Dear Sir or Madam,
I find a problem with the Pspice model of the device (https://www.ti.com.cn/cn/lit/zip/sbam486): when I inserted a gate-resistor, 10 Ohm for example, between pin 5 of the IC and the load capacitors, the simulation cannot converge. As external gate-resistor is common in application designs, how can I solve this problem? I was using the latest version of Pspice for TI in the simulation.
Thanks a lot.
Jerome
