Other Parts Discussed in Thread: BQSTUDIO
请问谁有1100_0_04-bq78z100.bqz这个文件,现在IC是这个版本,但是软件里没有,每次接入测试板需要重新选择IC
您好,pls download the file below. place this bqz file in the config folder of bqstudio on your computer and then manually select the bq78z100. Then program the srec file you downloaded from the link. You program using the firmware tab. This will program the latest firmware 1100_0_05 on the gauge and you will be able to automatically detect the gauge upon start up of bqstudio. I hope this helps
This is where you will place the bqz file on your computer. C:\ti\BatteryManagementStudio\config
