1394 PHY
Hello everyone! I now use a physical layer chip of 1394 such as TSB41BA3B-EP(or other chip with same funcyions). I want to transfer the data received  from TPA/B0 directly to TPA/B1 or TPA/B2 without going through the link layer. I would like to ask how to configure the specific pin to achieve this function? Tanks you very much if you can give any ideas!
