BQ25710: Vbus discharge slow after removing adapter
Part Number: BQ25710
I am using the BQ25710 solution. Recently, I found that VBUS discharges very slowly after removing the adapter. The longer the charging time (higher IC temperature), the slower VBUS discharges. Is there a way to modify the registers through commands to improve this issue? Thank you for your assistance.
