Other Parts Discussed in Thread: LM5155
we use lm5155 as flyback circuit. input 12V; output 65V 1A.
but we get the overshoot above 70V, it is too high, so how to reduce the overshoot,
thanks!
Hi,
This is an Application Note on how to design an isolated flyback regulator using the LM5155, which includes example applications and component selection methods. You can see if you can refer to it,www.ti.com.cn/.../zhcac13a.pdf
