Large current, low dropout, low output ripple, small size LDO selection
Output 1.8v 1.5A, Power the CMOS sensor,The input voltage is 2.0-3.3V,Is there an LDO that is small in size, meets the conditions, and generates a small amount of heat? Can TPS7A7002 satisfy? Is this power supply an LDO? Is the output ripple large?
