TL071H: How to use it as a voltage follower if the IN+ voltage may be larger than the V+ voltage
Part Number: TL071H
Please help to check the schematic.
I wish to use TL071H as a voltage follower. It's important that the IN+ voltage may be larger than the V+ voltage, Is it OK?
  • 您好,
    这里是中文论坛,您可以使用中文发帖。
    查看 TL071H的绝对最大额定值表格,其输入端信号范围是(VCC–) – 0.5 ~  (VCC+) + 0.5,即最大到V+ +0.5V,如果大于这个范围,很可能会永久性损坏芯片。
    如果想使用TL071H,只能降低输入电压值,否则只能考虑选择其他符合要求的运放。
