Other Parts Discussed in Thread: CC1101, SIMPLICITI, CC2500, CC1100
我运行了这两条指令:
CC1101_SET_CSN_HIGH( );
CC1101_Write_Cmd(CC1101_SPWD);
但是进不去睡眠模式,请问还应该配置其他的地方么?
你可以参考simpliciTI代码中关于sleep和wakeup的操作
* @fn MRFI_Sleep
* @brief Request radio go to sleep.
* @param none
* @return none
void MRFI_Sleep(void)
bspIState_t s;
/* Critical section necessary for watertight testing and
* setting of state variables.
BSP_ENTER_CRITICAL_SECTION(s);
/* If radio is not asleep, put it to sleep */
if(mrfiRadioState != MRFI_RADIO_STATE_OFF)
/* go to idle so radio is in a known state before sleeping */
MRFI_RxIdle();
mrfiSpiCmdStrobe( SPWD );
/* Our new state is OFF */
mrfiRadioState = MRFI_RADIO_STATE_OFF;
BSP_EXIT_CRITICAL_SECTION(s);
* @fn MRFI_WakeUp
* @brief Wake up radio from sleep state.
* @param none
* @return none
void MRFI_WakeUp(void)
/* if radio is already awake, just ignore wakeup request */
return;
/* drive CSn low to initiate wakeup */
MRFI_SPI_DRIVE_CSN_LOW();
/* wait for MISO to go high indicating the oscillator is stable */
while (MRFI_SPI_SO_IS_HIGH());
/* wakeup is complete, drive CSn high and continue */
MRFI_SPI_DRIVE_CSN_HIGH();
* The test registers must be restored after sleep for the CC1100 and CC2500 radios.
* This is not required for the CC1101 radio.
#ifndef MRFI_CC1101
mrfiSpiWriteReg( TEST2, SMARTRF_SETTING_TEST2 );
mrfiSpiWriteReg( TEST1, SMARTRF_SETTING_TEST1 );
mrfiSpiWriteReg( TEST0, SMARTRF_SETTING_TEST0 );
#endif
/* enter idle mode */
mrfiRadioState = MRFI_RADIO_STATE_IDLE;
MRFI_STROBE_IDLE_AND_WAIT();
#ifdef MRFI_TIMER_ALWAYS_ACTIVE
stx_active = false; // indicate we're not in transmit
#endif // MRFI_TIMER_ALWAYS_ACTIVE
