"D:/Tms320f28335Project/DSP2833x/v131/DSP2833x_common/lib/fft.lib<cfft32i.obj>" specifies ISA revision "C2800", which is not compatible with ISA revision "C28FPU32" specified in a previous file or on the command line
总共添加了两个库fft.lib与rts2800_fpu32.lib,编译提示错误,求各位大神解答?
用的是tms320f28335,环境CCS3.3
