AM3352: 升级至Processor SDK Linux for AM335X 09_01_00_001 在AM3352 BBB上无法启动, 可能与cpsw以及SDK版本有关
Part Number: AM3352
Other Parts Discussed in Thread: AM3359
硬件板卡: AM3359 BBB 和 AM3352 BBB(仅处理器区别)
软件环境: ti-processor-sdk-linux-am335x-evm-09.01.00.001 和 ti-processor-sdk-linux-am335x-evm-06.03.00.106
场景:
A. 使用ti-processor-sdk-linux-am335x-evm-09.01.00.001 中BBB默认配置编译zIamge与Uboot, AM3359 BBB 可正常运行, AM3352 BBB出现卡死情况(位置固定), 并伴随CPU发热现象;
报错位置如下(也附上完整日志):
[ 2.104406] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[ 2.111404] cpsw-switch 4a100000.switch: ALE Table size 1024
[ 2.134072] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies)
[ 2.141875] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[ 2.173971] cpsw-switch 4a100000.switch: Detected MACID = 88:c2:55:3a:d4:b8
[ 2.182314] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[ 2.215416] 8<--- cut here ---
[ 2.218580] Unhandled fault: external abort on non-linefetch (0x1008) at 0xd0366000
[ 2.226453] [d0366000] *pgd=81f1b811, *pte=4a326653, *ppte=4a326453
B. 使用ti-processor-sdk-linux-am335x-evm-06.03.00.106中BBB默认配置编译zIamge与Uboot, AM3359 BBB 和 AM3352 BBB均可正常启动, 无发热现象;
问题: 根据日志情况, 可能与cpsw在SDK9.0+与SDK6.0+中升级有关, 因此SDK9.0+需要什么特定配置支持AM3352呢? 十分感谢。
场景:
报错位置如下(也附上完整日志):
U-Boot SPL 2023.04 (Apr 08 2024 - 15:38:40 +0800)
Trying to boot from MMC1
U-Boot 2023.04 (Apr 08 2024 - 15:38:40 +0800)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  256 MiB
Core:  160 devices, 18 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing every 1000ms (60s timeout)
NAND:  256 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
<ethaddr> not set. Validating first E-fuse MAC
Net:   eth2: ethernet@4a100000, eth3: usb_ether
Hit any key to stop autoboot:  0
## Error: "mmcboot" not defined
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
1:      Arago
Retrieving file: /extlinux/../zImage
append: root=PARTUUID=72fecc67-02 rootwait rw earlycon console=ttyO0,115200n8,115200
Retrieving file: /extlinux/../am335x-boneblack.dtb
Kernel image @ 0x82000000 [ 0x000000 - 0x74c200 ]
## Flattened Device Tree blob at 88000000
   Booting using the fdt blob at 0x88000000
Working FDT set to 88000000
   Loading Device Tree to 8cf07000, end 8cf21ed3 ... OK
Working FDT set to 8cf07000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 6.1.46 (root@cao-machine) (arm-none-linux-gnueabihf-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #1 PREEMPT Sun Apr  7 15:40:09 CST 2024
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] earlycon: omap8250 at MMIO 0x44e09000 (options '')
[    0.000000] printk: bootconsole [omap8250] enabled
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 64 MiB at 0x88800000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000008fdfffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000008fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000008fdfffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (neon)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 64516
[    0.000000] Kernel command line: root=PARTUUID=72fecc67-02 rootwait rw earlycon console=ttyO0,115200n8,115200
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 173656K/260096K available (11264K kernel code, 1470K rwdata, 3264K rodata, 1024K init, 287K bss, 20904K reserved, 65536K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[    0.000002] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.008061] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.018046] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.029778] Console: colour dummy device 80x30
[    0.034382] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.041166] This ensures that you still see kernel messages. Please
[    0.047607] update your kernel commandline.
[    0.051942] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.094497] CPU: Testing write buffer coherency: ok
[    0.099580] CPU0: Spectre v2: using BPIALL workaround
[    0.104774] pid_max: default: 32768 minimum: 301
[    0.109702] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.117227] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.126766] cblist_init_generic: Setting adjustable number of callback queues.
[    0.134272] cblist_init_generic: Setting shift to 0 and lim to 1.
[    0.140692] Setting up static identity map for 0x80100000 - 0x80100060
[    0.147555] rcu: Hierarchical SRCU implementation.
[    0.152502] rcu:     Max phase no-delay instances is 1000.
[    0.159666] EFI services will not be available.
[    0.164912] devtmpfs: initialized
[    0.182764] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.191011] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.201162] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.213175] pinctrl core: initialized pinctrl subsystem
[    0.219718] DMI not present or invalid.
[    0.224326] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.232691] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.240974] thermal_sys: Registered thermal governor 'step_wise'
[    0.241081] cpuidle: using governor menu
[    0.265976] No ATAGs?
[    0.268417] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.276474] Serial: AMBA PL011 UART driver
[    0.301037] SCSI subsystem initialized
[    0.318471] usbcore: registered new interface driver usbfs
[    0.324164] usbcore: registered new interface driver hub
[    0.338097] usbcore: registered new device driver usb
[    0.343759] pps_core: LinuxPPS API ver. 1 registered
[    0.358042] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.367467] PTP clock support registered
[    0.388225] EDAC MC: Ver: 3.0.0
[    0.393931] clocksource: Switched to clocksource dmtimer
[    0.420791] NET: Registered PF_INET protocol family
[    0.434220] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.454459] tcp_listen_portaddr_hash hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.463179] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.483947] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.491846] TCP bind hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.513953] TCP: Hash tables configured (established 2048 bind 2048)
[    0.520590] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.543941] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.551268] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.574163] RPC: Registered named UNIX socket transport module.
[    0.580263] RPC: Registered udp transport module.
[    0.585163] RPC: Registered tcp transport module.
[    0.589998] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.613941] PCI: CLS 0 bytes, default 64
[    0.619287] Initialise system trusted keyrings
[    0.634245] workingset: timestamp_bits=30 max_order=16 bucket_order=0
[    0.656365] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.674329] NFS: Registering the id_resolver key type
[    0.679588] Key type id_resolver registered
[    0.683889] Key type id_legacy registered
[    0.704108] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.711006] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.723971] ntfs: driver 2.1.32 [Flags: R/O].
[    0.734121] Key type asymmetric registered
[    0.738346] Asymmetric key parser 'x509' registered
[    0.743523] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.773936] io scheduler mq-deadline registered
[    0.778599] io scheduler kyber registered
[    0.882593] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled
[    0.895520] STMicroelectronics ASC driver initialized
[    0.926772] brd: module loaded
[    0.947712] loop: module loaded
[    0.966124] CAN device driver interface
[    0.970468] e1000e: Intel(R) PRO/1000 Network Driver
[    0.983940] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.990122] igb: Intel(R) Gigabit Ethernet Network Driver
[    1.003944] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.010514] pegasus: Pegasus/Pegasus II USB Ethernet driver
[    1.034000] usbcore: registered new interface driver pegasus
[    1.039884] usbcore: registered new interface driver asix
[    1.053973] usbcore: registered new interface driver ax88179_178a
[    1.060267] usbcore: registered new interface driver cdc_ether
[    1.083977] usbcore: registered new interface driver smsc75xx
[    1.089923] usbcore: registered new interface driver smsc95xx
[    1.103966] usbcore: registered new interface driver net1080
[    1.109811] usbcore: registered new interface driver cdc_subset
[    1.123993] usbcore: registered new interface driver zaurus
[    1.129792] usbcore: registered new interface driver cdc_ncm
[    1.154678] usbcore: registered new interface driver usb-storage
[    1.161640] i2c_dev: i2c /dev entries driver
[    1.176011] cpuidle: enable-method property 'ti,am3352' found operations
[    1.183510] sdhci: Secure Digital Host Controller Interface driver
[    1.203951] sdhci: Copyright(c) Pierre Ossman
[    1.208642] Synopsys Designware Multimedia Card Interface Driver
[    1.234111] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.240439] ledtrig-cpu: registered to indicate activity on CPUs
[    1.254363] usbcore: registered new interface driver usbhid
[    1.260098] usbhid: USB HID core driver
[    1.276548] NET: Registered PF_INET6 protocol family
[    1.295158] Segment Routing with IPv6
[    1.298999] In-situ OAM (IOAM) with IPv6
[    1.303114] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.324750] NET: Registered PF_PACKET protocol family
[    1.329959] can: controller area network core
[    1.344017] NET: Registered PF_CAN protocol family
[    1.348948] can: raw protocol
[    1.352000] can: broadcast manager protocol
[    1.363941] can: netlink gateway - max_hops=1
[    1.368844] Key type dns_resolver registered
[    1.373373] ThumbEE CPU extension supported.
[    1.393946] Registering SWP/SWPB emulation handler
[    1.399363] omap_voltage_late_init: Voltage driver support not added
[    1.424085] Loading compiled-in X.509 certificates
[    1.500213] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    1.518681] ti-sysc: probe of 44e31000.target-module failed with error -16
[    1.565001] ti-sysc: probe of 48040000.target-module failed with error -16
[    1.605833] gpio gpiochip0: (gpio-0-31): not an immutable chip, please consider fixing it!
[    1.624302] OMAP GPIO hardware version 0.1
[    1.652387] at24 2-0054: supply vcc not found, using dummy regulator
[    1.698035] at24 2-0055: supply vcc not found, using dummy regulator
[    1.747622] at24 2-0056: supply vcc not found, using dummy regulator
[    1.797630] at24 2-0057: supply vcc not found, using dummy regulator
[    1.847372] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    1.867710] gpio gpiochip1: (gpio-32-63): not an immutable chip, please consider fixing it!
[    1.885972] gpio gpiochip2: (gpio-64-95): not an immutable chip, please consider fixing it!
[    1.918621] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[    1.932377] platform 4830e000.lcdc: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0/tda19988@70
[    1.964225] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[    1.975464] omap_rng 48310000.rng: Random Number Generator ver. 20
[    1.982281] random: crng init done
[    2.053947] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    2.085212] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    2.232920] Internal error: : 1008 [#1] PREEMPT ARM
[    2.237937] Modules linked in:
[    2.241076] CPU: 0 PID: 29 Comm: kworker/u2:3 Not tainted 6.1.46 #1
[    2.247521] Hardware name: Generic AM33XX (Flattened Device Tree)
[    2.253783] Workqueue: events_unbound deferred_probe_work_func
[    2.259797] PC is at sysc_probe+0xdd4/0x1530
[    2.264198] LR is at pwrdm_unlock+0x14/0x38
[    2.268503] pc : [<c05581d8>]    lr : [<c0126470>]    psr: 60000113
[    2.274943] sp : d007d870  ip : c1b6c8c0  fp : c0c45378
[    2.280310] r10: 00000001  r9 : c0c45818  r8 : c1a15e00
[    2.285679] r7 : 00000000  r6 : c2811010  r5 : c12ab910  r4 : c2803940
[    2.292387] r3 : d0366000  r2 : 00026000  r1 : c1b6c8c0  r0 : 00000000
[    2.299096] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
[    2.306434] Control: 10c5387d  Table: 80004019  DAC: 00000051
[    2.312339] Register r0 information: NULL pointer
[    2.317176] Register r1 information: slab kmalloc-128 start c1b6c880 pointer offset 64 size 128
[    2.326142] Register r2 information: non-paged memory
[    2.331333] Register r3 information: 0-page vmalloc region starting at 0xd0340000 allocated at devm_ioremap+0x4c/0x8c
[    2.342254] Register r4 information: slab kmalloc-256 start c2803900 pointer offset 64 size 256
[    2.351212] Register r5 information: non-slab/vmalloc memory
[    2.357030] Register r6 information: slab kmalloc-1k start c2811000 pointer offset 16 size 1024
[    2.365988] Register r7 information: NULL pointer
[    2.370821] Register r8 information: slab task_struct start c1a15e00 pointer offset 0
[    2.378882] Register r9 information: non-slab/vmalloc memory
[    2.384699] Register r10 information: non-paged memory
[    2.389981] Register r11 information: non-slab/vmalloc memory
[    2.395888] Register r12 information: slab kmalloc-128 start c1b6c880 pointer offset 64 size 128
[    2.404932] Process kworker/u2:3 (pid: 29, stack limit = 0x(ptrval))
[    2.411466] Stack: (0xd007d870 to 0xd007e000)
[    2.415942] d860:                                     00000001 00000000 c111a7f4 c0e35fd0
[    2.424350] d880: c2811010 c12ab910 00000001 c2811010 c1a15e00 c0e35eb0 00000001 00000001
[    2.432759] d8a0: 00000030 6352e0ca 00000000 00000000 c2811010 c11ff438 00000000 c1a15e00
[    2.441168] d8c0: cfbcdee8 00000000 c1211eac c06bc944 c2811010 00000000 c11ff438 c06ba234
[    2.449576] d8e0: c2811010 c11ff438 c2811010 00000045 c1a15e00 c06ba4e0 60000113 cfbcdee8
[    2.457985] d900: c12b0090 c11ff438 c2811010 00000045 c1a15e00 c06ba628 00000001 c11ff438
[    2.466395] d920: d007d974 c2811010 c1a15e00 c06bac30 00000000 d007d974 c1a15e00 c06bab9c
[    2.474801] d940: c1a15e00 c06b8380 60000113 c18b129c c1ae7834 6352e0ca c1211eac c2811010
[    2.483208] d960: 00000001 c1a15e00 c2811054 c06ba8d4 cfbce2bc c2811010 00000001 6352e0ca
[    2.491617] d980: c1a15e00 c2811010 c1212468 c2811010 c1fe1c10 c06b952c c2811010 00000000
[    2.500025] d9a0: c12b0060 c06b680c 00000200 00000000 00000000 00000000 00000000 6352e0ca
[    2.508434] d9c0: c2811010 c2811000 cfbcdedc c111a7f4 00000000 00000000 c111a7f4 c1a15e00
[    2.516841] d9e0: 00000001 c099d734 cfbcdedc c111a698 c111a7d8 00000000 00000000 c099d96c
[    2.525250] da00: c0e4910c d007da28 c1211eac 00000000 c1fe1c10 00000001 c0e490f8 4a326000
[    2.533658] da20: 4a326003 ff8157e4 00000200 00000000 00000000 00000000 00000000 6352e0ca
[    2.542064] da40: cfbcdd10 cfbcdedc cfbcbe14 00000000 c111a698 c1fe1c10 00000001 00000000
[    2.550468] da60: c1211eac c099dcd0 00000001 c1a15e00 c1fe1c10 cfbcbe14 c111a698 00000000
[    2.558879] da80: c1a15e00 cfbcbe20 00000000 c0554fe8 00000000 c1fe1c10 c11ff354 c06bc944
[    2.567282] daa0: c1fe1c10 00000000 c11ff354 c06ba234 c1fe1c10 c11ff354 c1fe1c10 00000041
[    2.575692] dac0: c1a15e00 c06ba4e0 60000113 cfbcbe20 c12b0090 c11ff354 c1fe1c10 00000041
[    2.584102] dae0: c1a15e00 c06ba628 00000001 c11ff354 d007db44 c1fe1c10 c1a15e00 c06bac30
[    2.592511] db00: 00000000 d007db44 c1a15e00 c06bab9c c1a15e00 c06b8380 60000113 c18b129c
[    2.600920] db20: c1ae7734 6352e0ca c1211eac c1fe1c10 00000001 c1a15e00 c1fe1c54 c06ba8d4
[    2.609327] db40: cfbcdee8 c1fe1c10 00000001 6352e0ca c1a15e00 c1fe1c10 c1212468 c1fe1c10
[    2.617734] db60: c1fe1810 c06b952c c1fe1c10 00000000 c12b0060 c06b680c c1a15e00 00000000
[    2.626142] db80: c111a788 c1a15e00 00000001 6352e0ca c1fe1c10 c1fe1c00 cfbcbe14 c111a698
[    2.634551] dba0: 00000000 00000000 c111a698 c1a15e00 00000001 c099d734 cfbcbe14 c111a698
[    2.642960] dbc0: c111a788 00000000 00000000 c099d96c 00000000 6352e0ca 00000000 00000000
[    2.651367] dbe0: c1fe1810 00000000 c1fe1810 c06d3d74 00000000 d007dbfc cfbcbb50 cfbb0a88
[    2.659773] dc00: 00000000 c1a15e00 00000000 6352e0ca 00000001 cfbcbe14 cfbcbb44 00000000
[    2.668185] dc20: c111a698 c1fe1810 00000001 00000000 c1211eac c099dcd0 00000001 c1a15e00
[    2.676593] dc40: c1fe1810 cfbcbb44 c111a698 00000000 c1a15e00 cfbcbb50 00000000 c0554fe8
[    2.685002] dc60: 00000000 c1fe1810 c11ff354 c06bc944 c1fe1810 00000000 c11ff354 c06ba234
[    2.693410] dc80: c1fe1810 c11ff354 c1fe1810 00000041 c1a15e00 c06ba4e0 60000113 cfbcbb50
[    2.701816] dca0: c12b0090 c11ff354 c1fe1810 00000041 c1a15e00 c06ba628 00000001 c11ff354
[    2.710225] dcc0: d007dd14 c1fe1810 c1a15e00 c06bac30 00000000 d007dd14 c1a15e00 c06bab9c
[    2.718636] dce0: c1a15e00 c06b8380 60000113 c18b129c c1ae7734 6352e0ca c1211eac c1fe1810
[    2.727045] dd00: 00000001 c1a15e00 c1fe1854 c06ba8d4 cfbcbe20 c1fe1810 00000001 6352e0ca
[    2.735453] dd20: c1a15e00 c1fe1810 c1212468 c1fe1810 c19e2410 c06b952c c1fe1810 00000000
[    2.743862] dd40: c12b0060 c06b680c 00000200 00000000 00000000 00000000 00000000 6352e0ca
[    2.752270] dd60: c1fe1810 c1fe1800 cfbcbb44 c111a698 00000000 00000000 c111a698 c1a15e00
[    2.760679] dd80: 00000001 c099d734 cfbcbb44 c111a698 c111a7d8 00000000 00000000 c099d96c
[    2.769085] dda0: 00000000 6352e0ca 00000000 00000000 c19e2410 00000001 c19e2410 4a000000
[    2.777493] ddc0: 4a0007ff ff814cc8 00000200 00000000 00000000 00000000 00000000 6352e0ca
[    2.785900] dde0: cfbc977c cfbcbb44 cfba59c0 00000000 c111a698 c19e2410 00000001 00000000
[    2.794310] de00: c1805600 c099dcd0 00000001 00000000 c19e2410 cfba59c0 c111a698 00000000
[    2.802717] de20: 00000000 c1a15e00 c181200d c0554fe8 00000000 c19e2410 c11ff354 c06bc944
[    2.811127] de40: c19e2410 00000000 c11ff354 c06ba234 c19e2410 c11ff354 c19e2410 00000001
[    2.819533] de60: 00000000 c06ba4e0 60000113 c1a15e00 c12b0090 c11ff354 c19e2410 00000001
[    2.827943] de80: 00000000 c06ba628 00000001 c11ff354 d007dee4 c19e2410 00000000 c06bac30
[    2.836349] dea0: 00000000 d007dee4 c1a15e00 c06bab9c 00000000 c06b8380 60000113 c18b129c
[    2.844756] dec0: c1ae7734 6352e0ca c1805600 c19e2410 00000001 c1a15e00 c19e2454 c06ba8d4
[    2.853165] dee0: c19e2410 c19e2410 00000001 6352e0ca 00000000 c19e2410 c1212468 c19e2410
[    2.861576] df00: 00000000 c06b952c c19e2410 c12121e4 c12121f0 c06b9970 c1212214 c1aada00
[    2.869984] df20: c1261580 c1812000 00000000 c0147558 c1805600 c1805600 c1805618 c1aada00
[    2.878392] df40: c1805600 c1aada18 c1805618 c1187ae0 00000088 c1a15e00 c1805600 c0147a88
[    2.886802] df60: c1aada00 c1260c06 60000113 c1ad4380 c1a15e00 c0147858 c1aada00 c1ad4440
[    2.895211] df80: d006dec0 00000000 00000000 c014e520 c1ad4380 c014e448 00000000 00000000
[    2.903623] dfa0: 00000000 00000000 00000000 c0100148 00000000 00000000 00000000 00000000
[    2.912033] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    2.920442] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[    2.928857]  sysc_probe from platform_probe+0x5c/0xbc
[    2.934071]  platform_probe from really_probe+0xc8/0x2ec
[    2.939539]  really_probe from __driver_probe_device+0x88/0x1a0
[    2.945630]  __driver_probe_device from driver_probe_device+0x30/0x104
[    2.952343]  driver_probe_device from __device_attach_driver+0x94/0x108
[    2.959148]  __device_attach_driver from bus_for_each_drv+0x7c/0xc0
[    2.965596]  bus_for_each_drv from __device_attach+0xa8/0x1d8
[    2.971505]  __device_attach from bus_probe_device+0x84/0x8c
[    2.977326]  bus_probe_device from device_add+0x3a0/0x778
[    2.982895]  device_add from of_platform_device_create_pdata+0x9c/0xd0
[    2.989626]  of_platform_device_create_pdata from of_platform_bus_create+0x1a0/0x398
[    2.997594]  of_platform_bus_create from of_platform_populate+0x70/0xe0
[    3.004402]  of_platform_populate from simple_pm_bus_probe+0x90/0x94
[    3.010945]  simple_pm_bus_probe from platform_probe+0x5c/0xbc
[    3.016949]  platform_probe from really_probe+0xc8/0x2ec
[    3.022413]  really_probe from __driver_probe_device+0x88/0x1a0
[    3.028503]  __driver_probe_device from driver_probe_device+0x30/0x104
[    3.035215]  driver_probe_device from __device_attach_driver+0x94/0x108
[    3.042019]  __device_attach_driver from bus_for_each_drv+0x7c/0xc0
[    3.048467]  bus_for_each_drv from __device_attach+0xa8/0x1d8
[    3.054377]  __device_attach from bus_probe_device+0x84/0x8c
[    3.060198]  bus_probe_device from device_add+0x3a0/0x778
[    3.065756]  device_add from of_platform_device_create_pdata+0x9c/0xd0
[    3.072473]  of_platform_device_create_pdata from of_platform_bus_create+0x1a0/0x398
[    3.080441]  of_platform_bus_create from of_platform_populate+0x70/0xe0
[    3.087248]  of_platform_populate from simple_pm_bus_probe+0x90/0x94
[    3.093787]  simple_pm_bus_probe from platform_probe+0x5c/0xbc
[    3.099789]  platform_probe from really_probe+0xc8/0x2ec
[    3.105254]  really_probe from __driver_probe_device+0x88/0x1a0
[    3.111345]  __driver_probe_device from driver_probe_device+0x30/0x104
[    3.118061]  driver_probe_device from __device_attach_driver+0x94/0x108
[    3.124865]  __device_attach_driver from bus_for_each_drv+0x7c/0xc0
[    3.131310]  bus_for_each_drv from __device_attach+0xa8/0x1d8
[    3.137221]  __device_attach from bus_probe_device+0x84/0x8c
[    3.143042]  bus_probe_device from device_add+0x3a0/0x778
[    3.148599]  device_add from of_platform_device_create_pdata+0x9c/0xd0
[    3.155319]  of_platform_device_create_pdata from of_platform_bus_create+0x1a0/0x398
[    3.163286]  of_platform_bus_create from of_platform_populate+0x70/0xe0
[    3.170095]  of_platform_populate from simple_pm_bus_probe+0x90/0x94
[    3.176635]  simple_pm_bus_probe from platform_probe+0x5c/0xbc
[    3.182637]  platform_probe from really_probe+0xc8/0x2ec
[    3.188105]  really_probe from __driver_probe_device+0x88/0x1a0
[    3.194195]  __driver_probe_device from driver_probe_device+0x30/0x104
[    3.200910]  driver_probe_device from __device_attach_driver+0x94/0x108
[    3.207714]  __device_attach_driver from bus_for_each_drv+0x7c/0xc0
[    3.214158]  bus_for_each_drv from __device_attach+0xa8/0x1d8
[    3.220067]  __device_attach from bus_probe_device+0x84/0x8c
[    3.225889]  bus_probe_device from deferred_probe_work_func+0x78/0xa4
[    3.232514]  deferred_probe_work_func from process_one_work+0x1c0/0x4c0
[    3.239337]  process_one_work from worker_thread+0x230/0x584
[    3.245165]  worker_thread from kthread+0xd8/0x108
[    3.250107]  kthread from ret_from_fork+0x14/0x2c
[    3.254949] Exception stack(0xd007dfb0 to 0xd007dff8)
[    3.260141] dfa0:                                     00000000 00000000 00000000 00000000
[    3.268549] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.276957] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    3.283759] Code: e3130004 1a000145 e5943014 e0833002 (e5933000)
[    3.290026] ---[ end trace 0000000000000000 ]---
[    3.294769] note: kworker/u2:3[29] exited with irqs disabled
