电压采样以1.65V为中心,1.65V基准电压的地是GND和逆变侧 网侧之间的PGND NEU 通过电容连接,这样能实现地的电压平衡吗,这样会不会导致获取的输出VG_SEN_C等采样电压出现飘动,目前我遇到的问题就是电压飘动
参考下下面的回复:
I have not seen it. Could you please repeat the measurement by doing the following:
first measurement close the relays
second measurement short circuit the three output phases, of course without any power applied in DC link or AC
