目前每个基本电池模块都配备了一个BQ3060,现在想将这样几个基本的电池模块并联使用,请问有什么方法可以实现通过BQ3060上的Smbus来采集每个基本电池模块的信息(单节电压、基本电池模块的容量信息等),并将将这些信息传输到主机或者用户端
多谢!
多谢!
Since this is 1s2p (for instance, one series, two parallel) you can use any single-cell TI gauge and treat it like one larger pack. The balancing is automatic since they are connected in parallel so you don't need to worry about it. Some gauges to look at are bq27541-G1/bq27545-G1 (for pack-side) or bq27520-G4 or bq27620-G1 for system-side.
