wl1271的AP功能 不能实现?
Other Parts Discussed in Thread: AM3715, AM3359
平台:AM3715+wl1271L
内核:2.6.37
问题:调试sdio 的wifi1271现在基本通了,过去2.6.32内核各种弊端都得以解决,但现在实现soft-AP出现以下问题,希望yao工能给点意见:
   1.识别的wifi只有802.11abg,并非802.11abgn,这点跟刚拿到手的AM3359有区别,并且3359使用的kernel是3.x.x,难道还要升内核?
   2.使用iw list 获取到Supported interface modes只有IBSS managed monitor,并没有AP,3359是有的,而且还多一个soft interface modes。
   3.hostapd已经使用过多个版本了,应该是没有问题的。AM3715的内核印象中只到了2.6.37,请教yao工和各位工程师给点意见了,谢谢!
root@GeoElectron:~# hostapd -d -B /etc/hostapd.conf
random: Trying to read entropy from /dev/random
Configuration file: /etc/hostapd.conf
ctrl_interface_group=0
nl80211: interface wlan0 in phy phy0
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
nl80211: Add own iwl1271_sdio_power_off...
nterface ifindex 4
nl80211: Set mode ifindex 4 iftype 3 (AP)
nl80211: Failed to set interface 4 to mode 3: -95 (Operation not supported)
nl80211: Interface already in requested mode - ignore error
nl80211: Setup AP - device_ap_sme=0 use_monitor=1
nl80211: Create interface iftype 6 (MONITOR)
nl80211: New interface mon.wlan0 created: ifindex=5
nl80211: Add own interface ifindex 5
Could not set interface mon.wlan0 flags (UP): Cannot assign requested address
nl80211: Remove interface ifindex=5
nl80211: Failed to set interface wlan0 into AP mode
netlink: Operstate: linkmode=0, operstate=6
nl80211: Set mode ifindex 4 iftype 2 (STATION)
nl80211 driver initialization failed.
root@GeoElectron:~# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
sit0 no wireless extensions.
wlan0 IEEE 802.11abg ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
root@GeoElectron:~#
