TMS320F280049: F280049 EPWM2有概率无法正常输出
Part Number: TMS320F280049
EPWM2与EPWM1同步,且移相180°,频率100KHz,每次启动的时候,EPWM2有时候会无法正常输出:A常高,B常低,重新启动也是不行,改成别的频率65KHz,又恢复正常了占空比输出,这可能是哪里的问题呢?
启动方式:
            EPwm1Regs.TZCLR.bit.OST = 1;
            EPwm1Regs.TZCLR.bit.INT = 1;
            EPwm2Regs.TZCLR.bit.OST = 1;
            EPwm2Regs.TZCLR.bit.INT = 1;
停止方式:
            EPwm1Regs.TZFRC.bit.OST = 1;
            EPwm2Regs.TZFRC.bit.OST = 1;
以下是EPWM的配置:
    EPwm1Regs.TBPRD = 999;
    EPwm1Regs.CMPA.bit.CMPA = 332;
    EPwm1Regs.TBPHS.bit.TBPHS = 0;
    EPwm1Regs.TBCTL.bit.PHSDIR = TB_UP;
    EPwm1Regs.TBCTL.bit.HSPCLKDIV = 0;
    EPwm1Regs.TBCTL.bit.CLKDIV = 0;
    EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP;
    EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW;
    EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE;
    EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
    //Init duty control register;
    EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
    EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
    EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
    //Set action
    EPwm1Regs.AQCTLA.all=0x0000;
    EPwm1Regs.AQCTLA.bit.ZRO = AQ_SET;
    EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR;
    //init software force register;
    EPwm1Regs.AQSFRC.bit.RLDCSF = 2;
    EPwm1Regs.AQSFRC.bit.ACTSFB = 0;
    EPwm1Regs.AQSFRC.bit.ACTSFA = 0;
    EPwm1Regs.AQCSFRC.bit.CSFA = 0;
    EPwm1Regs.AQCSFRC.bit.CSFB = 0;
    //Init deadband register;
    EPwm1Regs.DBCTL.bit.SHDWDBFEDMODE = 1;
    EPwm1Regs.DBCTL.bit.SHDWDBREDMODE = 1;
    EPwm1Regs.DBCTL.bit.IN_MODE = DBA_ALL;
    EPwm1Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
    EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
    EPwm1Regs.DBFED.bit.DBFED = 30;
    EPwm1Regs.DBRED.bit.DBRED = 30;
    //Init PWM interrupt;
    EPwm1Regs.ETSEL.bit.INTEN = 0;
    //Init AD trig;
    EPwm1Regs.ETSEL.bit.SOCAEN = 0;
    EPwm1Regs.ETSEL.bit.SOCBEN = 0;
    //Init TZ
    EALLOW;
    EPwm1Regs.TZSEL.all = 0x0000;
    EPwm1Regs.TZSEL.bit.OSHT1 = 1;
    EPwm1Regs.TZSEL.bit.OSHT2 = 1;
    EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
    EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
    EPwm1Regs.TZEINT.bit.OST = 0;
    //Init chop;
    EPwm1Regs.PCCTL.bit.CHPEN = CHP_DISABLE;
    EDIS;
    EPwm2Regs.TBPRD = 999;
    EPwm2Regs.CMPA.bit.CMPA = 332;
    EPwm2Regs.TBPHS.bit.TBPHS = 499;
    EPwm2Regs.TBCTL.bit.PHSDIR = TB_UP;
    EPwm2Regs.TBCTL.bit.HSPCLKDIV = 0;
    EPwm2Regs.TBCTL.bit.CLKDIV = 0;
    EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP;
    EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW;
    EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE;
    EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
    EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
    EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
    EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
    EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
    //Set action
    EPwm2Regs.AQCTLA.all=0x0000;
    EPwm2Regs.AQCTLA.bit.ZRO = AQ_SET;
    EPwm2Regs.AQCTLA.bit.CAU = AQ_CLEAR;
    EPwm2Regs.AQSFRC.bit.RLDCSF = 2;
    EPwm2Regs.AQSFRC.bit.ACTSFB = 0;
    EPwm2Regs.AQSFRC.bit.ACTSFA = 0;
    EPwm2Regs.AQCSFRC.bit.CSFA = 0;
    EPwm2Regs.AQCSFRC.bit.CSFB = 0;
    EPwm2Regs.DBCTL.bit.SHDWDBFEDMODE = 1;
    EPwm2Regs.DBCTL.bit.SHDWDBREDMODE = 1;
    EPwm2Regs.DBCTL.bit.IN_MODE = DBA_ALL;
    EPwm2Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
    EPwm2Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
    EPwm2Regs.DBFED.bit.DBFED = 30;
    EPwm2Regs.DBRED.bit.DBRED = 30;
    EPwm2Regs.ETSEL.bit.INTEN = 0;
    //Init AD trig;
    EPwm2Regs.ETSEL.bit.SOCAEN = 0;
    EPwm2Regs.ETSEL.bit.SOCBEN = 0;
    //Init TZ
    EALLOW;
    EPwm2Regs.TZSEL.all = 0x0000;
    EPwm2Regs.TZSEL.bit.OSHT1 = 1;
    EPwm2Regs.TZSEL.bit.OSHT2 = 1;
    EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_LO;
    EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_LO;
    EPwm2Regs.TZEINT.bit.OST = 0;
