CCS6用XDS200连接PGA900失败
Other Parts Discussed in Thread: PGA900
软硬连接的参考文档:
        PGAxxxEVM-034 User’s Guide -- SLDU011A
        PGA900 Software Quick Start Guide -- SLDU015A
环境:
        CCS Version: 6.2.0.00050
        XDS200
        WIN10
Test Connection Log:
[Start: Texas Instruments XDS2xx USB Debug Probe_0]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\ADMINI~1\AppData\Local\TEXASI~1\
CCS\CCS620~1.000\0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 560/2xx-class product.
This utility will load the program 'xds2xxu.out'.
The library build date was 'Feb 22 2017'.
The library build time was '16:39:45'.
The library package version is '6.0.579.0'.
The library component version is '35.35.0.0'.
The controller does not use a programmable FPGA.
An error occurred while hard opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-615' (0xfffffd99).
The title is 'SC_ERR_SWD_PROTOCOL'.
The explanation is:
The target failed to see a correctly formatted SWD header. The
connection to the target may be unreliable. Try lowering the
TCLK setting before trying again.
[End: Texas Instruments XDS2xx USB Debug Probe_0]
x 出现错误。请重试或与管理员联系。
