msp430g2231 IAR CSTACK 问题
我的程序compile时没错,make时出现如下错误
Error[e16]: Segment CSTACK (size: 0x40 align: 0x1) is too long for segment definition. At least 0x10 more bytes needed. The problem occurred while
processing the segment placement command "-Z(DATA)CSTACK+_STACK_SIZE#", where at the moment of placement the available memory ranges
were "CODE:250-27f"
   Reserved ranges relevant to this placement:
   200-21f              DATA16_I
   220-24f              DATA16_Z
   250-27f              CSTACK
Error while running Linker
我用的芯片是430g2231,IDE版本是IAR5.10.1
程序删减一些就不会出现这种错误,请大侠指点!
如果我把Stack size 改小没这个错误,但是运行时会出现Stack溢出问题。
