TPS65131 negative power can not be loaded
Other Parts Discussed in Thread: TPS65131
Using the TPS65131 to design a ±15V power supply, the positive power supply works normally, and the negative power supply cannot be loaded. What is the problem?0361.NLPH3.pdf
