Other Parts Discussed in Thread: TIDA-00913
TI INSTASPIN 下桥臂电阻采样改为U V W电流传感器采样,软件上要改什么地方啊?或者怎样换算符合算法要求?
首先你要计算一下换算比例,然后修改user.h中的USER_ADC_FULL_SCALE_CURRENT_A
其次: 修改hal.h中的readAdcData函数,如下标黄色三个值的正负符号,注意,算法里面以流进去电机电流的方向为正,如果你用霍尔采样,再经过运放,最终确定一下这个电流方向,如果反相了,则在value前面加符号。
static inline void HAL_readAdcData(HAL_Handle handle,HAL_AdcData_t *pAdcData)
HAL_Obj *obj = (HAL_Obj *)handle;
_iq value;
_iq current_sf = HAL_getCurrentScaleFactor(handle);
_iq voltage_sf = HAL_getVoltageScaleFactor(handle);
// convert current A
// sample the first sample twice due to errata sprz342f, ignore the first sample
value = (_iq)ADC_readResult(obj->adcHandle,ADC_ResultNumber_1);
value = _IQ12mpy(value,current_sf) - obj->adcBias.I.value[0]; // divide by 2^numAdcBits = 2^12
pAdcData->I.value[0] = value;
// convert current B
value = (_iq)ADC_readResult(obj->adcHandle,ADC_ResultNumber_2);
value = _IQ12mpy(value,current_sf) - obj->adcBias.I.value[1]; // divide by 2^numAdcBits = 2^12
pAdcData->I.value[1] = value;
// convert current C
value = (_iq)ADC_readResult(obj->adcHandle,ADC_ResultNumber_3);
value = _IQ12mpy(value,current_sf) - obj->adcBias.I.value[2]; // divide by 2^numAdcBits = 2^12
pAdcData->I.value[2] = value;
另外一个函数,updateAdcBias, 如果是正相采样,则bias +=, 否则 -=。
static inline void HAL_updateAdcBias(HAL_Handle handle)
uint_least8_t cnt;
_iq bias;
// update the current bias
for(cnt=0;cnt<HAL_getNumCurrentSensors(handle);cnt++)
bias = HAL_getBias(handle,HAL_SensorType_Current,cnt);
bias += OFFSET_getOffset(obj->offsetHandle_I[cnt]);
HAL_setBias(handle,HAL_SensorType_Current,cnt,bias);
ERIC
