Warning: creating output section $ build.attributes without SECTIONS问题解答
Other Parts Discussed in Thread: CCSTUDIO
编译的时候还是出现了如下的一个编译错误:
-------------------------  TestAppEncoder.pjt - Debug  -------------------------
[Linking...] "C:\CCStudio_v3.3\C6000\cgtools\bin\cl6x" -@"Debug.lkf"
<Linking>
>> warning: creating output section $build.attributes without SECTIONS
            specification
>> internal error: ABBREV_TABLE::find_decl: decl_map is not available
>> Compilation failure
Build Complete,
  2 Errors, 1 Warnings, 0 Remarks.
相关解决方法:
根据您的描述,这应该是由于CCS Code Generation Tools版本过低引起的。编译DM6446_h264enc_2_xx应该使用其User's Guide提到的CGTools6.1.2或更新的版本。而CCS3.3自带的为CGTools v6.0.8,你需要到下面的链接注册并下载新版本的Code Generation Tools。
https://www-a.ti.com/downloads/s ... GenerationTools.htm
