Other Parts Discussed in Thread: CC110L
最近在用CC110L做简单的发射功能的时候,发现发出来的数据刚好是反的,0变成1,1变成了0,前导字节和同步字节也是反的,是不是哪个寄存器没配置和好的关系,有没有大神遇到过这个问题,求帮助~~
你检查一下PATABLE的配置。
For OOK modulation, FREND0.PA_POWER should be 1 and the logic 0 and logic 1 power levels shall be programmed to index 0 and 1 respectively. For all other modulation formats, the desired output power should be programmed to index 0.
