cc2540 编译出错
BLE-CC254x-1.4.1.43908b\Projects\ble\SimpleBLESwitch\CC2540DB工程中,打开HAL_UART=TRUE后,编译出现错误:
Error[e16]: Segment XDATA_I (size: 0x358 align: 0) is too long for segment definition. At least 0x13a more bytes needed. The problem occurred while processing the segment placement command "-Z(XDATA)XDATA_Z,XDATA_I=_XDATA_START-_XDATA_END", where at the moment of placement the available memory ranges were "XDATA:1ce2-1eff"......
求救  可以解决吗?
