Other Parts Discussed in Thread: CONTROLSUITE, POWERSUITE
按照TI Resource Explorer里controlSUITE的方法导入THREE PHASE PFC的工程后,可以通过编译,但是双击打开main.cfg文件后,PowerSuite页为完全空白,没有任何内容,与tiducj0.pdf文档描述不一样。controlSUITE和CCS都是安装在英文目录里,尝试过CCS6和CCS7都一样是空白页。
Check if you have GUI Composer Installed. GUI Composer is required to run powerSUITE projects. To install GUI composer in CCS, go to View-> CCS App Center. You should see GUI Composer under Code Composer Studio Add-ons. If it says "Up to Date" that means you have GUI composer installed. Otherwise select it and click on "Install Software" . This will download GUI composer and install it on your machine.
我用CCSv7,安装GUI Composer之后,这个问题已经解决了。
ERIC
