关于二级保护
Other Parts Discussed in Thread: BQ3050
各位TI的大神,BQ3050开启二级保护的方法是怎样的啊?
是给相应的time位设置时间就可以了吗?另外Permanent Fail Cfg位需要设置吗?
[Voltage(2nd Level Safety)]
LT SOV Threshold = 4500
ST SOV Threshold = 4600
HT SOV Threshold = 4500
SOV Time = 0  //disable
PF SOV Fuse Blow Delay = 0
Cell Imbalance Current = 5
Cell Imbalance Fail Voltage = 1000
Cell Imbalance Time = 0//disable
谢谢各位!!
  • 是的,把相应的delay时间设成0会disable相应的二级保护。
     Permanent Fail Cfg是用来配置该PF是否需要在FUSE pin输出高电平。
    The Permanent Fail Cfg register enables or disables the use of the FUSE pin when the corresponding
    permanent fail error occurs
