Other Parts Discussed in Thread: CONTROLSUITE
can寄存器操作版例程使用问题。
例程来源:C:\ti\controlSUITE\device_support\F2837xD\v210\F2837xD_examples_Cpu1\can_loopback_bitfields;
根据控制板的CANB引脚修改相关配置,包括:
-- 时钟配置修改set clock for CANB not CANA,即ClkCfgRegs.CLKSRCCTL2.bit.CANBBCLKSEL = 0;
-- 把canaRegs全部改成canbRegs,包括:
--用InitCANB() 替换 InitCAN()
-- setupMessageObject();
-- sendCANMessage();
-- getCANMessage();
-- 屏蔽lookback功能语句:
-- // CanbRegs.CAN_CTL.bit.Test = 1;
-- // CanbRegs.CAN_TEST.bit.EXL = 1;
-- 屏蔽发送接收对比上报ERRO的语句:
-- /*if((*(unsigned long *)ucTXMsgData) != (*(unsigned long *)ucRXMsgData))
-- errFlag++;
-- asm(" ESTOP0");
但是最后还是无法从CAN适配器读取到发送的数据。详细代码如下:
//########################################################################### // // FILE: can_loopback_bitfields.c // // TITLE: Example to demonstrate basic CAN setup and use. // //! \addtogroup cpu01_example_list //! <h1>CAN External Loopback Using Bitfields (can_loopback_bitfields)</h1> //! //! IMPORTANT: CAN Bitfield headers require compiler v16.6.0.STS and newer! //! //! This example, using bitfield headers, shows the basic setup of CAN in //! order to transmit and receive messages on the CAN bus. The CAN //! peripheral is configured to transmit messages with a specific CAN ID. //! A message is then transmitted once per second, using a simple delay //! loop for timing. The message that is sent is a 4 byte message that //! contains an incrementing pattern. //! //! This example sets up the CAN controller in External Loopback test mode. //! Data transmitted is visible on the CAN0TX pin and can be received with //! an appropriate mailbox configuration. //! // //########################################################################### // $TI Release: F2837xD Support Library v210 $ // $Release Date: Tue Nov 1 14:46:15 CDT 2016 $ // $Copyright: Copyright (C) 2013-2016 Texas Instruments Incorporated - // http://www.ti.com/ ALL RIGHTS RESERVED $ //########################################################################### // // Included Files // #include "F28x_Project.h" // // Defines // #define CAN_MSG_ID 0x1111 #define CAN_TX_MSG_OBJ 1 #define CAN_RX_MSG_OBJ 2 #define CAN_MAX_BIT_DIVISOR (13) // The maximum CAN bit timing divisor #define CAN_MIN_BIT_DIVISOR (5) // The minimum CAN bit timing divisor #define CAN_MAX_PRE_DIVISOR (1024) // The maximum CAN pre-divisor #define CAN_MIN_PRE_DIVISOR (1) // The minimum CAN pre-divisor #define CAN_BTR_BRP_M (0x3F) #define CAN_BTR_BRPE_M (0xF0000) // // Globals // unsigned char ucTXMsgData[4] = {0x1, 0x2, 0x3, 0x4}; // TX Data unsigned char ucRXMsgData[4] = {0, 0, 0, 0}; // RX Data uint32_t messageSize = sizeof(ucTXMsgData); // Message Size (DLC) volatile unsigned long msgCount = 0; // A counter that keeps track of the // number of times the transmit was // successful. volatile unsigned long errFlag = 0; // A flag to indicate that some // transmission error occurred. static const uint16_t canBitValues[] = { 0x1100, // TSEG2 2, TSEG1 2, SJW 1, Divide 5 0x1200, // TSEG2 2, TSEG1 3, SJW 1, Divide 6 0x2240, // TSEG2 3, TSEG1 3, SJW 2, Divide 7 0x2340, // TSEG2 3, TSEG1 4, SJW 2, Divide 8 0x3340, // TSEG2 4, TSEG1 4, SJW 2, Divide 9 0x3440, // TSEG2 4, TSEG1 5, SJW 2, Divide 10 0x3540, // TSEG2 4, TSEG1 6, SJW 2, Divide 11 0x3640, // TSEG2 4, TSEG1 7, SJW 2, Divide 12 0x3740 // TSEG2 4, TSEG1 8, SJW 2, Divide 13 }; typedef enum { //! Transmit message object. MSG_OBJ_TYPE_TRANSMIT, //! Receive message object. MSG_OBJ_TYPE_RECEIVE } msgObjType; // // Function Prototypes // uint32_t setCANBitRate(uint32_t sourceClock, uint32_t bitRate); void setupMessageObject(uint32_t objID, uint32_t msgID, msgObjType msgType); void sendCANMessage(uint32_t objID); bool getCANMessage(uint32_t objID); void InitCANB(void); // // Main // int main(void) { // // Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the F2837xD_SysCtrl.c file. // InitSysCtrl(); // // Initialize GPIO: // This example function is found in the F2837xD_Gpio.c file and // illustrates how to set the GPIO to its default state. // InitGpio(); GPIO_SetupPinMux(17, GPIO_MUX_CPU1, 1); //GPIO30 - CANRXA GPIO_SetupPinMux(12, GPIO_MUX_CPU1, 1); //GPIO31 - CANTXA GPIO_SetupPinOptions(17, GPIO_INPUT, GPIO_ASYNC); GPIO_SetupPinOptions(12, GPIO_OUTPUT, GPIO_PUSHPULL); // // Initialize the CAN-A controller // // InitCAN(); InitCANB(); // // Setup CAN to be clocked off the SYSCLKOUT // // ClkCfgRegs.CLKSRCCTL2.bit.CANABCLKSEL = 0; ClkCfgRegs.CLKSRCCTL2.bit.CANBBCLKSEL = 0; // // Set up the bit rate for the CAN bus. This function sets up the CAN // bus timing for a nominal configuration. // In this example, the CAN bus is set to 500 kHz. // // Consult the data sheet for more information about // CAN peripheral clocking. // uint32_t status = setCANBitRate(200000000, 500000); // // If values requested are too small or too large, catch error // if(status == 0) { errFlag++; ESTOP0; // Stop here and handle error } // // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts // DINT; // // Initialize the PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the F2837xD_PieCtrl.c file. // InitPieCtrl(); // // Disable CPU interrupts and clear all CPU interrupt flags: // IER = 0x0000; IFR = 0x0000; // // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in F2837xD_DefaultIsr.c. // This function is found in F2837xD_PieVect.c. // InitPieVectTable(); // // Enable test mode and select external loopback // // CanbRegs.CAN_CTL.bit.Test = 1; // CanbRegs.CAN_TEST.bit.EXL = 1; // // Initialize the message object that will be used for sending CAN // messages. // setupMessageObject(CAN_TX_MSG_OBJ, CAN_MSG_ID, MSG_OBJ_TYPE_TRANSMIT); // // Initialize the message object that will be used for receiving CAN // messages. // setupMessageObject(CAN_RX_MSG_OBJ, CAN_MSG_ID, MSG_OBJ_TYPE_RECEIVE); // // Enable the CAN for operation. // CanbRegs.CAN_CTL.bit.Init = 0; // // Enter loop to send messages. A new message will be sent once per // second. The 4 bytes of message content will be treated as an unsigned // long and incremented by one each time. // for(;;) { // // Send the CAN message using object number 1 (not the same thing as // CAN ID, which is also 1 in this example). This function will cause // the message to be transmitted right away. // sendCANMessage(CAN_TX_MSG_OBJ); // // Now wait 1 second before continuing // DELAY_US(1000*1000); // // Get the receive message // getCANMessage(CAN_RX_MSG_OBJ); // // Ensure the received data matches the transmitted data // /*if((*(unsigned long *)ucTXMsgData) != (*(unsigned long *)ucRXMsgData)) { errFlag++; asm(" ESTOP0"); }*/ // // Increment successful message count and the value in the // transmitted message data. // msgCount++; (*(unsigned long *)ucTXMsgData)++; } } void InitCANB(void) { int16_t iMsg; // // Place CAN controller in init state, regardless of previous state. This // will put controller in idle, and allow the message object RAM to be // programmed. // CanbRegs.CAN_CTL.bit.Init = 1; CanbRegs.CAN_CTL.bit.SWR = 1; // // Wait for busy bit to clear // while(CanbRegs.CAN_IF1CMD.bit.Busy) { } // // Clear the message value bit in the arbitration register. This indicates // the message is not valid and is a "safe" condition to leave the message // object. The same arb reg is used to program all the message objects. // CanbRegs.CAN_IF1CMD.bit.DIR = 1; CanbRegs.CAN_IF1CMD.bit.Arb = 1; CanbRegs.CAN_IF1CMD.bit.Control = 1; CanbRegs.CAN_IF1ARB.all = 0; CanbRegs.CAN_IF1MCTL.all = 0; CanbRegs.CAN_IF2CMD.bit.DIR = 1; CanbRegs.CAN_IF2CMD.bit.Arb = 1; CanbRegs.CAN_IF2CMD.bit.Control = 1; CanbRegs.CAN_IF2ARB.all = 0; CanbRegs.CAN_IF2MCTL.all = 0; // // Loop through to program all 32 message objects // for(iMsg = 1; iMsg <= 32; iMsg+=2) { // // Wait for busy bit to clear // while(CanbRegs.CAN_IF1CMD.bit.Busy) { } // // Initiate programming the message object // CanbRegs.CAN_IF1CMD.bit.MSG_NUM = iMsg; // // Wait for busy bit to clear // while(CanbRegs.CAN_IF2CMD.bit.Busy) { } // // Initiate programming the message object // CanbRegs.CAN_IF2CMD.bit.MSG_NUM = iMsg + 1; } // // Acknowledge any pending status interrupts. // volatile uint32_t discardRead = CanbRegs.CAN_ES.all; } // // setCANBitRate - Set the CAN bit rate based on device clock (Hz) // and desired bit rate (Hz) // uint32_t setCANBitRate(uint32_t sourceClock, uint32_t bitRate) { uint32_t desiredRatio; uint32_t canBits; uint32_t preDivide; uint32_t regValue; uint16_t canControlValue; // // Calculate the desired clock rate. // desiredRatio = sourceClock / bitRate; // // Make sure that the Desired Ratio is not too large. This enforces the // requirement that the bit rate is larger than requested. // if((sourceClock / desiredRatio) > bitRate) { desiredRatio += 1; } // // Check all possible values to find a matching value. // while(desiredRatio <= CAN_MAX_PRE_DIVISOR * CAN_MAX_BIT_DIVISOR) { // // Loop through all possible CAN bit divisors. // for(canBits = CAN_MAX_BIT_DIVISOR; canBits >= CAN_MIN_BIT_DIVISOR; canBits--) { // // For a given CAN bit divisor save the pre divisor. // preDivide = desiredRatio / canBits; // // If the calculated divisors match the desired clock ratio then // return these bit rate and set the CAN bit timing. // if((preDivide * canBits) == desiredRatio) { // // Start building the bit timing value by adding the bit timing // in time quanta. // regValue = canBitValues[canBits - CAN_MIN_BIT_DIVISOR]; // // To set the bit timing register, the controller must be // placed // in init mode (if not already), and also configuration change // bit enabled. The state of the register should be saved // so it can be restored. // canControlValue = CanbRegs.CAN_CTL.all; CanbRegs.CAN_CTL.bit.Init = 1; CanbRegs.CAN_CTL.bit.CCE = 1; // // Now add in the pre-scalar on the bit rate. // regValue |= ((preDivide - 1) & CAN_BTR_BRP_M) | (((preDivide - 1) << 10) & CAN_BTR_BRPE_M); // // Set the clock bits in the and the bits of the // pre-scalar. // CanbRegs.CAN_BTR.all = regValue; // // Restore the saved CAN Control register. // CanbRegs.CAN_CTL.all = canControlValue; // // Return the computed bit rate. // return(sourceClock / ( preDivide * canBits)); } } // // Move the divisor up one and look again. Only in rare cases are // more than 2 loops required to find the value. // desiredRatio++; } return 0; } // // setupMessageObject - Setup message object as Transmit or Receive // void setupMessageObject(uint32_t objID, uint32_t msgID, msgObjType msgType) { // // Wait for busy bit to clear. // while(CanbRegs.CAN_IF1CMD.bit.Busy) { } // // Clear and Write out the registers to program the message object. // CanbRegs.CAN_IF1CMD.all = 0; CanbRegs.CAN_IF1MSK.all = 0; CanbRegs.CAN_IF1ARB.all = 0; CanbRegs.CAN_IF1MCTL.all = 0; // // Set the Control, Mask, and Arb bit so that they get transferred to the // Message object. // CanbRegs.CAN_IF1CMD.bit.Control = 1; CanbRegs.CAN_IF1CMD.bit.Arb = 1; CanbRegs.CAN_IF1CMD.bit.Mask = 1; CanbRegs.CAN_IF1CMD.bit.DIR = 1; // // Set direction to transmit // if(msgType == MSG_OBJ_TYPE_TRANSMIT) { CanbRegs.CAN_IF1ARB.bit.Dir = 1; } // // Set Message ID (this example assumes 11 bit ID mask) // CanbRegs.CAN_IF1ARB.bit.ID = msgID; CanbRegs.CAN_IF1ARB.bit.MsgVal = 1; // // Set the data length since this is set for all transfers. This is // also a single transfer and not a FIFO transfer so set EOB bit. // CanbRegs.CAN_IF1MCTL.bit.DLC = messageSize; CanbRegs.CAN_IF1MCTL.bit.EoB = 1; // // Transfer data to message object RAM // CanbRegs.CAN_IF1CMD.bit.MSG_NUM = objID; } // // sendCANMessage - Transmit data from the specified message object // void sendCANMessage(uint32_t objID) { // // Wait for busy bit to clear. // while(CanbRegs.CAN_IF1CMD.bit.Busy) { } // // Write data to transfer into DATA-A and DATA-B interface registers // uint16_t index; for(index = 0; index < messageSize; index++) { switch(index) { case 0: CanbRegs.CAN_IF1DATA.bit.Data_0 = ucTXMsgData[index]; break; case 1: CanbRegs.CAN_IF1DATA.bit.Data_1 = ucTXMsgData[index]; break; case 2: CanbRegs.CAN_IF1DATA.bit.Data_2 = ucTXMsgData[index]; break; case 3: CanbRegs.CAN_IF1DATA.bit.Data_3 = ucTXMsgData[index]; break; case 4: CanbRegs.CAN_IF1DATB.bit.Data_4 = ucTXMsgData[index]; break; case 5: CanbRegs.CAN_IF1DATB.bit.Data_5 = ucTXMsgData[index]; break; case 6: CanbRegs.CAN_IF1DATB.bit.Data_6 = ucTXMsgData[index]; break; case 7: CanbRegs.CAN_IF1DATB.bit.Data_7 = ucTXMsgData[index]; break; } } // // Set Direction to write and set DATA-A/DATA-B to be transfered to // message object // CanbRegs.CAN_IF1CMD.all = 0x830000; // // Set Tx Request Bit // CanbRegs.CAN_IF1CMD.bit.TXRQST = 1; // // Transfer the message object to the message object specified by // objID. // CanbRegs.CAN_IF1CMD.bit.MSG_NUM = objID; } // // getCANMessage - Check the message object for new data. // If new data, data written into array and return true. // If no new data, return false. // bool getCANMessage(uint32_t objID) { bool status; // // Set the Message Data A, Data B, and control values to be read // on request for data from the message object. // CanbRegs.CAN_IF2CMD.all = 0; CanbRegs.CAN_IF2CMD.bit.Control = 1; CanbRegs.CAN_IF2CMD.bit.DATA_A = 1; CanbRegs.CAN_IF2CMD.bit.DATA_B = 1; // // Transfer the message object to the message object IF register. // CanbRegs.CAN_IF2CMD.bit.MSG_NUM = objID; // // Wait for busy bit to clear. // while(CanbRegs.CAN_IF2CMD.bit.Busy) { } // // See if there is new data available. // if(CanbRegs.CAN_IF2MCTL.bit.NewDat == 1) { // // Read out the data from the CAN registers. // uint16_t index; for(index = 0; index < messageSize; index++) { switch(index) { case 0: ucRXMsgData[index] = CanbRegs.CAN_IF2DATA.bit.Data_0; break; case 1: ucRXMsgData[index] = CanbRegs.CAN_IF2DATA.bit.Data_1; break; case 2: ucRXMsgData[index] = CanbRegs.CAN_IF2DATA.bit.Data_2; break; case 3: ucRXMsgData[index] = CanbRegs.CAN_IF2DATA.bit.Data_3; break; case 4: ucRXMsgData[index] = CanbRegs.CAN_IF2DATB.bit.Data_4; break; case 5: ucRXMsgData[index] = CanbRegs.CAN_IF2DATB.bit.Data_5; break; case 6: ucRXMsgData[index] = CanbRegs.CAN_IF2DATB.bit.Data_6; break; case 7: ucRXMsgData[index] = CanbRegs.CAN_IF2DATB.bit.Data_7; break; } } // // Clear New Data Flag // CanbRegs.CAN_IF2CMD.bit.TxRqst = 1; // // Wait for busy bit to clear. // while(CanbRegs.CAN_IF2CMD.bit.Busy) { } // // Transfer the message object to the message object IF register. // CanbRegs.CAN_IF2CMD.bit.MSG_NUM = objID; status = true; } else { status = false; } return(status); } // // End of file //
我有看过英文论坛上的类似问题,但是无人解答(TMS320F28379D: Running can_loopback_bitfields_cpu01 example on Launchpad -- CAN traffic not present - C2000 microcontrollers forum - C2000︎ microcontrollers - TI E2E support forums),尝试了500k乘以2或者除以2的通信频率依旧不行。
最后,尝试了不屏蔽lookback相关代码,并且控制板上的CANH和CANL短接和不短接都试验,结果也无法实现回环测试(即接收发送不相等,导致跳转到ERRO中)
