D1 [ 3.396955] pci 0001:00:00.0: PME# supported from D0 D1 D3hot [ 3.404849] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.414916] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01 [ 3.421684] pci 0001:00:00.0: PCI bridge to [bus 01] [ 3.426967] pcieport 0001:00:00.0: PME: Signaling with IRQ 64 [ 3.433347] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges: [ 3.441016] j721e-pcie 2920000.pcie: IO 0x4400001000..0x4400010fff -> 0x0000001000 [ 3.449292] j721e-pcie 2920000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x0000011000 [ 3.457568] j721e-pcie 2920000.pcie: IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000 [ 4.469039] j721e-pcie 2920000.pcie: PCI host bridge to bus 0002:00 [ 4.475459] pci_bus 0002:00: root bus resource [bus 00-ff] [ 4.481064] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff]) [ 4.490311] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff]) [ 4.501087] pci 0002:00:00.0: [104c:b00d] type 01 class 0x060400 [ 4.507225] pci_bus 0002:00: 2-byte config write to 0002:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 4.517155] pci 0002:00:00.0: supports D1 [ 4.521249] pci 0002:00:00.0: PME# supported from D0 D1 D3hot [ 4.529144] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.539219] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01 [ 4.545986] pci 0002:00:00.0: PCI bridge to [bus 01] [ 4.551271] pcieport 0002:00:00.0: PME: Signaling with IRQ 67 [ 4.558142] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 4.568026] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 4.574785] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 4.583863] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 4.594017] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 4.600781] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 4.608783] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250 [ 4.618193] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250 [ 4.626939] printk: console [ttyS2] enabled [ 4.626939] printk: console [ttyS2] enabled [ 4.635376] printk: bootconsole [ns16550a0] disabled [ 4.635376] printk: bootconsole [ns16550a0] disabled [ 4.645850] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250 [ 4.654824] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250 [ 4.664544] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 4.675054] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 4.685206] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 4.695443] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 4.706705] scsi host0: ufshcd [ 4.716191] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode [ 4.728539] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0 [ 4.762266] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 4.764620] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2 [ 4.770820] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867 [ 4.781562] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0 [ 4.789827] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000 [ 4.801048] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 4.813702] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4 [ 4.822454] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 4.829279] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 4.843866] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0 [ 4.846477] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found [ 4.860451] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 4.970062] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 4.971046] mmc1: CQHCI version 5.10 [ 4.986116] vdd_mmc1: supplied by vsys_3v3 [ 4.991270] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 4.998144] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 5.004993] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 5.011838] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 5.014269] mmc1: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit [ 5.025845] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 5.036568] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8) [ 5.047329] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16) [ 5.061647] spi-nor spi7.0: mt35xu512aba (65536 Kbytes) [ 5.066891] 8 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 5.073497] Creating 8 MTD partitions on "47040000.spi.0": [ 5.078969] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 5.084949] 0x000000080000-0x000000280000 : "ospi.tispl" [ 5.090630] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 5.096385] 0x000000680000-0x0000006c0000 : "ospi.env" [ 5.101886] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 5.107560] 0x0000007c0000-0x000000800000 : "ospi.env.backup" [ 5.113498] mmc1: Command Queue Engine enabled [ 5.113706] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 5.117941] mmc1: new HS200 MMC card at address 0001 [ 5.123697] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 5.128594] mmcblk1: mmc1:0001 S0J56X 14.8 GiB [ 5.138709] mmcblk1boot0: mmc1:0001 S0J56X partition 1 31.5 MiB [ 5.144782] mmcblk1boot1: mmc1:0001 S0J56X partition 2 31.5 MiB [ 5.150789] mmcblk1rpmb: mmc1:0001 S0J56X partition 3 4.00 MiB, chardev (237:0) [ 5.160010] spi-nor spi8.0: mt25qu512a (65536 Kbytes) [ 5.166281] davinci-mcasp 2ba0000.mcasp: IRQ common not found [ 5.166804] mmc0: CQHCI version 5.10 [ 5.183190] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present! [ 5.190492] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present! [ 5.198894] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present! [ 5.206205] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present! [ 5.213516] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present! [ 5.220821] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present! [ 5.229242] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 5.252872] ALSA device list: [ 5.255843] No soundcards found. [ 6.238274] mmc0: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit [ 6.246423] Waiting for root device PARTUUID=c0a48dcd-02... [ 8.311887] mmc0: Skipping voltage switch [ 8.487909] mmc0: new high speed SDHC card at address aaaa [ 8.493754] mmcblk0: mmc0:aaaa JULIE 14.8 GiB [ 8.502740] mmcblk0: p1 p2 [ 8.539027] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 8.547138] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 8.563043] devtmpfs: mounted [ 8.566917] Freeing unused kernel memory: 1792K [ 8.571543] Run /sbin/init as init process [ 8.909518] systemd[1]: System time before build time, advancing clock. [ 8.996891] NET: Registered protocol family 10 [ 9.001841] Segment Routing with IPv6 [ 9.036429] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD) [ 9.058172] systemd[1]: Detected architecture arm64. Welcome to Arago 2021.09! [ 9.104901] systemd[1]: Set hostname to <j7-evm>. [ 9.340860] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock �→ /run/docker.sock; please update the uni. [ 9.414952] random: systemd: uninitialized urandom read (16 bytes read) [ 9.421705] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling. [ 9.434031] systemd[1]: (This warning is only shown for the first unit using IP firewalling.) [ 9.444058] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 9.466345] random: systemd: uninitialized urandom read (16 bytes read) [ 9.473672] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 9.494363] random: systemd: uninitialized urandom read (16 bytes read) [ 9.501584] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 9.522472] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ OK ] Started Dispatch Password �…ts to Console Directory Watch. [ 9.546399] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ OK ] Started Forward Password R�…uests to Wall Directory Watch. [ 9.570393] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 9.586327] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ 9.606320] systemd[1]: Reached target Slices. [ OK ] Reached target Slices. [ 9.622325] systemd[1]: Reached target Swap. [ OK ] Reached target Swap. [ 9.648307] systemd[1]: Listening on RPCbind Server Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ 9.670366] systemd[1]: Reached target RPC Port Mapper. [ OK ] Reached target RPC Port Mapper. [ 9.694679] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 9.714474] systemd[1]: Listening on initctl Compatibility Named Pipe. [ OK ] Listening on initctl Compatibility Named Pipe. [ 9.752341] systemd[1]: Condition check resulted in Journal Audit Socket being skipped. [ 9.760705] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 9.782599] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 9.798622] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 9.822535] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ 9.842459] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 9.864626] systemd[1]: Mounting Huge Pages File System... Mounting Huge Pages File System... [ 9.884603] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 9.908563] systemd[1]: Mounting Kernel Debug File System... Mounting Kernel Debug File System... [ 9.931134] systemd[1]: Mounting Temporary Directory (/tmp)... Mounting Temporary Directory (/tmp)... [ 9.948729] systemd[1]: Starting Create list of static device nodes for the current kernel... Starting Create list of st�…odes for the current kernel... [ 9.976486] systemd[1]: Starting Start psplash boot splash screen... Starting Start psplash boot splash screen... [ 10.013984] systemd[1]: Starting RPC Bind... Starting RPC Bind... [ 10.030464] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 10.042394] systemd[1]: Starting Journal Service... Starting Journal Service... [ 10.069439] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 10.092782] systemd[1]: Starting Remount Root and Kernel File Systems... [ 10.099636] cryptodev: loading out-of-tree module taints kernel. Starting Remount Root and Kernel File Systems 10.106579] cryptodev: driver 1.10 loaded. [0m... [ 10.115404] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 10.124525] systemd[1]: Starting udev Coldplug all Devices... Starting udev Coldplug all Devices... [ 10.145129] systemd[1]: Started RPC Bind. [ OK ] Started RPC Bind. [ 10.158629] systemd[1]: Started Journal Service. [ OK ] Started Journal Service. [ OK ] Mounted Huge Pages File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Create list of sta�… nodes for the current kernel. [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star�…progress communication helper. [ OK ] Started Load Kernel Modules. [ OK ] Started Remount Root and Kernel File Systems. Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... Starting Apply Kernel Variables...[ 10.383362] systemd-journald[174]: Received client request to flush runtime journal. Starting Create Static Device Nodes in /dev... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. [ 10.486899] random: systemd: uninitialized urandom read (16 bytes read) [ OK ] Reached target Local File Systems (Pre). [ 10.510568] random: systemd: uninitialized urandom read (16 bytes read) Mounting /media/ram... [ 10.522978] random: systemd-journal: uninitialized urandom read (16 bytes read) Mounting /var/volatile... Starting udev Kernel Device Manager... [ OK ] Started udev Coldplug all Devices. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting udev Wait for Complete Device Initialization... Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Create Volatile Files and Directories. [ OK ] Started udev Kernel Device Manager. Starting Network Time Synchronization... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Set. [ OK ] Reached target System Time Synchronized. [ 10.932713] random: crng init done [ 10.936236] random: 66 urandom warning(s) missed due to ratelimiting [ OK ] Started Load/Save Random Seed. [ 11.030719] ina2xx 4-0040: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.051637] ina2xx 4-0041: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.111190] ina2xx 4-0042: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.132220] ina2xx 4-0043: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.149491] ina2xx 4-0044: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.156981] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm) [ 11.164948] ina2xx 4-0046: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.172789] ina2xx 4-0047: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.180521] ina2xx 4-0048: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.188334] ina2xx 4-0049: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.196079] ina2xx 4-004a: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.203863] ina2xx 4-004b: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.211616] ina2xx 4-004c: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.219404] ina2xx 4-004d: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.227195] ina2xx 4-004e: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.235016] ina2xx 4-004f: power monitor ina226 (Rshunt = 10000 uOhm) [ 11.363158] CAN device driver interface [ 11.434424] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc [ 11.509912] img_enc 4200000.video-encoder: encoder registered as /dev/video1 [ 11.514302] img_dec 4300000.video-decoder: decoder registered as /dev/video0 [ 11.609828] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000 [ 11.629554] k3-dsp-rproc 4d80800000.dsp: configured DSP for IPC-only mode [ 11.722365] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains [ 11.787095] remoteproc remoteproc0: 4d80800000.dsp is available [ 11.820563] PVR_K: 212: Read BVNC 22.104.208.318 from HW device registers [ 11.883005] remoteproc remoteproc0: attaching to 4d80800000.dsp [ 11.945823] PVR_K: 212: RGX Device registered with BVNC 22.104.208.318 [ 11.967903] k3-dsp-rproc 4d80800000.dsp: DSP initialized in IPC-only mode [ 11.992532] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0 [ 12.002962] remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000 [ 12.042983] virtio_rpmsg_bus virtio0: rpmsg host is online [ 12.046763] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd [ 12.066950] remoteproc0#vdev0buffer: registered virtio0 (type 7) [ 12.106322] remoteproc remoteproc0: remote processor 4d80800000.dsp is now attached [ 12.129980] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000 [ 12.167574] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1) [ 12.183498] k3-dsp-rproc 4d81800000.dsp: configured DSP for IPC-only mode [ 12.220324] remoteproc remoteproc1: 4d81800000.dsp is available [ 12.229803] platform 41000000.r5f: configured R5F for IPC-only mode [ 12.266223] remoteproc remoteproc1: attaching to 4d81800000.dsp [ 12.275631] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 12.315865] k3-dsp-rproc 4d81800000.dsp: DSP initialized in IPC-only mode [ 12.351551] remoteproc remoteproc2: 41000000.r5f is available [ 12.380617] remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000 [ 12.405941] remoteproc remoteproc2: attaching to 41000000.r5f [ 12.461961] platform 41000000.r5f: R5F core initialized in IPC-only mode [ 12.476720] virtio_rpmsg_bus virtio1: rpmsg host is online [ 12.480335] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd [ 12.513949] remoteproc1#vdev0buffer: registered virtio1 (type 7) [ 12.530099] remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000 [ 12.557019] remoteproc remoteproc1: remote processor 4d81800000.dsp is now attached [ 12.597278] virtio_rpmsg_bus virtio2: rpmsg host is online [ 12.609966] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd [ 12.620369] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000 [ 12.622400] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe [ 12.637639] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode [ 12.662348] remoteproc2#vdev0buffer: registered virtio2 (type 7) [ 12.662373] remoteproc remoteproc3: 64800000.dsp is available [ 12.684737] remoteproc remoteproc2: remote processor 41000000.r5f is now attached [ 12.705203] remoteproc remoteproc3: attaching to 64800000.dsp [ 12.712309] remoteproc remoteproc3: unsupported resource 65538 [ 12.721028] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode [ 12.728468] remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b2000000 [ 12.741117] platform 5c00000.r5f: configured R5F for IPC-only mode [ 12.744488] virtio_rpmsg_bus virtio3: rpmsg host is online [ 12.752866] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd [ 12.755480] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 12.780507] remoteproc3#vdev0buffer: registered virtio3 (type 7) [ 12.791674] remoteproc remoteproc4: 5c00000.r5f is available [ 12.800120] remoteproc remoteproc3: remote processor 64800000.dsp is now attached [ 12.818442] remoteproc remoteproc4: attaching to 5c00000.r5f [ 12.845843] platform 5c00000.r5f: R5F core initialized in IPC-only mode [ 12.927477] remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000 [ 12.957316] m_can_platform 40528000.can: m_can device registered (irq=23, version=32) [ 12.969535] m_can_platform 40568000.can: m_can device registered (irq=25, version=32) [ 12.984226] m_can_platform 2701000.can: m_can device registered (irq=48, version=32) [ 12.999379] m_can_platform 2721000.can: m_can device registered (irq=50, version=32) [ 13.039382] virtio_rpmsg_bus virtio4: rpmsg host is online [ 13.050311] remoteproc4#vdev0buffer: registered virtio4 (type 7) [ 13.056481] remoteproc remoteproc4: remote processor 5c00000.r5f is now attached [ 13.064465] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd [ 13.075393] platform 5d00000.r5f: configured R5F for IPC-only mode [ 13.081869] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 13.096052] remoteproc remoteproc5: 5d00000.r5f is available [ 13.104783] remoteproc remoteproc5: attaching to 5d00000.r5f [ 13.110765] platform 5d00000.r5f: R5F core initialized in IPC-only mode [ 13.120482] remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000 [ 13.132031] virtio_rpmsg_bus virtio5: rpmsg host is online [ 13.138099] remoteproc5#vdev0buffer: registered virtio5 (type 7) [ 13.144337] remoteproc remoteproc5: remote processor 5d00000.r5f is now attached [ 13.151803] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15 [ 13.159260] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe [ 13.166859] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15 [ 13.175015] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd [ 13.183086] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15 [ 13.190336] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe [ 13.198003] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15 [ 13.205244] platform 5e00000.r5f: configured R5F for remoteproc mode [ 13.211715] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe [ 13.219308] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15 [ 13.226505] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe [ 13.237700] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000 [ 13.255922] remoteproc remoteproc6: 5e00000.r5f is available [ 13.270441] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2 [ 13.280865] remoteproc remoteproc6: powering up 5e00000.r5f [ 13.286509] remoteproc remoteproc6: Direct firmware load for j7-main-r5f1_0-fw failed with error -2 [ 13.295773] platform 5f00000.r5f: configured R5F for remoteproc mode [ 13.302178] remoteproc remoteproc6: request_firmware failed: -2 [ 13.308151] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e [ 13.316278] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a [ 13.324289] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2 [ 13.337660] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 17/Mar/2023 SHA: [ 13.348103] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 2 [ 13.359400] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 17/Mar/2023 SHA: [ 13.370166] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000 [ 13.390256] remoteproc remoteproc7: 5f00000.r5f is available [ 13.396480] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2 [ 13.405580] remoteproc remoteproc7: powering up 5f00000.r5f [ 13.412090] remoteproc remoteproc7: Direct firmware load for j7-main-r5f1_1-fw failed with error -2 [ 13.423105] remoteproc remoteproc7: request_firmware failed: -2 [ 13.451678] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe [ 13.462621] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:172 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only0 [ 13.499151] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded [ 13.508895] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00 mac_only:0 [ 13.530314] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1 [ 13.544280] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:173 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only1 [ OK ] Created slice system-systemd\x2dfsck.slice. [ 13.575396] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded [ 13.585319] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:173 tx_psil_dst_id:4A01 mac_only:1 [ 13.606316] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2 [ 14.039509] usbcore: registered new interface driver usbfs [ 14.051391] remoteproc remoteproc8: b034000.pru is available [ 14.067122] remoteproc remoteproc9: b004000.rtu is available [ 14.073854] remoteproc remoteproc10: b00a000.txpru is available [ 14.084607] remoteproc remoteproc11: b038000.pru is available [ 14.093097] remoteproc remoteproc12: b006000.rtu is available [ 14.103615] usbcore: registered new interface driver hub [ 14.103783] remoteproc remoteproc13: b00c000.txpru is available [ 14.116900] remoteproc remoteproc14: b134000.pru is available [ 14.125063] remoteproc remoteproc15: b104000.rtu is available [ 14.133333] remoteproc remoteproc16: b10a000.txpru is available [ 14.142560] remoteproc remoteproc17: b138000.pru is available [ 14.149080] remoteproc remoteproc18: b106000.rtu is available [ 14.158521] remoteproc remoteproc19: b10c000.txpru is available [ 14.191001] usbcore: registered new device driver usb [ OK ] Found device /dev/mmcblk0p1. Starting File System Check on /dev/mmcblk0p1... [ 14.268529] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c [ OK ] Started File System Check on /dev/mmcblk0p1. Mounting /run/media/mmcblk0p1... Starting Start psplash boot splash screen... [FAILED] Failed to start Start psplash boot splash screen. See 'systemctl status psplash-start.service' for details. [DEPEND] Dependency failed for Star�…progress communication helper. [ OK ] Mounted /run/media/mmcblk0p1. [ 15.038999] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 15.044680] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 15.052443] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010 [ 15.061866] xhci-hcd xhci-hcd.2.auto: irq 663, io mem 0x06410000 [ 15.068056] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 15.076316] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 15.083531] usb usb1: Product: xHCI Host Controller [ 15.088400] usb usb1: Manufacturer: Linux 5.10.153-g90c3a58fd2 xhci-hcd [ 15.096598] usb usb1: SerialNumber: xhci-hcd.2.auto [ 15.101741] hub 1-0:1.0: USB hub found [ 15.105521] hub 1-0:1.0: 1 port detected [ 15.110365] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 15.115853] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 15.123503] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 15.130065] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 15.138198] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 15.146450] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 15.153660] usb usb2: Product: xHCI Host Controller [ 15.158535] usb usb2: Manufacturer: Linux 5.10.153-g90c3a58fd2 xhci-hcd [ 15.165136] usb usb2: SerialNumber: xhci-hcd.2.auto [ 15.170247] hub 2-0:1.0: USB hub found [ 15.174010] hub 2-0:1.0: 1 port detected [ 15.366277] usb 1-1: new high-speed USB device number 2 using xhci-hcd [ 15.518542] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00 [ 15.526707] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1 [ 15.533832] usb 1-1: SerialNumber: 1E060069E165 [ 15.539107] hub 1-1:1.0: USB hub found [ 15.542891] hub 1-1:1.0: 4 ports detected [ OK ] Started udev Wait for Complete Device Initialization. [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Reached target System Initialization. [ OK ] Started Daily rotation of log files. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on D-Bus System Message Bus Socket. Starting Docker Socket for the API. [ OK ] Listening on dropbear.socket. Starting Reboot and dump vmcore via kexec... [ OK ] Listening on Docker Socket for the API. [ OK ] Started Reboot and dump vmcore via kexec. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. Starting Save/Restore Sound Card State... [ OK ] Started Job spooling tools. [ OK ] Started Periodic Command Scheduler. [ OK ] Started D-Bus System Message Bus. Starting Print notice about GPLv3 packages... Starting set host name as per compatible name... Starting IPv6 Packet Filtering Framework... Starting IPv4 Packet Filtering Framework... [ OK ] Started irqbalance daemon. Starting Telephony service... Starting Update pmic regis�…fety feature on power rails... Starting rc.pvr.service... Starting startwlanap... Starting startwlansta... Starting Login Service... [ OK ] Started TEE Supplicant. Starting Update weston ini�… based on the platform name... [ OK ] Started Save/Restore Sound Card State. [ OK ] Started Update pmic regist�…safety feature on power rails. [ OK ] Started startwlansta. [ OK ] Reached target Sound Card. [ OK ] Started set host name as per compatible name. [ OK ] Started IPv6 Packet Filtering Framework. [ OK ] Started IPv4 Packet Filtering Framework. [ OK ] Started startwlanap. [ OK ] Started Update weston ini �…ge based on the platform name. [ OK ] Started Telephony service. [ OK ] Reached target Network (Pre). Starting Network Service... [ 16.337242] Bluetooth: Core ver 2.22 [ OK ] Listening on Load/Save RF �…itch S[ 16.346580] NET: Registered protocol family 31 tatus /dev/rfkill Watch. [ 16.366306] Bluetooth: HCI device and connection manager initialized [ 16.378389] Bluetooth: HCI socket layer initialized [ 16.384695] Bluetooth: L2CAP socket layer initialized [ 16.394303] Bluetooth: SCO socket layer initialized [ OK ] Started Login Service. [ OK ] Started Network Service. Starting Wait for Network to be Configured... Starting Network Name Resolution... [ OK ] Started rc.pvr.service. Starting weston.service... [ 16.541835] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started [ OK ] Started weston.service. Starting DEMO... Starting telnetd.service... [ 16.588182] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started [ OK ] Started DEMO. [ OK ] Started telnetd.service. [ 16.663566] am65-cpsw-nuss 46000000.ethernet: down msc_sl f0000000 tmo 0 [ 16.691922] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 16.709360] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL) [ 16.722323] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode [ OK ] Started Network Name Resolution. [ OK ] Reached target Network. [ OK ] Reached target Host and Network Name Lookups. Starting Avahi mDNS/DNS-SD Stack... Starting Enable and configure wl18xx bluetooth stack... [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Simple Network Ma�…ent Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Started Permit User Sessions. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS2. [ OK ] Started Serial Getty on ttyS3. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [ OK ] Started Enable and configure wl18xx bluetooth stack. [ OK ] Started Avahi mDNS/DNS-SD Stack. [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ 17.013428] PVR_K: 996: RGX Firmware image 'rgx.fw.22.104.208.318' loaded [ 17.050896] PVR_K: 996: Shader binary image 'rgx.sh.22.104.208.318' loaded [ OK ] Started Simple Network Man�…ement Protocol (SNMP) Daemon.. *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash bc binutils cifs-utils coreutils-stdbuf coreutils cpio cpp-symlinks cpp dosfstools elfutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gstreamer1.0-libav-dev gstreamer1.0-libav gzip less libasm1 libbfd libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp-dev libgmp10 libgmpxx4 libidn2-0 libidn2-dev libmpc3 libmpfr6 libreadline-dev libreadline8 libunistring-dev libunistring2 m4-dev m4 make nettle-dev nettle parted python3-rfc3987 python3-strict-rfc3339 tar which zeromq If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Started Print notice about GPLv3 packages. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project j7-evm ttyS2 Arago 2021.09 j7-evm ttyS2 j7-evm login: root root@j7-evm:~# cd /opt/vision_apps/ root@j7-evm:/opt/vision_apps# source ./vision_apps_init.sh root@j7-evm:/opt/vision_apps# [MCU2_0] 4.409414 s: CIO: Init ... Done !!! [MCU2_0] 4.409487 s: ### CPU Frequency = 1000000000 Hz [MCU2_0] 4.409531 s: CPU is running FreeRTOS [MCU2_0] 4.409560 s: APP: Init ... !!! [MCU2_0] 4.409584 s: SCICLIENT: Init ... !!! [MCU2_0] 4.409859 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar] [MCU2_0] 4.409910 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_0] 4.409945 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 4.409981 s: SCICLIENT: Init ... Done !!! [MCU2_0] 4.410008 s: UDMA: Init ... !!! [MCU2_0] 4.411549 s: UDMA: Init ... Done !!! [MCU2_0] 4.411616 s: MEM: Init ... !!! [MCU2_0] 4.411661 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!! [MCU2_0] 4.411738 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!! [MCU2_0] 4.411800 s: MEM: Init ... Done !!! [MCU2_0] 4.411825 s: IPC: Init ... !!! [MCU2_0] 4.411887 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 4.411937 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 19.784560 s: IPC: HLOS is ready !!! [MCU2_0] 19.800100 s: IPC: Init ... Done !!! [MCU2_0] 19.800168 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 19.892767 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 19.892991 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 19.894522 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 19.894590 s: ETHFW: Init ... !!! [MCU2_0] 20.002700 s: Warning: Using 6 MAC address(es) from static pool [MCU2_0] 20.002815 s: ETHFW: Shared multicasts (software fanout): [MCU2_0] 20.002860 s: 01:00:5e:00:00:01 [MCU2_0] 20.002908 s: 01:00:5e:00:00:fb [MCU2_0] 20.002954 s: 01:00:5e:00:00:fc [MCU2_0] 20.002998 s: 33:33:00:00:00:01 [MCU2_0] 20.003043 s: 33:33:ff:1d:92:c2 [MCU2_0] 20.003101 s: 01:80:c2:00:00:00 [MCU2_0] 20.003152 s: 01:80:c2:00:00:03 [MCU2_0] 20.003200 s: ETHFW: Reserved multicasts: [MCU2_0] 20.003226 s: 01:80:c2:00:00:0e [MCU2_0] 20.003273 s: 01:1b:19:00:00:00 [MCU2_0] 20.003517 s: EnetMcm: CPSW_9G on MAIN NAVSS [MCU2_0] 20.011849 s: Mdio_open: MDIO manual mode enabled [MCU2_0] 20.015558 s: PHY 16 is alive [MCU2_0] 20.015705 s: PHY 17 is alive [MCU2_0] 20.015814 s: PHY 18 is alive [MCU2_0] 20.015913 s: PHY 19 is alive [MCU2_0] 20.017718 s: EnetPhy_bindDriver: PHY 16: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK [MCU2_0] 20.018228 s: EnetPhy_bindDriver: PHY 17: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK [MCU2_0] 20.018720 s: EnetPhy_bindDriver: PHY 18: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK [MCU2_0] 20.019217 s: EnetPhy_bindDriver: PHY 19: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK [MCU2_0] 20.020960 s: [MCU2_0] ETHFW Version : 0.02.00 [MCU2_0] 20.021031 s: ETHFW Build Date: Mar 17, 2023 [MCU2_0] 20.021066 s: ETHFW Build Time: 19:53:07 [MCU2_0] 20.021103 s: ETHFW Commit SHA: [MCU2_0] 20.021175 s: ETHFW: Init ... DONE !!! [MCU2_0] 20.021210 s: ETHFW: Remove server Init ... !!! [MCU2_0] 20.021384 s: CpswProxyServer: Virtual port configuration: [MCU2_0] 20.021440 s: mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0 [MCU2_0] 20.021488 s: mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1 [MCU2_0] 20.021532 s: mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1 [MCU2_0] 20.021574 s: mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4 [MCU2_0] 20.022586 s: CpswProxyServer: initialization completed (core: mcu2_0) [MCU2_0] 20.022648 s: ETHFW: Remove server Init ... DONE !!! [MCU2_0] 20.023809 s: Starting lwIP, local interface IP is dhcp-enabled [MCU2_0] 20.030889 s: Host MAC address: 70:ff:76:1d:92:c3 [MCU2_0] 20.035305 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully [MCU2_0] 20.065825 s: [LWIPIF_LWIP_IC] Interface started successfully [MCU2_0] 20.065897 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS [MCU2_0] 20.077109 s: FVID2: Init ... !!! [MCU2_0] 20.077219 s: FVID2: Init ... Done !!! [MCU2_0] 20.077273 s: DSS: Init ... !!! [MCU2_0] 20.077302 s: DSS: Display type is eDP !!! [MCU2_0] 20.077330 s: DSS: M2M Path is enabled !!! [MCU2_0] 20.077357 s: DSS: SoC init ... !!! [MCU2_0] 20.077381 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2 [MCU2_0] 20.077616 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.077657 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2 [MCU2_0] 20.077853 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.077887 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2 [MCU2_0] 20.078065 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.078235 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11 [MCU2_0] 20.078406 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 20.078447 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18 [MCU2_0] 20.078582 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 20.078618 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2 [MCU2_0] 20.078732 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 20.078769 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000 [MCU2_0] 20.079980 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success [MCU2_0] 20.080034 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0 [MCU2_0] 20.080303 s: SCICLIENT: Sciclient_pmModuleClkRequest success [MCU2_0] 20.080356 s: DSS: SoC init ... Done !!! [MCU2_0] 20.080387 s: DSS: Board init ... !!! [MCU2_0] 20.080413 s: DSS: Board init ... Done !!! [MCU2_0] 20.115276 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6 [MCU2_0] 20.116547 s: DSS: Init ... Done !!! [MCU2_0] 20.116614 s: VHWA: VPAC Init ... !!! [MCU2_0] 20.116644 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 20.116867 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.116907 s: VHWA: LDC Init ... !!! [MCU2_0] 20.121069 s: VHWA: LDC Init ... Done !!! [MCU2_0] 20.121257 s: VHWA: MSC Init ... !!! [MCU2_0] 20.135476 s: VHWA: MSC Init ... Done !!! [MCU2_0] 20.135543 s: VHWA: NF Init ... !!! [MCU2_0] 20.137642 s: VHWA: NF Init ... Done !!! [MCU2_0] 20.137705 s: VHWA: VISS Init ... !!! [MCU2_0] 20.150432 s: VHWA: VISS Init ... Done !!! [MCU2_0] 20.150498 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 20.150545 s: VX_ZONE_INIT:Enabled [MCU2_0] 20.150576 s: VX_ZONE_ERROR:Enabled [MCU2_0] 20.150603 s: VX_ZONE_WARNING:Enabled [MCU2_0] 20.151979 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-0 [MCU2_0] 20.152413 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_NF [MCU2_0] 20.152676 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_LDC1 [MCU2_0] 20.152907 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC1 [MCU2_0] 20.153342 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_MSC2 [MCU2_0] 20.153652 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target VPAC_VISS1 [MCU2_0] 20.153921 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE1 [MCU2_0] 20.154351 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE2 [MCU2_0] 20.154641 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY1 [MCU2_0] 20.154898 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DISPLAY2 [MCU2_0] 20.155300 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CSITX [MCU2_0] 20.155601 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE3 [MCU2_0] 20.155865 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE4 [MCU2_0] 20.156271 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE5 [MCU2_0] 20.156565 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE6 [MCU2_0] 20.156850 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE7 [MCU2_0] 20.157292 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target CAPTURE8 [MCU2_0] 20.157566 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M1 [MCU2_0] 20.157806 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M2 [MCU2_0] 20.158036 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M3 [MCU2_0] 20.158496 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DSS_M2M4 [MCU2_0] 20.158564 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! [MCU2_0] 20.158604 s: APP: OpenVX Target kernel init ... !!! [MCU2_0] 20.180499 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_0] 20.180568 s: CSI2RX: Init ... !!! [MCU2_0] 20.180597 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 20.180748 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.180790 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2 [MCU2_0] 20.180970 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.181006 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2 [MCU2_0] 20.181228 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.181286 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2 [MCU2_0] 20.181416 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.181455 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2 [MCU2_0] 20.181574 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.181822 s: CSI2RX: Init ... Done !!! [MCU2_0] 20.181861 s: CSI2TX: Init ... !!! [MCU2_0] 20.181887 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 20.181999 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.182035 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2 [MCU2_0] 20.182379 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.182438 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2 [MCU2_0] 20.182592 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 20.182704 s: CSI2TX: Init ... Done !!! [MCU2_0] 20.182745 s: ISS: Init ... !!! [MCU2_0] 20.182778 s: Found sensor IMX390-UB953_D3 at location 0 [MCU2_0] 20.182819 s: Found sensor AR0233-UB953_MARS at location 1 [MCU2_0] 20.182856 s: Found sensor AR0820-UB953_LI at location 2 [MCU2_0] 20.182892 s: Found sensor UB9xxx_RAW12_TESTPATTERN at location 3 [MCU2_0] 20.182930 s: Found sensor UB96x_UYVY_TESTPATTERN at location 4 [MCU2_0] 20.182967 s: Found sensor GW_AR0233_UYVY at location 5 [MCU2_0] 20.183002 s: Found sensor ISX016-UB913 at location 6 [MCU2_0] 20.183046 s: IssSensor_ISX016_Init Success [MCU2_0] 20.183077 s: IssSensor_Init ... Done !!! [MCU2_0] 20.183333 s: IttRemoteServer_Init ... Done !!! [MCU2_0] 20.183378 s: VISS REMOTE SERVICE: Init ... !!! [MCU2_0] 20.183448 s: VISS REMOTE SERVICE: Init ... Done !!! [MCU2_0] 20.183482 s: UDMA Copy: Init ... !!! [MCU2_0] 20.185613 s: UDMA Copy: Init ... Done !!! [MCU2_0] 20.185726 s: APP: Init ... Done !!! [MCU2_0] 20.185768 s: APP: Run ... !!! [MCU2_0] 20.185798 s: IPC: Starting echo test ... [MCU2_0] 20.188815 s: APP: Run ... Done !!! [MCU2_0] 20.195530 s: [LWIPIF_LWIP_IC] Interface started successfully [MCU2_0] 20.195602 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS [MCU2_0] 20.195721 s: Added interface 'br4', IP is 0.0.0.0 [MCU2_0] 20.197762 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 20.197885 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 20.198050 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[P] [MCU2_0] 20.198326 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_0] 20.288938 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6 [MCU2_0] 23.284873 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:173, FlowIdxOffset:1 [MCU2_0] 23.299917 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6,mode:disable [MCU2_0] 23.300395 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6,mode:disable [MCU2_0] 23.301218 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6,mode:disable [MCU2_0] 23.316724 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0 [MCU2_0] 23.319950 s: Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:7, Policer Entry:2 [MCU2_0] 23.379653 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 23.381704 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 23.383774 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 23.499213 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6,mode:disable [MCU2_0] 23.503153 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6,mode:disable [MCU2_0] 23.503522 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6,mode:disable [MCU2_0] 23.527497 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 23.534728 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 23.536914 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 23.537058 s: CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter [MCU2_0] 23.602422 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6,mode:disable [MCU2_0] 23.602596 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 25.139804 s: Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6,mode:disable [MCU2_0] 25.172892 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a3a4ef1c,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_1] 4.358070 s: CIO: Init ... Done !!! [MCU2_1] 4.358141 s: ### CPU Frequency = 1000000000 Hz [MCU2_1] 4.358183 s: CPU is running FreeRTOS [MCU2_1] 4.358209 s: APP: Init ... !!! [MCU2_1] 4.358231 s: SCICLIENT: Init ... !!! [MCU2_1] 4.358499 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar] [MCU2_1] 4.358549 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_1] 4.358599 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 4.358636 s: SCICLIENT: Init ... Done !!! [MCU2_1] 4.358663 s: UDMA: Init ... !!! [MCU2_1] 4.360325 s: UDMA: Init ... Done !!! [MCU2_1] 4.360384 s: MEM: Init ... !!! [MCU2_1] 4.360427 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!! [MCU2_1] 4.360503 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!! [MCU2_1] 4.360563 s: MEM: Init ... Done !!! [MCU2_1] 4.360604 s: IPC: Init ... !!! [MCU2_1] 4.360666 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 4.360715 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 19.877211 s: IPC: HLOS is ready !!! [MCU2_1] 19.892649 s: IPC: Init ... Done !!! [MCU2_1] 19.892715 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 19.892766 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 19.892804 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 19.894533 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 19.894608 s: FVID2: Init ... !!! [MCU2_1] 19.894680 s: FVID2: Init ... Done !!! [MCU2_1] 19.894716 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 19.894744 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 19.895178 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 19.895219 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 19.895702 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 19.895740 s: VHWA: DOF Init ... !!! [MCU2_1] 19.904216 s: VHWA: DOF Init ... Done !!! [MCU2_1] 19.904283 s: VHWA: SDE Init ... !!! [MCU2_1] 19.906983 s: VHWA: SDE Init ... Done !!! [MCU2_1] 19.907044 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 19.907091 s: VX_ZONE_INIT:Enabled [MCU2_1] 19.907120 s: VX_ZONE_ERROR:Enabled [MCU2_1] 19.907148 s: VX_ZONE_WARNING:Enabled [MCU2_1] 19.908348 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target MCU2-1 [MCU2_1] 19.908601 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_SDE [MCU2_1] 19.908830 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:66] Added target DMPAC_DOF [MCU2_1] 19.908886 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! [MCU2_1] 19.908923 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 19.909204 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 19.909249 s: UDMA Copy: Init ... !!! [MCU2_1] 19.911077 s: UDMA Copy: Init ... Done !!! [MCU2_1] 19.911145 s: APP: Init ... Done !!! [MCU2_1] 19.911180 s: APP: Run ... !!! [MCU2_1] 19.911206 s: IPC: Starting echo test ... [MCU2_1] 19.913767 s: APP: Run ... Done !!! [MCU2_1] 19.914969 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 19.915088 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 19.915178 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 20.197694 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [C6x_1 ] 4.419998 s: CIO: Init ... Done !!! [C6x_1 ] 4.420023 s: ### CPU Frequency = 1350000000 Hz [C6x_1 ] 4.420034 s: CPU is running FreeRTOS [C6x_1 ] 4.420041 s: APP: Init ... !!! [C6x_1 ] 4.420049 s: SCICLIENT: Init ... !!! [C6x_1 ] 4.420266 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar] [C6x_1 ] 4.420278 s: SCICLIENT: DMSC FW revision 0x8 [C6x_1 ] 4.420287 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 4.420297 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 4.420306 s: UDMA: Init ... !!! [C6x_1 ] 4.421883 s: UDMA: Init ... Done !!! [C6x_1 ] 4.421903 s: MEM: Init ... !!! [C6x_1 ] 4.421917 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!! [C6x_1 ] 4.421934 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 4.421950 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!! [C6x_1 ] 4.421966 s: MEM: Init ... Done !!! [C6x_1 ] 4.421974 s: IPC: Init ... !!! [C6x_1 ] 4.421994 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 4.422008 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 18.788169 s: IPC: HLOS is ready !!! [C6x_1 ] 18.792113 s: IPC: Init ... Done !!! [C6x_1 ] 18.792140 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 19.892765 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 19.892783 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 19.893422 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 19.893450 s: VX_ZONE_INIT:Enabled [C6x_1 ] 19.893461 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 19.893470 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 19.894231 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! [C6x_1 ] 19.894245 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 19.894505 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 19.894519 s: UDMA Copy: Init ... !!! [C6x_1 ] 19.898231 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 19.898251 s: APP: Init ... Done !!! [C6x_1 ] 19.898260 s: APP: Run ... !!! [C6x_1 ] 19.898268 s: IPC: Starting echo test ... [C6x_1 ] 19.899324 s: APP: Run ... Done !!! [C6x_1 ] 19.899648 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P] [C6x_1 ] 19.900132 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 19.914317 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 20.197556 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_2 ] 4.505105 s: CIO: Init ... Done !!! [C6x_2 ] 4.505131 s: ### CPU Frequency = 1350000000 Hz [C6x_2 ] 4.505142 s: CPU is running FreeRTOS [C6x_2 ] 4.505151 s: APP: Init ... !!! [C6x_2 ] 4.505159 s: SCICLIENT: Init ... !!! [C6x_2 ] 4.505380 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar] [C6x_2 ] 4.505393 s: SCICLIENT: DMSC FW revision 0x8 [C6x_2 ] 4.505403 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 4.505413 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 4.505422 s: UDMA: Init ... !!! [C6x_2 ] 4.507012 s: UDMA: Init ... Done !!! [C6x_2 ] 4.507033 s: MEM: Init ... !!! [C6x_2 ] 4.507047 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!! [C6x_2 ] 4.507065 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 4.507081 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!! [C6x_2 ] 4.507098 s: MEM: Init ... Done !!! [C6x_2 ] 4.507106 s: IPC: Init ... !!! [C6x_2 ] 4.507127 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 4.507142 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 19.221906 s: IPC: HLOS is ready !!! [C6x_2 ] 19.225649 s: IPC: Init ... Done !!! [C6x_2 ] 19.225675 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 19.892765 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 19.892782 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 19.893438 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 19.893468 s: VX_ZONE_INIT:Enabled [C6x_2 ] 19.893480 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 19.893489 s: VX_ZONE_WARNING:Enabled [C6x_2 ] 19.894245 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! [C6x_2 ] 19.894260 s: APP: OpenVX Target kernel init ... !!! [C6x_2 ] 19.894522 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 19.894537 s: UDMA Copy: Init ... !!! [C6x_2 ] 19.898564 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 19.898587 s: APP: Init ... Done !!! [C6x_2 ] 19.898596 s: APP: Run ... !!! [C6x_2 ] 19.898605 s: IPC: Starting echo test ... [C6x_2 ] 19.899744 s: APP: Run ... Done !!! [C6x_2 ] 19.900067 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 19.900125 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 19.914343 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 20.197580 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 4.730530 s: CIO: Init ... Done !!! [C7x_1 ] 4.730544 s: ### CPU Frequency = 1000000000 Hz [C7x_1 ] 4.730555 s: CPU is running FreeRTOS [C7x_1 ] 4.730563 s: APP: Init ... !!! [C7x_1 ] 4.730570 s: SCICLIENT: Init ... !!! [C7x_1 ] 4.730800 s: SCICLIENT: DMSC FW version [8.5.2--v08.05.02 (Chill Capybar] [C7x_1 ] 4.730814 s: SCICLIENT: DMSC FW revision 0x8 [C7x_1 ] 4.730823 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 4.730834 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 4.730842 s: UDMA: Init ... !!! [C7x_1 ] 4.732078 s: UDMA: Init ... Done !!! [C7x_1 ] 4.732090 s: MEM: Init ... !!! [C7x_1 ] 4.732100 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!! [C7x_1 ] 4.732121 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 4.732138 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!! [C7x_1 ] 4.732156 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 4.732172 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!! [C7x_1 ] 4.732191 s: MEM: Init ... Done !!! [C7x_1 ] 4.732199 s: IPC: Init ... !!! [C7x_1 ] 4.732212 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 4.732226 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 19.489668 s: IPC: HLOS is ready !!! [C7x_1 ] 19.491704 s: IPC: Init ... Done !!! [C7x_1 ] 19.491718 s: APP: Syncing with 5 CPUs ... !!! [C7x_1 ] 19.892767 s: APP: Syncing with 5 CPUs ... Done !!! [C7x_1 ] 19.892785 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 19.892931 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 19.892952 s: VX_ZONE_INIT:Enabled [C7x_1 ] 19.892962 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 19.892972 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 19.893111 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1 [C7x_1 ] 19.893174 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2 [C7x_1 ] 19.893270 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3 [C7x_1 ] 19.893361 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4 [C7x_1 ] 19.893436 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5 [C7x_1 ] 19.893501 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6 [C7x_1 ] 19.893608 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7 [C7x_1 ] 19.893672 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8 [C7x_1 ] 19.893694 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! [C7x_1 ] 19.893707 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 19.893845 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 19.893858 s: APP: Init ... Done !!! [C7x_1 ] 19.893867 s: APP: Run ... !!! [C7x_1 ] 19.893875 s: IPC: Starting echo test ... [C7x_1 ] 19.894019 s: APP: Run ... Done !!! [C7x_1 ] 19.899649 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s] [C7x_1 ] 19.900124 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 19.914364 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 20.197623 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] root@j7-evm:/opt/vision_apps# root@j7-evm:/opt/vision_apps# ls app_avp.cfg app_seg.cfg run_app_arm_fd_exchange.sh run_app_tidl_avp2.sh script.exp vx_app_multi_cam_codec.out vx_app_tidl_od_cam.out app_avp2.cfg app_seg_16bit.cfg run_app_c7x.sh run_app_tidl_avp3.sh test_list.txt vx_app_sfm.out vx_app_tidl_seg.out app_avp3.cfg app_seg_cam.cfg run_app_dof.sh run_app_tidl_avp4.sh vision_apps_init.sh vx_app_single_cam.out vx_app_tidl_seg_cam.out app_avp4.cfg app_sfm.cfg run_app_load_test.sh run_app_tidl_cam.sh vx_app_arm_fd_exchange_consumer.out vx_app_srv_calibration.out vx_app_tidl_vl.out app_c7x.cfg app_single_cam.cfg run_app_multi_cam.sh run_app_tidl_od.sh vx_app_arm_fd_exchange_producer.out vx_app_srv_camera.out vx_app_tutorial.out app_dof.cfg app_srv.cfg run_app_multi_cam_codec.sh run_app_tidl_od_cam.sh vx_app_arm_ipc.out vx_app_srv_fileio.out vx_app_viss.out app_encode.cfg app_srv_avp_cfg run_app_sfm.sh run_app_tidl_seg.sh vx_app_arm_mem.out vx_app_stereo_depth.out vx_rci_multi_cam.out app_multi_cam.cfg app_stereo.cfg run_app_single_cam.sh run_app_tidl_seg_16bit.sh vx_app_arm_opengl_mosaic.out vx_app_test_framework.out vx_rci_single_cam.out app_multi_cam_codec.cfg app_stereo_16bit.cfg run_app_srv.sh run_app_tidl_seg_cam.sh vx_app_arm_remote_log.out vx_app_tidl.out vx_rci_tidl_od_cam.out app_oc.cfg app_tidl_cam.cfg run_app_srv_avp.sh run_app_tidl_vl.sh vx_app_c7x_kernel.out vx_app_tidl_avp.out app_oc_16bit.cfg app_vl.cfg run_app_stereo.sh run_app_viss.sh vx_app_conformance.out vx_app_tidl_avp2.out app_od.cfg autorun.sh run_app_stereo_16bit.sh run_ptk_demo.sh vx_app_dense_optical_flow.out vx_app_tidl_avp3.out app_od_cam.cfg rci_multi_cam.cfg run_app_tidl.sh run_rci_multi_cam.sh vx_app_heap_stats.out vx_app_tidl_avp4.out app_pcie_video_sink.cfg rci_od_cam.cfg run_app_tidl_16bit.sh run_rci_single_cam.sh vx_app_load_test.out vx_app_tidl_cam.out app_pcie_video_source.cfg rci_single_cam.cfg run_app_tidl_avp.sh run_rci_tidl_od_cam.sh vx_app_multi_cam.out vx_app_tidl_od.out root@j7-evm:/opt/vision_apps# ./run_rci_tidl_od_cam.sh APP: Init ... !!! MEM: Init ... !!! MEM: Initialized DMA HEAP (fd=4) !!! MEM: Init ... Done !!! IPC: Init ... !!! IPC: Init ... Done !!! REMOTE_SERVICE: Init ... !!! REMOTE_SERVICE: Init ... Done !!! 65.350722 s: GTC Frequency = 200 MHz APP: Init ... Done !!! 65.362370 s: VX_ZONE_INIT:Enabled 65.362403 s: VX_ZONE_ERROR:Enabled 65.362415 s: VX_ZONE_WARNING:Enabled 65.363449 s: VX_ZONE_INIT:[tivxInitLocal:145] Initialization Done !!! 65.364602 s: VX_ZONE_INIT:[tivxHostInitLocal:93] Initialization Done for HOST !!! 65.365482 s: ISS: Enumerating sensors ... !!! [MCU2_0] 65.365758 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_ENUMERATE [MCU2_0] 65.366037 s: write 0xfe to TCA6408 register 0x3 [MCU2_0] 65.466127 s: UB960 config start 68.026664 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3 68.026691 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS 68.026712 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI 68.026717 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN 68.026722 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN 68.026727 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY 68.026732 s: ISS: Enumerating sensors ... found 6 : ISX016-UB913 Sensor index : 6 Sensor selected : ISX016-UB913 Querying ISX016-UB913 68.026759 s: ISS: Querying sensor [ISX016-UB913] ... !!! [MCU2_0] 68.026412 s: End of UB960 config [MCU2_0] 68.026957 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_QUERY [MCU2_0] 68.027019 s: Received Query for ISX016-UB913 68.027286 s: ISS: Querying sensor [ISX016-UB913] ... Done !!! Sensor pixel container is UYVY Sensor mask : 15 Num of cameras enabled : 4 WDR mode is supported Expsoure control is supported Gain control is supported Sensor DCC is enabled Sensor width = 1280 Sensor height = 724 Sensor DCC ID = 160 Sensor Supported Features = 0x00000378 Sensor Enabled Features = 0x00000158 Creating context done! Kernel loading done! 68.050241 s: ISS: Initializing sensor [ISX016-UB913], doing IM_SENSOR_CMD_PWRON ... !!! 68.050888 s: ISS: Initializing sensor [ISX016-UB913], doing IM_SENSOR_CMD_CONFIG ... !!! [MCU2_0] 68.050444 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_PWRON [MCU2_0] 68.050519 s: IM_SENSOR_CMD_PWRON : channel_mask = 0xf [MCU2_0] 68.050595 s: ISX016_PowerOn : chId = 0x0 [MCU2_0] 68.050644 s: ISX016_PowerOn : chId = 0x1 [MCU2_0] 68.050682 s: ISX016_PowerOn : chId = 0x2 [MCU2_0] 68.050722 s: ISX016_PowerOn : chId = 0x3 [MCU2_0] 68.051064 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CONFIG [MCU2_0] 68.051191 s: Application requested features = 0x158 [MCU2_0] [MCU2_0] 68.051241 s: UB960 config start [MCU2_0] 68.307212 s: End of UB960 config [MCU2_0] 68.307280 s: UB960 config start [MCU2_0] 68.563208 s: End of UB960 config [MCU2_0] 68.563271 s: Configuring camera # 0 [MCU2_0] 68.563320 s: Iss_sensor_isx016.c ...i am in ISX016_Config config script [MCU2_0] 68.563508 s: UB960 config start [MCU2_0] 68.567216 s: End of UB960 config [MCU2_0] 68.567272 s: ub953 config start : slaveAddr = 0x74 [MCU2_0] 68.759279 s: End of UB953 config [MCU2_0] 68.759393 s: iss_sensor_isx016.c ---> ISX016_Sensor_RegConfig regAddr,regValue, delayMilliSec 259 1 0 [MCU2_0] 68.759466 s: Configuring ISX016 imager 0x40.. Please wait till it finishes [MCU2_0] 69.078136 s: ISX016 config done [MCU2_0] 69.078210 s: iss_sensor_isx016.c ---> ISX016_Config finished [MCU2_0] 69.078252 s: Configuring camera # 1 [MCU2_0] 69.078294 s: Iss_sensor_isx016.c ...i am in ISX016_Config config script [MCU2_0] 69.078490 s: UB960 config start [MCU2_0] 69.082225 s: End of UB960 config [MCU2_0] 69.082289 s: ub953 config start : slaveAddr = 0x76 [MCU2_0] 69.274270 s: End of UB953 config [MCU2_0] 69.274384 s: iss_sensor_isx016.c ---> ISX016_Sensor_RegConfig regAddr,regValue, delayMilliSec 259 1 0 [MCU2_0] 69.274453 s: Configuring ISX016 imager 0x42.. Please wait till it finishes [MCU2_0] 69.608132 s: ISX016 config done [MCU2_0] 69.608200 s: iss_sensor_isx016.c ---> ISX016_Config finished [MCU2_0] 69.608241 s: Configuring camera # 2 [MCU2_0] 69.608281 s: Iss_sensor_isx016.c ...i am in ISX016_Config config script [MCU2_0] 69.608470 s: UB960 config start [MCU2_0] 69.612214 s: End of UB960 config [MCU2_0] 69.612272 s: ub953 config start : slaveAddr = 0x78 [MCU2_0] 69.804277 s: End of UB953 config [MCU2_0] 69.804391 s: iss_sensor_isx016.c ---> ISX016_Sensor_RegConfig regAddr,regValue, delayMilliSec 259 1 0 [MCU2_0] 69.804461 s: Configuring ISX016 imager 0x44.. Please wait till it finishes [MCU2_0] 70.123131 s: ISX016 config done [MCU2_0] 70.123201 s: iss_sensor_isx016.c ---> ISX016_Config finished [MCU2_0] 70.123246 s: Configuring camera # 3 [MCU2_0] 70.123286 s: Iss_sensor_isx016.c ...i am in ISX016_Config config script [MCU2_0] 70.123477 s: UB960 config start [MCU2_0] 70.127218 s: End of UB960 config [MCU2_0] 70.127280 s: ub953 config start : slaveAddr = 0x7a [MCU2_0] 70.319278 s: End of UB953 config [MCU2_0] 70.319393 s: iss_sensor_isx016.c ---> ISX016_Sensor_RegConfig regAddr,regValue, delayMilliSec 259 1 0 [MCU2_0] 70.319462 s: Configuring ISX016 imager 0x46.. Please wait till it finishes 70.638466 s: ISS: Initializing sensor [ISX016-UB913] ... Done !!! Sensor init done! Capture init done! app_init_viss() : Entering configure_viss_params() : Entering configure_viss_params() : Exiting configure_viss_params() : Entering configure_viss_params() : Exiting create_viss_outputs() : Entering create_viss_outputs() : Exiting app_init_viss() : Exiting VISS init done! Img Mosaic init done! Display init done! [MCU2_0] 70.638137 s: ISX016 config done [MCU2_0] 70.638208 s: iss_sensor_isx016.c ---> ISX016_Config finished [MCU2_0] 70.638253 s: IM_SENSOR_CMD_CONFIG returning status = 0 app_create_graph : Entering Graph create done! Capture graph done! app_create_graph_viss() : Entering app_create_graph_viss() : graph is OK app_create_graph_viss() : vissObj-config is OK app_create_graph_viss() : vissObj-dcc_config is NULL app_create_graph_viss() : raw_image is OK app_create_graph_viss() : output_img is OK app_create_graph_viss() : h3a_status is OK 70.707234 s: VX_ZONE_ERROR:[vxSetParameterByIndex:239] Invalid type 0x0000080f! 70.707243 s: VX_ZONE_ERROR:[vxSetParameterByIndex:287] Specified: parameter[3] type:0000080f => 0xffff981e3350 70.707249 s: VX_ZONE_ERROR:[vxSetParameterByIndex:289] Required: parameter[3] dir:0 type:00000817 70.707263 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference 70.707270 s: VX_ZONE_ERROR:[vxGetStatus:700] Reference is NULL [VISS-MODULE] Unable to create VISS Node! app_create_graph_viss() : Exiting VISS graph done! app_create_graph : Exiting 70.707300 s: VX_ZONE_ERROR:[ownReleaseReferenceInt:294] Invalid reference 70.707341 s: ISS: De-initializing sensor [ISX016-UB913] ... !!! 70.707665 s: ISS: De-initializing sensor [ISX016-UB913] ... Done !!! 71.216822 s: VX_ZONE_WARNING:[vxReleaseContext:1060] Found a reference 0xffff981e3350 of type 0000080f at external count 1, internal count 0, releasing it 71.216844 s: VX_ZONE_WARNING:[vxReleaseContext:1062] Releasing reference (name=image_107) now as a part of garbage collection 71.216888 s: VX_ZONE_INIT:[tivxHostDeInitLocal:107] De-Initialization Done for HOST !!! 71.221263 s: VX_ZONE_INIT:[tivxDeInitLocal:223] De-Initialization Done !!! APP: Deinit ... !!! REMOTE_SERVICE: Deinit ... !!! REMOTE_SERVICE: Deinit ... Done !!! IPC: Deinit ... !!! IPC: DeInit ... Done !!! MEM: Deinit ... !!! DDR_SHARED_MEM: Alloc's: 11 alloc's of 4272240 bytes DDR_SHARED_MEM: Free's : 11 free's of 4272240 bytes DDR_SHARED_MEM: Open's : 0 allocs of 0 bytes DDR_SHARED_MEM: Total size: 536870912 bytes MEM: Deinit ... Done !!! APP: Deinit ... Done !!! root@j7-evm:/opt/vision_apps#
如何解决这些 运行时错误?
