如题,求解决
希望这个文档对你有所帮助,自己建spice吧,有参数的。
* Library of Burr-Brown Opamps * $Revision: 1.28 $ * $Author: RPEREZ $ * $Date: 25 Mar 1998 08:47:36 $ * ************************************************************************** * * WELCOME TO * * BURR-BROWN CORPORATION * *** BASED MACROMODEL LIBRARY * * 6730 S. TUCSON BLVD. * TUCSON, AZ 85706 * 800-548-6132 * * * * INTRODUCTION * This library is a collection of *** macromodels of BURR-BROWN op amps, * difference amps, instrumentation amps, isolation amps, and analog * function circuits. * * The Standard macromodels were derived using standard simulation * software. This software uses the common Boyle op amp model structure. * * The second level of macromodel is an enhanced version of the standard * model, which is indicated by the suffix "E" in the model's name. * These models offer improved behaviour in terms of input bias current * and quiescent power. Also, voltage and current noise as well * as input capacitance is added. * * The Multiple Pole/Zero macromodels uses the same input stage as the * standard or enhanced op amp macromodel, but has multiple poles and * pole/zero pairs in the mid-section. These models have the designation * "M", and are primarily used for wide bandwidth op amps. * * In some instances, a fourth type of model is available, which are * designated by either a "X", "X1" or a "X2" suffix. The models of this * level are not a "macromodel", but rather a simplified circuit model * at the transistor level. * * This library is complemented by the application bulletin AB-020F, which * contains more information and details on the topologies used. Please write or call * BURR-BROWN at the address and number given above in order to obtain one. * * APPLICATION INFORMATION * This library and the application bulletin are revised frequently. * To ensure that you have the most current revision, please contact your * nearest sales office or BURR-BROWN directly. * * Each model net-list starts with a header containing the part number and the * revision date. The structure of the net-list co * Also, the format of the file specification has been changed in order * to provide a better and faster overview. The 'date' following the file * name now reflects the actual date of creation of each model. The 'time' * is now used as an indicator for the revision status of each model. * For example: * OPA131E.MOD 1-15-95 1:00:00 am ---> REV.A * OPA121E.MOD 3-21-92 2:00:00 am ---> REV.B etc. * * Happy simulation!! * * ------------------------------------------------------------------------ * | NOTICE: THE INFORMATION PROVIDED HEREIN IS BELIEVED TO BE RELIABLE; | * | HOWEVER; BURR-BROWN ASSUMES NO RESPONSIBILITY FOR INACCURACIES OR | * | OMISSIONS. BURR-BROWN ASSUMES NO RESPONSIBILITY FOR THE USE OF THIS | * | INFORMATION, AND ALL USE OF SUCH INFORMATION SHALL BE ENTIRELY AT | * | THE USER'S OWN RISK. NO PATENT RIGHTS OR LICENSES TO ANY OF THE | * | CIRCUITS DESCRIBED HEREIN ARE IMPLIED OR GRANTED TO ANY THIRD PARTY. | * | BURR-BROWN DOES NOT AUTHORIZE OR WARRANT ANY BURR-BROWN PRODUCT FOR | * | USE IN LIFE-SUPPORT DEVICES AND/OR SYSTEMS. | * ------------------------------------------------------------------------ * While reasonable care has been taken in their preparation, we cannot * be responsible for correct application on any and all computer * systems. * * Model users are hereby notified that these models are supplied * "as is", with no direct or implied responsibility on the part of * Burr-Brown for their operation within a customer circuit or system. * Further, Burr-Brown Corporation reserves the right to change these * models without prior notice. * * In all cases, the current data sheet information for a given real * device is your final design guideline, and is the only actual * performance guarantee. *$ ************************************************************************** * ACF2101M (switched integrator) MULTIPLE POLE/ZERO MACROMODEL * Created 2-14-92 BCB * REV.B 3/21/92 BCB input bias current correction circuitry added * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * | | * | Neither this library nor any part may be copied without | * | the express written consent of Burr-Brown Corporation. | * | | * | The users should carefully note the following factors | * | regarding this model. | * | | * |-------------------------------------------------------------| * * NOTES : * 1. The transient time for the input to the switches (HOLD, * RESET, and SELECT) should be programmed to 6V/usec. * Complying with this requirment will give you greater * success in convergence during transient analysis and * a more accurate simulation of the effect of the 200nsec * switching speed of the actual switching transistors in * the ACF2101. This is easily implemented with the PULSE * command in ***. If your input signal to the switches * is faster than recommended above, the R-C, low-pass filter * on the input of the switch will slow the signal down some- * what, however not enough to comply with the data sheet stated * switching speeds of 200nsec. * 2. To insure proper operation, always establish the initial * bias point for the transient analysis with RESET and * HOLD equal to the potential at COM * * COMMON * | SWITCH IN * | | IN * | | | CAPACITOR * | | | | OUTPUT * | | | | | SWITCH OUT * | | | | | | SWITCH COMMON * | | | | | | | RESET * | | | | | | | | HOLD * | | | | | | | | | SELECT * | | | | | | | | | | POSITIVE SUPPLY * | | | | | | | | | | | NEGATIVE SUPPLY * | | | | | | | | | | | | GROUND * | | | | | | | | | | | | | .SUBCKT ACF2101M/BB 3 31 2 37 6 32 33 36 34 35 7 4 30 * * Amp input stage (2nd pole @ 35M Hz) J11 15 2 14 JX J12 16 13 14 JX C12 15 16 18.2E-12 R13 15 7 796 R14 16 7 796 ISS 14 4 1.11E-3 VOS 13 3 0.5E-3 G1 2 30 POLY(3) (15,2) (14,2) (30,2) 0 1E-12 1E-12 1E-12 G2 13 30 POLY(3) (16,13) (14,13) (30,13) 0 1E-12 1E-12 1E-12 * Amp gain stage (130dB) and first pole (@ 4.20K HZ) R27 7 21 2.45E9 R28 4 21 2.45E9 C22 7 21 100E-12 C23 4 21 100E-12 G21 7 21 POLY(1) 15 16 1.751E-3 1.256E-3 G22 21 4 POLY(1) 16 15 1.751E-3 1.256E-3 V21 22 3 0.409 V22 23 4 1.885 D21 21 22 DX D22 23 21 DX * Amp correction current and output stage IPS 7 30 9E-3 RPS 7 30 100E3 R9 7 71 100E3 R10 4 71 100E3 D91 21 6 DX D92 6 21 DX D93 7 94 DX D94 7 95 DX D95 4 94 DY D96 4 95 DY G91 7 6 21 7 .020387 G92 4 6 21 4 .020387 G95 94 4 6 21 .020387 G96 95 4 21 6 .020387 R91 7 6 49.051 R92 4 6 49.051 CINT 37 6 CC 100E-12 * Switches SH1 31 2 34 30 SWH SH2 31 2 31 30 SWT SR 2 6 36 30 SWH SS 6 32 35 30 SWS SC 3 33 35 30 SWS * * Models .MODEL JX NJF(BETA=.788E-3 VTO=-2 IS=5E-14) .MODEL DX D(IS=1E-15) .MODEL DY D(IS=1E-15 BV=50) .MODEL SWH VSWITCH(RON=1000G ROFF=1.5K VON=2 VOFF=0.8) .MODEL SWS VSWITCH(RON=1000G ROFF=250 VON=2 VOFF=0.8) .MODEL SWT VSWITCH(RON=1000G ROFF=10 VON=0.45 VOFF=0.55) .MODEL CC CAP(VC1=25E-6 TC1=-25E-6) .ENDS *$ ************************************************************************** * BUF600X1 - DIAMOND BUFFER MACROMODEL SIMPLIFIED VERSION * CREATED 8/92 KL * REV.B 7/9/93 BCB : CLARIFICATION OF NODE SET INSTRUCTIONS * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------|* * * NOTE : THIS MACRO MODEL WILL CONVERGE QUICKER BY USING THE * NODESETS V(Xyour.21)=+4.2847 AND V(Xyour.24)=-4.2855 IN THE ROOT * SIMULATION FILE. ("Xyour" IS DEVICE NAME CALLED OUT IN * ROOT SIMULATION FILE.) * * * CONNECTIONS: POSITIVE POWER SUPPLY * | VOLTAGE IN * | | NEGATIVE POWER SUPPLY * | | | VOLTAGE OUT * | | | | .SUBCKT BUF600X1/BB 1 4 5 8 * C208 8 0 2E-12 I21 21 24 0.1E-6 V41 1 41 1.5 V42 42 5 1.5 C33 33 0 2E-12 C39 39 0 0.02E-12 C40 40 0 0.02E-12 R33 33 0 6.4E6 R34 33 4 100 RQC 22 5 590 Q21 21 21 1 5 PI Q22 21 24 22 1 NI 12 Q23 24 21 1 5 PI Q24 24 24 5 1 NI Q29 39 21 1 5 PI Q30 40 24 5 1 NI Q33 5 33 39 5 PI Q34 1 33 40 1 NI Q41 41 39 8 1 NIL 16 Q42 42 40 8 5 PIL 16 * .MODEL PI PNP .MODEL NI NPN .MODEL NIL NPN (BF = 500) .MODEL PIL PNP (BF = 500) .ENDS *$ ************************************************************************** * BUF600X2 - DIAMOND BUFFER MACROMODEL COMPLEX VERSION * CREATED 8/92 KL * REV.B 7/9/93 BCB : CLARIFICATION OF NODE SET INSTRUCTIONS * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * NOTE : THIS MACROMODEL WILL CONVERGE QUICKER IF THE NODESETS * V(Xyour.21)=+4.2902, V(Xyour.24)=-4.2910, * V(Xyour.27)=+4.2131 AND * V(Xyour.28)=-4.2129 IN THE ROOT SIMULATION FILE. * ("Xyour" IS DEVICE NAME CALLED OUT IN ROOT SIMULATION FILE.) * * CONNECTIONS: POSITIVE POWER SUPPLY * | VOLTAGE IN * | | NEGATIVE POWER SUPPLY * | | | VOLTAGE OUT * | | | | .SUBCKT BUF600X2/BB 1 4 5 8 * I21 21 24 0.1E-6 RQC 22 5 730 C204 4 0 2E-12 C208 8 0 2E-12 Q21 21 21 1 5 PI Q22 21 24 22 1 NI 12 Q23 24 21 1 5 PI Q24 24 24 5 1 NI Q25 28 21 1 5 PI Q26 27 24 5 1 NI Q27 27 27 1 5 PIJ 1.4 Q28 28 28 5 1 NIJ 1.4 Q29 31 27 1 5 PIJ 1.4 Q30 32 28 5 1 NIJ 1.4 Q31 31 31 35 1 NIJ 2 Q32 32 32 36 5 PIJ 2 Q33 28 4 35 5 PIJ Q34 27 4 36 1 NIJ Q35 35 35 34 1 NIJ Q36 36 36 34 5 PIJ Q37 1 31 39 1 NIJ 6 Q38 5 32 40 5 PIJ 6 Q39 39 39 41 1 NIJ 6 Q40 40 40 41 5 PIJ 6 Q41 1 39 8 1 NIJ 16 Q42 5 40 8 5 PIJ 16 * .MODEL NI NPN .MODEL PI PNP .MODEL PIJ PNP +(BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680 * .MODEL NIJ NPN +(BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) .ENDS *$ ************************************************************************** * BUF601X1 - DIAMOND BUFFER MACROMODEL SIMPLIFIED VERSION * CREATED 8/92 KL * REV.B 7/9/93 BCB : CLARIFICATION OF NODE SET INSTRUCTIONS * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * NOTE : THIS MACROMODEL WILL CONVERGE QUICKER IS THE NODESETS * V(Xyour.21)=+4.2689 AND V(Xyour.24)=-4.2697 ARE IN THE * ROOT SIMULATION FILE. ("Xyour" IS DEVICE NAME IN ROOT * FILE.) * * CONNECTIONS: POSITIVE POWER SUPPLY * | VOLTAGE IN * | | NEGATIVE POWER SUPPLY * | | | VOLTAGE OUT * | | | | .SUBCKT BUF601X1/BB 1 4 5 8 * I21 21 24 0.1E-6 V41 1 41 1.5 V42 42 5 1.5 C33 33 0 2E-12 C39 39 0 0.04E-12 C40 40 0 0.04E-12 C208 8 0 2E-12 R33 33 0 2.4E6 R34 33 4 65 RQC 22 5 320 Q21 21 21 1 5 PI Q22 21 24 22 1 NI 12 Q23 24 21 1 5 PI Q24 24 24 5 1 NI Q29 39 21 1 5 PI Q30 40 24 5 1 NI Q33 5 33 39 5 PI Q34 1 33 40 1 NI Q41 41 39 8 1 NIL 16 Q42 42 40 8 5 PIL 16 * .MODEL PI PNP .MODEL NI NPN .MODEL NIL NPN (BF = 500) .MODEL PIL PNP (BF = 500) .ENDS *$ ************************************************************************** * BUF601X2 - DIAMOND BUFFER MACROMODEL COMPLEX VERSION * CREATED 8/92 KL * REV.B7/9/93 BCB : CLARIFICATION OF NODE SET INSTRUCTIONS. * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * NOTE : THIS MACROMODEL WILL CONVERGE QUICKER IF THE NODESET * V(Xyour.27)=+4.1907, V(Xyour.28)=-4.1904, V(Xyour.21)=+4.2689, * AND V(Xyour.24)=-4.2697 ARE INCLUDED IN THE ROOT SIMULATION * FILE. ("Xyour" IS DEVICE CALLED OUT IN ROOT FILE.) * * CONNECTIONS: POSITIVE POWER SUPPLY * | VOLTAGE IN * | | NEGATIVE POWER SUPPLY * | | | VOLTAGE OUT * | | | | .SUBCKT BUF601X2/BB 1 4 5 8 * I21 21 24 0.1E-6 RQC 22 5 351 C204 4 0 2E-12 C208 8 0 2E-12 Q21 21 21 1 5 PI Q22 21 24 22 1 NI 12 Q23 24 21 1 5 PI Q24 24 24 5 1 NI Q25 28 21 1 5 PI Q26 27 24 5 1 NI Q27 27 27 1 5 PIJ 1.4 Q28 28 28 5 1 NIJ 1.4 Q29 31 27 1 5 PIJ 1.4 Q30 32 28 5 1 NIJ 1.4 Q31 31 31 35 1 NIJ 2 Q32 32 32 36 5 PIJ 2 Q33 28 4 35 5 PIJ Q34 27 4 36 1 NIJ Q35 35 35 34 1 NIJ Q36 36 36 34 5 PIJ Q37 1 31 39 1 NIJ 6 Q38 5 32 40 5 PIJ 6 Q39 39 39 41 1 NIJ 6 Q40 40 40 41 5 PIJ 6 Q41 1 39 8 1 NIJ 16 Q42 5 40 8 5 PIJ 16 * .MODEL PI PNP .MODEL NI NPN .MODEL PIJ PNP +(BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) * .MODEL NIJ NPN +(BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) .ENDS *$ ************************************************************************** * BUF634X SIMPLIFIED CIRCUIT MACROMODEL * CREATED 1/2/95 SB * REV. A * * CONNECTIONS: INPUT * | POSITIVE POWER SUPPLY * | | NEGATIVE POWER SUPPLY * | | | OUTPUT * | | | | .SUBCKT BUF634X/BB 1 80 90 16 * RIN 1 2 200 R1 6 13 500 R2 4 9 500 RO1 15 16 5 RO2 16 17 5 R5 20 90 150 R6 23 90 12E3 R7 94 90 60 R8 98 90 40 R9 80 85 40 R10 80 86 60 CP 1 2 1E-10 C1 13 0 1.5E-12 C2 9 0 1.5E-12 CO 16 0 2E-12 Q1 5 2 3 QN 8 Q2 8 2 7 QP 8 Q3 4 8 94 QN 8 Q4 6 5 86 QP 8 Q5 90 9 10 QP 8 Q6 80 13 12 QN 8 Q7 90 10 17 QP 96 Q8 80 12 15 QN 96 Q9 22 21 20 QN 2 Q10 5 21 20 QN 2 Q11 22 24 80 QP 4 Q12 8 22 24 QP 4 D1 3 4 DX 8 D2 85 5 DX 8 D3 8 98 DX 8 D4 6 7 DX 8 D5 11 10 DX 2 D6 12 11 DX 2 D8 21 23 DX 2 D9 80 24 DX 4 D10 7 73 DX 8 D11 73 3 DX 8 ISS 80 21 60E-6 * Input Errors VOS 2 102 30E-3 IB 80 1 5E-6 CIN 1 0 6E-12 * Input Protection Circuit R29 2 57 1E3 R30 16 58 1E3 Q57 16 57 2 QN 4 Q58 2 58 16 QN 4 V1 16 57 3 V2 2 58 3 * Short Circuit Current Protection R24 15 14 1.5E3 R25 14 16 1E3 R26 16 18 1E3 R27 18 17 1.5E3 Q35 86 14 16 QN Q36 94 18 16 QP * .MODEL DX D(IS=8E-16) .MODEL QN NPN(IS=1E-15 BF=200) .MODEL QP PNP(IS=1E-15 BF=200) .ENDS *$ ************************************************************************** * BURR-BRN.LIB LINEAR DIVISION MACROMODEL FILE * REV.A CREATED JUNE 1997 BY NEIL P. ALBAUGH * BURR-BRN.SLB LINEAR DIVISION SYMBOL FILE FOR P-*** DESIGN CENTER(R)OrCad CORP * REV.A CREATED JUNE 1997 BY NEIL P. ALBAUGH * * ------------------------------------------------------------------------ * | NOTICE: THE INFORMATION PROVIDED HEREIN IS BELIEVED TO BE RELIABLE; | * | HOWEVER; BURR-BROWN ASSUMES NO RESPONSIBILITY FOR INACCURACIES OR | * | OMISSIONS. BURR-BROWN ASSUMES NO RESPONSIBILITY FOR THE USE OF THIS | * | INFORMATION, AND ALL USE OF SUCH INFORMATION SHALL BE ENTIRELY AT | * | THE USER'S OWN RISK. NO PATENT RIGHTS OR LICENSES TO ANY OF THE | * | CIRCUITS DESCRIBED HEREIN ARE IMPLIED OR GRANTED TO ANY THIRD PARTY. | * | BURR-BROWN DOES NOT AUTHORIZE OR WARRANT ANY BURR-BROWN PRODUCT FOR | * | USE IN LIFE-SUPPORT DEVICES AND/OR SYSTEMS. | * ------------------------------------------------------------------------ * * INA101 = A1_101 + A2_101 + A3_101 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 10/30/90 AT 15:01 * REV.A * * INA101 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SET 1 * | | | | | | | GAIN SET 2 * | | | | | | | | .SUBCKT INA101/BB 1 2 3 4 5 8 9 10 * * A1_101 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 2 9 3 4 11 A1_101 * * A2_101 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 1 10 3 4 12 A2_101 * * A3_101 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_101 * R1 11 13 10.0000K R2 13 5 9.9994K C2 13 5 0.8000PF R3 12 14 10.0000K R4 14 8 10.0000K RFB1 9 11 20.0000K CC1 9 11 15.0000PF RFB2 10 12 20.0000K CC2 10 12 15.0000PF .ENDS * * A1_101 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 12:56 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_101 1 2 3 4 5 * C1 11 12 8.660E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 70.20E6 -70E6 70E6 70E6 -70E6 GA 6 0 11 12 320.4E-6 GCM 0 6 10 99 2.022E-9 IEE 10 4 DC 30.05E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 3.121E3 RC2 3 12 3.121E3 RE1 13 10 1.394E3 RE2 14 10 1.394E3 REE 10 99 6.656E6 RO1 8 5 25 RO2 7 99 25 RP 3 4 10.70E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 10 VLN 0 92 DC 10 .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=600) .ENDS * * A2_101 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 11:30 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_101 1 2 3 4 5 * C1 11 12 8.660E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 59.67E6 -60E6 60E6 60E6 -60E6 GA 6 0 11 12 377.0E-6 GCM 0 6 10 99 1.192E-9 IEE 10 4 DC 30.05E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.653E3 RC2 3 12 2.653E3 RE1 13 10 926.8 RE2 14 10 926.8 REE 10 99 6.656E6 RO1 8 5 25 RO2 7 99 25 RP 3 4 10.70E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 10 VLN 0 92 DC 10 .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=600) .ENDS * * A3_101 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 11:39 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_101 1 2 3 4 5 * C1 11 12 8.660E-12 C2 6 7 10.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 358.0E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 62.83E-6 GCM 0 6 10 99 198.7E-12 IEE 10 4 DC 5.050E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 15.92E3 RC2 3 12 15.92E3 RE1 13 10 5.515E3 RE2 14 10 5.515E3 REE 10 99 39.60E6 RO1 8 5 25 RO2 7 99 25 RP 3 4 10.61E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 10 VLN 0 92 DC 10 .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=100) .ENDS *$ ************************************************************************** * INA101E = A1_101E + A2_101E + A3_101E OP AMPS + PRECISION RESISTOR NETWORK * "E" IS ENHANCED MODEL * CREATED ON 10/30/90 AT 15:01 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA101E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA101E/BB 1 2 3 4 5 8 9 10 * * A1_101E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 2 9 3 4 11 A1_101E * * A2_101E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 1 10 3 4 12 A2_101E * * A3_101E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_101E * R1 11 13 10.0000K R2 13 5 9.9994K C2 13 5 0.8000PF R3 12 14 10.0000K R4 14 8 10.0000K RFB1 9 11 20.0000K CC1 9 11 15.0000PF RFB2 10 12 20.0000K CC2 10 12 15.0000PF * .ENDS * * A1_101E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 12:56 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_101E INP INN 3 4 5 * C1 11 12 8.660E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 70.20E6 -70E6 70E6 70E6 -70E6 GA 6 0 11 12 320.4E-6 GCM 0 6 10 99 2.022E-9 IEE 10 4 DC 30.05E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 3.121E3 RC2 3 12 3.121E3 RE1 13 10 1.394E3 RE2 14 10 1.394E3 REE 10 99 6.656E6 RO1 8 5 25 RO2 7 99 25 * RP 3 4 10.70E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 10 VLN 0 92 DC 10 **************************** * A1_101 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 2.136E-3 1 FQ2 0 4 POLY(1) VQ2 2.136E-3 -1 * QUIESCIENT CURRENT RQ 3 4 4.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 3.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT PROTECTION R1IN INP 1 1000 D1IN 1 2 DX R2IN INN 2 1000 D2IN 2 1 DX * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=600) .ENDS * * A2_101E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 11:30 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_101E INP INN 3 4 5 * C1 11 12 8.660E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 59.67E6 -60E6 60E6 60E6 -60E6 GA 6 0 11 12 377.0E-6 GCM 0 6 10 99 1.192E-9 IEE 10 4 DC 30.05E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.653E3 RC2 3 12 2.653E3 RE1 13 10 926.8 RE2 14 10 926.8 REE 10 99 6.656E6 RO1 8 5 25 RO2 7 99 25 * RP 3 4 10.70E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 10 VLN 0 92 DC 10 **************************** * A2_101 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 2.136E-3 1 FQ2 0 4 POLY(1) VQ2 2.136E-3 -1 * QUIESCIENT CURRENT RQ 3 4 4.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 3.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT PROTECTION R1IN INP 1 1000 D1IN 1 2 DX R2IN INN 2 1000 D2IN 2 1 DX * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=600) .ENDS * * A3_101E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 11:39 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_101E 1 2 3 4 5 * C1 11 12 8.660E-12 C2 6 7 10.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 358.0E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 62.83E-6 GCM 0 6 10 99 198.7E-12 IEE 10 4 DC 5.050E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 15.92E3 RC2 3 12 15.92E3 RE1 13 10 5.515E3 RE2 14 10 5.515E3 REE 10 99 39.60E6 RO1 8 5 25 RO2 7 99 25 * RP 3 4 10.61E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 10 VLN 0 92 DC 10 **************************** * A3_101 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 2.162E-3 1 FQ2 0 4 POLY(1) VQ2 2.162E-3 -1 * QUIESCIENT CURRENT RQ 3 4 4.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 3.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=100) .ENDS *$ ************************************************************************** * INA102 = A1_102 + A2_102 + A3_102 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 10/30/90 AT 15:01 * REV.A * REV.B 16 June 97 NPA Added Note 1. * NOTE 1.USE EXTERNAL RESISTORS TO MODEL PIN-STRAPPED GAINS: Av= 1V/V RG= OPEN * Av= 10V/V RG=4.44K * Av= 100V/V RG=404 * Av= 1K V/V RG=40.4 * UNMODELLED PINS: 1. INTERNAL GAIN RESISTORS * 2. OFFSET NULL * 3. CMR TRIM & FILTER * REV.C 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA102 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SET 1 * | | | | | | | GAIN SET 2 * | | | | | | | | .SUBCKT INA102/BB 1 2 3 4 5 8 9 10 * * A1_102 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 2 9 3 4 11 A1_102 * * A2_102 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 1 10 3 4 12 A2_102 * * A3_102 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_102 * R1 11 13 20.000K R2 13 5 19.999K C2 13 5 6.000PF R3 12 14 20.000K R4 14 8 20.000K C4 14 8 5.000PF RFB1 9 11 20.000K CC1 9 11 5.000PF RFB2 10 12 20.000K CC2 10 12 5.000PF * .ENDS * * A1_102 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 15:39 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_102 1 2 3 4 5 * C1 11 12 8.660E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 47.37E6 -50E6 50E6 50E6 -50E6 GA 6 0 11 12 52.78E-6 GCM 0 6 10 99 1.053E-9 IEE 10 4 DC 6.050E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 18.95E3 RC2 3 12 18.95E3 RE1 13 10 10.24E3 RE2 14 10 10.24E3 REE 10 99 33.06E6 RO1 8 5 100 RO2 7 99 400 RP 3 4 186.8E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=120) .ENDS * * A2_102 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 15:36 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_102 1 2 3 4 5 * C1 11 12 8.660E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 44.21E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 56.55E-6 GCM 0 6 10 99 565.5E-12 IEE 10 4 DC 6.050E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 17.68E3 RC2 3 12 17.68E3 RE1 13 10 8.988E3 RE2 14 10 8.988E3 REE 10 99 33.06E6 RO1 8 5 100 RO2 7 99 400 RP 3 4 186.8E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=120) .ENDS * * A3_102 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 15:36 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_102 1 2 3 4 5 * C1 11 12 8.660E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 44.21E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 56.55E-6 GCM 0 6 10 99 565.5E-12 IEE 10 4 DC 6.050E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 17.68E3 RC2 3 12 17.68E3 RE1 13 10 8.988E3 RE2 14 10 8.988E3 REE 10 99 33.06E6 RO1 8 5 100 RO2 7 99 400 RP 3 4 186.8E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=120) .ENDS *$ ************************************************************************** * INA102E = A1_102E + A2_102E + A3_102E OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 10/30/90 AT 15:01 * REV.A * REV.B 16 June 97 NPA Added Note 1. * NOTE 1.USE EXTERNAL RESISTORS TO MODEL PIN-STRAPPED GAINS: Av= 1V/V RG= OPEN * Av= 10V/V RG=4.44K * Av= 100V/V RG=404 * Av= 1K V/V RG=40.4 * UNMODELLED PINS: 1. INTERNAL GAIN RESISTORS * 2. OFFSET NULL * 3. CMR TRIM & FILTER * REV.C 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA102E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SET 1 * | | | | | | | GAIN SET 2 * | | | | | | | | .SUBCKT INA102E/BB 1 2 3 4 5 8 9 10 * * A1_102E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 2 9 3 4 11 A1_102E * * A2_102E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 1 10 3 4 12 A2_102E * * A3_102E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_102E * R1 11 13 20.0000K R2 13 5 19.9990K C2 13 5 6.0000PF R3 12 14 20.0000K R4 14 8 20.0000K C4 14 8 5.0000PF RFB1 9 11 20.0000K CC1 9 11 5.0000PF RFB2 10 12 20.0000K CC2 10 12 5.0000PF * .ENDS * * A1_102E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 15:39 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_102E 1 2 3 4 5 * C1 11 12 8.660E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 47.37E6 -50E6 50E6 50E6 -50E6 GA 6 0 11 12 52.78E-6 GCM 0 6 10 99 1.053E-9 IEE 10 4 DC 6.050E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 18.95E3 RC2 3 12 18.95E3 RE1 13 10 10.24E3 RE2 14 10 10.24E3 REE 10 99 33.06E6 RO1 8 5 100 RO2 7 99 400 * RP 3 4 186.8E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 **************************** * A1_102 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.45E-4 1 FQ2 0 4 POLY(1) VQ2 1.45E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.0E6 * DIFF INPUT CAPACITANCE CDIF 1 2 2.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.0E-12 C2CM 2 99 1.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=120) .ENDS * * A2_102E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 15:39 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_102E 1 2 3 4 5 * C1 11 12 8.660E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 44.21E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 56.55E-6 GCM 0 6 10 99 565.5E-12 IEE 10 4 DC 6.050E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 17.68E3 RC2 3 12 17.68E3 RE1 13 10 8.988E3 RE2 14 10 8.988E3 REE 10 99 33.06E6 RO1 8 5 100 RO2 7 99 400 * RP 3 4 186.8E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 **************************** * A2_102 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.45E-4 1 FQ2 0 4 POLY(1) VQ2 1.45E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.0E6 * DIFF INPUT CAPACITANCE CDIF 1 2 2.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.0E-12 C2CM 2 99 1.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=120) .ENDS * * A3_102E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/06/90 AT 15:39 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_102E 1 2 3 4 5 * C1 11 12 8.660E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 44.21E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 56.55E-6 GCM 0 6 10 99 565.5E-12 IEE 10 4 DC 6.050E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 17.68E3 RC2 3 12 17.68E3 RE1 13 10 8.988E3 RE2 14 10 8.988E3 REE 10 99 33.06E6 RO1 8 5 100 RO2 7 99 400 * RP 3 4 186.8E3 VB 9 0 DC 0 VC 3 53 DC 2.500 VE 54 4 DC 2.500 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 **************************** * A3_102 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.45E-4 1 FQ2 0 4 POLY(1) VQ2 1.45E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.0E6 * DIFF INPUT CAPACITANCE CDIF 1 2 2.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.0E-12 C2CM 2 99 1.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=120) .ENDS *$ ************************************************************************** * INA103 = A1_103 + A2_103 + A3_103 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 10/30/90 AT 15:01 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA103 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA103/BB 1 2 3 4 5 8 9 10 * * A1_103 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_103 * * A2_103 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_103 * * A3_103 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_103 * R1 11 13 6.0000K R2 13 5 5.9994K C2 13 5 2.0000PF R3 12 14 6.0000K R4 14 8 6.0000K R1FB 9 11 3.0000K CC1 17 11 35.0000PF R2FB 10 12 3.0000K CC2 16 12 35.0000PF RCE 17 9 75MEG I1 3 16 DC 1.300E-3 I2 3 17 DC 1.300E-3 I3 10 4 DC 1.300E-3 I4 9 4 DC 1.300E-3 D1 17 15 DX D2 16 15 DX Q1 16 1 10 QX Q2 17 2 9 QX V1 3 15 DC 2.000 * .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .ENDS * * A1_103 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/15/90 AT 13:24 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_103 1 2 3 4 5 * C1 11 12 2.098E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E6 -3E6 3E6 3E6 -3E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 2.987E-9 ISS 3 10 DC 100.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 5.305E3 RD2 4 12 5.305E3 RO1 8 5 20 RO2 7 99 20 RP 3 4 14.06E3 RSS 10 99 2.000E6 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 50 VLN 0 92 DC 50 .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.500E-12 BETA=177.7E-6 VTO=-1) .ENDS * * A2_103 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/13/90 AT 11:47 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_103 1 2 3 4 5 * C1 11 12 2.098E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E6 -3E6 3E6 3E6 -3E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 2.987E-9 ISS 3 10 DC 100.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 5.305E3 RD2 4 12 5.305E3 RO1 8 5 20 RO2 7 99 20 RP 3 4 14.06E3 RSS 10 99 2.000E6 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 50 VLN 0 92 DC 50 .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.500E-12 BETA=177.7E-6 VTO=-1) .ENDS * * A3_103 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/09/90 AT 10:20 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_103 1 2 3 4 5 * C1 11 12 3.356E-12 C2 6 7 8.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 16.62E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 301.6E-6 GCM 0 6 10 99 4.780E-9 ISS 3 10 DC 160.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 3.316E3 RD2 4 12 3.316E3 RO1 8 5 10 RO2 7 99 10 RP 3 4 14.06E3 RSS 10 99 1.250E6 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 70 VLN 0 92 DC 70 .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.500E-12 BETA=284.3E-6 VTO=-1) .ENDS *$ ************************************************************************** * INA103E = A1_103E + A2_103E + A3_103E OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 10/30/90 AT 15:01 * REV.B 3/21/92 BCB: added input bias current correction * REV.C 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA103E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA103E/BB 1 2 3 4 5 8 9 10 * * A1_103E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_103E * * A2_103E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_103E * * A3_103E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_103E * R1 11 13 6.0000K R2 13 5 5.9994K C2 13 5 2.0000PF R3 12 14 6.0000K R4 14 8 6.0000K R1FB 9 11 3.0000K CC1 17 11 35.0000PF R2FB 10 12 3.0000K CC2 16 12 35.0000PF RCE 17 9 75MEG I1 3 16 DC 1.300E-3 I2 3 17 DC 1.300E-3 I3 10 4 DC 1.300E-3 I4 9 4 DC 1.300E-3 D1 17 15 DX D2 16 15 DX Q1 16 1 10 QX Q2 17 2 9 QX V1 3 15 DC 2.000 C1CM 1 0 2.5PF C2CM 2 0 2.5PF CDIF 1 2 2.0PF * .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .ENDS * * A1_103E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/13/90 AT 14:01 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_103E 1 2 3 4 5 * C1 11 12 2.098E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E6 -3E6 3E6 3E6 -3E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 2.987E-9 ISS 3 10 DC 100.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 5.305E3 RD2 4 12 5.305E3 RO1 8 5 20 RO2 7 99 20 * RP 3 4 14.06E3 RSS 10 99 2.000E6 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 50 VLN 0 92 DC 50 **************************** * A1_103 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.70E-3 1 FQ2 0 4 POLY(1) VQ2 1.70E-3 -1 * QUIESCIENT CURRENT RQ 3 4 9.0E4 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.500E-12 BETA=177.7E-6 VTO=-1) .ENDS * * A2_103E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/13/90 AT 11:47 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_103E 1 2 3 4 5 * C1 11 12 2.098E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E6 -3E6 3E6 3E6 -3E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 2.987E-9 ISS 3 10 DC 100.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 5.305E3 RD2 4 12 5.305E3 RO1 8 5 20 RO2 7 99 20 * RP 3 4 14.06E3 RSS 10 99 2.000E6 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 50 VLN 0 92 DC 50 **************************** * A2_103 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.70E-3 1 FQ2 0 4 POLY(1) VQ2 1.70E-3 -1 * QUIESCIENT CURRENT RQ 3 4 9.0E4 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.500E-12 BETA=177.7E-6 VTO=-1) .ENDS * * A3_103E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/09/90 AT 10:20 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_103E 1 2 3 4 5 * C1 11 12 3.356E-12 C2 6 7 8.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 16.62E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 301.6E-6 GCM 0 6 10 99 4.780E-9 ISS 3 10 DC 160.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 3.316E3 RD2 4 12 3.316E3 RO1 8 5 10 RO2 7 99 10 * RP 3 4 14.06E3 RSS 10 99 1.250E6 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 70 VLN 0 92 DC 70 **************************** * A3_103 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.64E-3 1 FQ2 0 4 POLY(1) VQ2 1.64E-3 -1 * QUIESCIENT CURRENT RQ 3 4 9.0E4 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.500E-12 BETA=284.3E-6 VTO=-1) .ENDS *$ ************************************************************************** * INA105 = A3_105 OPERATIONAL AMPLIFIER + PRECISION RESISTOR NETWORK * CREATED ON 08/21/90 AT 12:54 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA105 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | SENSE * | | | | | | | .SUBCKT INA105/BB 1 2 3 4 5 8 9 * * A3_105 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 14 13 3 4 5 A3_105 * R1 2 13 25000 R2 13 9 24997.5 C2 13 9 0.1P R3 1 14 25000 R4 14 8 25000 C1CM 14 0 1.5PF C2CM 13 0 1.5PF CDIF 14 13 1.5PF * .ENDS * * A3_105 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/19/90 AT 11:02 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_105 1 2 3 4 5 * C1 11 12 1.146E-12 C2 6 7 13.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 10.20E6 -10E6 10E6 10E6 -10E6 GA 6 0 11 12 163.4E-6 GCM 0 6 10 99 163.4E-12 IEE 10 4 DC 39.14E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 6.121E3 RC2 3 12 6.121E3 RE1 13 10 4.778E3 RE2 14 10 4.778E3 REE 10 99 5.110E6 RO1 8 5 60 RO2 7 99 60 RP 3 4 20.53E3 VB 9 0 DC 0 VC 3 53 DC 4.500 VE 54 4 DC 2 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=278.6) .ENDS *$ ************************************************************************** * INA105E = A3_105E OPERATIONAL AMPLIFIER + PRECISION RESISTOR NETWORK * "E" IS ENHANCED MODEL * CREATED ON 08/28/90 AT 9:50 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA105E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | SENSE * | | | | | | | .SUBCKT INA105E/BB 1 2 3 4 5 8 9 * * A3_105E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 14 13 3 4 5 A3_105E * R1 2 13 25000 R2 13 9 24997.5 C2 13 9 0.1PF R3 1 14 25000 R4 14 8 25000 C1CM 14 0 1.5PF C2CM 13 0 1.5PF CDIF 14 13 1.5PF * .ENDS * * A3_105E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/09/90 AT 08:58 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_105E 1 2 3 4 5 * C1 11 12 1.146E-12 C2 6 7 13.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 10.20E6 -10E6 10E6 10E6 -10E6 GA 6 0 11 12 163.4E-6 GCM 0 6 10 99 163.4E-12 IEE 10 4 DC 39.14E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 6.121E3 RC2 3 12 6.121E3 RE1 13 10 4.778E3 RE2 14 10 4.778E3 REE 10 99 5.110E6 RO1 8 5 60 RO2 7 99 60 * RP 3 4 20.53E3 VB 9 0 DC 0 VC 3 53 DC 4.500 VE 54 4 DC 2 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 **************************** * A3_105 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.414E-3 1 FQ2 0 4 POLY(1) VQ2 1.414E-3 -1 * QUIESCIENT CURRENT RQ 3 4 6.5E5 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=278.6) .ENDS *$ ************************************************************************** * INA106 = A3_106 OPERATIONAL AMPLIFIER + PRECISION RESISTOR NETWORK * CREATED ON 08/21/90 AT 12:54 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA106 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | SENSE * | | | | | | | .SUBCKT INA106/BB 1 2 3 4 5 8 9 * * A3_106 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 14 13 3 4 5 A3_106 * R1 2 13 10.0000K R2 13 9 100.0100K C2 13 9 0.1000PF R3 1 14 10.0000K R4 14 8 100.0000K C1CM 14 0 1.5PF C2CM 13 0 1.5PF CDIF 14 13 1.5PF * .ENDS * * A3_106 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/18/90 AT 13:55 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_106 1 2 3 4 5 * C1 11 12 9.283E-12 C2 6 7 13.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.081E6 -4E6 4E6 4E6 -4E6 GA 6 0 11 12 408.4E-6 GCM 0 6 10 99 408.4E-12 IEE 10 4 DC 39.14E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.449E3 RC2 3 12 2.449E3 RE1 13 10 1.118E3 RE2 14 10 1.118E3 REE 10 99 5.110E6 RO1 8 5 60 RO2 7 99 60 RP 3 4 20.53E3 VB 9 0 DC 0 VC 3 53 DC 4.500 VE 54 4 DC 2 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=278.6) .ENDS *$ ************************************************************************** * INA106E = A3_106E OPERATIONAL AMPLIFIER + PRECISION RESISTOR NETWORK * "E" IS ENHANCED MODEL * CREATED ON 08/28/90 AT 9:50 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA106E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | SENSE * | | | | | | | .SUBCKT INA106E/BB 1 2 3 4 5 8 9 * * A3_106E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 14 13 3 4 5 A3_106E * R1 2 13 10000 R2 13 9 100010 C2 13 9 0.1PF R3 1 14 10000 R4 14 8 100000 C1CM 14 0 1.5PF C2CM 13 0 1.5PF CDIF 14 13 1.5PF * .ENDS * * A3_106E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/09/90 AT 08:58 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_106E 1 2 3 4 5 * C1 11 12 9.283E-12 C2 6 7 13.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.081E6 -4E6 4E6 4E6 -4E6 GA 6 0 11 12 408.4E-6 GCM 0 6 10 99 408.4E-12 IEE 10 4 DC 39.14E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.449E3 RC2 3 12 2.449E3 RE1 13 10 1.118E3 RE2 14 10 1.118E3 REE 10 99 5.110E6 RO1 8 5 60 RO2 7 99 60 * RP 3 4 20.53E3 VB 9 0 DC 0 VC 3 53 DC 4.500 VE 54 4 DC 2 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 **************************** * A3_106 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.414E-3 1 FQ2 0 4 POLY(1) VQ2 1.414E-3 -1 * QUIESCIENT CURRENT RQ 3 4 6.5E5 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=278.6) .ENDS *$ ************************************************************************** * INA110 = A1_110 + A2_110 + A3_110 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 10/30/90 AT 15:01 * REV.B 1/6/93 BCB :Removed Gain Set 1 and Gain Set 2 pins from model * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA110 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | * | | | | | | | | * | | | | | | | | .SUBCKT INA110/BB 1 2 3 4 5 8 9 10 * * A1_110 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_110 * * A2_110 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_110 * * A3_110 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_110 * R1 11 13 10.0000K R2 13 5 9.9995K C2 13 5 6.0000PF R3 12 14 10.0000K R4 14 8 10.0000K C4 14 8 5.0000PF R1FB 9 11 20.0000K CC1 17 11 5.0000PF R2FB 10 12 20.0000K CC2 16 12 5.0000PF RCE 17 9 400MEG I1 3 16 DC 50.00E-6 I2 3 17 DC 50.00E-6 I3 10 4 DC 50.00E-6 I4 9 4 DC 50.00E-6 I5 3 21 DC 200.00E-6 I6 3 22 DC 200.00E-6 CG1 9 0 30.0000PF CG2 10 0 20.0000PF D1 17 15 DX D2 16 15 DX Q1 16 21 10 QX Q2 17 22 9 QX J1 4 1 21 JX J2 4 2 22 JX V1 3 15 DC 3.000 * .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .MODEL JX PJF(IS=10.00E-12 BETA=500.0E-6 VTO=-1) .ENDS * * A1_110 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/14/90 AT 11:10 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_110 1 2 3 4 5 * C1 11 12 1.443E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E3 -3E3 3E3 3E3 -3E3 GA 6 0 11 12 628.3E-6 GCM 0 6 10 99 6.283E-6 ISS 3 10 DC 250.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.592E3 RD2 4 12 1.592E3 RO1 8 5 60 RO2 7 99 60 RP 3 4 37.50E3 RSS 10 99 800.0E3 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 60 VLN 0 92 DC 60 .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=789.5E-6 VTO=-1) .ENDS * * A2_110 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/14/90 AT 11:12 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_110 1 2 3 4 5 * C1 11 12 1.443E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E3 -3E3 3E3 3E3 -3E3 GA 6 0 11 12 628.3E-6 GCM 0 6 10 99 6.283E-6 ISS 3 10 DC 250.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.592E3 RD2 4 12 1.592E3 RO1 8 5 60 RO2 7 99 60 RP 3 4 37.50E3 RSS 10 99 800.0E3 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 60 VLN 0 92 DC 60 .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=789.5E-6 VTO=-1) .ENDS * * A3_110 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/14/90 AT 12:59 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_110 1 2 3 4 5 * C1 11 12 7.151E-12 C2 6 7 12.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 27.96E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 377.0E-6 GCM 0 6 10 99 1.889E-9 ISS 3 10 DC 240.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 2.653E3 RD2 4 12 2.653E3 RO1 8 5 30 RO2 7 99 30 RP 3 4 37.50E3 RSS 10 99 833.3E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=296.0E-6 VTO=-1) .ENDS *$ ************************************************************************** * INA110E = A1_110E + A2_110E + A3_110E OP AMPS + PRECISION RESISTOR NETWORK * "E" IS ENHANCED MODEL * CREATED ON 10/30/90 AT 15:01 * REV.B 3/21/92 BCB added input bias current correction * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA110E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA110E/BB 1 2 3 4 5 8 9 10 * * A1_110E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_110E * * A2_110E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_110E * * A3_110E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_110E * R1 11 13 10.0000K R2 13 5 9.9995K C2 13 5 6.0000PF R3 12 14 10.0000K R4 14 8 10.0000K C4 14 8 5.0000PF R1FB 9 11 20.0000K CC1 17 11 5.0000PF R2FB 10 12 20.0000K CC2 16 12 5.0000PF RCE 17 9 400MEG I1 3 16 DC 50.00E-6 I2 3 17 DC 50.00E-6 I3 10 4 DC 50.00E-6 I4 9 4 DC 50.00E-6 I5 3 21 DC 200.00E-6 I6 3 22 DC 200.00E-6 CG1 9 0 30.0000PF CG2 10 0 20.0000PF D1 17 15 DX D2 16 15 DX Q1 16 21 10 QX Q2 17 22 9 QX J1 4 1 21 JX J2 4 2 22 JX G11 1 4 POLY(2) (21,1) (4,1) 0 1E-12 1E-12 G21 2 4 POLY(2) (22,2) (4,2) 0 1E-12 1E-12 V1 3 15 DC 3.000 C1CM 1 0 1.0PF C2CM 2 0 1.0PF CDIF 1 2 6.0PF * .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .MODEL JX PJF(IS=5.00E-12 BETA=500.0E-6 VTO=-1) .ENDS * * A1_110E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/14/90 AT 11:10 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_110E 1 2 3 4 5 * C1 11 12 1.443E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E3 -3E3 3E3 3E3 -3E3 GA 6 0 11 12 628.3E-6 GCM 0 6 10 99 6.283E-6 ISS 3 10 DC 250.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.592E3 RD2 4 12 1.592E3 RO1 8 5 60 RO2 7 99 60 * RP 3 4 37.50E3 RSS 10 99 800.0E3 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 60 VLN 0 92 DC 60 **************************** * A1_110 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 4.16E-4 1 FQ2 0 4 POLY(1) VQ2 4.16E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.25E5 * DIFF INPUT CAPACITANCE CDIF 1 2 3.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=789.5E-6 VTO=-1) .ENDS * * A2_110E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/14/90 AT 11:12 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_110E 1 2 3 4 5 * C1 11 12 1.443E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E3 -3E3 3E3 3E3 -3E3 GA 6 0 11 12 628.3E-6 GCM 0 6 10 99 6.283E-6 ISS 3 10 DC 250.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.592E3 RD2 4 12 1.592E3 RO1 8 5 60 RO2 7 99 60 * RP 3 4 37.50E3 RSS 10 99 800.0E3 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 60 VLN 0 92 DC 60 **************************** * A2_110 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 4.16E-4 1 FQ2 0 4 POLY(1) VQ2 4.16E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.25E5 * DIFF INPUT CAPACITANCE CDIF 1 2 3.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=789.5E-6 VTO=-1) .ENDS * * A3_110E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/14/90 AT 12:59 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_110E 1 2 3 4 5 * C1 11 12 7.151E-12 C2 6 7 12.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 27.96E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 377.0E-6 GCM 0 6 10 99 1.889E-9 ISS 3 10 DC 240.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 2.653E3 RD2 4 12 2.653E3 RO1 8 5 30 RO2 7 99 30 * RP 3 4 37.50E3 RSS 10 99 833.3E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 **************************** * A3_110 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 4.264E-4 1 FQ2 0 4 POLY(1) VQ2 4.264E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.25E5 * DIFF INPUT CAPACITANCE CDIF 1 2 3.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=296.0E-6 VTO=-1) .ENDS *$ ************************************************************************** * INA111 = A1_111 + A2_111 + A3_111 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 12/1/92 AT 10:00 HB * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA111 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA111/BB 1 2 3 4 5 8 9 10 * * A1_111 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_111 * * A2_111 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_111 * * A3_111 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_111 * R1 11 13 10.0000E3 R3 12 14 10.0000E3 R2 13 5 9.9993E3 R4 14 8 10.0000E3 C2 13 5 6.0000E-12 C4 14 8 5.0000E-12 R1FB 9 11 25.0000E3 R2FB 10 12 25.0000E3 CC1 17 11 5.0000E-12 CC2 16 12 5.5000E-12 RCE 17 9 400E6 I1 3 16 DC 50.00E-6 I2 3 17 DC 50.00E-6 I3 10 4 DC 50.00E-6 I4 9 4 DC 50.00E-6 I5 3 21 DC 200.00E-6 I6 3 22 DC 200.00E-6 CG1 9 0 13.5000E-12 CG2 10 0 12.0000E-12 D1 17 15 DX D2 16 15 DX Q1 16 21 10 QX Q2 17 22 9 QX J1 4 1 21 JX J2 4 2 22 JX V1 3 15 DC 3.000 * .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .MODEL JX PJF(IS=10.00E-12 BETA=500.0E-6 VTO=-1) .ENDS * * A1_111 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/1/92 AT 10:00 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_111 1 2 3 4 5 * C1 11 12 1.443E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E3 -3E3 3E3 3E3 -3E3 GA 6 0 11 12 628.3E-6 GCM 0 6 10 99 6.283E-6 ISS 3 10 DC 250.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.592E3 RD2 4 12 1.592E3 RO1 8 5 60 RO2 7 99 60 RP 3 4 37.50E3 RSS 10 99 800.0E3 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 60 VLN 0 92 DC 60 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=789.5E-6 VTO=-1) .ENDS * * A2_111 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/1/92 AT 10:00 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_111 1 2 3 4 5 * C1 11 12 1.443E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E3 -3E3 3E3 3E3 -3E3 GA 6 0 11 12 628.3E-6 GCM 0 6 10 99 6.283E-6 ISS 3 10 DC 250.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.592E3 RD2 4 12 1.592E3 RO1 8 5 60 RO2 7 99 60 RP 3 4 37.50E3 RSS 10 99 800.0E3 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 60 VLN 0 92 DC 60 .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=789.5E-6 VTO=-1) .ENDS * * A3_111 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/1/92 AT 10:00 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_111 1 2 3 4 5 * C1 11 12 7.151E-12 C2 6 7 12.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 27.96E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 377.0E-6 GCM 0 6 10 99 1.889E-9 ISS 3 10 DC 240.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 2.653E3 RD2 4 12 2.653E3 RO1 8 5 30 RO2 7 99 30 RP 3 4 37.50E3 RSSS 10 99 833.3E3 VB 9 0 DC 0 VC 3 53 DC 2.300 VE 54 4 DC 2.300 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=296.0E-6 VTO=-1) .ENDS *$ ************************************************************************** * INA111E = A1_111E + A2_111E + A3_111E OP AMPS + PRECISION RESISTOR NETWORK * "E" IS ENHANCED MODEL * CREATED ON 12/1/92 AT 10:00 HB * REV.A * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * | | * | Neither this library nor any part may be copied without | * | the express written consent of Burr-Brown Corporation. | * | | * |-------------------------------------------------------------| * * INA111E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA111E/BB 1 2 3 4 5 8 9 10 * * A1_111E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_111E * * A2_111E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_111E * * A3_111E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_111E * R1 11 13 10.0000E3 R3 12 14 10.0000E3 R2 13 5 9.9993E3 R4 14 8 10.0000E3 C2 13 5 6.0000E-12 C4 14 8 5.0000E-12 R1FB 9 11 25.0000E3 R2FB 10 12 25.0000E3 CC1 17 11 5.0000E-12 CC2 16 12 5.5000E-12 RCE 17 9 400E6 I1 3 16 DC 50.00E-6 I2 3 17 DC 50.00E-6 I3 10 4 DC 50.00E-6 I4 9 4 DC 50.00E-6 I5 3 21 DC 200.00E-6 I6 3 22 DC 200.00E-6 CG1 9 0 13.5000E-12 CG2 10 0 12.0000E-12 D1 17 15 DX D2 16 15 DX Q1 16 21 10 QX Q2 17 22 9 QX J1 4 1 21 JX J2 4 2 22 JX V1 3 15 DC 3.000 C1CM 1 0 1.0E-12 C2CM 2 0 1.0E-12 CDIF 1 2 6.0E-12 * .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .MODEL JX PJF(IS=10.00E-12 BETA=500.0E-6 VTO=-1) .ENDS * * A1_111E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/1/92 AT 10:00 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_111E 1 2 3 4 5 * C1 11 12 1.443E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E3 -3E3 3E3 3E3 -3E3 GA 6 0 11 12 628.3E-6 GCM 0 6 10 99 6.283E-6 ISS 3 10 DC 250.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.592E3 RD2 4 12 1.592E3 RO1 8 5 60 RO2 7 99 60 * RP 3 4 37.50E3 RSS 10 99 800.0E3 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 60 VLN 0 92 DC 60 **************************** * A1_111 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 4.16E-4 1 FQ2 0 4 POLY(1) VQ2 4.16E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.25E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.0E-12 C2CM 2 99 1.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=789.5E-6 VTO=-1) .ENDS * * A2_111E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/1/92 AT 10:00 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_111E 1 2 3 4 5 * C1 11 12 1.443E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E3 -3E3 3E3 3E3 -3E3 GA 6 0 11 12 628.3E-6 GCM 0 6 10 99 6.283E-6 ISS 3 10 DC 250.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.592E3 RD2 4 12 1.592E3 RO1 8 5 60 RO2 7 99 60 * RP 3 4 37.50E3 RSS 10 99 800.0E3 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 60 VLN 0 92 DC 60 **************************** * A2_111 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 4.16E-4 1 FQ2 0 4 POLY(1) VQ2 4.16E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.25E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.0E-12 C2CM 2 99 1.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=789.5E-6 VTO=-1) .ENDS * * A3_111E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/1/92 AT 10:00 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_111E 1 2 3 4 5 * C1 11 12 7.151E-12 C2 6 7 12.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 27.96E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 377.0E-6 GCM 0 6 10 99 1.889E-9 ISS 3 10 DC 240.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 2.653E3 RD2 4 12 2.653E3 RO1 8 5 30 RO2 7 99 30 * RP 3 4 37.50E3 RSSS 10 99 833.3E3 VB 9 0 DC 0 VC 3 53 DC 2.300 VE 54 4 DC 2.300 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 **************************** * A3_111 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 4.264E-4 1 FQ2 0 4 POLY(1) VQ2 4.264E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.25E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.0E-12 C2CM 2 99 1.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=296.0E-6 VTO=-1) .ENDS *$ ************************************************************************** * INA111Z = A1_111Z + A2_111Z + A3_111Z OP AMPS + PRECISION RESISTOR NETWORK * "Z" IS ENHANCED MODEL * CREATED ON 12/1/92 AT 10:00 HB * REV.A * REV.B 13 June 97 NPA: Changed "E" to "Z" to correct run error * REV.C 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA111Z SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA111Z/BB 1 2 3 4 5 8 9 10 * * A1_111Z SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_111Z * * A2_111Z SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_111Z * * A3_111Z SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_111Z * R1 11 13 10.0000E3 R3 12 14 10.0000E3 R2 13 5 9.9993E3 R4 14 8 10.0000E3 C2 13 5 6.0000E-12 C4 14 8 5.0000E-12 R1FB 9 11 25.0000E3 R2FB 10 12 25.0000E3 CC1 17 11 5.0000E-12 CC2 16 12 5.5000E-12 RCE 17 9 400E6 I1 3 16 DC 50.00E-6 I2 3 17 DC 50.00E-6 I3 10 4 DC 50.00E-6 I4 9 4 DC 50.00E-6 I5 3 21 DC 200.00E-6 I6 3 22 DC 200.00E-6 CG1 9 0 13.5000E-12 CG2 10 0 12.0000E-12 D1 17 15 DX D2 16 15 DX Q1 16 21 10 QX Q2 17 22 9 QX J1 4 1 21 JX J2 4 2 22 JX V1 3 15 DC 3.000 C1CM 1 0 1.0E-12 C2CM 2 0 1.0E-12 CDIF 1 2 6.0E-12 * .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .MODEL JX PJF(IS=10.00E-12 BETA=500.0E-6 VTO=-1) .ENDS * * A1_111Z OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "Z" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/1/92 AT 10:00 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_111Z 1 2 3 4 5 * C1 11 12 1.443E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E3 -3E3 3E3 3E3 -3E3 GA 6 0 11 12 628.3E-6 GCM 0 6 10 99 6.283E-6 ISS 3 10 DC 250.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.592E3 RD2 4 12 1.592E3 RO1 8 5 60 RO2 7 99 60 * RP 3 4 37.50E3 RSS 10 99 800.0E3 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 60 VLN 0 92 DC 60 **************************** * A1_111 "Z" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 4.16E-4 1 FQ2 0 4 POLY(1) VQ2 4.16E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.25E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.0E-12 C2CM 2 99 1.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=789.5E-6 VTO=-1) .ENDS * * A2_111Z OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "Z" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/1/92 AT 10:00 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_111Z 1 2 3 4 5 * C1 11 12 1.443E-12 C2 6 7 5.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E3 -3E3 3E3 3E3 -3E3 GA 6 0 11 12 628.3E-6 GCM 0 6 10 99 6.283E-6 ISS 3 10 DC 250.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.592E3 RD2 4 12 1.592E3 RO1 8 5 60 RO2 7 99 60 * RP 3 4 37.50E3 RSS 10 99 800.0E3 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 60 VLN 0 92 DC 60 **************************** * A2_111 "Z" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 4.16E-4 1 FQ2 0 4 POLY(1) VQ2 4.16E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.25E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.0E-12 C2CM 2 99 1.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=789.5E-6 VTO=-1) .ENDS * * A3_111Z OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "Z" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/1/92 AT 10:00 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_111Z 1 2 3 4 5 * C1 11 12 7.151E-12 C2 6 7 12.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 27.96E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 377.0E-6 GCM 0 6 10 99 1.889E-9 ISS 3 10 DC 240.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 2.653E3 RD2 4 12 2.653E3 RO1 8 5 30 RO2 7 99 30 * RP 3 4 37.50E3 RSSS 10 99 833.3E3 VB 9 0 DC 0 VC 3 53 DC 2.300 VE 54 4 DC 2.300 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 **************************** * A3_111 "Z" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 4.264E-4 1 FQ2 0 4 POLY(1) VQ2 4.264E-4 -1 * QUIESCIENT CURRENT RQ 3 4 2.25E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.0E-12 C2CM 2 99 1.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=296.0E-6 VTO=-1) .ENDS *$ ************************************************************************** * INA114 = A1_114 + A2_114 + A3_114 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 1/30/92 AT 4:30PM * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * NOTE: THE OUTPUT PERFORMANCE OF THIS MACRO MODEL WILL BE ERRONEOUS IF * NODE 6 (FEEDBACK) IS NOT CONNECTED PROPERLY. * * INA114 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | FEEDBACK * | | | | | | REFERENCE * | | | | | | | GAIN SET 1 * | | | | | | | | GAIN SET 2 * | | | | | | | | | .SUBCKT INA114/BB 1 2 3 4 5 6 8 9 10 * * A1_114 SUBCIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 2 9 3 4 11 A1_114 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 1 10 3 4 12 A2_114 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_114 * R1 11 13 25K R2 13 6 24.9985K C2 13 6 5P R3 12 14 25K R4 14 8 25K RFB1 9 11 25K CC1 9 11 5P RFB2 10 12 25K CC2 10 12 5P * .ENDS * * A1_114 OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:21 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_114 1 2 3 4 5 * C1 11 12 6.060E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 165.8E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 188.5E-12 IEE 10 4 DC 27E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 5.305E3 RC2 3 12 5.305E3 RE1 13 10 4.348E3 RE2 14 10 4.348E3 REE 10 99 7.4074E6 RO1 8 5 40 RO2 7 99 320 RP 3 4 52.53E3 VB 9 0 DC 0 VC 3 53 DC 1.672 VE 54 4 DC 1.672 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=36.00E3) .ENDS * * A2_114 OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:30 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_114 1 2 3 4 5 * C1 11 12 6.060E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 165.8E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 188.5E-12 IEE 10 4 DC 27E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 5.305E3 RC2 3 12 5.305E3 RE1 13 10 4.318E3 RE2 14 10 4.348E3 REE 10 99 7.4074E6 RO1 8 5 40 RO2 7 99 320 RP 3 4 52.53E3 VB 9 0 DC 0 VC 3 53 DC 1.672 VE 54 4 DC 1.672 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=36.00E3) .ENDS * * A3_114 OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:46 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_114 1 2 3 4 5 * C1 11 12 13.51E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 251.9E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 339.3E-6 GCM 0 6 10 99 339.3E-12 IEE 10 4 DC 18E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.947E3 RC2 3 12 2.947E3 RE1 13 10 74.778 RE2 14 10 74.778 REE 10 99 11.111E6 RO1 8 5 13 RO2 7 99 117 RP 3 4 30.123E3 VB 9 0 DC 0 VC 3 53 DC 1.972 VE 54 4 DC 1.972 VLIM 7 8 DC 0 VLP 91 0 DC 12 VLN 0 92 DC 12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=30.00E3) .ENDS *$ ************************************************************************** * INA114E = A1_114E + A2_114E + A3_114E OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 1/30/92 AT 4:30PM * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * NOTE: THE OUTPUT PERFORMANCE OF THE MACRO MODEL WILL BE ERRONEOUS IF * NODE 6 (FEEDBACK) IS NOT CONNECTED PROPERLY. * * INA114E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | FEEDBACK * | | | | | | REFERENCE * | | | | | | | GAIN SET 1 * | | | | | | | | GAIN SET 2 * | | | | | | | | | .SUBCKT INA114E/BB 1 2 3 4 5 6 8 9 10 * * A1_114E SUBCIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 2 9 3 4 11 A1_114E * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 1 10 3 4 12 A2_114E * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_114E * R1 11 13 25K R2 13 6 24.9985K C2 13 6 5P R3 12 14 25K R4 14 8 25K RFB1 9 11 25K CC1 9 11 5P RFB2 10 12 25K CC2 10 12 5P * .ENDS * * A1_114E OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:21 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_114E 1 2 3 4 5 * C1 11 12 6.060E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 165.8E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 188.5E-12 IEE 10 4 DC 27E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 5.305E3 RC2 3 12 5.305E3 RE1 13 10 4.348E3 RE2 14 10 4.348E3 REE 10 99 7.4074E6 RO1 8 5 40 RO2 7 99 320 VB 9 0 DC 0 VC 3 53 DC 1.672 VE 54 4 DC 1.672 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 **************************** * A1_114E "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0 1 FQ2 0 4 POLY(1) VQ2 0 -1 * QUIESCIENT CURRENT RQ 3 4 52.53E3 * DIFF INPUT CAPACITANCE CDIF 1 2 3E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 0 3E-12 C2CM 2 0 3E-12 * INPUT PROTECTION VS11 3 31 0 FS11 0 3 VS11 1 S11 31 0 1 0 SP FS12 1 4 VS11 1 VS21 32 4 0 FS21 4 0 VS21 1 S21 0 32 1 0 SM FS22 3 1 VS21 1 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=36.00E3 NC=100 NR=100) .MODEL SP VSWITCH(RON=10K ROFF=100G VON=15.6 VOFF=15.5) .MODEL SM VSWITCH(RON=10K ROFF=100G VON=-15.6 VOFF=-15.5) .ENDS * * A2_114E OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:30 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_114E 1 2 3 4 5 * C1 11 12 6.060E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 165.8E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 188.5E-12 IEE 10 4 DC 27E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 5.305E3 RC2 3 12 5.305E3 RE1 13 10 4.348E3 RE2 14 10 4.348E3 REE 10 99 7.4074E6 RO1 8 5 40 RO2 7 99 320 VB 9 0 DC 0 VC 3 53 DC 1.672 VE 54 4 DC 1.672 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 **************************** * A2_114E "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0 1 FQ2 0 4 POLY(1) VQ2 0 -1 * QUIESCIENT CURRENT RQ 3 4 52.53E3 * DIFF INPUT CAPACITANCE CDIF 1 2 3E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 0 3E-12 C2CM 2 0 3E-12 * INPUT PROTECTION VS11 3 31 0 FS11 0 3 VS11 1 S11 31 0 1 0 SP FS12 1 4 VS11 1 VS21 32 4 0 FS21 4 0 VS21 1 S21 0 32 1 0 SM FS22 3 1 VS21 1 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=36.00E3 NC=100 NR=100) .MODEL SP VSWITCH(RON=10K ROFF=100G VON=15.6 VOFF=15.5) .MODEL SM VSWITCH(RON=10K ROFF=100G VON=-15.6 VOFF=-15.5) .ENDS * * A3_114E OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:46 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_114E 1 2 3 4 5 * C1 11 12 13.51E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 251.9E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 339.3E-6 GCM 0 6 10 99 339.3E-12 IEE 10 4 DC 18E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.947E3 RC2 3 12 2.947E3 RE1 13 10 74.778 RE2 14 10 74.778 REE 10 99 11.111E6 RO1 8 5 13 RO2 7 99 117 VB 9 0 DC 0 VC 3 53 DC 1.972 VE 54 4 DC 1.972 VLIM 7 8 DC 0 VLP 91 0 DC 12 VLN 0 92 DC 12 **************************** * A3_114E "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0 1 FQ2 0 4 POLY(1) VQ2 0 -1 * QUIESCIENT CURRENT RQ 3 4 30.123E3 * DIFF INPUT CAPACITANCE CDIF 1 2 10E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 0 5E-12 C2CM 2 0 5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=30.00E3) .ENDS *$ ************************************************************************** * INA115 = 2 x A1_115 + A3_115 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 1/10/94 BY JLA * REV.A * NODE ASSIGNMENTS OF SUBCKT INA115 CORRESPOND TO SURFACE MOUNT PACKAGE OF * BURR-BROWN'S INA115 (NO DIP AVAILABLE) * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * NOTE: THE OUTPUT PERFORMANCE OF THE MACRO MODEL WILL BE ERRONEOUS IF * NODE 12 (FEEDBACK) IS NOT CONNECTED PROPERLY. THIS IS GENERALLY * CONNECTED TO NODE 11 (OUTPUT). * * INA115 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | FEEDBACK * | | | | | | REFERENCE * | | | | | | | GAIN SET 1 * | | | | | | | | GAIN SET 2 * | | | | | | | | | GAIN SENSE 1 * | | | | | | | | | | GAIN SENSE 2 * | | | | | | | | | | | .SUBCKT INA115/BB 5 4 13 7 11 12 10 3 14 2 15 * * A1_115 SUBCIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 4 2 13 7 1 A1_115 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 5 15 13 7 8 A1_115 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 17 18 13 7 11 A3_115 * RFB1 1 3 25K RFB2 8 14 25K R1 1 18 25K R2 18 12 24.9985K R3 8 17 25K R4 17 10 25K C1 17 10 5P C2 18 12 5P CC1 1 3 5P CC2 8 14 5P * .ENDS * * A1_115 OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:21 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_115 1 2 3 4 5 * C1 11 12 6.060E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 165.8E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 188.5E-12 IEE 10 4 DC 27E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 5.305E3 RC2 3 12 5.305E3 RE1 13 10 4.348E3 RE2 14 10 4.348E3 REE 10 99 7.4074E6 RO1 8 5 40 RO2 7 99 320 RP 3 4 52.53E3 VB 9 0 DC 0 VC 3 53 DC 1.672 VE 54 4 DC 1.672 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=36.00E3 NC=100 NR=100) .ENDS * * A3_115 OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:46 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_115 1 2 3 4 5 * C1 11 12 13.51E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 251.9E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 339.3E-6 GCM 0 6 10 99 339.3E-12 IEE 10 4 DC 18E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.947E3 RC2 3 12 2.947E3 RE1 13 10 74.778 RE2 14 10 74.778 REE 10 99 11.111E6 RO1 8 5 13 RO2 7 99 117 RP 3 4 30.123E3 VB 9 0 DC 0 VC 3 53 DC 1.972 VE 54 4 DC 1.972 VLIM 7 8 DC 0 VLP 91 0 DC 12 VLN 0 92 DC 12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=30.00E3) .ENDS *$ ************************************************************************** * INA115E = 2 x A1_115E + A3_115E OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 1/10/94 BY JLA * REV.A * NODE ASSIGNMENTS OF SUBCKT INA115 CORRESPOND TO SURFACE MOUNT PACKAGE OF * BURR-BROWN'S INA115 (NO DIP AVAILABLE) * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * NOTE: THE OUTPUT PERFORMANCE OF THE MACRO MODEL WILL BE ERRONEOUS IF * NODE 12 (FEEDBACK) IS NOT CONNECTED PROPERLY. THIS IS GENERALLY * CONNECTED TO NODE 11 (OUTPUT). * * INA115E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | FEEDBACK * | | | | | | REFERENCE * | | | | | | | GAIN SET 1 * | | | | | | | | GAIN SET 2 * | | | | | | | | | GAIN SENSE 1 * | | | | | | | | | | GAIN SENSE 2 * | | | | | | | | | | | .SUBCKT INA115E/BB 5 4 13 7 11 12 10 3 14 2 15 * * A1_115E SUBCIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 4 2 13 7 1 A1_115E * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 5 15 13 7 8 A1_115E * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 17 18 13 7 11 A3_115E * RFB1 1 3 25K RFB2 8 14 25K R1 1 18 25K R2 18 12 24.9985K R3 8 17 25K R4 17 10 25K C1 17 10 5P C2 18 12 5P CC1 1 3 5P CC2 8 14 5P * .ENDS * * A1_115E OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:21 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_115E 1 2 3 4 5 * C1 11 12 6.060E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 165.8E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 188.5E-12 IEE 10 4 DC 27E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 5.305E3 RC2 3 12 5.305E3 RE1 13 10 4.348E3 RE2 14 10 4.348E3 REE 10 99 7.4074E6 RO1 8 5 40 RO2 7 99 320 VB 9 0 DC 0 VC 3 53 DC 1.672 VE 54 4 DC 1.672 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 **************************** * A1_115E "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0 1 FQ2 0 4 POLY(1) VQ2 0 -1 * QUIESCIENT CURRENT RQ 3 4 52.53E3 * DIFF INPUT CAPACITANCE CDIF 1 2 3E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 0 3E-12 C2CM 2 0 3E-12 * INPUT PROTECTION VS11 3 31 0 FS11 0 3 VS11 1 S11 31 0 1 0 SP FS12 1 4 VS11 1 VS21 32 4 0 FS21 4 0 VS21 1 S21 0 32 1 0 SM FS22 3 1 VS21 1 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=36.00E3 NC=100 NR=100) .MODEL SP VSWITCH(RON=10K ROFF=100G VON=15.6 VOFF=15.5) .MODEL SM VSWITCH(RON=10K ROFF=100G VON=-15.6 VOFF=-15.5) .ENDS * * A3_115E OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:46 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_115E 1 2 3 4 5 * C1 11 12 13.51E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 251.9E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 339.3E-6 GCM 0 6 10 99 339.3E-12 IEE 10 4 DC 18E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.947E3 RC2 3 12 2.947E3 RE1 13 10 74.778 RE2 14 10 74.778 REE 10 99 11.111E6 RO1 8 5 13 RO2 7 99 117 VB 9 0 DC 0 VC 3 53 DC 1.972 VE 54 4 DC 1.972 VLIM 7 8 DC 0 VLP 91 0 DC 12 VLN 0 92 DC 12 **************************** * A3_115E "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0 1 FQ2 0 4 POLY(1) VQ2 0 -1 * QUIESCIENT CURRENT RQ 3 4 30.123E3 * DIFF INPUT CAPACITANCE CDIF 1 2 10E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 0 5E-12 C2CM 2 0 5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=30.00E3) .ENDS *$ ************************************************************************** * INA117 = A3_117 OPERATIONAL AMPLIFIER + PRECISION RESISTOR NETWORK * CREATED ON 08/21/90 AT 12:54 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA117 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE A * | | | | | | REFERENCE B * | | | | | | | .SUBCKT INA117/BB 1 2 3 4 5 8 9 * * A3_117 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 14 13 3 4 5 A3_117 * R1 2 13 380.0000K R2 13 5 380.0000K C2 13 5 0.500PF R3 1 14 380.0000K R4 14 8 19.9990K R5 13 9 21.1111K C1CM 14 0 3PF C2CM 13 0 3PF CDIF 14 13 7PF * .ENDS * * A3_117 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/19/90 AT 12:37 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_117 1 2 3 4 5 * C1 11 12 9.283E-12 C2 6 7 13.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.081E6 -4E6 4E6 4E6 -4E6 GA 6 0 11 12 408.4E-6 GCM 0 6 10 99 408.4E-12 IEE 10 4 DC 39.14E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.449E3 RC2 3 12 2.449E3 RE1 13 10 1.118E3 RE2 14 10 1.118E3 REE 10 99 5.110E6 RO1 8 5 60 RO2 7 99 60 RP 3 4 20.53E3 VB 9 0 DC 0 VC 3 53 DC 4.500 VE 54 4 DC 2 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=278.6) .ENDS *$ ************************************************************************** * INA117E = A3_117E OPERATIONAL AMPLIFIER + PRECISION RESISTOR NETWORK * "E" IS ENHANCED MODEL * CREATED ON 08/28/90 AT 9:50 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA117E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE A * | | | | | | REFERENCE B * | | | | | | | .SUBCKT INA117E/BB 1 2 3 4 5 8 9 * * A3_117E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 14 13 3 4 5 A3_117E * R1 2 13 380.0000K R2 13 5 380.0000K C2 13 5 0.5000PF R3 1 14 380.0000K R4 14 8 19.9990K R5 13 9 21.1111K C1CM 14 0 3PF C2CM 13 0 3PF CDIF 14 13 7PF * .ENDS * * A3_117E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/09/90 AT 08:58 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_117E 1 2 3 4 5 * C1 11 12 9.283E-12 C2 6 7 13.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.081E6 -4E6 4E6 4E6 -4E6 GA 6 0 11 12 408.4E-6 GCM 0 6 10 99 408.4E-12 IEE 10 4 DC 39.14E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.449E3 RC2 3 12 2.449E3 RE1 13 10 1.118E3 RE2 14 10 1.118E3 REE 10 99 5.110E6 RO1 8 5 60 RO2 7 99 60 * RP 3 4 20.53E3 VB 9 0 DC 0 VC 3 53 DC 4.500 VE 54 4 DC 2 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 **************************** * A3_117 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.414E-3 1 FQ2 0 4 POLY(1) VQ2 1.414E-3 -1 * QUIESCIENT CURRENT RQ 3 4 6.5E5 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=278.6) .ENDS *$ ************************************************************************** * INA118 = A1_118 + A2_118 + A3_118 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 05/20/94 AT 15:01 * REV.A * * INA118 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA118/BB 1 2 3 4 5 8 9 10 * * A1_118 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_118 * * A2_118 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_118 * * A3_118 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_118 * R1 11 13 60.0000K R2 13 5 59.994K R3 12 14 60.0000K R4 14 8 60.0000K CIN 13 14 4.0000PF R1FB 9 11 25.0000K CC1 17 11 13.0000PF R2FB 10 12 25.0000K CC2 16 12 13.0000PF CG1 9 0 10.0000PF CG2 10 0 9.0000PF RCE 17 9 1.7G I1 3 16 DC 15.00E-6 I2 3 17 DC 15.00E-6 IB1CAN 3 1 DC 29.00E-9 IB2CAN 3 2 DC 29.00E-9 Ibal 0 4 DC 31.30E-6 D1 15 17 DX D2 15 16 DX Q1 16 1 10 QX Q2 17 2 9 QX V1 3 15 DC 1.100 * .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .ENDS * * A1_118 operational amplifier "macromodel" subcircuit * created using Parts release 6.0 on 05/20/94 at 09:20 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A1_118 1 2 3 4 5 * c1 11 12 1.340E-12 c2 6 7 10.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 127.3E6 -130E6 130E6 130E6 -130E6 ga 6 0 11 12 110.0E-6 gcm 0 6 10 99 11.00E-12 iss 3 10 dc 10.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 9.095E3 rd2 4 12 9.095E3 ro1 8 5 50 ro2 7 99 25 rp 3 4 900.0E12 rss 10 99 20.00E6 vb 9 0 dc 0 vc 3 53 dc .6 ve 54 4 dc .6 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=1.209E-3 Vto=-1) .ends * * A2_118 operational amplifier "macromodel" subcircuit * created using Parts release 6.0 on 05/20/94 at 09:20 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A2_118 1 2 3 4 5 * c1 11 12 1.340E-12 c2 6 7 10.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 127.3E6 -130E6 130E6 130E6 -130E6 ga 6 0 11 12 110.0E-6 gcm 0 6 10 99 11.00E-12 iss 3 10 dc 10.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 9.095E3 rd2 4 12 9.095E3 ro1 8 5 50 ro2 7 99 25 rp 3 4 900.0E12 rss 10 99 20.00E6 vb 9 0 dc 0 vc 3 53 dc .6 ve 54 4 dc .6 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=1.209E-3 Vto=-1) .ends * * A3_118 operational amplifier "macromodel" subcircuit * created using Parts release 6.0 on 05/20/94 at 09:22 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A3_118 1 2 3 4 5 * c1 11 12 3.501E-12 c2 6 7 10.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 212.2E6 -210E6 210E6 210E6 -210E6 ga 6 0 11 12 75.40E-6 gcm 0 6 10 99 754.0E-12 iee 10 4 dc 9.002E-6 hlim 90 0 vlim 1K q1 11 2 13 qx q2 12 1 14 qx r2 6 9 100.0E3 rc1 3 11 13.26E3 rc2 3 12 13.26E3 re1 13 10 7.514E3 re2 14 10 7.514E3 ree 10 99 22.22E6 ro1 8 5 75 ro2 7 99 75 rp 3 4 103.09E3 vb 9 0 dc 0 vc 3 53 dc 1.400 ve 54 4 dc .8 vlim 7 8 dc 0 vlp 91 0 dc 4.5 vln 0 92 dc 11.5 * .model dx D(Is=800.0E-18) .model qx NPN(Is=800.0E-18 Bf=4.500E3) .ends *$ ************************************************************************** * INA118E = A1_118E + A2_118E + A3_118E OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 05/20/94 AT 15:01 TLB * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA118E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA118E/BB 1 2 3 4 5 8 9 10 * * A1_118E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_118E * * A2_118E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_118E * * A3_118E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_118E * R1 11 13 60.0000K R2 13 5 59.994K R3 12 14 60.0000K R4 14 8 60.0000K CIN 13 14 4.0000PF R1FB 9 11 25.0000K CC1 17 11 13.0000PF R2FB 10 12 25.0000K CC2 16 12 13.0000PF CG1 9 0 10.0000PF CG2 10 0 9.0000PF **************************** * INA118 "E" - ENHANCEMENTS **************************** RDIFF 1 2 1.0000E10 R1CM 1 0 2.5000E10 R2CM 2 0 2.5000E10 CDIF 1 2 1.0000PF C1CM 1 0 4.0000PF C2CM 2 0 4.0000PF RCE 17 9 1.7G I1 3 16 DC 15.00E-6 I2 3 17 DC 15.00E-6 IB1CAN 3 1 DC 29.00E-9 IB2CAN 3 2 DC 29.00E-9 D1 15 17 DX D2 15 16 DX Q1 16 1 10 QX Q2 17 2 9 QX V1 3 15 DC 1.100 ********************************* * INA118 "E" - ENHANCEMENTS ********************************* * POS INPUT PROTECTION VS11 3 31 0 S11 31 0 1 0 SP FS12 1 4 VS11 1 FS11 0 3 VS11 1 VS21 32 4 0 S21 0 32 1 0 SM FS22 3 1 VS21 1 FS21 4 0 VS21 1 * NEG INPUT PROTECTION VS11- 3 33 0 S11- 33 0 2 0 SP FS12- 2 4 VS11- 1 FS11- 0 3 VS11- 1 VS21- 34 4 0 S21- 0 34 2 0 SM FS22- 3 2 VS21- 1 FS21- 4 0 VS21- 1 * .model sp vswitch(ron=300k roff=100g von=14.8 voff=14.7) .model sm vswitch(ron=3.5k roff=100g von=-15.1 voff=-15.0) .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .ENDS * * A1_118E operational amplifier "macromodel" subcircuit * created using Parts release 6.0 on 05/20/94 at 09:20 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A1_118E 1 2 3 4 5 * c1 11 12 1.340E-12 c2 6 7 10.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 127.3E6 -130E6 130E6 130E6 -130E6 ga 6 0 11 12 110.0E-6 gcm 0 6 10 99 11.00E-12 iss 3 10 dc 10.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 9.095E3 rd2 4 12 9.095E3 ro1 8 5 50 ro2 7 99 25 rss 10 99 20.00E6 vb 9 0 dc 0 vc 3 53 dc .6 ve 54 4 dc .6 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 **************************** * A1_118 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0 1 FQ2 0 4 POLY(1) VQ2 0 -1 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=1.209E-3 Vto=-1) .ends * * A2_118E operational amplifier "macromodel" subcircuit * created using Parts release 6.0 on 05/20/94 at 09:20 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A2_118E 1 2 3 4 5 * c1 11 12 1.340E-12 c2 6 7 10.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 127.3E6 -130E6 130E6 130E6 -130E6 ga 6 0 11 12 110.0E-6 gcm 0 6 10 99 11.00E-12 iss 3 10 dc 10.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 9.095E3 rd2 4 12 9.095E3 ro1 8 5 50 ro2 7 99 25 rss 10 99 20.00E6 vb 9 0 dc 0 vc 3 53 dc .6 ve 54 4 dc .6 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 **************************** * A2_118 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0 1 FQ2 0 4 POLY(1) VQ2 0 -1 **************************** .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=1.209E-3 Vto=-1) .ends * * A3_118E operational amplifier "macromodel" subcircuit * created using Parts release 6.0 on 05/20/94 at 09:22 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A3_118E 1 2 3 4 5 * c1 11 12 3.501E-12 c2 6 7 10.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 212.2E6 -210E6 210E6 210E6 -210E6 ga 6 0 11 12 75.40E-6 gcm 0 6 10 99 754.0E-12 iee 10 4 dc 9.002E-6 hlim 90 0 vlim 1K q1 11 2 13 qx q2 12 1 14 qx r2 6 9 100.0E3 rc1 3 11 13.26E3 rc2 3 12 13.26E3 re1 13 10 7.514E3 re2 14 10 7.514E3 ree 10 99 22.22E6 ro1 8 5 75 ro2 7 99 75 vb 9 0 dc 0 vc 3 53 dc 1.400 ve 54 4 dc .8 vlim 7 8 dc 0 vlp 91 0 dc 4.5 vln 0 92 dc 11.5 **************************** * A3_118 "E" ENHANCEMENTS **************************** *OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 260.8E-6 1 FQ2 0 4 POLY(1) VQ2 261.0E-6 -1 * SUPPLY CURRENT VARIATION RQ 3 4 1.365E6 * .model dx D(Is=800.0E-18) .model qx NPN(Is=800.0E-18 Bf=4.500E3) .ends *$ ************************************************************************** * INA120 = A1_120 + A2_120 + A3_120 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 10/30/90 AT 15:01 * REV.A * * INA120 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA120/BB 1 2 3 4 5 8 9 10 * * A1_120 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 2 9 3 4 11 A1_120 * * A2_120 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 1 10 3 4 12 A2_120 * * A3_120 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_120 * R1 11 13 10.0000K R2 13 5 9.9995K C2 13 5 1.0000PF R3 12 14 10.0000K R4 14 8 10.0000K R1FB 9 11 20.0000K CC1 9 11 10.0000PF R2FB 10 12 20.0000K CC2 10 12 10.0000PF * .ENDS * * A1_120 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/07/90 AT 16:07 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_120 1 2 3 4 5 * C1 11 12 16.38E-12 C2 6 7 90.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 23.58E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 1.696E-3 GCM 0 6 10 99 3.385E-9 IEE 10 4 DC 108.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 589.5 RC2 3 12 589.5 RE1 13 10 110.5 RE2 14 10 110.5 REE 10 99 1.852E6 RO1 8 5 25 RO2 7 99 25 RP 3 4 33.63E3 VB 9 0 DC 0 VC 3 53 DC 2.200 VE 54 4 DC 2.200 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=7.714E3) .ENDS * * A2_120 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/07/90 AT 16:08 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_120 1 2 3 4 5 * C1 11 12 16.38E-12 C2 6 7 90.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 20.21E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 1.979E-3 GCM 0 6 10 99 1.979E-9 IEE 10 4 DC 108.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 505.3 RC2 3 12 505.3 RE1 13 10 26.28 RE2 14 10 26.28 REE 10 99 1.852E6 RO1 8 5 25 RO2 7 99 25 RP 3 4 33.63E3 VB 9 0 DC 0 VC 3 53 DC 2.200 VE 54 4 DC 2.200 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=7.714E3) .ENDS * * A3_120 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 11/07/90 AT 16:10 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_120 1 2 3 4 5 * C1 11 12 17.32E-12 C2 6 7 20.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 159.2E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 251.3E-6 GCM 0 6 10 99 251.3E-12 ISS 3 10 DC 20.00E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 3.979E3 RD2 4 12 3.979E3 RO1 8 5 25 RO2 7 99 25 RP 3 4 30.00E3 RSS 10 99 10.00E6 VB 9 0 DC 0 VC 3 53 DC 2.200 VE 54 4 DC 2.200 VLIM 7 8 DC 0 VLP 91 0 DC 24 VLN 0 92 DC 24 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=10.00E-12 BETA=1.579E-3 VTO=-1) .ENDS *$ ************************************************************************** * INA120E = A1_120E + A2_120E + A3_120E OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 10/30/90 AT 15:01 * REV.B 3/21/92 BCB: added input bias current correction * * INA120E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA120E/BB 1 2 3 4 5 8 9 10 * * A1_120E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 2 9 3 4 11 A1_120E * * A2_120E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 1 10 3 4 12 A2_120E * * A3_120E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_120E * R1 11 13 10.0000K R2 13 5 9.9995K C2 13 5 1.0000PF R3 12 14 10.0000K R4 14 8 10.0000K R1FB 9 11 20.0000K CC1 9 11 10.0000PF R2FB 10 12 20.0000K CC2 10 12 10.0000PF * .ENDS * * A1_120E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/07/90 AT 16:07 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_120E INP INN 3 4 5 * C1 11 12 16.38E-12 C2 6 7 90.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 23.58E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 1.696E-3 GCM 0 6 10 99 3.385E-9 IEE 10 4 DC 108.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 589.5 RC2 3 12 589.5 RE1 13 10 110.5 RE2 14 10 110.5 REE 10 99 1.852E6 RO1 8 5 25 RO2 7 99 25 * RP 3 4 33.63E3 VB 9 0 DC 0 VC 3 53 DC 2.200 VE 54 4 DC 2.200 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 **************************** * A1_120 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 8.72E-4 1 FQ2 0 4 POLY(1) VQ2 8.72E-4 -1 * QUIESCIENT CURRENT RQ 3 4 1.5E6 * DIFF INPUT CAPACITANCE CDIF 1 2 3.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT PROTECTION R1IN INP 1 1000 D1IN 1 2 DX R2IN INN 2 1000 D2IN 2 1 DX * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=7.714E3) .ENDS * * A2_120E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/07/90 AT 16:08 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A2_120E INP INN 3 4 5 * C1 11 12 16.38E-12 C2 6 7 90.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 20.21E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 1.979E-3 GCM 0 6 10 99 1.979E-9 IEE 10 4 DC 108.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 505.3 RC2 3 12 505.3 RE1 13 10 26.28 RE2 14 10 26.28 REE 10 99 1.852E6 RO1 8 5 25 RO2 7 99 25 * RP 3 4 33.63E3 VB 9 0 DC 0 VC 3 53 DC 2.200 VE 54 4 DC 2.200 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 **************************** * A2_120 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 8.72E-4 1 FQ2 0 4 POLY(1) VQ2 8.72E-4 -1 * QUIESCIENT CURRENT RQ 3 4 1.5E6 * DIFF INPUT CAPACITANCE CDIF 1 2 3.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT PROTECTION R1IN INP 1 1000 D1IN 1 2 DX R2IN INN 2 1000 D2IN 2 1 DX * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=7.714E3) .ENDS * * A3_120E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 11/07/90 AT 16:10 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_120E 1 2 3 4 5 * C1 11 12 17.32E-12 C2 6 7 20.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 159.2E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 251.3E-6 GCM 0 6 10 99 251.3E-12 ISS 3 10 DC 20.00E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (12,1) (10,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 3.979E3 RD2 4 12 3.979E3 RO1 8 5 25 RO2 7 99 25 * RP 3 4 30.00E3 RSS 10 99 10.00E6 VB 9 0 DC 0 VC 3 53 DC 2.200 VE 54 4 DC 2.200 VLIM 7 8 DC 0 VLP 91 0 DC 24 VLN 0 92 DC 24 **************************** * A3_120 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 9.60E-4 1 FQ2 0 4 POLY(1) VQ2 9.60E-4 -1 * QUIESCIENT CURRENT RQ 3 4 1.5E6 * DIFF INPUT CAPACITANCE CDIF 1 2 3.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=10.00E-12 BETA=1.579E-3 VTO=-1) .ENDS *$ ************************************************************************** * INA126P MICROPOWER INSTRUMENTATION AMPLIFIER MACROMODEL * REV A. 4/14/97 WM * REV B. 27 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO TOP OF FILE. * INA126 two opamp connections * * connections: Rg * | negative input * | | positive input * | | | negative power supply * | | | | ref * | | | | | output * | | | | | | positive power supply * | | | | | | | Rg * | | | | | | | | .subckt INA126P/BB 1 2 3 4 5 6 7 8 * x1 2 1 7 4 222 5 opamp1_126 x2 3 8 7 4 6 222 opamp2_126 * .ends * * INA126 operational amplifier "macromodel" subcircuits: * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | ref input * | | | | | | .subckt OPAMP1_126 1 2 3 4 5 22 * c1 11 12 2.9E-12 c2 6 7 12.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 42.44E6 -42E6 42E6 42E6 -42E6 ga 6 0 11 12 94.25E-6 gcm 0 6 10 99 942.5E-12 iee 3 10 dc 6.040E-6 hlim 90 0 vlim 1K q1 11 2 13 qx q2 12 1 14 qx r2 6 9 100.0E3 rc1 4 11 10.61E3 rc2 4 12 10.61E3 re1 13 10 1.976E3 re2 14 10 1.976E3 ree 10 99 33.11E6 ro1 8 5 50 ro2 7 99 25 rp 3 4 379.8E3 vb 9 0 dc 0 vc 3 53 dc 1 ve 54 4 dc 1 vlim 7 8 dc 0 vlp 91 0 dc 2 vln 0 92 dc 2 * .model dx D(Is=800.0E-18) .model qx PNP(Is=800.0E-18 Bf=150) * FEEDBACK RESISTORS RFB1 2 22 40K RFB2 2 5 10K * .ends * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | ref input * | | | | | | .subckt OPAMP2_126 1 2 3 4 5 22 * c1 11 12 2.9E-12 c2 6 7 12.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 42.44E6 -42E6 42E6 42E6 -42E6 ga 6 0 11 12 94.25E-6 gcm 0 6 10 99 942.5E-12 iee 3 10 dc 6.040E-6 hlim 90 0 vlim 1K q1 11 2 13 qx q2 12 1 14 qx r2 6 9 100.0E3 rc1 4 11 10.61E3 rc2 4 12 10.61E3 re1 13 10 1.976E3 re2 14 10 1.976E3 ree 10 99 33.11E6 ro1 8 5 50 ro2 7 99 25 rp 3 4 379.8E3 vb 9 0 dc 0 vc 3 53 dc 1 ve 54 4 dc 1 vlim 7 8 dc 0 vlp 91 0 dc 2 vln 0 92 dc 2 * .model dx D(Is=800.0E-18) .model qx PNP(Is=800.0E-18 Bf=150) * * FEEDBACK RESISTORS RFB3 2 22 10K RFB4 2 5 40K * .ends *$ ************************************************************************** * INA128 = A1_128 + A2_128 + A3_128 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 11/20/96 AT 15:01 * * Note: A1_128, A2_128 and A3_128 op amps modeled here for the INA128 * ARE NOT related to any standard BB op amps such as the OPA128. * * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA128 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA128/BB 1 2 3 4 5 8 9 10 * * A1_128 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_128 * * A2_128 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_128 * * A3_128 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_128 * R1 11 13 40.0000K R2 13 5 39.996K R3 12 14 40.0000K R4 14 8 40.0000K CIN 13 14 4.0000PF R1FB 9 11 25.000K CC1 17 11 5.0000PF R2FB 10 12 25.000K CC2 16 12 5.0000PF CG1 9 0 10.0000PF CG2 10 0 8.0000PF RCE 17 9 20G I1 3 16 DC 20.00E-6 I2 3 17 DC 20.00E-6 IB1CAN 3 1 DC 40.00E-9 IB2CAN 3 2 DC 40.00E-9 Ibal 0 4 DC 60.0E-6 D1 15 17 DX D2 15 16 DX Q1 16 1 10 QX Q2 17 2 9 QX V1 3 15 DC 1.700 * .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .ENDS * * A1_128 operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:19 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A1_128 1 2 3 4 5 * c1 11 12 2.887E-12 c2 6 7 10.00E-12 css 10 99 1.000E-30 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 79.58E6 -80E6 80E6 80E6 -80E6 ga 6 0 11 12 1.257E-3 gcm 0 6 10 99 125.7E-12 iss 3 10 dc 50.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 795.8 rd2 4 12 795.8 ro1 8 5 10 ro2 7 99 10 ip 3 4 dc 120u rp 3 4 3.00E6 rss 10 99 4.000E6 vb 9 0 dc 0 vc 3 53 dc 1.5 ve 54 4 dc .9 vlim 7 8 dc 0 vlp 91 0 dc 14 vln 0 92 dc 14 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=31.58E-3 Vto=-1) .ends * * A2_128 operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:19 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A2_128 1 2 3 4 5 * c1 11 12 2.887E-12 c2 6 7 10.00E-12 css 10 99 1.000E-30 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 79.58E6 -80E6 80E6 80E6 -80E6 ga 6 0 11 12 1.257E-3 gcm 0 6 10 99 125.7E-12 iss 3 10 dc 50.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 795.8 rd2 4 12 795.8 ro1 8 5 10 ro2 7 99 10 ip 3 4 dc 120u rp 3 4 3.00E6 rss 10 99 4.000E6 vb 9 0 dc 0 vc 3 53 dc 1.5 ve 54 4 dc .9 vlim 7 8 dc 0 vlp 91 0 dc 14 vln 0 92 dc 14 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=31.58E-3 Vto=-1) .ends * * A3_128 operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:33 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A3_128 1 2 3 4 5 * c1 11 12 2.730E-12 c2 6 7 15.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 163.2E6 -160E6 160E6 160E6 -160E6 ga 6 0 11 12 122.5E-6 gcm 0 6 10 99 12.25E-12 iee 10 4 dc 63.95E-6 hlim 90 0 vlim 1K q1 11 2 13 qx q2 12 1 14 qx r2 6 9 100.0E3 rc1 3 11 8.162E3 rc2 3 12 8.162E3 re1 13 10 7.327E3 re2 14 10 7.327E3 ree 10 99 3.127E6 ro1 8 5 10 ro2 7 99 10 ip 3 4 dc 220u rp 3 4 1.87E6 vb 9 0 dc 0 vc 3 53 dc 1.500 ve 54 4 dc 1.400 vlim 7 8 dc 0 vlp 91 0 dc 5 vln 0 92 dc 14 * .model dx D(Is=800.0E-18) .model qx NPN(Is=800.0E-18 Bf=318.8) .ends *$ ************************************************************************** * INA128E = A1_128E + A2_128E + A3_128E OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 12/11/96 AT 15:01 * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA128E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA128E/BB 1 2 3 4 5 8 9 10 * * A1_128E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_128E * * A2_128E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_128E * * A3_128E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_128E * R1 11 13 40.0000K R2 13 5 39.996K R3 12 14 40.0000K R4 14 8 40.0000K CIN 13 14 4.0000PF R1FB 9 11 25.000K CC1 17 11 5.0000PF R2FB 10 12 25.000K CC2 16 12 5.0000PF CG1 9 0 10.0000PF CG2 10 0 8.0000PF RCE 17 9 20G I1 3 16 DC 20.00E-6 I2 3 17 DC 20.00E-6 IB1CAN 3 42 DC 40.00E-9 IB2CAN 3 46 DC 40.00E-9 IBAL 0 4 DC 6.5E-6 D1 15 17 DX D2 15 16 DX Q1 16 42 10 QX Q2 17 46 9 QX V1 3 15 DC 1.700 ****************************** * Additions for the INA128E * * (Enhanced) macromodel * ****************************** * INPUT PROTECTION RIN1 1 41 1K I11 41 42 .7MA S11 41 42 1 41 SP DI1 43 41 DX I12 4 43 DC .8MA S12 4 43 1 41 SM RIN2 2 45 1K I21 45 46 .7MA S21 45 46 2 45 SP DI2 47 45 DX I22 4 47 DC .8MA S22 4 47 2 45 SM ************************* * Anti-inversion clamps * ************************* VSET1 3 40 DC 2.0 QSET1 4 40 42 QY VSET2 3 44 DC 2.0 QSET2 4 44 46 QY * .model sp vswitch(ron=10 roff=100E3 von=.7 voff=1) .model sm vswitch(ron=10 roff=100E3 von=-.7 voff=-1) .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .MODEL QY PNP(IS=800.0E-18 BF=500) .ENDS * * A1_128E operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:19 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A1_128E 1 2 3 4 5 * c1 11 12 2.887E-12 c2 6 7 10.00E-12 css 10 99 1.000E-30 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 79.58E6 -80E6 80E6 80E6 -80E6 ga 6 0 11 12 1.257E-3 gcm 0 6 10 99 125.7E-12 iss 3 10 dc 50.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 795.8 rd2 4 12 795.8 ro1 8 5 10 ro2 7 99 10 rss 10 99 4.000E6 vb 9 0 dc 0 vc 3 53 dc 1.5 ve 54 4 dc .9 vlim 7 8 dc 0 vlp 91 0 dc 14 vln 0 92 dc 14 ****************************** * Additions for the INA128E * * (Enhanced) macromodel * * A1_128e sub-circuit * ****************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 120u 1 FQ2 0 4 POLY(1) VQ2 120u -1 RP 3 4 3.00E6 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=31.58E-3 Vto=-1) .ends * * A2_128E operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:19 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A2_128E 1 2 3 4 5 * c1 11 12 2.887E-12 c2 6 7 10.00E-12 css 10 99 1.000E-30 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 79.58E6 -80E6 80E6 80E6 -80E6 ga 6 0 11 12 1.257E-3 gcm 0 6 10 99 125.7E-12 iss 3 10 dc 50.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 795.8 rd2 4 12 795.8 ro1 8 5 10 ro2 7 99 10 rss 10 99 4.000E6 vb 9 0 dc 0 vc 3 53 dc 1.5 ve 54 4 dc .9 vlim 7 8 dc 0 vlp 91 0 dc 14 vln 0 92 dc 14 ****************************** * Additions for the INA128E * * (Enhanced) macromodel * * A2_128e sub-circuit * ****************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 120u 1 FQ2 0 4 POLY(1) VQ2 120u -1 RP 3 4 3.00E6 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=31.58E-3 Vto=-1) .ends * * A3_128E operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:33 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A3_128E 1 2 3 4 5 * c1 11 12 2.730E-12 c2 6 7 15.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 163.2E6 -160E6 160E6 160E6 -160E6 ga 6 0 11 12 122.5E-6 gcm 0 6 10 99 12.25E-12 iee 10 4 dc 63.95E-6 hlim 90 0 vlim 1K q1 11 2 13 qx q2 12 1 14 qx r2 6 9 100.0E3 rc1 3 11 8.162E3 rc2 3 12 8.162E3 re1 13 10 7.327E3 re2 14 10 7.327E3 ree 10 99 3.127E6 ro1 8 5 300 ro2 7 99 300 vb 9 0 dc 0 vc 3 53 dc 1.500 ve 54 4 dc 1.400 vlim 7 8 dc 0 vlp 91 0 dc 5 vln 0 92 dc 14 ****************************** * * * Additions for the INA128E * * (Enhanced) macromodel * * A3_128e sub-circuit * * * ****************************** *OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 206.7E-6 1 FQ2 0 4 POLY(1) VQ2 206.7E-6 -1 RQ 3 4 1.87e6 * .model dx D(Is=800.0E-18) .model qx NPN(Is=800.0E-18 Bf=318.8) .ends *$ ************************************************************************** * INA129 = A1_129 + A2_129 + A3_129 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 11/20/96 AT 15:01 * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA129 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA129/BB 1 2 3 4 5 8 9 10 * * A1_129 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_129 * * A2_129 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_129 * * A3_129 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_129 * R1 11 13 40.0000K R2 13 5 39.996K R3 12 14 40.0000K R4 14 8 40.0000K CIN 13 14 4.0000PF R1FB 9 11 24.700K CC1 17 11 5.0000PF R2FB 10 12 24.700K CC2 16 12 5.0000PF CG1 9 0 10.0000PF CG2 10 0 8.0000PF RCE 17 9 20G I1 3 16 DC 20.00E-6 I2 3 17 DC 20.00E-6 IB1CAN 3 1 DC 40.00E-9 IB2CAN 3 2 DC 40.00E-9 Ibal 0 4 DC 60.0E-6 D1 15 17 DX D2 15 16 DX Q1 16 1 10 QX Q2 17 2 9 QX V1 3 15 DC 1.700 * .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .ENDS * * A1_129 operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:19 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A1_129 1 2 3 4 5 * c1 11 12 2.887E-12 c2 6 7 10.00E-12 css 10 99 1.000E-30 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 79.58E6 -80E6 80E6 80E6 -80E6 ga 6 0 11 12 1.257E-3 gcm 0 6 10 99 125.7E-12 iss 3 10 dc 50.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 795.8 rd2 4 12 795.8 ro1 8 5 10 ro2 7 99 10 ip 3 4 dc 120u rp 3 4 3.00E6 rss 10 99 4.000E6 vb 9 0 dc 0 vc 3 53 dc 1.5 ve 54 4 dc .9 vlim 7 8 dc 0 vlp 91 0 dc 14 vln 0 92 dc 14 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=31.58E-3 Vto=-1) .ends * * A2_129 operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:19 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A2_129 1 2 3 4 5 * c1 11 12 2.887E-12 c2 6 7 10.00E-12 css 10 99 1.000E-30 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 79.58E6 -80E6 80E6 80E6 -80E6 ga 6 0 11 12 1.257E-3 gcm 0 6 10 99 125.7E-12 iss 3 10 dc 50.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 795.8 rd2 4 12 795.8 ro1 8 5 10 ro2 7 99 10 ip 3 4 dc 120u rp 3 4 3.00E6 rss 10 99 4.000E6 vb 9 0 dc 0 vc 3 53 dc 1.5 ve 54 4 dc .9 vlim 7 8 dc 0 vlp 91 0 dc 14 vln 0 92 dc 14 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=31.58E-3 Vto=-1) .ends * * A3_129 operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:33 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A3_129 1 2 3 4 5 * c1 11 12 2.730E-12 c2 6 7 15.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 163.2E6 -160E6 160E6 160E6 -160E6 ga 6 0 11 12 122.5E-6 gcm 0 6 10 99 12.25E-12 iee 10 4 dc 63.95E-6 hlim 90 0 vlim 1K q1 11 2 13 qx q2 12 1 14 qx r2 6 9 100.0E3 rc1 3 11 8.162E3 rc2 3 12 8.162E3 re1 13 10 7.327E3 re2 14 10 7.327E3 ree 10 99 3.127E6 ro1 8 5 10 ro2 7 99 10 ip 3 4 dc 220u rp 3 4 1.87E6 vb 9 0 dc 0 vc 3 53 dc 1.500 ve 54 4 dc 1.400 vlim 7 8 dc 0 vlp 91 0 dc 5 vln 0 92 dc 14 * .model dx D(Is=800.0E-18) .model qx NPN(Is=800.0E-18 Bf=318.8) .ends *$ ************************************************************************** * INA129E = A1_129E + A2_129E + A3_129E OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 12/11/96 AT 15:01 * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA129E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SENSE 1 * | | | | | | | GAIN SENSE 2 * | | | | | | | | .SUBCKT INA129E/BB 1 2 3 4 5 8 9 10 * * A1_129E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 15 17 3 4 11 A1_129E * * A2_129E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 15 16 3 4 12 A2_129E * * A3_129E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 14 13 3 4 5 A3_129E * R1 11 13 40.0000K R2 13 5 39.996K R3 12 14 40.0000K R4 14 8 40.0000K CIN 13 14 4.0000PF R1FB 9 11 24.700K CC1 17 11 5.0000PF R2FB 10 12 24.700K CC2 16 12 5.0000PF CG1 9 0 10.0000PF CG2 10 0 8.0000PF RCE 17 9 20G I1 3 16 DC 20.00E-6 I2 3 17 DC 20.00E-6 IB1CAN 3 42 DC 40.00E-9 IB2CAN 3 46 DC 40.00E-9 IBAL 0 4 DC 6.5E-6 D1 15 17 DX D2 15 16 DX Q1 16 42 10 QX Q2 17 46 9 QX V1 3 15 DC 1.700 ****************************** * Additions for the INA129E * * (Enhanced) macromodel * ****************************** * INPUT PROTECTION RIN1 1 41 1K I11 41 42 .7MA S11 41 42 1 41 SP DI1 43 41 DX I12 4 43 DC .8MA S12 4 43 1 41 SM RIN2 2 45 1K I21 45 46 .7MA S21 45 46 2 45 SP DI2 47 45 DX I22 4 47 DC .8MA S22 4 47 2 45 SM ************************* * Anti-inversion clamps * ************************* VSET1 3 40 DC 2.0 QSET1 4 40 42 QY VSET2 3 44 DC 2.0 QSET2 4 44 46 QY * .model sp vswitch(ron=10 roff=100E3 von=.7 voff=1) .model sm vswitch(ron=10 roff=100E3 von=-.7 voff=-1) .MODEL DX D(IS=1.0E-24) .MODEL QX NPN(IS=800.0E-18 BF=500) .MODEL QY PNP(IS=800.0E-18 BF=500) .ENDS * * A1_129E operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:19 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A1_129E 1 2 3 4 5 * c1 11 12 2.887E-12 c2 6 7 10.00E-12 css 10 99 1.000E-30 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 79.58E6 -80E6 80E6 80E6 -80E6 ga 6 0 11 12 1.257E-3 gcm 0 6 10 99 125.7E-12 iss 3 10 dc 50.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 795.8 rd2 4 12 795.8 ro1 8 5 10 ro2 7 99 10 rss 10 99 4.000E6 vb 9 0 dc 0 vc 3 53 dc 1.5 ve 54 4 dc .9 vlim 7 8 dc 0 vlp 91 0 dc 14 vln 0 92 dc 14 ****************************** * Additions for the INA129E * * (Enhanced) macromodel * * A1_129e sub-circuit * ****************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 120u 1 FQ2 0 4 POLY(1) VQ2 120u -1 RP 3 4 3.00E6 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=31.58E-3 Vto=-1) .ends * * A2_129E operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:19 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A2_129E 1 2 3 4 5 * c1 11 12 2.887E-12 c2 6 7 10.00E-12 css 10 99 1.000E-30 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 79.58E6 -80E6 80E6 80E6 -80E6 ga 6 0 11 12 1.257E-3 gcm 0 6 10 99 125.7E-12 iss 3 10 dc 50.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 795.8 rd2 4 12 795.8 ro1 8 5 10 ro2 7 99 10 rss 10 99 4.000E6 vb 9 0 dc 0 vc 3 53 dc 1.5 ve 54 4 dc .9 vlim 7 8 dc 0 vlp 91 0 dc 14 vln 0 92 dc 14 ****************************** * Additions for the INA129E * * (Enhanced) macromodel * * A2_129e sub-circuit * ****************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 120u 1 FQ2 0 4 POLY(1) VQ2 120u -1 RP 3 4 3.00E6 * .model dx D(Is=800.0E-18) .model jx PJF(Is=15.00E-12 Beta=31.58E-3 Vto=-1) .ends * * A3_129E operational amplifier "macromodel" subcircuit * created using Parts release 6.3a on 11/18/96 at 14:33 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A3_129E 1 2 3 4 5 * c1 11 12 2.730E-12 c2 6 7 15.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 163.2E6 -160E6 160E6 160E6 -160E6 ga 6 0 11 12 122.5E-6 gcm 0 6 10 99 12.25E-12 iee 10 4 dc 63.95E-6 hlim 90 0 vlim 1K q1 11 2 13 qx q2 12 1 14 qx r2 6 9 100.0E3 rc1 3 11 8.162E3 rc2 3 12 8.162E3 re1 13 10 7.327E3 re2 14 10 7.327E3 ree 10 99 3.127E6 ro1 8 5 300 ro2 7 99 300 vb 9 0 dc 0 vc 3 53 dc 1.500 ve 54 4 dc 1.400 vlim 7 8 dc 0 vlp 91 0 dc 5 vln 0 92 dc 14 ****************************** * Additions for the INA129E * * (Enhanced) macromodel * * A3_129e sub-circuit * ****************************** *OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 206.7E-6 1 FQ2 0 4 POLY(1) VQ2 206.7E-6 -1 RQ 3 4 1.87e6 * .model dx D(Is=800.0E-18) .model qx NPN(Is=800.0E-18 Bf=318.8) .ends * XDUT 1 2 3 4 5 8 9 10 INA129E/BB VSUP1 3 0 DC 15 VSUP2 0 4 DC 15 VREF 8 0 DC 0 VP 1 0 DC 0 *VP 1 0 PULSE(0 .1 2ns 2ns 2ns 30us 60us) VM 2 0 AC 1 *VM 2 0 PULSE(0 -.1 2ns 2ns 2ns 80us 160us) RG 9 10 RMOD {RVAL} *RG 9 10 50.05 *RL 5 0 10K *CL 5 0 10000PF * .MODEL RMOD RES(R=1) * .OP .PROBE .AC DEC 10 .010 10000000 .DC VP -40 40 .05 .PARAM RVAL:1000 .STEP PARAM RVAL LIST 1000000000000 5555.5 505.05 50.05 *.TRAN 2ns 60us 100ns 100ns *.NOISE V([5]) VM 10 *.OPTIONS ITL1=1000 ;ITL2=100 *$ ************************************************************************** * INA131 = 2 x A1_131 + A3_131 OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 1/10/93 BY JLA. INA114E.MOD MODIFIED TO INA131 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * NODE ASSIGNMENTS OF SUBCKT INA131 CORRESPOND TO 8 PIN DIP PACKAGE OF * BURR-BROWN'S INA131 * * INA131 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SET 1 * | | | | | | | GAIN SET 2 * | | | | | | | | .SUBCKT INA131/BB 3 2 7 4 6 5 1 8 * * A1_131 SUBCIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 2 1 7 4 10 A1_131 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 3 8 7 4 11 A1_131 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 13 12 7 4 6 A3_131 * RFB1 10 1 25K RFB2 11 8 25K R1 10 12 5K R2 12 6 24.9985K R3 11 13 5K R4 13 5 25K C1 12 6 5P C2 13 5 5P CC1 10 1 5P CC2 11 8 5P RG1 1 8 2631.58 * .ENDS * * A1_131 OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:21 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_131 1 2 3 4 5 * C1 11 12 6.060E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 165.8E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 188.5E-12 IEE 10 4 DC 27E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 5.305E3 RC2 3 12 5.305E3 RE1 13 10 4.348E3 RE2 14 10 4.348E3 REE 10 99 7.4074E6 RO1 8 5 40 RO2 7 99 320 RP 3 4 52.53E3 VB 9 0 DC 0 VC 3 53 DC 1.672 VE 54 4 DC 1.672 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=36.00E3 NC=100 NR=100) .ENDS * * A3_131 OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:46 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_131 1 2 3 4 5 * C1 11 12 13.51E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 251.9E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 339.3E-6 GCM 0 6 10 99 339.3E-12 IEE 10 4 DC 18E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.947E3 RC2 3 12 2.947E3 RE1 13 10 74.778 RE2 14 10 74.778 REE 10 99 11.111E6 RO1 8 5 13 RO2 7 99 117 RP 3 4 30.123E3 VB 9 0 DC 0 VC 3 53 DC 1.972 VE 54 4 DC 1.972 VLIM 7 8 DC 0 VLP 91 0 DC 12 VLN 0 92 DC 12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=30.00E3) .ENDS *$ ************************************************************************** * INA131E = 2 x A1_131E + A3_131E OP AMPS + PRECISION RESISTOR NETWORK * CREATED ON 1/10/93 BY JLA. INA114E.MOD MODIFIED TO INA131 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * NODE ASSIGNMENTS OF SUBCKT INA131 CORRESPOND TO 8 PIN DIP PACKAGE OF * BURR-BROWN'S INA131 * * INA131E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | GAIN SET 1 * | | | | | | | GAIN SET 2 * | | | | | | | | .SUBCKT INA131E/BB 3 2 7 4 6 5 1 8 * * A1_131E SUBCIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 2 1 7 4 10 A1_131E * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 3 8 7 4 11 A1_131E * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 13 12 7 4 6 A3_131E * RFB1 10 1 25K RFB2 11 8 25K R1 10 12 5K R2 12 6 24.9985K R3 11 13 5K R4 13 5 25K C1 12 6 5P C2 13 5 5P CC1 10 1 5P CC2 11 8 5P RG1 1 8 2631.58 * .ENDS * * A1_131E OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:21 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A1_131E 1 2 3 4 5 * C1 11 12 6.060E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 165.8E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 188.5E-12 IEE 10 4 DC 27E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 5.305E3 RC2 3 12 5.305E3 RE1 13 10 4.348E3 RE2 14 10 4.348E3 REE 10 99 7.4074E6 RO1 8 5 40 RO2 7 99 320 VB 9 0 DC 0 VC 3 53 DC 1.672 VE 54 4 DC 1.672 VLIM 7 8 DC 0 VLP 91 0 DC 2 VLN 0 92 DC 2 **************************** * A1_131E "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0 1 FQ2 0 4 POLY(1) VQ2 0 -1 * QUIESCIENT CURRENT RQ 3 4 52.53E3 * DIFF INPUT CAPACITANCE CDIF 1 2 3E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 0 3E-12 C2CM 2 0 3E-12 * INPUT PROTECTION VS11 3 31 0 FS11 0 3 VS11 1 S11 31 0 1 0 SP FS12 1 4 VS11 1 VS21 32 4 0 FS21 4 0 VS21 1 S21 0 32 1 0 SM FS22 3 1 VS21 1 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=36.00E3 NC=100 NR=100) .MODEL SP VSWITCH(RON=10K ROFF=100G VON=15.6 VOFF=15.5) .MODEL SM VSWITCH(RON=10K ROFF=100G VON=-15.6 VOFF=-15.5) .ENDS * * A3_131E OPERATIONAL AMPLIFIER " MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 5.0 ON 1/22/92 AT 13:46 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT A3_131E 1 2 3 4 5 * C1 11 12 13.51E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 251.9E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 339.3E-6 GCM 0 6 10 99 339.3E-12 IEE 10 4 DC 18E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 2.947E3 RC2 3 12 2.947E3 RE1 13 10 74.778 RE2 14 10 74.778 REE 10 99 11.111E6 RO1 8 5 13 RO2 7 99 117 VB 9 0 DC 0 VC 3 53 DC 1.972 VE 54 4 DC 1.972 VLIM 7 8 DC 0 VLP 91 0 DC 12 VLN 0 92 DC 12 **************************** * A3_131E "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0 1 FQ2 0 4 POLY(1) VQ2 0 -1 * QUIESCIENT CURRENT RQ 3 4 30.123E3 * DIFF INPUT CAPACITANCE CDIF 1 2 10E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 0 5E-12 C2CM 2 0 5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=30.00E3) .ENDS *$ ************************************************************************** * INA132 = A3_132 OPERATIONAL AMPLIFIER + PRECISION RESISTOR NETWORK * CREATED ON 11/12/96 AT 4:50 * REV.A * REV.B 18 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * Notes on the INA132 macromodel: The only modification * made to the standard model was the inclusion of current source * ip. The combination of ip and rp give a better simulation of * quiescent current over different supply voltages. * * INA132 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | SENSE * | | | | | | | .SUBCKT INA132/BB 1 2 3 4 5 8 9 * * A3_132 SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 14 13 3 4 5 A3_132 * R1 2 13 40000 R2 13 9 39997 C2 13 9 .15p R3 1 14 40000 R4 14 8 40000 * .ENDS * * INA132 operational amplifier "macromodel" subcircuit * created using Parts release 6.0 on 11/08/96 at 17:04 * Parts is a OrCAD product. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A3_132 1 2 3 4 5 * c1 11 12 7.279E-12 c2 6 7 40.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 1.326E9 -1E9 1E9 1E9 -1E9 ga 6 0 11 12 75.40E-6 gcm 0 6 10 99 377.0E-12 iee 3 10 dc 4.730E-6 hlim 90 0 vlim 1K q1 11 2 13 qx q2 12 1 14 qx r2 6 9 100.0E3 rc1 4 11 13.26E3 rc2 4 12 13.26E3 re1 13 10 .9k re2 14 10 .9k ree 10 99 42.28E6 ro1 8 5 200 ro2 7 99 200 vb 9 0 dc 0 vc 3 53 dc 1.350 ve 54 4 dc .80 vlim 7 8 dc 0 vlp 91 0 dc 12 vln 0 92 dc 12 rp 3 4 5E6 ip 3 4 149u * .model dx D(Is=800.0E-18) .model qx PNP(Is=800.0E-18 Bf=300) .ENDS *$ ************************************************************************** * INA132E = A3_132E OPERATIONAL AMPLIFIER + PRECISION RESISTOR NETWORK * "E" IS ENHANCED MODEL * CREATED ON 11/11/96 AT 2:50 * REV.A * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * INA132E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | REFERENCE * | | | | | | SENSE * | | | | | | | .SUBCKT INA132E/BB 1 2 3 4 5 8 9 * * A3_132E SUB-CIRCUIT * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 14 13 3 4 5 A3_132E * R1 2 13 40000 R2 13 9 39997 C2 13 9 .15p R3 1 14 40000 R4 14 8 40000 * .ENDS * * INA132E operational amplifier "macromodel" subcircuit * created using Parts release 6.0 on 11/08/96 at 17:04 * Parts is a OrCAD product. * * Notes on construction of the INA132E Extended Macromodel: * * Differential and Common-Mode capacitances for the op-amp have been * eliminated because the inputs to the op-amp are not brought out of * the package. This limits the capacitance at those nodes. Any effect * on the AC performance of the part (particularly the AC CMRR) is * minimal because of the INA132's bandwidth of 300kHz * * The noise of the simulated op-amp is larger than that in the actual * circuit. This comes from the op-amp that was generated by the Micro- * Sim Parts program. It should be noted that the dominant source of * voltage noise is the four 40K resistors. VN1, VN2, DN1, DN2, and EN * are included so that the 1/f noise is accurately simulated. * The input bias current is also roughly half of the actual circuit. * This discrepancy also comes from the Parts program. * * Simulations involving capacitive load drive are approximate. In the * actual circuit, the output stage characteristics change more * with the type of load. Swing to the rails are also modeled with * approximations for the same reasons. * * While using the simulation in single supply, the simulation may not * give the correct result for the current coming out of the supplies * due to the nature of the model. The model was designed for dual * supply operation. * * For further information see the INA132 data sheet and the Burr-Brown * *** Based Macromodels Applications Bulletin. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt A3_132E 1 2 3 4 5 * c1 11 12 7.279E-12 c2 6 7 40.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 1.326E9 -1E9 1E9 1E9 -1E9 ga 6 0 11 12 75.40E-6 gcm 0 6 10 99 377.0E-12 iee 3 10 dc 4.730E-6 hlim 90 0 vlim 1K q1 11 2 13 qx q2 12 64 14 qx r2 6 9 100.0E3 rc1 4 11 13.26E3 rc2 4 12 13.26E3 re1 13 10 .9k re2 14 10 .9k ree 10 99 42.28E6 ro1 8 5 200 ro2 7 99 200 vb 9 0 dc 0 vc 3 53 dc 1.350 ve 54 4 dc .80 vlim 7 8 dc 0 vlp 91 0 dc 12 vln 0 92 dc 12 ********************************** * * * Additions for the * * INA132E (enhanced) macro model * * * ********************************** rp 3 4 5E6 ; replace rp w/ rp and ip to ; get correct Iq change w/supply dq1 20 21 dx dq2 22 20 dx vq1 21 0 0 vq2 22 0 0 fq1 3 0 poly(1) vq1 149u 1 ; Models current from fq2 0 4 poly(1) vq2 149u -1 ; supplies with load fq3 0 20 poly(1) vlim 0 1 vn1 61 0 .6 ; Noise model (1/f portion) vn2 0 62 .6 dn1 61 63 dy dn2 63 62 dy en 64 1 63 0 .6 * .model dx D(Is=800.0E-18) .model dy D(Is=1.9E-16 AF=1 KF=2.258E-17) .model qx PNP(Is=800.0E-18 Bf=300) .ENDS *$ ************************************************************************** * ISO120X *** MACROMODEL-- Copyright 1990 Burr-Brown Corp. * REV.B 6/11/92 BCB, adjusted Iq to PDS typ, added Vos, adjusted output * swing to PDS typ, adjusted barrier impedance * * Users should very carefully note the following factors regarding this * model: * * To help designers working with the IS0120 isolation amplifiers, * a *** listing for an equivalent circuit was developed (the listing * for the actual circuit is extremely long). Also, owing to the digital * transmission of the signal across the barrier, the listing for the * actual circuit could only be run with transient analysis, which would * be impractical for an application circuit. The equivalent circuit * listing, though, should be helpful. * * The equivalent circuit simulates both quiescent and output loading. * The model includes the output voltage swing and current limit, the * bandwidth, and the input and output impedance limits. It doesn't * simulate synchronization, though, nor the notched response. The macro * circuit may be run with ac, dc, or transient analysis. * * CONNECTIONS: +VS1 * | -VS1 * | | COM2 * | | | VOUT * | | | | VOUT SENSE * | | | | | GND2 * | | | | | | C2H * | | | | | | | C2L * | | | | | | | | +VS2 * | | | | | | | | | -VS2 * | | | | | | | | | | COM1 * | | | | | | | | | | | VIN * | | | | | | | | | | | | GND1 * | | | | | | | | | | | | | .SUBCKT ISO120X/BB 3 4 9 10 11 12 13 14 15 16 21 23 24 * *NOTE PINS 1, 2, AND 22 (C1H. C1L AND EXT OSC ARE NOT USED *POWER SUPPLY OUIESCENT CURRENTS * I1 3 24 4.0E-3 I2 24 4 4.0E-3 I3 15 12 4.5E-3 I4 12 16 4.5E-3 *INPUT SECTION VOS 23 60 5E-3 R1 60 50 200E3 R2 50 51 200E3 E1 51 21 21 50 100E3 E2 52 9 51 21 1 *OUTPUT SECTION R3 52 13 200E3 R4 13 11 200E3 R5 10 12 20E3 C1 13 14 150E-12 E3 14 12 9 13 1.6E3 E4 54 12 14 12 6.28 Q1 55 55 54 N Q2 56 56 54 P Q3 57 55 10 N Q4 58 56 10 P * .MODEL N NPN BF=100 .MODEL P PNP BF=100 V1 15 57 2.5 V2 58 16 2.5 I5 15 55 250E-6 I6 56 16 250E-6 *BARRIER IMPEDANCE R6 24 12 100E12 C2 24 12 2E-12 *REFERENCE TO NODE 0 NEEDED BY SOME VERSIONS OF *** R7 23 0 100E9 .ENDS *$ ************************************************************************** * ISO121X *** MODEL-- Copyright 1990 Burr-Brown Corp. * Rev.B 6/11/92 BCB, adjusted Iq to PDS typ, added Vos, adjusted output * swing to PDS typ, adjusted barrier impedance * * Users should very carefully note the following factors regarding this * model: * * To help designers working with the IS0121 isolation amplifiers, * a *** listing for an equivalent circuit was developed (the listing * for the actual circuit is extremely long). Also, owing to the digital * transmission of the signal across the barrier, the listing for the * actual circuit could only be run with transient analysis, which would * be impractical for an application circuit. The equivalent circuit * listing, though, should be helpful. * * The equivalent circuit simulates both quiescent and output loading. * The model includes the output voltage swing and current limit, the * bandwidth, and the input and output impedance limits. It doesn't * simulate synchronization, though, nor the notched response. The macro * circuit may be run with ac, dc, or transient analysis. * * +VS1 * | -VS1 * | | COM2 * | | | VOUT * | | | | VOUT SENSE * | | | | | GND2 * | | | | | | C2H * | | | | | | | C2L * | | | | | | | | +VS2 * | | | | | | | | | -VS2 * | | | | | | | | | | COM1 * | | | | | | | | | | | VIN * | | | | | | | | | | | | GND1 * | | | | | | | | | | | | | .SUBCKT ISO121X/BB 3 4 17 18 19 20 21 22 23 24 37 39 40 * *NOTE PINS 1, 2, AND 38 (C1H. C1L AND EXT OSC ARE NOT USED *POWER SUPPLY OUIESCENT CURRENTS * I1 3 40 4.0E-3 I2 40 4 4.0E-3 I3 23 20 4.5E-3 I4 20 24 4.5E-3 *INPUT SECTION VOS 39 60 5E-3 R1 60 50 200E3 R2 50 51 200E3 E1 51 37 37 50 100E3 E2 52 17 51 37 1 *OUTPUT SECTION R3 52 21 200E3 R4 21 19 200E3 R5 18 20 20E3 C1 21 22 150E-12 E3 22 20 17 21 1.6E3 E4 54 20 22 20 6.28 Q1 55 55 54 N Q2 56 56 54 P Q3 57 55 18 N Q4 58 56 18 P * .MODEL N NPN BF=100 .MODEL P PNP BF=100 V1 23 57 2.5 V2 58 24 2.5 I5 23 55 250E-6 I6 56 24 250E-6 *BARRIER IMPEDANCE R6 40 20 100E12 C2 40 20 2E-12 *REFERENCE TO NODE 0 NEEDED BY SOME VERSIONS OF *** R7 39 0 100E9 * .ENDS *$ ************************************************************************** * ISO130X SIMPLIFIED CIRCUIT MODEL * CREATED 12/19/94 SB * REV. A * * CONNECTIONS: VS1 * | VIN+ * | | VIN- * | | | GND1 * | | | | GND2 * | | | | | VOUT- * | | | | | | VOUT+ * | | | | | | | VS2 .SUBCKT ISO130X/BB 1 2 3 4 5 6 7 8 * * INPUT STAGE D1 2 1 DMOD D2 3 1 DMOD R1 2 9 530 R2 3 10 530 D3 4 9 DMOD D4 4 10 DMOD R3 4 9 530k R4 4 10 530k I1 4 9 670n I2 4 10 670n GVS1 1 4 POLY(1) (22,23) 4.37M 0 -445U 0 69.1U 0 -6.34U R5 1 4 790 E1 11 5 POLY(1) (9,10) -3.6M 4 V2 13 11 2.395 V3 12 5 3.61 Q1 13 11 14 QMOD Q2 17 5 16 QMOD RE1 14 15 31k RE2 15 16 31k I3 15 5 37.356U R6 12 17 65.7k TDELAY 17 5 18 5 Z0=65.7k TD=970n C1 18 5 6.3p R7 18 19 65.7k C2 19 5 6.3p R8 19 20 52.7k C3 20 22 15.2p R9 20 21 52.7k C4 21 5 6.52p E2 22 5 21 5 1 E3 23 5 POLY(1) (22,5) 4.79 -1 R10 22 7 11 R11 23 6 11 R12 8 5 2.2k GVS2 8 5 POLY(1) (22,23) 8.71M 145U 189U -1.22U -15.8U -127N 1.43U * .MODEL DMOD D IS=8E-13 .MODEL QMOD NPN .ENDS *$ ************************************************************************** * IVC102M (switched integrator) MULTIPLE POLE/ZERO MACROMODEL * REV. A Created 5-30-96 BCB * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * NOTES : * 1. The transient time for the input to the switches (HOLD and * RESET) should be programmed to 6V/usec. * Complying with this requirment will give you greater * success in convergence during transient analysis and * a more accurate simulation of the effect of the 200nsec * switching speed of the actual switching transistors in * the IVC102. This is easily implemented with the PULSE * command in ***. If your input signal to the switches * is faster than recommended above, the R-C, low-pass filter * on the input of the switch will slow the signal down some- * what, however not enough to comply with the data sheet stated * switching speeds of 200nsec. * 2. To insure proper operation, always establish the initial * bias point for the transient analysis with RESET and * HOLD equal to the potential at COM * * AGND * | SWIN (SWITCH IN) * | | INM * | | | C1 * | | | | C2 * | | | | | C3 * | | | | | | VM (NEGATIVE SUPPLY) * | | | | | | | VOUT * | | | | | | | | S1 (HOLD) * | | | | | | | | | S2 (RESET) * | | | | | | | | | | DGND * | | | | | | | | | | | VP (POSITIVE SUPPLY) * | | | | | | | | | | | | .SUBCKT IVC102M/BB 1 2 3 4 5 6 9 10 11 12 13 14 * X1 3 1 10 9 14 OPA_102 *Integration Capacitors C1 10 4 CC 10E-12 C2 10 5 CC 30E-12 C3 10 6 CC 60E-12 * Switches SH1 2 3 11 13 SWH SH2 2 3 2 13 SWT SR 3 10 12 13 SWR * .MODEL SWH VSWITCH(RON=1000G ROFF=1.7E3 VON=2 VOFF=0.8) .MODEL SWR VSWITCH(RON=1000G ROFF=1.5E3 VON=2 VOFF=0.8) .MODEL SWT VSWITCH(RON=1000G ROFF=10 VON=0.45 VOFF=0.55) .MODEL CC CAP(VC1=25E-6 TC1=-25E-6) .ENDS * * INM * | INP * | | OUT * | | | VM * | | | | VP * | | | | | .SUBCKT OPA_102 2 3 6 4 7 * * Amp input stage (2nd pole @ 35M Hz) J11 15 2 14 JX J12 16 13 14 JX C12 15 16 18.2E-12 R13 15 7 796 R14 16 7 796 ISS 14 4 1.11E-3 VOS 13 3 0.5E-3 G1 2 30 POLY(3) (15,2) (14,2) (30,2) 0 1E-12 1E-12 1E-12 G2 13 30 POLY(3) (16,13) (14,13) (30,13) 0 1E-12 1E-12 1E-12 * Amp gain stage (130dB) and first pole (@ 4.20K HZ) R27 7 21 2.45E9 R28 4 21 2.45E9 C22 7 21 100E-12 C23 4 21 100E-12 G21 7 21 POLY(1) 15 16 1.451E-3 1.256E-3 G22 21 4 POLY(1) 16 15 1.451E-3 1.256E-3 I22 7 13 2.2E-3 V21 7 22 1.885 V22 23 4 1.885 D21 21 22 DX D22 23 21 DX * Amp correction current and output stage IPS 7 30 9E-3 RPS 7 30 100E3 R9 7 71 100E3 R10 4 71 100E3 D91 21 6 DX D92 6 21 DX D93 7 94 DX D94 7 95 DX D95 4 94 DY D96 4 95 DY G91 7 6 21 7 .020387 G92 4 6 21 4 .020387 G95 94 4 6 21 .020387 G96 95 4 21 6 .020387 R91 7 6 49.051 R92 4 6 49.051 * Models .MODEL JX NJF(BETA=.788E-3 VTO=-2 IS=5E-14) .MODEL DX D(IS=1E-15) .MODEL DY D(IS=1E-15 BV=50) .ENDS *$ ************************************************************************** * MPC100X1 4X1 VIDEO MULTIPLEXER MACROMODEL * REV.A 7/6/92 KL * REV.B 2/14/96 SB changed node assignments * * CONNECTIONS: IN 1 * | IN 2 * | | IN 3 * | | | IN 4 * | | | | SELECT 4 * | | | | | SELECT 3 * | | | | | | POSITIVE SUPPLY * | | | | | | | OUPUT * | | | | | | | | NEGATIVE SUPPLY * | | | | | | | | | SELECT 2 * | | | | | | | | | | SELECT 1 * | | | | | | | | | | | .SUBCKT MPC100X1/BB 1 3 5 7 8 9 10 11 12 13 14 * X1 1 12 11 10 14 MUX1 ; One of four muxes X2 3 12 11 10 13 MUX1 ; One of four muxes X3 5 12 11 10 9 MUX1 ; One of four muxes X4 7 12 11 10 8 MUX1 ; One of four muxes * C208 8 0 2E-12 C209 9 0 2E-12 C211 11 0 2E-12 C213 13 0 2E-12 C214 14 0 2E-12 * .ENDS * * ONE OF FOUR CHANNELS OF THE VIDEO SIGNAL MULTIPLEXER * INPUT * | NEGATIVE SUPPLY * | | OUTPUT * | | | POSITIVE SUPPLY * | | | | SELECT * | | | | | * | | | | | .SUBCKT MUX1 1 10 11 12 14 * V22 22 0 1.5 V27 12 27 1.5 V28 28 10 1.5 G21 25 26 14 22 -87E-6 C23 23 0 2.0E-12 C24 23 11 0.1E-12 C25 25 0 0.6E-12 C26 26 0 0.6E-12 R21 14 0 40E3 R22 22 0 1E9 R23 23 0 1.3E6 R24 23 1 145 Q22 10 10 25 NI Q21 26 26 12 NI Q23 10 23 25 PI Q24 12 23 26 NI Q25 27 25 11 NI 4 Q26 28 26 11 PI 4 * .MODEL NI NPN .MODEL PI PNP .ENDS *$ ************************************************************************** * MPC100X2 4X1 VIDEO MULTIPLEXER MACROMODEL * REV.A 7/6/92 KL * REV.B 2/14/96 SB changed node assignments * * NOTE: CHANNELS THAT ARE DISABLED DURING DC CONVERGENCE REQUIRE A NODESET. * BRIEFLY, THE NODES FOR THE MUX2 SUBCIRCUIT SHOULD BE SET AS FOLLOWS: * V(27)=+4.61943527 V(28)=-4.61934561 * V(35)=-2.80931530 V(36)=+2.80931527 * V(39)=-1.30810853 V(40)=+1.30803889 * V(41)=-34.818621E-6 * THE FILE THAT CONTAINS THE COMMAND TO ACCESS THIS MACRO MODEL SHOULD * CONTAIN THIS NODE SET FOR THE DISABLED CHANNELS OF THE MPC100. FOR * EXAMPLE, IF CHANNEL A IS ON AND CHANNEL B, C, AND D ARE OFF DURING * DC CONVERGENCE AND THE DEVICE NAME FOR THE MPC100X2 MODEL IS IS X1, * THE REQUIRED NODESET WOULD BE: * * Channel B = OFF * .NODESET V(X1.X2.27)=+4.61943527 V(X1.X2.28)=-4.61934561 * .NODESET V(X1.X2.35)=-2.80931530 V(X1.X2.36)=+2.80931527 * .NODESET V(X1.X2.39)=-1.30810853 V(X1.X2.40)=+1.30803889 * .NODESET V(X1.X2.41)=-34.818621E-6 * *Channel C = OFF * .NODESET V(X1.X3.27)=+4.61943527 V(X1.X3.28)=-4.61934561 * .NODESET V(X1.X3.35)=-2.80931530 V(X1.X3.36)=+2.80931527 * .NODESET V(X1.X3.39)=-1.30810853 V(X1.X3.40)=+1.30803889 * .NODESET V(X1.X3.41)=-34.818621E-6 * *Channel D = OFF * .NODESET V(X1.X4.27)=+4.61943527 V(X1.X4.28)=-4.61934561 * .NODESET V(X1.X4.35)=-2.80931530 V(X1.X4.36)=+2.80931527 * .NODESET V(X1.X4.39)=-1.30810853 V(X1.X4.40)=+1.30803889 * .NODESET V(X1.X4.41)=-34.818621E-6 * * CONNECTIONS: IN 1 * | IN 2 * | | IN 3 * | | | IN 4 * | | | | SELECT 4 * | | | | | SELECT 3 * | | | | | | POSITIVE SUPPLY * | | | | | | | OUPUT * | | | | | | | | NEGATIVE SUPPLY * | | | | | | | | | SELECT 2 * | | | | | | | | | | SELECT 1 * | | | | | | | | | | | .SUBCKT MPC100X2/BB 1 3 5 7 8 9 10 11 12 13 14 * X1 1 12 11 10 14 MUX2 ; One of four muxes X2 3 12 11 10 13 MUX2 ; One of four muxes X3 5 12 11 10 9 MUX2 ; One of four muxes X4 7 12 11 10 8 MUX2 ; One of four muxes * C201 1 0 2E-12 C203 3 0 2E-12 C205 5 0 2E-12 C207 7 0 2E-12 C208 8 0 2E-12 C209 9 0 2E-12 C211 11 0 2E-12 C213 13 0 2E-12 C214 14 0 2E-12 * .ENDS * * ONE OF FOUR CHANNELS OF THE VIDEO SIGNAL MULTIPLEXER * INPUT * | NEGATIVE SUPPLY * | | OUTPUT * | | | POSITIVE SUPPLY * | | | | SELECT * | | | | | * | | | | | .SUBCKT MUX2 1 10 11 12 14 * C24 24 0 3.0E-12 C28 28 10 0.1E-12 C33 1 11 0.1E-12 * R21 21 14 40E3 R23 23 24 22E3 R29 29 12 100 R30 30 10 100 R31 31 12 100 R32 32 10 100 R43 43 12 40E3 R44 44 10 40E3 R45 45 46 80E3 * Q21 24 21 22 NI Q22 22 22 0 NI Q23 23 23 12 PI Q24 25 23 12 PI Q25 25 25 26 NI Q26 0 0 26 PI Q27 27 25 42 NI 8 Q28 28 0 42 PI 8 Q29 27 27 29 PIJ 6 Q30 28 28 30 NIJ 6 Q31 35 27 31 PIJ 6 Q32 36 28 32 NIJ 6 Q33 10 1 33 PIJ 2 Q34 12 1 34 NIJ 2 Q35 35 35 33 NIJ 2 Q36 36 36 34 PIJ 2 Q37 35 35 39 NIJ 6 Q38 36 36 40 PIJ 6 Q39 39 39 41 NIJ 6 Q40 40 40 41 PIJ 6 Q41 12 39 11 NIJ 10 Q42 10 40 11 PIJ 10 Q43 36 45 43 PI Q44 35 46 44 NI Q45 45 45 43 PI 5 Q46 46 46 44 NI 5 * .MODEL PI PNP .MODEL NI NPN .MODEL PIJ PNP +BF = 110 IS = 0.1567E-16 +CJC = 0.029p AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017p EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050p FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80p MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00p MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680 * .MODEL NIJ NPN +BF = 110 IS = 0.1567E-16 +CJC = 0.029p AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017p EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050p FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80p MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00p MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680 * .ENDS *$ ************************************************************************** * MPC102X1 DUAL 2X1 VIDEO MULTIPLEXER MACROMODEL * REV.A 1/10/95 KL/SB * REV.B 2/14/96 SB changed node assignments * * CONNECTIONS: IN 1 * | IN 2 * | | +Vcc * | | | IN 3 * | | | | IN 4 * | | | | | SELECT 4 * | | | | | | SELECT 3 * | | | | | | | OUT 2 * | | | | | | | | -Vcc * | | | | | | | | | OUT 1 * | | | | | | | | | | SELECT 2 * | | | | | | | | | | | SELECT 1 .SUBCKT MPC102X1/BB 1 3 4 5 7 8 9 10 11 12 13 14 * X1 1 11 12 4 14 MUX3 ; Channel 1 into Out 1 X2 3 11 12 4 13 MUX3 ; Channel 2 into Out 1 X3 5 11 10 4 9 MUX3 ; Channel 3 into Out 2 X4 7 11 10 4 8 MUX3 ; Channel 4 into Out 2 * C208 8 0 2E-12 C209 9 0 2E-12 C210 10 0 2E-12 C212 12 0 2E-12 C213 13 0 2E-12 C214 14 0 2E-12 * .ENDS * * ONE OUT OF FOUR CHANNELS OF THE MPC102X1 MODEL * INPUT * | NEGATIVE SUPPLY * | | OUTPUT * | | | POSITIVE SUPPLY * | | | | SELECT * | | | | | * | | | | | .SUBCKT MUX3 1 10 11 12 14 * V22 22 0 1.5 V27 12 27 1.5 V28 28 10 1.5 * G21 25 26 14 22 -87E-6 * C23 23 0 2.0E-12 C24 23 11 0.1E-12 C25 25 0 0.6E-12 C26 26 0 0.6E-12 * R21 14 0 40E3 R22 22 0 1E9 R23 23 0 1.3E6 R24 23 1 145 * Q22 10 10 25 NI Q21 26 26 12 NI Q23 10 23 25 PI Q24 12 23 26 NI Q25 27 25 11 NI 4 Q26 28 26 11 PI 4 * .MODEL NI NPN .MODEL PI PNP .ENDS *$ ************************************************************************** * MPC104X1 2X1 VIDEO MULTIPLEXER MACROMODEL * REV.A 1/10/95 KL/SB * REV.B 2/14/96 SB changed node assignments * * CONNECTIONS: IN1 * | +Vcc * | | IN2 * | | | SELECT2 * | | | | OUT * | | | | | -Vcc * | | | | | | SELECT 1 * | | | | | | | .SUBCKT MPC104X1/BB 1 3 4 5 6 7 8 * X1 1 7 6 3 8 MUX4 ; One out of two channels X2 4 7 6 3 5 MUX4 ; One out of two channels * C208 8 0 2E-12 C205 5 0 2E-12 C206 6 0 2E-12 * .ENDS * * ONE OUT OF TWO CHANNELS OF THE VIDEO SIGNAL MULTIPLEXER * INPUT * | NEGATIVE SUPPLY * | | OUTPUT * | | | POSITIVE SUPPLY * | | | | SELECT * | | | | | * | | | | | .SUBCKT MUX4 1 10 11 12 14 * V22 22 0 1.5 V27 12 27 1.5 V28 28 10 1.5 G21 25 26 14 22 -87E-6 C23 23 0 2.0E-12 C24 23 11 0.1E-12 C25 25 0 0.6E-12 C26 26 0 0.6E-12 R21 14 0 40E3 R22 22 0 1E9 R23 23 0 1.3E6 R24 23 1 145 Q22 10 10 25 NI Q21 26 26 12 NI Q23 10 23 25 PI Q24 12 23 26 NI Q25 27 25 11 NI 4 Q26 28 26 11 PI 4 * .MODEL NI NPN .MODEL PI PNP * .ENDS *$ ************************************************************************** * OPA1013 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/09/90 AT 15:20 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA1013/BB 1 2 3 4 5 * C1 11 12 6.062E-12 C2 6 7 21.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 1.624E9 -2E9 2E9 2E9 -2E9 GA 6 0 11 12 92.36E-6 GCM 0 6 10 99 130.5E-12 IEE 3 10 DC 8.418E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 4 11 10.83E3 RC2 4 12 10.83E3 RE1 13 10 4.659E3 RE2 14 10 4.659E3 REE 10 99 23.76E6 RO1 8 5 120 RO2 7 99 30 RP 3 4 87.82E3 VB 9 0 DC 0 VC 3 53 DC 1 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 30 VLN 0 92 DC 30 * .MODEL DX D(IS=800.0E-18) .MODEL QX PNP(IS=800.0E-18 BF=466.7) .ENDS *$ ************************************************************************** * OPA1013E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/08/90 AT 16:35 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA1013E/BB 1 2 3 4 5 * C1 11 12 6.062E-12 C2 6 7 21.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 1.624E9 -2E9 2E9 2E9 -2E9 GA 6 0 11 12 92.36E-6 GCM 0 6 10 99 130.5E-12 IEE 3 10 DC 8.418E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 4 11 10.83E3 RC2 4 12 10.83E3 RE1 13 10 4.659E3 RE2 14 10 4.659E3 REE 10 99 23.76E6 RO1 8 5 120 RO2 7 99 30 * RP 3 4 87.82E3 VB 9 0 DC 0 VC 3 53 DC 1 VE 54 4 DC 1 VLIM 7 8 DC 0 VLP 91 0 DC 30 VLN 0 92 DC 30 **************************** * OPA1013 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0.2814E-3 1 FQ2 0 4 POLY(1) VQ2 0.2814E-3 -1 * QUIESCIENT CURRENT RQ 3 4 5.0E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL QX PNP(IS=800.0E-18 BF=466.7) .ENDS *$ ************************************************************************** * OPA111 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/12/90 AT 16:35 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA111/BB 1 2 3 4 5 * C1 11 12 72.79E-12 C2 6 7 400.0E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.717E6 -5E6 5E6 5E6 -5E6 GA 6 0 11 12 5.027E-3 GCM 0 6 10 99 15.90E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 198.9 RD2 4 12 198.9 RO1 8 5 25 RO2 7 99 75 RP 3 4 12.00E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=400.0E-15 BETA=15.79E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA111E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/27/90 AT 11:56 * REV.B 3/21/92 BCB: added input bias current correction and * current and voltage noise * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA111E/BB 1 2 3 4 5 * C1 11 12 72.79E-12 C2 6 7 400.0E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.717E6 -5E6 5E6 5E6 -5E6 GA 6 0 11 12 5.027E-3 GCM 0 6 10 99 15.90E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 400E-9 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 400E-9 R2 6 9 100.0E3 RD1 4 11 198.9 RD2 4 12 198.9 RO1 8 5 25 RO2 7 99 75 * RP 3 4 12.00E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 **************************** * OPA111 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.30E-3 1 FQ2 0 4 POLY(1) VQ2 1.30E-3 -1 * QUIESCIENT CURRENT RQ 3 4 7.5E4 * DIFF INPUT CAPACITANCE CDIF 64 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 64 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT VOLTAGE NOISE VN1 61 4 0.6 VN2 4 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 4 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=3.8E-16 AF=1 KF=1.175E-16) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=400.0E-15 BETA=15.79E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA121 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/15/90 AT 14:41 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA121/BB 1 2 3 4 5 * C1 11 12 72.79E-12 C2 6 7 400.0E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E6 -3E6 3E6 3E6 -3E6 GA 6 0 11 12 5.027E-3 GCM 0 6 10 99 31.72E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 198.9 RD2 4 12 198.9 RO1 8 5 25 RO2 7 99 75 RP 3 4 12.00E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=15.79E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA121E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/27/90 AT 11:56 * REV.B 3/21/92 BCB: added input bias current correction and * current and voltage noise * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA121E/BB 1 2 3 4 5 * C1 11 12 72.79E-12 C2 6 7 400.0E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E6 -3E6 3E6 3E6 -3E6 GA 6 0 11 12 5.027E-3 GCM 0 6 10 99 31.72E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 800E-9 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 800E-9 R2 6 9 100.0E3 RD1 4 11 198.9 RD2 4 12 198.9 RO1 8 5 25 RO2 7 99 75 * RP 3 4 12.00E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 **************************** * OPA121 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.30E-3 1 FQ2 0 4 POLY(1) VQ2 1.30E-3 -1 * QUIESCIENT CURRENT RQ 3 4 7.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT VOLTAGE NOISE VN1 61 4 0.6 VN2 4 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 4 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=3.8E-16 AF=1 KF=2.089E-16) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=15.79E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA124 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED 11/8/93 BCB * REV. A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA124/BB 1 2 3 4 5 * C1 11 12 72.79E-12 C2 6 7 400.0E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.717E6 -5E6 5E6 5E6 -5E6 GA 6 0 11 12 5.027E-3 GCM 0 6 10 99 15.90E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 198.9 RD2 4 12 198.9 RO1 8 5 25 RO2 7 99 75 RP 3 4 12.00E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=400.0E-15 BETA=15.79E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA124E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED 11/8/93 BCB * REV. A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA124E/BB 1 2 3 4 5 * C1 11 12 72.79E-12 C2 6 7 400.0E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.717E6 -5E6 5E6 5E6 -5E6 GA 6 0 11 12 5.027E-3 GCM 0 6 10 99 15.90E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 400E-9 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 400E-9 R2 6 9 100E3 RD1 4 11 198.9 RD2 4 12 198.9 RO1 8 5 25 RO2 7 99 75 * RP 3 4 12.00E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 **************************** * OPA124 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.30E-3 1 FQ2 0 4 POLY(1) VQ2 1.30E-3 -1 * QUIESCIENT CURRENT RQ 3 4 7.5E4 * DIFF INPUT CAPACITANCE CDIF 64 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 64 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT VOLTAGE NOISE VN1 61 4 0.6 VN2 4 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 4 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=3.8E-16 AF=1 KF=1.175E-16) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=400.0E-15 BETA=15.79E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA128 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/15/90 AT 08:27 * REV. A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA128/BB 1 2 3 4 5 * C1 11 12 2.204E-12 C2 6 7 25.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 106.6E6 -10E6 10E6 10E6 -10E6 GA 6 0 11 12 314.2E-6 GCM 0 6 10 99 395.5E-12 ISS 3 10 DC 80.00E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 3.183E3 RD2 4 12 3.183E3 RO1 8 5 25 RO2 7 99 75 RP 3 4 33.33E3 RSS 10 99 2.500E6 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 2 VLIM 7 8 DC 0 VLP 91 0 DC 29 VLN 0 92 DC 29 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=20.00E-15 BETA=616.8E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA128E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/28/90 AT 15:02 * REV.B 3/21/92 BCB: added input bias current correction and * current and voltage noise * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA128E/BB 1 2 3 4 5 * C1 11 12 2.204E-12 C2 6 7 25.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 106.6E6 -10E6 10E6 10E6 -10E6 GA 6 0 11 12 314.2E-6 GCM 0 6 10 99 395.5E-12 ISS 3 10 DC 80.00E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 120E-9 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 120E-9 R2 6 9 100.0E3 RD1 4 11 3.183E3 RD2 4 12 3.183E3 RO1 8 5 25 RO2 7 99 75 * RP 3 4 33.33E3 RSS 10 99 2.500E6 VB 9 0 DC 0 VC 3 53 DC 2 VE 54 4 DC 2 VLIM 7 8 DC 0 VLP 91 0 DC 29 VLN 0 92 DC 29 **************************** * OPA128 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0.700E-3 1 FQ2 0 4 POLY(1) VQ2 0.700E-3 -1 * QUIESCIENT CURRENT RQ 3 4 2.5E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.0E-12 C2CM 2 99 1.0E-12 * INPUT VOLTAGE NOISE VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=1.9E-16 AF=1 KF=5.643E-16) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=20.00E-15 BETA=616.8E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA129 operational amplifier "macromodel" subcircuit * created using Parts release 5.2 on 12/15/94 at 14:58 * REV.A SB * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA129/BB 1 2 3 4 5 * c1 11 12 4.000E-12 c2 6 7 2.204E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 192.5E6 -20E6 20E6 20E6 -20E6 ga 6 0 11 12 314.2E-6 gcm 0 6 10 99 395.5E-12 iss 3 10 dc 80.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 3.183E3 rd2 4 12 3.183E3 ro1 8 5 25 ro2 7 99 75 rp 3 4 25.00E3 rss 10 99 2.500E6 vb 9 0 dc 0 vc 3 53 dc 2 ve 54 4 dc 2 vlim 7 8 dc 0 vlp 91 0 dc 22.00E-3 vln 0 92 dc 22.00E-3 * .model dx D(Is=800.0E-18) .model jx PJF(Is=20.00E-15 Beta=616.8E-6 Vto=-1) .ends *$ ************************************************************************** * OPA129E operational amplifier "macromodel" subcircuit * "E" is enhanced model * created using Parts release 5.2 on 12/15/94 at 14:58 * REV. A SB * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA129E/BB 1 2 3 4 5 * c1 11 12 4.000E-12 c2 6 7 2.204E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 192.5E6 -20E6 20E6 20E6 -20E6 ga 6 0 11 12 314.2E-6 gcm 0 6 10 99 395.5E-12 iss 3 10 dc 80.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx g11 2 4 poly(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 100E-9 g21 1 4 poly(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 100E-9 r2 6 9 100.0E3 rd1 4 11 3.183E3 rd2 4 12 3.183E3 ro1 8 5 25 ro2 7 99 75 rp 3 4 25.00E3 rss 10 99 2.500E6 vb 9 0 dc 0 vc 3 53 dc 2 ve 54 4 dc 2 vlim 7 8 dc 0 vlp 91 0 dc 22.00E-3 vln 0 92 dc 22.00E-3 ***************************** * OPA129 "E" ENHANCEMENTS ***************************** * Output Supply Mirror fq3 0 20 poly(1) vlim 0 1 dq1 20 21 dx dq2 22 20 dx vq1 21 0 0 vq2 22 0 0 fq1 3 0 poly(1) vq1 0.700E-3 1 fq2 0 4 poly(1) vq2 0.700E-3 -1 * Diff Input Capacitance cdif 1 2 1.0E-12 * Common Mode Input Capacitance c1cm 1 99 1.0E-12 c2cm 2 99 1.0E-12 * Input Voltage Noise vn1 61 0 0.6 vn2 0 62 0.6 dn1 61 63 dy dn2 63 62 dy en 64 1 63 0 1 * Input Current Noise rn1 0 65 60.3865 rn2 65 66 60.3865 rn3 66 0 120.773 rn4 0 67 60.3865 rn5 67 68 60.3865 rn6 68 0 120.773 * .model dy D(IS=1.9E-16 AF=1 KF=5.643E-16) .model dx D(Is=800.0E-18) .model jx PJF(Is=20.00E-15 Beta=616.8E-6 Vto=-1) .ends *$ ************************************************************************** * OPA130 operational amplifier "macromodel" subcircuit * created using Parts release 6.2i on 04/03/96 at 16:48 * Parts is a OrCAD product. * Rev. A SB * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA130/BB 1 2 3 4 5 * c1 11 12 4.330E-12 c2 6 7 15.00E-12 css 10 99 1.000E-30 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 2.386E9 -2E9 2E9 2E9 -2E9 ga 6 0 11 12 94.25E-6 gcm 0 6 10 99 530.1E-12 iss 3 10 dc 30.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 10.61E3 rd2 4 12 10.61E3 ro1 8 5 50 ro2 7 99 25 rp 3 4 56.25E3 rss 10 99 6.667E6 vb 9 0 dc 0 vc 3 53 dc 1.500 ve 54 4 dc 1 vlim 7 8 dc 0 vlp 91 0 dc 18 vln 0 92 dc 18 * .model dx D(Is=800.0E-18) .model jx PJF(Is=2.500E-12 Beta=296.1E-6 Vto=-1) .ends *$ ************************************************************************** * OPA131 operational amplifier "macromodel" subcircuit * created using Parts release 5.4 on 01/14/95 at 21:25 * REV. A SB * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA131/BB 1 2 3 4 5 * c1 11 12 4.197E-12 c2 6 7 18.00E-12 css 10 99 7.200E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 127.3E6 -130E6 130E6 130E6 -130E6 ga 6 0 11 12 452.4E-6 gcm 0 6 10 99 45.24E-9 iss 3 10 dc 252.0E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 2.210E3 rd2 4 12 2.210E3 ro1 8 5 50 ro2 7 99 25 rp 3 4 20.00E3 rss 10 99 793.7E3 vb 9 0 dc 0 vc 3 53 dc 2.500 ve 54 4 dc 2.500 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 * .model dx D(Is=800.0E-18) .model jx PJF(Is=2.500E-12 Beta=812.1E-6 Vto=-1) .ends OPA131/BB *$ ************************************************************************** * OPA131E "Enhanced" operational amplifier "macromodel" subcircuit * created using Parts release 5.4 on 01/14/95 at 21:25 * REV.A SB - model includes input bias current correction, * voltage and current noise. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA131E/BB 1 2 3 4 5 * c1 11 12 4.197E-12 c2 6 7 18.00E-12 css 10 99 7.200E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 127.3E6 -130E6 130E6 130E6 -130E6 ga 6 0 11 12 452.4E-6 gcm 0 6 10 99 45.24E-9 iss 3 10 dc 252.0E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 64 10 jx g11 2 4 Poly(4) (10,2) (11,2) (4,2) (66,0) 0 1e-12 1e-12 1e-12 3e-6 g12 1 4 Poly(4) (10,1) (12,1) (4,1) (68,0) 0 1e-12 1e-12 1e-12 3e-6 r2 6 9 100.0E3 rd1 4 11 2.210E3 rd2 4 12 2.210E3 ro1 8 5 50 ro2 7 99 25 * rp 3 4 20.00E3 rss 10 99 793.7E3 vb 9 0 dc 0 vc 3 53 dc 2.500 ve 54 4 dc 2.500 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 ********************************** * OPA131 "E" - Enhancements ********************************** * Output Supply Mirror FQ3 0 20 Poly(1) Vlim 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 Poly(1) VQ1 1.06E-3 1 FQ2 0 4 Poly(1) VQ2 1.06E-3 -1 * Quiescent Current RQ 3 4 160E3 * Diff Input Capacitance CDIF 1 2 1E-12 * Common Mode Input Capacitance C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * Input Voltage Noise VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * Input Current Noise RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .model dy D(Is=1.9E-16 RS=2000 AF=1 KF=2.258E-17) .model dx D(Is=800.0E-18) .model jx PJF(Is=2.500E-12 Beta=812.1E-6 Vto=-1) .ends *$ ************************************************************************** * OPA132 operational amplifier "macromodel" subcircuit * created using Parts release 6.2i on 02/23/96 at 08:48 * Parts is a OrCAD product. * REV. A SB 7/20/96 * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .SUBCKT OPA132/BB 1 2 3 4 5 * C1 11 12 3.240E-12 C2 6 7 8.000E-12 CSS 10 99 1.000E-30 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 248.0E6 -250E6 250E6 250E6 -250E6 GA 6 0 11 12 402.0E-6 GCM 0 6 10 99 4.020E-9 ISS 3 10 DC 160.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 2.490E3 RD2 4 12 2.490E3 RO1 8 5 20 RO2 7 99 20 RP 3 4 7.500E3 RSS 10 99 1.250E6 VB 9 0 DC 0 VC 3 53 DC 1.200 VE 54 4 DC .9 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.500E-15 BETA=1.010E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA134 operational amplifier "macromodel" subcircuit * This model can also be used for OPA2134 (dual op amp) * created using Parts release 6.2i on 02/23/96 at 08:48 * Parts is a OrCAD product. * REV. A SB 7/20/96 adapted from OPA132 model 9/24/96 BCT * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .SUBCKT OPA134/BB 1 2 3 4 5 * C1 11 12 3.240E-12 C2 6 7 8.000E-12 CSS 10 99 1.000E-30 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 248.0E6 -250E6 250E6 250E6 -250E6 GA 6 0 11 12 402.0E-6 GCM 0 6 10 99 4.020E-9 ISS 3 10 DC 160.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 2.490E3 RD2 4 12 2.490E3 RO1 8 5 20 RO2 7 99 20 RP 3 4 7.500E3 RSS 10 99 1.250E6 VB 9 0 DC 0 VC 3 53 DC 1.200 VE 54 4 DC .9 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.500E-15 BETA=1.010E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA177 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/15/90 AT 15:33 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA177/BB 1 2 3 4 5 * C1 11 12 40.00E-12 C2 6 7 80.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 1.326E9 -1E9 1E9 1E9 -1E9 GA 6 0 11 12 301.6E-6 GCM 0 6 10 99 30.16E-12 IEE 10 4 DC 20.00E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 3.316E3 RC2 3 12 3.316E3 RE1 13 10 729.2 RE2 14 10 729.2 REE 10 99 9.999E6 RO1 8 5 30 RO2 7 99 30 RP 3 4 15.15E3 VB 9 0 DC 0 VC 3 53 DC 1.500 VE 54 4 DC 1.500 VLIM 7 8 DC 0 VLP 91 0 DC 22 VLN 0 92 DC 22 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=10.00E3) .ENDS *$ ************************************************************************** * OPA177E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/20/90 AT 15:29 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA177E/BB INP INN 3 4 5 * C1 11 12 40.00E-12 C2 6 7 80.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 1.326E9 -1E9 1E9 1E9 -1E9 GA 6 0 11 12 301.6E-6 GCM 0 6 10 99 30.16E-12 IEE 10 4 DC 20.00E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 3.316E3 RC2 3 12 3.316E3 RE1 13 10 729.2 RE2 14 10 729.2 REE 10 99 9.999E6 RO1 8 5 30 RO2 7 99 30 * RP 3 4 15.15E3 VB 9 0 DC 0 VC 3 53 DC 1.500 VE 54 4 DC 1.500 VLIM 7 8 DC 0 VLP 91 0 DC 22 VLN 0 92 DC 22 **************************** * OPA177 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0.976E-3 1 FQ2 0 4 POLY(1) VQ2 0.976E-3 -1 * QUIESCIENT CURRENT RQ 3 4 3.0E4 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT PROTECTION R1IN INP 1 500 D1A 1 VD1 DX D1B VD1 2 DX R2IN INN 2 500 D2A 2 VD2 DX D2B VD2 1 DX * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=10.00E3) .ENDS *$ ************************************************************************** * OPA2107 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/17/90 AT 10:03 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA2107/BB 1 2 3 4 5 * C1 11 12 7.764E-12 C2 6 7 33.30E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.124E6 -2E6 2E6 2E6 -2E6 GA 6 0 11 12 941.5E-6 GCM 0 6 10 99 9.415E-9 ISS 3 10 DC 599.4E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.062E3 RD2 4 12 1.062E3 RO1 8 5 50 RO2 7 99 50 RP 3 4 13.33E3 RSS 10 99 333.7E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.000E-12 BETA=739.5E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA2107E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/17/90 AT 10:03 * REV.B 3/21/92 BCB: added input bias current correction and * current and voltage noise * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA2107E/BB 1 2 3 4 5 * C1 11 12 7.764E-12 C2 6 7 33.30E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.124E6 -2E6 2E6 2E6 -2E6 GA 6 0 11 12 941.5E-6 GCM 0 6 10 99 9.415E-9 ISS 3 10 DC 599.4E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 900E-9 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 900E-9 R2 6 9 100.0E3 RD1 4 11 1.062E3 RD2 4 12 1.062E3 RO1 8 5 50 RO2 7 99 50 * RP 3 4 13.33E3 RSS 10 99 333.7E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 **************************** * OPA2107 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.350E-3 1 FQ2 0 4 POLY(1) VQ2 1.350E-3 -1 * QUIESCIENT CURRENT RQ 3 4 1.0E5 * DIFF INPUT CAPACITANCE CDIF 1 2 2.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 2.0E-12 C2CM 2 99 2.0E-12 * INPUT VOLTAGE NOISE VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=1E-12 AF=1 KF=68.36E-15) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.000E-12 BETA=739.5E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA2111 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/15/90 AT 14:57 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA2111/BB 1 2 3 4 5 * C1 11 12 72.79E-12 C2 6 7 400.0E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.717E6 -5E6 5E6 5E6 -5E6 GA 6 0 11 12 5.027E-3 GCM 0 6 10 99 15.90E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 198.9 RD2 4 12 198.9 RO1 8 5 25 RO2 7 99 75 RP 3 4 12.00E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 4 VE 54 4 DC 4 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=15.79E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA2111E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/27/90 AT 11:56 * REV.B 3/21/92 BCB: added input bias current correction and * current and voltage noise * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA2111E/BB 1 2 3 4 5 * C1 11 12 72.79E-12 C2 6 7 400.0E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 4.717E6 -5E6 5E6 5E6 -5E6 GA 6 0 11 12 5.027E-3 GCM 0 6 10 99 15.90E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 600E-9 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 600E-9 R2 6 9 100.0E3 RD1 4 11 198.9 RD2 4 12 198.9 RO1 8 5 25 RO2 7 99 75 * RP 3 4 12.00E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 4 VE 54 4 DC 4 VLIM 7 8 DC 0 VLP 91 0 DC 40 VLN 0 92 DC 40 **************************** * OPA2111 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.30E-3 1 FQ2 0 4 POLY(1) VQ2 1.30E-3 -1 * QUIESCIENT CURRENT RQ 3 4 7.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT VOLTAGE NOISE VN1 61 4 0.6 VN2 4 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 4 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=2.25E-16 AF=1 KF=91E-18) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=15.79E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA2131 operational amplifier "macromodel" subcircuit * created using Parts release 5.4 on 01/14/95 at 21:25 * REV. A SB * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA2131/BB 1 2 3 4 5 * c1 11 12 4.197E-12 c2 6 7 18.00E-12 css 10 99 7.200E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 127.3E6 -130E6 130E6 130E6 -130E6 ga 6 0 11 12 452.4E-6 gcm 0 6 10 99 45.24E-9 iss 3 10 dc 252.0E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 2.210E3 rd2 4 12 2.210E3 ro1 8 5 50 ro2 7 99 25 rp 3 4 20.00E3 rss 10 99 793.7E3 vb 9 0 dc 0 vc 3 53 dc 2.500 ve 54 4 dc 2.500 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 * .model dx D(Is=800.0E-18) .model jx PJF(Is=2.500E-12 Beta=812.1E-6 Vto=-1) .ends *$ ************************************************************************** * OPA2131E "Enhanced" operational amplifier "macromodel" subcircuit * created using Parts release 5.4 on 01/14/95 at 21:25 * REV.A SB - model includes input bias current correction, * voltage and current noise. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA2131E/BB 1 2 3 4 5 * c1 11 12 4.197E-12 c2 6 7 18.00E-12 css 10 99 7.200E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 127.3E6 -130E6 130E6 130E6 -130E6 ga 6 0 11 12 452.4E-6 gcm 0 6 10 99 45.24E-9 iss 3 10 dc 252.0E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 64 10 jx g11 2 4 Poly(4) (10,2) (11,2) (4,2) (66,0) 0 1e-12 1e-12 1e-12 3e-6 g12 1 4 Poly(4) (10,1) (12,1) (4,1) (68,0) 0 1e-12 1e-12 1e-12 3e-6 r2 6 9 100.0E3 rd1 4 11 2.210E3 rd2 4 12 2.210E3 ro1 8 5 50 ro2 7 99 25 * rp 3 4 20.00E3 rss 10 99 793.7E3 vb 9 0 dc 0 vc 3 53 dc 2.500 ve 54 4 dc 2.500 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 ********************************** * OPA2131 "E" - Enhancements ********************************** * Output Supply Mirror FQ3 0 20 Poly(1) Vlim 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 Poly(1) VQ1 1.06E-3 1 FQ2 0 4 Poly(1) VQ2 1.06E-3 -1 * Quiescent Current RQ 3 4 160E3 * Diff Input Capacitance CDIF 1 2 1E-12 * Common Mode Input Capacitance C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * Input Voltage Noise VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * Input Current Noise RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .model dy D(Is=1.9E-16 RS=2000 AF=1 KF=2.258E-17) .model dx D(Is=800.0E-18) .model jx PJF(Is=2.500E-12 Beta=812.1E-6 Vto=-1) .ends *$ ************************************************************************** * OPA234 operational amplifier "macromodel" subcircuit * created using Parts release 6.1 on 06/20/96 at 16:06 * Parts is a OrCAD product. * REV A. BB 7/20/96 * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .SUBCKT OPA234/BB 1 2 3 4 5 * C1 11 12 6.995E-12 C2 6 7 30.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 479.3E6 -480E6 480E6 480E6 -480E6 GA 6 0 11 12 65.97E-6 GCM 0 6 10 99 1.046E-9 IEE 3 10 DC 6.100E-6 HLIM 90 0 VLIM 1E3 Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 4 11 15.16E3 RC2 4 12 15.16E3 RE1 13 10 6.429E3 RE2 14 10 6.429E3 REE 10 99 50.00E6 RO1 8 5 10 RO2 7 99 10 RP 3 4 20.49E3 VB 9 0 DC 0 VC 3 53 DC 1.3 VE 54 4 DC .65 VLIM 7 8 DC 0 VLP 91 0 DC 10 VLN 0 92 DC 10 * .MODEL DX D(IS=800.0E-18) .MODEL QX PNP(IS=800.0E-18 BF=60) .ends *$ ************************************************************************** * OPA234E operational amplifier enhanced "macromodel" subcircuit * created using Parts release 6.1 on 06/04/96 at 17:04 * Parts is a OrCAD product. * REV A. BB 7/20/96 * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .SUBCKT OPA234E/BB 1 2 3 4 5 * C1 11 12 6.995E-12 C2 6 7 30E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 479.3E6 -480E6 480E6 480E6 -480E6 GA 6 0 11 12 65.97E-6 GCM 0 6 10 99 1.046E-9 IEE 3 10 DC 6.100E-6 HLIM 90 0 VLIM 1E3 Q1 11 2 13 QX Q2 12 64 14 QX R2 6 9 100.0E3 RC1 4 11 15.16E3 RC2 4 12 15.16E3 RE1 13 10 6.429E3 RE2 14 10 6.429E3 REE 10 99 50.00E6 RO1 8 5 10 RO2 7 99 10 VB 9 0 DC 0 VC 3 53 DC 1.3 VE 54 4 DC 0.65 VLIM 7 8 DC 0 VLP 91 0 DC 10 VLN 0 92 DC 10 ********************************** * OPA234 "E" - Enhancements ********************************** * Output Supply Mirror DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 *adds quiescent plus positive output current FQ1 3 0 POLY(1) VQ1 235E-6 1 *adds quiescent plus negative output current FQ2 0 4 POLY(1) VQ2 235E-6 -1 *mirrors output current-used by FQ1 and FQ2 FQ3 0 20 POLY(1) VLIM 0 1 * delta Quiescent Current / delta Supplies * determines change in IQ with change in power supply voltages RQ 3 4 1E6 * Diff Input Capacitance CDIF 1 2 5E-12 * Common Mode Input Capacitance C1CM 1 99 6E-12 C2CM 2 99 6E-12 * Input Voltage Noise VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY *adds 1/f noise to model. Adjusted to agree w/actual en EN 64 1 63 0 0.8 RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DX D(IS=800.0E-18) *adds voltage noise .MODEL DY D(IS=1.9E-16 RS=2000 AF=1 KF=2.258E-17) .MODEL QX PNP(IS=800.0E-18 BF=60) .ENDS *$ ************************************************************************** * OPA237 operational amplifier circuit model subcircuit * Also can be used for OPA2237 (dual) and OPA4237 (quad) op amps * Rev. A 10/3/96 G.W. * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * OPA237 operational amplifier "macromodel" subcircuit * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA237/BB 1 2 3 4 5 * J2 4 14 5 QJ 15 R3 11 13 5.0K Q16 14 11 4 QN C1 13 14 15.5P R1 8 12 1.2K R2 12 9 1.2K Q6 11 10 4 QN Q5 10 10 4 QN Q3 4 2 6 QP I1 3 6 4U I2 3 7 4U I3 3 12 10U I4 3 14 20U ISUP 3 4 35U Q4 4 1 7 QP DCLMPO 14 15 Dx VCLMPO 3 15 DC 0.65 Q1 10 6 8 QP Q2 11 7 9 QP Q17 3 14 5 QN VCLMPI 3 16 DC 0.65 DCLMPI 12 16 Dx CDIF 1 2 4P C2CM 0 2 2P C1CM 0 1 2P C2 10 11 15P * * Transistor Models .model Dx D(Is=1.0E-15) .model QN NPN(Is=1.0E-15 Bf=200) .model QP PNP(Is=800.0E-18 Bf=500 RB=4K KF=.6F) .model QJ PJF(Is=6.0E-15 VTO=-1.2 LAMBDA=40M BETA=20.0U) .ENDS *$ ************************************************************************** * OPA2541 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/15/90 AT 14:22 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA2541/BB 1 2 3 4 5 * C1 11 12 10.71E-12 C2 6 7 15.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E9 -3E9 3E9 3E9 -3E9 GA 6 0 11 12 150.8E-6 GCM 0 6 10 99 337.6E-12 ISS 3 10 DC 120.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 6.631E3 RD2 4 12 6.631E3 RO1 8 5 .25 RO2 7 99 .25 RP 3 4 4.000E3 RSS 10 99 1.667E6 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 8.000E3 VLN 0 92 DC 8.000E3 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.000E-12 BETA=94.75E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA2541E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/12/90 AT 09:50 * REV.B 3/21/92 BCB: added input bias current correction * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA2541E/BB 1 2 3 4 5 * C1 11 12 10.71E-12 C2 6 7 15.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E9 -3E9 3E9 3E9 -3E9 GA 6 0 11 12 150.8E-6 GCM 0 6 10 99 337.6E-12 ISS 3 10 DC 120.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 6.631E3 RD2 4 12 6.631E3 RO1 8 5 .25 RO2 7 99 .25 * RP 3 4 4.000E3 RSS 10 99 1.667E6 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 8.000E3 VLN 0 92 DC 8.000E3 **************************** * OPA2541 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 16.68E-3 1 FQ2 0 4 POLY(1) VQ2 16.68E-3 -1 * QUIESCIENT CURRENT RQ 3 4 2.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 2.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 2.0E-12 C2CM 2 99 2.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.000E-12 BETA=94.75E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA2544 operational amplifier "macromodel" subcircuit * created using Parts release 5.4 on 10/12/95 at 07:51 * Parts is a OrCAD product. * REV.A SB * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA2544/BB 1 2 3 4 5 * c1 11 12 2.200E-12 c2 6 7 10.00E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 9.446E9 -9E9 9E9 9E9 -9E9 ga 6 0 11 12 87.96E-6 gcm 0 6 10 99 440.9E-12 iss 10 4 dc 80.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 3 11 11.37E3 rd2 3 12 11.37E3 ro1 8 5 .17 ro2 7 99 .17 rp 3 4 5.833E3 rss 10 99 2.500E6 vb 9 0 dc 0 vc 3 53 dc 4.400 ve 54 4 dc 3.800 vlim 7 8 dc 0 vlp 91 0 dc 4.000E3 vln 0 92 dc 4.000E3 * .model dx D(Is=800.0E-18) .model jx NJF(Is=7.500E-12 Beta=96.72E-6 Vto=-1) .ends *$ ************************************************************************** * OPA2604 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/11/90 AT 13:06 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA2604/BB 1 2 3 4 5 * C1 11 12 22.85E-12 C2 6 7 32.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 418.4E3 -40E3 40E3 40E3 -40E3 GA 6 0 11 12 2.011E-3 GCM 0 6 10 99 20.11E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 497.4 RD2 4 12 497.4 RO1 8 5 25 RO2 7 99 75 RP 3 4 6.294E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 50 VLN 0 92 DC 50 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=12.50E-12 BETA=2.528E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA2604E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/28/90 AT 16:46 * REV.B 3/21/92 BCB: added input bias current correction and * current and voltage noise * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA2604E/BB 1 2 3 4 5 * C1 11 12 22.85E-12 C2 6 7 32.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 418.4E3 -40E3 40E3 40E3 -40E3 GA 6 0 11 12 2.011E-3 GCM 0 6 10 99 20.11E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 6E-6 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 6E-6 R2 6 9 100.0E3 RD1 4 11 497.4 RD2 4 12 497.4 RO1 8 5 25 RO2 7 99 75 * RP 3 4 6.294E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 50 VLN 0 92 DC 50 **************************** * OPA2604 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 3.45E-3 1 FQ2 0 4 POLY(1) VQ2 3.45E-3 -1 * QUIESCIENT CURRENT RQ 3 4 6.0E4 * DIFF INPUT CAPACITANCE CDIF 1 2 8.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 5.0E-12 C2CM 2 99 5.0E-12 * INPUT VOLTAGE NOISE VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=133.62E-18 AF=1 KF=11.726E-18) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=12.50E-12 BETA=2.528E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA2604M OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "M" IS MULTIPLE POLE/ZERO TOPOLOGY * CREATED 7/8/92 BCB * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA2604M/BB 3 2 7 4 6 * * INPUT STAGE (pole=1.6MHz) J1 13 2 12 PJ J2 14 11 12 PJ G51 2 4 POLY(2) (13,2) (12,2) 0 1E-12 1E-12 G52 11 4 POLY(2) (14,11) (12,11) 0 1E-12 1E-12 R3 4 13 198.94 R4 4 14 198.94 C1 13 14 250E-12 IEE 7 12 1.8E-3 EOS 11 3 POLY(1) (33,10) 3E-3 1 R1 2 15 5E11 R2 3 15 5E11 CIN 2 3 8E-12 IOS 2 3 4E-12 * GAIN STAGE (gain=100dB, pole=200Hz) V21 7 21 3.236 D21 23 21 DX V22 22 4 3.236 D22 22 23 DX G21 7 23 POLY(1) (13,14) 2.9238E-3 5.0265E-3 G22 4 23 POLY(1) (13,14) -2.9238E-3 5.0265E-3 R27 7 23 19.89E6 R28 4 23 19.89E6 C22 7 23 40E-12 C23 4 23 40E-12 * ZERO / POLE STAGE (zero=1.6MHz, pole=10MHz) R46 41 43 1E6 R47 42 43 1E6 R45 7 41 5.25E6 R48 4 42 5.25E6 L41 7 41 83.6E-3 L42 4 42 83.6E-3 G45 7 43 23 10 1E-6 G46 4 43 23 10 1E-6 * POLE / ZERO STAGE (pole=0.4MHz, zero=1.6MHz) R81 7 83 1E6 R84 4 83 1E6 R82 81 83 0.25E6 R83 82 83 0.25E6 C84 81 7 397.9E-15 C85 82 4 397.9E-15 G81 7 83 43 10 1E-6 G82 4 83 43 10 1E-6 * COMMON-MODE REJECTION STAGE (zero at 2kHz) R31 31 33 1E6 R32 32 33 1E6 G31 7 33 15 10 1E-11 G32 4 33 15 10 1E-11 L31 31 7 79.577 L32 32 4 79.577 * OUTPUT STAGE D3 83 71 DX D4 72 83 DX D5 7 73 DX D6 7 74 DX D7 4 73 DZ D8 4 74 DZ G14 73 4 6 83 20E-3 G13 74 4 83 6 20E-3 V3 71 6 0.38686 V4 6 72 0.38686 G11 6 7 7 83 20E-3 G12 4 6 83 4 20E-3 R23 7 6 50 R24 4 6 50 * CENTER OF SUPPLIES R9 7 10 31.304E3 R10 4 10 31.304E3 * .MODEL DX D(IS=1E-15) .MODEL PJ PJF(BETA=12.63285E-3 VTO=-2 IS=50E-12) .MODEL DZ D(IS=1E-15 BV=50) .ENDS *$ ************************************************************************** * OPA2650X WIDEBAND, LOW POWER VOLTAGE FEEDBACK OP AMP MACROMODEL * CREATED 7/27/95 DY/SB * REV.A * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | .SUBCKT OPA2650X/BB 13 14 11 12 10 * * Input Stage and Current Source Q2 16 6 19 2 NPN1 4 Q1 17 7 18 2 NPN1 4 Q3 20 24 23 2 NPN1 2 R3 18 20 300 R5 19 20 300 R4 23 22 500 ISOUR 27 24 DC 370E-6 Q6 27 26 28 3 PNP1 1 Q7 24 24 25 2 NPN1 1 Q10 2 27 26 3 PNP1 1 R8 21 28 2K R9 25 22 1K R2 2 22 20 R1 3 21 20 C1 27 24 0.6E-12 * Gain Stage Q11 29 26 17 3 PNP1 1 Q15 30 32 31 2 NPN1 1 Q16 46 26 16 3 PNP1 1 Q17 47 30 32 2 NPN1 1 Q18 32 32 33 2 NPN1 1 R11 21 17 1K R13 21 16 1K R12 31 22 320 R14 33 22 320 R18 46 47 500 V1 29 30 DC 2.4 C2 32 22 0.4E-12 C4 46 22 1.2E-12 C3 47 22 0.42E-12 * Output Stage Q19 35 26 34 3 PNP1 2 Q20 35 35 44 2 NPN1 2 Q21 38 47 44 3 PNP1 2 Q22 39 46 45 2 NPN1 2 Q23 36 36 45 3 PNP1 2 Q24 36 24 37 2 NPN1 2 Q25 21 17 39 2 NPN1 2 Q26 22 31 38 3 PNP1 2 Q27 43 40 42 3 PNP1 10 Q28 3 35 42 2 NPN1 2 Q29 2 36 43 3 PNP1 2 Q30 42 40 43 2 NPN1 10 Q31 3 42 41 2 NPN1 48 Q32 2 43 41 3 PNP1 48 R17 41 5 10 R16 37 22 500 R15 21 34 1K * Package Parasitics R11P 12 65 .1 R10P 64 63 .01 R9P 10 62 .1 R8P 61 60 .01 R7P 57 58 .01 R6P 11 56 .1 R5P 58 59 .01 R4P 14 53 .1 R3P 54 55 .01 R2P 13 50 .1 R1P 51 52 .01 C3P 51 54 .05E-12 C6P 54 58 .05E-12 L7P 2 57 .7E-9 L2P 50 51 1.08E-9 L4P 53 54 1.08E-9 L6P 56 58 1.5E-9 L11P 65 64 1.08E-9 L10P 63 5 .7E-9 L9P 62 61 1.08E-9 L8P 60 3 .7E-9 L5P 59 2 .7E-9 L1P 52 6 .7E-9 C11P 61 64 .05E-12 C10P 61 2 .0425E-12 C9P 3 2 .15E-12 C8P 58 2 .0125E-12 C7P 2 2 .15E-12 C5P 54 2 .0425E-12 C4P 7 2 .15E-12 C2P 51 2 .0425E-12 L3P 55 7 .7E-9 C1P 6 2 .15E-12 C12P 5 2 .15E-12 C13P 64 2 .0425E-12 * * Models Used .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS * ****************** OPA2650 TEST CIRCUIT ****************** * *VCC 80 0 DC 5V *VEE 0 81 DC 5V *VIN 85 0 PWL ( 0N -2 1N 2 50N 2 51N -2 ) *VIN 85 0 *+ SIN( 0 .5 5.000E6 0 0 0 ) *Vin 85 0 DC 0 AC 1 *RL 82 0 100 *CL 82 0 5E-12 *CFB 83 82 .15E-12 *CFF1 83 0 0.75E-12 *RIN 85 84 25 *RFB 86 82 402 *RFF 83 0 402 *LFB 83 86 2.2E-9 *X82 83 84 81 82 80 OPA2650X/BB * *.probe ; *ipsp* *.options abstol = 1.000m reltol = .01 ; *ipsp* *.ac dec 11 10.000k 3.000g ; *ipsp* *.four 5.000meg V(82) ; *ipsp* *.tran 50.000n 4.000u 0 0 ; *ipsp* * *.ENDS *$ ************************************************************************** * OPA2658X DUAL-WIDEBAND, LOW-POWER CURRENT-FEEDBACK OP AMP *MACROMODEL * CREATED 12/30/94 DY/SB * REV. A * * NOTE: THE FOLLOWING NETLIST REFLECTS ONLY ONE OUT OF THE TWO OP AMPS OF THE * DUAL OPA2658. TO MODEL THE COMPLETE DEVICE PLEASE USE THIS MODEL TWICE. * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | .SUBCKT OPA2658X/BB 8 9 7 10 6 * * Input Stage ISOUR1 11 13 DC 0.5MA ISOUR2 14 12 DC 0.5MA Q2 14 14 4 1 PNP1 2 Q4 18 14 3 1 PNP1 2 Q1 13 13 4 2 NPN1 2 Q3 15 13 3 2 NPN1 2 R5 11 12 20K C3 13 0 0.3E-12 C4 14 0 0.1E-12 R16 1 11 10 R17 2 12 10 C1 11 12 1E-12 * Gain Stage Q7 24 15 37 1 PNP1 6 Q6 37 17 20 1 PNP1 6 Q5 15 37 16 1 PNP1 6 Q8 18 19 22 2 NPN1 3 Q9 19 23 21 2 NPN1 3 Q10 26 18 19 2 NPN1 3 R1 11 16 300 R2 11 20 300 R3 22 12 100 R4 21 12 100 R12 37 17 600 R6 19 23 200 C2 25 12 0.5E-12 * Output Stage Q21 1 33 36 2 NPN1 48 Q22 2 35 36 1 PNP1 48 Q11 12 26 28 1 PNP1 3 Q12 11 24 30 2 NPN1 3 Q20 35 34 33 1 PNP1 10 Q19 33 34 35 2 NPN1 10 Q13 29 29 28 2 NPN1 3 Q17 1 29 33 2 NPN1 2 Q14 31 31 30 1 PNP1 3 Q18 2 31 35 1 PNP1 2 Q15 29 37 27 1 PNP1 6 Q16 31 19 32 2 NPN1 3 R9 11 27 300 R10 32 12 100 R7 24 25 80 R8 25 26 80 R11 36 5 10 * Package Parasitics CINV 8 0 .75E-12 L6P 49 48 1.5E-9 L4P 46 45 1.08E-9 L2P 43 42 1.08E-9 C8P 55 2 .0425E-12 L3P 44 4 .7E-9 C1P 42 2 .0425E-12 C2P 42 45 .05E-12 C3P 45 2 .0425E-12 C4P 45 48 .05E-12 C5P 48 2 .0125E-12 C6P 52 2 .0425E-12 C7P 52 55 .05E-12 L1P 41 3 .7E-9 L5P 47 2 .7E-9 L7P 51 1 .7E-9 L8P 53 52 1.08E-9 L9P 54 5 .7E-9 L10P 56 55 1.08E-9 L11P 2 50 .7E-9 R1P 42 41 .1 R2P 8 43 .1 R3P 45 44 .1 R4P 9 46 .1 R5P 48 47 .1 R6P 7 49 .1 R11P 50 48 .025 R7P 52 51 .1 R8P 6 53 .1 R9P 55 54 .1 R10P 10 56 .1 * * MODELS USED .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS * ****************** OPA2658 TEST CIRCUIT ****************** * *X1 60 61 63 65 62 OPA2658X/BB *VCC 62 0 DC 5V *VEE 0 63 DC 5V *RFB 66 65 400 *VIN 67 0 PWL ( 0N -1 1N 1 20N 1 21N -1 ) *RL 65 0 100 *LFB 60 66 2.2E-9 *CL 65 0 5E-12 *CFB 60 65 0.15E-12 *RSOUR 67 61 50 *CFF 60 0 0.15E-12 *RFF 60 64 400 *LFF 64 0 2.2E-9 *.ENDS *$ ************************************************************************** * OPA2662 WIDE-BAND, DUAL, OPERATIONAL TRANSCONDUCTANCE AMPLIFIER * CREATED 9/6/95 SB * REV.A * * CONNECTIONS: BASE * | EMITTER * | | COLLECTOR * | | | POSITIVE VCC * | | | | NEGATIVE VCC * | | | | | POSITIVE VCCOUT * | | | | | | NEGATIVE VCCOUT * | | | | | | | IQ ADJUST * | | | | | | | | ENABLE .SUBCKT OPA2662X1/BB 2 10 11 1 8 16 9 5 EN * * Bias Circuit I1 20 21 1E-6 Q1 20 20 1 PIJ Q2 21 20 1 PIJ Q4 20 21 22 NIJ 9 Q3 21 21 8 NIJ R4 5 22 60 R5 22 8 50E3 C4 5 0 2pF *Enable Circuit Q40 20 40 1 PIJ R40 40 1 10k G1 0 40 VALUE={-20uA*((-1*V(EN,0))+5V)} Q45 21 45 8 NIJ R45 45 8 10k G2 0 45 VALUE={20uA*((-1*V(EN,0))+5V)} *Input Q73 6 6 3 NIJ Q12 20 20 1 PIJ Q7 3 3 76 NIJ Q6 4 4 76 PIJ Q5 6 20 1 PIJ 2.3 Q8 21 2 3 PIJ Q9 20 2 4 NIJ Q74 23 23 4 PIJ Q10 23 21 8 NIJ 2.3 Q11 21 21 8 NIJ CB 2 0 1pF *OTA (Collector Output) Q17 24 24 41 PIJ 4 R17 16 41 15 R18 16 32 3.5 Q18 33 24 32 PIJ 18 Q13 24 13 26 NIJ 1.5 Q14 25 14 27 PIJ 1.5 Q15 25 25 42 NIJ 4 R15 9 42 15 R16 9 31 3.5 Q16 33 25 31 NIJ 18 Q19 26 30 27 NIJ Q20 27 30 26 PIJ Q21 24 26 10 NIJ 3 Q22 25 27 10 PIJ 3 C12 24 0 10pF C16 25 0 10pF C13 13 0 3pF R13 13 6 220 C14 23 0 3pF R14 23 14 220 RC 33 34 0.05 LC 34 11 1E-9 CC 11 0 6.5pF CE 10 0 1.7pF * .MODEL NIJ NPN (BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) * .MODEL PIJ PNP (BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) * .ENDS * * OPA2662 Macromodel Test * *X1 B E C 1 8 11 18 IQ TTL OPA2662X1/BB *Vcc1+ 1 0 +5V *Vcc1- 8 0 -5V *Vcc2+ 11 0 +5V *Vcc2- 18 0 -5V *Cb1 1 0 1uF *Cb2 8 0 1uF *Cb3 11 0 2.2uF *Cb4 18 8 2.2uF *RQ IQ 8 750 *RC C 0 40 *RE E 0 100 *CE E 0 5.6pF *.NODESET V(X1.20)=4.18V V(X1.21)=-4.18V *.ENDS *$ ************************************************************************** * OPA27 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 09/20/90 AT 16:00 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA27/BB 1 2 3 4 5 * C1 11 12 20.79E-12 C2 6 7 114.3E-12 CEE 10 99 5.713E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 10.95E6 -10E6 10E6 10E6 -10E6 GA 6 0 11 12 4.638E-3 GCM 0 6 10 99 2.608E-9 IEE 10 4 DC 240.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 215.6 RC2 3 12 215.6 RE1 13 10 5.395E-3 RE2 14 10 5.395E-3 REE 10 99 833.5E3 RO1 8 5 35 RO2 7 99 35 RP 3 4 10.87E3 VB 9 0 DC 0 VC 3 53 DC 1.200 VE 54 4 DC 1.200 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=7.998E3) .ENDS *$ ************************************************************************** * OPA27E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/05/90 AT 10:27 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA27E/BB 1 2 3 4 5 * C1 11 12 20.79E-12 C2 6 7 114.3E-12 CEE 10 99 5.713E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 10.95E6 -10E6 10E6 10E6 -10E6 GA 6 0 11 12 4.638E-3 GCM 0 6 10 99 2.608E-9 IEE 10 4 DC 240.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 215.6 RC2 3 12 215.6 RE1 13 10 5.395E-3 RE2 14 10 5.395E-3 REE 10 99 833.5E3 RO1 8 5 35 RO2 7 99 35 * RP 3 4 10.87E3 VB 9 0 DC 0 VC 3 53 DC 1.200 VE 54 4 DC 1.200 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 **************************** * OPA27 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.56E-3 1 FQ2 0 4 POLY(1) VQ2 1.56E-3 -1 * QUIESCIENT CURRENT RQ 3 4 2.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 5.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 2.5E-12 C2CM 2 99 2.5E-12 * INPUT PROTECTION DIN1 1 2 DX DIN2 2 1 DX * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=7.998E3) .ENDS *$ ************************************************************************** * OPA27M OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "M" IS MULTIPLE POLE/ZERO TOPOLOGY * CREATED 7/8/92 BCB * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA27M/BB 3 2 7 4 6 * * INPUT STAGE (pole @ 2M Hz) Q1 13 2 15 N Q2 14 11 16 N R3 7 13 42.513 R4 7 14 42.513 C1 13 14 935.92E-12 R5 15 12 -9.187 R6 16 12 -9.187 IEE 12 4 1E-3 EOS 11 3 POLY(1) (33,9) 25E-6 1 R1 2 10 5E11 R2 3 10 5E11 CIN 2 3 5E-12 IOS 2 3 35E-9 * GAIN STAGE (pole @ 4 Hz) V21 7 21 1.8336 D21 23 21 DX V22 22 4 1.8336 D22 22 23 DX G21 7 23 POLY(1) (13,14) 2.721E-3 17.41E-3 G22 4 23 POLY(1) (13,14) -2.721E-3 17.41E-3 R27 7 23 75.6E6 R28 4 23 75.6E6 C22 7 23 526.3E-12 C23 4 23 526.3E-12 * ZERO / POLE STAGE (zero @ 2.91M Hz, pole @ 10.91M Hz) R46 41 43 1E6 R47 42 43 1E6 R45 7 41 2.75E6 R48 4 42 2.75E6 L41 7 41 14.589E-3 L42 4 42 14.589E-3 G45 7 43 23 9 1E-6 G46 4 43 23 9 1E-6 * ZERO / POLE STAGE (zero @ 2.91M Hz, pole @ 10.91M Hz) R59 51 53 1E6 R50 52 53 1E6 R51 7 51 2.75E6 R52 4 52 2.75E6 L51 7 51 14.589E-3 L52 4 52 14.589E-3 G57 7 53 43 9 1E-6 G58 4 53 43 9 1E-6 * ZERO / POLE STAGE (zero @ 910k Hz, pole @ 6.37M Hz) R69 61 63 1E6 R68 62 63 1E6 R61 7 61 6E6 R62 4 62 6E6 L61 7 61 25E-3 L62 4 62 25E-3 G67 7 63 53 9 1E-6 G68 4 63 53 9 1E-6 * COMMON-MODE REJECTION STAGE (zero @ 1k Hz) R31 31 33 1E6 R32 32 33 1E6 G31 7 33 10 9 1.99526E-12 G32 4 33 10 9 1.99526E-12 L31 31 7 159.1549 L32 32 4 159.1549 * OUTPUT STAGE D3 63 71 DX D4 72 63 DX D5 7 73 DX D6 7 74 DX D7 4 73 DZ D8 4 74 DZ G14 73 4 6 63 7.14286E-3 G13 74 4 63 6 7.14286E-3 V3 71 6 3.58686 V4 6 72 3.58686 G11 6 7 7 63 7.14286E-3 G12 4 6 63 4 7.14286E-3 R23 7 6 140 R24 4 6 140 * CENTER OF SUPPLIES R9 7 9 16.359E3 R10 4 9 16.359E3 * .MODEL DX D(IS=1E-15) .MODEL N NPN(BF=12.5E3) .MODEL DZ D(IS=1E-15 BV=50) .ENDS *$ ************************************************************************** * SUBCIRCUIT MACROMODEL OPA336 * PSpice ver. 6.3 * REV A. CREATED Wednesday, June 18, 1997 RH * REV B. 25 JUNE 97 NPA: COMPILED INTO OPA336.MOD * REV C. 26 JUNE 97 NPA: EDITED NODE SYNTAX AND ADDED .OPTION NOTES * * Notes concerning using macromodel to simulate OPA336: * 1) Model is actually a simplified schematic of OPA336. * 2) Model was created with PSpice ver. 6.3, level 3 device models. * 3) Operation of the circuit is assumed to be single supply * * Example: X_U1 1 2 3 0 5 OPA336/BB * * Where U is the subcircuit name and * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | * .subckt OPA336/BB 1 2 3 4 5 * * Note that node "4" may be connected to ground "0", i.e., single supply operation. * * 4) ADD .OPTION ITL=40 AND .OPTION GMIN=10p TO NET LIST IF SIMULATION DOES NOT * CONVERGE * 5) ADDING .NODESET STATEMENT (BELOW) TO NET LIST MAY HELP CONVERGENCE IS CASES * WHERE V+=5V AND V-=0V ; SINGLE SUPPLY OPERATION. ASSUMES SUBCIRCUIT IS "U1". * * .NODESET * +V(2) = 2.5 V(1) = 2.5 V(5) = 2.5 V(3) = 5.0 * +V(X_U1.20)= 3.8 V(X_U1.23)= 3.8 V(X_U1.25)= .834 V(X_U1.27)= .833 V(X_U1.29)= .834 * +V(X_U1.32)= 2.03 V(X_U1.34)= 2.03 V(X_U1.43)= 4.065 V(X_U1.44)= 2.51 V(X_U1.45)= 1.93 * +V(X_U1.47)= 1.93 V(X_U1.51)= .848 V(X_U1.53)= 4.07 V(X_U1.54)= 1.58 V(X_U1.55)= 4.02 * +V(X_U1.60)= 1.94 V(X_U1.62)= .855 V(X_U1.64)= 3.17 V(X_U1.67)= 4.98 V(X_U1.76)= 2.51 * +V(X_U1.GNDS)= 0.0 V(0)= 0.0 * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA336/BB 1 2 3 4 5 * M61 4 64 55 55 PCH W=20U L=0.8U M=1 M59 55 53 3 3 PCH W=15U L=5U M=4 M55 55 60 51 GNDS NCH W=5U L=0.8U M=1 M53 53 45 51 GNDS NCH W=5U L=0.8U M=1 M57 53 53 3 3 PCH W=15U L=5U M=2 C55 55 60 CP1P2 2P M67 55 55 67 3 PCH W=5U L=5U M=1 M74 45 51 62 GNDS NCH W=5U L=1U M=1 R67 3 67 RNW 200K R47 45 47 RPO2 2K ITAIL 3 23 DC 6U AC 0 ITAIL2 27 4 DC 1.6U AC 0 ITAIL3 51 4 DC 0.8U AC 0 I60 3 60 DC 0.4U AC 0 RGNDS GNDS 4 0.01 M24 29 1 23 3 PCH W=90U L=2U AD=2560P PD=3328U AS=2688P PS=3494U M=1 M26 29 27 4 GNDS NCH W=500U L=2U AD=1142P PD=1670U AS=1142P PS=1670U M=1 I20 20 4 DC 1U AC 0 R20 3 20 1.2MEG M20 4 20 23 3 PCH W=5U L=2U M=1 R32 32 25 1.2MEG R34 34 29 1.2MEG I34 3 34 DC 1U AC 0 I32 3 32 DC 1U AC 0 V64 3 64 DC 1.8302 V60 60 62 DC 1.0897 V62 62 4 DC .8547 M23 25 2 23 3 PCH W=90U L=2U AD=2560P PD=3328U AS=2688P PS=3494U M=1 M47 43 43 3 3 PCH W=60U L=4U M=1 M43 43 34 27 GNDS NCH W=4U L=4U M=1 M45 45 32 27 GNDS NCH W=4U L=4U M=1 M73 76 51 4 GNDS NCH W=5U L=0.8U M=20 M25 25 27 4 GNDS NCH W=500U L=2U AD=1142P PD=1670U AS=1142P PS=1670U M=1 M71 76 55 3 3 PCH W=20U L=0.8U M=20 M49 45 43 3 3 PCH W=60U L=4U M=1 RC1 44 76 RPO2 10K R76 76 5 RPO2 100 CM1 29 44 CP1P2 200P C45 47 76 CP1P2 22P RC2 54 4 RPO2 10K CM2 25 54 CP1P2 200P * * MODELS for LEVEL 3 PSpice .MODEL PCH PMOS (LEVEL=3 TOX=30E-9 CGDO=1.80e-10 CGSO=1.80e-10 CJ=7.199E-4 CJSW=3.40E-10 +AF=1.05 KF=1.0e-31 JS=4.0e-7 JSSW=3.0e-13 RSH=117 MJ=.47 MJSW=.16 VFB=-0.34 PHI=0.71 VTO=-.892 +LD=12E-9 WD=43E-9 TPG=+1 GAMMA=0.6) * .MODEL NCH NMOS (LEVEL=3 TOX=30E-9 CGDO=1.55e-10 CGSO=1.55e-10 CJ=6.300E-4 CJSW=3.83E-10 +AF=1.05 KF=2.6e-31 JS=2.0e-7 JSSW=5e-13 RSH=68 MJ=.25 MJSW=.11 VFB=-0.784 PHI=0.792 VTO=.81 +LD=34E-9 WD=17E-9 TPG=-1 GAMMA=0.6) * .MODEL RPO2 RES (R=1 TC1=6.3e-4 TC2= 1.1e-6) .MODEL RNW RES (R=1 TC1=5.5e-3 TC2=-1.3e-5) .MODEL CP1P2 CAP (C=1) .ENDS *$ ************************************************************************** * OPA37 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/16/90 AT 10:32 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA37/BB 1 2 3 4 5 * C1 11 12 21.45E-12 C2 6 7 20.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 10.64E6 -10E6 10E6 10E6 -10E6 GA 6 0 11 12 4.775E-3 GCM 0 6 10 99 2.685E-9 IEE 10 4 DC 250.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 209.4 RC2 3 12 209.4 RE1 13 10 2.501 RE2 14 10 2.501 REE 10 99 799.9E3 RO1 8 5 35 RO2 7 99 35 RP 3 4 10.91E3 VB 9 0 DC 0 VC 3 53 DC 1.200 VE 54 4 DC 1.200 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=8.333E3) .ENDS *$ ************************************************************************** * OPA37E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/02/90 AT 09:06 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA37E/BB 1 2 3 4 5 * C1 11 12 21.45E-12 C2 6 7 20.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 10.64E6 -10E6 10E6 10E6 -10E6 GA 6 0 11 12 4.775E-3 GCM 0 6 10 99 2.685E-9 IEE 10 4 DC 250.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 209.4 RC2 3 12 209.4 RE1 13 10 2.501 RE2 14 10 2.501 REE 10 99 799.9E3 RO1 8 5 35 RO2 7 99 35 * RP 3 4 10.91E3 VB 9 0 DC 0 VC 3 53 DC 1.200 VE 54 4 DC 1.200 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 **************************** * OPA37 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.55E-3 1 FQ2 0 4 POLY(1) VQ2 1.55E-3 -1 * QUIESCIENT CURRENT RQ 3 4 2.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 5.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 2.5E-12 C2CM 2 99 2.5E-12 * INPUT PROTECTION DIN1 1 2 DX DIN2 2 1 DX * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=8.333E3) .ENDS *$ ************************************************************************** * OPA404 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/11/90 AT 10:49 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA404/BB 1 2 3 4 5 * C1 11 12 6.850E-12 C2 6 7 13.70E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.213E6 -2E6 2E6 2E6 -2E6 GA 6 0 11 12 602.6E-6 GCM 0 6 10 99 6.026E-9 ISS 3 10 DC 479.5E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.660E3 RD2 4 12 1.660E3 RO1 8 5 25 RO2 7 99 75 RP 3 4 13.33E3 RSS 10 99 417.1E3 VB 9 0 DC 0 VC 3 53 DC 1.800 VE 54 4 DC 1.200 VLIM 7 8 DC 0 VLP 91 0 DC 18 VLN 0 92 DC 18 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=3.785E-4 VTO=-1) .ENDS *$ ************************************************************************** * OPA404E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/11/90 AT 10:13 * REV.B 3/21/92 BCB: added input bias current correction and * current and voltage noise * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA404E/BB 1 2 3 4 5 * C1 11 12 6.850E-12 C2 6 7 13.70E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.213E6 -2E6 2E6 2E6 -2E6 GA 6 0 11 12 602.6E-6 GCM 0 6 10 99 6.026E-9 ISS 3 10 DC 479.5E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 600E-9 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (66,0) 0 1E-12 1E-12 1E-12 600E-9 R2 6 9 100.0E3 RD1 4 11 1.660E3 RD2 4 12 1.660E3 RO1 8 5 25 RO2 7 99 75 * RP 3 4 13.33E3 RSS 10 99 417.1E3 VB 9 0 DC 0 VC 3 53 DC 1.800 VE 54 4 DC 1.200 VLIM 7 8 DC 0 VLP 91 0 DC 18 VLN 0 92 DC 18 **************************** * OPA404 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.47E-3 1 FQ2 0 4 POLY(1) VQ2 1.47E-3 -1 * QUIESCIENT CURRENT RQ 3 4 1.0E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT VOLTAGE NOISE VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=1.8E-16 AF=1 KF=34.45E-18) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=3.785E-4 VTO=-1) .ENDS *$ ************************************************************************** * OPA4131 operational amplifier "macromodel" subcircuit * created using Parts release 5.4 on 01/14/95 at 21:25 * REV. A SB * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA4131/BB 1 2 3 4 5 * c1 11 12 4.197E-12 c2 6 7 18.00E-12 css 10 99 7.200E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 127.3E6 -130E6 130E6 130E6 -130E6 ga 6 0 11 12 452.4E-6 gcm 0 6 10 99 45.24E-9 iss 3 10 dc 252.0E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 2.210E3 rd2 4 12 2.210E3 ro1 8 5 50 ro2 7 99 25 rp 3 4 20.00E3 rss 10 99 793.7E3 vb 9 0 dc 0 vc 3 53 dc 2.500 ve 54 4 dc 2.500 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 * .model dx D(Is=800.0E-18) .model jx PJF(Is=2.500E-12 Beta=812.1E-6 Vto=-1) .ends *$ ************************************************************************** * OPA4131E "Enhanced" operational amplifier "macromodel" subcircuit * created using Parts release 5.4 on 01/14/95 at 21:25 * REV.A SB - model includes input bias current correction, * voltage and current noise. * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .subckt OPA4131E/BB 1 2 3 4 5 * c1 11 12 4.197E-12 c2 6 7 18.00E-12 css 10 99 7.200E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 127.3E6 -130E6 130E6 130E6 -130E6 ga 6 0 11 12 452.4E-6 gcm 0 6 10 99 45.24E-9 iss 3 10 dc 252.0E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 64 10 jx g11 2 4 Poly(4) (10,2) (11,2) (4,2) (66,0) 0 1e-12 1e-12 1e-12 3e-6 g12 1 4 Poly(4) (10,1) (12,1) (4,1) (68,0) 0 1e-12 1e-12 1e-12 3e-6 r2 6 9 100.0E3 rd1 4 11 2.210E3 rd2 4 12 2.210E3 ro1 8 5 50 ro2 7 99 25 * rp 3 4 20.00E3 rss 10 99 793.7E3 vb 9 0 dc 0 vc 3 53 dc 2.500 ve 54 4 dc 2.500 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 ********************************** * OPA4131 "E" - Enhancements ********************************** * Output Supply Mirror FQ3 0 20 Poly(1) Vlim 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 Poly(1) VQ1 1.06E-3 1 FQ2 0 4 Poly(1) VQ2 1.06E-3 -1 * Quiescent Current RQ 3 4 160E3 * Diff Input Capacitance CDIF 1 2 1E-12 * Common Mode Input Capacitance C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * Input Voltage Noise VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * Input Current Noise RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .model dy D(Is=1.9E-16 RS=2000 AF=1 KF=2.258E-17) .model dx D(Is=800.0E-18) .model jx PJF(Is=2.500E-12 Beta=812.1E-6 Vto=-1) .ends *$ ************************************************************************** * OPA445 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/12/90 AT 11:04 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA445/BB 1 2 3 4 5 * C1 11 12 5.252E-12 C2 6 7 15.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 37.74E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 3.352E-9 ISS 3 10 DC 202.5E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 5.305E3 RD2 4 12 5.305E3 RO1 8 5 25 RO2 7 99 25 RP 3 4 21.05E3 RSS 10 99 987.7E3 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 26 VLN 0 92 DC 26 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=10.00E-12 BETA=87.73E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA445E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/04/90 AT 14:31 * REV.B 3/21/92 BCB: adding input bias current correction * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA445E/BB 1 2 3 4 5 * C1 11 12 5.252E-12 C2 6 7 15.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 37.74E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 188.5E-6 GCM 0 6 10 99 3.352E-9 ISS 3 10 DC 202.5E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 5.305E3 RD2 4 12 5.305E3 RO1 8 5 25 RO2 7 99 25 * RP 3 4 21.05E3 RSS 10 99 987.7E3 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 26 VLN 0 92 DC 26 **************************** * OPA445 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 2.795E-3 1 FQ2 0 4 POLY(1) VQ2 2.795E-3 -1 * QUIESCIENT CURRENT RQ 3 4 1.0E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=10.00E-12 BETA=87.73E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA4658X QUAD-WIDEBAND, LOW-POWER CURRENT-FEEDBACK OP AMP MACROMODEL * CREATED 12/30/94 DY/SB * REV. A * * NOTE: THIS NETLIST REFLECTS ONLY ONE OUT OF THE FOUR OP AMP SECTIONS OF THE * OPA4658. TO MODEL THE COMPLETE DEVICE PLEASE USE MULTIPLE SUBCIRCUIT CALLS * IN YOUR CIRCUIT NETLIST. * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | .SUBCKT OPA4658X/BB 8 9 7 10 6 * * Input Stage ISOUR1 11 13 DC 0.5MA ISOUR2 14 12 DC 0.5MA Q2 14 14 4 1 PNP1 2 Q4 18 14 3 1 PNP1 2 Q1 13 13 4 2 NPN1 2 Q3 15 13 3 2 NPN1 2 R5 11 12 20K C3 13 0 0.3E-12 C4 14 0 0.1E-12 R16 1 11 10 R17 2 12 10 C1 11 12 1E-12 * Gain Stage Q7 24 15 37 1 PNP1 6 Q6 37 17 20 1 PNP1 6 Q5 15 37 16 1 PNP1 6 Q8 18 19 22 2 NPN1 3 Q9 19 23 21 2 NPN1 3 Q10 26 18 19 2 NPN1 3 R1 11 16 300 R2 11 20 300 R3 22 12 100 R4 21 12 100 R12 37 17 600 R6 19 23 200 C2 25 12 0.55E-12 * Output Stage Q21 1 33 36 2 NPN1 48 Q22 2 35 36 1 PNP1 48 Q11 12 26 28 1 PNP1 3 Q12 11 24 30 2 NPN1 3 Q20 35 34 33 1 PNP1 10 Q19 33 34 35 2 NPN1 10 Q13 29 29 28 2 NPN1 3 Q17 1 29 33 2 NPN1 2 Q14 31 31 30 1 PNP1 3 Q18 2 31 35 1 PNP1 2 Q15 29 37 27 1 PNP1 6 Q16 31 19 32 2 NPN1 3 R9 11 27 300 R10 32 12 100 R7 24 25 80 R8 25 26 80 R11 36 5 10 * Package Parasitics CINV 8 0 .75E-12 L6P 49 48 1.5E-9 L4P 46 45 1.08E-9 L2P 43 42 1.08E-9 C8P 55 2 .0425E-12 L3P 44 4 .7E-9 C1P 42 2 .0425E-12 C2P 42 45 .05E-12 C3P 45 2 .0425E-12 C4P 45 48 .05E-12 C5P 48 2 .0125E-12 C6P 52 2 .0425E-12 C7P 52 55 .05E-12 L1P 41 3 .7E-9 L5P 47 2 .7E-9 L7P 51 1 .7E-9 L8P 53 52 1.08E-9 L9P 54 5 .7E-9 L10P 56 55 1.08E-9 L11P 2 50 .7E-9 R1P 42 41 .1 R2P 8 43 .1 R3P 45 44 .1 R4P 9 46 .1 R5P 48 47 .1 R6P 7 49 .1 R11P 50 48 .025 R7P 52 51 .1 R8P 6 53 .1 R9P 55 54 .1 R10P 10 56 .1 * * MODELS USED .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS * ****************** OPA4658 TEST CIRCUIT ****************** * *X1 60 61 63 65 62 OPA4658X/BB *VCC 62 0 DC 5V *VEE 0 63 DC 5V *RFB 66 65 402 *VIN 67 0 PWL ( 0N -1 1N 1 20N 1 21N -1 ) *VIN 67 0 AC 1 *RL 65 0 100 *LFB 60 66 2.2E-9 *CL 65 0 5E-12 *CFB 60 65 0.15E-12 *RSOUR 67 61 50 *CFF 60 0 0.15E-12 *RFF 60 64 402 *LFF 64 0 2.2E-9 *.PROBE *.ENDs *$ ************************************************************************** * OPA501 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/15/90 AT 10:36 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA501/BB 1 2 3 4 5 * C1 11 12 20.00E-12 C2 6 7 40.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 12.64E9 -10E9 10E9 10E9 -10E9 GA 6 0 11 12 251.3E-6 GCM 0 6 10 99 794.8E-12 ISS 3 10 DC 160.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 3.979E3 RD2 4 12 3.979E3 RO1 8 5 .25 RO2 7 99 .25 RP 3 4 26.12E3 RSS 10 99 1.250E6 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 12.00E3 VLN 0 92 DC 12.00E3 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=7.500E-9 BETA=197.4E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA501E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/11/90 AT 11:33 * REV.B 3/21/92 BCB: added input bias current correction * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA501E/BB 1 2 3 4 5 * C1 11 12 20.00E-12 C2 6 7 40.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 12.64E9 -10E9 10E9 10E9 -10E9 GA 6 0 11 12 251.3E-6 GCM 0 6 10 99 794.8E-12 ISS 3 10 DC 160.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 3.979E3 RD2 4 12 3.979E3 RO1 8 5 .25 RO2 7 99 .25 * RP 3 4 26.12E3 RSS 10 99 1.250E6 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 12.00E3 VLN 0 92 DC 12.00E3 **************************** * OPA501 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 1.987E-3 1 FQ2 0 4 POLY(1) VQ2 1.987E-3 -1 * QUIESCIENT CURRENT RQ 3 4 1.5E5 * DIFF INPUT CAPACITANCE CDIF 1 2 2.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 2.0E-12 C2CM 2 99 2.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=7.500E-9 BETA=197.4E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA502 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 07/06/92 AT 10:32 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA502/BB 1 2 3 4 5 * C1 11 12 21.45E-12 C2 6 7 12.00E-12 CSS 10 99 10.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 886.3E6 -90E6 90E6 90E6 -90E6 GA 6 0 11 12 113.1E-6 GCM 0 6 10 99 1.131E-9 ISS 3 10 DC 240.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 8.842E3 RD2 4 12 8.842E3 RO1 8 5 5 RO2 7 99 1.5 RP 3 4 4.000E3 RSS 10 99 833.3E3 VB 9 0 DC 0 VC 3 53 DC 4 VE 54 4 DC 4 VLIM 7 8 DC 0 VLP 91 0 DC 15.00E3 VLN 0 92 DC 15.00E3 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=6.000E-12 BETA=106.6E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA502E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 07/06/92 AT 10:32 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA502E/BB 1 2 3 4 5 * C1 11 12 21.45E-12 C2 6 7 12.00E-12 CSS 10 99 10.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 886.3E6 -90E6 90E6 90E6 -90E6 GA 6 0 11 12 113.1E-6 GCM 0 6 10 99 1.131E-9 ISS 3 10 DC 240.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 8.842E3 RD2 4 12 8.842E3 RO1 8 5 5 RO2 7 99 1.5 RP 3 4 4.000E3 RSS 10 99 833.3E3 VB 9 0 DC 0 VC 3 53 DC 4 VE 54 4 DC 4 VLIM 7 8 DC 0 VLP 91 0 DC 15.00E3 VLN 0 92 DC 15.00E3 **************************** * OPA512 "E" - enhancements **************************** * output supply mirror FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 19.44E-3 1 FQ2 0 4 POLY(1) VQ2 19.44E-3 -1 * quiescient current RQ 3 4 2.5E5 * diff input capacitance CDIFF 1 2 5.0E-12 * common mode input capacitance C1CM 1 99 4.0E-12 C2CM 2 99 4.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=6.000E-12 BETA=106.6E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA511 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/15/90 AT 11:36 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA511/BB 1 2 3 4 5 * C1 11 12 20.00E-12 C2 6 7 40.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 8.950E9 -9E9 9E9 9E9 -9E9 GA 6 0 11 12 251.3E-6 GCM 0 6 10 99 794.8E-12 ISS 3 10 DC 160.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 3.979E3 RD2 4 12 3.979E3 RO1 8 5 .25 RO2 7 99 .25 RP 3 4 2.800E3 RSS 10 99 1.250E6 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 5.000E3 VLN 0 92 DC 5.000E3 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=7.500E-9 BETA=197.4E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA511E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/11/90 AT 13:16 * REV.A 3/21/92 BCB: added input bias current correction * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA511E/BB 1 2 3 4 5 * C1 11 12 20.00E-12 C2 6 7 40.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 8.950E9 -9E9 9E9 9E9 -9E9 GA 6 0 11 12 251.3E-6 GCM 0 6 10 99 794.8E-12 ISS 3 10 DC 160.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 3.979E3 RD2 4 12 3.979E3 RO1 8 5 .25 RO2 7 99 .25 * RP 3 4 2.800E3 RSS 10 99 1.250E6 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 5.000E3 VLN 0 92 DC 5.000E3 **************************** * OPA511 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 19.62E-3 1 FQ2 0 4 POLY(1) VQ2 19.62E-3 -1 * QUIESCIENT CURRENT RQ 3 4 2.5E5 * DIFF INPUT CAPACITANCE CDIF 1 2 2.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 2.0E-12 C2CM 2 99 2.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=7.500E-9 BETA=197.4E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA512 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/15/90 AT 11:58 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA512/BB 1 2 3 4 5 * C1 11 12 27.47E-12 C2 6 7 20.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.516E9 -3E9 3E9 3E9 -3E9 GA 6 0 11 12 502.7E-6 GCM 0 6 10 99 5.027E-9 ISS 3 10 DC 160.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.989E3 RD2 4 12 1.989E3 RO1 8 5 .25 RO2 7 99 .25 RP 3 4 3.200E3 RSS 10 99 1.250E6 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 15.00E3 VLN 0 92 DC 15.00E3 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=6.000E-9 BETA=789.5E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA512E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/11/90 AT 12:32 * REV.B 3/21/92 BCB: added input bias current correction * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA512E/BB 1 2 3 4 5 * C1 11 12 27.47E-12 C2 6 7 20.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.516E9 -3E9 3E9 3E9 -3E9 GA 6 0 11 12 502.7E-6 GCM 0 6 10 99 5.027E-9 ISS 3 10 DC 160.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 1.989E3 RD2 4 12 1.989E3 RO1 8 5 .25 RO2 7 99 .25 * RP 3 4 3.200E3 RSS 10 99 1.250E6 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 15.00E3 VLN 0 92 DC 15.00E3 **************************** * OPA512 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 24.52E-3 1 FQ2 0 4 POLY(1) VQ2 24.52E-3 -1 * QUIESCIENT CURRENT RQ 3 4 2.5E5 * DIFF INPUT CAPACITANCE CDIF 1 2 2.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 2.0E-12 C2CM 2 99 2.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=6.000E-9 BETA=789.5E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA541 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/15/90 AT 14:05 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA541/BB 1 2 3 4 5 * C1 11 12 10.71E-12 C2 6 7 15.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E9 -3E9 3E9 3E9 -3E9 GA 6 0 11 12 150.8E-6 GCM 0 6 10 99 337.6E-12 ISS 3 10 DC 120.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 6.631E3 RD2 4 12 6.631E3 RO1 8 5 .25 RO2 7 99 .25 RP 3 4 4.000E3 RSS 10 99 1.667E6 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 14.00E3 VLN 0 92 DC 14.00E3 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.000E-12 BETA=94.75E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA541E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/12/90 AT 09:50 * REV.B 3/21/92 BCB: added input bias current correction * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA541E/BB 1 2 3 4 5 * C1 11 12 10.71E-12 C2 6 7 15.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.653E9 -3E9 3E9 3E9 -3E9 GA 6 0 11 12 150.8E-6 GCM 0 6 10 99 337.6E-12 ISS 3 10 DC 120.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 6.631E3 RD2 4 12 6.631E3 RO1 8 5 .25 RO2 7 99 .25 * RP 3 4 4.000E3 RSS 10 99 1.667E6 VB 9 0 DC 0 VC 3 53 DC 5 VE 54 4 DC 5 VLIM 7 8 DC 0 VLP 91 0 DC 14.00E3 VLN 0 92 DC 14.00E3 **************************** * OPA541 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 16.68E-3 1 FQ2 0 4 POLY(1) VQ2 16.68E-3 -1 * QUIESCIENT CURRENT RQ 3 4 2.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 2.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 2.0E-12 C2CM 2 99 2.0E-12 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=2.000E-12 BETA=94.75E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA544 operational amplifier "macromodel" subcircuit * created using Parts release 5.4 on 10/12/95 at 07:51 * Parts is a OrCAD product. * REV.A SB 7/20/96 * REV.B 6 June 97 NPA: added Note: Current Limit not modeled. * REV.C 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .SUBCKT OPA544/BB 1 2 3 4 5 * C1 11 12 2.200E-12 C2 6 7 10.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 9.446E9 -9E9 9E9 9E9 -9E9 GA 6 0 11 12 87.96E-6 GCM 0 6 10 99 440.9E-12 ISS 10 4 DC 80.00E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 3 11 11.37E3 RD2 3 12 11.37E3 RO1 8 5 .17 RO2 7 99 .17 RP 3 4 5.833E3 RSS 10 99 2.500E6 VB 9 0 DC 0 VC 3 53 DC 4.400 VE 54 4 DC 3.800 VLIM 7 8 DC 0 VLP 91 0 DC 4.000E3 VLN 0 92 DC 4.000E3 * .MODEL DX D(IS=800.0E-18) .MODEL JX NJF(IS=7.500E-12 BETA=96.72E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPA547 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * REV.A 2 June 97 GG * REV.B 6 June 97 NPA: added Note: Current Limit & E/S ARE modeled. * REV.C 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | CURRENT LIMIT ADJUST * | | | NEGATIVE POWER SUPPLY * | | | | POSITIVE POWER SUPPLY * | | | | | OUTPUT * | | | | | | ENABLE/STATUS * | | | | | | | .SUBCKT OPA547/BB 1 2 3 4 5 6 7 * Q2 18 16 14 PSUB R3 13 14 8.4K Q1 13 12 11 LAT5 R15 40 4 .4 Q9 5 34 35 NMIN 480 Q4 25 26 4 NMAX 2 HCCVSP 47 36 V475 -2000 HCCVSN 42 4 V475 -2000 GNEGDRV 5 37 31 36 -.00025 R4 13 15 8.4K GAINBLK 26 4 18 19 .00175 R8 19 4 1K R6 17 1 1K R5 2 16 1K R7 18 4 1K C2 37 36 11PF C1 26 25 31PF Q3 19 17 15 PSUB Q7 5 37 38 NMIN 24 R17 38 4 690 D6 32 31 DIODE 18 D3 27 26 DIODE 1 D5 27 37 DIODE 10 D2 23 22 DIODE 6 D1 10 12 DIODE 6 VCLMP 27 4 DC .8 VDUM 20 4 DC 0 R9 21 20 35K C3 21 32 15PF FICOMP 37 4 VDUM 1 D4 29 28 DIODE 1 R13 28 4 750 Q6 31 29 30 NMIN 2 R14 30 4 300 R18 39 38 100 DCLAMP 37 36 DIODE 1 R12 25 33 1K R0 32 34 25 V475 43 4 DC 4.75 GCLPGAIN 5 51 35 47 .00015 Q11 33 51 36 NMIN 1 C5 51 33 20PF D7 48 51 DIODE 1 VDP 48 36 DC .65 R21 3 43 31600 D8 49 41 DIODE 1 Q12 37 41 4 NMIN 1 GCLNGAIN 5 41 40 42 .00015 V1I459 49 4 DC .65 C6 41 37 20PF DZ1 31 36 ZEN VCM 5 9 DC 1.4 D9 45 46 DIODE 1 D10 45 7 DIODE 1 IBES 5 45 60UA R22 7 4 250K VBES 46 4 DC 3.6 R16 34 36 2K R1 35 36 .4 VTHES 44 4 DC 2.0 DP2 4 1 DIODE 1 DP1 1 5 DIODE 1 DP4 4 2 DIODE 1 DP3 2 5 DIODE 1 DP5 3 5 DIODE 10 DP6 4 3 DIODE 50 DP8 4 6 DIODE 1 DP7 6 5 DIODE 1 DP9 7 5 DIODE 1 DP10 4 7 DIODE 1 SVCS1 36 6 45 44 VSM SVCS2 32 31 45 44 VSM2 CS2 4 2 3PF CS1 4 1 3PF CS3 2 1 2.5PF Q5 25 22 24 LAT5 R11 5 24 300 R10 5 23 300 I2 22 29 200UA Q10 36 39 40 NMIN 480 Q8 5 33 32 NMIN 16 I1 12 4 100UA R2 9 11 1K R19 9 10 1K * * DEVICE MODELS .MODEL ZEN D(IS=6E-16 CJO=1E-15 RS=1 BV=.2) .MODEL LAT5 PNP(IS=4E-15 BF=80 VAF=80 CJE=1E-13 CJC=6E-13 TF=3.5E-8 RC=1.2E3 ) + .MODEL PSUB PNP(IS=6E-16 BF=360 VAF=140 CJE=5E-13 CJC=2.5E-13 TF=2.5E-10 + RC=1.2E3) .MODEL NMAX NPN(IS=6E-16 BF=1200 VAF=140 CJE=5E-13 CJC=2.5E-13 TF=2.5E-10 + RC=1.0E3) .MODEL NMIN NPN(IS=6E-16 BF=300 VAF=140 CJE=5E-13 CJC=2.5E-13 TF=2.5E-10 + RC=1.0E3) .MODEL DIODE D(IS=6E-16 CJO=1E-15 RS=1) .MODEL VSM2 VSWITCH(RON=1500 ROFF=1E7 VON=1.9 VOFF=2.1) .MODEL VSM VSWITCH(RON=.1 ROFF=5E5 VON=2.1 VOFF=1.9) .ENDS *$ ************************************************************************** * OPA602 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/11/90 AT 13:48 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA602/BB 1 2 3 4 5 * C1 11 12 6.850E-12 C2 6 7 13.70E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.213E6 -2E6 2E6 2E6 -2E6 GA 6 0 11 12 602.6E-6 GCM 0 6 10 99 6.026E-9 ISS 3 10 DC 479.5E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.660E3 RD2 4 12 1.660E3 RO1 8 5 25 RO2 7 99 75 RP 3 4 10.00E3 RSS 10 99 417.1E3 VB 9 0 DC 0 VC 3 53 DC 2.100 VE 54 4 DC 1.200 VLIM 7 8 DC 0 VLP 91 0 DC 50 VLN 0 92 DC 50 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=3.785E-4 VTO=-1) .ENDS *$ ************************************************************************** * OPA602E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/11/90 AT 10:13 * REV.B 3/21/92 BCB: added input bias current correction and * current and voltage noise * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA602E/BB 1 2 3 4 5 * C1 11 12 6.850E-12 C2 6 7 13.70E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 2.213E6 -2E6 2E6 2E6 -2E6 GA 6 0 11 12 602.6E-6 GCM 0 6 10 99 6.026E-9 ISS 3 10 DC 479.5E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 600E-9 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 600E-9 R2 6 9 100.0E3 RD1 4 11 1.660E3 RD2 4 12 1.660E3 RO1 8 5 25 RO2 7 99 75 * RP 3 4 10.00E3 RSS 10 99 417.1E3 VB 9 0 DC 0 VC 3 53 DC 2.100 VE 54 4 DC 1.200 VLIM 7 8 DC 0 VLP 91 0 DC 50 VLN 0 92 DC 50 **************************** * OPA602 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 2.221E-3 1 FQ2 0 4 POLY(1) VQ2 2.221E-3 -1 * QUIESCIENT CURRENT RQ 3 4 1.0E5 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT VOLTAGE NOISE VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=1.7424E-16 AF=1 KF=24.597E-18) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=3.785E-4 VTO=-1) .ENDS *$ ************************************************************************** * OPA603X CURRENT-FEEDBACK AMPLIFIER "CIRCUIT MODEL" SUBCIRCUIT * CREATED USING BLOOD,SWEAT AND TEARS ON 10/12/90 AT 09:03AM * REV.B 5/23/91 * REV.C 10/20/92 - SYNTAX ERRORS BCB * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA603X/BB 3 4 1 2 5 * R0A 3 6 100 R0B 3 7 100 R0EA 10 8 21 R0EB 11 9 21 R1A 10 12 100 R1B 11 13 100 R1EA 14 4 21 R1EB 15 4 21 R2AT 1 16 1213.22365 R2BT 2 17 1200 R3 22 23 16.25 R4A 24 5 3.25 R4B 25 5 3.25 X0A 2 6 8 2 XP4LC X0B 1 7 9 2 XN4LC X1A 16 12 14 2 XN4LC X1B 17 13 15 2 XP4LC X2A 20 16 18 2 XP4LC X2B 21 17 19 2 XN4LC C2B 17 21 0.75PF X3A 20 20 22 2 XN16HC X3B 21 21 23 2 XP16HC X4A1 1 20 24 2 XN16HC X4A2 1 20 24 2 XN16HC X4A3 1 20 24 2 XN16HC X4B1 2 21 25 2 XP16HC X4B2 2 21 25 2 XP16HC X4B3 2 21 25 2 XP16HC X6A1 18 18 26 2 XP16HC X6A2 18 18 26 2 XP16HC X6B1 19 19 27 2 XN16HC X6B2 19 19 27 2 XN16HC V6A 1 26 0 V6B 27 2 0 FB 1 28 POLY(2) V6A V6B 15UA -0.0025 -0.0025 RB 28 2 500MEG CB 28 2 350PF DB1 28 2 DCLAMP DB2 2 28 DCLAMP GC 36 37 28 2 0.01 R5A 30 32 21 R5B 31 33 21 R8A 34 36 21 R8B 35 37 21 X5A 10 36 32 2 XP4LC X5B 11 37 33 2 XN4LC X8A 1 30 34 2 XN4LC X8B 2 31 35 2 XP4LC X9A 1 1 30 2 XN4LC X9B 2 2 31 2 XP4LC IS 1 2 290UA RPS 1 2 21.6K XSCA 5 22 22 2 XN4LC XSCB 5 23 23 2 XP4LC .ENDS ******************************** .MODEL DCLAMP D ******************************** .SUBCKT XN4LC 1 2 3 SUB Q1 4 2 3 SUB N4 RCDC 1 4 250 RCAC 1 5 85 CRC 4 5 1NF CS 1 0 0.45PF * .MODEL N4 NPN IS=4.4FA BF=250 VA=100 IKF=14MA BR=0.1 +RE=1.5 RB=200 RBM=75 IRB=22MA RC=0 CJE=2.2PF VJE=0.77 MJE=0.3 +CJC=0.98PF VJC=0.64 MJC=0.425 XCJC=0.2 CCS=0 VJS=0.75 MJS=0 +FC=0.9 TF=65P XTF=20 VTF=10 ITF=300MA TR=1US EG=1.20561 XTB=6M +XTI=2.33 KF=0.16F .ENDS * .SUBCKT XN16HC 1 2 3 SUB Q1 4 2 3 SUB N16HC 1 RCDC 1 4 62.5 RCAC 1 5 20 CRC 5 4 100N CS 1 0 0.80PF * .MODEL N16HC NPN IS=16FA BF=250 VA=100 IKF=56MA BR=0.1 +RE=187.5M RB=50 RBM=9 IRB=176MA RC=0 CJE=11.2PF VJE=0.77 MJE=0.3 +CJC=2.929PF VJC=0.64 MJC=0.36 XCJC=0.2 CCS=0 VJS=0.75 MJS=0 +FC=0.8 TF=150P XTF=80 VTF=50 ITF=1.6 TR=1US EG=1.20561 XTB=6M +XTI=2.33 KF=0.16F .ENDS * .SUBCKT XP4LC 1 2 3 SUB Q1 4 2 3 SUB P4 RCDC 1 4 300 RCAC 1 5 100 CRC 4 5 1NF CS 1 0 0.54PF * .MODEL P4 PNP IS=4.4FA BF=100 VA=60 IKF=14MA BR=0.1 +RE=3 RB=100 RBM=15 IRB=1.93MA RC=0 CJE=2PF VJE=0.77 MJE=0.3 +CJC=1.6PF VJC=0.64 MJC=0.425 XCJC=0.21 CCS=0 VJS=0.75 MJS=0 +FC=0.9 TF=150P XTF=20 ITF=160MA TR=1US EG=1.205612 XTB=6M +XTI=2.33 KF=0.16F .ENDS * .SUBCKT XP16HC 1 2 3 SUB Q1 4 2 3 SUB P16HC 1 RCDC 1 4 75 RCAC 1 5 75 CRC 5 4 100N CS 1 0 0.93PF * .MODEL P16HC PNP IS=16FA BF=100 VA=60 IKF=40MA BR=0.1 +RE=0.3 RB=25 RBM=5 IRB=68MA RC=0 CJE=9.6PF VJE=0.6 MJE=0.3 +CJC=4.383PF VJC=0.64 MJC=0.3 XCJC=0.2 CCS=0 VJS=0.75 MJS=0 +FC=0.95 TF=100P XTF=25 VTF=100 ITF=500MA TR=1US EG=1.20561 XTB=6M +XTI=2.33 KF=0.16F .ENDS *$ ************************************************************************** * OPA604 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 6/10/92 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA604/BB 1 2 3 4 5 * C1 11 12 22.85E-12 C2 6 7 32.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 418.4E3 -40E3 40E3 40E3 -40E3 GA 6 0 11 12 2.011E-3 GCM 0 6 10 99 20.11E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 497.4 RD2 4 12 497.4 RO1 8 5 25 RO2 7 99 75 RP 3 4 6.294E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 50 VLN 0 92 DC 50 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=12.50E-12 BETA=2.528E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA604E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 6/10/92 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA604E/BB 1 2 3 4 5 * C1 11 12 22.85E-12 C2 6 7 32.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 418.4E3 -40E3 40E3 40E3 -40E3 GA 6 0 11 12 2.011E-3 GCM 0 6 10 99 20.11E-9 ISS 3 10 DC 800.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 6E-6 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 6E-6 R2 6 9 100.0E3 RD1 4 11 497.4 RD2 4 12 497.4 RO1 8 5 25 RO2 7 99 75 * RP 3 4 6.294E3 RSS 10 99 250.0E3 VB 9 0 DC 0 VC 3 53 DC 3 VE 54 4 DC 3 VLIM 7 8 DC 0 VLP 91 0 DC 50 VLN 0 92 DC 50 **************************** * OPA2604 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 3.45E-3 1 FQ2 0 4 POLY(1) VQ2 3.45E-3 -1 * QUIESCIENT CURRENT RQ 3 4 6.0E4 * DIFF INPUT CAPACITANCE CDIF 1 2 8.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 5.0E-12 C2CM 2 99 5.0E-12 * INPUT VOLTAGE NOISE VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=133.62E-18 AF=1 KF=11.726E-18) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=12.50E-12 BETA=2.528E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA604M OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "M" IS MULTIPLE POLE/ZERO TOPOLOGY * CREATED 7/8/92 BCB * REV.A * * ------------------------------------------------------------- * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * | | * | Neither this library nor any part may be copied without | * | the express written consent of Burr-Brown Corporation. | * | | * | The users should carefully note the following factors | * | regarding this model. | * ------------------------------------------------------------- * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA604M/BB 3 2 7 4 6 * * INPUT STAGE (pole=1.6MHz) J1 13 2 12 PJ J2 14 11 12 PJ G51 2 4 POLY(2) (13,2) (12,2) 0 1E-12 1E-12 G52 11 4 POLY(2) (14,11) (12,11) 0 1E-12 1E-12 R3 4 13 198.94 R4 4 14 198.94 C1 13 14 250E-12 IEE 7 12 1.8E-3 EOS 11 3 POLY(1) (33,10) 3E-3 1 R1 2 15 5E11 R2 3 15 5E11 CIN 2 3 8E-12 IOS 2 3 4E-12 * GAIN STAGE (gain=100dB, pole=200Hz) V21 7 21 3.236 D21 23 21 DX V22 22 4 3.236 D22 22 23 DX G21 7 23 POLY(1) (13,14) 2.9238E-3 5.0265E-3 G22 4 23 POLY(1) (13,14) -2.9238E-3 5.0265E-3 R27 7 23 19.89E6 R28 4 23 19.89E6 C22 7 23 40E-12 C23 4 23 40E-12 * ZERO / POLE STAGE (zero=1.6MHz, pole=10MHz) R46 41 43 1E6 R47 42 43 1E6 R45 7 41 5.25E6 R48 4 42 5.25E6 L41 7 41 83.6E-3 L42 4 42 83.6E-3 G45 7 43 23 10 1E-6 G46 4 43 23 10 1E-6 * POLE / ZERO STAGE (pole=0.4MHz, zero=1.6MHz) R81 7 83 1E6 R84 4 83 1E6 R82 81 83 0.25E6 R83 82 83 0.25E6 C84 81 7 397.9E-15 C85 82 4 397.9E-15 G81 7 83 43 10 1E-6 G82 4 83 43 10 1E-6 * COMMON-MODE REJECTION STAGE (zero at 2kHz) R31 31 33 1E6 R32 32 33 1E6 G31 7 33 15 10 1E-11 G32 4 33 15 10 1E-11 L31 31 7 79.577 L32 32 4 79.577 * OUTPUT STAGE D3 83 71 DX D4 72 83 DX D5 7 73 DX D6 7 74 DX D7 4 73 DZ D8 4 74 DZ G14 73 4 6 83 20E-3 G13 74 4 83 6 20E-3 V3 71 6 0.38686 V4 6 72 0.38686 G11 6 7 7 83 20E-3 G12 4 6 83 4 20E-3 R23 7 6 50 R24 4 6 50 * CENTER OF SUPPLIES R9 7 10 31.304E3 R10 4 10 31.304E3 * .MODEL DX D(IS=1E-15) .MODEL PJ PJF(BETA=12.63285E-3 VTO=-2 IS=50E-12) .MODEL DZ D(IS=1E-15 BV=50) .ENDS *$ ************************************************************************** * OPA606 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/11/90 AT 15:00 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA606/BB 1 2 3 4 5 * C1 11 12 4.195E-12 C2 6 7 10.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 35.80E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 785.4E-6 GCM 0 6 10 99 13.97E-9 ISS 3 10 DC 300.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 1.273E3 RD2 4 12 1.273E3 RO1 8 5 20 RO2 7 99 20 RP 3 4 4.615E3 RSS 10 99 666.7E3 VB 9 0 DC 0 VC 3 53 DC 2.800 VE 54 4 DC 2.800 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=3.500E-12 BETA=1.028E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA606E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/28/90 AT 11:39 * REV.B 3/21/92 BCB: added input bias current correction and * current and voltage noise * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA606E/BB 1 2 3 4 5 * C1 11 12 4.195E-12 C2 6 7 10.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 35.80E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 785.4E-6 GCM 0 6 10 99 13.97E-9 ISS 3 10 DC 300.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 1.3E-6 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 1.3E-6 R2 6 9 100.0E3 RD1 4 11 1.273E3 RD2 4 12 1.273E3 RO1 8 5 20 RO2 7 99 20 * RP 3 4 4.615E3 RSS 10 99 666.7E3 VB 9 0 DC 0 VC 3 53 DC 2.800 VE 54 4 DC 2.800 VLIM 7 8 DC 0 VLP 91 0 DC 20 VLN 0 92 DC 20 **************************** * OPA606 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 5.00E-3 1 FQ2 0 4 POLY(1) VQ2 5.00E-3 -1 * QUIESCIENT CURRENT RQ 3 4 2.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT VOLTAGE NOISE VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=1.85E-16 AF=1 KF=53.291E-18) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=3.500E-12 BETA=1.028E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA620 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/05/90 AT 16:04 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA620/BB 1 2 3 4 5 * C1 11 12 577.4E-15 C2 6 7 2.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 53.05E3 -50E3 50E3 50E3 -50E3 GA 6 0 11 12 3.770E-3 GCM 0 6 10 99 670.4E-9 IEE 10 4 DC 830.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 265.3 RC2 3 12 265.3 RE1 13 10 193.3 RE2 14 10 193.3 REE 10 99 241.0E3 RO1 8 5 5 RO2 7 99 5 RP 3 4 495.4 VB 9 0 DC 0 VC 3 53 DC 1.500 VE 54 4 DC 1.500 VLIM 7 8 DC 0 VLP 91 0 DC 150 VLN 0 92 DC 150 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=26.67) .ENDS *$ ************************************************************************** * OPA620E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/05/90 AT 14:07 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA620E/BB 1 2 3 4 5 * C1 11 12 577.4E-15 C2 6 7 2.000E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 53.05E3 -50E3 50E3 50E3 -50E3 GA 6 0 11 12 3.770E-3 GCM 0 6 10 99 670.4E-9 IEE 10 4 DC 830.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 265.3 RC2 3 12 265.3 RE1 13 10 193.3 RE2 14 10 193.3 REE 10 99 241.0E3 RO1 8 5 5 RO2 7 99 5 * RP 3 4 495.4 VB 9 0 DC 0 VC 3 53 DC 1.500 VE 54 4 DC 1.500 VLIM 7 8 DC 0 VLP 91 0 DC 150 VLN 0 92 DC 150 **************************** * OPA620 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 17.7E-3 1 FQ2 0 4 POLY(1) VQ2 17.7E-3 -1 * QUIESCIENT CURRENT RQ 3 4 4.0E3 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 0.5E-12 C2CM 2 99 0.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=26.67) .ENDS *$ ************************************************************************** * OPA620X OPERATIONAL AMPLIFIER SUBCIRCUIT * "X" IS SIMPLIFIED CIRCUIT MODEL * REV.B 3/16/90 PWT * * USERS SHOULD VERY CAREFULLY NOTE THE FOLLOWING FACTORS REGARDING THESE * MODELS: * THE MODELS ARE VALID ONLY AT AN AMBIENT TEMPERATURE OF 25 DEGREES * CENTIGRADE, AND AT SUPPLY VOLTAGES OF +/-5VDC. * * THIS SIMPLIFIED CIRCUIT USES ACTUAL TRANSISTORS INSTEAD OF * MATHEMATICAL MODELING IN ORDER TO MORE CLOSELY MODEL DEVICE * PERFORMANCE. AS SUCH, REASONABLY ACCURATE SIMULATIONS OF GAIN/PHASE, * PULSE RESPONSE, DISTORTION, AND NOISE ARE POSSIBLE. THIS CAPABILITY * CAN BE ESPECIALLY VALUABLE TO DESIGNERS OF VIDEO AND RF SYSTEMS. * * THIS SIMPLIFIED CIRCUIT IS BEING SUPPLIED TO USERS AS AN AID TO * CIRCUIT DESIGNS. WHILE IT REFLECTS REASONABLY CLOSE SIMILARITY * TO THE ACTUAL DEVICE IN TERMS OF PERFORMANCE, IT IS NOT SUGGESTED * AS A REPLACEMENT FOR BREADBOARDING. SIMULATION SHOULD BE USED AS * A FORERUNNER OR A SUPPLEMENT TO TRADITIONAL LAB TESTING. * * MODEL USERS ARE HEREBY NOTIFIED THAT THESE MODELS ARE SUPPLIED * "AS IS", WITH NO DIRECT OR IMPLIED RESPONSIBILITY ON THE PART OF * BURR-BROWN FOR THEIR OPERATION WITHIN A CUSTOMER CIRCUIT OR SYSTEM. * FURTHER, BURR-BROWN CORPORATION RESERVES THE RIGHT TO CHANGE THESE * MODELS WITHOUT PRIOR NOTICE. * * IN ALL CASES, THE CURRENT DATA SHEET INFORMATION FOR A GIVEN REAL * DEVICE IS YOUR FINAL DESIGN GUIDELINE, AND IS THE ONLY ACTUAL * PERFORMANCE GUARANTEE. * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA620X/BB 1 2 3 4 5 * C1 20 4 10PF I1 18 15 1.1MA I2 24 4 4.0MA I3 3 25 2.0MA Q1 9 1 11 4 NPN 2 Q2 10 2 12 4 NPN 2 Q3 13 15 14 4 NPN 4 Q4 15 15 16 4 NPN 1 Q5 18 18 17 3 PNP 0.5 Q6 19 18 9 3 PNP Q7 20 18 10 3 PNP Q8 20 19 21 4 NPN 2 Q9 19 21 22 4 NPN 2 Q10 21 21 23 4 NPN 2 Q11 3 20 24 4 NPN 20 Q12 4 20 25 3 PNP 20 Q13 3 25 5 4 NPN 40 Q14 4 24 5 3 PNP 40 R1 3 9 250 R2 3 10 250 R3 11 13 35 R4 12 13 35 R5 14 4 62.5 R6 16 4 250 R7 3 17 1K R8 22 4 250 R9 23 4 250 * *DEVICE MODELS COPYRIGHT 1989, AT&T. REPRINTED WITH PERMISSION. .MODEL NPN NPN RB=63.71 IRB=0 RBM=29.0 RC=16.67 RE=1.667 +IS=111E-18 EG=1.206 XTI=2 XTB=2.363 BF=234.2 +IKF=5.838E-3 NF=1.0 VAF=30.00 ISE=35.1E-16 NE=1.999 +BR=4 IKR=10E6 NR=1.0 VAR=3.00 ISC=2.34E-20 NC=1.653 +TF=32.4E-12 TR=32.4E-11 CJE=.2E-12 VJE=1.104 +MJE=0.495 CJC=0.286E-13 VJC=0.508 MJC=0.3345 XCJC=1.00 +CJS=0.505E-12 VJS=0.793 MJS=0.167 FC=0.5 AF=1 KF=15F * .MODEL PNP PNP RB=25.87 IRB=0 RBM=11.98 RC=126.32 RE=1.667 +IS=285.3E-18 EG=1.206 XTI=1.5 XTB=2.053 BF=119.3 +IKF=7.254E-3 NF=1 VAF=28.0 ISE=88E-16 NE=1.557 +BR=4 IKR=10E6 NR=1 VAR=1.4 ISC=4.01E-16 NC=1.634 +TF=48E-12 TR=65E-11 CJE=.186E-12 VJE=0.892 +MJE=0.493 CJC=.518E-13 VJC=0.611 MJC=0.335 XCJC=1.00 +CJS=1.072PF VJS=0.469 MJS=0.1875 FC=0.5 AF=1 KF=15F .ENDS *$ ************************************************************************** * OPA621 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/05/90 AT 16:10 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA621/BB 1 2 3 4 5 * C1 11 12 433.0E-15 C2 6 7 500.0E-15 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 106.1E3 -10E3 10E3 10E3 -10E3 GA 6 0 11 12 1.885E-3 GCM 0 6 10 99 335.2E-9 IEE 10 4 DC 330.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 530.5 RC2 3 12 530.5 RE1 13 10 325.5 RE2 14 10 325.5 REE 10 99 606.1E3 RO1 8 5 5 RO2 7 99 5 RP 3 4 389.3 VB 9 0 DC 0 VC 3 53 DC 1.500 VE 54 4 DC 1.500 VLIM 7 8 DC 0 VLP 91 0 DC 150 VLN 0 92 DC 150 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=10) .ENDS *$ ************************************************************************** * OPA621E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/05/90 AT 14:07 * REV.A * USERS SHOULD VERY CAREFULLY NOTE THE FOLLOWING FACTORS REGARDING THESE * MODELS: * * THE MODELS ARE VALID ONLY AT AN AMBIENT TEMPERATURE OF 25 DEGREES * CENTIGRADE, AND AT SUPPLY VOLTAGES OF +/-5VDC. * * THIS SIMPLIFIED CIRCUIT USES ACTUAL TRANSISTORS INSTEAD OF * MATHEMATICAL MODELING IN ORDER TO MORE CLOSELY MODEL DEVICE * PERFORMANCE. AS SUCH, REASONABLY ACCURATE SIMULATIONS OF GAIN/PHASE, * PULSE RESPONSE, DISTORTION, AND NOISE ARE POSSIBLE. THIS CAPABILITY * CAN BE ESPECIALLY VALUABLE TO DESIGNERS OF VIDEO AND RF SYSTEMS. * * FOR FURTHER TECHNICAL INFORMATION REFER APPLICATION NOTE AN-167 * "*** MODELS FOR OPA620 AND OPA621". * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA621E/BB 1 2 3 4 5 * C1 11 12 433.0E-15 C2 6 7 500.0E-15 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 106.1E3 -10E3 10E3 10E3 -10E3 GA 6 0 11 12 1.885E-3 GCM 0 6 10 99 335.2E-9 IEE 10 4 DC 330.0E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 530.5 RC2 3 12 530.5 RE1 13 10 325.5 RE2 14 10 325.5 REE 10 99 606.1E3 RO1 8 5 5 RO2 7 99 5 * RP 3 4 389.3 VB 9 0 DC 0 VC 3 53 DC 1.500 VE 54 4 DC 1.500 VLIM 7 8 DC 0 VLP 91 0 DC 150 VLN 0 92 DC 150 **************************** * OPA621 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 22.37E-3 1 FQ2 0 4 POLY(1) VQ2 22.37E-3 -1 * QUIESCIENT CURRENT RQ 3 4 3.0E3 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 0.5E-12 C2CM 2 99 0.5E-12 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=10) .ENDS *$ ************************************************************************** * OPA621X OPERATIONAL AMPLIFIER SUBCIRCUIT * "X" IS SIMPLIFIED CIRCUIT MODEL * REV.B 3/16/90 PWT * * USERS SHOULD VERY CAREFULLY NOTE THE FOLLOWING FACTORS REGARDING THESE * MODELS: * * THE MODELS ARE VALID ONLY AT AN AMBIENT TEMPERATURE OF 25 DEGREES * CENTIGRADE, AND AT SUPPLY VOLTAGES OF +/-5VDC. * * THIS SIMPLIFIED CIRCUIT USES ACTUAL TRANSISTORS INSTEAD OF * MATHEMATICAL MODELING IN ORDER TO MORE CLOSELY MODEL DEVICE * PERFORMANCE. AS SUCH, REASONABLY ACCURATE SIMULATIONS OF GAIN/PHASE, * PULSE RESPONSE, DISTORTION, AND NOISE ARE POSSIBLE. THIS CAPABILITY * CAN BE ESPECIALLY VALUABLE TO DESIGNERS OF VIDEO AND RF SYSTEMS. * * THIS SIMPLIFIED CIRCUIT IS BEING SUPPLIED TO USERS AS AN AID TO * CIRCUIT DESIGNS. WHILE IT REFLECTS REASONABLY CLOSE SIMILARITY * TO THE ACTUAL DEVICE IN TERMS OF PERFORMANCE, IT IS NOT SUGGESTED * AS A REPLACEMENT FOR BREADBOARDING. SIMULATION SHOULD BE USED AS * A FORERUNNER OR A SUPPLEMENT TO TRADITIONAL LAB TESTING. * * MODEL USERS ARE HEREBY NOTIFIED THAT THESE MODELS ARE SUPPLIED * "AS IS", WITH NO DIRECT OR IMPLIED RESPONSIBILITY ON THE PART OF * BURR-BROWN FOR THEIR OPERATION WITHIN A CUSTOMER CIRCUIT OR SYSTEM. * FURTHER, BURR-BROWN CORPORATION RESERVES THE RIGHT TO CHANGE THESE * MODELS WITHOUT PRIOR NOTICE. * * IN ALL CASES, THE CURRENT DATA SHEET INFORMATION FOR A GIVEN REAL * DEVICE IS YOUR FINAL DESIGN GUIDELINE, AND IS THE ONLY ACTUAL * PERFORMANCE GUARANTEE. * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA621X/BB 1 2 3 4 5 * C1 20 4 2PF I1 18 15 1.3MA I2 24 4 3.5MA I3 3 25 3.5MA Q1 9 1 11 4 NPN 2 Q2 10 2 12 4 NPN 2 Q3 13 15 14 4 NPN 4 Q4 15 15 16 4 NPN 1 Q5 18 18 17 3 PNP 0.5 Q6 19 18 9 3 PNP Q7 20 18 10 3 PNP Q8 20 19 21 4 NPN 2 Q9 19 21 22 4 NPN 2 Q10 21 21 23 4 NPN 2 Q11 3 20 24 4 NPN 20 Q12 4 20 25 3 PNP 20 Q13 3 25 5 4 NPN 40 Q14 4 24 5 3 PNP 40 R1 3 9 250 R2 3 10 250 R3 11 13 35 R4 12 13 35 R5 14 4 62.5 R6 16 4 250 R7 3 17 1K R8 22 4 250 R9 23 4 250 * *DEVICE MODELS COPYRIGHT 1989, AT&T. REPRINTED WITH PERMISSION. .MODEL NPN NPN RB=63.71 IRB=0 RBM=29.0 RC=16.67 RE=1.667 +IS=111E-18 EG=1.206 XTI=2 XTB=2.363 BF=234.2 +IKF=5.838E-3 NF=1.0 VAF=30.00 ISE=35.1E-16 NE=1.999 +BR=4 IKR=10E6 NR=1.0 VAR=3.00 ISC=2.34E-20 NC=1.653 +TF=32.4E-12 TR=32.4E-11 CJE=.2E-12 VJE=1.104 +MJE=0.495 CJC=0.286E-13 VJC=0.508 MJC=0.3345 XCJC=1.00 +CJS=0.505E-12 VJS=0.793 MJS=0.167 FC=0.5 AF=1 KF=15F * .MODEL PNP PNP RB=25.87 IRB=0 RBM=11.98 RC=126.32 RE=1.667 +IS=285.3E-18 EG=1.206 XTI=1.5 XTB=2.053 BF=119.3 +IKF=7.254E-3 NF=1 VAF=28.0 ISE=88E-16 NE=1.557 +BR=4 IKR=10E6 NR=1 VAR=1.4 ISC=4.01E-16 NC=1.634 +TF=48E-12 TR=65E-11 CJE=.186E-12 VJE=0.892 +MJE=0.493 CJC=.518E-13 VJC=0.611 MJC=0.335 XCJC=1.00 +CJS=1.072PF VJS=0.469 MJS=0.1875 FC=0.5 AF=1 KF=15F .ENDS *$ ************************************************************************** * OPA622X1 - WIDE-BANDWIDTH OPERATIONAL AMPLIFIER MACROMODEL SIMPLIFIED VERSION * CREATED 8/92 KL * REV.B 7/9/93 BCB: CLARIFICATION OF NODE SET INSTRUCTIONS * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * NOTE : FOR QUICKER CONVERSION PLACE THE NODESET * V(Xyour.X1.131)=+4.2798 AND * V(Xyour.X1.141)=-4.2808 IN THE ROOT SIMULATION FILE. * ("Xyour" IS DEVICE NAME CALLED OUT IN THE ROOT FILE.) * * CONNECTIONS: Iq ADJUST * | INVERTING INPUT * | | NON-INVERTING INPUT * | | | NEGATIVE POWER SUPPLY * | | | | NEGATIVE OUTPUT POWER SUPPLY * | | | | | BUFFER - * | | | | | | VOLTAGE OUT * | | | | | | | OTA * | | | | | | | | POSITIVE OUTPUT POWER SUPPLY * | | | | | | | | | POSITIVE POWER SUPPLY * | | | | | | | | | | BUFFER + * | | | | | | | | | | | .SUBCKT OPA622X1/BB 2 3 4 5 6 8 9 10 11 12 13 * X1 2 5 12 131 141 BC/OPA622x1 ; Biasing Circuit BC X2 4 5 10 12 13 111 121 131 141 DT/OPA622x1 ; Diamond Transistor DT X3 6 9 11 111 121 CB/OPA622x1 ; Current-Buffer CB X4 3 5 8 12 131 141 DB/OPA622x1 ; Diamond-Buffer DB * C202 2 0 2E-12 C208 8 0 2E-12 C209 9 0 2E-12 C210 10 0 2E-12 C213 13 0 2E-12 * .ENDS * *Diamond Buffer DB .SUBCKT DB/OPA622x1 3 5 8 12 131 141 * R63 63 3 40 C61 61 0 0.02E-12 C62 62 0 0.02E-12 C63 63 0 2E-12 Q61 61 131 12 12 PI/OPA622x1 Q62 62 141 5 5 NI/OPA622x1 Q63 5 63 61 12 PI/OPA622x1 Q64 12 63 62 5 NI/OPA622x1 Q65 12 61 8 5 NI/OPA622x1 6 Q66 5 62 8 12 PI/OPA622x1 6 * .ENDS * *Diamond Transistor DT .SUBCKT DT/OPA622x1 4 5 10 12 13 111 121 131 141 * R23 23 4 40 C10 10 0 2.0E-12 C21 21 0 0.02E-12 C22 22 0 0.02E-12 C23 23 0 2E-12 C27 27 0 14E-12 C28 28 0 14E-12 Q21 21 131 12 12 PI/OPA622x1 Q22 22 141 5 5 NI/OPA622x1 Q23 5 23 21 12 PI/OPA622x1 Q24 12 23 22 5 NI/OPA622x1 Q25 27 21 13 5 NI/OPA622x1 6 Q26 28 22 13 12 PI/OPA622x1 6 Q27 27 27 12 12 PIM/OPA622x1 Q28 28 28 5 5 NIM/OPA622x1 Q29 111 27 12 12 PIM/OPA622x1 Q30 121 28 5 5 NIM/OPA622x1 Q31 111 111 33 5 NI/OPA622x1 Q32 121 121 34 12 PI/OPA622x1 Q33 33 33 10 5 NI/OPA622x1 Q34 34 34 10 12 PI/OPA622x1 * .ENDS * *Current Buffer CB .SUBCKT CB/OPA622x1 6 9 11 111 121 * Q35 11 111 37 6 NI/OPA622x1 Q36 6 121 38 11 PI/OPA622x1 Q37 37 37 39 6 NI/OPA622x1 Q38 38 38 39 11 PI/OPA622x1 Q39 11 37 9 6 NI/OPA622x1 2.2 Q40 6 38 9 11 PI/OPA622x1 2.2 * .ENDS * *Biasing Circuit BC .SUBCKT BC/OPA622x1 2 5 12 131 141 * R122 122 5 100k R123 122 2 200 Q121 131 131 12 12 PI/OPA622x1 Q122 131 141 122 5 NI/OPA622x1 10 Q123 141 131 12 12 PI/OPA622x1 Q124 141 141 5 5 NI/OPA622x1 * .ENDS * .MODEL NI/OPA622x1 NPN .MODEL PI/OPA622x1 PNP .MODEL NIM/OPA622x1 NPN (VAF=18) .MODEL PIM/OPA622x1 PNP (VAF=18) *$ ************************************************************************** * OPA622X2 WIDE-BANDWIDTH OPERATIONAL AMPLIFIER MACROMODEL COMPLEX VERSION * CREATED 8/92 BY KL * REV.B 7/9/93 BCB: CLARIFICATION OF NODE SET INSTRUCTIONS * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * NOTE : FOR QUICKER CONVERSIONS PLACE THE NODESET * V(Xyour.X1.121)=+4.2833 AND * V(Xyour.X1.124)=-4.2838 INTO THE ROOT SIMULATION FILE. * ("Xyour" IS THE DEVICE NAME CALLED OUT IN THE ROOT FILE.) * * CONNECTIONS : Iq ADJUST * | INVERTING INPUT * | | NON-INVERTING INPUT * | | | NEGATIVE POWER SUPPLY * | | | | NEGATIVE OUTPUT POWER SUPPLY * | | | | | BUFFER - * | | | | | | VOLTAGE OUT * | | | | | | | OTA * | | | | | | | | POSITIVE OUTPUT POWER SUPPLY * | | | | | | | | | POSITIVE POWER SUPPLY * | | | | | | | | | | BUFFER + * | | | | | | | | | | | .SUBCKT OPA622X2/BB 2 3 4 5 6 8 9 10 11 12 13 * X1 2 5 12 131 141 BC/OPA622x2 ; Biasing Circuit BC X2 4 5 10 12 13 111 125 131 141 DT/OPA622x2 ; Diamond Transistor DT X3 6 9 11 111 125 CB/OPA622x2 ; Current-Buffer CB X4 3 5 8 12 131 141 DB/OPA622x2 ; Diamond-Buffer DB * C202 2 0 2E-12 C203 3 0 2E-12 C204 4 0 2E-12 C208 8 0 2E-12 C209 9 0 2E-12 C210 10 0 2E-12 C213 13 0 2E-12 * .ENDS * *Diamond Buffer DB .SUBCKT DB/OPA622x2 3 5 8 12 131 141 * Q61 64 131 12 12 PI/OPA622x2 Q62 63 141 5 5 NI/OPA622x2 Q63 63 63 12 12 PIJ/OPA622x2 10 Q64 64 64 5 5 NIJ/OPA622x2 10 Q65 69 63 12 12 PIJ/OPA622x2 10 Q66 70 64 5 5 NIJ/OPA622x2 10 Q67 64 3 69 12 PIJ/OPA622x2 Q68 63 3 70 5 NIJ/OPA622x2 Q69 69 69 68 5 NIJ/OPA622x2 Q70 70 70 68 12 PIJ/OPA622x2 Q71 73 69 8 5 NIJ/OPA622x2 6 Q72 74 70 8 12 PIJ/OPA622x2 6 Q73 73 73 12 12 PIJ/OPA622x2 4 Q74 74 74 5 5 NIJ/OPA622x2 4 * .ENDS * *Diamond Transistor DT .SUBCKT DT/OPA622x2 4 5 10 12 13 111 125 131 141 * Q21 24 131 12 12 PI/OPA622x2 Q22 23 141 5 5 NI/OPA622x2 Q23 23 23 12 12 PIJ/OPA622x2 10 Q24 24 24 5 5 NIJ/OPA622x2 10 Q25 29 23 12 12 PIJ/OPA622x2 10 Q26 30 24 5 5 NIJ/OPA622x2 10 Q27 24 4 29 12 PIJ/OPA622x2 Q28 23 4 30 5 NIJ/OPA622x2 Q29 29 29 28 5 NIJ/OPA622x2 Q30 30 30 28 12 PIJ/OPA622x2 Q31 33 29 13 5 NIJ/OPA622x2 6 Q32 34 30 13 12 PIJ/OPA622x2 6 Q33 33 33 12 12 PIJ/OPA622x2 8 Q34 34 34 5 5 NIJ/OPA622x2 8 Q35 111 33 12 12 PIJ/OPA622x2 8 Q36 125 34 5 5 NIJ/OPA622x2 8 Q37 111 37 10 5 NIJ/OPA622x2 5 Q38 10 38 125 5 NIJ/OPA622x2 5 Q39 10 37 111 12 PIJ/OPA622x2 5 Q40 125 38 10 12 PIJ/OPA622x2 5 * .ENDS * *Current Buffer CB .SUBCKT CB/OPA622x2 6 9 11 111 125 * Q43 11 111 45 6 NIJ/OPA622x2 4 Q44 6 125 46 11 PIJ/OPA622x2 4 Q45 45 45 47 6 NIJ/OPA622x2 12 Q46 46 46 47 11 PIJ/OPA622x2 12 Q47 11 45 9 6 NIJ/OPA622x2 48 Q48 6 46 9 11 PIJ/OPA622x2 48 * .ENDS * *Biasing Circuit BC .SUBCKT BC/OPA622x2 2 5 12 131 141 * E13 131 0 121 0 1 E14 141 0 124 0 1 I121 121 124 0.1E-6 R122 122 5 100E3 R123 122 2 200 C121 121 12 10E-12 C124 124 5 10E-12 Q121 121 121 12 12 PI/OPA622x2 Q122 121 124 122 5 NI/OPA622x2 6 Q123 124 121 12 12 PI/OPA622x2 Q124 124 124 5 5 NI/OPA622x2 Q125 5 131 12 12 PI/OPA622x2 11 * .ENDS * .MODEL NIJ/OPA622x2 NPN (BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) * .MODEL PIJ/OPA622x2 PNP (BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) * .MODEL NI/OPA622x2 NPN .MODEL PI/OPA622x2 PNP *$ ************************************************************************** * OPA623X1 WIDE BANDWIDTH, CURRENT FEEDBACK, SIMPLIFIED VERSION MACROMODEL * CREATED 8/92 KL * REV.B 7/9/93 BCB: CLARIFICATION OF NODE SET INSTRUCTIONS * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * NOTE : FOR QUICKER CONVERGENCE ADD THE NODESET * V(Xyour.X1.131)=+4.2885 AND * V(Xyour.X1.141)=-4.2893 IN THE ROOT SIMULATION FILE. * ("Xyour" IS THE DEVICE NAME CALLED OUT IN THE ROOT FILE.) * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | .SUBCKT OPA623X1/BB 2 3 4 6 7 * X1 4 7 131 141 BC/OPA623X1 ; Biasing Circuit BC X2 2 3 4 7 111 121 131 141 DT/OPA623X1 ; Diamond Transistor DT X3 4 6 7 111 121 CB/OPA623X1 ; Current-Buffer CB * C202 2 0 2E-12 C206 6 0 2E-12 * .ENDS * *Diamond Transistor DT .SUBCKT DT/OPA623X1 2 3 4 7 111 121 131 141 * R23 23 3 40 C21 21 0 0.02E-12 C22 22 0 0.02E-12 C23 23 0 2E-12 C27 27 0 14E-12 C28 28 0 14E-12 C35 35 0 3.1E-12 Q21 21 131 7 7 PI/OPA623X1 Q22 22 141 4 4 NI/OPA623X1 Q23 4 23 21 7 PI/OPA623X1 Q24 7 23 22 4 NI/OPA623X1 Q25 27 21 2 4 NI/OPA623X1 6 Q26 28 22 2 7 PI/OPA623X1 6 Q27 27 27 7 7 PIM/OPA623X1 Q28 28 28 4 4 NIM/OPA623X1 Q29 111 27 7 7 PIM/OPA623X1 Q30 121 28 4 4 NIM/OPA623X1 Q31 111 111 33 4 NI/OPA623X1 Q32 121 121 34 7 PI/OPA623X1 Q33 33 33 35 4 NI/OPA623X1 Q34 34 34 35 7 PI/OPA623X1 * .ENDS * *Current Buffer CB .SUBCKT CB/OPA623X1 4 6 7 111 121 * Q35 7 111 37 4 NI/OPA623X1 Q36 4 121 38 7 PI/OPA623X1 Q37 37 37 39 4 NI/OPA623X1 Q38 38 38 39 7 PI/OPA623X1 Q39 7 37 6 4 NI/OPA623X1 2.2 Q40 4 38 6 7 PI/OPA623X1 2.2 * .ENDS * *Biasing Circuit BC .SUBCKT BC/OPA623X1 4 7 131 141 * RQC 122 4 630 ; 745 Q121 131 131 7 7 PI/OPA623X1 Q122 131 141 122 4 NI/OPA623X1 10 Q123 141 131 7 7 PI/OPA623X1 Q124 141 141 4 4 NI/OPA623X1 * .ENDS * .MODEL NI/OPA623X1 NPN .MODEL PI/OPA623X1 PNP .MODEL PIM/OPA623X1 PNP (VAF=18) .MODEL NIM/OPA623X1 NPN (VAF=18) *$ ************************************************************************** * OPA623X2 WIDE BANDWIDTH, CURRENT FEEDBACK, MACROMODEL, COMPLEX VERSION * CREATED 8/92 KL * REV.B 7/9/93 BCB: CLARIFICATION OF NODE SET INSTRUCTIONS * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * NOTE : FOR QUICKER CONVERSIONS INCLUDE THE NODESET * V(Xyour.X1.121)=+4.2990 AND * V(Xyour.X1.124)=-4.2995 IN THE ROOT SIMULATION FILE. * ("Xyour" IS THE DEVICE NAME USED IN THE ROOT FILE.) * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | VOLTAGE OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | .SUBCKT OPA623X2/BB 2 3 4 6 7 * X1 4 7 131 141 BC/OPA623X2 ; Biasing Circuit BC X2 2 3 4 7 111 123 131 141 DT/OPA623X2 ; Diamond Transistor DT X3 4 6 7 111 123 CB/OPA623X2 ; Current-Buffer CB * C202 2 0 2E-12 C203 3 0 2E-12 C206 6 0 2E-12 * .ENDS * *Diamond Transistor DT .SUBCKT DT/OPA623X2 2 3 4 7 111 123 131 141 * C39 39 0 0.6E-12 Q21 24 131 7 7 PI/OPA623X2 Q22 23 141 4 4 NI/OPA623X2 Q23 23 23 7 7 PIJ/OPA623X2 10 Q24 24 24 4 4 NIJ/OPA623X2 10 Q25 29 23 7 7 PIJ/OPA623X2 10 Q26 30 24 4 4 NIJ/OPA623X2 10 Q27 24 3 29 7 PIJ/OPA623X2 Q28 23 3 30 4 NIJ/OPA623X2 Q29 29 29 28 4 NIJ/OPA623X2 Q30 30 30 28 7 PIJ/OPA623X2 Q31 33 29 2 4 NIJ/OPA623X2 6 Q32 34 30 2 7 PIJ/OPA623X2 6 Q33 33 33 7 7 PIJ/OPA623X2 10 Q34 34 34 4 4 NIJ/OPA623X2 10 Q35 111 33 7 7 PIJ/OPA623X2 10 Q36 123 34 4 4 NIJ/OPA623X2 10 Q37 111 37 39 4 NIJ/OPA623X2 5 Q38 39 38 123 4 NIJ/OPA623X2 5 Q39 39 37 111 7 PIJ/OPA623X2 5 Q40 123 38 39 7 PIJ/OPA623X2 5 * .ENDS * *Current Buffer CB .SUBCKT CB/OPA623X2 4 6 7 111 123 * Q43 7 111 45 4 NIJ/OPA623X2 4 Q44 4 123 46 7 PIJ/OPA623X2 4 Q45 45 45 47 4 NIJ/OPA623X2 12 Q46 46 46 47 7 PIJ/OPA623X2 12 Q47 7 45 6 4 NIJ/OPA623X2 48 Q48 4 46 6 7 PIJ/OPA623X2 48 * .ENDS * *Biasing Circuit BC .SUBCKT BC/OPA623X2 4 7 131 141 * E13 131 0 121 0 1 E14 141 0 124 0 1 * I121 121 124 0.1E-6 RQC 122 4 745 C121 121 7 10E-12 C124 124 4 10E-12 Q121 121 121 7 7 PI/OPA623X2 Q122 121 124 122 4 NI/OPA623X2 6 Q123 124 121 7 7 PI/OPA623X2 Q124 124 124 4 4 NI/OPA623X2 Q125 4 131 7 7 PI/OPA623X2 11 * .ENDS * .MODEL PI/OPA623X2 PNP .MODEL NI/OPA623X2 NPN .MODEL PIJ/OPA623X2 PNP (BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) * .MODEL NIJ/OPA623X2 NPN (BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) *$ ************************************************************************** * OPA627 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/12/90 AT 07:59 * REV.B 5/22/91 TK * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA627/BB 1 2 3 4 5 * C1 11 12 3.182E-12 C2 6 7 23.00E-12 CSS 10 99 40.45E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 419.4E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 2.432E-3 GCM 0 6 10 99 3.779E-9 ISS 3 10 DC 1.840E-3 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 419.4 RD2 4 12 419.4 RO1 8 5 54 RO2 7 99 1 RP 3 4 4.286E3 RSS 10 99 108.7E3 VB 9 0 DC 0 VC 3 53 DC 2.700 VE 54 4 DC 2.700 VLIM 7 8 DC 0 VLP 91 0 DC 55 VLN 0 92 DC 55 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=1.545E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA627E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/04/90 AT 09:30 * REV.B 5/22/91 TK * REV.C 3/21/92 BCB:added input bias current correction and * current and voltage noise * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA627E/BB 1 2 3 4 5 * C1 11 12 3.182E-12 C2 6 7 23.00E-12 CSS 10 99 40.45E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 419.4E6 -40E6 40E6 40E6 -40E6 GA 6 0 11 12 2.432E-3 GCM 0 6 10 99 3.779E-9 ISS 3 10 DC 1.840E-3 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 1.6E-6 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 1.6E-6 R2 6 9 100.0E3 RD1 4 11 419.4 RD2 4 12 419.4 RO1 8 5 54 RO2 7 99 1 * RP 3 4 4.286E3 RSS 10 99 108.7E3 VB 9 0 DC 0 VC 3 53 DC 2.700 VE 54 4 DC 2.700 VLIM 7 8 DC 0 VLP 91 0 DC 55 VLN 0 92 DC 55 **************************** * OPA627 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 4.76E-3 1 FQ2 0 4 POLY(1) VQ2 4.76E-3 -1 * QUIESCIENT CURRENT RQ 3 4 7.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 8.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 7.0E-12 C2CM 2 99 7.0E-12 * INPUT VOLTAGE NOISE VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=1E-12 AF=1 KF=71.89E-15) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=1.545E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA628M OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "M" IS MULTIPLE POLE/ZERO TOPOLOGY * CREATED 7/16/93 BCB * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA628M/BB 3 2 7 4 6 * * INPUT STAGE (pole @ 220M Hz) Q1 13 2 15 N Q2 14 11 16 N R3 7 13 47.75 R4 7 14 47.75 C1 13 14 6E-12 R5 15 12 42.55 R6 16 12 42.55 IEE 12 4 5.5E-3 EOS 11 3 POLY(1) (33,9) 500E-6 1 R1 2 10 16E3 R2 3 10 16E3 CIN 2 3 2E-12 IOS 2 3 0.3E-6 * GAIN STAGE (pole @ 2K Hz) V21 7 21 2.736 D21 23 21 DX V22 22 4 2.736 D22 22 23 DX G21 7 23 POLY(1) (13,14) 26.706E-3 20.94E-3 G22 4 23 POLY(1) (13,14) -26.706E-3 20.94E-3 R27 7 23 4.77E6 R28 4 23 4.77E6 C22 7 23 16.68E-12 C23 4 23 16.68E-12 * COMMON-MODE REJECTION STAGE (zero @ 300K Hz) R31 31 33 1E6 R32 32 33 1E6 G31 7 33 10 9 3.1623E-12 G32 4 33 10 9 3.1623E-12 L31 31 7 530.5E-3 L32 32 4 530.5E-3 * OUTPUT STAGE D3 23 71 DX D4 72 23 DX D5 7 73 DX D6 7 74 DX D7 4 73 DZ D8 4 74 DZ G14 73 4 6 23 1000 G13 74 4 23 6 1000 V3 71 6 -.9125 V4 6 72 -.9125 G11 6 7 7 23 1000 G12 4 6 23 4 1000 R23 7 6 0.001 R24 4 6 0.001 * CENTER OF SUPPLIES R9 7 9 16.359E3 R10 4 9 16.359E3 * .MODEL DX D(IS=1E-15) .MODEL N NPN(BF=183) .MODEL DZ D(IS=1E-15 BV=50) .ENDS *$ ************************************************************************** * OPA637 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/04/90 AT 11:11 * REV.B 5/22/91 TK * REV.C 1/8/93 Changed nodes on J2 BCB * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA637/BB 1 2 3 4 5 * C1 11 12 8.221E-12 C2 6 7 3.600E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 552.6E6 -20E6 20E6 20E6 -20E6 GA 6 0 11 12 1.810E-3 GCM 0 6 10 99 2.868E-9 ISS 3 10 DC 486.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 552.6 RD2 4 12 552.6 RO1 8 5 54 RO2 7 99 1 RP 3 4 4.286E3 RSS 10 99 411.5E3 VB 9 0 DC 0 VC 3 53 DC 2.700 VE 54 4 DC 2.700 VLIM 7 8 DC 0 VLP 91 0 DC 55 VLN 0 92 DC 55 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=3.37E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA637E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 10/04/90 AT 11:11 * REV.B 5/22/91 TK * REV.C 3/21/92 BCB added input bias current correction and * current and voltage noise * REV.D 2/05/93 BCB Changed parameters of FB * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA637E/BB 1 2 3 4 5 * C1 11 12 8.221E-12 C2 6 7 3.600E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 552.6E6 -60E6 60E6 60E6 -60E6 GA 6 0 11 12 1.810E-3 GCM 0 6 10 99 2.868E-9 ISS 3 10 DC 486.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 64 10 JX G11 2 4 POLY(4) (10,2) (11,2) (4,2) (66,0) 0 1E-12 1E-12 1E-12 1.6E-6 G21 1 4 POLY(4) (10,1) (12,1) (4,1) (68,0) 0 1E-12 1E-12 1E-12 1.6E-6 R2 6 9 100.0E3 RD1 4 11 552.6 RD2 4 12 552.6 RO1 8 5 54 RO2 7 99 1 * RP 3 4 4.286E3 RSS 10 99 411.5E3 VB 9 0 DC 0 VC 3 53 DC 2.700 VE 54 4 DC 2.700 VLIM 7 8 DC 0 VLP 91 0 DC 55 VLN 0 92 DC 55 **************************** * OPA637 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 5.38E-3 1 FQ2 0 4 POLY(1) VQ2 5.38E-3 -1 * QUIESCIENT CURRENT RQ 3 4 7.5E4 * DIFF INPUT CAPACITANCE CDIF 1 2 8.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 7.0E-12 C2CM 2 99 7.0E-12 * INPUT VOLTAGE NOISE VN1 61 0 0.6 VN2 0 62 0.6 DN1 61 63 DY DN2 63 62 DY EN 64 1 63 0 1 * INPUT CURRENT NOISE RN1 0 65 60.3865 RN2 65 66 60.3865 RN3 66 0 120.773 RN4 0 67 60.3865 RN5 67 68 60.3865 RN6 68 0 120.773 * .MODEL DY D(IS=1E-15 AF=1 KF=73.4E-18) .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=3.37E-3 VTO=-1) .ENDS *$ ************************************************************************** * OPA640X - WIDEBAND VOLTAGE FEEDBACK OPERATIONAL AMPLIFIER MACROMODEL * CREATED 11/21/93 DS * REV.A * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * NOTE : SUGGESTED TEST CIRCUIT * X1 83 84 81 81 82 80 80 OPA640X/BB * VCC 80 0 DC 5V * VEE 0 81 DC 5V * CFB 83 82 .15E-12 * RFB 86 82 25 * LFB 83 86 2.2E-9 * VIN 85 0 AC 1 DC 0 PWL ( 0N -1 1N 1 20N 1 21N -1 ) * RSOURCE 85 84 25 * RL 82 0 100 * CL 82 0 2E-12 * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | NEGATIVE OUTPUT POWER SUPPLY * | | | | OUTPUT * | | | | | POSITIVE POWER SUPPLY * | | | | | | POSITIVE OUTPUT POWER SUPPLY * | | | | | | | .SUBCKT OPA640X/BB 13 14 11 9 12 10 8 * Q34 41 43 4 2 NPN1 10 Q33 41 42 1 1 PNP1 10 Q32 43 43 4 2 NPN1 20 Q31 43 40 41 1 PNP1 36 Q30 42 37 41 2 NPN1 36 Q29 42 42 1 1 PNP1 20 Q28 40 39 38 2 NPN1 2 Q15 29 30 31 2 NPN1 4 Q27 1 33 40 2 NPN1 24 Q26 4 33 37 1 PNP1 24 Q25 37 36 35 1 PNP1 2 Q24 39 38 4 2 NPN1 1 Q23 36 35 1 1 PNP1 1 Q14 28 26 17 3 PNP1 4 Q7 24 24 25 2 NPN1 1 Q18 15 26 16 3 PNP1 4 Q21 21 15 33 2 NPN1 2 Q22 33 24 34 2 NPN1 2 Q20 30 30 32 2 NPN1 4 Q19 15 29 30 2 NPN1 4 Q1 17 7 18 2 NPN1 12 Q10 26 26 44 3 PNP1 1 Q3 20 24 23 2 NPN1 8 Q2 16 6 19 2 NPN1 12 Q6 27 26 45 3 PNP1 1 Q11 22 27 26 3 PNP1 1 R3 18 20 60 R5 19 20 60 C2 21 22 20E-12 C3 1 4 28E-12 R11 21 44 2E3 R8 21 45 2E3 R12 21 17 250 R22 2 4 20 R2 2 22 20 R4 23 22 125 ISOUR 27 24 450E-6 V1 28 29 3.26 R13 31 22 80 R15 32 22 80 C8 30 22 1.0E-12 C6 15 22 4.6E-12 R16 34 22 320 R14 21 16 250 R9 25 22 1E3 R18 1 35 450 R19 38 4 450 R20 41 5 10 R21 1 3 20 R1 3 21 20 I1 36 39 500E-6 * * PACKAGE PARASITICS CINV 13 0 0.75E-12 L10P 66 68 1.5E-9 L6P 63 64 1.08E-9 L2P 60 61 1.08E-9 C1P 15 2 .15E-12 C30P 77 2 .0425E-12 C29P 5 2 .15E-12 C2P 6 2 .15E-12 L5P 65 7 .7E-9 C3P 61 2 .0425E-12 C4P 61 64 .05E-12 C8P 7 2 .15E-12 C9P 64 2 .0425E-12 C10P 64 68 .05E-12 C14P 2 2 .15E-12 C15P 68 2 .0125E-12 C16P 1 2 .15E-12 C17P 71 2 .0125E-12 C18P 71 74 .05E-12 C22P 3 2 .15E-12 C23P 74 2 .0425E-12 C24P 74 77 .05E-12 C31P 77 80 .05E-12 C35P 4 2 .15E-12 C36P 80 2 .0125E-12 L1P 62 6 .7E-9 L9P 69 2 .7E-9 L14P 70 1 .7E-9 L15P 72 71 1.5E-9 L18P 73 3 .7E-9 L19P 75 74 1.08E-9 L22P 76 5 .7E-9 L23P 78 77 1.08E-9 L27P 79 4 .7E-9 L28P 81 80 1.5E-9 L31P 82 2 .7E-9 L13P 2 67 .7E-9 R1P 61 62 .01 R2P 13 60 .1 R6P 64 65 .01 R7P 14 63 .1 R11P 68 69 .01 R12P 11 66 .1 R16P 67 68 .01 R17P 71 70 .01 R18P 8 72 .1 R22P 74 73 .01 R23P 10 75 .1 R27P 77 76 .01 R28P 12 78 .1 R33P 80 79 .01 R34P 9 81 .1 R38P 80 82 .01 * * MODELS USED .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS *$ ************************************************************************** * OPA641X - WIDEBAND VOLTAGE FEEDBACK OPERATIONAL AMPLIFIER MACROMODEL *CREATED 7/11/94 DY * REV. A * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | NEGATIVE OUTPUT POWER SUPPLY * | | | | OUTPUT * | | | | | POSITIVE POWER SUPPLY * | | | | | | POSITIVE OUTPUT POWER SUPPLY * | | | | | | | .SUBCKT OPA641X/BB 13 14 11 9 12 10 8 * Q34 41 43 4 2 NPN1 10 Q33 41 42 1 1 PNP1 10 Q32 43 43 4 2 NPN1 20 Q31 43 40 41 1 PNP1 36 Q30 42 37 41 2 NPN1 36 Q29 42 42 1 1 PNP1 20 Q28 40 39 38 2 NPN1 2 Q15 29 30 31 2 NPN1 4 Q27 1 33 40 2 NPN1 24 Q26 4 33 37 1 PNP1 24 Q25 37 36 35 1 PNP1 2 Q24 39 38 4 2 NPN1 1 Q23 36 35 1 1 PNP1 1 Q14 28 26 17 3 PNP1 4 Q7 24 24 25 2 NPN1 1 Q18 15 26 16 3 PNP1 4 Q21 21 15 33 2 NPN1 2 Q22 33 24 34 2 NPN1 2 Q20 30 30 32 2 NPN1 4 Q19 15 29 30 2 NPN1 4 Q1 17 7 18 2 NPN1 12 Q10 26 26 44 3 PNP1 1 Q3 20 24 23 2 NPN1 8 Q2 16 6 19 2 NPN1 12 Q6 27 26 45 3 PNP1 1 Q11 22 27 26 3 PNP1 1 R3 18 20 60 R5 19 20 60 C2 21 22 20E-12 C3 1 4 28E-12 R11 21 44 2K R8 21 45 2K R12 21 17 250 R22 2 4 20 R2 2 22 20 R4 23 22 125 ISOUR 27 24 DC 450E-6 V1 28 29 DC 3.2 R13 31 22 80 R15 32 22 80 C8 30 22 0.6E-12 C6 15 22 2.3E-12 R16 34 22 320 R14 21 16 250 R9 25 22 1K R18 1 35 500 R19 38 4 500 R20 41 5 10 R21 1 3 20 R1 3 21 20 I1 36 39 DC 500E-6 C4 6 5 2.0E-12 * PACKAGE PARASITICS CINV 13 0 0.75E-12 L10P 56 58 1.5E-9 L6P 53 54 1.08E-9 L2P 50 51 1.08E-9 C1P 15 2 .15E-12 C30P 67 2 .0425E-12 C29P 5 2 .15E-12 C2P 6 2 .15E-12 L5P 55 7 .7E-9 C3P 51 2 .0425E-12 C4P 51 54 .05E-12 C8P 7 2 .15E-12 C9P 54 2 .0425E-12 C10P 54 58 .05E-12 C14P 2 2 .15E-12 C15P 58 2 .0125E-12 C16P 1 2 .15E-12 C17P 61 2 .0125E-12 C18P 61 64 .05E-12 C22P 3 2 .15E-12 C23P 64 2 .0425E-12 C24P 64 67 .05E-12 C31P 67 70 .05E-12 C35P 4 2 .15E-12 C36P 70 2 .0125E-12 L1P 52 6 .7E-9 L9P 59 2 .7E-9 L14P 60 1 .7E-9 L15P 62 61 1.5E-9 L18P 63 3 .7E-9 L19P 65 64 1.08E-9 L22P 66 5 .7E-9 L23P 68 67 1.08E-9 L27P 69 4 .7E-9 L28P 71 70 1.5E-9 L31P 72 2 .7E-9 L13P 2 57 .7E-9 R1P 51 52 .01 R2P 13 50 .1 R6P 54 55 .01 R7P 14 53 .1 R11P 58 59 .01 R12P 11 56 .1 R16P 57 58 .01 R17P 61 60 .01 R18P 8 62 .1 R22P 64 63 .01 R23P 10 65 .1 R27P 67 66 .01 R28P 12 68 .1 R33P 70 69 .01 R34P 9 71 .1 R38P 70 72 .01 * * MODELS USED .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS * ****************** OPA641X TEST CIRCUIT ****************** * *X1 83 84 81 81 82 80 80 OPA641X/BB *VCC 80 0 DC 5V *VEE 0 81 DC 5V *CFB 83 82 .15E-12 *RFB 86 82 400 *LFB 83 86 2.2E-9 *RFF 83 87 400 *LFF 87 0 2.2E-9 *CFF 83 0 .15E-12 *VIN 85 0 PWL ( 0N -1 1N 1 49N 1 50N -1 ) *RSOURCE 85 84 25 *RL 82 0 100 *CL 82 0 5E-12 *.ENDS *$ ************************************************************************** * OPA642X - WIDEBAND LOW DISTORTION OPERATIONAL AMPLIFIER MACROMODEL * CREATED 11/21/93 DS * REV. A * * NOTE : SUGGESTED TEST CIRCUIT * X1 93 94 91 91 92 90 90 OPA642/BB * VCC 90 0 5V * VEE 0 91 5V * RL 92 0 100 * CL 92 0 5E-12 * VIN 96 0 AC 1 DC 0 PWL ( 0NS -1 1N 1 20N 1 21N -1 ) * RSOURCE 96 94 20 * RFB 95 92 20 * LFB 93 95 2.2E-9 * CFB 93 92 .19E-12 * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | NEGATIVE OUTPUT POWER SUPPLY * | | | | OUTPUT * | | | | | POSITIVE POWER SUPPLY * | | | | | | POSITIVE OUTPUT POWER SUPPLY * | | | | | | | .SUBCKT OPA642X/BB 13 14 11 9 12 10 8 * Q1 16 35 40 3 PNP1 4 Q3 17 35 41 3 PNP1 4 Q34 54 51 53 1 PNP1 36 Q30 1 15 51 2 NPN1 20 Q14 34 27 30 3 PNP1 1 Q15 22 17 34 3 PNP1 2 Q17 42 34 37 3 PNP1 4 Q21 15 36 38 3 PNP1 4 Q25 22 16 36 3 PNP1 2 Q19 42 43 44 2 NPN1 4 Q16 37 27 31 3 PNP1 3 Q20 38 27 32 3 PNP1 3 Q23 43 43 45 2 NPN1 4 Q22 15 42 43 2 NPN1 4 Q32 52 52 1 1 PNP1 20 Q26 47 46 1 1 PNP1 1 Q28 50 47 46 1 PNP1 2 Q24 36 27 33 3 PNP1 1 Q31 51 48 49 2 NPN1 2 Q27 48 49 4 2 NPN1 1 Q29 4 15 50 1 PNP1 20 Q36 53 52 1 1 PNP1 20 Q37 53 54 4 2 NPN1 20 Q9 24 25 23 3 PNP1 2 Q13 23 26 27 3 PNP1 1 Q35 54 54 4 2 NPN1 20 Q5 20 23 24 2 NPN1 8 Q4 17 6 19 2 NPN1 12 Q2 16 7 18 2 NPN1 12 Q33 52 50 53 2 NPN1 36 Q8 26 27 29 3 PNP1 1 Q12 27 27 28 3 PNP1 1 R26 1 3 20 R24 3 21 20 R1 21 40 250 R4 21 41 250 R2 18 20 75 R5 19 20 75 R27 2 4 20 R25 2 22 20 R3 24 22 125 C2 21 22 18E-12 C3 1 4 18E-12 R23 53 5 5 ISOUR 26 25 500E-6 R11 21 28 500 R8 21 29 500 R9 25 22 1250 R12 21 30 500 R13 21 31 166 R17 21 32 166 R15 37 35 160 R16 35 38 160 R19 21 33 500 R14 44 22 320 R18 45 22 320 C8 43 22 0.5E-12 C6 15 22 0.56E-12 R21 1 46 400 C7 16 5 11E-12 R22 49 4 400 C1 17 22 11E-12 I1 47 48 500E-6 CA4 5 2 8.8E-12 CA1 22 2 8.8E-12 CA2 22 2 14.4E-12 CA3 4 2 14.4E-12 * PACKAGE PARASITICS CINV 13 0 0.75E-12 L10P 66 68 1.5E-9 L6P 63 64 1.08E-9 L2P 60 61 1.08E-9 C1P 15 2 .15E-12 C30P 77 2 .0425E-12 C29P 5 2 .15E-12 C2P 6 2 .15E-12 L5P 65 7 .7E-9 C3P 61 2 .0425E-12 C4P 61 64 .05E-12 C8P 7 2 .15E-12 C9P 64 2 .0425E-12 C10P 64 68 .05E-12 C14P 2 2 .15E-12 C15P 68 2 .0125E-12 C16P 1 2 .15E-12 C17P 71 2 .0125E-12 C18P 71 74 .05E-12 C22P 3 2 .15E-12 C23P 74 2 .0425E-12 C24P 74 77 .05E-12 C31P 77 80 .05E-12 C35P 4 2 .15E-12 C36P 80 2 .0125E-12 L1P 62 6 .7E-9 L9P 69 2 .7E-9 L14P 70 1 .7E-9 L15P 72 71 1.5E-9 L18P 73 3 .7E-9 L19P 75 74 1.08E-9 L22P 76 5 .7E-9 L23P 78 77 1.08E-9 L27P 79 4 .7E-9 L28P 81 80 1.5E-9 L31P 82 2 .7E-9 L13P 2 67 .7E-9 R1P 61 62 .01 R2P 13 60 .1 R6P 64 65 .01 R7P 14 63 .1 R11P 68 69 .01 R12P 11 66 .1 R16P 67 68 .01 R17P 71 70 .01 R21P 8 72 .1 R22P 74 73 .01 R26P 10 75 .1 R27P 77 76 .01 R31P 12 78 .1 R33P 80 79 .01 R37P 9 81 .1 R38P 80 82 .01 * * MODELS USED .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS *$ ************************************************************************** * OPA643X - WIDEBAND LOW DISTORTION OPERATIONAL AMPLIFIER MACROMODEL * CREATED 11/21/93 DS * REV.A * * NOTE : SUGGESTED TEST CIRCUIT * X1 93 94 91 91 92 90 90 OPA643/BB * VCC 90 0 5V * VEE 0 91 5V * RL 92 0 100 * CL 92 0 5E-12 * VIN 96 0 AC 1 DC 0 PWL ( 0NS -0.2 1N 0.2 20N 0.2 21N -0.2 ) * RSOURCE 96 94 20 * RFB 95 92 400 * LFB 93 95 2.2E-9 * CFB 93 92 .19E-12 * RFF 93 97 100 * LFF 97 0 2.2E-9 * CFF 93 0 .19E-12 * .END * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | NEGATIVE OUTPUT POWER SUPPLY * | | | | OUTPUT * | | | | | POSITIVE POWER SUPPLY * | | | | | | POSITIVE OUTPUT POWER SUPPLY * | | | | | | | .SUBCKT OPA643X/BB 13 14 11 9 12 10 8 * Q1 16 35 40 3 PNP1 4 Q3 17 35 41 3 PNP1 4 Q34 54 51 53 1 PNP1 36 Q30 1 15 51 2 NPN1 20 Q14 34 27 30 3 PNP1 1 Q15 22 17 34 3 PNP1 2 Q17 42 34 37 3 PNP1 4 Q21 15 36 38 3 PNP1 4 Q25 22 16 36 3 PNP1 2 Q19 42 43 44 2 NPN1 4 Q16 37 27 31 3 PNP1 3 Q20 38 27 32 3 PNP1 3 Q23 43 43 45 2 NPN1 4 Q22 15 42 43 2 NPN1 4 Q32 52 52 1 1 PNP1 20 Q26 47 46 1 1 PNP1 1 Q28 50 47 46 1 PNP1 2 Q24 36 27 33 3 PNP1 1 Q31 51 48 49 2 NPN1 2 Q27 48 49 4 2 NPN1 1 Q29 4 15 50 1 PNP1 20 Q36 53 52 1 1 PNP1 20 Q37 53 54 4 2 NPN1 20 Q9 24 25 23 3 PNP1 2 Q13 23 26 27 3 PNP1 1 Q35 54 54 4 2 NPN1 20 Q5 20 23 24 2 NPN1 8 Q4 17 6 19 2 NPN1 12 Q2 16 7 18 2 NPN1 12 Q33 52 50 53 2 NPN1 36 Q8 26 27 29 3 PNP1 1 Q12 27 27 28 3 PNP1 1 R26 1 3 20 R24 3 21 20 R1 21 40 250 R4 21 41 250 R2 18 20 45 R5 19 20 45 R27 2 4 20 R25 2 22 20 R3 24 22 125 C2 21 22 20E-12 C3 1 4 20E-12 R23 53 5 5 ISOUR 26 25 500E-6 R11 21 28 500 R8 21 29 500 R9 25 22 1250 R12 21 30 500 R13 21 31 166 R17 21 32 166 R15 37 35 160 R16 35 38 160 R19 21 33 500 R14 44 22 320 R18 45 22 320 C8 43 22 0.75E-12 C6 15 22 0.55E-12 R21 1 46 400 C7 16 5 3.5E-12 R22 49 4 400 C1 17 22 3.5E-12 I1 47 48 500E-6 CA4 5 2 2.8E-12 CA1 22 2 2.8E-12 CA2 22 2 16E-12 CA3 4 2 16E-12 * PACKAGE PARASITICS CINV 13 0 0.75E-12 L10P 66 68 1.5E-9 L6P 63 64 1.08E-9 L2P 60 61 1.08E-9 C1P 15 2 .15E-12 C30P 77 2 .0425E-12 C29P 5 2 .15E-12 C2P 6 2 .15E-12 L5P 65 7 .7E-9 C3P 61 2 .0425E-12 C4P 61 64 .05E-12 C8P 7 2 .15E-12 C9P 64 2 .0425E-12 C10P 64 68 .05E-12 C14P 2 2 .15E-12 C15P 68 2 .0125E-12 C16P 1 2 .15E-12 C17P 71 2 .0125E-12 C18P 71 74 .05E-12 C22P 3 2 .15E-12 C23P 74 2 .0425E-12 C24P 74 77 .05E-12 C31P 77 80 .05E-12 C35P 4 2 .15E-12 C36P 80 2 .0125E-12 L1P 62 6 .7E-9 L9P 69 2 .7E-9 L14P 70 1 .7E-9 L15P 72 71 1.5E-9 L18P 73 3 .7E-9 L19P 75 74 1.08E-9 L22P 76 5 .7E-9 L23P 78 77 1.08E-9 L27P 79 4 .7E-9 L28P 81 80 1.5E-9 L31P 82 2 .7E-9 L13P 2 67 .7E-9 R1P 61 62 .01 R2P 13 60 .1 R6P 64 65 .01 R7P 14 63 .1 R11P 68 69 .01 R12P 11 66 .1 R16P 67 68 .01 R17P 71 70 .01 R21P 8 72 .1 R22P 74 73 .01 R26P 10 75 .1 R27P 77 76 .01 R31P 12 78 .1 R33P 80 79 .01 R37P 9 81 .1 R38P 80 82 .01 * * MODELS USED .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS *$ ************************************************************************** * OPA644X - LOW DISTORTION CURRENT FEEDBACK OPERATIONAL AMPLIFIER MACROMODEL * CREATED 12/21/93 DS * REV.A * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * NOTE : SUGGESTED TEST CIRCUIT * *X1 93 94 91 91 92 90 90 OPA644X/BB *VEE 0 91 DC 5V *VCC 90 0 DC 5V *VIN 96 0 PWL ( 0NS -2 1N 2 49N 2 50N -2 ) *V0 96 0 AC 1 DC 0 SIN ( 0 1 1MEG 0 0 0 ) *RIN 96 94 50 *CLOAD 92 0 5E-12 *RLOAD 92 0 100 *RFB 95 92 400 *LFB 93 95 2.2E-9 *CFB 93 92 .19E-12 *.END * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | NEGATIVE OUTPUT POWER SUPPLY * | | | | OUTPUT * | | | | | POSITIVE POWER SUPPLY * | | | | | | POSITIVE OUTPUT POWER SUPPLY * | | | | | | | .SUBCKT OPA644X/BB 13 14 11 9 12 10 8 * Q11 29 21 26 3 PNP1 2 Q14 30 24 28 2 NPN1 2 Q41 1 48 16 2 NPN2 3 Q42 4 49 16 1 PNP2 3 Q6 19 24 27 2 NPN1 2 Q9 17 19 24 2 NPN1 1 Q8 18 20 22 3 PNP1 1 Q44 51 48 52 2 NPN2 36 Q45 50 49 52 1 PNP2 36 Q10 18 22 21 3 PNP1 1 Q38 4 36 48 1 PNP1 20 Q17 32 30 54 3 PNP1 2 Q39 1 36 49 2 NPN1 20 Q12 29 29 7 2 NPN1 2 Q13 30 30 7 3 PNP1 2 Q16 31 29 54 2 NPN1 2 Q43 51 51 1 1 PNP2 20 Q46 50 50 4 2 NPN2 20 Q47 52 51 1 1 PNP2 20 Q48 52 50 4 2 NPN2 20 Q3 20 21 25 3 PNP1 2 C2 1 4 20E-12 C1 17 18 28E-12 ISOUR 20 19 DC 700E-6 R34 2 4 20 R2 2 18 20 R33 1 3 20 R1 3 17 20 R7 27 18 1E3 R28 24 18 10E3 R10 28 18 1E3 R26 52 5 10 R5 17 25 1E3 R27 17 21 10E3 R9 17 26 1E3 R18 38 39 266 C8 15 16 2.0E-12 C3 17 20 1.5E-12 C4 17 19 1.5E-12 C12 36 18 0.3E-12 C1PP 18 2 22.4E-12 C2PP 4 2 16E-12 C4PP 19 2 1.2E-12 C3PP 20 2 1.2E-12 C8PP 16 2 1.6E-12 C12PP 18 2 0.24E-12 F1 17 33 V1 1 V1 17 31 DC 2.1V V2 32 18 DC 2.1V F2 33 18 V2 1 V3 33 59 DC 0 F3 15 59 V3 1 IOUT1 1 48 DC 1.8E-3 IOUT2 49 4 DC 1.8E-3 RE30 39 59 33.7 RE29 37 38 2950 CE29 37 38 0.42E-12 CU29 37 35 32.32E-15 G1 35 38 37 38 0.0305 R029 35 38 39.84E3 CO29 35 2 6.69E-15 RB29 15 37 160 RB33 59 40 6.2E3 CS33 36 2 0.195E-12 RO33 36 35 30.67E3 G2 36 35 34 35 0.0188 CE33 34 35 0.405E-12 RE33 34 35 2364 CU33 34 36 32.5E-15 RBB33 40 34 120 RE31 46 59 35.1 RE32 44 45 1300 CE32 44 45 0.613E-12 G3 43 45 44 45 0.0295 CU32 44 43 37.83E-15 RO32 43 45 19.12E3 CO32 43 2 0.15E-12 RO34 36 43 65.36E3 CO34 36 2 8.57E-15 CU34 42 36 27.82E-15 RE34 42 43 5319 CE34 42 43 0.279E-12 G4 36 43 42 43 0.0194 RB34 59 41 6.2E3 RB32 15 44 120 R19 45 46 266 RBB34 41 42 160 R20 59 35 500 R21 59 43 500 C6 38 59 20E-15 C7 45 59 20E-15 R3 1 58 1080 R4 58 4 1080 E1 59 4 58 4 1 R6 6 54 10 * PACKAGE PARASITICS CINV 13 0 0.75E-12 L10P 66 68 1.5E-9 L6P 63 64 1.08E-9 L2P 60 61 1.08E-9 C1P 15 2 .15E-12 C30P 77 2 .0425E-12 C29P 5 2 .15E-12 C2P 6 2 .15E-12 L5P 65 7 .7E-9 C3P 61 2 .0425E-12 C4P 61 64 .05E-12 C8P 7 2 .15E-12 C9P 64 2 .0425E-12 C10P 64 68 .05E-12 C14P 2 2 .15E-12 C15P 68 2 .0125E-12 C16P 1 2 .15E-12 C17P 71 2 .0125E-12 C18P 71 74 .05E-12 C22P 3 2 .15E-12 C23P 74 2 .0425E-12 C24P 74 77 .05E-12 C31P 77 80 .05E-12 C35P 4 2 .15E-12 C36P 80 2 .0125E-12 L1P 62 6 .7E-9 L9P 69 2 .7E-9 L14P 70 1 .7E-9 L15P 72 71 1.5E-9 L18P 73 3 .7E-9 L19P 75 74 1.08E-9 L22P 76 5 .7E-9 L23P 78 77 1.08E-9 L27P 79 4 .7E-9 L28P 81 80 1.5E-9 L31P 82 2 .7E-9 L13P 2 67 .7E-9 R1P 61 62 .01 R2P 13 60 .1 R6P 64 65 .01 R7P 14 63 .1 R11P 68 69 .01 R12P 11 66 .1 R16P 67 68 .01 R17P 71 70 .01 R18P 8 72 .1 R22P 74 73 .01 R23P 10 75 .1 R27P 77 76 .01 R28P 12 78 .1 R33P 80 79 .01 R34P 9 81 .1 R38P 80 82 .01 C37P 16 2 .15E-12 * * MODELS USED .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL NPN2 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 1.831E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 1.065E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .MODEL PNP2 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 3.053E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 0.571E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS *$ ************************************************************************** * OPA646X - LOW POWER, WIDE BANDWIDTH OPERATIONAL AMPLIFIER MACROMODEL * CREATED 11/21/93 DS * REV.A * * NOTE : SUGGESTED TEST CIRCUIT * X1 83 84 81 81 82 80 80 OPA646X/BB * VCC 80 0 5V * VEE 0 81 5V * VIN 85 0 AC 1 DC 0 PWL ( 0N -1 1N 1 20N 1 21N -1 ) * RSOURCE 85 84 25 * RL 82 0 100 * CL 82 0 5E-12 * CFB 83 82 .15E-12 * RFB 86 82 25 * LFB 83 86 2.2E-9 * .END * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | NEGATIVE OUTPUT POWER SUPPLY * | | | | OUTPUT * | | | | | POSITIVE POWER SUPPLY * | | | | | | POSITIVE OUTPUT POWER SUPPLY * | | | | | | | .SUBCKT OPA646X/BB 13 14 11 9 12 10 8 * Q31 1 42 41 1 NPN1 36 Q32 4 43 41 1 PNP1 36 Q30 42 40 43 2 NPN1 20 Q29 4 36 43 1 PNP1 1 Q28 1 35 42 2 NPN1 1 Q27 43 40 42 1 PNP1 20 Q24 36 24 37 2 NPN1 2 Q15 30 32 31 2 NPN1 1 Q22 39 15 45 2 NPN1 2 Q21 38 15 44 1 PNP1 2 Q19 35 26 34 1 PNP1 2 Q11 29 26 17 3 PNP1 1 Q7 24 24 25 2 NPN1 1 Q16 15 26 16 3 PNP1 1 Q23 36 36 45 1 PNP1 4 Q20 35 35 44 2 NPN1 4 Q25 21 17 39 2 NPN1 2 Q26 22 30 38 3 PNP1 2 Q18 32 32 33 2 NPN1 1 Q17 15 30 32 2 NPN1 1 Q10 22 27 26 3 PNP1 1 Q3 20 24 23 2 NPN1 2 Q2 16 6 19 2 NPN1 4 Q1 17 7 18 2 NPN1 4 Q6 27 26 28 3 PNP1 1 R3 18 20 350 R5 19 20 350 R19 2 4 20 R2 2 22 20 R4 23 22 500 R8 21 28 2.2E3 R11 21 17 1E3 R13 21 16 1E3 R17 41 5 10 R12 31 22 320 R14 33 22 320 R16 37 22 400 R15 21 34 400 R18 1 3 20 R1 3 21 20 C2 21 22 28E-12 C3 1 4 28E-12 C6 32 22 0.65E-12 C7 15 22 0.75E-12 R9 25 22 1E3 ISOUR 27 24 200E-6 V1 29 30 2.352 * PACKAGE PARASITICS CINV 13 0 0.75E-12 R38P 80 82 .01 R33P 80 79 .01 R28P 12 78 .1 R27P 77 76 .01 R23P 10 75 .1 R22P 74 73 .01 R18P 8 72 .1 R17P 71 70 .01 R16P 67 68 .01 R14P 11 66 .1 R11P 68 69 .01 R9P 14 63 .1 R6P 64 65 .01 R4P 13 60 .1 R1P 61 62 .01 C6P 61 64 .05E-12 C12P 64 68 .05E-12 L13P 2 67 .7E-9 L4P 60 61 1.08E-9 L8P 63 64 1.08E-9 L12P 66 68 1.5E-9 L31P 82 2 .7E-9 L28P 81 80 1.5E-9 L27P 79 4 .7E-9 L23P 78 77 1.08E-9 L22P 76 5 .7E-9 L19P 75 74 1.08E-9 L18P 73 3 .7E-9 L15P 72 71 1.5E-9 L14P 70 1 .7E-9 L9P 69 2 .7E-9 L1P 62 6 .7E-9 C36P 80 2 .0125E-12 C35P 4 2 .15E-12 C31P 77 80 .05E-12 C24P 74 77 .05E-12 C23P 74 2 .0425E-12 C22P 3 2 .15E-12 C18P 71 74 .05E-12 C17P 71 2 .0125E-12 C16P 1 2 .15E-12 C15P 68 2 .0125E-12 C14P 2 2 .15E-12 C9P 64 2 .0425E-12 C8P 7 2 .15E-12 C3P 61 2 .0425E-12 L5P 65 7 .7E-9 C2P 6 2 .15E-12 C29P 5 2 .15E-12 C30P 77 2 .0425E-12 C1P 15 2 .15E-12 R34P 9 81 .1 * * MODELS USED .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS *$ ************************************************************************** * OPA648X ULTRA WIDE-BAND CURRENT FEEDBACK AMPLIFIER * CREATED 8/24/94 DY * REV. A * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | .SUBCKT OPA648X/BB 9 10 8 11 7 * Q14 19 20 21 2 NPN1 2 Q15 20 20 22 2 NPN1 2 Q16 23 19 20 2 NPN1 2 Q2 23 23 4 1 PNP1 2 Q4 28 23 3 1 PNP1 2 Q1 18 18 4 2 NPN1 2 Q3 27 18 3 2 NPN1 2 Q7 33 27 26 1 PNP1 2 Q6 26 26 25 1 PNP1 2 Q5 27 26 24 1 PNP1 2 Q8 28 31 29 2 NPN1 2 Q9 31 31 30 2 NPN1 2 Q10 32 28 31 2 NPN1 2 Q28 37 36 35 1 PNP1 2 Q30 40 38 39 2 NPN1 2 Q42 43 42 13 2 NPN1 36 Q40 43 41 12 1 PNP1 36 Q31 13 34 37 1 PNP1 20 Q32 12 34 40 2 NPN1 20 Q41 42 42 13 2 NPN1 20 Q39 41 41 12 1 PNP1 20 Q33 41 37 43 2 NPN1 20 Q35 42 40 43 1 PNP1 20 Q29 38 39 13 2 NPN1 2 Q27 36 35 12 1 PNP1 2 Q38 40 42 13 2 NPN1 1 Q37 37 41 12 1 PNP1 1 Q22 33 33 6 2 NPN1 4 Q23 12 33 34 2 NPN1 2 Q25 13 32 34 1 PNP1 2 Q24 32 32 6 1 PNP1 4 Q11 17 16 14 1 PNP1 2 Q13 18 17 16 1 PNP1 2 Q12 16 16 15 1 PNP1 2 ISOUR 17 19 DC 0.7E-3 R19 2 13 10 R18 1 12 10 R5 12 14 1K R6 12 15 1K R7 21 13 1K R8 22 13 1K R1 12 24 240 R2 12 25 240 R3 29 13 240 R4 30 13 240 CCOMP 6 13 0.7E-12 R24 43 5 10 I2 36 38 DC 0.5E-3 R22 12 35 400 R23 39 13 400 C3 1 2 56E-12 * Package Parasitics CINV 9 0 0.75E-12 L6P 61 62 1.5E-9 L4P 58 59 1.08E-9 L2P 55 56 1.08E-9 C1P 6 2 .15E-12 C14P 68 2 .0425E-12 C13P 5 2 .15E-12 C2P 3 2 .15E-12 L3P 60 4 .7E-9 C3P 56 2 .0425E-12 C4P 56 59 .05E-12 C5P 4 2 .15E-12 C6P 59 2 .0425E-12 C7P 59 62 .05E-12 C8P 2 2 .15E-12 C9P 62 2 .0125E-12 C10P 1 2 .15E-12 C11P 65 2 .0425E-12 C12P 65 68 .05E-12 L1P 57 3 .7E-9 L5P 63 2 .7E-9 L7P 64 1 .7E-9 L8P 66 65 1.08E-9 L9P 67 5 .7E-9 L10P 69 68 1.08E-9 L11P 2 70 .7E-9 R1P 56 57 .01 R2P 9 55 .1 R3P 59 60 .01 R4P 10 58 .1 R5P 62 63 .01 R6P 8 61 .1 R16P 70 62 .01 R7P 65 64 .01 R8P 7 66 .1 R9P 68 67 .01 R10P 11 69 .1 * * MODELS USED .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS * ****************** OPA648X TEST CIRCUIT ****************** * *X1 80 81 84 82 83 OPA648X/BB *VCC 83 0 DC 5V *VEE 0 84 DC 5V *RFB 85 82 250 *VIN 87 0 PWL ( 0N -1 1N 1 20N 1 21N -1 ) *vin 87 0 ac 1 *RL0AD 82 0 100 *LFB 80 85 2.2E-9 *CLOAD 82 0 5E-12 *CFB 80 82 0.15E-12 *RSOUR 87 81 50 *RFF 80 86 250 *CFF 80 0 0.15E-12 *LFF 86 0 2.2E-9 *.ENDS *$ ************************************************************************** * OPA650X WIDEBAND, LOW POWER VOLTAGE FEEDBACK OP AMP MACROMODEL * CREATED 1/12/95 DY * REV.A * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | .SUBCKT OPA650X/BB 13 14 11 12 10 * * Input Stage and Current Source Q2 16 6 19 2 NPN1 4 Q1 17 7 18 2 NPN1 4 Q3 20 24 23 2 NPN1 2 R3 18 20 300 R5 19 20 300 R4 23 22 500 ISOUR 27 24 DC 370E-6 Q6 27 26 28 3 PNP1 1 Q7 24 24 25 2 NPN1 1 Q10 2 27 26 3 PNP1 1 R8 21 28 2K R9 25 22 1K R2 2 22 20 R1 3 21 20 C1 27 24 .6E-12 * Gain Stage Q11 29 26 17 3 PNP1 1 Q15 30 32 31 2 NPN1 1 Q16 46 26 16 3 PNP1 1 Q17 47 30 32 2 NPN1 1 Q18 32 32 33 2 NPN1 1 R11 21 17 1K R13 21 16 1K R12 31 22 320 R14 33 22 320 R18 46 47 500 V1 29 30 DC 2.4 C2 32 22 0.4E-12 C4 46 22 1.0E-12 C3 47 22 0.35E-12 * Output Stage Q19 35 26 34 3 PNP1 2 Q20 35 35 44 2 NPN1 2 Q21 38 47 44 3 PNP1 2 Q22 39 46 45 2 NPN1 2 Q23 36 36 45 3 PNP1 2 Q24 36 24 37 2 NPN1 2 Q25 21 17 39 2 NPN1 2 Q26 22 31 38 3 PNP1 2 Q27 43 40 42 3 PNP1 10 Q28 3 35 42 2 NPN1 2 Q29 2 36 43 3 PNP1 2 Q30 42 40 43 2 NPN1 10 Q31 3 42 41 2 NPN1 48 Q32 2 43 41 3 PNP1 48 R17 41 5 10 R16 37 22 500 R15 21 34 1K * Package Parasitics R11P 12 65 .1 R10P 64 63 .01 R9P 10 62 .1 R8P 61 60 .01 R7P 57 58 .01 R6P 11 56 .1 R5P 58 59 .01 R4P 14 53 .1 R3P 54 55 .01 R2P 13 50 .1 R1P 51 52 .01 C3P 51 54 .05E-12 C6P 54 58 .05E-12 L7P 2 57 .7E-9 L2P 50 51 1.08E-9 L4P 53 54 1.08E-9 L6P 56 58 1.5E-9 L11P 65 64 1.08E-9 L10P 63 5 .7E-9 L9P 62 61 1.08E-9 L8P 60 3 .7E-9 L5P 59 2 .7E-9 L1P 52 6 .7E-9 C11P 61 64 .05E-12 C10P 61 2 .0425E-12 C9P 3 2 .15E-12 C8P 58 2 .0125E-12 C7P 2 2 .15E-12 C5P 54 2 .0425E-12 C4P 7 2 .15E-12 C2P 51 2 .0425E-12 L3P 55 7 .7E-9 C1P 6 2 .15E-12 C12P 5 2 .15E-12 C13P 64 2 .0425E-12 * * Models Used .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS * ****************** OPA650 TEST CIRCUIT ****************** * *VCC 80 0 DC 5V *VEE 0 81 DC 5V *VIN 85 0 PWL ( 0N -2 1N 2 50N 2 51N -2 ) *RL 82 0 100 *CL 82 0 5E-12 *CFB 83 82 .15E-12 *CFF1 83 0 0.75E-12 *RIN 85 84 25 *RFB 86 82 25 *LFB 83 86 2.2E-9 *X82 83 84 81 82 80 OPA650X/BB *.ENDS *$ ************************************************************************** * OPA651x WIDEABND, LOW POWER VOLTAGE FEEDBACK OP AMP MACROMODEL * STABLE IN GAINS >=2V/V * CREATED 5/4/95 DY * REV. A * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | .SUBCKT OPA651X/BB 13 14 11 12 10 * * Input Stage and Current Source Q1 17 7 18 2 NPN1 4 Q2 16 6 19 2 NPN1 4 Q3 20 24 23 2 NPN1 2 Q6 27 26 28 3 PNP1 1 Q7 24 24 25 2 NPN1 1 Q10 2 27 26 3 PNP1 1 ISOUR 27 24 DC 370E-6 R1 3 21 20 R2 2 22 20 R3 18 20 100 R5 19 20 100 R4 23 22 500 R8 21 28 2K R9 25 22 1K C1 27 24 .5E-12 C5 21 22 .5E-12 * Gain Stage Q11 29 26 17 3 PNP1 1 Q15 30 32 31 2 NPN1 1 Q16 46 26 16 3 PNP1 1 Q17 47 30 32 2 NPN1 1 Q18 32 32 33 2 NPN1 1 V1 29 30 DC 2.4 R11 21 17 1K R13 21 16 1K R12 31 22 320 R14 33 22 320 C2 32 22 0.1E-12 C3 47 22 0.6E-12 C4 46 22 0.6E-12 C6 6 5 1.5E-12 * Output Stage Q19 35 26 34 3 PNP1 2 Q20 35 35 44 2 NPN1 2 Q21 38 47 44 3 PNP1 2 Q22 39 46 45 2 NPN1 2 Q23 36 36 45 3 PNP1 2 Q24 36 24 37 2 NPN1 2 Q25 21 17 39 2 NPN1 2 Q26 22 31 38 3 PNP1 2 Q27 43 40 42 3 PNP1 10 Q28 3 35 42 2 NPN1 2 Q29 2 36 43 3 PNP1 2 Q30 42 40 43 2 NPN1 10 Q31 3 42 41 2 NPN1 48 Q32 2 43 41 3 PNP1 48 R15 21 34 1K R16 37 22 500 R17 41 5 10 R18 46 47 500 * Package Parasitics R1P 51 52 .01 R2P 13 50 .1 R3P 54 55 .01 R4P 14 53 .1 R5P 58 59 .01 R6P 11 56 .1 R7P 57 58 .01 R8P 61 60 .01 R9P 10 62 .1 R10P 64 63 .01 R11P 12 65 .1 L1P 52 6 .7E-9 L2P 50 51 1.08E-9 L3P 55 7 .7E-9 L4P 53 54 1.08E-9 L5P 59 2 .7E-9 L6P 56 58 1.5E-9 L7P 2 57 .7E-9 L8P 60 3 .7E-9 L9P 62 61 1.08E-9 L10P 63 5 .7E-9 L11P 65 64 1.08E-9 C1P 6 2 .15E-12 C2P 51 2 .0425E-12 C3P 51 54 .05E-12 C4P 7 2 .15E-12 C5P 54 2 .0425E-12 C6P 54 58 .05E-12 C7P 2 2 .15E-12 C8P 58 2 .0125E-12 C9P 3 2 .15E-12 C10P 61 2 .0425E-12 C11P 61 64 .05E-12 C12P 5 2 .15E-12 C13P 64 2 .0425E-12 CINV 6 0 .75E-12 * * Models Used .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS * ********************** OPA651X TEST CIRCUIT ************************ * *X84 83 84 81 82 80 OPA651X/BB *VCC 80 0 DC 5V *VEE 0 81 DC 5V *VIN 85 0 PWL ( 0N -1 1N 1 50N 1 51N -1 ) *RIN 85 84 25 *RLOAD 82 0 100 *CLOAD 82 0 5E-12 *CFB 83 82 .15E-12 *RFB 86 82 400 *LFB 83 86 2.2E-9 *RFF 83 87 400 *LFF 87 0 2.2E-9 *CFF 83 0 0.15E-12 *.ENDS *$ ************************************************************************** * OPA655M operational amplifier "macromodel" subscircuit * using Multiple pole-zero topology * created 5/28/96 sb * Rev.A 7/20/96 BB * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * Notes: * 1. The output stage includes a parasitic capacitance (C5=1pF) from the output * node to ground. * 2. For better convergence during transient analysis set: * .OPTIONS ITL4=40 * * Node assignments: * -In * | +In * | | Negative Supply * | | | Output * | | | | Positive Supply * | | | | | .SUBCKT OPA655M/BB 2 3 4 6 7 * * Input Stage R1 1 2 5E11 R2 1 3 5E11 R3 7 15 19.2 R4 7 16 19.2 *2nd POLE at 260MHz C1 15 16 1.1E-11 ISS 14 4 14E-3 IOS 2 3 2E-12 EOS 12 2 POLY(1) 70 9 0.5E-3 1 J1 15 12 14 JX J2 16 3 14 JX * Second Stage R7 7 23 15385 R8 4 23 15385 *1st POLE at 300KHz C2 7 23 34.5E-12 C3 4 23 34.5E-12 G1 7 23 POLY(1) 15 16 10E-3 0.052 G2 23 4 POLY(1) 16 15 10E-3 0.052 V1 7 8 0.5V V2 10 4 0.5V D1 23 8 DX D2 10 23 DX R9 7 9 1E4 R10 9 4 1E4 *Pole at 800MHz R11 7 20 1E6 R12 20 4 1E6 C11 7 20 0.2E-16 C12 20 4 0.2E-16 G3 7 20 23 9 1E-6 G4 20 4 9 23 1E-6 *Pole at 2.5GHz R30 7 30 1E6 R31 4 30 1E6 C30 7 30 6.3E-17 C31 4 30 6.3E-17 G30 7 30 20 9 1E-6 G31 30 4 9 20 1E-6 *Common Mode Stage R19 71 70 1E6 R20 70 72 1E6 L3 7 71 0.851 L4 72 4 0.851 G7 7 70 1 9 5.623E-10 G8 70 4 9 1 5.623E-10 *Pole at 1500MHz R21 7 80 1E6 R22 4 80 1E6 C21 7 80 1.1E-16 C22 4 80 1.1E-16 G9 7 80 20 9 1E-6 G10 80 4 9 20 1E-6 *Output Stage R23 7 81 64 R24 81 4 64 L5 81 88 1.8E-9 R5 88 6 1 C5 6 0 1E-12 G11 81 7 7 80 1.5625E-2 G12 4 81 80 4 1.5625E-2 G13 84 4 80 81 1.5625E-2 G14 85 4 81 80 1.5625E-2 V3 82 81 1.64 V4 81 83 1.64 D3 80 82 DX D4 83 80 DX D5 7 84 DX D6 7 85 DX D7 4 84 DY D8 4 85 DY * .MODEL JX NJF(BETA=0.205 VTO=-1.55 IS=2.5E-12 CGD=5E-13 AF=3.5 KF=8E-10) .MODEL DX D(IS=1E-15) .MODEL DY D(IS=1E-15 BV=20) .ENDS *$ ************************************************************************** * OPA658X WIDEBAND, LOW-POWER CURRENT-FEEDBACK OP AMP MACROMODEL * CREATED 11/24/94 DY * REV. A * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * CONNECTIONS: INVERTING INPUT * | NON-INVERTING INPUT * | | NEGATIVE POWER SUPPLY * | | | OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | .SUBCKT OPA658X/BB 8 9 7 10 6 * * Input Stage ISOUR1 11 13 DC 0.5MA ISOUR2 14 12 DC 0.5MA Q2 14 14 4 1 PNP1 2 Q4 18 14 3 1 PNP1 2 Q1 13 13 4 2 NPN1 2 Q3 15 13 3 2 NPN1 2 R5 11 12 20K C3 13 0 0.3E-12 C4 14 0 0.1E-12 R16 1 11 10 R17 2 12 10 C1 11 12 1E-12 * Gain Stage Q7 24 15 37 1 PNP1 6 Q6 37 17 20 1 PNP1 6 Q5 15 37 16 1 PNP1 6 Q8 18 19 22 2 NPN1 3 Q9 19 23 21 2 NPN1 3 Q10 26 18 19 2 NPN1 3 R1 11 16 300 R2 11 20 300 R3 22 12 100 R4 21 12 100 R12 37 17 600 R6 19 23 200 C2 25 12 0.4E-12 * Output Stage Q21 1 33 36 2 NPN1 48 Q22 2 35 36 1 PNP1 48 Q11 12 26 28 1 PNP1 3 Q12 11 24 30 2 NPN1 3 Q20 35 34 33 1 PNP1 10 Q19 33 34 35 2 NPN1 10 Q13 29 29 28 2 NPN1 3 Q17 1 29 33 2 NPN1 2 Q14 31 31 30 1 PNP1 3 Q18 2 31 35 1 PNP1 2 Q15 29 37 27 1 PNP1 6 Q16 31 19 32 2 NPN1 3 R9 11 27 300 R10 32 12 100 R7 24 25 80 R8 25 26 80 R11 36 5 10 * Package Parasitics CINV 8 0 .75E-12 L6P 49 48 1.5E-9 L4P 46 45 1.08E-9 L2P 43 42 1.08E-9 C8P 55 2 .0425E-12 L3P 44 4 .7E-9 C1P 42 2 .0425E-12 C2P 42 45 .05E-12 C3P 45 2 .0425E-12 C4P 45 48 .05E-12 C5P 48 2 .0125E-12 C6P 52 2 .0425E-12 C7P 52 55 .05E-12 L1P 41 3 .7E-9 L5P 47 2 .7E-9 L7P 51 1 .7E-9 L8P 53 52 1.08E-9 L9P 54 5 .7E-9 L10P 56 55 1.08E-9 L11P 2 50 .7E-9 R1P 42 41 .1 R2P 8 43 .1 R3P 45 44 .1 R4P 9 46 .1 R5P 48 47 .1 R6P 7 49 .1 R11P 50 48 .025 R7P 52 51 .1 R8P 6 53 .1 R9P 55 54 .1 R10P 10 56 .1 * * MODELS USED .MODEL NPN1 NPN + IS = 4.647E-17 BF = 2.293E+02 NF = 1.000E+00 VAF = 4.398E+01 + IKF = 7.233E-03 ISE = 1.222E-14 NE = 2.000E+00 BR = 3.695E+01 + NR = 1.000E+00 VAR = 1.494E+00 IKR = 1.667E+05 ISC = 1.057E-14 + NC = 1.653E+00 RB = 3.170E+02 IRB = 0.000E+00 RBM = 1.500E+02 + RE = 1.133E+01 RC = 2.768E+01 CJE = 2.070E-14 VJE = 7.414E-01 + MJE = 4.950E-01 TF = 1.150E-11 XTF = 2.452E+01 VTF = 1.029E+00 + ITF = 1.878E-02 PTF = 0.000E+00 CJC = 3.661E-14 VJC = 6.465E-01 + MJC = 4.509E-01 XCJC = 1.270E-01 TR = 3.240E-10 CJS = 5.326E-14 + VJS = 5.291E-01 MJS = 4.389E-01 XTB = 1.218E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 8.614E-01 * .MODEL PNP1 PNP + IS = 2.628E-17 BF = 1.478E+02 NF = 1.000E+00 VAF = 3.106E+01 + IKF = 3.115E-03 ISE = 8.930E-17 NE = 1.283E+00 BR = 3.061E+03 + NR = 1.000E+00 VAR = 1.448E+00 IKR = 5.000E-03 ISC = 1.061E-14 + NC = 1.634E+00 RB = 2.794E+02 IRB = 0.000E+00 RBM = 1.544E+02 + RE = 7.452E+00 RC = 1.142E+02 CJE = 2.038E-14 VJE = 7.470E-01 + MJE = 4.930E-01 TF = 1.434E-11 XTF = 2.216E+01 VTF = 1.072E+00 + ITF = 2.397E-02 PTF = 0.000E+00 CJC = 6.106E-14 VJC = 7.743E-01 + MJC = 5.185E-01 XCJC = 8.499E-02 TR = 6.500E-10 CJS = 2.855E-13 + VJS = 9.063E-01 MJS = 4.931E-01 XTB = 1.181E+00 EG = 1.184E+00 + XTI = 2.000E+00 KF = 0.000E+00 AF = 1.000E+00 FC = 9.014E-01 * .ENDS * ****************** OPA658 TEST CIRCUIT ****************** * *X1 60 61 63 65 62 OPA658X/BB *VCC 62 0 DC 5V *VEE 0 63 DC 5V *RFB 66 65 400 *VIN 67 0 PWL ( 0N -1 1N 1 20N 1 21N -1 ) *RL 65 0 100 *LFB 60 66 2.2E-9 *CL 65 0 5E-12 *CFB 60 65 0.15E-12 *RSOUR 67 61 50 *CFF 60 0 0.15E-12 *RFF 60 64 400 *LFF 64 0 2.2E-9 *.ENDS *$ ************************************************************************** * OPA660X1 = MDB + MDT + MBC OPERATIONAL TRANSCONDUCTANCE AMPLIFIER * AND BUFFER SIMPLIFIED MACROMODEL VERSION * CREATED 8/92 KL * REV.B 7/9/93 BCB: CLARIFCATION OF NODE SET INSTRUCTIONS * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * NOTE : FOR QUICKER CONVERSION USE THE NODESET V(Xyour.13)=+4.2758 AND * V(Xyour.14)=-4.2774 IN THE ROOT SIMULATION FILE. ("Xyour" IS * THE DEVICE NAME USED IN THE ROOT FILE.) * * CONNECTIONS: IQ ADJUST * | E (EMITTER) * | | B (BASE) * | | | NEGATIVE SUPPLY * | | | | BUFFER IN * | | | | | BUFFER OUT * | | | | | | POSITIVE SUPPLY * | | | | | | | C (COLLECTOR) * | | | | | | | | .SUBCKT OPA660X1/BB 1 2 3 4 5 6 7 8 * X1 4 5 6 7 13 14 MDB/OPA660X1 ; Diamond Buffer DB X2 2 3 4 7 8 13 14 MDT/OPA660X1 ; Diamond Transistor DT X3 1 4 7 13 14 MBC/OPA660X1 ; Biasing Circuit BC C201 1 0 2.0E-12 C202 2 0 3.3E-12 C206 6 0 2.0E-12 C208 8 0 4.2E-12 * .ENDS * *Diamond Buffer MDB .SUBCKT MDB/OPA660X1 4 5 6 7 13 14 C71 71 0 0.06E-12 C72 72 0 0.06E-12 C73 73 0 2.00E-12 R73 73 5 90 Q71 71 13 7 PI/OPA660X1 2 Q72 72 14 4 NI/OPA660X1 2 Q73 4 73 71 PI/OPA660X1 Q74 7 73 72 NI/OPA660X1 Q75 7 71 6 NI/OPA660X1 7 Q76 4 72 6 PI/OPA660X1 7 * .ENDS * *Diamond Transistor MDT .SUBCKT MDT/OPA660X1 2 3 4 7 8 13 14 R23 23 3 90 C21 21 0 0.06E-12 C22 22 0 0.06E-12 C23 23 0 2.00E-12 C25 25 0 28E-12 C26 26 0 28E-12 Q21 21 13 7 PI/OPA660X1 2 Q22 22 14 4 NI/OPA660X1 2 Q23 4 23 21 PI/OPA660X1 Q24 7 23 22 NI/OPA660X1 Q25 25 21 2 NI/OPA660X1 7 Q26 26 22 2 PI/OPA660X1 7 Q27 25 25 7 PIJ/OPA660X1 Q28 26 26 4 NIJ/OPA660X1 Q29 8 25 7 PIJ/OPA660X1 Q30 8 26 4 NIJ/OPA660X1 * .ENDS * * Biasing Circuit MBC .SUBCKT MBC/OPA660X1 1 4 7 13 14 R122 122 4 50E3 R123 122 1 100 Q121 13 13 7 PI/OPA660X1 Q122 13 14 122 NI/OPA660X1 9 Q123 14 13 7 PI/OPA660X1 Q124 14 14 4 NI/OPA660X1 * .ENDS * .MODEL NI/OPA660X1 NPN .MODEL PI/OPA660X1 PNP .MODEL NIJ/OPA660X1 NPN (VAF=100) .MODEL PIJ/OPA660X1 PNP (VAF=100) *$ ************************************************************************** * OPA660X2 = MDB + MDT + MBC OPERATIONAL TRANSCONDUCTANCE AMPLIFIER * AND BUFFER COMPLEX MACROMODEL VERSION * CREATED 8/92 KL * REV.A * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * |-------------------------------------------------------------| * * CONNECTIONS: IQ ADJUST * | E (EMITTER) * | | B (BASE) * | | | NEGATIVE SUPPLY * | | | | BUFFER IN * | | | | | BUFFER OUT * | | | | | | POSITIVE SUPPLY * | | | | | | | C (COLLECTOR) * | | | | | | | | .SUBCKT OPA660X2/BB 1 2 3 4 5 6 7 8 * X1 4 5 6 7 13 14 MDB/OPA660X2 ; Diamond Buffer DB X2 2 3 4 7 8 13 14 MDT/OPA660X2 ; Diamond Transistor DT X3 1 4 7 13 14 MBC/OPA660X2 ; Biasing Circuit BC C201 1 0 2E-12 C202 2 0 2E-12 C203 3 0 2E-12 C205 5 0 2E-12 C206 6 0 2E-12 C208 8 0 2E-12 * .ENDS * *Diamond Buffer MDB .SUBCKT MDB/OPA660X2 4 5 6 7 13 14 R77 77 5 25 Q71 74 13 7 7 PI/OPA660X2 2.8 Q72 73 14 4 4 NI/OPA660X2 2.8 Q73 73 73 7 7 PIJ/OPA660X2 18 Q74 74 74 4 4 NIJ/OPA660X2 18 Q75 79 73 7 7 PIJ/OPA660X2 18 Q76 80 74 4 4 NIJ/OPA660X2 18 Q77 74 77 79 7 PIJ/OPA660X2 Q78 73 77 80 4 NIJ/OPA660X2 Q79 79 79 78 4 NIJ/OPA660X2 6 Q80 80 80 78 7 PIJ/OPA660X2 6 Q81 7 79 6 4 NIJ/OPA660X2 18 Q82 4 80 6 7 PIJ/OPA660X2 18 * .ENDS * *Diamond Transistor MDT .SUBCKT MDT/OPA660X2 2 3 4 7 8 13 14 R27 27 3 25 R33 33 7 50 R34 34 4 50 R35 35 7 50 R36 36 4 50 C38 2 0 2.2E-12 Q21 24 13 7 7 PI/OPA660X2 2.8 Q22 23 14 4 4 NI/OPA660X2 2.8 Q23 23 23 7 7 PIJ/OPA660X2 18 Q24 24 24 4 4 NIJ/OPA660X2 18 Q25 29 23 7 7 PIJ/OPA660X2 18 Q26 30 24 4 4 NIJ/OPA660X2 18 Q27 24 27 29 7 PIJ/OPA660X2 Q28 23 27 30 4 NIJ/OPA660X2 Q29 29 29 28 4 NIJ/OPA660X2 6 Q30 30 30 28 7 PIJ/OPA660X2 6 Q31 31 29 2 4 NIJ/OPA660X2 18 Q32 32 30 2 7 PIJ/OPA660X2 18 Q33 31 31 33 7 PIJ/OPA660X2 18 Q34 32 32 34 4 NIJ/OPA660X2 18 Q35 8 31 35 7 PIJ/OPA660X2 18 Q36 8 32 36 4 NIJ/OPA660X2 18 * .ENDS * * Biasing Circuit MBC .SUBCKT MBC/OPA660X2 1 4 7 13 14 R122 122 4 50E3 R123 122 1 100 C121 121 0 10E-12 C124 124 0 10E-12 I121 121 124 0.1E-6 E13 13 0 121 0 1 E14 14 0 124 0 1 Q121 121 121 7 7 PI/OPA660X2 Q122 121 124 122 4 NI/OPA660X2 27 Q123 124 121 7 7 PI/OPA660X2 Q124 124 124 4 4 NI/OPA660X2 Q125 4 13 7 7 PI/OPA660X2 32 * .ENDS * * BIPOLAR TRANSISTOR MODELS .MODEL NI/OPA660X2 NPN .MODEL PI/OPA660X2 PNP .MODEL NIJ/OPA660X2 NPN (BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) * .MODEL PIJ/OPA660X2 PNP (BF = 110 IS = 0.1567E-16 +CJC = 0.029E-12 AF = 1.000 NE = 1.366 XTB = 2.452 BR = 12.89 +CJE = 0.017E-12 EG = 1.183 NF = 1.000 XTF = 9.000 IKF = 2.272E-3 +CJS = 0.050E-12 FC = 0.900 NR = 1.000 XTI = 2.000 IKR = 16.67E-3 +RB = 228.0 IRB = 0.000 PTF = 0.000 ISC = 5.248E-20 +RC = 48.83 KF = 0.000 VAR = 1.771 ISE = 8.040E-18 +RE = 5.065 MJC = 0.190 VJC = 0.526 ITF = 6.683E-3 +TF = 29.80E-12 MJE = 0.493 VJE = 0.816 RBM = 60.00 +TR = 65.00E-12 MJS = 0.348 VJS = 0.596 XCJC= 0.0732 +VAF = 39.00 NC = 1.634 VTF = 2.680) *$ ************************************************************************** * *** MACRO MODEL -- OPA671M * Created 1-8-92 BCB * REV.B 6-3-92 BCB (added TC for Aol, Is, PSR, and GBWP) * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * | | * | Neither this library nor any part may be copied without | * | the express written consent of Burr-Brown Corporation. | * | | * | The users should carefully note the following factors | * | regarding this model. | * | | * |-------------------------------------------------------------| * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | * | | | | | * | | | | | * | | | | | * | | | | | .SUBCKT OPA671M/BB 31 32 7 4 36 * * Input and output parasitics CINP1 31 4 1.1P CINP2 3 4 1.9P LINP 3 31 4N CINM1 32 4 1.1P CINM2 2 4 1.9P LINM 2 32 4N COUT1 36 4 2.2P COUT2 6 4 2.2P LOUT 6 36 75N CDIF1 2 3 4.5P R11 2 13 5E12 R12 13 3 5E12 * Input stage (2nd pole @ 56M Hz) and GBW product vs temperature J11 15 2 14 JX J12 16 12 14 JX G11 2 4 POLY(3) (15,2) (14,2) (4,2) 0 1E-12 1E-12 1E-12 G12 12 4 POLY(3) (16,12) 14,12) (4,12) 0 1E-12 1E-12 1E-12 C12 15 16 CX 3.336E-12 R13 15 4 426 R14 16 4 426 EOS 12 3 POLY(2) 81 71 63 4 0.5E-3 1 1 ISS 7 14 0.666E-3 * Gain stage (80dB)[over temperature] and first pole (@ 6K HZ) R27 7 21 4.26E6 TC=-0.55E-2 R28 4 21 4.26E6 TC=-0.55E-2 C22 7 21 6.2267E-12 C23 4 21 6.2267E-12 G21 7 21 POLY(1) 15 16 9.35E-3 2.347E-3 G22 21 4 POLY(1) 16 15 9.35E-3 2.347E-3 V21 7 22 2.89 V22 23 4 2.89 D21 21 22 DX D22 23 21 DX * power supply voltage vs current and supply center reference * quiescent error current and supply current vs temperature R9 7 71 4.5E3 R10 4 71 4.5E3 R15 7 4 20.724E3 TC=-1E-3 G10 7 4 7 4 -0.5 * Power-supply rejection vs temperature GPSR1 63 4 7 22 207.1204E-6 GPSR2 63 4 7 4 -19.9526E-6 R61 63 4 1 TC=27.5E-3 * Common-mode gain network -92dB, zero at 400kHz R82 82 81 1 L82 7 82 .3979E-6 R83 81 83 1 L83 83 4 .3979E-6 G82 7 81 13 71 25E-6 G83 81 4 71 13 25E-6 * correction current and output stage D91 21 92 DX D92 93 21 DX D93 7 94 DX D94 7 95 DX D95 4 94 DY D96 4 95 DY V93 92 6 1.39 V94 6 93 1.05 G91 7 6 21 7 25E-3 G92 4 6 21 4 25E-3 G95 94 4 6 21 25E-3 G96 95 4 21 6 25E-3 R91 7 6 40 R92 4 6 40 * .MODEL JX PJF(BETA=2E-3 VTO=-2 IS=2.5E-12 AF=1 KF=19E-18) .MODEL DX D(IS=1E-15) .MODEL DY D(IS=1E-15 BV=50) .MODEL CX CAP(TC1=-.008) .ENDS *$ ************************************************************************** * *** MACRO MODEL -- OPA675M * Created 3-23-92 BCB * REV.A * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * | | * | Neither this library nor any part may be copied without | * | the express written consent of Burr-Brown Corporation. | * | | * | The users should carefully note the following factors | * | regarding this model. | * | | * |-------------------------------------------------------------| * * This model includes the device characteristics as well as * package parasitics. If you are using the product in die * form, the package parasitics no longer apply. * * CONNECTIONS: NON-INVERTING INPUT A * | INVERTING INPUT A * | | COMPENSATION PIN (see note above) * | | | OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | NEGATIVE POWER SUPPLY * | | | | | | NON-INVERTING INPUT B * | | | | | | | INVERTING INPUT B * | | | | | | | | ECL * | | | | | | | | | NOT ECL * | | | | | | | | | | GND * | | | | | | | | | | | .SUBCKT OPA675M/BB 1 2 5 8 7 10 16 15 13 12 11 * * Output and comp cap bond pad and pin parasitics LOUT 3 8 2.5N COUT1 3 11 2.2P COUT2 8 11 2.2P CCPP1 19 0 1.1P CCPP2 5 0 1.1P LCPP 19 5 10N * common mode reference R11 7 99 382 R12 10 99 382 * Side A bond pad and pin parasitics LM 2 102 5N CM1 2 11 1.1P CM2 102 11 1.1P LP 1 101 5N CP1 1 11 1.1P CP2 101 11 1.1P * Side A input stage (2nd pole @ 569M Hz) Q1 110 102 114 QX Q2 111 113 115 QX R5 114 116 1065 R6 115 116 1065 RIN1 102 4 2.107E3 RIN2 101 4 2.107E3 CIN 102 101 2P IOS 101 102 0.8U VOS 113 101 250E-6 * Side B bond pad and pin parasitics LM_2 15 202 5N CM1_2 15 11 1.1P CM2_2 202 11 1.1P LP_2 16 201 5N CP1_2 16 11 1.1P CP2_2 201 11 1.1P * Side B input stage (2nd pole @ 569M Hz) Q1_2 110 202 214 QX Q2_2 111 213 215 QX R5_2 214 216 1065 R6_2 215 216 1065 RIN1_2 202 6 2.107E3 RIN2_2 201 6 2.107E3 CIN_2 202 201 2P IOS_2 201 202 0.8U VOS_2 213 201 250E-6 * SWOP AMP switch RSW1 995 997 1 CSW1 997 11 1000P RSW2 996 998 1 CSW2 998 11 1000P Q11 116 997 999 QY Q12 216 998 999 QY C11 116 10 1.1P C12 216 10 1.1P IEE 999 10 0.9452E-3 VECL1 13 995 1 VECL2 12 996 1 * Common-input stage load for both sides C1 110 111 1.2485E-13 R3 7 110 1120 R4 7 111 1120 * first gain stage (36dB) R9 7 118 18.11K R10 10 118 18.11K G1 7 118 110 111 3.4E-3 G2 10 118 110 111 3.4E-3 E1 7 22 POLY(1) 7 99 -1.847 1 E2 23 10 POLY(1) 99 10 -1.847 1 D1 118 22 DX D2 23 118 DX * second gain stage (1st pole @ 1.5M Hz {determined by device * and pad parasitics}, 34dB) and external compensation stage R7 7 19 56.14K R8 10 19 56.14K C3 7 19 0.791P C4 10 19 0.791P G3 7 19 POLY(1) 118 99 6.48E-3 0.8928E-3 G4 19 10 POLY(1) 99 118 6.48E-3 0.8928E-3 V3 7 20 2.667 V4 21 10 2.352 D3 19 20 DX D4 21 19 DX * pole stage @ 800 MHz G60 7 60 19 99 1E-6 G61 10 60 19 99 1E-6 R60 7 60 1E6 R61 10 60 1E6 C60 7 60 198.9E-18 C61 10 60 198.9E-18 * pole stage @ 2 GHz G80 7 80 60 99 1E-6 G81 10 80 60 99 1E-6 R80 7 80 1E6 R81 10 80 1E6 C80 7 80 795.8E-19 C81 10 80 795.8E-19 * pole stage @ 200 MHz G90 7 90 80 99 1E-6 G91 10 90 80 99 1E-6 R90 7 90 1E6 R91 10 90 1E6 C90 7 90 795.8E-18 C91 10 90 795.8E-18 * pole stage @ 20 GHz G100 7 100 90 99 1E-6 G101 10 100 90 99 1E-6 R100 7 100 1E6 R101 10 100 1E6 C100 7 100 795.8E-20 C101 10 100 795.8E-20 * pole stage @ 20 GHz G110 7 119 100 99 1E-6 G111 10 119 100 99 1E-6 R110 7 119 1E6 R111 10 119 1E6 C110 7 119 795.8E-20 C111 10 119 795.8E-20 * zero / pole pair @ (fz = 142 MHz , fp = 569 MHz) G120 7 120 119 99 1E-6 G121 10 120 119 99 1E-6 R120 7 81 3E6 R123 82 10 3E6 R121 81 120 1E6 R122 120 82 1E6 L120 7 81 839.1E-6 L123 10 82 839.1E-6 * correction current and output stage D5 7 51 DX D6 7 52 DX D7 120 53 DX D8 54 120 DX D9 10 51 DY D10 10 52 DY V5 53 3 -.05 V6 3 54 -.05 G7 7 3 120 7 .03333 G8 10 3 120 10 .03333 G9 51 10 3 120 .03333 G10 52 10 120 3 .03333 R15 7 3 30 R16 10 3 30 * .MODEL QY NPN(BF=400) .MODEL QX NPN(BF=41) .MODEL DX D(IS=1E-15) .MODEL DY D(IS=1E-15 BV=50) .ENDS *$ ************************************************************************** * *** MACRO MODEL -- OPA676M * Created 1/13/92 BCB * REV.B 2/8/93 : BCB: TTL switch overdrove into saturation. Reduced voltage * amplitude to npn switch. * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * | | * | Neither this library nor any part may be copied without | * | the express written consent of Burr-Brown Corporation. | * | | * | The users should carefully note the following factors | * | regarding this model. | * | | * |-------------------------------------------------------------| * * 1. This model includes the device characteristics as well as * package parasitics. If you are using the product in die * form, the package parasitics no longer apply. * * Your feedback and suggestions on this model will be appreciated! * * Bonnie Baker * Burr-Brown Corporation * 6730 S. Tucson Blvd. * Tucson, Arizona * (800) 548-6132 (WATS line) * * NON-INVERTING INPUT A * | INVERTING INPUT A * | | COMPENSATION PIN (see note above) * | | | OUTPUT * | | | | POSITIVE POWER SUPPLY * | | | | | NEGATIVE POWER SUPPLY * | | | | | | NON-INVERTING INPUT B * | | | | | | | INVERTING INPUT B * | | | | | | | | NOT TTL * | | | | | | | | | GND * | | | | | | | | | | .SUBCKT OPA676M/BB 1 2 5 8 7 10 16 15 12 11 * * Output and comp cap bond pad and pin parasitics LOUT 3 8 2.5N COUT1 3 11 2.2P COUT2 8 11 2.2P CCPP1 19 0 1.1P CCPP2 5 0 1.1P LCPP 19 5 10N * common mode reference R11 7 99 382 R12 10 99 382 * Side A bond pad and pin parasitics LM 2 102 5N CM1 2 11 1.1P CM2 102 11 1.1P LP 1 101 5N CP1 1 11 1.1P CP2 101 11 1.1P * Side A input stage (2nd pole @ 569M Hz) Q1 110 102 114 QX Q2 111 113 115 QX R5 114 116 1065 R6 115 116 1065 RIN1 102 4 2.107E3 RIN2 101 4 2.107E3 CIN 102 101 2P IOS 101 102 0.8U VOS 113 101 250E-6 * Side B bond pad and pin parasitics LM_2 15 202 5N CM1_2 15 11 1.1P CM2_2 202 11 1.1P LP_2 16 201 5N CP1_2 16 11 1.1P CP2_2 201 11 1.1P * Side B input stage (2nd pole @ 569M Hz) Q1_2 110 202 214 QX Q2_2 111 213 215 QX R5_2 214 216 1065 R6_2 215 216 1065 RIN1_2 202 6 2.107E3 RIN2_2 201 6 2.107E3 CIN_2 202 201 2P IOS_2 201 202 0.8U VOS_2 213 201 250E-6 * SWOP AMP switch RSW1 13 997 1 CSW1 997 11 1000P RSW2 996 998 1 CSW2 998 11 1000P Q11 116 997 999 QY Q12 216 998 999 QY C11 116 10 2.75P C12 216 10 2.75P IEE 999 10 0.9452E-3 ETTL1 13 11 POLY(1) 12,11 -1.8 -0.42 ETTL2 996 11 POLY(1) 12,11 -3.9 0.42 RTTL2 12 11 1E6 * Common-input stage load for both sides C1 110 111 1.2485E-13 R3 7 110 1120 R4 7 111 1120 * first gain stage (36dB) R9 7 118 18.11K R10 10 118 18.11K G1 7 118 110 111 3.4E-3 G2 10 118 110 111 3.4E-3 E1 7 22 POLY(1) 7 99 -1.847 1 E2 23 10 POLY(1) 99 10 -1.847 1 D1 118 22 DX D2 23 118 DX * second gain stage (1st pole @ 1.5M Hz {determined by device * and pad parasitics}, 34dB) and external compensation stage R7 7 19 56.14K R8 10 19 56.14K C3 7 19 0.791P C4 10 19 0.791P G3 7 19 POLY(1) 118 99 6.48E-3 0.8928E-3 G4 19 10 POLY(1) 99 118 6.48E-3 0.8928E-3 V3 7 20 2.667 V4 21 10 2.352 D3 19 20 DX D4 21 19 DX * pole stage @ 800 MHz G60 7 60 19 99 1E-6 G61 10 60 19 99 1E-6 R60 7 60 1E6 R61 10 60 1E6 C60 7 60 198.9E-18 C61 10 60 198.9E-18 * pole stage @ 2 GHz G80 7 80 60 99 1E-6 G81 10 80 60 99 1E-6 R80 7 80 1E6 R81 10 80 1E6 C80 7 80 795.8E-19 C81 10 80 795.8E-19 * pole stage @ 200 MHz G90 7 90 80 99 1E-6 G91 10 90 80 99 1E-6 R90 7 90 1E6 R91 10 90 1E6 C90 7 90 795.8E-18 C91 10 90 795.8E-18 * pole stage @ 20 GHz G100 7 100 90 99 1E-6 G101 10 100 90 99 1E-6 R100 7 100 1E6 R101 10 100 1E6 C100 7 100 795.8E-20 C101 10 100 795.8E-20 * pole stage @ 20 GHz G110 7 119 100 99 1E-6 G111 10 119 100 99 1E-6 R110 7 119 1E6 R111 10 119 1E6 C110 7 119 795.8E-20 C111 10 119 795.8E-20 * zero / pole pair @ (fz = 142 MHz , fp = 569 MHz) G120 7 120 119 99 1E-6 G121 10 120 119 99 1E-6 R120 7 81 3E6 R123 82 10 3E6 R121 81 120 1E6 R122 120 82 1E6 L120 7 81 839.1E-6 L123 10 82 839.1E-6 * correction current and output stage D5 7 51 DX D6 7 52 DX D7 120 53 DX D8 54 120 DX D9 10 51 DY D10 10 52 DY V5 53 3 -.05 V6 3 54 -.05 G7 7 3 120 7 .03333 G8 10 3 120 10 .03333 G9 51 10 3 120 .03333 G10 52 10 120 3 .03333 R15 7 3 30 R16 10 3 30 * .MODEL QY NPN(BF=400) .MODEL QX NPN(BF=41) .MODEL DX D(IS=1E-15) .MODEL DY D(IS=1E-15 BV=50) .ENDS *$ ************************************************************************** * OPA77 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * CREATED USING PARTS RELEASE 4.03 ON 10/15/90 AT 15:33 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA77/BB 1 2 3 4 5 * C1 11 12 40.00E-12 C2 6 7 80.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 1.326E9 -1E9 1E9 1E9 -1E9 GA 6 0 11 12 301.6E-6 GCM 0 6 10 99 30.16E-12 IEE 10 4 DC 20.00E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 3.316E3 RC2 3 12 3.316E3 RE1 13 10 729.2 RE2 14 10 729.2 REE 10 99 9.999E6 RO1 8 5 30 RO2 7 99 30 RP 3 4 15.15E3 VB 9 0 DC 0 VC 3 53 DC 1.500 VE 54 4 DC 1.500 VLIM 7 8 DC 0 VLP 91 0 DC 22 VLN 0 92 DC 22 * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=10.00E3) .ENDS *$ ************************************************************************** * OPA77E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * CREATED USING PARTS RELEASE 4.03 ON 09/20/90 AT 15:29 * REV.A * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT OPA77E/BB INP INN 3 4 5 * C1 11 12 40.00E-12 C2 6 7 80.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 1.326E9 -1E9 1E9 1E9 -1E9 GA 6 0 11 12 301.6E-6 GCM 0 6 10 99 30.16E-12 IEE 10 4 DC 20.00E-6 HLIM 90 0 VLIM 1K Q1 11 2 13 QX Q2 12 1 14 QX R2 6 9 100.0E3 RC1 3 11 3.316E3 RC2 3 12 3.316E3 RE1 13 10 729.2 RE2 14 10 729.2 REE 10 99 9.999E6 RO1 8 5 30 RO2 7 99 30 * RP 3 4 15.15E3 VB 9 0 DC 0 VC 3 53 DC 1.500 VE 54 4 DC 1.500 VLIM 7 8 DC 0 VLP 91 0 DC 22 VLN 0 92 DC 22 **************************** * OPA77 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0.976E-3 1 FQ2 0 4 POLY(1) VQ2 0.976E-3 -1 * QUIESCIENT CURRENT RQ 3 4 3.0E4 * DIFF INPUT CAPACITANCE CDIF 1 2 1.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 1.5E-12 C2CM 2 99 1.5E-12 * INPUT PROTECTION R1IN INP 1 500 D1A 1 VD1 DX D1B VD1 2 DX R2IN INN 2 500 D2A 2 VD2 DX D2B VD2 1 DX * .MODEL DX D(IS=800.0E-18) .MODEL QX NPN(IS=800.0E-18 BF=10.00E3) .ENDS *$ ************************************************************************** * OPT101P,W *** MACROMODEL-- Copyright 1994 Burr-Brown Corp. * Bandwidth: 14kHz, Iq = 0.12mA, Single-Supply: +2.7 - +36V * REV.A 12-13-94 EM * * Users should very carefully note the following factors regarding this * model: * * This macromodel, although similar to the commonly used * Boyle model, has limitations on many characteristics. * * Use this macromodel to model both OPT101P (PDIP), and OPT101W (SIP). * The inverting input is used on the SIP to connect a current source to, * much like the photodiode acts as a current source on the real devices. * * Modeled behavior includes: * Offset Voltage (initially set to 7.5mV) * Input bias current (initially set to 200pA) * Current limit and load-dependant output swing * Quiescent Current, including the effect of Vpin3 * Input Impedance * Open Loop Gain * Large-signal dynamic behavior * * Behavior that is not modeled includes: * Changes in parameters over temperature * Noise * Parameter variation for Monte Carlo analysis * Over-voltage effects * Slew Rate * * This macromodel may not accurately model all aforementioned behaviour * with other than the internal 1meg-ohm feedback resistor, and feedback * capacitors. * * While reasonable care has been taken in their preparation, we cannot * be responsible for correct application on any and all computer * systems. * * Further, Burr-Brown Corporation reserves the right to change these * models without prior notice. * * In all cases, the current data sheet information for a given real * device is your final design guideline, and is the only actual * performance guarantee. * * Connections: vs * | inverting input * | | vpin3 * | | | feedback * | | | | vout * | | | | | common * | | | | | | .subckt OPT101/BB vs in vpd feed vout com * c1 11 12 1E-12 c2 6 7 1E-12 cee 10 99 9E-12 cpar in feed 5.5e-12 cf in vout 9e-12 cphoto in com 1200e-12 ; photodiode capacitance dc vout 53 dx de 54 vout dx dlp 90 91 dx dln 92 90 dx dp 4 vs dx egnd 99 0 poly(2) (vs,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 1.061E9 -1E9 1E9 1E9 -1E9 ga 6 0 11 12 22.5E-6 gcm 0 6 10 99 314.2E-12 iee vs 10 dc 10.00E-6 hlim 90 0 vlim 1K q1 11 in 13 qx q2 12 1 14 qx jpd ed vout vout jp ; JFET pulldown r2 6 9 100e3 rc1 44 11 79.58E3 rc2 44 12 79.58E3 re1 13 10 74.40E3 re2 14 10 74.40E3 ree 10 99 20.00E6 ro1 8 vout 3 ro2 7 99 3 rp vs 4 2.8e6 rf in feed 1e6 ; internal 1meg vb 9 0 dc 0 vc vs 53 dc 1.815 ve 54 4 dc 0 vlim 7 8 dc 0 vlp 91 0 dc 15 vln 0 92 dc 15 vls 4 44 dc 0.7 vped 1 com dc 7.5e-3 ; offset voltage vbulk 4 0 dc 0 vdrain ed vpd dc 0 iq vs 4 dc 100u fdrain vs 4 vdrain 1 * .model dx D(Is=800.0E-18) .model qx PNP(Is=800.0E-18 Bf=25.00E3) .model jp PJF(VTO=-1.2 BETA=72U LAMBDA=7M) .ends *$ ************************************************************************** * OPT201 INTEGRATED PHOTODIODE AND AMPLIFIER MACROMODEL * CREATED USING PARTS 3/18/93 WM * REV.A * * ------------------------------------------------------------* * | NOTE: USE AN EXTERNAL CURRENT SOURCE BETWEEN PINS 2 AND 8 * * | TO MODEL THE CURRENT GENERATED BY THE PHOTODIODE. * * ------------------------------------------------------------* * * connections: COM * | -IN * | | +V * | | | -V * | | | | OUT * | | | | | 1MEG * | | | | | | .subckt OPT201KP/BB 8 2 1 3 5 4 * X1 8 2 1 3 55 OPAMP_201 * PHOTODIODE AND FEEDBACK COMPONENTS RFB 2 4 1E6 ROUT 55 5 75 CFB 55 2 40E-12 RPHOTO 2 8 100E6 CPHOTO 2 8 4000E-12 DPHOTO 2 8 DIODE * .MODEL DIODE D .ENDS * OPAMP MODEL .SUBCKT OPAMP_201 1 2 3 4 5 C1 11 12 10.49E-12 C2 6 7 45.00E-12 CSS 10 99 61.36E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 29.43E9 -30E9 30E9 30E9 -30E9 GA 6 0 11 12 107.4E-6 GCM 0 6 10 99 1.074E-9 ISS 3 10 DC 117.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 9.307E3 RD2 4 12 9.307E3 RO1 8 5 75 RO2 7 99 2 RP 3 4 75.00E3 RSS 10 99 1.709E6 VB 9 0 DC 0 VC 3 53 DC 1. VE 54 4 DC .5 VLIM 7 8 DC 0 VLP 91 0 DC 15 VLN 0 92 DC 15 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=58.E-6 VTO=-1) .ENDS *$ ************************************************************************** * OPT202 INTEGRATED PHOTODIODE AND AMPLIFIER MACROMODEL * Bandwidth 50KHz, Iq = 1.4mA * CREATED USING PARTS 4/15/94 WM * REV. A * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * ------------------------------------------------------------* * | NOTE: USE AN EXTERNAL CURRENT SOURCE BETWEEN PINS 2 AND 8 * * | TO MODEL THE CURRENT GENERATED BY THE PHOTODIODE. * * ------------------------------------------------------------* * * PHOTODIODE AND FEEDBACK COMPONENTS * * connections: COM * | -IN * | | V+ * | | | V- * | | | | Vo * | | | | | RFB,1MEG * | | | | | | .subckt OPT202/BB 8 2 1 3 5 4 * X1 8 2 1 3 55 OPAMP_202 RFB 2 4 1MEG ROUT 55 5 5 CFB 55 2 3pF RPHOTO 2 8 100MEG CPHOTO 2 8 600pF DPHOTO 2 8 DIODE * .MODEL DIODE D .ends * * OPAMP MODEL .subckt OPAMP_202 1 2 3 4 5 c1 11 12 5.715E-12 c2 6 7 1.000E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 99.47E6 -99E6 99E6 99E6 -99E6 ga 6 0 11 12 100.5E-6 gcm 0 6 10 99 503.8E-12 iss 3 10 dc 4.000E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 9.947E3 rd2 4 12 9.947E3 ro1 8 5 75 ro2 7 99 100 rp 3 4 75.00E3 rss 10 99 50.00E6 vb 9 0 dc 0 vc 3 53 dc .6 ve 54 4 dc .6 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 * .model dx D(Is=800.0E-18) .model jx PJF(Is=250.0E-15 Beta=2.527E-3 Vto=-1) .ends *$ ************************************************************************** * OPT209 INTEGRATED PHOTODIODE AND AMPLIFIER MACROMODEL * Bandwidth 16kHz, Iq = 0.4mA * CREATED USING PARTS 4/27/94 WM * REV. A * REV. B 11 June 97 NPA: added missing period in .MODEL DIODE D * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * ------------------------------------------------------------* * | NOTE: USE AN EXTERNAL CURRENT SOURCE BETWEEN PINS 2 AND 8 * * | TO MODEL THE CURRENT GENERATED BY THE PHOTODIODE. * * ------------------------------------------------------------* * * PHOTODIODE AND FEEDBACK COMPONENTS * * connections: COM * | -IN * | | V+ * | | | V- * | | | | Vo * | | | | | RFB,1MEG * | | | | | | .subckt OPT209/BB 8 2 1 3 5 4 * X1 8 2 1 3 55 OPAMP_209 RFB 2 4 1MEG ROUT 55 5 5 CFB 55 2 10pF RPHOTO 2 8 1000MEG CPHOTO 2 8 600pF DPHOTO 2 8 DIODE .MODEL DIODE D .ends * * OPAMP MODEL .subckt OPAMP_209 1 2 3 4 5 c1 11 12 12.63E-12 c2 6 7 4.000E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 99.7E6 -99E6 99E6 99E6 -99E6 ga 6 0 11 12 100.5E-6 gcm 0 6 10 99 1.005E-9 iss 3 10 dc 16.00E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 9.947E3 rd2 4 12 9.947E3 ro1 8 5 75 ro2 7 99 100 rp 3 4 75.00E3 rss 10 99 12.50E6 vb 9 0 dc 0 vc 3 53 dc .6 ve 54 4 dc .6 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 * .model dx D(Is=800.0E-18) .model jx PJF(Is=250.0E-15 Beta=631.7E-6 Vto=-1) .ends *$ ************************************************************************** * OPT211 INTEGRATED PHOTODIODE AND AMPLIFIER MACROMODEL * CREATED USING PARTS 12/6/94 WM * REV.A 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * ------------------------------------------------------------ * | NOTE: USE AN EXTERNAL CURRENT SOURCE BETWEEN PINS 2 AND 8 | * | TO MODEL THE CURRENT GENERATED BY THE PHOTODIODE. | * ------------------------------------------------------------ * * PHOTODIODE AND FEEDBACK COMPONENTS * * * connections: COM * | -IN * | | +V * | | | -V * | | | | OUT * | | | | | PHOTO * | | | | | | .subckt OPT211/BB 8 2 1 3 5 7 * X1 8 2 1 3 5 OPAMP_211 * Photodiode RPHOTO 2 7 1000GIG CPHOTO 2 7 600pF DPHOTO 2 7 DIODE CSUB 2 8 80pF .MODEL DIODE D .ENDS * *OPAMP MODEL * .subckt OPAMP_211 1 2 3 4 5 c1 11 12 5.715E-12 c2 6 7 1.000E-12 dc 5 53 dx de 54 5 dx dlp 90 91 dx dln 92 90 dx dp 4 3 dx egnd 99 0 poly(2) (3,0) (4,0) 0 .5 .5 fb 7 99 poly(5) vb vc ve vlp vln 0 99E7 -99E7 99E7 99E7 -99E7 ga 6 0 11 12 100.5E-6 gcm 0 6 10 99 503.8E-12 iss 3 10 dc 4.000E-6 hlim 90 0 vlim 1K j1 11 2 10 jx j2 12 1 10 jx r2 6 9 100.0E3 rd1 4 11 9.947E3 rd2 4 12 9.947E3 ro1 8 5 5 ro2 7 99 5 rp 3 4 75.00E3 rss 10 99 50.00E6 vb 9 0 dc 0 vc 3 53 dc .6 ve 54 4 dc .6 vlim 7 8 dc 0 vlp 91 0 dc 20 vln 0 92 dc 20 * .model dx D(Is=800.0E-18) .model jx PJF(Is=250.0E-15 Beta=2.527E-3 Vto=-1) .ends *$ ************************************************************************** * OPT301 INTEGRATED PHOTODIODE AND AMPLIFIER MACROMODEL * CREATED USING PARTS 3/18/93 WM * REV.A * REV.B 7 June 97 NPA added text: Model optical input as an equivalent photodiode * current into SJ (pin 2). * REV.C 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * ------------------------------------------------------------* * | NOTE: USE AN EXTERNAL CURRENT SOURCE BETWEEN PINS 2 AND 8 * * | TO MODEL THE CURRENT GENERATED BY THE PHOTODIODE. * * ------------------------------------------------------------* * * connections: COM * | -IN * | | +V * | | | -V * | | | | OUT * | | | | | 1MEG * | | | | | | .subckt OPT301/BB 8 2 1 3 5 4 * X1 8 2 1 3 55 OPAMP_301 * PHOTODIODE AND FEEDBACK COMPONENTS RFB 2 4 1E6 ROUT 55 5 75 CFB 55 2 40E-12 RPHOTO 2 8 100E6 CPHOTO 2 8 4000E-12 DPHOTO 2 8 DIODE .MODEL DIODE D .ENDS * * OPAMP MODEL .SUBCKT OPAMP_301 1 2 3 4 5 C1 11 12 10.49E-12 C2 6 7 45.00E-12 CSS 10 99 61.36E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 29.43E9 -30E9 30E9 30E9 -30E9 GA 6 0 11 12 107.4E-6 GCM 0 6 10 99 1.074E-9 ISS 3 10 DC 117.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 4 11 9.307E3 RD2 4 12 9.307E3 RO1 8 5 75 RO2 7 99 2 RP 3 4 75.00E3 RSS 10 99 1.709E6 VB 9 0 DC 0 VC 3 53 DC 1. VE 54 4 DC .5 VLIM 7 8 DC 0 VLP 91 0 DC 15 VLN 0 92 DC 15 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=500.0E-15 BETA=58.E-6 VTO=-1) .ENDS *$ ************************************************************************** * PGA206 HIGH SPEED PROGRAMMABLE GAIN AMPLIFIER * Rev. A Created 5/30/96 BCB * REV. B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * REV. C 24 JUNE 97 NPA: ADDED NOTE: DRIVE A0 & A1 INPUTS WITH VDC SOURCES * TO PREVENT POSSIBLE NON-CONVERGENCE. * * connections: V01 * | VIN- * | | VIN+ * | | | V- * | | | | VO2 * | | | | | REF * | | | | | | VO * | | | | | | | SENSE * | | | | | | | | V+ * | | | | | | | | | DIG GND * | | | | | | | | | | A0 * | | | | | | | | | | | A1 * | | | | | | | | | | | | .SUBCKT PGA206/BB 1 4 5 8 9 10 11 12 13 14 15 16 * XG1 51 50 14 59 55 NOR_206 XG4 51 50 14 56 AND_206 XG2 56 51 14 58 XOR_206 XG3 56 50 14 57 XOR_206 XA1 4 31 13 8 1 OPAMP_206 XA2 5 30 13 8 9 OPAMP_206 XA3 40 41 13 8 11 OPAMP_206 R1A 27 26 625 R2A 26 25 1.25E3 R3A 25 24 2.5E3 R4AB 24 23 1.25E3 R1B 20 21 625 R2B 21 22 1.25E3 R3B 22 23 2.5E3 R1C 27 41 10000 R2C 41 12 10000 R3C 20 40 10000.2 R4C 40 10 10000 CF3 41 12 3E-12 CF4 40 10 3E-12 CF1 31 1 10E-12 CF2 30 9 10E-12 RO1 1 27 15 RO2 9 20 15 S1 31 27 59 14 SW S2 31 26 57 14 SW S3 31 25 58 14 SW S4 31 24 55 14 SW S5 30 23 55 14 SW S6 30 22 58 14 SW S7 30 21 57 14 SW S8 30 20 59 14 SW GA0 15 14 15 50 -100 GA1 16 14 16 51 -100 RA0 15 50 0.01 RA1 16 51 0.01 IVPS 14 13 0.2E-3 IVMS 8 14 1.5E-3 * .MODEL SW VSWITCH(RON=1 ROFF=1000G VON=0.15 VOFF=0.1) .ENDS * .SUBCKT AND_206 16 15 14 75 D71 71 16 DX D72 71 15 DX D73 71 72 DX D74 72 73 DX Q71 74 73 14 QX Q72 75 74 14 QX R71 80 71 4E3 R72 80 74 8E3 R73 73 76 7E3 R74 80 75 1E3 VBIAS 14 76 2 VSUP 80 14 5 * .MODEL DX D(IS=1E-15) .MODEL QX NPN(IS=800E-18 BF=500) .ENDS * .SUBCKT XOR_206 57 17 14 88 * Logic cell - X-OR Gate R52 57 51 450 R53 57 52 450 Q50 55 51 14 QX Q52 53 52 14 QX R56 80 55 2000 Q51 55 53 14 QX Q53 51 54 14 QX * A1 for switch 3, A0 for switch 2 R54 53 17 450 R55 54 17 450 Q54 88 55 14 QX R57 80 88 2000 VSUP 80 14 2.5 * .MODEL QX NPN(IS=800E-18 BF=500) .ENDS * .SUBCKT NOR_206 16 15 14 85 86 * Logic cell - NOR R61 16 61 450 Q60 85 61 14 QX R62 15 63 450 R60 80 85 3E3 Q61 85 63 14 QX VSUP 80 14 2 Q62 86 85 14 QX R63 86 80 2000 * * Models .MODEL QX NPN(IS=800E-18 BF=500) .ENDS * * PGA206 operational amplifier "macromodel" subcircuit * created using Parts release 5.2 on 05/30/96 at 07:47 * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .SUBCKT OPAMP_206 1 2 3 4 5 * C1 11 12 7.002E-12 C2 6 7 20.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 265.3E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 754.0E-6 GCM 0 6 10 99 754.0E-12 ISS 10 4 DC 600.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 3 11 1.326E3 RD2 3 12 1.326E3 RO1 8 5 10 RO2 7 99 5 RP 3 4 8.036E3 RSS 10 99 333.3E3 VB 9 0 DC 0 VC 3 53 DC 2.300 VE 54 4 DC 1.500 VLIM 7 8 DC 0 VLP 91 0 DC 10 VLN 0 92 DC 10 * .MODEL DX D(IS=800.0E-18) .MODEL JX NJF(IS=1.000E-12 BETA=947.5E-6 VTO=-1) .ENDS *$ ************************************************************************** * PGA207 HIGH SPEED PROGRAMMABLE GAIN AMPLIFIER * REV.A Created 5/30/96 BCB * REV.B 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * REV.C 24 JUNE 97 NPA: ADDED NOTE: DRIVE A0 & A1 INPUTS WITH VDC SOURCES * TO PREVENT POSSIBLE NON-CONVERGENCE. * *connections: V01 * | VIN- * | | VIN+ * | | | V- * | | | | VO2 * | | | | | REF * | | | | | | VO * | | | | | | | SENSE * | | | | | | | | V+ * | | | | | | | | | DIG GND * | | | | | | | | | | A0 * | | | | | | | | | | | A1 * | | | | | | | | | | | | .SUBCKT PGA207/BB 1 4 5 8 9 10 11 12 13 14 15 16 * XG1 51 50 14 59 55 NOR_207 XG4 51 50 14 56 AND_207 XG2 56 51 14 58 XOR_207 XG3 56 50 14 57 XOR_207 XA1 4 31 13 8 1 OPAMP_207 XA2 5 30 13 8 9 OPAMP_207 XA3 40 41 13 8 11 OPAMP_207 R1A 27 26 625 R2A 26 25 1.875E3 R3A 25 24 3.125E3 R4AB 24 23 1.25E3 R1B 20 21 625 R2B 21 22 1.875E3 R3B 22 23 3.125E3 R1C 27 41 10000 R2C 41 12 10000 R3C 20 40 10000.2 R4C 40 10 10000 CF3 41 12 3E-12 CF4 40 10 3E-12 CF1 31 1 10E-12 CF2 30 9 10E-12 RO1 1 27 15 RO2 9 20 15 S1 31 27 59 14 SW S2 31 26 57 14 SW S3 31 25 58 14 SW S4 31 24 55 14 SW S5 30 23 55 14 SW S6 30 22 58 14 SW S7 30 21 57 14 SW S8 30 20 59 14 SW GA0 15 14 15 50 -100 GA1 16 14 16 51 -100 RA0 15 50 0.01 RA1 16 51 0.01 IVPS 14 13 0.2E-3 IVMS 8 14 1.5E-3 * .MODEL SW VSWITCH(RON=1 ROFF=1000G VON=0.15 VOFF=0.1) .ENDS * .SUBCKT AND_207 16 15 14 75 D71 71 16 DX D72 71 15 DX D73 71 72 DX D74 72 73 DX Q71 74 73 14 QX Q72 75 74 14 QX R71 80 71 4E3 R72 80 74 8E3 R73 73 76 7E3 R74 80 75 1E3 VBIAS 14 76 2 VSUP 80 14 5 * .MODEL DX D(IS=1E-15) .MODEL QX NPN(IS=800E-18 BF=500) .ENDS * .SUBCKT XOR_207 57 17 14 88 * Logic cell - X-OR Gate R52 57 51 450 R53 57 52 450 Q50 55 51 14 QX Q52 53 52 14 QX R56 80 55 2000 Q51 55 53 14 QX Q53 51 54 14 QX * A1 for switch 3, A0 for switch 2 R54 53 17 450 R55 54 17 450 Q54 88 55 14 QX R57 80 88 2000 VSUP 80 14 2.5 * .MODEL QX NPN(IS=800E-18 BF=500) .ENDS * .SUBCKT NOR_207 16 15 14 85 86 * Logic cell - NOR R61 16 61 450 Q60 85 61 14 QX R62 15 63 450 R60 80 85 3K Q61 85 63 14 QX VSUP 80 14 2 Q62 86 85 14 QX R63 86 80 2000 * * Models .MODEL QX NPN(IS=800E-18 BF=500) .ENDS * * PGA207 operational amplifier "macromodel" subcircuit * created using Parts release 5.2 on 05/30/96 at 07:47 * * connections: non-inverting input * | inverting input * | | positive power supply * | | | negative power supply * | | | | output * | | | | | .SUBCKT OPAMP_207 1 2 3 4 5 * C1 11 12 7.002E-12 C2 6 7 20.00E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 265.3E6 -30E6 30E6 30E6 -30E6 GA 6 0 11 12 754.0E-6 GCM 0 6 10 99 754.0E-12 ISS 10 4 DC 600.0E-6 HLIM 90 0 VLIM 1E3 J1 11 2 10 JX J2 12 1 10 JX R2 6 9 100.0E3 RD1 3 11 1.326E3 RD2 3 12 1.326E3 RO1 8 5 10 RO2 7 99 5 RP 3 4 8.036E3 RSS 10 99 333.3E3 VB 9 0 DC 0 VC 3 53 DC 2.300 VE 54 4 DC 1.500 VLIM 7 8 DC 0 VLP 91 0 DC 10 VLN 0 92 DC 10 * .MODEL DX D(IS=800.0E-18) .MODEL JX NJF(IS=1.000E-12 BETA=947.5E-6 VTO=-1) .ENDS *$ ************************************************************************** * UAF42 OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * SUBCIRCUIT AMP_UAF CREATED USING PARTS RELEASE 4.03 ON 10/17/90 AT 14:54 * UAF42 = 4x AMP_UAF + PRECISION RESISTORS AND CAPS * REV. B 1/3/94/JA CHANGED THE ENTIRE MACRO MODEL FILE TO BE A UAF42 * INSTEAD OF A SINGLE OP AMP CONTAINED IN THE UAF42. * NODE ASSIGNMENTS OF SUBCKT UAF42 ARE THE SAME AS THE DIP * PACKAGE UAF42 PINOUT. * REV.C 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * UAF42 SUB-CIRCUIT * CONNECTIONS: LOW-PASS OUTPUT * | V IN 3 * | | V IN 2 * | | | AUX AMP NON-INVERTING INPUT * | | | | AUX AMP INVERTING INPUT * | | | | | AUX AMP OUTPUT * | | | | | | BAND-PASS OUTPUT * | | | | | | | FREQUENCY ADJ1 * | | | | | | | | NEGATIVE POWER SUPPLY * | | | | | | | | | POSITIVE POWER SUPPLY * | | | | | | | | | | GROUND * | | | | | | | | | | | V IN 1 * | | | | | | | | | | | | HIGH-PASS OUTPUT * | | | | | | | | | | | | | FREQUENCY ADJ2 * | | | | | | | | | | | | | | .SUBCKT UAF42/BB 1 2 3 4 5 6 7 8 9 10 11 12 13 14 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 3 12 10 9 13 AMP_UAF * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 11 8 10 9 7 AMP_UAF * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 11 14 10 9 1 AMP_UAF * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X4 4 5 10 9 6 AMP_UAF * R1 12 1 50K R2 12 13 50K R4 3 7 50K R3A 3 2 100K R3B 3 2 100K C1 7 8 1000P C2 1 14 1000P C3 13 14 1P * .ENDS * * AMP_UAF OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT AMP_UAF 1 2 3 4 5 * C1 11 12 8.938E-12 C2 6 7 15.00E-12 CSS 10 99 8.077E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 99.42E6 -10E6 10E6 10E6 -10E6 GA 6 0 11 12 424.1E-6 GCM 0 6 10 99 6.722E-9 ISS 3 10 DC 300.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 2.358E3 RD2 4 12 2.358E3 RO1 8 5 75 RO2 7 99 75 RP 3 4 20.00E3 RSS 10 99 666.7E3 VB 9 0 DC 0 VC 3 53 DC 3.500 VE 54 4 DC 3.500 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 * .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=299.8E-6 VTO=-1) .ENDS *$ ************************************************************************** * UAF42E OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * SUBCIRCUIT AMP_UAFE CREATED USING PARTS RELEASE 4.03 ON 10/17/90 AT 14:54 * UAF42E = 4x AMP_UAFE + PRECISION RESISTORS AND CAPS * REV.B 3/21/92 BCB added input bias current error correction to AMP_UAFE * REV.C 1/3/94 JA Changed the entire macro model file to be * a UAF42 instead of a single op amp contained in the UAF42 * REV.D 20 JUNE 97 NPA: MOVED LEGAL DISCLAIMER TO BEGINNING OF FILE * * UAF42E SUB-CIRCUIT * CONNECTIONS: LOW-PASS OUTPUT * | V IN 3 * | | V IN 2 * | | | AUX AMP NON-INVERTING INPUT * | | | | AUX AMP INVERTING INPUT * | | | | | AUX AMP OUTPUT * | | | | | | BAND-PASS OUTPUT * | | | | | | | FREQUENCY ADJ1 * | | | | | | | | NEGATIVE POWER SUPPLY * | | | | | | | | | POSITIVE POWER SUPPLY * | | | | | | | | | | GROUND * | | | | | | | | | | | V IN 1 * | | | | | | | | | | | | HIGH-PASS OUTPUT * | | | | | | | | | | | | | FREQUENCY ADJ2 * | | | | | | | | | | | | | | .SUBCKT UAF42E/BB 1 2 3 4 5 6 7 8 9 10 11 12 13 14 * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X1 3 12 10 9 13 AMP_UAFE * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X2 11 8 10 9 7 AMP_UAFE * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X3 11 14 10 9 1 AMP_UAFE * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | X4 4 5 10 9 6 AMP_UAFE * R1 12 13 50K R2 12 1 50K R3 3 7 50K R4A 3 2 100K R4B 3 2 100K C1 7 8 1000P C2 1 14 1000P C3 13 14 1P * .ENDS * * AMP_UAFE OPERATIONAL AMPLIFIER "MACROMODEL" SUBCIRCUIT * "E" IS ENHANCED MODEL * * CONNECTIONS: NON-INVERTING INPUT * | INVERTING INPUT * | | POSITIVE POWER SUPPLY * | | | NEGATIVE POWER SUPPLY * | | | | OUTPUT * | | | | | .SUBCKT AMP_UAFE 1 2 3 4 5 * C1 11 12 8.938E-12 C2 6 7 15.00E-12 CSS 10 99 8.077E-12 DC 5 53 DX DE 54 5 DX DLP 90 91 DX DLN 92 90 DX DP 4 3 DX EGND 99 0 POLY(2) (3,0) (4,0) 0 .5 .5 FB 7 99 POLY(5) VB VC VE VLP VLN 0 99.42E6 -10E6 10E6 10E6 -10E6 GA 6 0 11 12 424.1E-6 GCM 0 6 10 99 6.722E-9 ISS 3 10 DC 300.0E-6 HLIM 90 0 VLIM 1K J1 11 2 10 JX J2 12 1 10 JX G11 2 4 POLY(3) (10,2) (11,2) (4,2) 0 1E-12 1E-12 1E-12 G21 1 4 POLY(3) (10,1) (12,1) (4,1) 0 1E-12 1E-12 1E-12 R2 6 9 100.0E3 RD1 4 11 2.358E3 RD2 4 12 2.358E3 RO1 8 5 75 RO2 7 99 75 * RP 3 4 20.00E3 RSS 10 99 666.7E3 VB 9 0 DC 0 VC 3 53 DC 3.500 VE 54 4 DC 3.500 VLIM 7 8 DC 0 VLP 91 0 DC 25 VLN 0 92 DC 25 **************************** * UAF42 "E" - ENHANCEMENTS **************************** * OUTPUT SUPPLY MIRROR FQ3 0 20 POLY(1) VLIM 0 1 DQ1 20 21 DX DQ2 22 20 DX VQ1 21 0 0 VQ2 22 0 0 FQ1 3 0 POLY(1) VQ1 0.950E-3 1 FQ2 0 4 POLY(1) VQ2 0.950E-3 -1 * QUIESCIENT CURRENT RQ 3 4 1.2E5 * DIFF INPUT CAPACITANCE CDIF 1 2 2.0E-12 * COMMON MODE INPUT CAPACITANCE C1CM 1 99 3.0E-12 C2CM 2 99 3.0E-12 **************************** .MODEL DX D(IS=800.0E-18) .MODEL JX PJF(IS=5.000E-12 BETA=299.8E-6 VTO=-1) .ENDS *$ *---------------------------------------------------------------------------- * VCA610M VOLTAGE CONTROLLED AMPLIFIER "MACROMODEL" SUBCIRCUIT * "M" IS MULTIPLE POLE/ZERO TOPOLOGY * CREATED 6/16/93 BCB * REV.A * * |-------------------------------------------------------------| * | This macro model is being supplied as an aid to | * | circuit designs. While it reflects reasonably close | * | similarity to the actual device in terms of performance, | * | it is not suggested as a replacement for breadboarding. | * | Simulation should be used as a forerunner or a supplement | * | to traditional lab testing. | * | | * | Neither this library nor any part may be copied without | * | the express written consent of Burr-Brown Corporation. | * | | * | The users should carefully note the following factors | * | regarding this model. | * | | * |-------------------------------------------------------------| * * CONNECTIONS: NON-INVERTING INPUT * | GROUND * | | GAIN CONTROL, VC * | | | OUTPUT * | | | | POSITIVE SUPPLY VOLTAGE * | | | | | NEGATIVE SUPPLY VOLTAGE * | | | | | | INVERTING INPUT * | | | | | | | .SUBCKT VCA610M/BB 1 2 3 5 6 7 8 * CONTROL VOLTAGE Q1 7 3 13 P C1 3 7 1E-12 Q2 7 2 13 P I1 6 13 384E-6 Q3 10 11 7 N R2 6 10 2 E1 11 7 POLY(1) (3,0) 0.45 -0.11911 G3 12 0 POLY(1) (10,6) 0 1 R3 12 0 139 C3 12 0 1.145E-9 G1 6 7 POLY(1) (6,10) 13.5102E-3 -0.489 G2 0 7 POLY(1) (6,10) 1.7958E-3 2.939E-3 * INPUT STAGE Q01 20 1 26 N C01 1 0 1E-12 Q02 21 8 26 N C02 8 0 1E-12 R01 20 27 1E3 D01 29 27 DX D03 6 29 DX R02 21 28 1E3 D02 24 28 DX D04 6 24 DX IS 26 7 2.32E-3 * GAIN STAGE 1 R31 31 0 1E6 G31 31 0 POLY(2) (8,1) (12,0) 0 0 0 0 1E-6 0 * GAIN STAGE 2 R41 41 44 20E3 C41 41 44 265.25E-15 G41 41 44 0 31 1E-3 D41 41 43 DX E41 44 43 POLY(1) (3,0) 100.2 14.87 R42 41 45 20E3 C42 41 45 265.25E-15 G42 41 45 0 31 1E-3 D42 42 41 DX E42 42 45 POLY(1) (3,0) 100.2 14.87 E43 44 0 6 0 20 E44 0 45 0 7 20 * OUTPUT STAGE E51 55 0 41 0 50E-3 D53 55 51 DX D54 52 55 DX D55 6 53 DX D56 6 54 DX D57 7 53 DZ D58 7 54 DZ G54 53 7 5 55 50E-3 G53 54 7 55 5 50E-3 V53 51 5 0.1833 V54 5 52 0.1833 G51 5 6 6 55 50E-3 G52 7 5 55 7 50E-3 R53 6 5 20 R54 7 5 20 .MODEL N NPN (IS=1E-12 BF=193) .MODEL P PNP (IS=1E-12 BF=96) .MODEL DX D(IS=1E-15 BV=200) .MODEL DZ D(IS=1E-15 BV=50) .ENDS *$
这是很老的一款器件了,是TI收购的BB公司的产品,官网已经查不到相关资料了 ,也没有spice模型可参考。
建议更换其他产品,或者把您的应用需求说一下,帮您选择替代产品。
