SysCtl_disableSRAMBank(SYSCTL_SRAM_BANK2); 变量SYSCTL_SRAM_BANK2 CCS不认识
请问TI工程师:
      SysCtl_disableSRAMBank(SYSCTL_SRAM_BANK2);     为何变量 SYSCTL_SRAM_BANK2  CCS无法识别  是不是需要加上头文件
    我默认的 #include <ti/devices/msp432p4xx/driverlib/driverlib.h>  是不是不够
  • 我在TI例程内加入了您的上述语句是可以的
    程序如下
    /* --COPYRIGHT--,BSD
     * Copyright (c) 2017, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     *    notice, this list of conditions and the following disclaimer.
     * *  Redistributions in binary form must reproduce the above copyright
     *    notice, this list of conditions and the following disclaimer in the
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     *    its contributors may be used to endorse or promote products derived
     *    from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     * --/COPYRIGHT--*/
     * MSP432 Clock System - Clock Source Initialization
     * Description: In this code example, the CS_initClockSignal is used to
     * initialize every clock on the controller to a non-default value. The
     * CS_initClockSignal function is one of the most convenient CS functions as it
     * provides a readable/usable method for users to initialize specific clock
     * sources to a specific clock signal. Once each clock source is initialized,
     * the convenience functions that get clock frequencies are used to assign
     * the frequencies to variables. The user can pause the debugger to observe
     * that the correct frequencies have been assigned to the variables.
     * MCLK = MODOSC/4 = 6MHz
     * ACLK = REFO/2 = 16kHz
     * HSMCLK = DCO/2 = 1.5Mhz
     * SMCLK = DCO/4 = 750kHz
     * BCLK  = REFO = 32kHz
     *              MSP432P401
     *          --|RST               |
    /* DriverLib Includes */
    /* Standard Includes */
    #include <stdint.h>
    /* Statics */
    static volatile uint32_t aclk, mclk, smclk, hsmclk, bclk;
    int main(void)
        /* Halting WDT */
        MAP_WDT_A_holdTimer();
        /* Initializing the clock source as follows:
        MAP_CS_initClockSignal(CS_MCLK, CS_MODOSC_SELECT, CS_CLOCK_DIVIDER_4);
        MAP_CS_initClockSignal(CS_ACLK, CS_REFOCLK_SELECT, CS_CLOCK_DIVIDER_2);
        MAP_CS_initClockSignal(CS_HSMCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_2);
        MAP_CS_initClockSignal(CS_SMCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_4);
        MAP_CS_initClockSignal(CS_BCLK, CS_REFOCLK_SELECT, CS_CLOCK_DIVIDER_1);
         *  Getting all of the frequency values of the CLK sources using the
         * convenience functions */
        aclk = CS_getACLK();
        mclk = CS_getMCLK();
        smclk = CS_getSMCLK();
        hsmclk = CS_getHSMCLK();
        bclk = CS_getBCLK();
        SysCtl_disableSRAMBank(SYSCTL_SRAM_BANK2); //susan
         * Staying in active mode so that the user can see the values that are put
         * in the above registers through the debugger
        while (1)
    您现在有没有将driverlib的路径加入工程?如下图所示
  • 应该是库文件这边不全~~ 谢谢Susan Yang
  • 要使用驱动库的话是去CCS的设置里面添加库文件的
    祝你成功
