Part Number: LM7301
Can you please help regarding the following query and ask for the details from TI:
During product testing, we noticed that the parameters of component 4002136 (MPN: LM7301IM5X/NOPB) from PO 3619089, DC 2437, had been changed. It has a higher gain coefficient, as a result of which the product cannot calibrate itself during the “self-test” and triggers an 06 error.
Components from DC 2405 did not exhibit this issue.
After discussions with our customer, we will implement a design change by removing one of the components in the product, which will resolve this issue.
Can you please check with TI if there really was a change what customer is referring to and if yes, which PCN is including this information?
