Part Number: BQ25713
Other Parts Discussed in Thread: BQ76920, BQ76905
I am designing a charger using the BQ25713 for a 3S Li-Ion battery, and I hope to automatically balance the voltage between the different cells.
I found that the BQ76905 and BQ76920 both perform low-side current sensing on the negative terminal of the battery. If used together with the BQ25713 charger, will the voltage generated across the low-side sense resistor interfere with the BQ25713's battery voltage monitoring function?
