Other Parts Discussed in Thread: TPS61040
在TPS61040的数据手册中写到
To achieve high efficiency a Schottky diode should be used. The current rating of the diode should meet the
peak current rating of the converter as it is calculated in Peak Current Control. Use the maximum value for I
LIM for this calculation.
这段话是什么意思呢?能够翻译一下吗?我是这样理解的,“二极管的额定电流要大于TPS61040的峰值电流”,但是这和我理解平时了解的“整流二极管的额定电流是输出电流的2~3倍”有冲突。
