CC1200 137–158.3MHz 的外围电路如何设计,是否可以按照169 MHz的外围电路通过修改寄存器达到140Mhz?
169 MHz: http://www.ti.com/tool/cc1120em-169-rd. This is for CC1120, but you can use this and simply change to CC1200 and use 40 MHz crystal. This design can be used as a starting point and might need to be tweaked for optimum performance at 140 MHz.
