Part Number: INA214
In my design, I want to sense about 10-600mA current use 0.045ohm current-sensing resistor. I am concerned that the output may be nonlinear when detecting small currents, so I want to give negative voltage like -5V to the GND pin and short REF pin to system GND. If INA214 can work normally when using negative voltage with GND pin.
