Use the HALCoGen to Cofigurate the TMS570LS1114PGE,occuring a serious problem?
I try to configurate the ETPWM modules and I want to use the TZn.I selected Trip Zone Source:all TZn. Once I selected TZ1 to TZ3,my driver program will drop into the error.I use the Scope ,appearing unnormal PWM scope.
Prj_ETPWMTZ_CS_01.zip
  • I try to configurate the ETPWM modules and I want to use the TZn.I selected Trip Zone Source:all TZn. Once I selected TZ1 to TZ3,my driver program will drop into the error.I use the Scope ,appearing unnormal PWM scope.
    编译出错的话,可通过console查看报错信息;烧录时JTAG连接等也会给出提示,您可根据这些查找原因;或者您也可把问题贴出来。
