安装DLP ALC SDK时出现的问题
按照指导一步步进行安装。出现了如下问题:
Configuring incomplete, errors occurred!
See also "C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0_build/CMakeFiles/CMakeOutput.log".
指导书中没有提到该问题,请问如何解决?
5 个回复
  • 您好!
    感谢使用TI的DLP产品。
    可以更详细描述下问题吗?比如在哪一步碰到的问题,具体的配置是什么样的。
  • 回复 Kevin Shi:
    我根据dlpu042文件进行环境配置,到第8步"Building the DLP ALC SDK"其中的第四小步:Click “Configure.” Use MinGW Makefiles and default native compilers as in Section 6. Allow CMake to run.
    "Note: If you get an error as shown in Figure 46, you may need to point CMake to the location of
    OpenCV. In “Ungrouped entries” look for OpenCV_DIR and browse for the location of OpenCV on
    your machine. As shown in Figure 47 an example is: C:/OpenCV. Click “Configure” once the path has
    been specified. There should be no errors displayed."文件中说明的这个问题,我也碰到了,已经解决。但解决该问题之后,后面依然出现了错误,文件中没有提及。报错内容如下:
    CMake Error at CMakeLists.txt:343 (file):
    file COPY cannot find
    "C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK/PG_FLYCAP_BIN_DIR-NOTFOUND/FlyCapture2.dll".
    CMake Error at CMakeLists.txt:344 (file):
    "C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK/PG_FLYCAP_BIN_DIR-NOTFOUND/FlyCapture2_C.dll".
    CMake Error at CMakeLists.txt:345 (file):
    "C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK/PG_FLYCAP_BIN_DIR-NOTFOUND/libiomp5md.dll".
    CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
    Please set them or make sure they are set and tested correctly in the CMake files:
    PG_FLYCAP_INCLUDE_DIR
    used as include directory in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    PG_FLYCAP_LIB
    linked by target "DLP_SDK" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    linked by target "generate_structured_light_patterns" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    linked by target "returncode_example" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    linked by target "image_file_io" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    linked by target "image_pixels" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    linked by target "image_window" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    linked by target "camera_view_opencv" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    linked by target "generate_graycode_patterns" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    linked by target "point_cloud_viewer" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    linked by target "camera_view_pg_flycap2_c" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    linked by target "camera_config_pg_flycap2_c" in directory C:/TexasInstruments-DLP/DLP-ALC-LIGHTCRAFTER-SDK-2.0/DLP-ALC-LIGHTCRAFTER-SDK
    PG_FLYCAP_LIB_C
    WIN32_SETUPAPI_LIB
    WIN32_WS2_32_LIB
  • 回复 user5949072:
    请参考如下FAQ第十一条。
  • 回复 Kevin Shi:
    官网上没有找到2.11版本的FlyCapture,我在其他网站上找到的2.11.3.425版本安装后,又出现如下问题:
    WIN32_SETUPAPI_LIB
    WIN32_WS2_32_LIB
    请问如何解决
  • 回复 user5949072:
    请提供详细配置界面。
