ti-sdk-am335x-evm-06.00.00.00找不到TI's ADC driver
我要把接在AIN0引脚上的电压做模数转换,参考AM335X ADC Driver's Guide:http://processors.wiki.ti.com/index.php/AM335x_ADC_Driver%27s_Guide   但是,我找不到这个编译选项 TI's ADC driver:
Device Drivers  --->
         [*]  Staging drivers  --->
                  [*]  Industrial I/O support  --->
                  [*]  Enable buffer support within IIO
                  <*>     Industrial I/O lock free software ring
                  < >     Industrial I/O buffering based on kfifo
                  -*-  Enable triggered sampling support
                  (2)     Maximum number of consumers per trigger
                       Analog to digital converters  --->
                                <*>   TI's ADC driver
  •  进如menuconfig菜单后,用“/”查找即可。
  • 这里还有个文档 http://processors.wiki.ti.com/index.php/AM335x_ADC_Driver%27s_Guide
  • 在对应的ti-sdk-am335x-evm-06.00.00.00的linux内核目录下,内容是:
          < > Analog Devices AD7291 ADC driver (NEW)
          < > Analog Devices AD7298 ADC driver (NEW)
          < > Analog Devices AD7606 ADC driver (NEW)
          < > Analog Devices AD799x ADC driver (NEW)
          < > Analog Devices AD7475/6/7/8 AD7466/7/8 and AD7495 ADC driver
          < > Analog Devices AD7887 ADC driver (NEW)
          < > Analog Devices AD7780 AD7781 ADC driver (NEW)
          < > Analog Devices AD7792 AD7793 ADC driver (NEW)
          < > Analog Devices AD7816/7/8 temperature sensor and ADC driver (
          < > Analog Devices AD7190 AD7192 AD7195 ADC driver (NEW)
  • 贴图那么明白了,还是没找到???
