Other Parts Discussed in Thread: LP5860
We're using LP5860 Ip5866 for lighting module, and using LP5860EVM to test LED lighting, need your kindly help to provide PCB layout to design Adapter plate, many thanks.
Hi,
Please refer to the PCB layout in the evaluation board User’s Guide:www.ti.com/.../snvu762.pdf
Hi,
I have checked that there are similar request thread before, but the engineer did not provide gerber file, so probably there is no such file to provide, please refer to this thread,
