TPS62812-Q1: The label on the bag is inconsistent with that on the reel. The label on the bag is (4W) TKY and the reel is (4W) SWR.
Part Number: TPS62812-Q1
Recently we received 3 reels of TPS6281208QWRWYRQ1. We found 2 problem.
First problem is the number on the label is different. The label on the box and bag is 3000, the label on the reel is 1054.
Second problem is the label on the box and bag is (4W) TKY and the reel is (4W) SWR.  We found that SWR means Special Work Request (Engineering Material).
So, is SWR engineering sample? And why the labels are different? Can we use it as normal products? Will the defect rate be high?
Attachment are photos of label and packing list.
  • Hi
        有可能的,你们应该是买到了散装,而不是整装3000Pcs.
        TI判定芯片质量唯一标准是购货渠道,如果你是找TI购买,不会出现质量问题。如果不是TI, 建议你找你们长期合作的渠道商购买。 (市场上假劣芯片还是有很多的,所以渠道很重要,建议特别注意)
  • Mr. Tao 您好,谢谢您的回复。您说的散装是什么意思呀,是说原厂就是这种非整包的吗?这个SWR的物料和TKY的实际上是一样的吗?不良率会比较高吗?
  • Hi
          是的, 一般购买都是整包,除非数量上不合适(例如你购买3100Pcs,  整包3000Pcs, 还有100Pcs散装)
          正常而言整装,或者散装都不存在质量上的问题,不会有不良率上的差异。但是散装并非真空包装,如果保存不好,不配出受潮,氧化等问题,可能会导致不良率。
