TMDSCSK388 DM388 CSK 官方开发板 初次使用出现重复
Other Parts Discussed in Thread: DM388
硬件:DM388 CSK 官方开发板,为红色核心板+红色底板。
操作:将红色核心板装到红色底板,将摄像头连接到红色底板,网线连接电脑, debug口USB连接到电脑。按guide描述的将拨码开关拨到on一侧,插入附带的SD卡,用5V3A电源供电。
安装串口驱动,打开超级终端,选择115200,打开电源。
按guide描述会打印大一堆启动信息,完成启动后输出流媒体地址,可以通过网络访问网页和流媒体。
实际情况是大部分情况下超级终端会反复打印启动信息一直循环,无法完成启动。无法通过浏览器访问。
小部分情况可以完成启动并给出流媒体地址192.168.1.244,可以通过浏览器进入192.168.1.244并登录,但是video框是黑色没有画面显示。用HDMI线连接电脑显示器也是黑屏。
U-Boot SPL 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46)
Trying to boot from MMC2
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46 -0500)
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
Net: <ethaddr> not set. Reading from E-fuse
cpsw
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Booting from mmc ...
reading uImage
2662320 bytes read in 306 ms (8.3 MiB/s)
reading dm38x-csk.dtb
58698 bytes read in 14 ms (4 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-4.4.12-00004-g82adbbf-dirt
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2662256 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 84000000
Booting using the fdt blob at 0x84000000
Loading Kernel Image ... OK
Loading Device Tree to 844ee000, end 844ff549 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.12-00004-g82adbbf-dirty (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 Mon Feb 13 17:38:26 EST 2017
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: DM38X CSK
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] omap_barrier_reserve_memblock():Reserving DRAM area @ addr = 0x84e00000 size = 1048576 Bytes
[ 0.000000] cma: Reserved 24 MiB at 0x82c00000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] TI81XX: Map 0x84e00000 to 0xfe500000 for dram barrier
[ 0.000000] TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] TI814X ES1.0 (iva neon )
[ 0.000000] powerdomain: gem_pwrdm: voltagedomain dsp does not exist
[ 0.000000] powerdomain: ivahd_pwrdm: voltagedomain iva does not exist
[ 0.000000] powerdomain: hdvpss_pwrdm: voltagedomain dsp does not exist
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19788
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rootwait rw mem=80M vram=4M cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 notifyk.vpssm3_sva=0xBFD00000 earlyprintk
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 46648K/79872K available (4911K kernel code, 260K rwdata, 1708K rodata, 276K init, 241K bss, 8648K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc5800000 - 0xff800000 ( 928 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc067efa4 (6620 kB)
[ 0.000000] .init : 0xc067f000 - 0xc06c4000 ( 276 kB)
[ 0.000000] .data : 0xc06c4000 - 0xc0705308 ( 261 kB)
[ 0.000000] .bss : 0xc0705308 - 0xc0741718 ( 242 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 20000000 Hz
[ 0.000016] sched_clock: 32 bits at 20MHz, resolution 50ns, wraps every 107374182375ns
[ 0.008264] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 95563022313 ns
[ 0.017840] OMAP clocksource: timer1 at 20000000 Hz
[ 0.023136] Console: colour dummy device 80x30
[ 0.027837] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.086910] pid_max: default: 32768 minimum: 301
[ 0.091860] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098772] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.106812] Initializing cgroup subsys io
[ 0.111043] Initializing cgroup subsys memory
[ 0.115667] Initializing cgroup subsys devices
[ 0.120343] Initializing cgroup subsys freezer
[ 0.125024] Initializing cgroup subsys pids
[ 0.129437] CPU: Testing write buffer coherency: ok
[ 0.134890] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.142701] devtmpfs: initialized
[ 0.168778] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.217169] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.229298] pinctrl core: initialized pinctrl subsystem
[ 0.236093] NET: Registered protocol family 16
[ 0.242328] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.255286] OMAP GPIO hardware version 0.1
[ 0.267858] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
[ 0.301524] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.309796] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.323400] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.337067] media: Linux media interface: v0.10
[ 0.341883] Linux video capture interface: v2.00
[ 0.346792] pps_core: LinuxPPS API ver. 1 registered
[ 0.351987] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.361514] PTP clock support registered
[ 0.365656] EDAC MC: Ver: 3.0.0
[ 0.369706] Advanced Linux Sound Architecture Driver Initialized.
[ 0.377106] clocksource: Switched to clocksource timer1
[ 0.394556] NET: Registered protocol family 2
[ 0.399920] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.407228] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.413866] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.420585] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.426689] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.433409] NET: Registered protocol family 1
[ 0.438363] RPC: Registered named UNIX socket transport module.
[ 0.444547] RPC: Registered udp transport module.
[ 0.449507] RPC: Registered tcp transport module.
[ 0.454433] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462480] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.469594] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.486565] NFS: Registering the id_resolver key type
[ 0.491965] Key type id_resolver registered
[ 0.496356] Key type id_legacy registered
[ 0.502257] io scheduler noop registered
[ 0.506395] io scheduler deadline registered
[ 0.511144] io scheduler cfq registered (default)
[ 0.517462] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
[ 0.598583] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.609596] console [ttyS0] disabled
[ 0.613410] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 3000000) is a 8250
[ 0.622369] console [ttyS0] enabled
[ 0.629563] bootconsole [earlycon0] disabled
[ 0.639356] Reference Linux version 4.4.12
[ 0.643653] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script/TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.662198] allocated heap buffer 0xc8000000 of size 0x4000000
[ 0.668101] cmemk initialized
[ 0.678441] loop: module loaded
[ 0.747164] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
[ 0.753301] libphy: 4a100800.mdio: probed
[ 0.758194] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, driver TI DP83867
[ 0.767193] cpsw 4a100000.ethernet: Detected MACID = 7c:66:9d:f8:c5:0c
[ 0.777298] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.807383] mousedev: PS/2 mouse device common for all mice
[ 0.813901] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
[ 0.821381] i2c /dev entries driver
[ 0.825836] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 0.832964] sdhci: Secure Digital Host Controller Interface driver
[ 0.839198] sdhci: Copyright(c) Pierre Ossman
[ 0.962605] omap_hsmmc 48060000.mmc: card claims to support voltages below defined range
[ 0.981625] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 0.987991] mmc0: new high speed SDIO card at address 0001
[ 0.997373] Synopsys Designware Multimedia Card Interface Driver
[ 1.003873] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.010855] notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
[ 1.017012] notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbfd00000
[ 1.028773] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 1.036048] davinci_evm sound: snd_soc_register_card failed (-517)
[ 1.043520] NET: Registered protocol family 10
[ 1.050384] sit: IPv6 over IPv4 tunneling driver
[ 1.055866] NET: Registered protocol family 17
[ 1.060529] Key type dns_resolver registered
[ 1.065063] omap_voltage_late_init: Could not get sys clk.
[ 1.070979] Power Management for TI81XX.
[ 1.080218] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.085401] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.093259] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.099704] nand: Micron MT29F2G16ABAEAWP
[ 1.103736] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.111374] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.116789] 8 ofpart partitions found on MTD device 8000000.nand
[ 1.122844] Creating 8 MTD partitions on "8000000.nand":
[ 1.128203] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.137968] 0x000000020000-0x000000420000 : "NAND.u-boot"
[ 1.146083] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
[ 1.153197] 0x000000440000-0x000000a40000 : "NAND.kernel"
[ 1.162274] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
[ 1.172062] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.187184] mmc1: new high speed SDHC card at address 0007
[ 1.207159] mmcblk0: mmc1:0007 SD16G 14.5 GiB
[ 1.213131] mmcblk0: p1 p2
[ 1.261315] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
[ 1.268689] 0x00000ca80000-0x00000d680000 : "NAND.data"
[ 1.279467] 0x00000d680000-0x000010000000 : "NAND.reserved"
[ 1.343864] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1
[ 1.351568] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.359068] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.365868] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
[ 1.372933] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 1.382351] omap_rtc 480c0000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 1.404179] wlan-en-regulator: disabling
[ 1.408534] ALSA device list:
[ 1.411523] #0: TI81XX-CSK
[ 1.416487] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 10.817665] EXT4-fs (mmcblk0p2): recovery complete
[ 10.831130] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 10.839344] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 10.854564] devtmpfs: mounted
[ 10.858177] Freeing unused kernel memory: 276K (c067f000 - c06c4000)
[ 10.864559] This architecture does not have kernel memory protection.
[ 11.107594] systemd[1]: System time before build time, advancing clock.
[ 11.129633] random: systemd urandom read with 30 bits of entropy available
[ 11.150067] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 11.168853] systemd[1]: Detected architecture arm.
Welcome to [1mArago 2016.05 [0m!
[ 11.199215] systemd[1]: Set hostname to <ti81xx>.
[ 11.484686] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-usecase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 11.634299] systemd[1]: Listening on Journal Socket.
[ [0;32m OK [0m] Listening on Journal Socket.
[ 11.657463] systemd[1]: Reached target Swap.
[ [0;32m OK [0m] Reached target Swap.
[ 11.677544] systemd[1]: Listening on udev Kernel Socket.
[ [0;32m OK [0m] Listening on udev Kernel Socket.
[ 11.697562] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ [0;32m OK [0m] Listening on /dev/initctl Compatibility Named Pipe.
[ 11.727593] systemd[1]: Listening on Syslog Socket.
[ [0;32m OK [0m] Listening on Syslog Socket.
[ 11.747637] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ [0;32m OK [0m] Started Forward Password Requests to Wall Directory Watch.
[ 11.796039] systemd[1]: Reached target Remote File Systems.
[ [0;32m OK [0m] Reached target Remote File Systems.
[ 11.817645] systemd[1]: Listening on Journal Socket (/dev/log).
[ [0;32m OK [0m] Listening on Journal Socket (/dev/log).
[ 11.837908] systemd[1]: Listening on Network Service Netlink Socket.
[ [0;32m OK [0m] Listening on Network Service Netlink Socket.
[ 11.867379] systemd[1]: Reached target Timers.
[ [0;32m OK [0m] Reached target Timers.
[ 11.887672] systemd[1]: Listening on udev Control Socket.
[ [0;32m OK [0m] Listening on udev Control Socket.
[ 11.911335] systemd[1]: Created slice System Slice.
[ [0;32m OK [0m] Created slice System Slice.
[ 11.931272] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.962050] systemd[1]: Starting Journal Service...
[ 12.018819] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ [0;32m OK [0m] Created slice system-serial\x2dgetty.slice.
[ 12.052757] systemd[1]: Mounting Temporary Directory...
[ 12.105276] systemd[1]: Starting udev Coldplug all Devices...
[ 12.161139] systemd[1]: Mounting /var/volatile...
[ 12.207959] systemd[1]: Reached target Slices.
[ [0;32m OK [0m] Reached target Slices.
[ 12.238791] systemd[1]: Created slice system-getty.slice.
[ [0;32m OK [0m] Created slice system-getty.slice.
[ 12.261357] systemd[1]: Starting udev Kernel Device Manager...
[ 12.292479] systemd[1]: Starting Synchronize System and HW clocks...
[ 12.358960] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[0;32m OK [0m] Started Dispatch Password Requests to Console Directory Watch.
S[ 12.390488] systemd[1]: Reached target Paths.
[ [0;32m OK [0m] Reached target Paths.
[ 12.442878] systemd[1]: Mounting /media/ram...
[ 12.524225] systemd[1]: Mounted POSIX Message Queue File System.
[ [0;32m OK [0m] Mounted POSIX Message Queue File System.
[ 12.547642] systemd[1]: Mounted Temporary Directory.
[ [0;32m OK [0m] Mounted Temporary Directory.
[ 12.558219] systemd[1]: Mounted /var/volatile.
[ [0;32m OK [0m] Mounted /var/volatile.
[ 12.577562] systemd[1]: Mounted /media/ram.
[ [0;32m OK [0m] Mounted /media/ram.
[ 12.598068] systemd[1]: Started Journal Service.
[ [0;32m OK [0m] Started Journal Service.
[ [0;32m OK [0m] Started udev Kernel Device Manager.
[ [0;32m OK [0m] Started Synchronize System and HW clocks.
[ [0;32m OK [0m] Started udev Coldplug all Devices.
[ [0;32m OK [0m] Found device /dev/ttyS0.
[ [0;32m OK [0m] Started IPNC RDK use case service.
[ [0;32m OK [0m] Reached target Local File Systems.
[ [0;32m OK [0m] Reached target System Initialization.
[ [0;32m OK [0m] Listening on D-Bus System Message Bus Socket.
[ [0;32m OK [0m] Reached target Sockets.
[ [0;32m OK [0m] Reached target Basic System.
[ [0;32m OK [0m] Started D-Bus System Message Bus.
[ 13.721821] autorun-usecase.sh[113]: numid=1,iface=MIXER,name='PCM Playback Volume'
[ 13.742305] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
[ 13.761883] autorun-usecase.sh[113]: : values=115,115
[ 13.781786] autorun-usecase.sh[113]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
[ 13.801840] autorun-usecase.sh[113]: numid=31,iface=MIXER,name='PGA Capture Volume'
[ 13.821837] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
[ 13.841894] autorun-usecase.sh[113]: : values=72,72
[ 13.861812] autorun-usecase.sh[113]: | dBscale-min=0.00dB,step=0.50dB,mute=0
[ 13.881938] autorun-usecase.sh[113]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
[ 13.901869] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ 13.922123] autorun-usecase.sh[113]: : values=on
Starting Network Service...
[ [0;32m OK [0m] Started Getty on tty1.
[ 13.941849] autorun-usecase.sh[113]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
[ 13.971745] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ 13.991816] [ 14.010388] ubi0: attaching mtd6
Starting uim-sysfs.service...
[ [0;32m OK [0m] Started System Logging Service.
[ [0;32m OK [0m] Started Kernel Logging Service.
[ 14.013756] autorun-usecase.sh[113]: Mount mtd6 and mtd7 partitions
[ [0;32m OK [0m] Started Serial Getty on ttyS0.
[ [0;32m OK [0m] Reached target Login Prompts.
[ [0;32m OK [0m] Started Network Service.
[ 14.251364] net eth0: initializing cpsw version 1.10 (0)
[ 14.256726] net eth0: initialized cpsw ale version 1.3
[ 14.265234] net eth0: phy found : id is : 0x2000a231
[ 14.270303] libphy: PHY not found
[ 14.273727] net eth0: phy "" not found on slave 1, err -19
[ 14.290788] ubi0: scanning is finished
[ 14.355451] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 14.361493] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 14.368426] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 14.375159] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 14.382167] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 14.388128] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 14.395386] ubi0: max/mean erase counter: 9/4, WL threshold: 4096, image sequence number: 2667817441
[ 14.404575] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
[ 14.414236] ubi0: background thread "ubi_bgt0d" started, PID 146
[ 14.469632] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.623628] autorun-usecase.sh[113]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 15.247169] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 151
[ 15.328455] UBIFS (ubi0:0): recovery needed
[ 15.640547] UBIFS (ubi0:0): recovery completed
[ 15.645122] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
[ 15.653132] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 15.663119] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 15.673270] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 15.679763] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID AA21A384-4ECC-4F1F-BA8C-EBB1D35EBD16, small LPT model
[ [0;32m OK [0m] Reached target Network.
Starting Network Name Resolution...
[ [0;32m OK [0m] Started Network Name Resolution.
[ 16.500946] ubi1: attaching mtd7
[ [0;32m OK [0m] Started uim-sysfs.service.
[ 16.757096] ubi1: scanning is finished
Starting telnetd.service...
[ 16.820714] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 16.827036] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 16.834018] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 16.840770] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 16.847779] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 16.853813] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 16.861085] ubi1: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 3383995126
[ 16.870276] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 16.885143] ubi1: background thread "ubi_bgt1d" started, PID 166
[ [0;32m OK [0m] Started telnetd.service.
[ 16.930210] autorun-usecase.sh[113]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
Starting thermal-zone-init.service...
[ [0;32m OK [0m] Started thermal-zone-init.service.
[ [0;32m OK [0m] Reached target Multi-User System.
[ 17.487270] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 181
[ 17.510643] UBIFS (ubi1:0): recovery needed
[ 17.530292] UBIFS (ubi1:0): recovery completed
[ 17.534866] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 17.542889] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 17.552872] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 17.563372] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 17.570041] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID EBC3BFCA-673F-4B1C-B1F6-5BF526D40A9C, small LPT model
[ 18.083727] autorun-usecase.sh[113]: wifi: in STA mode
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
ti81xx login: [ 20.525226] cfg80211: World regulatory domain updated:
[ 20.530513] cfg80211: DFS Master region: unset
[ 20.534893] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 20.544722] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.552782] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.560843] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.568903] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 20.578446] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 20.587988] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 20.596116] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.604173] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 21.043341] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 21.427754] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 21.455000] wlcore: loaded
[ 22.057574] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 22.152609] random: nonblocking pool is initialized
[ 22.163143] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 22.180021] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 24.258038] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 24.265975] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 26.299931] autorun-usecase.sh[113]: SSID: gaff
[ 26.301810] autorun-usecase.sh[113]: SSID: TP-LINK_A394
[ 26.303228] autorun-usecase.sh[113]: SSID: TP-LINK_THW
[ 26.304557] autorun-usecase.sh[113]: SSID: gaff
[ 26.690459] <1>SysLink version : 2.21.02.10
[ 26.690459] SysLink module created on Date:Feb 13 2017 Time:19:16:30
[ 26.701149] <1>Trace enabled
[ 26.704045] <1>Trace SetFailureReason enabled
[ 26.800926] autorun-usecase.sh[113]: /dev/mem opened.
[ 26.802659] autorun-usecase.sh[113]: Phy Addr : 0x48181560 Data : 0x00000002
[ 26.808655] autorun-usecase.sh[113]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 26.815424] autorun-usecase.sh[113]: Phy Addr : 0x48180508 Data : 0x00000302
[ 26.817703] autorun-usecase.sh[113]: Phy Addr : 0x48180520 Data : 0x00000002
[ 26.819384] autorun-usecase.sh[113]: Phy Addr : 0x48180524 Data : 0x00000002
[ 26.821046] autorun-usecase.sh[113]: Phy Addr : 0x48180528 Data : 0x00000002
[ 26.824985] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 26.826696] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 26.828128] autorun-usecase.sh[113]: DDR IOs RX is shutdown
[ 26.829577] autorun-usecase.sh[113]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 27.780585] autorun-usecase.sh[113]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (226) - No such process
[ 27.808288] autorun-usecase.sh[113]: [host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[ 27.812982] autorun-usecase.sh[113]: [host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[ 27.817559] autorun-usecase.sh[113]: [host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[ 27.822386] autorun-usecase.sh[113]: [host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[ 27.888287] autorun-usecase.sh[113]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 28.920304] autorun-usecase.sh[113]: mkfs.fat 3.0.28 (2015-05-16)
[ 28.922395] autorun-usecase.sh[113]: unable to get drive geometry, using default 255/63
[ 28.924660] autorun-usecase.sh[113]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 28.931572] autorun-usecase.sh[113]: hidden sectors 0x0000;
[ 28.933466] autorun-usecase.sh[113]: logical sector size is 512,
[ 28.938464] autorun-usecase.sh[113]: using 0xf8 media descriptor, with 1024 sectors;
[ 28.941677] autorun-usecase.sh[113]: drive number 0x80;
[ 28.945376] autorun-usecase.sh[113]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 28.947922] autorun-usecase.sh[113]: FAT size is 1 sector, and provides 247 clusters.
[ 28.950983] autorun-usecase.sh[113]: There is 1 reserved sector.
[ 28.957692] autorun-usecase.sh[113]: Root directory contains 512 slots and uses 32 sectors.
[ 28.968217] autorun-usecase.sh[113]: Volume ID is 9c1c9f31, no volume label.
[ 29.194351] Mass Storage Function, version: 2009/09/11
[ 29.199625] LUN: removable file: (no medium)
[ 29.244339] LUN: removable file: /dev/sbulla
[ 29.248716] Number of LUNs=1
[ 29.261656] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 29.268741] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 29.275823] g_mass_storage gadget: g_mass_storage ready
[ 29.329087] autorun-usecase.sh[113]: Creat queue id:0
[ 29.331305] autorun-usecase.sh[113]: queue id:0
[ 29.334735] autorun-usecase.sh[113]: Creat queue id:32769
[ 29.340654] autorun-usecase.sh[113]: queue id:32769
[ 29.345381] autorun-usecase.sh[113]: Creat queue id:65538
[ 29.350156] autorun-usecase.sh[113]: queue id:65538
[ 29.353674] autorun-usecase.sh[113]: Creat queue id:98307
[ 29.360549] autorun-usecase.sh[113]: queue id:98307
[ 29.365658] autorun-usecase.sh[113]: queue id:32769
[ 29.463616] autorun-usecase.sh[113]: [host] Attached to slave procId 1.
[ 32.118595] autorun-usecase.sh[113]: [host] Attached to slave procId 0.
[ 32.121486] autorun-usecase.sh[113]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[ 32.292297] autorun-usecase.sh[113]: [host] Started slave procId 1.
[ 32.295445] autorun-usecase.sh[113]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[ 32.372758] autorun-usecase.sh[113]: [host] After Ipc_loadcallback status [0x00000000]
[ 32.374767] autorun-usecase.sh[113]: [host] Started slave procId 0.
[ 32.376461] autorun-usecase.sh[113]: [host] After Ipc_loadcallback status [0x00000000]
[ 32.486674] autorun-usecase.sh[113]: [host] After Ipc_startcallback status [0x00000000]
[ 32.512615] autorun-usecase.sh[113]: [host] After Ipc_startcallback status [0x00000000]
[ 32.576103] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.577879] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 32.579282] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 32.585781] autorun-usecase.sh[113]: [m3vpss ] Received character 's'
[ 32.675982] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.677789] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 32.679171] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 32.694684] autorun-usecase.sh[113]: [m3video] Received character 's'
[ 32.696764] autorun-usecase.sh[113]: queue id:65538
[ 32.704387] autorun-usecase.sh[113]: Creat queue id:131076
[ 32.710151] autorun-usecase.sh[113]: queue id:131076
[ 32.712052] autorun-usecase.sh[113]: CPU is TI812x
[ 32.725169] autorun-usecase.sh[113]: vsenable : 0
[ 32.836664] autorun-usecase.sh[113]: Creat queue id:163845
[ 32.838993] autorun-usecase.sh[113]: queue id:163845
[ 32.842496] autorun-usecase.sh[113]: queue id:65538
[ 33.650155] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.651956] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.653342] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.726641] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.728418] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.729784] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 35.195403] autorun-usecase.sh[113]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 35.197189] autorun-usecase.sh[113]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 35.205463] autorun-usecase.sh[113]: [m3video]
[ 35.224962] autorun-usecase.sh[113]: [m3vpss ] notify_attach rtnVal 0
[ 35.228246] autorun-usecase.sh[113]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 35.231448] autorun-usecase.sh[113]: [m3video]
[ 35.233507] autorun-usecase.sh[113]: [m3video] 38: SYSTEM : System Common Init in progress !!!
[ 35.235195] autorun-usecase.sh[113]: [m3video] 38: SYSTEM: IPC init in progress !!!
[ 35.238381] autorun-usecase.sh[113]: [m3video] 38: SYSTEM: Attaching to [HOST] ...
[ 35.244837] autorun-usecase.sh[113]: [m3video] 88: SYSTEM: Attaching to [HOST] ...
[ 35.246915] autorun-usecase.sh[113]: [m3vpss ] initProxyServer rtnVal 0
[ 35.249715] autorun-usecase.sh[113]: [m3vpss ]
[ 35.251633] autorun-usecase.sh[113]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 35.253250] autorun-usecase.sh[113]: [m3vpss ]
[ 35.254785] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 35.256377] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM: IPC init in progress !!!
[ 35.257820] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM: Attaching to [HOST] ...
[ 35.259367] autorun-usecase.sh[113]: [m3vpss ] 117: SYSTEM: Attaching to [HOST] ...
[ 35.261011] autorun-usecase.sh[113]: [m3video] 118: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 35.262477] autorun-usecase.sh[113]: [m3video] 118: SYSTEM: Attaching to [VPSS-M3] ...
[ 35.263909] autorun-usecase.sh[113]: [m3vpss ] 140: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 35.265399] autorun-usecase.sh[113]: [m3vpss ] 140: SYSTEM: Attaching to [VIDEO-M3] ...
[ 35.266924] autorun-usecase.sh[113]: [m3video] 168: SYSTEM: Attaching to [VPSS-M3] ...
[ 35.268381] autorun-usecase.sh[113]: [m3video] 190: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 35.269912] autorun-usecase.sh[113]: [m3vpss ] 189: SYSTEM: Attaching to [VIDEO-M3] ...
[ 35.272014] autorun-usecase.sh[113]: [m3video] 190: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 35.273664] autorun-usecase.sh[113]: [m3vpss ] 190: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 35.275216] autorun-usecase.sh[113]: [m3vpss ] 190: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 35.276845] autorun-usecase.sh[113]: [m3vpss ] 191: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 35.279556] autorun-usecase.sh[113]: [m3vpss ] 191: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 35.281338] autorun-usecase.sh[113]: [m3vpss ] 193: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 35.283139] autorun-usecase.sh[113]: [m3vpss ] 193: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 35.284762] autorun-usecase.sh[113]: [m3vpss ] 193: SYSTEM: IPC init DONE !!!
[ 35.286572] autorun-usecase.sh[113]: [m3vpss ] 204: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 35.288202] autorun-usecase.sh[113]: [m3vpss ] 205: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 35.290278] autorun-usecase.sh[113]: [m3vpss ] 207: SYSTEM : System Common Init Done !!!
[ 35.291924] autorun-usecase.sh[113]: [m3video] 291: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 35.293859] autorun-usecase.sh[113]: [m3video] 291: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 35.295425] autorun-usecase.sh[113]: [m3video] 292: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 35.297036] autorun-usecase.sh[113]: [m3video] 293: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 35.298880] autorun-usecase.sh[113]: [m3video] 294: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 35.300597] autorun-usecase.sh[113]: [m3video] 294: SYSTEM: IPC init DONE !!!
[ 35.302311] autorun-usecase.sh[113]: [m3video] 305: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 35.303901] autorun-usecase.sh[113]: [m3video] 305: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 35.305439] autorun-usecase.sh[113]: [m3video] 307: SYSTEM : System Common Init Done !!!
[ 35.307369] autorun-usecase.sh[113]: [m3vpss ] 1306: SYSTEM : System VPSS Init in progress !!!
[ 35.308928] autorun-usecase.sh[113]: [m3vpss ] === I2C0/2 Clk is active ===
[ 35.310937] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 35.312515] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 35.314302] autorun-usecase.sh[113]: [m3vpss ] 1326: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 35.315833] autorun-usecase.sh[113]: [m3vpss ] 1326: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 35.317645] autorun-usecase.sh[113]: [m3vpss ] 1326: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 35.319230] autorun-usecase.sh[113]: [m3vpss ] 1329: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 35.321142] autorun-usecase.sh[113]: [m3vpss ] 1329: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 35.322903] autorun-usecase.sh[113]: [m3vpss ] 1329: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 35.324722] autorun-usecase.sh[113]: [m3vpss ] 1342: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 35.658733] autorun-usecase.sh[113]: [m3vpss ] 1343: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 35.660493] autorun-usecase.sh[113]: [m3vpss ] 1343: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 35.662255] autorun-usecase.sh[113]: [m3vpss ] 1345: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 35.663915] autorun-usecase.sh[113]: [m3vpss ] 1346: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 35.665567] autorun-usecase.sh[113]: [m3vpss ] 1346: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[ 35.667160] autorun-usecase.sh[113]: [m3vpss ] 1349: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 35.668898] autorun-usecase.sh[113]: [m3vpss ] 1349: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 35.670577] autorun-usecase.sh[113]: [m3vpss ] 1349: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[ 35.672493] autorun-usecase.sh[113]: [m3vpss ] 1355: SYSTEM: Creating ListMP [VPSS-M3_IPC_ [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 35.674268] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 35.675856] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 35.677584] autorun-usecase.sh[113]: ApproDrvInit: 7
[ 35.679292] autorun-usecase.sh[113]: queue id:163845
[ 37.333705] autorun-usecase.sh[113]: queue id:0
[ 39.234012] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 39.235807] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 39.237234] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 39.238611] autorun-usecase.sh[113]: [m3vpss ] Received character 't'
[ 39.262912] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 39.264699] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 39.266073] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 39.267389] autorun-usecase.sh[113]: [m3video] Received character 't'
[ 39.295705] autorun-usecase.sh[113]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 39.370055] DMA: Module install successful, device major num = 244
[ 39.376394] DRV: Module install successful
[ 39.380569] DRV: Module built on Feb 13 2017 19:26:20
[ 39.452352]
[ 39.452352] soc_is_dm38x
[ 39.553357] HDMI W1 rev 4.0
[ 39.556208] HDMI CEC Spec version 1.2
[ 39.556791] autorun-usecase.sh[113]: ApproDrvInit: 3
[ 39.674895] autorun-usecase.sh[113]: queue id:163845
[ 39.937122] I2C No Ack
[ 39.939623] HDMI failed to read E-EDID
[ 40.423793] autorun-usecase.sh[113]: [host]
[ 40.427223] autorun-usecase.sh[113]: [host] ORG 0x46c00524: 0
[ 40.429180] autorun-usecase.sh[113]: [host] NEW 0x46c00524: 2
[ 40.430936] autorun-usecase.sh[113]: [host]
[ 40.432710] autorun-usecase.sh[113]: [host] Application Start Completed
[ 40.534270] autorun-usecase.sh[113]: [host] 0: SYSTEM: System Common Init in progress !!!
[ 40.536402] autorun-usecase.sh[113]: [host] 0: SYSTEM: IPC init in progress !!!
[ 40.539547] autorun-usecase.sh[113]: [host] 11: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 40.544087] autorun-usecase.sh[113]: [host] 11: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!! [ 40.585321] DMA: ChannelID allocated:4
[ 40.548794] autorun-usecase.sh[113]: [host] 11: SYSTEM: CPU [VPSS-M3] syslink proc ID is [1] !!!
[ 40.553532] autorun-usecase.sh[113]: [host] 11: SYSTEM: CPU [HOST] syslink proc I[ 40.604081] DMA: ChannelID allocated:5
D is [2] !!!
[ 40.567190] autorun-usecase.sh[113]: [host] 11: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 40.574984] autorun-usecase.sh[113]: [host] 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[ 40.583452] autorun-usecase.sh[113]: [host] 13: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[ 40.595494] autorun-usecase.sh[113]: [host] 13: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 40.599407] autorun-usecase.sh[113]: [host] 13: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 40.602575] autorun-usecase.sh[113]: [host] 15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 40.607603] autorun-usecase.sh[113]: [host] 15: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 40.611068] autorun-usecase.sh[113]: [host] 15: SYSTEM: IPC init DONE !!!
[ 40.614381] autorun-usecase.sh[113]: [host] 17: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[ 40.618382] autorun-usecase.sh[113]: [host] 17: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[ 40.620311] autorun-usecase.sh[113]: [host] 18: SYSTEM: ListElem Shared Addr = 0xb55f3580
[ 40.622139] autorun-usecase.sh[113]: [host] 18: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[ 40.624014] autorun-usecase.sh[113]: [host] 18: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[ 40.625760] autorun-usecase.sh[113]: [host] 19: SYSTEM: ListElem Shared Addr = 0xb560d200
[ 40.627423] autorun-usecase.sh[113]: [host] 22: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[ 40.629168] autorun-usecase.sh[113]: [host] 22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[ 40.630874] autorun-usecase.sh[113]: [host] 22: SYSTEM: ListElem Shared Addr = 0xb5626e80
[ 40.632560] autorun-usecase.sh[113]: [host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[ 40.634218] autorun-usecase.sh[113]: [host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[ 40.635916] autorun-usecase.sh[113]: [host] 24: SYSTEM: ListElem Shared Addr = 0xb5646880
[ 40.637541] autorun-usecase.sh[113]: [host] 25: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[ 40.639264] autorun-usecase.sh[113]: [host] 25: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[ 40.640938] autorun-usecase.sh[113]: [host] 25: SYSTEM: ListElem Shared Addr = 0xb5666280
[ 40.642596] autorun-usecase.sh[113]: [host] 28: SYSTEM: System Common Init Done !!!
[ 40.644232] autorun-usecase.sh[113]: [host] Vsys_allocBuf - addr = 0xa739c000,size = 65011712
[ 40.645889] autorun-usecase.sh[113]: ##########pInfo->totalsize 63897600
[ 40.648638] autorun-usecase.sh[113]: queue id:0
[ 40.650419] autorun-usecase.sh[113]: queue id:32769
[ 40.652669] autorun-usecase.sh[113]: [host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[ 40.654340] autorun-usecase.sh[113]: [host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[ 40.656082] autorun-usecase.sh[113]: [host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[ 40.657719] autorun-usecase.sh[113]: [host] Vsys_allocBuf - addr = 0xb6f2f000,size = 33603
[ 40.659438] autorun-usecase.sh[113]: [host] DCC buffer allocated for size 33603
[ 40.661185] autorun-usecase.sh[113]: [host] DCC Default File Intialization Done
[ 40.662787] autorun-usecase.sh[113]: [host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[ 40.688238] autorun-usecase.sh[113]: [host]
[ 40.690554] autorun-usecase.sh[113]: ********** FULL FEATURE USECASE ********
[ 40.692268] autorun-usecase.sh[113]: [host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[ 40.694065] autorun-usecase.sh[113]: [host] 160: MCFW : CPU Revision [ES1.0] !!!
[ 40.695790] autorun-usecase.sh[113]: [host] 160: MCFW : Detected [UNKNOWN] Board !!!
[ 40.697476] autorun-usecase.sh[113]: [host] 160: MCFW : Base Board Revision [REV A] !!!
[ 40.719289] autorun-usecase.sh[113]: OUT_29] in region 0 ...
[ 40.721244] autorun-usecase.sh[113]: [m3vpss ] 1356: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 40.723096] autorun-usecase.sh[113]: [m3vpss ] 1356: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[ 40.724800] autorun-usecase.sh[113]: [m3vpss ] 1358: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 40.726763] autorun-usecase.sh[113]: [m3vpss ] 1359: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 40.728564] autorun-usecase.sh[113]: [m3vpss ] 1359: SYSTEM: ListElem Shared Addr = 0xbea03600
[ 40.730411] autorun-usecase.sh[113]: [m3vpss ] 1361: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 40.732139] autorun-usecase.sh[113]: [m3vpss ] 1361: SYSTEM : FVID2 Init in progress !!!
[ 40.733825] autorun-usecase.sh[113]: [m3video] 1407: SYSTEM : System Video Init in progress !!!
[ 40.735522] autorun-usecase.sh[113]: [m3video] 1407: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 40.737152] autorun-usecase.sh[113]: [m3video] 1408: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 40.738871] autorun-usecase.sh[113]: [m3video] 1408: SYSTEM: ListElem Shared Addr = 0xbea1d280
[ 40.740702] autorun-usecase.sh[113]: [m3video] 1410: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 40.742413] autorun-usecase.sh[113]: [m3video] 1411: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 40.744054] autorun-usecase.sh[113]: [m3video] 1411: SYSTEM: ListElem Shared Addr = 0xbea20780
[ 40.745776] autorun-usecase.sh[113]: [m3video] 1421: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 40.747464] autorun-usecase.sh[113]: [m3video] 1421: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 41.082056] autorun-usecase.sh[113]: [m3video] 1421: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 41.083738] autorun-usecase.sh[113]: [m3video] 1424: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 41.085409] autorun-usecase.sh[113]: [m3vpss ] 1432: SYSTEM : FVID2 Init in progress DONE !!!
[ 41.087152] autorun-usecase.sh[113]: [m3video] 1424: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 41.088775] autorun-usecase.sh[113]: [m3vpss ] 1433: SYSTEM : Device Init in progress !!!
[ 41.090514] autorun-usecase.sh[113]: [m3video] 1424: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 41.092237] autorun-usecase.sh[113]: [m3vpss ] Iss_init called !!!!!!
[ 41.093929] autorun-usecase.sh[113]: [m3video] 1426: HDVICP: Doing PRCM for IVAHD[0] ...
[ 41.095524] autorun-usecase.sh[113]: [m3video] 1427: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 41.097228] autorun-usecase.sh[113]: [m3video] 1428: SYSTEM : Initializing Links !!!
[ 41.097794] autorun-usecase.sh[113]: [m3video] 1428: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 41.098341] autorun-usecase.sh[113]: [m3vpss ] CPIS_init DONE !!!!!!
[ 41.098827] autorun-usecase.sh[113]: [m3video] 1428: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 41.099293] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 41.100074] autorun-usecase.sh[113]: [m3video] 1428: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 41.100691] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 41.101183] autorun-usecase.sh[113]: [m3video] 1429: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 41.101694] autorun-usecase.sh[113]: [m3video] 1429: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 41.102199] autorun-usecase.sh[113]: [m3video] 1430: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 41.102703] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_init()
[ 41.103228] autorun-usecase.sh[113]: [m3video] 1489: SYSTEM : Initializing Links ... DONE !!!
[ 41.103689] autorun-usecase.sh[113]: [m3video] 1489: SYSTEM : System Video Init Done !!!
[ 41.104213] autorun-usecase.sh[113]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 41.104666] autorun-usecase.sh[113]: [m3vpss ] 1627: SYSTEM : Device Init in progress DONE !!!
[ 41.105170] autorun-usecase.sh[113]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 41.105620] autorun-usecase.sh[113]: [m3vpss ] 6736: SYSTEM : System VPSS Init Done !!!
[ 41.106109] autorun-usecase.sh[113]: [m3vpss ] 6736: UTILS: DMA: HWI Create for INT62 !!!
[ 41.106563] autorun-usecase.sh[113]: [m3vpss ] 6737: SYSTEM : Initializing Links !!!
[ 41.107011] autorun-usecase.sh[113]: [m3vpss ] 6737: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 41.107531] autorun-usecase.sh[113]: [m3vpss ] 6737: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 41.107978] autorun-usecase.sh[113]: [m3vpss ] 6737: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 41.108503] autorun-usecase.sh[113]: [m3vpss ] 6738: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 41.108962] autorun-usecase.sh[113]: [m3vpss ] 6738: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 41.109453] autorun-usecase.sh[113]: [m3vpss ] 6868: SYSTEM : Initializing Links ... DONE !!!
[ 41.109901] autorun-usecase.sh[113]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 41.110402] autorun-usecase.sh[113]: [m3vpss ] VPS_DCTRL_INST_0
[ 41.110915] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 41.111373] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 41.111901] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 41.112407] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 41.444452] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 41.445449] autorun-usecase.sh[113]: [m3vpss ] HDCOMPCLK
[ 41.446108] autorun-usecase.sh[113]: [m3vpss ] 8259: CAMERA: Create in progress !!!
[ 41.446808] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 41.447445] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 41.448028] autorun-usecase.sh[113]: [m3vpss ] 8259: CAMERA: VIP0 PortA camera mode is [ 8-bit,[ 41.537983] DMA: ChannelID allocated:6
Non-mux Embedded Sync] !!!
[ 41.448889] autorun-usecase.sh[1[ 41.543175] DMA: ChannelID allocated:7
13]: [m3vpss ] 8260: CAMERA: VIP 0: VID DEC 268436737 (0x10): queue id:0
[ 41.536972] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[ 41.537821] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[ 41.621366] DMA: ChannelID allocated:12
[ 41.608693] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[ 41.850712] autorun-usecase.sh[113]: 0002:20202020:20202020, AUD_STATUS 538976288
[ 41.851603] autorun-usecase.sh[113]: [m3vpss ] Iss_captCreate:1661
[ 41.852267] autorun-usecase.sh[113]: [m3vpss ] 8473: CAMERA: Create Done !!!
[ 41.852919] autorun-usecase.sh[113]: [m3vpss ] 8563: CAMERA: Detect video in progress !!!
[ 41.853500] autorun-usecase.sh[113]: [m3vpss ] 8563: CAMERA: Detect video Done !!!
[ 41.854121] autorun-usecase.sh[113]: [m3vpss ] 8636: DUP : Create Done !!!
[ 41.854691] autorun-usecase.sh[113]: [m3vpss ] 8636: IPC_OUT_M3 : Create in progress !!!
[ 41.855320] autorun-usecase.sh[113]: [m3video] 8638: IPC_IN_M3 : Create in progress !!!
[ 41.855882] autorun-usecase.sh[113]: [m3vpss ] 8638: IPC_OUT_M3 : Create Done !!!
[ 41.856545] autorun-usecase.sh[113]: [m3video] 8639: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 41.857154] autorun-usecase.sh[113]: [m3vpss ] DCC server task running
[ 41.857716] autorun-usecase.sh[113]: [m3video] 8639: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 41.858358] autorun-usecase.sh[113]: [m3video] 8642: IPC_IN_M3 : Create Done !!!
[ 41.858914] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_tskMain()
[ 41.859527] autorun-usecase.sh[113]: [m3video] inChInfo->width = 1920
[ 41.860135] autorun-usecase.sh[113]: [m3video] inChInfo->height = 1080
[ 41.860819] autorun-usecase.sh[113]: [m3video] inChInfo->pitch[0] = 1984
[ 41.861392] autorun-usecase.sh[113]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 41.862023] autorun-usecase.sh[113]: [m3video] [MCTNF] startX = 0
[ 41.862678] autorun-usecase.sh[113]: [m3vpss ] 8825: IPC_IN_M3 : Create in progress !!!
[ 41.863260] autorun-usecase.sh[113]: [m3video] [MCTNF] startY = 0
[ 41.863908] autorun-usecase.sh[113]: [m3vpss ] 8825: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 41.864467] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->width = 1920
[ 41.865103] autorun-usecase.sh[113]: [m3vpss ] 8826: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 41.865667] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->height = 1080
[ 41.866293] autorun-usecase.sh[113]: [m3vpss ] 8827: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 41.866897] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 41.867463] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 41.868060] autorun-usecase.sh[113]: [m3video] 8823: IPC_OUT_M3 : Create in progress !!!
[ 41.868618] autorun-usecase.sh[113]: [m3video] 8824: IPC_OUT_M3 : Create Done !!!
[ 41.869288] autorun-usecase.sh[113]: [m3vpss ] 8829: IPC_IN_M3 : Create Done !!!
[ 41.869859] autorun-usecase.sh[113]: [m3vpss ] 8763: VNF:
[ 41.870602] autorun-usecase.sh[113]: [m3vpss ] Create in progress ... !!!
[ 41.871718] autorun-usecase.sh[113]: [m3vpss ] 8764: VNF:
[ 41.872608] autorun-usecase.sh[113]: [m3vpss ] Input Channel CH0 of 1920 x 1080, pitch = (1984, 1984) [0,0][PROGRESSIVE] [7] ...
[ 41.873347] autorun-usecase.sh[113]: [m3vpss ] 8765: VNF:
[ 41.873999] autorun-usecase.sh[113]: [m3vpss ] [VNF] eOperateMode=7 [6-TNF3,7-NSF2]chVnfCreateParams->ulStartX = -16 chVnfCreateParams->ulStartY = -18 chVnfCreateParams->ulInputStride = 1984 chVnfCreateParams->ulInputWidth=1952,chVnfCreateParams->ulInputHeight=1112
[ 41.874629] autorun-usecase.sh[113]: [m3vpss ] 8934: VNF:
[ 41.875374] autorun-usecase.sh[113]: [m3vpss ] [VNF] outChInfo->StartX = 0 outChInfo->startY = 0 outChInfo->pitch[0] = 1920 outChInfo->width=1920,outChInfo->height=1080
[ 41.875987] autorun-usecase.sh[113]: [m3vpss ] 8936: VNF:
[ 41.876642] autorun-usecase.sh[113]: [m3vpss ] Create ... DONE !!!
[ 41.877295] autorun-usecase.sh[113]: [m3vpss ] 9002: NSF: Create in progress !!!
[ 41.877889] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 41.878510] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 41.879076] autorun-usecase.sh[113]: [m3vpss ] 9128: NSF: Create Done !!!
[ 41.879689] autorun-usecase.sh[113]: [m3vpss ] 9128: Mux : Creating... !!!
[ 41.880334] autorun-usecase.sh[113]: [m3vpss ] 9130: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[ 41.881028] autorun-usecase.sh[113]: [m3vpss ] 9130: Mux : Create Done !!!
[ 42.216713] autorun-usecase.sh[113]: [m3vpss ] 9137: DUP : Create Done !!!
[ 42.217461] autorun-usecase.sh[113]: [m3vpss ] 9144: DUP : Create Done !!!
[ 42.218145] autorun-usecase.sh[113]: [m3vpss ] 9144: Mux : Creating... !!!
[ 42.218879] autorun-usecase.sh[113]: [m3vpss ] 9146: Mux : Create Done !!!
[ 42.219585] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[ 42.220499] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 36
[ 42.221255] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[ 42.221973] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 37
[ 42.222606] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[ 42.223317] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 38
[ 42.224055] autorun-usecase.sh[113]: [m3vpss ] 9156: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[ 42.224684] autorun-usecase.sh[113]: [m3vpss ] 9156: SWOSD : Create Done !!!
[ 42.225473] autorun-usecase.sh[113]: [m3vpss ] 9229: DUP : Create Done !!!
[ 42.226216] autorun-usecase.sh[113]: [m3vpss ] 9230: SCLR: Create in progress !!!
[ 42.226906] autorun-usecase.sh[113]: [m3vpss ] 9235: SCLR : Loading Up-scaling Co-effs ...
[ 42.227614] autorun-usecase.sh[113]: [m3vpss ] 9235: SCLR : Co-effs Loading ... DONE !!!
[ 42.228877] autorun-usecase.sh[113]: [m3video] 9248: IPC_IN_M3 : Create in progress !!!
[ 42.229688] autorun-usecase.sh[113]: [m3video] 9249: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[ 42.230440] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:0 USED:64
[ 42.231182] autorun-usecase.sh[113]: [m3video] 9249: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[ 42.231896] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:1 USED:5952
[ 42.232571] autorun-usecase.sh[113]: [m3video] 9252: IPC_IN_M3 : Create Done !!!
[ 42.233295] autorun-usecase.sh[113]: [m3vpss ] 9235: SCLR: Create Done !!!
[ 42.234031] autorun-usecase.sh[113]: [m3video] 9252: ENCODE: Create in progress ... !!!
[ 42.234725] autorun-usecase.sh[113]: [m3vpss ] 9180: FD : Alg Create Done !!!
[ 42.235443] autorun-usecase.sh[113]: [m3vpss ] 9180: FD : Create Done !!!
[ 42.236249] autorun-usecase.sh[113]: [m3vpss ] 9246: IPC_OUT_M3 : Create in progress !!!
[ 42.236901] autorun-usecase.sh[113]: [m3vpss ] 9248: IPC_OUT_M3 : Create Done !!!
[ 42.237623] autorun-usecase.sh[113]: [m3video] 9378: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 42.238371] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 42.239397] autorun-usecase.sh[113]: [m3video] 9463: ENCODE: Creating
[ 42.241119] autorun-usecase.sh[113]: [host] IpcBitsInLink_tskMain:Entered
[ 42.241851] autorun-usecase.sh[113]: [host] 1393: IPC_BITS_IN : Create in progress !!!
[ 42.244744] autorun-usecase.sh[113]: [host] 1393: IPC_BITS_IN : ListMPOpen start !!!
[ 42.245821] autorun-usecase.sh[113]: [host] 1393: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[ 42.246640] autorun-usecase.sh[113]: [host] 1393: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[ 42.247322] autorun-usecase.sh[113]: [host] 1394: IPC_BITS_IN : ListMPOpen done !!!
[ 42.248056] autorun-usecase.sh[113]: [host] 1394: IPC_BITS_IN : System_linkGetInfo done !!!
[ 42.248713] autorun-usecase.sh[113]: [host] 1395: IPC_BITS_IN : Create Done !!!
[ 42.249365] autorun-usecase.sh[113]: [host] USECASE SETUP DONE
[ 42.250108] autorun-usecase.sh[113]: [host]
[ 42.250735] autorun-usecase.sh[113]: Application Run Completed
[ 42.251575] autorun-usecase.sh[113]: [host] ITT server task running !!!
[ 42.252494] autorun-usecase.sh[113]: [host]
[ 42.253325] autorun-usecase.sh[113]: ITT ittServer_run
[ 42.254011] autorun-usecase.sh[113]: [host] ITT Server Message initialization successful
[ 42.254928] autorun-usecase.sh[113]: [host]
[ 42.255677] autorun-usecase.sh[113]: ITT capture task created
[ 42.256321] autorun-usecase.sh[113]: [host] DCC server Message ques is open succefully
[ 42.257023] autorun-usecase.sh[113]: [host] Setting cmd <1> in message <b549fc00>
[ 42.591263] autorun-usecase.sh[113]: [host] Posting message <b549fc00> in QId <10002>
[ 42.592373] autorun-usecase.sh[113]: [host] Response from M3 is : 1
[ 42.593204] autorun-usecase.sh[113]: [host] Response from M3 is : 1
[ 42.593884] autorun-usecase.sh[113]: [host] Default parameters were sent sucessfully
[ 42.594630] autorun-usecase.sh[113]: [host] Server Socket created with ID <22>
[ 45.454110] autorun-usecase.sh[113]: Venc not supported!!
[ 45.455219] autorun-usecase.sh[113]: [host] VNF MESSAGE RECIEVED: (Enable:0) (Mode:5) (Strength:0) (EnableTNF:0) (EnableSNF:0)
[ 45.459436] autorun-usecase.sh[113]: [host]
[ 45.474900] autorun-usecase.sh[113]: Channel Selected: 0
[ 45.476216] autorun-usecase.sh[113]: [host]
[ 45.484220] autorun-usecase.sh[113]: Channel Selected: 0,rate control = 0
[ 45.485033] autorun-usecase.sh[113]: [host]
[ 45.485580] autorun-usecase.sh[113]: ========== Stream FrameRate1 = 30 =================
[ 45.489250] autorun-usecase.sh[113]: [host]
[ 45.491443] autorun-usecase.sh[113]: Channel Selected: 0
[ 45.493801] autorun-usecase.sh[113]: [host]
[ 45.499288] autorun-usecase.sh[113]: Channel Selected: 0
[ 45.500319] autorun-usecase.sh[113]: [host]
[ 45.501740] autorun-usecase.sh[113]: Channel Selected: 0
[ 45.502809] autorun-usecase.sh[113]: [host]
[ 45.504148] autorun-usecase.sh[113]: Channel Selected: 0,packet size = 100
[ 45.513246] autorun-usecase.sh[113]: [host]
[ 45.516421] autorun-usecase.sh[113]: Channel Selected: 0,encPreset = 0
[ 45.523427] autorun-usecase.sh[113]: [host]
[ 45.525062] autorun-usecase.sh[113]: Channel Selected: 0,enable = 0
[ 45.526003] autorun-usecase.sh[113]: [host]
[ 45.531553] autorun-usecase.sh[113]: Channel Selected: 1
[ 45.534151] autorun-usecase.sh[113]: [host]
[ 45.539840] autorun-usecase.sh[113]: Channel Selected: 1,rate control = 0
[ 45.544424] autorun-usecase.sh[113]: [host]
[ 45.545635] autorun-usecase.sh[113]: Channel Selected: 1
[ 45.546422] autorun-usecase.sh[113]: [host]
[ 45.547072] autorun-usecase.sh[113]: Channel Selected: 1
[ 45.555205] autorun-usecase.sh[113]: [host]
[ 45.556659] autorun-usecase.sh[113]: Channel Selected: 1
[ 45.560178] autorun-usecase.sh[113]: [host]
[ 45.561420] autorun-usecase.sh[113]: Channel Selected: 1,packet size = 100
[ 45.564297] autorun-usecase.sh[113]: [host]
[ 45.568036] autorun-usecase.sh[113]: Channel Selected: 1,encPreset = 0
[ 45.570955] autorun-usecase.sh[113]: [host]
[ 45.572748] autorun-usecase.sh[113]: Channel Selected: 1,enable = 0
[ 45.573567] autorun-usecase.sh[113]: [host]
[ 45.574556] autorun-usecase.sh[113]: Channel Selected: 2
[ 45.575538] autorun-usecase.sh[113]: [host]
[ 45.576208] autorun-usecase.sh[113]: Channel Selected: 2,rate control = 2
[ 45.576824] autorun-usecase.sh[113]: [host] MJPEG in Rate Control OFF Mode
[ 45.686783] autorun-usecase.
reading u-boot.img
reading u-boot.img
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
cpsw
reading uImage
2662320 bytes read in 304 ms (8.4 MiB/s)
Starting kernel ...
[ 0.008262] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 95563022313 ns
[ 0.017837] OMAP clocksource: timer1 at 20000000 Hz
[ 0.023133] Console: colour dummy device 80x30
[ 0.027832] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.086903] pid_max: default: 32768 minimum: 301
[ 0.091851] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098764] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.106804] Initializing cgroup subsys io
[ 0.111036] Initializing cgroup subsys memory
[ 0.115660] Initializing cgroup subsys devices
[ 0.120335] Initializing cgroup subsys freezer
[ 0.125015] Initializing cgroup subsys pids
[ 0.129429] CPU: Testing write buffer coherency: ok
[ 0.134883] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.142691] devtmpfs: initialized
[ 0.168773] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.217155] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.229284] pinctrl core: initialized pinctrl subsystem
[ 0.236076] NET: Registered protocol family 16
[ 0.242315] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.255280] OMAP GPIO hardware version 0.1
[ 0.267852] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
[ 0.301528] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.309802] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.323406] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.337078] media: Linux media interface: v0.10
[ 0.341894] Linux video capture interface: v2.00
[ 0.346803] pps_core: LinuxPPS API ver. 1 registered
[ 0.351998] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.361525] PTP clock support registered
[ 0.365667] EDAC MC: Ver: 3.0.0
[ 0.369716] Advanced Linux Sound Architecture Driver Initialized.
[ 0.377119] clocksource: Switched to clocksource timer1
[ 0.394548] NET: Registered protocol family 2
[ 0.399923] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.407234] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.413873] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.420591] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.426695] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.433414] NET: Registered protocol family 1
[ 0.438365] RPC: Registered named UNIX socket transport module.
[ 0.444548] RPC: Registered udp transport module.
[ 0.449505] RPC: Registered tcp transport module.
[ 0.454431] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462478] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.469581] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.486563] NFS: Registering the id_resolver key type
[ 0.491959] Key type id_resolver registered
[ 0.496351] Key type id_legacy registered
[ 0.502249] io scheduler noop registered
[ 0.506386] io scheduler deadline registered
[ 0.511139] io scheduler cfq registered (default)
[ 0.517464] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
[ 0.598616] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.609623] console [ttyS0] disabled
[ 0.613438] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 3000000) is a 8250
[ 0.622397] console [ttyS0] enabled
[ 0.629592] bootconsole [earlycon0] disabled
[ 0.639395] Reference Linux version 4.4.12
[ 0.643691] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script/TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.662239] allocated heap buffer 0xc8000000 of size 0x4000000
[ 0.668142] cmemk initialized
[ 0.678534] loop: module loaded
[ 0.747179] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
[ 0.753315] libphy: 4a100800.mdio: probed
[ 0.758219] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, driver TI DP83867
[ 0.767212] cpsw 4a100000.ethernet: Detected MACID = 7c:66:9d:f8:c5:0c
[ 0.777304] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.807393] mousedev: PS/2 mouse device common for all mice
[ 0.813502] omap_rtc 480c0000.rtc: already running
[ 0.818772] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
[ 0.826202] i2c /dev entries driver
[ 0.830703] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 0.837829] sdhci: Secure Digital Host Controller Interface driver
[ 0.844037] sdhci: Copyright(c) Pierre Ossman
[ 0.972622] omap_hsmmc 48060000.mmc: card claims to support voltages below defined range
[ 0.991760] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 0.998010] mmc0: new high speed SDIO card at address 0001
[ 1.007384] Synopsys Designware Multimedia Card Interface Driver
[ 1.013884] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.020868] notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
[ 1.027026] notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbfd00000
[ 1.038776] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 1.046052] davinci_evm sound: snd_soc_register_card failed (-517)
[ 1.053522] NET: Registered protocol family 10
[ 1.060393] sit: IPv6 over IPv4 tunneling driver
[ 1.065873] NET: Registered protocol family 17
[ 1.070535] Key type dns_resolver registered
[ 1.075071] omap_voltage_late_init: Could not get sys clk.
[ 1.080978] Power Management for TI81XX.
[ 1.090154] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.095340] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.102963] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.109451] nand: Micron MT29F2G16ABAEAWP
[ 1.113485] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.121121] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.126536] 8 ofpart partitions found on MTD device 8000000.nand
[ 1.132591] Creating 8 MTD partitions on "8000000.nand":
[ 1.137949] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.147731] 0x000000020000-0x000000420000 : "NAND.u-boot"
[ 1.155931] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
[ 1.163046] 0x000000440000-0x000000a40000 : "NAND.kernel"
[ 1.172140] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
[ 1.181923] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.197196] mmc1: new high speed SDHC card at address 0007
[ 1.217176] mmcblk0: mmc1:0007 SD16G 14.5 GiB
[ 1.223148] mmcblk0: p1 p2
[ 1.271146] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
[ 1.278524] 0x00000ca80000-0x00000d680000 : "NAND.data"
[ 1.289297] 0x00000d680000-0x000010000000 : "NAND.reserved"
[ 1.353991] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1
[ 1.361693] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.369187] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.375983] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
[ 1.383054] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 1.392470] omap_rtc 480c0000.rtc: setting system clock to 2016-12-05 15:40:08 UTC (1480952408)
[ 1.414374] wlan-en-regulator: disabling
[ 1.418730] ALSA device list:
[ 1.421718] #0: TI81XX-CSK
[ 1.426694] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 7.914956] EXT4-fs (mmcblk0p2): recovery complete
[ 7.928374] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 7.936562] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 7.951769] devtmpfs: mounted
[ 7.955352] Freeing unused kernel memory: 276K (c067f000 - c06c4000)
[ 7.961765] This architecture does not have kernel memory protection.
[ 8.220971] random: systemd urandom read with 28 bits of entropy available
[ 8.241690] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 8.260501] systemd[1]: Detected architecture arm.
[ 8.289220] systemd[1]: Set hostname to <ti81xx>.
[ 8.570678] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-usecase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 8.721344] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 8.747735] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ [0;32m OK [0m] Started Dispatch Password Requests to Console Directory Watch.
[ 8.777436] systemd[1]: Reached target Swap.
[ 8.797378] systemd[1]: Reached target Remote File Systems.
[ 8.817707] systemd[1]: Listening on Journal Socket.
[ 8.837603] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.857541] systemd[1]: Listening on Syslog Socket.
[ 8.896217] systemd[1]: Listening on udev Kernel Socket.
[ 8.917974] systemd[1]: Listening on Network Service Netlink Socket.
[ 8.947677] systemd[1]: Listening on udev Control Socket.
[ 8.971304] systemd[1]: Created slice System Slice.
[ 8.991140] systemd[1]: Starting Synchronize System and HW clocks...
[ 9.017483] systemd[1]: Reached target Slices.
[ 9.059485] systemd[1]: Mounting Temporary Directory...
[ 9.092476] systemd[1]: Mounting /var/volatile...
[ 9.151451] systemd[1]: Starting Journal Service...
[ 9.171247] systemd[1]: Created slice system-getty.slice.
[ 9.211454] systemd[1]: Mounting POSIX Message Queue File System...
[ 9.264978] systemd[1]: Starting udev Coldplug all Devices...
[ 9.332806] systemd[1]: Mounting /media/ram...
[ 9.376825] systemd[1]: Starting udev Kernel Device Manager...
[ 9.439437] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 9.468496] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 9.497529] systemd[1]: Reached target Paths.
[ 9.517527] systemd[1]: Reached target Timers.
[ 9.569026] systemd[1]: Mounted POSIX Message Queue File System.
[ 9.597675] systemd[1]: Mounted Temporary Directory.
[ 9.617702] systemd[1]: Mounted /var/volatile.
[ 9.637633] systemd[1]: Mounted /media/ram.
[ 9.658100] systemd[1]: Started Journal Service.
[ 10.798301] autorun-usecase.sh[114]: numid=1,iface=MIXER,name='PCM Playback Volume'
[ 10.832065] autorun-usecase.sh[114]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
[ 10.851879] autorun-usecase.sh[114]: : values=115,115
[ 10.871808] autorun-usecase.sh[114]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
[ 10.891909] autorun-usecase.sh[114]: numid=31,iface=MIXER,name='PGA Capture Volume'
[ 10.911844] autorun-usecase.sh[114]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
[ 10.932036] autorun-usecase.sh[114]: : values=72,72
[ 10.951897] autorun-usecase.sh[114]: | dBscale-min=0.00dB,step=0.50dB,mute=0
[ 10.972112] autorun-usecase.sh[114]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
[ 10.992016] autorun-usecase.sh[114]: ; type=BOOLEAN,access=rw------,values=1
[ 11.012036] autorun-usecase.sh[114]: : values=on
[ 11.042101] autorun-usecase.sh[114]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
[ 11.061860] autorun-usecase.sh[114]: ; type=BOOLEAN,access=rw------,values=1
[ 11.081725] autorun-usecase.sh[114]: : values=on
[ 11.105150] autorun-usecase.sh[114]: Mount mtd6 and mtd7 partitions
[ 11.189410] ubi0: attaching mtd6
[ 11.317512] net eth0: initializing cpsw version 1.10 (0)
[ 11.322873] net eth0: initialized cpsw ale version 1.3
[ 11.331422] net eth0: phy found : id is : 0x2000a231
[ 11.336463] libphy: PHY not found
[ 11.339914] net eth0: phy "" not found on slave 1, err -19
[ 11.414084] ubi0: scanning is finished
[ 11.482170] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.493511] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 11.499564] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 11.506472] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 11.513223] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 11.520241] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 11.526189] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 11.533462] ubi0: max/mean erase counter: 9/4, WL threshold: 4096, image sequence number: 2667817441
[ 11.542658] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
[ 11.552427] ubi0: background thread "ubi_bgt0d" started, PID 147
[ 11.763472] autorun-usecase.sh[114]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 12.387191] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 152
[ 12.474965] UBIFS (ubi0:0): recovery needed
[ 12.792990] UBIFS (ubi0:0): recovery completed
[ 12.797636] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
[ 12.805596] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 12.815593] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 12.825747] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 12.832239] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID AA21A384-4ECC-4F1F-BA8C-EBB1D35EBD16, small LPT model
[ 13.644322] ubi1: attaching mtd7
[ 13.941925] ubi1: scanning is finished
[ 13.987227] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 13.993549] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 14.000495] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 14.007244] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 14.014237] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 14.020286] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 14.027558] ubi1: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 3383995126
[ 14.036731] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 14.048571] ubi1: background thread "ubi_bgt1d" started, PID 169
[ 14.066793] autorun-usecase.sh[114]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 14.627261] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 183
[ 14.648447] UBIFS (ubi1:0): recovery needed
[ 14.668153] UBIFS (ubi1:0): recovery completed
[ 14.672723] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 14.680724] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 14.690708] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 14.701207] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 14.707877] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID EBC3BFCA-673F-4B1C-B1F6-5BF526D40A9C, small LPT model
[ 15.223681] autorun-usecase.sh[114]: wifi: in STA mode
_____ _____ _ _
|___| |___|
ti81xx login: [ 16.328074] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 16.336020] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 19.066370] cfg80211: World regulatory domain updated:
[ 19.071624] cfg80211: DFS Master region: unset
[ 19.076004] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 19.085862] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.093948] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.102026] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.110090] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 19.119633] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 19.129176] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 19.137322] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 19.145364] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 19.588623] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 19.987775] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 20.015056] wlcore: loaded
[ 20.626140] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 20.737389] random: nonblocking pool is initialized
[ 20.745386] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 20.763710] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 24.928251] autorun-usecase.sh[114]: SSID: gaff
[ 24.930873] autorun-usecase.sh[114]: SSID: TP-LINK_THW
[ 24.933839] autorun-usecase.sh[114]: SSID: TP-LINK_A394
[ 24.937910] autorun-usecase.sh[114]: SSID: gaff
[ 25.352487] <1>SysLink version : 2.21.02.10
[ 25.352487] SysLink module created on Date:Feb 13 2017 Time:19:16:30
[ 25.363158] <1>Trace enabled
[ 25.366054] <1>Trace SetFailureReason enabled
[ 25.450273] autorun-usecase.sh[114]: /dev/mem opened.
[ 25.452005] autorun-usecase.sh[114]: Phy Addr : 0x48181560 Data : 0x00000002
[ 25.453424] autorun-usecase.sh[114]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 25.454765] autorun-usecase.sh[114]: Phy Addr : 0x48180508 Data : 0x00000302
[ 25.456130] autorun-usecase.sh[114]: Phy Addr : 0x48180520 Data : 0x00000002
[ 25.457486] autorun-usecase.sh[114]: Phy Addr : 0x48180524 Data : 0x00000002
[ 25.482731] autorun-usecase.sh[114]: Phy Addr : 0x48180528 Data : 0x00000002
[ 25.484661] autorun-usecase.sh[114]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 25.486144] autorun-usecase.sh[114]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 25.487528] autorun-usecase.sh[114]: DDR IOs RX is shutdown
[ 25.488903] autorun-usecase.sh[114]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 26.432810] autorun-usecase.sh[114]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (228) - No such process
[ 26.457222] autorun-usecase.sh[114]: [host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[ 26.463566] autorun-usecase.sh[114]: [host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[ 26.467892] autorun-usecase.sh[114]: [host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[ 26.474399] autorun-usecase.sh[114]: [host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[ 26.538010] autorun-usecase.sh[114]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 27.567695] autorun-usecase.sh[114]: mkfs.fat 3.0.28 (2015-05-16)
[ 27.569418] autorun-usecase.sh[114]: unable to get drive geometry, using default 255/63
[ 27.573713] autorun-usecase.sh[114]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 27.580155] autorun-usecase.sh[114]: hidden sectors 0x0000;
[ 27.582080] autorun-usecase.sh[114]: logical sector size is 512,
[ 27.583607] autorun-usecase.sh[114]: using 0xf8 media descriptor, with 1024 sectors;
[ 27.587635] autorun-usecase.sh[114]: drive number 0x80;
[ 27.590841] autorun-usecase.sh[114]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 27.594526] autorun-usecase.sh[114]: FAT size is 1 sector, and provides 247 clusters.
[ 27.597146] autorun-usecase.sh[114]: There is 1 reserved sector.
[ 27.599989] autorun-usecase.sh[114]: Root directory contains 512 slots and uses 32 sectors.
[ 27.606683] autorun-usecase.sh[114]: Volume ID is a72a85bc, no volume label.
[ 27.834693] Mass Storage Function, version: 2009/09/11
[ 27.839960] LUN: removable file: (no medium)
[ 27.844650] LUN: removable file: /dev/sbulla
[ 27.849003] Number of LUNs=1
[ 27.883757] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 27.890823] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 27.897943] g_mass_storage gadget: g_mass_storage ready
[ 27.956365] autorun-usecase.sh[114]: Creat queue id:0
[ 27.958059] autorun-usecase.sh[114]: queue id:0
[ 27.959412] autorun-usecase.sh[114]: Creat queue id:32769
[ 27.975147] autorun-usecase.sh[114]: queue id:32769
[ 27.977298] autorun-usecase.sh[114]: Creat queue id:65538
[ 27.983134] autorun-usecase.sh[114]: queue id:65538
[ 27.990163] autorun-usecase.sh[114]: Creat queue id:98307
[ 27.993234] autorun-usecase.sh[114]: queue id:98307
[ 27.998267] autorun-usecase.sh[114]: queue id:32769
[ 28.082970] autorun-usecase.sh[114]: [host] Attached to slave procId 1.
[ 31.572162] autorun-usecase.sh[114]: [host] Attached to slave procId 0.
[ 31.575729] autorun-usecase.sh[114]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[ 31.785627] autorun-usecase.sh[114]: [host] Started slave procId 1.
[ 31.787719] autorun-usecase.sh[114]: [host] After Ipc_loadcallback status [0x00000000]
[ 31.837789] autorun-usecase.sh[114]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[ 31.839851] autorun-usecase.sh[114]: [host] Started slave procId 0.
[ 31.841732] autorun-usecase.sh[114]: [host] After Ipc_loadcallback status [0x00000000]
[ 31.924579] autorun-usecase.sh[114]: [host] After Ipc_startcallback status [0x00000000]
[ 31.957643] autorun-usecase.sh[114]: [host] After Ipc_startcallback status [0x00000000]
[ 32.032021] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.033792] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 32.035211] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 32.036517] autorun-usecase.sh[114]: [m3vpss ] Received character 's'
[ 32.130893] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.132684] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 32.134064] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 32.135338] autorun-usecase.sh[114]: [m3video] Received character 's'
[ 32.150987] autorun-usecase.sh[114]: queue id:65538
[ 32.157187] autorun-usecase.sh[114]: Creat queue id:131076
[ 32.167372] autorun-usecase.sh[114]: queue id:131076
[ 32.169346] autorun-usecase.sh[114]: CPU is TI812x
[ 32.177234] autorun-usecase.sh[114]: vsenable : 0
[ 32.324288] autorun-usecase.sh[114]: Creat queue id:163845
[ 32.326526] autorun-usecase.sh[114]: queue id:163845
[ 32.331153] autorun-usecase.sh[114]: queue id:65538
[ 33.154706] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.156788] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.166460] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.271610] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.273410] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.274778] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.276051] autorun-usecase.sh[114]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 33.277292] autorun-usecase.sh[114]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 33.278519] autorun-usecase.sh[114]: [m3video]
[ 33.279790] autorun-usecase.sh[114]: [m3vpss ] notify_attach rtnVal 0
[ 33.281887] autorun-usecase.sh[114]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 33.283405] autorun-usecase.sh[114]: [m3video]
[ 33.284906] autorun-usecase.sh[114]: [m3video] 38: SYSTEM : System Common Init in progress !!!
[ 33.286349] autorun-usecase.sh[114]: [m3video] 38: SYSTEM: IPC init in progress !!!
[ 33.287769] autorun-usecase.sh[114]: [m3video] 38: SYSTEM: Attaching to [HOST] ...
[ 33.289164] autorun-usecase.sh[114]: [m3video] 88: SYSTEM: Attaching to [HOST] ...
[ 33.290710] autorun-usecase.sh[114]: [m3vpss ] initProxyServer rtnVal 0
[ 33.292225] autorun-usecase.sh[114]: [m3vpss ]
[ 33.293708] autorun-usecase.sh[114]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 33.295146] autorun-usecase.sh[114]: [m3vpss ]
[ 33.296601] autorun-usecase.sh[114]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 33.298007] autorun-usecase.sh[114]: [m3vpss ] 68: SYSTEM: IPC init in progress !!!
[ 33.299394] autorun-usecase.sh[114]: [m3vpss ] 68: SYSTEM: Attaching to [HOST] ...
[ 33.300887] autorun-usecase.sh[114]: [m3video] 98: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 33.302457] autorun-usecase.sh[114]: [m3video] 99: SYSTEM: Attaching to [VPSS-M3] ...
[ 33.303890] autorun-usecase.sh[114]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ...
[ 33.305307] autorun-usecase.sh[114]: [m3vpss ] 131: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 33.306791] autorun-usecase.sh[114]: [m3vpss ] 132: SYSTEM: Attaching to [VIDEO-M3] ...
[ 33.308240] autorun-usecase.sh[114]: [m3video] 148: SYSTEM: Attaching to [VPSS-M3] ...
[ 33.309672] autorun-usecase.sh[114]: [m3video] 182: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 33.312057] autorun-usecase.sh[114]: [m3vpss ] 182: SYSTEM: Attaching to [VIDEO-M3] ...
[ 33.313571] autorun-usecase.sh[114]: [m3video] 183: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 33.315008] autorun-usecase.sh[114]: [m3vpss ] 182: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 33.316425] autorun-usecase.sh[114]: [m3vpss ] 183: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 33.317848] autorun-usecase.sh[114]: [m3vpss ] 183: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 33.319352] autorun-usecase.sh[114]: [m3vpss ] 183: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 33.320896] autorun-usecase.sh[114]: [m3vpss ] 185: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 33.322414] autorun-usecase.sh[114]: [m3vpss ] 185: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 33.323907] autorun-usecase.sh[114]: [m3vpss ] 186: SYSTEM: IPC init DONE !!!
[ 33.325354] autorun-usecase.sh[114]: [m3vpss ] 197: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 33.326780] autorun-usecase.sh[114]: [m3vpss ] 197: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 33.328296] autorun-usecase.sh[114]: [m3vpss ] 199: SYSTEM : System Common Init Done !!!
[ 33.329878] autorun-usecase.sh[114]: [m3video] 283: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 33.331486] autorun-usecase.sh[114]: [m3video] 284: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 33.333073] autorun-usecase.sh[114]: [m3video] 284: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 33.334558] autorun-usecase.sh[114]: [m3video] 286: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 33.336040] autorun-usecase.sh[114]: [m3video] 286: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 33.337462] autorun-usecase.sh[114]: [m3video] 286: SYSTEM: IPC init DONE !!!
[ 33.338867] autorun-usecase.sh[114]: [m3video] 297: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 33.340374] autorun-usecase.sh[114]: [m3video] 297: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 33.341900] autorun-usecase.sh[114]: [m3video] 299: SYSTEM : System Common Init Done !!!
[ 33.343478] autorun-usecase.sh[114]: [m3vpss ] 1399: SYSTEM : System VPSS Init in progress !!!
[ 33.344919] autorun-usecase.sh[114]: [m3vpss ] === I2C0/2 Clk is active ===
[ 33.346415] autorun-usecase.sh[114]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 33.347856] autorun-usecase.sh[114]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 33.682914] autorun-usecase.sh[114]: [m3vpss ] 1418: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 33.684454] autorun-usecase.sh[114]: [m3vpss ] 1418: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 33.686044] autorun-usecase.sh[114]: [m3vpss ] 1418: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 33.687580] autorun-usecase.sh[114]: [m3vpss ] 1421: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 33.689170] autorun-usecase.sh[114]: [m3vpss ] 1421: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 33.690737] autorun-usecase.sh[114]: [m3vpss ] 1421: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 33.692209] autorun-usecase.sh[114]: [m3vpss ] 1434: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 33.693714] autorun-usecase.sh[114]: [m3vpss ] 1435: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 33.695224] autorun-usecase.sh[114]: [m3vpss ] 1435: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 33.696677] autorun-usecase.sh[114]: [m3vpss ] 1438: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 33.698153] autorun-usecase.sh[114]: [m3vpss ] 1438: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 33.699596] autorun-usecase.sh[114]: [m3vpss ] 1438: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[ 33.701123] autorun-usecase.sh[114]: [m3vpss ] 1441: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 33.702621] autorun-usecase.sh[114]: [m3vpss ] 1441: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 33.704116] autorun-usecase.sh[114]: [m3vpss ] 1442: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[ 34.673344] autorun-usecase.sh[114]: [m3vpss ] 1448: SYSTEM: Creating ListMP [VPSS-M3_IPC_OU [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 34.677723] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 34.682858] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 36.130995] autorun-usecase.sh[114]: queue id:0
[ 36.148956] autorun-usecase.sh[114]: ApproDrvInit: 7
[ 36.151317] autorun-usecase.sh[114]: queue id:163845
[ 38.046108] autorun-usecase.sh[114]: ApproDrvInit: 3
[ 38.059352] autorun-usecase.sh[114]: queue id:163845
[ 38.783633] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 38.787769] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 38.789490] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 38.794154] autorun-usecase.sh[114]: [m3vpss ] Received character 't'
[ 38.813310] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 38.815377] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 38.819380] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 38.822758] autorun-usecase.sh[114]: [m3video] Received character 't'
[ 38.849290] autorun-usecase.sh[114]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 38.914280] DMA: Module install successful, device major num = 244
[ 38.920642] DRV: Module install successful
[ 38.924771] DRV: Module built on Feb 13 2017 19:26:20
[ 38.989267]
[ 38.989267] soc_is_dm38x
[ 39.056735] HDMI W1 rev 4.0
[ 39.059627] HDMI CEC Spec version 1.2
[ 39.437138] I2C No Ack
[ 39.439640] HDMI failed to read E-EDID
[ 39.924559] autorun-usecase.sh[114]: [host]
[ 39.928098] autorun-usecase.sh[114]: [host] ORG 0x46c00524: 0
[ 39.929968] autorun-usecase.sh[114]: [host] NEW 0x46c00524: 2
[ 39.931833] autorun-usecase.sh[114]: [host]
[ 39.933632] autorun-usecase.sh[114]: [host] Application Start Completed
[ 39.961897] autorun-usecase.sh[114]: queue id:0
[ 40.028975] autorun-usecase.sh[114]: [host] 0: SYSTEM: System Common Init in progress !!!
[ 40.031940] autorun-usecase.sh[114]: [host] 0: SYSTEM: IPC init in progress !!!
[ 40.037473] autorun-usecase.sh[114]: [host] 9: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 40.038603] autorun-usecase.sh[114]: [host] 10: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
[ 40.080779] DMA: ChannelID allocated:4
[ 40.039468] autorun-usecase.sh[114]: [host] 11: SYSTEM: CPU [VPSS-M3] syslink proc ID is [1] !!!
[ 40.040548] autorun-usecase.sh[114]: [host] 12: SYSTEM: CPU [HOST] syslink proc ID[ 40.101310] DMA: ChannelID allocated:5
is [2] !!!
[ 40.041237] autorun-usecase.sh[114]: [host] 12: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 40.042875] autorun-usecase.sh[114]: [host] 14: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[ 40.044991] autorun-usecase.sh[114]: [host] 14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[ 40.046949] autorun-usecase.sh[114]: [host] 14: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 40.048851] autorun-usecase.sh[114]: [host] 15: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 40.050598] autorun-usecase.sh[114]: [host] 16: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 40.052091] autorun-usecase.sh[114]: [host] 16: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 40.054010] autorun-usecase.sh[114]: [host] 16: SYSTEM: IPC init DONE !!!
[ 40.055853] autorun-usecase.sh[114]: [host] 19: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[ 40.057240] autorun-usecase.sh[114]: [host] 19: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[ 40.061468] autorun-usecase.sh[114]: [host] 19: SYSTEM: ListElem Shared Addr = 0xb55c5580
[ 40.062469] autorun-usecase.sh[114]: [host] 20: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[ 40.072585] autorun-usecase.sh[114]: [host] 21: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[ 40.074968] autorun-usecase.sh[114]: [host] 21: SYSTEM: ListElem Shared Addr = 0xb55df200
[ 40.077186] autorun-usecase.sh[114]: [host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[ 40.079407] autorun-usecase.sh[114]: [host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[ 40.080324] autorun-usecase.sh[114]: [host] 25: SYSTEM: ListElem Shared Addr = 0xb55f8e80
[ 40.081605] autorun-usecase.sh[114]: [host] 26: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[ 40.088403] autorun-usecase.sh[114]: [host] 26: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[ 40.089533] autorun-usecase.sh[114]: [host] 26: SYSTEM: ListElem Shared Addr = 0xb5618880
[ 40.091175] autorun-usecase.sh[114]: [host] 27: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[ 40.091989] autorun-usecase.sh[114]: [host] 28: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[ 40.095284] autorun-usecase.sh[114]: [host] 28: SYSTEM: ListElem Shared Addr = 0xb5638280
[ 40.096070] autorun-usecase.sh[114]: [host] 30: SYSTEM: System Common Init Done !!!
[ 40.099948] autorun-usecase.sh[114]: [host] Vsys_allocBuf - addr = 0xa736e000,size = 65011712
[ 40.100947] autorun-usecase.sh[114]: ##########pInfo->totalsize 63897600
[ 40.103748] autorun-usecase.sh[114]: queue id:0
[ 40.104567] autorun-usecase.sh[114]: queue id:32769
[ 40.107359] autorun-usecase.sh[114]: [host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[ 40.108151] autorun-usecase.sh[114]: [host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[ 40.108894] autorun-usecase.sh[114]: [host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[ 40.109536] autorun-usecase.sh[114]: [host] Vsys_allocBuf - addr = 0xb6f01000,size = 33603
[ 40.110292] autorun-usecase.sh[114]: [host] DCC buffer allocated for size 33603
[ 40.110995] autorun-usecase.sh[114]: [host] DCC Default File Intialization Done
[ 40.111579] autorun-usecase.sh[114]: [host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[ 40.177286] autorun-usecase.sh[114]: [host]
[ 40.178341] autorun-usecase.sh[114]: ********** FULL FEATURE USECASE ********
[ 40.179041] autorun-usecase.sh[114]: [host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[ 40.179715] autorun-usecase.sh[114]: [host] 149: MCFW : CPU Revision [ES1.0] !!!
[ 40.180435] autorun-usecase.sh[114]: [host] 149: MCFW : Detected [UNKNOWN] Board !!!
[ 40.181082] autorun-usecase.sh[114]: [host] 149: MCFW : Base Board Revision [REV A] !!!
[ 40.204028] autorun-usecase.sh[114]: T_29] in region 0 ...
[ 40.204780] autorun-usecase.sh[114]: [m3vpss ] 1448: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 40.205435] autorun-usecase.sh[114]: [m3vpss ] 1448: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[ 40.206133] autorun-usecase.sh[114]: [m3vpss ] 1451: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 40.206748] autorun-usecase.sh[114]: [m3vpss ] 1451: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 40.207321] autorun-usecase.sh[114]: [m3vpss ] 1451: SYSTEM: ListElem Shared Addr = 0xbea03600
[ 40.207920] autorun-usecase.sh[114]: [m3vpss ] 1453: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 40.208482] autorun-usecase.sh[114]: [m3vpss ] 1454: SYSTEM : FVID2 Init in progress !!!
[ 40.209090] autorun-usecase.sh[114]: [m3vpss ] 1524: SYSTEM : FVID2 Init in progress DONE !!!
[ 40.209646] autorun-usecase.sh[114]: [m3vpss ] 1524: SYSTEM : Device Init in progress !!!
[ 40.210300] autorun-usecase.sh[114]: [m3vpss ] Iss_init called !!!!!!
[ 40.210876] autorun-usecase.sh[114]: [m3vpss ] CPIS_init DONE !!!!!!
[ 40.211515] autorun-usecase.sh[114]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 40.212117] autorun-usecase.sh[114]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 40.212743] autorun-usecase.sh[114]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 40.213341] autorun-usecase.sh[114]: [m3vpss ] 1718: SYSTEM : Device Init in progress DONE !!!
[ 40.547450] autorun-usecase.sh[114]: [m3video] 2899: SYSTEM : System Video Init in progress !!!
[ 40.548110] autorun-usecase.sh[114]: [m3video] 2900: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 40.548725] autorun-usecase.sh[114]: [m3video] 2900: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 40.549301] autorun-usecase.sh[114]: [m3video] 2900: SYSTEM: ListElem Shared Addr = 0xbea1d280
[ 40.549907] autorun-usecase.sh[114]: [m3video] 2903: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 40.550530] autorun-usecase.sh[114]: [m3video] 2903: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 40.551157] autorun-usecase.sh[114]: [m3video] 2903: SYSTEM: ListElem Shared Addr = 0xbea20780
[ 40.551772] autorun-usecase.sh[114]: [m3video] 2913: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 40.552428] autorun-usecase.sh[114]: [m3video] 2913: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 40.552994] autorun-usecase.sh[114]: [m3video] 2914: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 40.553630] autorun-usecase.sh[114]: [m3video] 2916: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 40.554188] autorun-usecase.sh[114]: [m3video] 2916: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 40.554796] autorun-usecase.sh[114]: [m3video] 2917: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 40.555383] autorun-usecase.sh[114]: [m3video] 2918: HDVICP: Doing PRCM for IVAHD[0] ...
[ 40.555938] autorun-usecase.sh[114]: [m3video] 2919: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 40.556547] autorun-usecase.sh[114]: [m3video] 2920: SYSTEM : Initializing Links !!!
[ 40.557310] autorun-usecase.sh[114]: [m3video] 2920: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 40.558074] autorun-usecase.sh[114]: [m3video] 2920: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 40.558721] autorun-usecase.sh[114]: [m3video] 2920: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 40.559305] autorun-usecase.sh[114]: [m3video] 2921: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 40.559928] autorun-usecase.sh[114]: [m3video] 2921: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 40.560554] autorun-usecase.sh[114]: [m3video] 2922: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 40.561189] autorun-usecase.sh[114]: [m3video] Entered the MctnfLink_init()
[ 40.561746] autorun-usecase.sh[114]: [m3video] 2980: SYSTEM : Initializing Links ... DONE !!!
[ 40.562380] autorun-usecase.sh[114]: [m3video] 2981: SYSTEM : System Video Init Done !!!
[ 40.562938] autorun-usecase.sh[114]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 40.563581] autorun-usecase.sh[114]: [m3vpss ] 6827: SYSTEM : System VPSS Init Done !!!
[ 40.564171] autorun-usecase.sh[114]: [m3vpss ] 6828: UTILS: DMA: HWI Create for INT62 !!!
[ 40.564767] autorun-usecase.sh[114]: [m3vpss ] 6828: SYSTEM : Initializing Links !!!
[ 40.565387] autorun-usecase.sh[114]: [m3vpss ] 6828: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 40.565959] autorun-usecase.sh[114]: [m3vpss ] 6828: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 40.566573] autorun-usecase.sh[114]: [m3vpss ] 6829: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 40.567186] autorun-usecase.sh[114]: [m3vpss ] 6829: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 40.567816] autorun-usecase.sh[114]: [m3vpss ] 6829: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 40.568374] autorun-usecase.sh[114]: [m3vpss ] 6960: SYSTEM : Initializing Links ... DONE !!!
[ 40.568994] autorun-usecase.sh[114]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 40.569603] autorun-usecase.sh[114]: [m3vpss ] VPS_DCTRL_INST_0
[ 40.570193] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 40.905227] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 40.905889] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 40.906511] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 40.907094] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 40.907704] autorun-usecase.sh[114]: [m3vpss ] HDCOMPCLK
[ 40.908273] autorun-usecase.sh[114]: [m3vpss ] 8290: CAMERA: Create in progress !!!
[ 40.908870] autorun-usecase.sh[114]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 40.909462] autorun-usecase.sh[114]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 40.910327] autorun-usecase.sh[114]:[ 41.026361] DMA: ChannelID allocated:6
[m3vpss ] 8290: CAMERA: VIP0 PortA camera mode is [ 8-bit, No[ 41.031988] DMA: ChannelID allocated:7
[ 41.025805] autorun-usecase.sh[114]: [m3vpss ] 8291: CAMERA: VIP 0: VID DEC 268436737 (0x10): 00
[ 41.026664] autorun-usecase.sh[114]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[ 41.027300] autorun-usecase.sh[114]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[ 41.110292] DMA: ChannelID allocated:12
[ 41.097832] autorun-usecase.sh[114]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[ 41.339815] autorun-usecase.sh[114]: 02:20202020:20202020, AUD_STATUS 538976288
[ 41.340702] autorun-usecase.sh[114]: [m3vpss ] Iss_captCreate:1661
[ 41.341461] autorun-usecase.sh[114]: [m3vpss ] 8504: CAMERA: Create Done !!!
[ 41.342106] autorun-usecase.sh[114]: [m3vpss ] 8594: CAMERA: Detect video in progress !!!
[ 41.342706] autorun-usecase.sh[114]: [m3vpss ] 8594: CAMERA: Detect video Done !!!
[ 41.343394] autorun-usecase.sh[114]: [m3video] 8669: IPC_IN_M3 : Create in progress !!!
[ 41.343982] autorun-usecase.sh[114]: [m3vpss ] 8667: DUP : Create Done !!!
[ 41.344627] autorun-usecase.sh[114]: [m3video] 8669: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 41.345188] autorun-usecase.sh[114]: [m3vpss ] 8667: IPC_OUT_M3 : Create in progress !!!
[ 41.345811] autorun-usecase.sh[114]: [m3video] 8670: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 41.346411] autorun-usecase.sh[114]: [m3vpss ] 8668: IPC_OUT_M3 : Create Done !!!
[ 41.346991] autorun-usecase.sh[114]: [m3video] 8673: IPC_IN_M3 : Create Done !!!
[ 41.347580] autorun-usecase.sh[114]: [m3vpss ] DCC server task running
[ 41.348131] autorun-usecase.sh[114]: [m3video] Entered the MctnfLink_tskMain()
[ 41.348727] autorun-usecase.sh[114]: [m3video] inChInfo->width = 1920
[ 41.349283] autorun-usecase.sh[114]: [m3video] inChInfo->height = 1080
[ 41.349993] autorun-usecase.sh[114]: [m3video] inChInfo->pitch[0] = 1984
[ 41.350625] autorun-usecase.sh[114]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 41.351269] autorun-usecase.sh[114]: [m3video] [MCTNF] startX = 0
[ 41.351831] autorun-usecase.sh[114]: [m3video] [MCTNF] startY = 0
[ 41.352429] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->width = 1920
[ 41.353041] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->height = 1080
[ 41.353601] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 41.354189] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 41.354747] autorun-usecase.sh[114]: [m3video] 8854: IPC_OUT_M3 : Create in progress !!!
[ 41.355336] autorun-usecase.sh[114]: [m3video] 8855: IPC_OUT_M3 : Create Done !!!
[ 41.355928] autorun-usecase.sh[114]: [m3vpss ] 8856: IPC_IN_M3 : Create in progress !!!
[ 41.356564] autorun-usecase.sh[114]: [m3vpss ] 8856: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 41.357198] autorun-usecase.sh[114]: [m3vpss ] 8856: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 41.357841] autorun-usecase.sh[114]: [m3vpss ] 8857: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 41.358439] autorun-usecase.sh[114]: [m3vpss ] 8860: IPC_IN_M3 : Create Done !!!
[ 41.359063] autorun-usecase.sh[114]: [m3vpss ] 8794: VNF:
[ 41.359699] autorun-usecase.sh[114]: [m3vpss ] Create in progress ... !!!
[ 41.360312] autorun-usecase.sh[114]: [m3vpss ] 8794: VNF:
[ 41.360918] autorun-usecase.sh[114]: [m3vpss ] Input Channel CH0 of 1920 x 1080, pitch = (1984, 1984) [0,0][PROGRESSIVE] [7] ...
[ 41.361491] autorun-usecase.sh[114]: [m3vpss ] 8795: VNF:
[ 41.362134] autorun-usecase.sh[114]: [m3vpss ] [VNF] eOperateMode=7 [6-TNF3,7-NSF2]chVnfCreateParams->ulStartX = -16 chVnfCreateParams->ulStartY = -18 chVnfCreateParams->ulInputStride = 1984 chVnfCreateParams->ulInputWidth=1952,chVnfCreateParams->ulInputHeight=1112
[ 41.362727] autorun-usecase.sh[114]: [m3vpss ] 8964: VNF:
[ 41.363469] autorun-usecase.sh[114]: [m3vpss ] [VNF] outChInfo->StartX = 0 outChInfo->startY = 0 outChInfo->pitch[0] = 1920 outChInfo->width=1920,outChInfo->height=1080
[ 41.364136] autorun-usecase.sh[114]: [m3vpss ] 8966: VNF:
[ 41.364714] autorun-usecase.sh[114]: [m3vpss ] Create ... DONE !!!
[ 41.365307] autorun-usecase.sh[114]: [m3vpss ] 9033: NSF: Create in progress !!!
[ 41.365869] autorun-usecase.sh[114]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 41.366471] autorun-usecase.sh[114]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 41.367034] autorun-usecase?
U-Boot SPL 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46)
Trying to boot from MMC2
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46 -0500)
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
Net: <ethaddr> not set. Reading from E-fuse
cpsw
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Booting from mmc ...
reading uImage
2662320 bytes read in 305 ms (8.3 MiB/s)
reading dm38x-csk.dtb
58698 bytes read in 14 ms (4 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-4.4.12-00004-g82adbbf-dirt
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2662256 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 84000000
Booting using the fdt blob at 0x84000000
Loading Kernel Image ... OK
Loading Device Tree to 844ee000, end 844ff549 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.12-00004-g82adbbf-dirty (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 Mon Feb 13 17:38:26 EST 2017
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: DM38X CSK
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] omap_barrier_reserve_memblock():Reserving DRAM area @ addr = 0x84e00000 size = 1048576 Bytes
[ 0.000000] cma: Reserved 24 MiB at 0x82c00000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] TI81XX: Map 0x84e00000 to 0xfe500000 for dram barrier
[ 0.000000] TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] TI814X ES1.0 (iva neon )
[ 0.000000] powerdomain: gem_pwrdm: voltagedomain dsp does not exist
[ 0.000000] powerdomain: ivahd_pwrdm: voltagedomain iva does not exist
[ 0.000000] powerdomain: hdvpss_pwrdm: voltagedomain dsp does not exist
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19788
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rootwait rw mem=80M vram=4M cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 notifyk.vpssm3_sva=0xBFD00000 earlyprintk
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 46648K/79872K available (4911K kernel code, 260K rwdata, 1708K rodata, 276K init, 241K bss, 8648K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc5800000 - 0xff800000 ( 928 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc067efa4 (6620 kB)
[ 0.000000] .init : 0xc067f000 - 0xc06c4000 ( 276 kB)
[ 0.000000] .data : 0xc06c4000 - 0xc0705308 ( 261 kB)
[ 0.000000] .bss : 0xc0705308 - 0xc0741718 ( 242 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 20000000 Hz
[ 0.000015] sched_clock: 32 bits at 20MHz, resolution 50ns, wraps every 107374182375ns
[ 0.017838] OMAP clocksource: timer1 at 20000000 Hz
[ 0.086914] pid_max: default: 32768 minimum: 301
[ 0.091864] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098776] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.106822] Initializing cgroup subsys io
[ 0.111055] Initializing cgroup subsys memory
[ 0.115683] Initializing cgroup subsys devices
[ 0.120356] Initializing cgroup subsys freezer
[ 0.125035] Initializing cgroup subsys pids
[ 0.129449] CPU: Testing write buffer coherency: ok
[ 0.134904] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.142728] devtmpfs: initialized
[ 0.168794] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.217165] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.229300] pinctrl core: initialized pinctrl subsystem
[ 0.236101] NET: Registered protocol family 16
[ 0.242339] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.255305] OMAP GPIO hardware version 0.1
[ 0.267898] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
[ 0.301596] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.309865] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.323472] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.337142] media: Linux media interface: v0.10
[ 0.341957] Linux video capture interface: v2.00
[ 0.346866] pps_core: LinuxPPS API ver. 1 registered
[ 0.352060] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.361588] PTP clock support registered
[ 0.365729] EDAC MC: Ver: 3.0.0
[ 0.369790] Advanced Linux Sound Architecture Driver Initialized.
[ 0.377191] clocksource: Switched to clocksource timer1
[ 0.394623] NET: Registered protocol family 2
[ 0.399984] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.407294] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.413933] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.420650] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.426754] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.433475] NET: Registered protocol family 1
[ 0.438428] RPC: Registered named UNIX socket transport module.
[ 0.444610] RPC: Registered udp transport module.
[ 0.449569] RPC: Registered tcp transport module.
[ 0.454494] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462541] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.469655] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.486654] NFS: Registering the id_resolver key type
[ 0.492051] Key type id_resolver registered
[ 0.496443] Key type id_legacy registered
[ 0.502332] io scheduler noop registered
[ 0.506469] io scheduler deadline registered
[ 0.511222] io scheduler cfq registered (default)
[ 0.517548] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
[ 0.598724] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.609746] console [ttyS0] disabled
[ 0.613561] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 3000000) is a 8250
[ 0.622522] console [ttyS0] enabled
[ 0.629716] bootconsole [earlycon0] disabled
[ 0.639518] Reference Linux version 4.4.12
[ 0.643813] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script/TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.662363] allocated heap buffer 0xc8000000 of size 0x4000000
[ 0.668267] cmemk initialized
[ 0.678634] loop: module loaded
[ 0.747249] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
[ 0.753386] libphy: 4a100800.mdio: probed
[ 0.758260] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, driver TI DP83867
[ 0.767252] cpsw 4a100000.ethernet: Detected MACID = 7c:66:9d:f8:c5:0c
[ 0.777350] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.807416] mousedev: PS/2 mouse device common for all mice
[ 0.813530] omap_rtc 480c0000.rtc: already running
[ 0.818808] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
[ 0.826234] i2c /dev entries driver
[ 0.830747] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 0.837868] sdhci: Secure Digital Host Controller Interface driver
[ 0.844077] sdhci: Copyright(c) Pierre Ossman
[ 0.972691] omap_hsmmc 48060000.mmc: card claims to support voltages below defined range
[ 0.991835] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 0.998086] mmc0: new high speed SDIO card at address 0001
[ 1.007452] Synopsys Designware Multimedia Card Interface Driver
[ 1.013945] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.020930] notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
[ 1.027086] notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbfd00000
[ 1.038839] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 1.046115] davinci_evm sound: snd_soc_register_card failed (-517)
[ 1.053582] NET: Registered protocol family 10
[ 1.060453] sit: IPv6 over IPv4 tunneling driver
[ 1.065935] NET: Registered protocol family 17
[ 1.070601] Key type dns_resolver registered
[ 1.075139] omap_voltage_late_init: Could not get sys clk.
[ 1.081046] Power Management for TI81XX.
[ 1.090274] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.095459] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.103081] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.109568] nand: Micron MT29F2G16ABAEAWP
[ 1.113602] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.121237] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.126652] 8 ofpart partitions found on MTD device 8000000.nand
[ 1.132707] Creating 8 MTD partitions on "8000000.nand":
[ 1.138066] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.147848] 0x000000020000-0x000000420000 : "NAND.u-boot"
[ 1.156043] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
[ 1.163158] 0x000000440000-0x000000a40000 : "NAND.kernel"
[ 1.172234] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
[ 1.182020] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.197267] mmc1: new high speed SDHC card at address 0007
[ 1.217248] mmcblk0: mmc1:0007 SD16G 14.5 GiB
[ 1.223219] mmcblk0: p1 p2
[ 1.271223] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
[ 1.278589] 0x00000ca80000-0x00000d680000 : "NAND.data"
[ 1.289364] 0x00000d680000-0x000010000000 : "NAND.reserved"
[ 1.354053] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1
[ 1.361757] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.369248] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.376048] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
[ 1.383119] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 1.392542] omap_rtc 480c0000.rtc: setting system clock to 2016-12-05 23:40:54 UTC (1480981254)
[ 1.414462] wlan-en-regulator: disabling
[ 1.418815] ALSA device list:
[ 1.421802] #0: TI81XX-CSK
[ 1.426785] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 6.707828] EXT4-fs (mmcblk0p2): recovery complete
[ 6.721154] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.729368] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 6.744585] devtmpfs: mounted
[ 6.748199] Freeing unused kernel memory: 276K (c067f000 - c06c4000)
[ 6.754583] This architecture does not have kernel memory protection.
[ 7.013163] random: systemd urandom read with 22 bits of entropy available
[ 7.033739] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 7.052538] systemd[1]: Detected architecture arm.
Welcome to [1mArago 2016.05 [0m!
[ 7.079261] systemd[1]: Set hostname to <ti81xx>.
[ 7.365437] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-usecase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 7.515025] systemd[1]: Reached target Remote File Systems.
[ [0;32m OK [0m] Reached target Remote File Systems.
[ 7.537817] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 7.567692] systemd[1]: Listening on Journal Socket (/dev/log).
[ [0;32m OK [0m] Listening on Journal Socket (/dev/log).
[ 7.587723] systemd[1]: Listening on Journal Socket.
[ [0;32m OK [0m] Listening on Journal Socket.
[ 7.607796] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ [0;32m OK [0m] Started Forward Password Requests to Wall Directory Watch.
[ 7.637455] systemd[1]: Reached target Paths.
[ [0;32m OK [0m] Reached target Paths.
[ 7.657453] systemd[1]: Reached target Swap.
[ [0;32m OK [0m] Reached target Swap.
[ 7.677709] systemd[1]: Listening on udev Control Socket.
[ [0;32m OK [0m] Listening on udev Control Socket.
[ 7.716268] systemd[1]: Listening on udev Kernel Socket.
[ [0;32m OK [0m] Listening on udev Kernel Socket.
[ 7.737514] systemd[1]: Reached target Timers.
[ [0;32m OK [0m] Reached target Timers.
[ 7.757690] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ [0;32m OK [0m] Listening on /dev/initctl Compatibility Named Pipe.
[ 7.787622] systemd[1]: Listening on Syslog Socket.
[ [0;32m OK [0m] Listening on Syslog Socket.
[ 7.811462] systemd[1]: Created slice System Slice.
[ [0;32m OK [0m] Created slice System Slice.
[ 7.831391] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.863239] systemd[1]: Mounting Temporary Directory...
[ 7.918848] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ [0;32m OK [0m] Created slice system-serial\x2dgetty.slice.
[ 7.938740] systemd[1]: Created slice system-getty.slice.
[ [0;32m OK [0m] Created slice system-getty.slice.
[ 7.971496] systemd[1]: Starting udev Coldplug all Devices...
[ 8.015900] systemd[1]: Mounting /media/ram...
[ 8.042066] systemd[1]: Starting udev Kernel Device Manager...
[ 8.108041] systemd[1]: Starting Journal Service...
[ 8.148412] systemd[1]: Starting Synchronize System and HW clocks...
[ 8.205993] systemd[1]: Mounting /var/volatile...
[ 8.234079] systemd[1]: Reached target Slices.
[ [0;32m OK [0m] Reached target Slices.
[ 8.278318] systemd[1]: Listening on Network Service Netlink Socket.
[ [0;32m OK [0m] Listening on Network Service Netlink Socket.
[ 8.351815] systemd[1]: Mounted POSIX Message Queue File System.
[ [0;32m OK [0m] Mounted POSIX Message Queue File System.
[ 8.407701] systemd[1]: Mounted Temporary Directory.
[ [0;32m OK [0m] Mounted Temporary Directory.
[ 8.427613] systemd[1]: Mounted /var/volatile.
[ [0;32m OK [0m] Mounted /var/volatile.
[ 8.447602] systemd[1]: Mounted /media/ram.
[ [0;32m OK [0m] Mounted /media/ram.
[ 8.468445] systemd[1]: Started udev Kernel Device Manager.
[ [0;32m OK [0m] Started udev Kernel Device Manager.
[ 8.488222] systemd[1]: Started Journal Service.
[ [0;32m OK [0m] Started Journal Service.
[ [0;32m OK [0m] Started Synchronize System and HW clocks.
[ [0;32m OK [0m] Started udev Coldplug all Devices.
[ [0;32m OK [0m] Found device /dev/ttyS0.
[ [0;32m OK [0m] Started IPNC RDK use case service.
[ [0;32m OK [0m] Reached target Local File Systems.
[ [0;32m OK [0m] Reached target System Initialization.
[ [0;32m OK [0m] Listening on D-Bus System Message Bus Socket.
[ [0;32m OK [0m] Reached target Sockets.
[ [0;32m OK [0m] Reached target Basic System.
[ [0;32m OK [0m] Started Kernel Logging Service.
[ 9.557836] autorun-usecase.sh[113]: numid=1,iface=MIXER,name='PCM Playback Volume'
[ 9.567251] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
[ 9.568705] autorun-usecase.sh[113]: : values=115,115
[ [0;32m OK [0m] Started D-Bus System Message Bus.
[ 9.569989] autorun-usecase.sh[113]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
[ 9.666902] autorun-usecase.sh[113]: numid=31,iface=MIXER,name='PGA Capture Volume'
[ 9.694063] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
[ 9.721918] autorun-usecase.sh[113]: : values=72,72
[ 9.741887] autorun-usecase.sh[113]: | dBscale-min=0.00dB,step=0.50dB,mute=0
[ 9.763270] autorun-usecase.sh[113]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
[ 9.791769] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ 9.811823] autorun-usecase.sh[113]: : values=on
[ [0;32m OK [0m] Started Serial Getty on ttyS0.
[ [0;32m OK [0m] Started System Logging Service.
[ [0;32m OK [0m] Started Getty on tty1.
[ [0;32m OK [0m] Reached target Login Prompts.
[ 9.834647] autorun-usecase.sh[113]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
[ 9.889525] ubi0: attaching mtd6
[ 9.881989] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ 9.901771] autorun-usecase.sh[113]: : values=on
Starting Network Service...
[ 9.938408] autorun-usecase.sh[113]: Mount mtd6 and mtd7 partitions
Starting uim-sysfs.service...
[ 10.105518] ubi0: scanning is finished
[ [0;32m OK [0m] Started Network Service.
[ 10.164461] net eth0: initializing cpsw version 1.10 (0)
[ 10.172203] net eth0: initialized cpsw ale version 1.3
[ 10.180705] net eth0: phy found : id is : 0x2000a231
[ 10.185745] libphy: PHY not found
[ 10.189197] net eth0: phy "" not found on slave 1, err -19
[ 10.207322] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 10.213293] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 10.220237] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 10.226971] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 10.233980] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 10.239955] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 10.247231] ubi0: max/mean erase counter: 9/4, WL threshold: 4096, image sequence number: 2667817441
[ 10.256406] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
[ 10.266112] ubi0: background thread "ubi_bgt0d" started, PID 146
[ 10.381077] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.478768] autorun-usecase.sh[113]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 11.107317] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 151
[ 11.182083] UBIFS (ubi0:0): recovery needed
[ [0;32m OK [0m] Reached target Network.
[ 11.517719] UBIFS (ubi0:0): recovery completed
[ 11.522273] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
[ 11.530287] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 11.540271] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 11.550423] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 11.556902] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID AA21A384-4ECC-4F1F-BA8C-EBB1D35EBD16, small LPT model
Starting Network Name Resolution...
[ [0;32m OK [0m] Started Network Name Resolution.
[ 12.369738] ubi1: attaching mtd7
[ [0;32m OK [0m] Started uim-sysfs.service.
Starting telnetd.service...
[ 12.634938] ubi1: scanning is finished
[ 12.697168] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 12.703562] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 12.710498] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 12.717247] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 12.724240] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 12.730289] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 12.737561] ubi1: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 3383995126
[ 12.746736] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 12.758565] ubi1: background thread "ubi_bgt1d" started, PID 166
[ [0;32m OK [0m] Started telnetd.service.
[ 12.817443] autorun-usecase.sh[113]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
Starting thermal-zone-init.service...
[ [0;32m OK [0m] Started thermal-zone-init.service.
[ [0;32m OK [0m] Reached target Multi-User System.
[ 13.377756] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 182
[ 13.399180] UBIFS (ubi1:0): recovery needed
[ 13.419080] UBIFS (ubi1:0): recovery completed
[ 13.423655] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 13.431659] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 13.441642] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 13.452141] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 13.458809] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID EBC3BFCA-673F-4B1C-B1F6-5BF526D40A9C, small LPT model
[ 13.973731] autorun-usecase.sh[113]: wifi: in STA mode
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
ti81xx login: [ 15.178139] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 15.186087] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.816535] cfg80211: World regulatory domain updated:
[ 17.821968] cfg80211: DFS Master region: unset
[ 17.826352] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 17.836211] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.844293] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.852363] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.860427] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 17.869971] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 17.879513] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 17.887657] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 17.895699] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 18.338627] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 18.737843] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 18.767020] wlcore: loaded
[ 19.375926] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 19.500405] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 19.510463] random: nonblocking pool is initialized
[ 19.524449] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 23.644676] autorun-usecase.sh[113]: SSID: gaff
[ 23.646477] autorun-usecase.sh[113]: SSID: TP-LINK_THW
[ 23.647895] autorun-usecase.sh[113]: SSID: TP-LINK_A394
[ 23.649217] autorun-usecase.sh[113]: SSID: gaff
[ 23.661223] autorun-usecase.sh[113]: SSID: Znks
[ 24.041407] <1>SysLink version : 2.21.02.10
[ 24.041407] SysLink module created on Date:Feb 13 2017 Time:19:16:30
[ 24.052072] <1>Trace enabled
[ 24.054969] <1>Trace SetFailureReason enabled
[ 24.133191] autorun-usecase.sh[113]: /dev/mem opened.
[ 24.134984] autorun-usecase.sh[113]: Phy Addr : 0x48181560 Data : 0x00000002
[ 24.136408] autorun-usecase.sh[113]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 24.137738] autorun-usecase.sh[113]: Phy Addr : 0x48180508 Data : 0x00000302
[ 24.139114] autorun-usecase.sh[113]: Phy Addr : 0x48180520 Data : 0x00000002
[ 24.163174] autorun-usecase.sh[113]: Phy Addr : 0x48180524 Data : 0x00000002
[ 24.172963] autorun-usecase.sh[113]: Phy Addr : 0x48180528 Data : 0x00000002
[ 24.174741] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 24.176249] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 24.177699] autorun-usecase.sh[113]: DDR IOs RX is shutdown
[ 24.179316] autorun-usecase.sh[113]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 25.120663] autorun-usecase.sh[113]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (228) - No such process
[ 25.144335] autorun-usecase.sh[113]: [host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[ 25.153634] autorun-usecase.sh[113]: [host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[ 25.159124] autorun-usecase.sh[113]: [host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[ 25.163796] autorun-usecase.sh[113]: [host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[ 25.228351] autorun-usecase.sh[113]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 26.259214] autorun-usecase.sh[113]: mkfs.fat 3.0.28 (2015-05-16)
[ 26.261594] autorun-usecase.sh[113]: unable to get drive geometry, using default 255/63
[ 26.265108] autorun-usecase.sh[113]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 26.270139] autorun-usecase.sh[113]: hidden sectors 0x0000;
[ 26.272055] autorun-usecase.sh[113]: logical sector size is 512,
[ 26.277511] autorun-usecase.sh[113]: using 0xf8 media descriptor, with 1024 sectors;
[ 26.280678] autorun-usecase.sh[113]: drive number 0x80;
[ 26.284509] autorun-usecase.sh[113]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 26.287130] autorun-usecase.sh[113]: FAT size is 1 sector, and provides 247 clusters.
[ 26.290085] autorun-usecase.sh[113]: There is 1 reserved sector.
[ 26.305765] autorun-usecase.sh[113]: Root directory contains 512 slots and uses 32 sectors.
[ 26.307608] autorun-usecase.sh[113]: Volume ID is b1f5d106, no volume label.
[ 26.536568] Mass Storage Function, version: 2009/09/11
[ 26.541840] LUN: removable file: (no medium)
[ 26.546520] LUN: removable file: /dev/sbulla
[ 26.550871] Number of LUNs=1
[ 26.585593] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 26.592652] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 26.599763] g_mass_storage gadget: g_mass_storage ready
[ 26.654475] autorun-usecase.sh[113]: Creat queue id:0
[ 26.656767] autorun-usecase.sh[113]: queue id:0
[ 26.660304] autorun-usecase.sh[113]: Creat queue id:32769
[ 26.663524] autorun-usecase.sh[113]: queue id:32769
[ 26.673132] autorun-usecase.sh[113]: Creat queue id:65538
[ 26.674965] autorun-usecase.sh[113]: queue id:65538
[ 26.680292] autorun-usecase.sh[113]: Creat queue id:98307
[ 26.683444] autorun-usecase.sh[113]: queue id:98307
[ 26.700132] autorun-usecase.sh[113]: queue id:32769
[ 26.748434] autorun-usecase.sh[113]: [host] Attached to slave procId 1.
[ 28.597455] autorun-usecase.sh[113]: [host] Attached to slave procId 0.
[ 28.599623] autorun-usecase.sh[113]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[ 29.612487] autorun-usecase.sh[113]: [host] Started slave procId 1.
[ 29.614791] autorun-usecase.sh[113]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[ 29.692043] autorun-usecase.sh[113]: [host] Started slave procId 0.
[ 29.693979] autorun-usecase.sh[113]: [host] After Ipc_loadcallback status [0x00000000]
[ 29.695665] autorun-usecase.sh[113]: [host] After Ipc_loadcallback status [0x00000000]
[ 29.777595] autorun-usecase.sh[113]: [host] After Ipc_startcallback status [0x00000000]
[ 29.813390] autorun-usecase.sh[113]: [host] After Ipc_startcallback status [0x00000000]
[ 29.877530] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 29.879334] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 29.885056] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 29.889438] autorun-usecase.sh[113]: [m3vpss ] Received character 's'
[ 29.978371] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 29.980498] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 29.988593] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 30.000564] autorun-usecase.sh[113]: [m3video] Received character 's'
[ 30.002729] autorun-usecase.sh[113]: queue id:65538
[ 30.010174] autorun-usecase.sh[113]: Creat queue id:131076
[ 30.014561] autorun-usecase.sh[113]: queue id:131076
[ 30.016387] autorun-usecase.sh[113]: CPU is TI812x
[ 30.024771] autorun-usecase.sh[113]: vsenable : 0
[ 30.121784] autorun-usecase.sh[113]: Creat queue id:163845
[ 30.125008] autorun-usecase.sh[113]: queue id:163845
[ 30.128456] autorun-usecase.sh[113]: queue id:65538
[ 30.955648] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 30.957444] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 30.958847] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.005039] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.006811] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.011006] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.025357] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 31.027133] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 31.028659] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 31.030224] autorun-usecase.sh[113]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 31.036220] autorun-usecase.sh[113]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 31.050417] autorun-usecase.sh[113]: [m3video]
[ 31.053712] autorun-usecase.sh[113]: [m3vpss ] notify_attach rtnVal 0
[ 31.061444] autorun-usecase.sh[113]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 31.063659] autorun-usecase.sh[113]: [m3video]
[ 31.065250] autorun-usecase.sh[113]: [m3video] 35: SYSTEM : System Common Init in progress !!!
[ 31.066841] autorun-usecase.sh[113]: [m3video] 36: SYSTEM: IPC init in progress !!!
[ 31.068383] autorun-usecase.sh[113]: [m3video] 36: SYSTEM: Attaching to [HOST] ...
[ 31.069881] autorun-usecase.sh[113]: [m3video] 85: SYSTEM: Attaching to [HOST] ...
[ 31.071449] autorun-usecase.sh[113]: [m3vpss ] initProxyServer rtnVal 0
[ 31.072908] autorun-usecase.sh[113]: [m3vpss ]
[ 31.074389] autorun-usecase.sh[113]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 31.075859] autorun-usecase.sh[113]: [m3vpss ]
[ 31.077505] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 31.079009] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM: IPC init in progress !!!
[ 31.080566] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM: Attaching to [HOST] ...
[ 31.082081] autorun-usecase.sh[113]: [m3video] 91: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 31.083627] autorun-usecase.sh[113]: [m3video] 91: SYSTEM: Attaching to [VPSS-M3] ...
[ 31.085150] autorun-usecase.sh[113]: [m3vpss ] 117: SYSTEM: Attaching to [HOST] ...
[ 31.086788] autorun-usecase.sh[113]: [m3vpss ] 126: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 31.088303] autorun-usecase.sh[113]: [m3vpss ] 126: SYSTEM: Attaching to [VIDEO-M3] ...
[ 31.089828] autorun-usecase.sh[113]: [m3video] 140: SYSTEM: Attaching to [VPSS-M3] ...
[ 31.091386] autorun-usecase.sh[113]: [m3video] 177: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 31.092828] autorun-usecase.sh[113]: [m3vpss ] 176: SYSTEM: Attaching to [VIDEO-M3] ...
[ 31.094543] autorun-usecase.sh[113]: [m3video] 177: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.096047] autorun-usecase.sh[113]: [m3vpss ] 177: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 31.097851] autorun-usecase.sh[113]: [m3vpss ] 177: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.099309] autorun-usecase.sh[113]: [m3vpss ] 177: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 31.100842] autorun-usecase.sh[113]: [m3vpss ] 178: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 31.102353] autorun-usecase.sh[113]: [m3vpss ] 179: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 31.103820] autorun-usecase.sh[113]: [m3vpss ] 180: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 31.105311] autorun-usecase.sh[113]: [m3vpss ] 180: SYSTEM: IPC init DONE !!!
[ 31.106766] autorun-usecase.sh[113]: [m3vpss ] 191: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 31.108477] autorun-usecase.sh[113]: [m3vpss ] 191: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 31.110091] autorun-usecase.sh[113]: [m3vpss ] 193: SYSTEM : System Common Init Done !!!
[ 31.111601] autorun-usecase.sh[113]: [m3video] 276: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 31.113092] autorun-usecase.sh[113]: [m3video] 277: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 31.114537] autorun-usecase.sh[113]: [m3video] 277: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 31.115963] autorun-usecase.sh[113]: [m3video] 279: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 31.117557] autorun-usecase.sh[113]: [m3video] 279: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 31.119113] autorun-usecase.sh[113]: [m3video] 280: SYSTEM: IPC init DONE !!!
[ 31.120705] autorun-usecase.sh[113]: [m3video] 290: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 31.122188] autorun-usecase.sh[113]: [m3video] 291: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 31.123658] autorun-usecase.sh[113]: [m3video] 293: SYSTEM : System Common Init Done !!!
[ 31.125155] autorun-usecase.sh[113]: [m3vpss ] 1293: SYSTEM : System VPSS Init in progress !!!
[ 31.126594] autorun-usecase.sh[113]: [m3vpss ] === I2C0/2 Clk is active ===
[ 31.128139] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 31.129587] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 31.131311] autorun-usecase.sh[113]: [m3vpss ] 1312: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 31.132788] autorun-usecase.sh[113]: [m3vpss ] 1312: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 31.134280] autorun-usecase.sh[113]: [m3vpss ] 1313: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 31.466713] autorun-usecase.sh[113]: [m3vpss ] 1315: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 31.468273] autorun-usecase.sh[113]: [m3vpss ] 1315: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 31.469757] autorun-usecase.sh[113]: [m3vpss ] 1316: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 31.471554] autorun-usecase.sh[113]: [m3vpss ] 1329: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 31.473065] autorun-usecase.sh[113]: [m3vpss ] 1329: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 31.474519] autorun-usecase.sh[113]: [m3vpss ] 1329: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 31.475960] autorun-usecase.sh[113]: [m3vpss ] 1332: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 31.477500] autorun-usecase.sh[113]: [m3vpss ] 1332: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 31.478970] autorun-usecase.sh[113]: [m3vpss ] 1333: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[ 31.480530] autorun-usecase.sh[113]: [m3vpss ] 1335: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 31.482061] autorun-usecase.sh[113]: [m3vpss ] 1336: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 31.483525] autorun-usecase.sh[113]: [m3vpss ] 1336: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[ 32.500292] autorun-usecase.sh[113]: [m3vpss ] 1342: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUApproDrvInit: 7
[ 32.502114] autorun-usecase.sh[113]: queue id:163845
[ 34.654813] autorun-usecase.sh[113]: queue id:0
[ 36.542384] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 36.544203] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 36.545635] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 36.552587] autorun-usecase.sh[113]: [m3vpss ] Received character 't'
[ 36.571554] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 36.573273] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 36.574664] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 36.575960] autorun-usecase.sh[113]: [m3video] Received character 't'
[ 36.607118] autorun-usecase.sh[113]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 36.675278] DMA: Module install successful, device major num = 244
[ 36.681659] DRV: Module install successful
[ 36.685776] DRV: Module built on Feb 13 2017 19:26:20
[ 36.790036]
[ 36.790036] soc_is_dm38x
[ 36.863583] autorun-usecase.sh[113]: ApproDrvInit: 3
[ 36.897990] HDMI W1 rev 4.0
[ 36.900868] HDMI CEC Spec version 1.2
[ 36.889256] autorun-usecase.sh[113]: queue id:163845
[ 37.277206] I2C No Ack
[ 37.279706] HDMI failed to read E-EDID
[ 37.765204] autorun-usecase.sh[113]: [host]
[ 37.768473] autorun-usecase.sh[113]: [host] ORG 0x46c00524: 0
[ 37.770301] autorun-usecase.sh[113]: [host] NEW 0x46c00524: 2
[ 37.772059] autorun-usecase.sh[113]: [host]
[ 37.773809] autorun-usecase.sh[113]: [host] Application Start Completed
[ 37.874505] autorun-usecase.sh[113]: [host] 0: SYSTEM: System Common Init in progress !!!
[ 37.876705] autorun-usecase.sh[113]: [host] 0: SYSTEM: IPC init in progress !!!
[ 37.879850] autorun-usecase.sh[113]: [host] 12: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 37.883035] autorun-usecase.sh[113]: [ 37.917814] DMA: ChannelID allocated:4
[host] 12: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
[ 37.889209] autorun-usecase.sh[113]: [host] 12: SYSTEM: CPU [VPSS-M3] syslink proc ID is [1] !!!
[ 37.893922] autorun-usecase.sh[113]: [host] 13: SYSTEM: CPU [HOST] syslink proc I[ 37.943103] DMA: ChannelID allocated:5
D is [2] !!!
[ 37.907986] autorun-usecase.sh[113]: [host] 13: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 37.909913] autorun-usecase.sh[113]: [host] 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[ 37.911942] autorun-usecase.sh[113]: [host] 14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[ 37.924074] autorun-usecase.sh[113]: [host] 14: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 37.935108] autorun-usecase.sh[113]: [host] 14: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 37.939472] autorun-usecase.sh[113]: [host] 16: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 37.941933] autorun-usecase.sh[113]: [host] 16: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 37.943938] autorun-usecase.sh[113]: [host] 16: SYSTEM: IPC init DONE !!!
[ 37.945766] autorun-usecase.sh[113]: [host] 17: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[ 37.949689] autorun-usecase.sh[113]: [host] 18: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[ 37.952520] autorun-usecase.sh[113]: [host] 18: SYSTEM: ListElem Shared Addr = 0xb55c2580
[ 37.956594] autorun-usecase.sh[113]: [host] 20: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[ 37.958427] autorun-usecase.sh[113]: [host] 20: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[ 37.960195] autorun-usecase.sh[113]: [host] 20: SYSTEM: ListElem Shared Addr = 0xb55dc200
[ 37.961855] autorun-usecase.sh[113]: [host] 22: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[ 37.963555] autorun-usecase.sh[113]: [host] 22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[ 37.965128] autorun-usecase.sh[113]: [host] 22: SYSTEM: ListElem Shared Addr = 0xb55f5e80
[ 37.966875] autorun-usecase.sh[113]: [host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[ 37.968498] autorun-usecase.sh[113]: [host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[ 37.970181] autorun-usecase.sh[113]: [host] 24: SYSTEM: ListElem Shared Addr = 0xb5615880
[ 37.972896] autorun-usecase.sh[113]: [host] 26: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[ 37.974867] autorun-usecase.sh[113]: [host] 26: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[ 37.976623] autorun-usecase.sh[113]: [host] 27: SYSTEM: ListElem Shared Addr = 0xb5635280
[ 37.978299] autorun-usecase.sh[113]: [host] 28: SYSTEM: System Common Init Done !!!
[ 37.979981] autorun-usecase.sh[113]: [host] Vsys_allocBuf - addr = 0xa736b000,size = 65011712
[ 37.981715] autorun-usecase.sh[113]: ##########pInfo->totalsize 63897600
[ 37.983917] autorun-usecase.sh[113]: queue id:0
[ 37.985587] autorun-usecase.sh[113]: queue id:32769
[ 37.987365] autorun-usecase.sh[113]: [host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[ 37.989005] autorun-usecase.sh[113]: [host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[ 37.990765] autorun-usecase.sh[113]: [host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[ 37.992384] autorun-usecase.sh[113]: [host] Vsys_allocBuf - addr = 0xb6efe000,size = 33603
[ 37.994201] autorun-usecase.sh[113]: [host] DCC buffer allocated for size 33603
[ 37.995931] autorun-usecase.sh[113]: [host] DCC Default File Intialization Done
[ 37.997630] autorun-usecase.sh[113]: [host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[ 38.025528] autorun-usecase.sh[113]: [host]
[ 38.027817] autorun-usecase.sh[113]: ********** FULL FEATURE USECASE ********
[ 38.029600] autorun-usecase.sh[113]: [host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[ 38.031441] autorun-usecase.sh[113]: [host] 157: MCFW : CPU Revision [ES1.0] !!!
[ 38.033180] autorun-usecase.sh[113]: [host] 157: MCFW : Detected [UNKNOWN] Board !!!
[ 38.034854] autorun-usecase.sh[113]: [host] 157: MCFW : Base Board Revision [REV A] !!!
[ 38.047142] autorun-usecase.sh[113]: T_29] in region 0 ...
[ 38.048951] autorun-usecase.sh[113]: [m3vpss ] 1342: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 38.050857] autorun-usecase.sh[113]: [m3vpss ] 1343: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[ 38.052622] autorun-usecase.sh[113]: [m3vpss ] 1345: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 38.054520] autorun-usecase.sh[113]: [m3vpss ] 1345: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 38.056288] autorun-usecase.sh[113]: [m3vpss ] 1346: SYSTEM: ListElem Shared Addr = 0xbea03600
[ 38.058099] autorun-usecase.sh[113]: [m3vpss ] 1348: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 38.059786] autorun-usecase.sh[113]: [m3vpss ] 1348: SYSTEM : FVID2 Init in progress !!!
[ 38.061561] autorun-usecase.sh[113]: [m3video] 1392: SYSTEM : System Video Init in progress !!!
[ 38.063246] autorun-usecase.sh[113]: [m3video] 1393: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 38.064961] autorun-usecase.sh[113]: [m3video] 1393: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 38.066558] autorun-usecase.sh[113]: [m3video] 1394: SYSTEM: ListElem Shared Addr = 0xbea1d280
[ 38.068314] autorun-usecase.sh[113]: [m3video] 1396: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 38.069928] autorun-usecase.sh[113]: [m3video] 1396: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 38.071668] autorun-usecase.sh[113]: [m3video] 1397: SYSTEM: ListElem Shared Addr = 0xbea20780
[ 38.073516] autorun-usecase.sh[113]: [m3video] 1406: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 38.405548] autorun-usecase.sh[113]: [m3video] 1407: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 38.407373] autorun-usecase.sh[113]: [m3video] 1407: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 38.409132] autorun-usecase.sh[113]: [m3video] 1409: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 38.410977] autorun-usecase.sh[113]: [m3video] 1410: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 38.412676] autorun-usecase.sh[113]: [m3video] 1410: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 38.414332] autorun-usecase.sh[113]: [m3video] 1412: HDVICP: Doing PRCM for IVAHD[0] ...
[ 38.416019] autorun-usecase.sh[113]: [m3video] 1412: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 38.417639] autorun-usecase.sh[113]: [m3video] 1413: SYSTEM : Initializing Links !!!
[ 38.419273] autorun-usecase.sh[113]: [m3video] 1413: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 38.421096] autorun-usecase.sh[113]: [m3vpss ] 1419: SYSTEM : FVID2 Init in progress DONE !!!
[ 38.421651] autorun-usecase.sh[113]: [m3vpss ] 1419: SYSTEM : Device Init in progress !!!
[ 38.422188] autorun-usecase.sh[113]: [m3video] 1414: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 38.422673] autorun-usecase.sh[113]: [m3vpss ] Iss_init called !!!!!!
[ 38.423131] autorun-usecase.sh[113]: [m3video] 1414: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 38.423655] autorun-usecase.sh[113]: [m3vpss ] CPIS_init DONE !!!!!!
[ 38.424296] autorun-usecase.sh[113]: [m3video] 1414: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 38.424874] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 38.425344] autorun-usecase.sh[113]: [m3video] 1415: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 38.425891] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 38.426383] autorun-usecase.sh[113]: [m3video] 1415: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 38.426903] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_init()
[ 38.427351] autorun-usecase.sh[113]: [m3video] 1474: SYSTEM : Initializing Links ... DONE !!!
[ 38.427850] autorun-usecase.sh[113]: [m3video] 1475: SYSTEM : System Video Init Done !!!
[ 38.428302] autorun-usecase.sh[113]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 38.428780] autorun-usecase.sh[113]: [m3vpss ] 1613: SYSTEM : Device Init in progress DONE !!!
[ 38.429229] autorun-usecase.sh[113]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 38.429670] autorun-usecase.sh[113]: [m3vpss ] 6722: SYSTEM : System VPSS Init Done !!!
[ 38.430273] autorun-usecase.sh[113]: [m3vpss ] 6722: UTILS: DMA: HWI Create for INT62 !!!
[ 38.430740] autorun-usecase.sh[113]: [m3vpss ] 6723: SYSTEM : Initializing Links !!!
[ 38.431269] autorun-usecase.sh[113]: [m3vpss ] 6723: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 38.431757] autorun-usecase.sh[113]: [m3vpss ] 6723: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 38.432260] autorun-usecase.sh[113]: [m3vpss ] 6723: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 38.432707] autorun-usecase.sh[113]: [m3vpss ] 6724: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 38.433195] autorun-usecase.sh[113]: [m3vpss ] 6724: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 38.433648] autorun-usecase.sh[113]: [m3vpss ] 6854: SYSTEM : Initializing Links ... DONE !!!
[ 38.434089] autorun-usecase.sh[113]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 38.434599] autorun-usecase.sh[113]: [m3vpss ] VPS_DCTRL_INST_0
[ 38.435035] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 38.435527] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 38.435970] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 38.767855] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 38.768483] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 38.768981] autorun-usecase.sh[113]: [m3vpss ] HDCOMPCLK
[ 38.769441] autorun-usecase.sh[113]: [m3vpss ] 8278: CAMERA: Create in progress !!!
[ 38.769894] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ [ 38.860758] DMA: ChannelID allocated:6
38.770898] autorun-usecase.sh[113]: [m3vpss ] Channel Num St[ 38.866741] DMA: ChannelID allocated:7
[ 38.771592] autorun-usecase.sh[113]: [m3vpss ] 8278: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 38.772425] autorun-usecase.sh[113]: [m3vpss ] 8279: CAMERA: VIP 0: VID DEC 268436737 (0x10): 00queue id:0
[ 38.860403] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[ 38.861244] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[ 38.943875] DMA: ChannelID allocated:12
[ 38.931150] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[ 39.173255] autorun-usecase.sh[113]: 02:20202020:20202020, AUD_STATUS 538976288
[ 39.174166] autorun-usecase.sh[113]: [m3vpss ] Iss_captCreate:1661
[ 39.174836] autorun-usecase.sh[113]: [m3vpss ] 8488: CAMERA: Create Done !!!
[ 39.175500] autorun-usecase.sh[113]: [m3vpss ] 8577: CAMERA: Detect video in progress !!!
[ 39.176083] autorun-usecase.sh[113]: [m3vpss ] 8577: CAMERA: Detect video Done !!!
[ 39.176726] autorun-usecase.sh[113]: [m3video] 8651: IPC_IN_M3 : Create in progress !!!
[ 39.177296] autorun-usecase.sh[113]: [m3vpss ] 8649: DUP : Create Done !!!
[ 39.177976] autorun-usecase.sh[113]: [m3video] 8652: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 39.178600] autorun-usecase.sh[113]: [m3vpss ] 8649: IPC_OUT_M3 : Create in progress !!!
[ 39.179176] autorun-usecase.sh[113]: [m3video] 8652: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 39.179784] autorun-usecase.sh[113]: [m3vpss ] 8651: IPC_OUT_M3 : Create Done !!!
[ 39.180442] autorun-usecase.sh[113]: [m3video] 8655: IPC_IN_M3 : Create Done !!!
[ 39.181087] autorun-usecase.sh[113]: [m3vpss ] DCC server task running
[ 39.181654] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_tskMain()
[ 39.182298] autorun-usecase.sh[113]: [m3video] inChInfo->width = 1920
[ 39.182854] autorun-usecase.sh[113]: [m3video] inChInfo->height = 1080
[ 39.183512] autorun-usecase.sh[113]: [m3video] inChInfo->pitch[0] = 1984
[ 39.184158] autorun-usecase.sh[113]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 39.184749] autorun-usecase.sh[113]: [m3video] [MCTNF] startX = 0
[ 39.185370] autorun-usecase.sh[113]: [m3vpss ] 8834: IPC_IN_M3 : Create in progress !!!
[ 39.185967] autorun-usecase.sh[113]: [m3video] [MCTNF] startY = 0
[ 39.186580] autorun-usecase.sh[113]: [m3vpss ] 8834: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 39.187141] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->width = 1920
[ 39.187781] autorun-usecase.sh[113]: [m3vpss ] 8835: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 39.188347] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->height = 1080
[ 39.188969] autorun-usecase.sh[113]: [m3vpss ] 8836: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 39.189570] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 39.190194] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 39.190863] autorun-usecase.sh[113]: [m3video] 8832: IPC_OUT_M3 : Create in progress !!!
[ 39.191433] autorun-usecase.sh[113]: [m3video] 8834: IPC_OUT_M3 : Create Done !!!
[ 39.192078] autorun-usecase.sh[113]: [m3vpss ] 8838: IPC_IN_M3 : Create Done !!!
[ 39.192644] autorun-usecase.sh[113]: [m3vpss ] 8773: VNF:
[ 39.193316] autorun-usecase.sh[113]: [m3vpss ] Create in progress ... !!!
[ 39.193876] autorun-usecase.sh[113]: [m3vpss ] 8774: VNF:
[ 39.194486] autorun-usecase.sh[113]: [m3vpss ] Input Channel CH0 of 1920 x 1080, pitch = (1984, 1984) [0,0][PROGRESSIVE] [7] ...
[ 39.195085] autorun-usecase.sh[113]: [m3vpss ] 8774: VNF:
[ 39.195654] autorun-usecase.sh[113]: [m3vpss ] [VNF] eOperateMode=7 [6-TNF3,7-NSF2]chVnfCreateParams->ulStartX = -16 chVnfCreateParams->ulStartY = -18 chVnfCreateParams->ulInputStride = 1984 chVnfCreateParams->ulInp
reading u-boot.img
reading u-boot.img
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
cpsw
reading uImage
2662320 bytes read in 304 ms (8.4 MiB/s)
Starting kernel ...
[ 0.008263] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 95563022313 ns
[ 0.017839] OMAP clocksource: timer1 at 20000000 Hz
[ 0.023135] Console: colour dummy device 80x30
[ 0.027838] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.086905] pid_max: default: 32768 minimum: 301
[ 0.091855] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098768] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.106808] Initializing cgroup subsys io
[ 0.111041] Initializing cgroup subsys memory
[ 0.115663] Initializing cgroup subsys devices
[ 0.120336] Initializing cgroup subsys freezer
[ 0.125017] Initializing cgroup subsys pids
[ 0.129429] CPU: Testing write buffer coherency: ok
[ 0.134886] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.142701] devtmpfs: initialized
[ 0.168778] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.217182] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.229313] pinctrl core: initialized pinctrl subsystem
[ 0.236106] NET: Registered protocol family 16
[ 0.242347] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.255298] OMAP GPIO hardware version 0.1
[ 0.267882] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
[ 0.301593] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.309856] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.323463] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.337134] media: Linux media interface: v0.10
[ 0.341949] Linux video capture interface: v2.00
[ 0.346859] pps_core: LinuxPPS API ver. 1 registered
[ 0.352054] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.361582] PTP clock support registered
[ 0.365724] EDAC MC: Ver: 3.0.0
[ 0.369783] Advanced Linux Sound Architecture Driver Initialized.
[ 0.377180] clocksource: Switched to clocksource timer1
[ 0.399994] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.407307] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.413945] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.420666] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.426769] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.433490] NET: Registered protocol family 1
[ 0.438446] RPC: Registered named UNIX socket transport module.
[ 0.444629] RPC: Registered udp transport module.
[ 0.449588] RPC: Registered tcp transport module.
[ 0.454514] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462555] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.469666] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.486657] NFS: Registering the id_resolver key type
[ 0.492053] Key type id_resolver registered
[ 0.496445] Key type id_legacy registered
[ 0.502333] io scheduler noop registered
[ 0.506471] io scheduler deadline registered
[ 0.517552] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
[ 0.598693] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.609706] console [ttyS0] disabled
[ 0.613521] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 3000000) is a 8250
[ 0.622480] console [ttyS0] enabled
[ 0.629673] bootconsole [earlycon0] disabled
[ 0.639470] Reference Linux version 4.4.12
[ 0.643767] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script/TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.662311] allocated heap buffer 0xc8000000 of size 0x4000000
[ 0.668211] cmemk initialized
[ 0.678595] loop: module loaded
[ 0.747238] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
[ 0.753375] libphy: 4a100800.mdio: probed
[ 0.758280] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, driver TI DP83867
[ 0.767272] cpsw 4a100000.ethernet: Detected MACID = 7c:66:9d:f8:c5:0c
[ 0.777373] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.807450] mousedev: PS/2 mouse device common for all mice
[ 0.813555] omap_rtc 480c0000.rtc: already running
[ 0.818825] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
[ 0.826248] i2c /dev entries driver
[ 0.830762] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 0.837884] sdhci: Secure Digital Host Controller Interface driver
[ 0.844093] sdhci: Copyright(c) Pierre Ossman
[ 0.972675] omap_hsmmc 48060000.mmc: card claims to support voltages below defined range
[ 0.991818] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 0.998071] mmc0: new high speed SDIO card at address 0001
[ 1.013953] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.020938] notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
[ 1.027097] notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbfd00000
[ 1.038847] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 1.046122] davinci_evm sound: snd_soc_register_card failed (-517)
[ 1.053594] NET: Registered protocol family 10
[ 1.060459] sit: IPv6 over IPv4 tunneling driver
[ 1.065934] NET: Registered protocol family 17
[ 1.070586] Key type dns_resolver registered
[ 1.075119] omap_voltage_late_init: Could not get sys clk.
[ 1.081025] Power Management for TI81XX.
[ 1.090288] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.095473] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.103085] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.109546] nand: Micron MT29F2G16ABAEAWP
[ 1.113580] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.121216] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.126632] 8 ofpart partitions found on MTD device 8000000.nand
[ 1.132686] Creating 8 MTD partitions on "8000000.nand":
[ 1.138046] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.147812] 0x000000020000-0x000000420000 : "NAND.u-boot"
[ 1.155957] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
[ 1.163075] 0x000000440000-0x000000a40000 : "NAND.kernel"
[ 1.172153] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
[ 1.181941] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.197260] mmc1: new high speed SDHC card at address 0007
[ 1.217234] mmcblk0: mmc1:0007 SD16G 14.5 GiB
[ 1.223210] mmcblk0: p1 p2
[ 1.271170] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
[ 1.278551] 0x00000ca80000-0x00000d680000 : "NAND.data"
[ 1.289316] 0x00000d680000-0x000010000000 : "NAND.reserved"
[ 1.354075] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1
[ 1.361775] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.369263] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.376066] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
[ 1.383138] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 1.392553] omap_rtc 480c0000.rtc: setting system clock to 2016-12-06 07:41:37 UTC (1481010097)
[ 1.414479] wlan-en-regulator: disabling
[ 1.418840] ALSA device list:
[ 1.421828] #0: TI81XX-CSK
[ 1.426808] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 9.593906] EXT4-fs (mmcblk0p2): recovery complete
[ 9.607282] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 9.615473] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 9.630675] devtmpfs: mounted
[ 9.634258] Freeing unused kernel memory: 276K (c067f000 - c06c4000)
[ 9.640671] This architecture does not have kernel memory protection.
[ 9.900629] random: systemd urandom read with 29 bits of entropy available
[ 9.921253] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 9.940046] systemd[1]: Detected architecture arm.
[ 9.969281] systemd[1]: Set hostname to <ti81xx>.
[ 10.257153] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-usecase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.408519] systemd[1]: Listening on udev Kernel Socket.
[ 10.427741] systemd[1]: Listening on udev Control Socket.
[ 10.447768] systemd[1]: Listening on Journal Socket.
[ 10.467478] systemd[1]: Reached target Swap.
[ 10.487626] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 10.517443] systemd[1]: Reached target Remote File Systems.
[ 10.541411] systemd[1]: Created slice System Slice.
[ 10.561409] systemd[1]: Mounting POSIX Message Queue File System...
[ 10.595458] systemd[1]: Mounting Temporary Directory...
[ 10.651367] systemd[1]: Starting Synchronize System and HW clocks...
[ 10.702666] systemd[1]: Mounting /var/volatile...
[ 10.752478] systemd[1]: Mounting /media/ram...
[ 10.771720] systemd[1]: Starting udev Kernel Device Manager...
[ 10.852353] systemd[1]: Starting udev Coldplug all Devices...
[ 10.887970] systemd[1]: Listening on Syslog Socket.
[ 10.956746] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 10.977830] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.001674] systemd[1]: Starting Journal Service...
[ 11.051469] systemd[1]: Listening on Network Service Netlink Socket.
[ 11.087626] systemd[1]: Reached target Slices.
[ 11.107693] systemd[1]: Reached target Timers.
[ 11.127938] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ [0;32m OK [0m] Started Dispatch Password Requests to Console Directory Watch.
[ 11.149056] systemd[1]: Created slice system-getty.slice.
[ 11.177946] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.207503] systemd[1]: Reached target Paths.
[ 11.240329] systemd[1]: Mounted POSIX Message Queue File System.
[ 11.277667] systemd[1]: Mounted Temporary Directory.
[ 11.297596] systemd[1]: Mounted /var/volatile.
[ 11.317565] systemd[1]: Mounted /media/ram.
[ 11.338441] systemd[1]: Started udev Kernel Device Manager.
[ 11.358192] systemd[1]: Started Journal Service.
[ 12.461024] autorun-usecase.sh[114]: numid=1,iface=MIXER,name='PCM Playback Volume'
[ 12.482008] autorun-usecase.sh[114]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
[ 12.502765] autorun-usecase.sh[114]: : values=115,115
[ 12.542540] autorun-usecase.sh[114]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
[ 12.597399] autorun-usecase.sh[114]: numid=31,iface=MIXER,name='PGA Capture Volume'
[ 12.623311] autorun-usecase.sh[114]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
[ 12.652222] autorun-usecase.sh[114]: : values=72,72
[ 12.672117] autorun-usecase.sh[114]: | dBscale-min=0.00dB,step=0.50dB,mute=0
[ 12.702689] autorun-usecase.sh[114]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
[ 12.731953] autorun-usecase.sh[114]: ; type=BOOLEAN,access=rw------,values=1
[ 12.752152] autorun-usecase.sh[114]: : values=on
[ 12.772576] autorun-usecase.sh[114]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
[ 12.801950] autorun-usecase.sh[114]: ; type=BOOLEAN,access=rw------,values=1
[ 12.822642] autorun-usecase.sh[114]: : values=on
[ 12.858962] autorun-usecase.sh[114]: Mount mtd6 and mtd7 partitions
[ 12.996828] ubi0: attaching mtd6
[ 13.106697] net eth0: initializing cpsw version 1.10 (0)
[ 13.112123] net eth0: initialized cpsw ale version 1.3
[ 13.120612] net eth0: phy found : id is : 0x2000a231
[ 13.125651] libphy: PHY not found
[ 13.129101] net eth0: phy "" not found on slave 1, err -19
[ 13.205207] ubi0: scanning is finished
[ 13.259480] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.280633] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 13.286605] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 13.293587] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 13.300340] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 13.307365] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 13.313312] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 13.320586] ubi0: max/mean erase counter: 9/4, WL threshold: 4096, image sequence number: 2667817441
[ 13.329778] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
[ 13.339461] ubi0: background thread "ubi_bgt0d" started, PID 148
[ 13.543786] autorun-usecase.sh[114]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 14.167291] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 152
[ 14.242249] UBIFS (ubi0:0): recovery needed
[ 14.515453] UBIFS (ubi0:0): recovery completed
[ 14.520096] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
[ 14.528089] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 14.538070] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 14.548220] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 14.554700] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID AA21A384-4ECC-4F1F-BA8C-EBB1D35EBD16, small LPT model
[ 15.348550] ubi1: attaching mtd7
[ 15.643683] ubi1: scanning is finished
[ 15.705321] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 15.711723] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 15.718658] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 15.725391] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 15.732404] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 15.738453] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 15.745712] ubi1: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 3383995126
[ 15.754901] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 15.767264] ubi1: background thread "ubi_bgt1d" started, PID 172
[ 15.794416] autorun-usecase.sh[114]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 16.347395] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 182
[ 16.375500] UBIFS (ubi1:0): recovery needed
[ 16.395210] UBIFS (ubi1:0): recovery completed
[ 16.399868] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 16.407865] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 16.417847] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 16.428346] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 16.434999] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID EBC3BFCA-673F-4B1C-B1F6-5BF526D40A9C, small LPT model
[ 16.950679] autorun-usecase.sh[114]: wifi: in STA mode
_____ _____ _ _
|___| |___|
ti81xx login: [ 20.816805] cfg80211: World regulatory domain updated:
[ 20.822074] cfg80211: DFS Master region: unset
[ 20.826453] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 20.836281] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.844342] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.852398] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.860459] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 20.870002] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 20.879544] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 20.887688] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.895730] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 21.328607] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 21.727848] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 21.754893] wlcore: loaded
[ 22.365915] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 22.468547] random: nonblocking pool is initialized
[ 22.476792] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 22.495152] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 23.118102] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 23.126038] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 26.638146] autorun-usecase.sh[114]: SSID: gaff
[ 26.639934] autorun-usecase.sh[114]: SSID: TP-LINK_THW
[ 26.643494] autorun-usecase.sh[114]: SSID: nosi
[ 26.650116] autorun-usecase.sh[114]: SSID: TP-LINK_A394
[ 26.651989] autorun-usecase.sh[114]: SSID: gaff
[ 27.052270] <1>SysLink version : 2.21.02.10
[ 27.052270] SysLink module created on Date:Feb 13 2017 Time:19:16:30
[ 27.062938] <1>Trace enabled
[ 27.065834] <1>Trace SetFailureReason enabled
[ 27.158084] autorun-usecase.sh[114]: /dev/mem opened.
[ 27.159818] autorun-usecase.sh[114]: Phy Addr : 0x48181560 Data : 0x00000002
[ 27.166784] autorun-usecase.sh[114]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 27.176435] autorun-usecase.sh[114]: Phy Addr : 0x48180508 Data : 0x00000302
[ 27.178333] autorun-usecase.sh[114]: Phy Addr : 0x48180520 Data : 0x00000002
[ 27.182322] autorun-usecase.sh[114]: Phy Addr : 0x48180524 Data : 0x00000002
[ 27.184047] autorun-usecase.sh[114]: Phy Addr : 0x48180528 Data : 0x00000002
[ 27.185539] autorun-usecase.sh[114]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 27.187034] autorun-usecase.sh[114]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 27.188423] autorun-usecase.sh[114]: DDR IOs RX is shutdown
[ 27.190265] autorun-usecase.sh[114]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 28.122677] autorun-usecase.sh[114]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (228) - No such process
[ 28.146097] autorun-usecase.sh[114]: [host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[ 28.153014] autorun-usecase.sh[114]: [host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[ 28.158768] autorun-usecase.sh[114]: [host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[ 28.163435] autorun-usecase.sh[114]: [host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[ 28.239192] autorun-usecase.sh[114]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 29.261371] autorun-usecase.sh[114]: mkfs.fat 3.0.28 (2015-05-16)
[ 29.263642] autorun-usecase.sh[114]: unable to get drive geometry, using default 255/63
[ 29.267204] autorun-usecase.sh[114]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 29.272644] autorun-usecase.sh[114]: hidden sectors 0x0000;
[ 29.274479] autorun-usecase.sh[114]: logical sector size is 512,
[ 29.279535] autorun-usecase.sh[114]: using 0xf8 media descriptor, with 1024 sectors;
[ 29.282761] autorun-usecase.sh[114]: drive number 0x80;
[ 29.286493] autorun-usecase.sh[114]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 29.289051] autorun-usecase.sh[114]: FAT size is 1 sector, and provides 247 clusters.
[ 29.292127] autorun-usecase.sh[114]: There is 1 reserved sector.
[ 29.298841] autorun-usecase.sh[114]: Root directory contains 512 slots and uses 32 sectors.
[ 29.300531] autorun-usecase.sh[114]: Volume ID is bcd5d89f, no volume label.
[ 29.525327] Mass Storage Function, version: 2009/09/11
[ 29.530589] LUN: removable file: (no medium)
[ 29.535238] LUN: removable file: /dev/sbulla
[ 29.539593] Number of LUNs=1
[ 29.574655] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 29.581717] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 29.588831] g_mass_storage gadget: g_mass_storage ready
[ 29.644450] autorun-usecase.sh[114]: Creat queue id:0
[ 29.646704] autorun-usecase.sh[114]: queue id:0
[ 29.650293] autorun-usecase.sh[114]: Creat queue id:32769
[ 29.653530] autorun-usecase.sh[114]: queue id:32769
[ 29.663080] autorun-usecase.sh[114]: Creat queue id:65538
[ 29.665043] autorun-usecase.sh[114]: queue id:65538
[ 29.670284] autorun-usecase.sh[114]: Creat queue id:98307
[ 29.673446] autorun-usecase.sh[114]: queue id:98307
[ 29.683302] autorun-usecase.sh[114]: queue id:32769
[ 29.735589] autorun-usecase.sh[114]: [host] Attached to slave procId 1.
[ 31.595946] autorun-usecase.sh[114]: [host] Attached to slave procId 0.
[ 31.598334] autorun-usecase.sh[114]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[ 32.625609] autorun-usecase.sh[114]: [host] Started slave procId 1.
[ 32.630831] autorun-usecase.sh[114]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[ 32.709371] autorun-usecase.sh[114]: [host] Started slave procId 0.
[ 32.711548] autorun-usecase.sh[114]: [host] After Ipc_loadcallback status [0x00000000]
[ 32.713307] autorun-usecase.sh[114]: [host] After Ipc_loadcallback status [0x00000000]
[ 32.796085] autorun-usecase.sh[114]: [host] After Ipc_startcallback status [0x00000000]
[ 32.831975] autorun-usecase.sh[114]: [host] After Ipc_startcallback status [0x00000000]
[ 32.890615] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.892432] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 32.897635] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 32.902156] autorun-usecase.sh[114]: [m3vpss ] Received character 's'
[ 32.991203] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.993000] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.000362] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.010563] autorun-usecase.sh[114]: [m3video] Received character 's'
[ 33.014463] autorun-usecase.sh[114]: queue id:65538
[ 33.020157] autorun-usecase.sh[114]: Creat queue id:131076
[ 33.024609] autorun-usecase.sh[114]: queue id:131076
[ 33.030296] autorun-usecase.sh[114]: CPU is TI812x
[ 33.034731] autorun-usecase.sh[114]: vsenable : 0
[ 33.142726] autorun-usecase.sh[114]: Creat queue id:163845
[ 33.146265] autorun-usecase.sh[114]: queue id:163845
[ 33.152974] autorun-usecase.sh[114]: queue id:65538
[ 33.947930] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.949731] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.952858] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.999296] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 34.001165] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 34.002549] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 34.034746] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 34.036483] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 34.037849] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 34.039127] autorun-usecase.sh[114]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 34.063073] autorun-usecase.sh[114]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 34.065073] autorun-usecase.sh[114]: [m3video]
[ 34.068024] autorun-usecase.sh[114]: [m3vpss ] notify_attach rtnVal 0
[ 34.075218] autorun-usecase.sh[114]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 34.077501] autorun-usecase.sh[114]: [m3video]
[ 34.079134] autorun-usecase.sh[114]: [m3video] 36: SYSTEM : System Common Init in progress !!!
[ 34.084071] autorun-usecase.sh[114]: [m3video] 36: SYSTEM: IPC init in progress !!!
[ 34.086211] autorun-usecase.sh[114]: [m3video] 36: SYSTEM: Attaching to [HOST] ...
[ 34.088023] autorun-usecase.sh[114]: [m3video] 86: SYSTEM: Attaching to [HOST] ...
[ 34.089562] autorun-usecase.sh[114]: [m3vpss ] initProxyServer rtnVal 0
[ 34.091312] autorun-usecase.sh[114]: [m3vpss ]
[ 34.092972] autorun-usecase.sh[114]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 34.094536] autorun-usecase.sh[114]: [m3vpss ]
[ 34.096206] autorun-usecase.sh[114]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 34.097731] autorun-usecase.sh[114]: [m3vpss ] 67: SYSTEM: IPC init in progress !!!
[ 34.099237] autorun-usecase.sh[114]: [m3vpss ] 67: SYSTEM: Attaching to [HOST] ...
[ 34.101587] autorun-usecase.sh[114]: [m3video] 93: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 34.103098] autorun-usecase.sh[114]: [m3video] 93: SYSTEM: Attaching to [VPSS-M3] ...
[ 34.104606] autorun-usecase.sh[114]: [m3vpss ] 117: SYSTEM: Attaching to [HOST] ...
[ 34.106311] autorun-usecase.sh[114]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 34.107775] autorun-usecase.sh[114]: [m3vpss ] 118: SYSTEM: Attaching to [VIDEO-M3] ...
[ 34.109249] autorun-usecase.sh[114]: [m3video] 143: SYSTEM: Attaching to [VPSS-M3] ...
[ 34.111396] autorun-usecase.sh[114]: [m3video] 169: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 34.112976] autorun-usecase.sh[114]: [m3vpss ] 168: SYSTEM: Attaching to [VIDEO-M3] ...
[ 34.114450] autorun-usecase.sh[114]: [m3video] 169: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 34.116170] autorun-usecase.sh[114]: [m3vpss ] 169: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 34.117665] autorun-usecase.sh[114]: [m3vpss ] 169: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 34.119119] autorun-usecase.sh[114]: [m3vpss ] 169: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 34.120679] autorun-usecase.sh[114]: [m3vpss ] 170: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 34.122148] autorun-usecase.sh[114]: [m3vpss ] 172: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 34.123605] autorun-usecase.sh[114]: [m3vpss ] 172: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 34.125076] autorun-usecase.sh[114]: [m3vpss ] 172: SYSTEM: IPC init DONE !!!
[ 34.126715] autorun-usecase.sh[114]: [m3vpss ] 183: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 34.128219] autorun-usecase.sh[114]: [m3vpss ] 183: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 34.129770] autorun-usecase.sh[114]: [m3vpss ] 185: SYSTEM : System Common Init Done !!!
[ 34.131357] autorun-usecase.sh[114]: [m3video] 269: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 34.132868] autorun-usecase.sh[114]: [m3video] 269: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 34.134307] autorun-usecase.sh[114]: [m3video] 269: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 34.135737] autorun-usecase.sh[114]: [m3video] 271: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 34.137444] autorun-usecase.sh[114]: [m3video] 272: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 34.138955] autorun-usecase.sh[114]: [m3video] 272: SYSTEM: IPC init DONE !!!
[ 34.140470] autorun-usecase.sh[114]: [m3video] 282: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 34.141957] autorun-usecase.sh[114]: [m3video] 283: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 34.143491] autorun-usecase.sh[114]: [m3video] 285: SYSTEM : System Common Init Done !!!
[ 34.144942] autorun-usecase.sh[114]: [m3vpss ] 1285: SYSTEM : System VPSS Init in progress !!!
[ 34.146382] autorun-usecase.sh[114]: [m3vpss ] === I2C0/2 Clk is active ===
[ 34.147983] autorun-usecase.sh[114]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 34.149488] autorun-usecase.sh[114]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 34.151161] autorun-usecase.sh[114]: [m3vpss ] 1304: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 34.152642] autorun-usecase.sh[114]: [m3vpss ] 1305: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 34.154164] autorun-usecase.sh[114]: [m3vpss ] 1305: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 34.155616] autorun-usecase.sh[114]: [m3vpss ] 1307: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 34.490892] autorun-usecase.sh[114]: [m3vpss ] 1308: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 34.492449] autorun-usecase.sh[114]: [m3vpss ] 1308: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 34.493951] autorun-usecase.sh[114]: [m3vpss ] 1321: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 34.495471] autorun-usecase.sh[114]: [m3vpss ] 1321: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 34.496939] autorun-usecase.sh[114]: [m3vpss ] 1322: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 34.498381] autorun-usecase.sh[114]: [m3vpss ] 1324: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 34.499996] autorun-usecase.sh[114]: [m3vpss ] 1324: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 34.501609] autorun-usecase.sh[114]: [m3vpss ] 1325: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[ 34.503093] autorun-usecase.sh[114]: [m3vpss ] 1327: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 34.504543] autorun-usecase.sh[114]: [m3vpss ] 1328: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 34.506022] autorun-usecase.sh[114]: [m3vpss ] 1328: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[ 34.507704] autorun-usecase.sh[114]: [m3vpss ] 1334: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUApproDrvInit: 7
[ 34.509251] autorun-usecase.sh[114]: queue id:163845
[ 37.645533] autorun-usecase.sh[114]: queue id:0
[ 39.553375] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 39.555189] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 39.559107] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 39.563824] autorun-usecase.sh[114]: [m3vpss ] Received character 't'
[ 39.582600] autorun-usecase.sh[114]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 39.584376] autorun-usecase.sh[114]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 39.588568] autorun-usecase.sh[114]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 39.592181] autorun-usecase.sh[114]: [m3video] Received character 't'
[ 39.618038] autorun-usecase.sh[114]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 39.687782] DMA: Module install successful, device major num = 244
[ 39.694145] DRV: Module install successful
[ 39.698304] DRV: Module built on Feb 13 2017 19:26:20
[ 39.799535]
[ 39.799535] soc_is_dm38x
[ 39.846646] autorun-usecase.sh[114]: ApproDrvInit: 3
[ 39.873319] autorun-usecase.sh[114]: queue id:163845
[ 39.895911] HDMI W1 rev 4.0
[ 39.898801] HDMI CEC Spec version 1.2
[ 40.277197] I2C No Ack
[ 40.279699] HDMI failed to read E-EDID
[ 40.764271] autorun-usecase.sh[114]: [host]
[ 40.767778] autorun-usecase.sh[114]: [host] ORG 0x46c00524: 0
[ 40.769762] autorun-usecase.sh[114]: [host] NEW 0x46c00524: 2
[ 40.771654] autorun-usecase.sh[114]: [host]
[ 40.773355] autorun-usecase.sh[114]: [host] Application Start Completed
[ 40.874509] autorun-usecase.sh[114]: [host] 0: SYSTEM: System Common Init in progress !!!
[ 40.876685] autorun-usecase.sh[114]: [host] 0: SYSTEM: IPC init in progress !!!
[ 40.879746] autorun-usecase.sh[114]: [host] 11: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 40.885582] autorun-usecase.sh[114]: [host] 13: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
[ 40.890458] autorun-usecase.sh[114]: [host] 13: SYSTEM: C[ 40.926792] DMA: ChannelID allocated:4
[ 40.894315] autorun-usecase.sh[114]: [host] 13: SYSTEM: CPU [HOST] syslink proc I[ 40.946646] DMA: ChannelID allocated:5
D is [2] !!!
[ 40.908264] autorun-usecase.sh[114]: [host] 13: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 40.919939] autorun-usecase.sh[114]: [host] 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[ 40.921993] autorun-usecase.sh[114]: [host] 13: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[ 40.923726] autorun-usecase.sh[114]: [host] 13: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 40.925393] autorun-usecase.sh[114]: [host] 14: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 40.927054] autorun-usecase.sh[114]: [host] 15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 40.928657] autorun-usecase.sh[114]: [host] 15: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 40.935319] autorun-usecase.sh[114]: [host] 15: SYSTEM: IPC init DONE !!!
[ 40.938190] autorun-usecase.sh[114]: [host] 17: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[ 40.941661] autorun-usecase.sh[114]: [host] 17: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[ 40.945001] autorun-usecase.sh[114]: [host] 17: SYSTEM: ListElem Shared Addr = 0xb5653580
[ 40.948964] autorun-usecase.sh[114]: [host] 18: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[ 40.951010] autorun-usecase.sh[114]: [host] 19: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[ 40.952731] autorun-usecase.sh[114]: [host] 19: SYSTEM: ListElem Shared Addr = 0xb566d200
[ 40.954339] autorun-usecase.sh[114]: [host] 22: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[ 40.955943] autorun-usecase.sh[114]: [host] 22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[ 40.957625] autorun-usecase.sh[114]: [host] 22: SYSTEM: ListElem Shared Addr = 0xb5686e80
[ 40.959228] autorun-usecase.sh[114]: [host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[ 40.960975] autorun-usecase.sh[114]: [host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[ 40.962661] autorun-usecase.sh[114]: [host] 24: SYSTEM: ListElem Shared Addr = 0xb56a6880
[ 40.964493] autorun-usecase.sh[114]: [host] 25: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[ 40.966194] autorun-usecase.sh[114]: [host] 25: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[ 40.967859] autorun-usecase.sh[114]: [host] 25: SYSTEM: ListElem Shared Addr = 0xb56c6280
[ 40.969499] autorun-usecase.sh[114]: [host] 28: SYSTEM: System Common Init Done !!!
[ 40.971262] autorun-usecase.sh[114]: [host] Vsys_allocBuf - addr = 0xa73fc000,size = 65011712
[ 40.972910] autorun-usecase.sh[114]: ##########pInfo->totalsize 63897600
[ 40.974533] autorun-usecase.sh[114]: [host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[ 40.976272] autorun-usecase.sh[114]: [host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[ 40.977897] autorun-usecase.sh[114]: [host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[ 40.979571] autorun-usecase.sh[114]: [host] Vsys_allocBuf - addr = 0xb6f8f000,size = 33603
[ 40.981279] autorun-usecase.sh[114]: [host] DCC buffer allocated for size 33603
[ 40.982900] autorun-usecase.sh[114]: [host] DCC Default File Intialization Done
[ 40.984548] autorun-usecase.sh[114]: [host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[ 41.010597] autorun-usecase.sh[114]: queue id:0
[ 41.015950] autorun-usecase.sh[114]: queue id:32769
[ 41.021193] autorun-usecase.sh[114]: [host]
[ 41.025369] autorun-usecase.sh[114]: ********** FULL FEATURE USECASE ********
[ 41.030457] autorun-usecase.sh[114]: [host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[ 41.032697] autorun-usecase.sh[114]: [host] 151: MCFW : CPU Revision [ES1.0] !!!
[ 41.034432] autorun-usecase.sh[114]: [host] 151: MCFW : Detected [UNKNOWN] Board !!!
[ 41.036196] autorun-usecase.sh[114]: [host] 151: MCFW : Base Board Revision [REV A] !!!
[ 41.041081] autorun-usecase.sh[114]: T_29] in region 0 ...
[ 41.042943] autorun-usecase.sh[114]: [m3vpss ] 1334: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 41.044627] autorun-usecase.sh[114]: [m3vpss ] 1335: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[ 41.046325] autorun-usecase.sh[114]: [m3vpss ] 1337: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 41.047952] autorun-usecase.sh[114]: [m3vpss ] 1337: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 41.049595] autorun-usecase.sh[114]: [m3vpss ] 1338: SYSTEM: ListElem Shared Addr = 0xbea03600
[ 41.051399] autorun-usecase.sh[114]: [m3vpss ] 1340: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 41.053032] autorun-usecase.sh[114]: [m3vpss ] 1340: SYSTEM : FVID2 Init in progress !!!
[ 41.054636] autorun-usecase.sh[114]: [m3video] 1385: SYSTEM : System Video Init in progress !!!
[ 41.056285] autorun-usecase.sh[114]: [m3video] 1385: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 41.058237] autorun-usecase.sh[114]: [m3video] 1386: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 41.059936] autorun-usecase.sh[114]: [m3video] 1386: SYSTEM: ListElem Shared Addr = 0xbea1d280
[ 41.061772] autorun-usecase.sh[114]: [m3video] 1388: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 41.063441] autorun-usecase.sh[114]: [m3video] 1389: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 41.065108] autorun-usecase.sh[114]: [m3video] 1389: SYSTEM: ListElem Shared Addr = 0xbea20780
[ 41.399860] autorun-usecase.sh[114]: [m3video] 1399: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 41.401593] autorun-usecase.sh[114]: [m3video] 1399: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 41.403265] autorun-usecase.sh[114]: [m3video] 1399: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 41.405055] autorun-usecase.sh[114]: [m3video] 1402: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 41.406676] autorun-usecase.sh[114]: [m3video] 1402: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 41.408326] autorun-usecase.sh[114]: [m3video] 1402: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 41.409930] autorun-usecase.sh[114]: [m3video] 1404: HDVICP: Doing PRCM for IVAHD[0] ...
[ 41.411644] autorun-usecase.sh[114]: [m3video] 1405: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 41.413233] autorun-usecase.sh[114]: [m3video] 1405: SYSTEM : Initializing Links !!!
[ 41.414974] autorun-usecase.sh[114]: [m3video] 1406: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 41.416561] autorun-usecase.sh[114]: [m3vpss ] 1411: SYSTEM : FVID2 Init in progress DONE !!!
[ 41.417105] autorun-usecase.sh[114]: [m3vpss ] 1411: SYSTEM : Device Init in progress !!!
[ 41.417651] autorun-usecase.sh[114]: [m3video] 1406: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 41.418119] autorun-usecase.sh[114]: [m3vpss ] Iss_init called !!!!!!
[ 41.418646] autorun-usecase.sh[114]: [m3video] 1406: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 41.419102] autorun-usecase.sh[114]: [m3vpss ] CPIS_init DONE !!!!!!
[ 41.419812] autorun-usecase.sh[114]: [m3video] 1406: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 41.420451] autorun-usecase.sh[114]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 41.420986] autorun-usecase.sh[114]: [m3video] 1407: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 41.421458] autorun-usecase.sh[114]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 41.421973] autorun-usecase.sh[114]: [m3video] 1408: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 41.422429] autorun-usecase.sh[114]: [m3video] Entered the MctnfLink_init()
[ 41.422939] autorun-usecase.sh[114]: [m3video] 1466: SYSTEM : Initializing Links ... DONE !!!
[ 41.423397] autorun-usecase.sh[114]: [m3video] 1467: SYSTEM : System Video Init Done !!!
[ 41.423911] autorun-usecase.sh[114]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 41.424365] autorun-usecase.sh[114]: [m3vpss ] 1605: SYSTEM : Device Init in progress DONE !!!
[ 41.424811] autorun-usecase.sh[114]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 41.425322] autorun-usecase.sh[114]: [m3vpss ] 6714: SYSTEM : System VPSS Init Done !!!
[ 41.425762] autorun-usecase.sh[114]: [m3vpss ] 6715: UTILS: DMA: HWI Create for INT62 !!!
[ 41.426298] autorun-usecase.sh[114]: [m3vpss ] 6715: SYSTEM : Initializing Links !!!
[ 41.426746] autorun-usecase.sh[114]: [m3vpss ] 6715: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 41.427248] autorun-usecase.sh[114]: [m3vpss ] 6715: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 41.427700] autorun-usecase.sh[114]: [m3vpss ] 6716: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 41.428145] autorun-usecase.sh[114]: [m3vpss ] 6716: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 41.428647] autorun-usecase.sh[114]: [m3vpss ] 6716: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 41.429095] autorun-usecase.sh[114]: [m3vpss ] 6847: SYSTEM : Initializing Links ... DONE !!!
[ 41.429602] autorun-usecase.sh[114]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 41.430093] autorun-usecase.sh[114]: [m3vpss ] VPS_DCTRL_INST_0
[ 41.430604] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 41.431067] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 41.762330] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 41.762928] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 41.763405] autorun-usecase.sh[114]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 41.763871] autorun-usecase.sh[114]: [m3vpss ] HDCOMPCLK
[ 41.764320] autorun-usecase.sh[114]: [m3vpss ] 8255: CAMERA: Create in progress !!!
[ 41.764770] autorun-usecase[ 41.854490] DMA: ChannelID allocated:6
.sh[114]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ [ 41.861236] DMA: ChannelID allocated:7
41.765219] autorun-usecase.sh[114]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 41.765667] autorun-usecase.sh[114]: [m3vpss ] 8255: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 41.766339] autorun-usecase.sh[114]: [m3vpss ] 8256: CAMERA: VIP 0: VID DEC 268436737 (0x10): 00queue id:0
[ 41.854878] autorun-usecase.sh[114]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[ 41.855717] autorun-usecase.sh[114]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[ 41.938491] DMA: ChannelID allocated:12
[ 41.925737] autorun-usecase.sh[114]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[ 42.167640] autorun-usecase.sh[114]: 02:20202020:20202020, AUD_STATUS 538976288
[ 42.168484] autorun-usecase.sh[114]: [m3vpss ] Iss_captCreate:1661
[ 42.169254] autorun-usecase.sh[114]: [m3vpss ] 8465: CAMERA: Create Done !!!
[ 42.169902] autorun-usecase.sh[114]: [m3vpss ] 8554: CAMERA: Detect video in progress !!!
[ 42.170554] autorun-usecase.sh[114]: [m3vpss ] 8554: CAMERA: Detect video Done !!!
[ 42.171190] autorun-usecase.sh[114]: [m3video] 8629: IPC_IN_M3 : Create in progress !!!
[ 42.171812] autorun-usecase.sh[114]: [m3vpss ] 8626: DUP : Create Done !!!
[ 42.172458] autorun-usecase.sh[114]: [m3video] 8629: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 42.173028] autorun-usecase.sh[114]: [m3vpss ] 8627: IPC_OUT_M3 : Create in progress !!!
[ 42.173661] autorun-usecase.sh[114]: [m3video] 8629: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 42.174234] autorun-usecase.sh[114]: [m3vpss ] 8628: IPC_OUT_M3 : Create Done !!!
[ 42.174851] autorun-usecase.sh[114]: [m3video] 8632: IPC_IN_M3 : Create Done !!!
[ 42.175445] autorun-usecase.sh[114]: [m3vpss ] DCC server task running
[ 42.175993] autorun-usecase.sh[114]: [m3video] Entered the MctnfLink_tskMain()
[ 42.176593] autorun-usecase.sh[114]: [m3video] inChInfo->width = 1920
[ 42.177151] autorun-usecase.sh[114]: [m3video] inChInfo->height = 1080
[ 42.177852] autorun-usecase.sh[114]: [m3video] inChInfo->pitch[0] = 1984
[ 42.178414] autorun-usecase.sh[114]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 42.179047] autorun-usecase.sh[114]: [m3video] [MCTNF] startX = 0
[ 42.179592] autorun-usecase.sh[114]: [m3vpss ] 8811: IPC_IN_M3 : Create in progress !!!
[ 42.180244] autorun-usecase.sh[114]: [m3video] [MCTNF] startY = 0
[ 42.180873] autorun-usecase.sh[114]: [m3vpss ] 8812: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 42.181442] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->width = 1920
[ 42.182028] autorun-usecase.sh[114]: [m3vpss ] 8812: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 42.182584] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->height = 1080
[ 42.183182] autorun-usecase.sh[114]: [m3vpss ] 8813: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 42.183737] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 42.184376] autorun-usecase.sh[114]: [m3vpss ] 8815: IPC_IN_M3 : Create Done !!!
[ 42.184934] autorun-usecase.sh[114]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 42.185540] autorun-usecase.sh[114]: [m3video] 8810: IPC_OUT_M3 : Create in progress !!!
[ 42.186120] autorun-usecase.sh[114]: [m3video] 8811: IPC_OUT_M3 : Create Done !!!
[ 42.186735] autorun-usecase.sh[114]: [m3vpss ] 8750: VNF:
[ 42.187280] autorun-usecase.sh[114]: [m3vpss ] Create in progress ... !!!
[ 42.187947] autorun-usecase.sh[114]: [m3vpss ] 8751: VNF:
[ 42.188534] autorun-usecase.sh[114]: [m3vpss ] Input Channel CH0 of 1920 x 1080, pitch = (1984, 1984) [0,0][PROGRESSIVE] [7] ...
[ 42.189092] autorun-usecase.sh[114]: [m3vpss ] 8751: V?
U-Boot SPL 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46)
Trying to boot from MMC2
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46 -0500)
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
Net: <ethaddr> not set. Reading from E-fuse
cpsw
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Booting from mmc ...
reading uImage
2662320 bytes read in 306 ms (8.3 MiB/s)
reading dm38x-csk.dtb
58698 bytes read in 14 ms (4 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-4.4.12-00004-g82adbbf-dirt
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2662256 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 84000000
Booting using the fdt blob at 0x84000000
Loading Kernel Image ... OK
Loading Device Tree to 844ee000, end 844ff549 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.12-00004-g82adbbf-dirty (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 Mon Feb 13 17:38:26 EST 2017
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: DM38X CSK
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] omap_barrier_reserve_memblock():Reserving DRAM area @ addr = 0x84e00000 size = 1048576 Bytes
[ 0.000000] cma: Reserved 24 MiB at 0x82c00000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] TI81XX: Map 0x84e00000 to 0xfe500000 for dram barrier
[ 0.000000] TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] TI814X ES1.0 (iva neon )
[ 0.000000] powerdomain: gem_pwrdm: voltagedomain dsp does not exist
[ 0.000000] powerdomain: ivahd_pwrdm: voltagedomain iva does not exist
[ 0.000000] powerdomain: hdvpss_pwrdm: voltagedomain dsp does not exist
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19788
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rootwait rw mem=80M vram=4M cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 notifyk.vpssm3_sva=0xBFD00000 earlyprintk
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 46648K/79872K available (4911K kernel code, 260K rwdata, 1708K rodata, 276K init, 241K bss, 8648K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc5800000 - 0xff800000 ( 928 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc067efa4 (6620 kB)
[ 0.000000] .init : 0xc067f000 - 0xc06c4000 ( 276 kB)
[ 0.000000] .data : 0xc06c4000 - 0xc0705308 ( 261 kB)
[ 0.000000] .bss : 0xc0705308 - 0xc0741718 ( 242 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 20000000 Hz
[ 0.000016] sched_clock: 32 bits at 20MHz, resolution 50ns, wraps every 107374182375ns
[ 0.008264] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 95563022313 ns
[ 0.017840] OMAP clocksource: timer1 at 20000000 Hz
[ 0.023136] Console: colour dummy device 80x30
[ 0.086915] pid_max: default: 32768 minimum: 301
[ 0.091864] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098775] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.106821] Initializing cgroup subsys io
[ 0.111053] Initializing cgroup subsys memory
[ 0.115674] Initializing cgroup subsys devices
[ 0.120347] Initializing cgroup subsys freezer
[ 0.125028] Initializing cgroup subsys pids
[ 0.129443] CPU: Testing write buffer coherency: ok
[ 0.134893] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.142705] devtmpfs: initialized
[ 0.168773] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.217139] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.229275] pinctrl core: initialized pinctrl subsystem
[ 0.236063] NET: Registered protocol family 16
[ 0.242302] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.255256] OMAP GPIO hardware version 0.1
[ 0.267827] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
[ 0.301532] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.309802] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.323406] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.337075] media: Linux media interface: v0.10
[ 0.341891] Linux video capture interface: v2.00
[ 0.346800] pps_core: LinuxPPS API ver. 1 registered
[ 0.351995] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.361522] PTP clock support registered
[ 0.365664] EDAC MC: Ver: 3.0.0
[ 0.369715] Advanced Linux Sound Architecture Driver Initialized.
[ 0.377117] clocksource: Switched to clocksource timer1
[ 0.394530] NET: Registered protocol family 2
[ 0.399898] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.407213] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.413851] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.420570] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.426674] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.433396] NET: Registered protocol family 1
[ 0.438348] RPC: Registered named UNIX socket transport module.
[ 0.444530] RPC: Registered udp transport module.
[ 0.449487] RPC: Registered tcp transport module.
[ 0.454413] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462458] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.469563] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.486530] NFS: Registering the id_resolver key type
[ 0.491929] Key type id_resolver registered
[ 0.496321] Key type id_legacy registered
[ 0.502221] io scheduler noop registered
[ 0.506358] io scheduler deadline registered
[ 0.511108] io scheduler cfq registered (default)
[ 0.517424] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
[ 0.598560] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.609575] console [ttyS0] disabled
[ 0.613392] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 3000000) is a 8250
[ 0.622352] console [ttyS0] enabled
[ 0.629544] bootconsole [earlycon0] disabled
[ 0.639351] Reference Linux version 4.4.12
[ 0.643647] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script/TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.662195] allocated heap buffer 0xc8000000 of size 0x4000000
[ 0.668099] cmemk initialized
[ 0.678469] loop: module loaded
[ 0.747176] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
[ 0.753313] libphy: 4a100800.mdio: probed
[ 0.758213] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, driver TI DP83867
[ 0.767212] cpsw 4a100000.ethernet: Detected MACID = 7c:66:9d:f8:c5:0c
[ 0.777311] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.807381] mousedev: PS/2 mouse device common for all mice
[ 0.813491] omap_rtc 480c0000.rtc: already running
[ 0.818772] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
[ 0.826196] i2c /dev entries driver
[ 0.830691] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 0.837815] sdhci: Secure Digital Host Controller Interface driver
[ 0.844025] sdhci: Copyright(c) Pierre Ossman
[ 0.972623] omap_hsmmc 48060000.mmc: card claims to support voltages below defined range
[ 0.991759] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 0.998010] mmc0: new high speed SDIO card at address 0001
[ 1.007386] Synopsys Designware Multimedia Card Interface Driver
[ 1.013887] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.020878] notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
[ 1.027036] notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbfd00000
[ 1.038786] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 1.046059] davinci_evm sound: snd_soc_register_card failed (-517)
[ 1.053532] NET: Registered protocol family 10
[ 1.060402] sit: IPv6 over IPv4 tunneling driver
[ 1.065883] NET: Registered protocol family 17
[ 1.070559] Key type dns_resolver registered
[ 1.075093] omap_voltage_late_init: Could not get sys clk.
[ 1.081000] Power Management for TI81XX.
[ 1.090186] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.095371] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.102984] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.109470] nand: Micron MT29F2G16ABAEAWP
[ 1.113504] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.121141] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.126556] 8 ofpart partitions found on MTD device 8000000.nand
[ 1.132612] Creating 8 MTD partitions on "8000000.nand":
[ 1.137970] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.147747] 0x000000020000-0x000000420000 : "NAND.u-boot"
[ 1.155930] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
[ 1.163034] 0x000000440000-0x000000a40000 : "NAND.kernel"
[ 1.172120] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
[ 1.181906] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.197195] mmc1: new high speed SDHC card at address 0007
[ 1.217174] mmcblk0: mmc1:0007 SD16G 14.5 GiB
[ 1.223144] mmcblk0: p1 p2
[ 1.271099] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
[ 1.278463] 0x00000ca80000-0x00000d680000 : "NAND.data"
[ 1.289209] 0x00000d680000-0x000010000000 : "NAND.reserved"
[ 1.353990] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1
[ 1.361693] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.369188] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.375988] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
[ 1.383059] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 1.392488] omap_rtc 480c0000.rtc: setting system clock to 2016-12-06 15:42:23 UTC (1481038943)
[ 1.414405] wlan-en-regulator: disabling
[ 1.418761] ALSA device list:
[ 1.421748] #0: TI81XX-CSK
[ 1.426738] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 9.575334] EXT4-fs (mmcblk0p2): recovery complete
[ 9.588730] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 9.596919] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 9.612115] devtmpfs: mounted
[ 9.615699] Freeing unused kernel memory: 276K (c067f000 - c06c4000)
[ 9.622113] This architecture does not have kernel memory protection.
[ 9.881532] random: systemd urandom read with 29 bits of entropy available
[ 9.902093] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 9.920892] systemd[1]: Detected architecture arm.
Welcome to [1mArago 2016.05 [0m!
[ 9.949216] systemd[1]: Set hostname to <ti81xx>.
[ 10.237450] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-usecase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 10.387772] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ [0;32m OK [0m] Started Forward Password Requests to Wall Directory Watch.
[ 10.417420] systemd[1]: Reached target Timers.
[ [0;32m OK [0m] Reached target Timers.
[ 10.441265] systemd[1]: Created slice System Slice.
[ [0;32m OK [0m] Created slice System Slice.
[ 10.457739] systemd[1]: Listening on udev Control Socket.
[ [0;32m OK [0m] Listening on udev Control Socket.
[ 10.478634] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ [0;32m OK [0m] Created slice system-serial\x2dgetty.slice.
[ 10.497415] systemd[1]: Reached target Slices.
[ [0;32m OK [0m] Reached target Slices.
[ 10.517382] systemd[1]: Reached target Swap.
[ [0;32m OK [0m] Reached target Swap.
[ 10.556723] systemd[1]: Listening on Network Service Netlink Socket.
[ [0;32m OK [0m] Listening on Network Service Netlink Socket.
[ 10.587438] systemd[1]: Reached target Remote File Systems.
[ [0;32m OK [0m] Reached target Remote File Systems.
[ 10.607693] systemd[1]: Listening on Journal Socket.
[ [0;32m OK [0m] Listening on Journal Socket.
[ 10.634705] systemd[1]: Mounting POSIX Message Queue File System...
[ 10.680314] systemd[1]: Mounting /var/volatile...
[ 10.727814] systemd[1]: Mounting Temporary Directory...
[ 10.750471] systemd[1]: Starting Synchronize System and HW clocks...
[ 10.798391] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 10.827536] systemd[1]: Reached target Paths.
[ [0;32m OK [0m] Reached target Paths.
[ 10.847707] systemd[1]: Listening on Syslog Socket.
[ [0;32m OK [0m] Listening on Syslog Socket.
[ 10.867645] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ [0;32m OK [0m] Listening on /dev/initctl Compatibility Named Pipe.
[ 10.898800] systemd[1]: Created slice system-getty.slice.
[ [0;32m OK [0m] Created slice system-getty.slice.
[ 10.917645] systemd[1]: Listening on Journal Socket (/dev/log).
[ [0;32m OK [0m] Listening on Journal Socket (/dev/log).
[ 10.941202] systemd[1]: Starting Journal Service...
[ 10.967697] systemd[1]: Listening on udev Kernel Socket.
[ [0;32m OK [0m] Listening on udev Kernel Socket.
[ 11.001480] systemd[1]: Starting udev Kernel Device Manager...
[ 11.036265] systemd[1]: Starting udev Coldplug all Devices...
[ 11.130882] systemd[1]: Mounting /media/ram...
[ 11.232207] systemd[1]: Mounted POSIX Message Queue File System.
[ [0;32m OK [0m] Mounted POSIX Message Queue File System.
[ 11.267639] systemd[1]: Mounted Temporary Directory.
[ [0;32m OK [0m] Mounted Temporary Directory.
[ 11.287693] systemd[1]: Mounted /var/volatile.
[ [0;32m OK [0m] Mounted /var/volatile.
[ 11.307638] systemd[1]: Mounted /media/ram.
[ [0;32m OK [0m] Mounted /media/ram.
[ 11.328107] systemd[1]: Started Journal Service.
[ [0;32m OK [0m] Started Journal Service.
[ [0;32m OK [0m] Started udev Kernel Device Manager.
[ [0;32m OK [0m] Started Synchronize System and HW clocks.
[ [0;32m OK [0m] Started udev Coldplug all Devices.
[ [0;32m OK [0m] Found device /dev/ttyS0.
[ [0;32m OK [0m] Started IPNC RDK use case service.
[ [0;32m OK [0m] Reached target Local File Systems.
[ [0;32m OK [0m] Reached target System Initialization.
[ [0;32m OK [0m] Listening on D-Bus System Message Bus Socket.
[ [0;32m OK [0m] Reached target Sockets.
[ [0;32m OK [0m] Reached target Basic System.
[ [0;32m OK [0m] Started Kernel Logging Service.
[ 12.427735] autorun-usecase.sh[113]: numid=1,iface=MIXER,name='PCM Playback Volume'
[ 12.437167] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
[ 12.438615] autorun-usecase.sh[113]: : values=115,115
[ 12.439876] autorun-usecase.sh[113]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
[ [0;32m OK [0m] Started Getty on tty1.
=[0;32m OK [0m] Started System Logging Service.
Starting uim-sysfs.service...
[ [0;32m OK [0m] Started Serial Getty on ttyS0.
[ 12.580841] autorun-usecase.sh[113]: numid=31,iface=MIXER,name='PGA Capture Volume'
[ [0;32m OK [0m] Reached target Login Prompts.
[ 12.603396] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
[ 12.627286] autorun-usecase.sh[113]: : values=72,72
[ 12.630150] autorun-usecase.sh[113]: | dBscale-min=0.00dB,step=0.50dB,mute=0
[ [0;32m OK [0m] Started D-Bus System Message Bus.
[ 12.665724] autorun-usecase.sh[113]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
[ 12.702586] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ 12.731997] autorun-usecase.sh[113]: : values=on
[ 12.766021] autorun-usecase.sh[113]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
[ 12.792525] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ 12.822233] autorun-usecase.sh[113]: : values=on
[ 12.861720] autorun-usecase.sh[113]: Mount mtd6 and mtd7 partitions
[ 12.914046] ubi0: attaching mtd6
Starting Network Service...
[ 13.104460] ubi0: scanning is finished
[ 13.187522] net eth0: initializing cpsw version 1.10 (0)
[ 13.192883] net eth0: initialized cpsw ale version 1.3
[ 13.201390] net eth0: phy found : id is : 0x2000a231
[ 13.206432] libphy: PHY not found
[ 13.209886] net eth0: phy "" not found on slave 1, err -19
[ 13.233799] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 13.239853] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 13.246762] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 13.253520] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 13.260535] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 13.266482] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 13.273760] ubi0: max/mean erase counter: 9/4, WL threshold: 4096, image sequence number: 2667817441
[ 13.282951] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
[ 13.292662] ubi0: background thread "ubi_bgt0d" started, PID 146
[ [0;32m OK [0m] Started Network Service.
[ 13.383866] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 13.490806] autorun-usecase.sh[113]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 14.137270] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 151
[ 14.205904] UBIFS (ubi0:0): recovery needed
[ 14.399150] UBIFS (ubi0:0): recovery completed
[ 14.403736] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
[ 14.411744] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 14.421727] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 14.431877] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 14.438371] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID AA21A384-4ECC-4F1F-BA8C-EBB1D35EBD16, small LPT model
[ [0;32m OK [0m] Reached target Network.
Starting Network Name Resolution...
[ [0;32m OK [0m] Started Network Name Resolution.
[ 15.205564] ubi1: attaching mtd7
[ [0;32m OK [0m] Started uim-sysfs.service.
Starting telnetd.service...
[ 15.483592] ubi1: scanning is finished
[ 15.534041] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 15.540433] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 15.547370] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 15.554103] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 15.561111] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 15.567160] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 15.574418] ubi1: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 3383995126
[ 15.583605] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 15.595372] ubi1: background thread "ubi_bgt1d" started, PID 167
[ [0;32m OK [0m] Started telnetd.service.
[ 15.636211] autorun-usecase.sh[113]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
Starting thermal-zone-init.service...
[ [0;32m OK [0m] Started thermal-zone-init.service.
[ [0;32m OK [0m] Reached target Multi-User System.
[ 16.198113] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 181
[ 16.218422] UBIFS (ubi1:0): recovery needed
[ 16.238334] UBIFS (ubi1:0): recovery completed
[ 16.242905] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 16.250907] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 16.260890] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 16.271389] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 16.278058] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID EBC3BFCA-673F-4B1C-B1F6-5BF526D40A9C, small LPT model
[ 16.793625] autorun-usecase.sh[113]: wifi: in STA mode
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
ti81xx login: [ 18.198043] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 18.205988] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.682760] cfg80211: World regulatory domain updated:
[ 20.688007] cfg80211: DFS Master region: unset
[ 20.692385] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 20.702213] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.710429] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.718503] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.726548] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 20.736093] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 20.745642] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 20.753788] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 20.761844] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 21.209026] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 21.607781] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 21.634893] wlcore: loaded
[ 22.244304] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 22.348719] random: nonblocking pool is initialized
[ 22.356956] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 22.375324] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 26.517950] autorun-usecase.sh[113]: SSID: gaff
[ 26.519750] autorun-usecase.sh[113]: SSID: TP-LINK_THW
[ 26.523371] autorun-usecase.sh[113]: SSID: TP-LINK_A394
[ 26.530179] autorun-usecase.sh[113]: SSID: gaff
[ 26.532041] autorun-usecase.sh[113]: SSID: Znks
[ 26.910788] <1>SysLink version : 2.21.02.10
[ 26.910788] SysLink module created on Date:Feb 13 2017 Time:19:16:30
[ 26.921457] <1>Trace enabled
[ 26.924354] <1>Trace SetFailureReason enabled
[ 27.016312] autorun-usecase.sh[113]: /dev/mem opened.
[ 27.018052] autorun-usecase.sh[113]: Phy Addr : 0x48181560 Data : 0x00000002
[ 27.019467] autorun-usecase.sh[113]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 27.031453] autorun-usecase.sh[113]: Phy Addr : 0x48180508 Data : 0x00000302
[ 27.036900] autorun-usecase.sh[113]: Phy Addr : 0x48180520 Data : 0x00000002
[ 27.041042] autorun-usecase.sh[113]: Phy Addr : 0x48180524 Data : 0x00000002
[ 27.042785] autorun-usecase.sh[113]: Phy Addr : 0x48180528 Data : 0x00000002
[ 27.044293] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 27.045804] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 27.047186] autorun-usecase.sh[113]: DDR IOs RX is shutdown
[ 27.048735] autorun-usecase.sh[113]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 27.980567] autorun-usecase.sh[113]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (227) - No such process
[ 28.008330] autorun-usecase.sh[113]: [host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[ 28.013337] autorun-usecase.sh[113]: [host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[ 28.016308] autorun-usecase.sh[113]: [host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[ 28.022368] autorun-usecase.sh[113]: [host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[ 28.088488] autorun-usecase.sh[113]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 29.124369] autorun-usecase.sh[113]: mkfs.fat 3.0.28 (2015-05-16)
[ 29.126255] autorun-usecase.sh[113]: unable to get drive geometry, using default 255/63
[ 29.127598] autorun-usecase.sh[113]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 29.128860] autorun-usecase.sh[113]: hidden sectors 0x0000;
[ 29.139428] autorun-usecase.sh[113]: logical sector size is 512,
[ 29.142506] autorun-usecase.sh[113]: using 0xf8 media descriptor, with 1024 sectors;
[ 29.146350] autorun-usecase.sh[113]: drive number 0x80;
[ 29.148952] autorun-usecase.sh[113]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 29.152018] autorun-usecase.sh[113]: FAT size is 1 sector, and provides 247 clusters.
[ 29.167564] autorun-usecase.sh[113]: There is 1 reserved sector.
[ 29.169364] autorun-usecase.sh[113]: Root directory contains 512 slots and uses 32 sectors.
[ 29.173172] autorun-usecase.sh[113]: Volume ID is c7b3c24e, no volume label.
[ 29.396474] Mass Storage Function, version: 2009/09/11
[ 29.401747] LUN: removable file: (no medium)
[ 29.439367] LUN: removable file: /dev/sbulla
[ 29.443681] Number of LUNs=1
[ 29.457264] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 29.464299] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 29.471413] g_mass_storage gadget: g_mass_storage ready
[ 29.531543] autorun-usecase.sh[113]: Creat queue id:0
[ 29.533626] autorun-usecase.sh[113]: queue id:0
[ 29.537098] autorun-usecase.sh[113]: Creat queue id:32769
[ 29.541169] autorun-usecase.sh[113]: queue id:32769
[ 29.550148] autorun-usecase.sh[113]: Creat queue id:65538
[ 29.552213] autorun-usecase.sh[113]: queue id:65538
[ 29.554887] autorun-usecase.sh[113]: Creat queue id:98307
[ 29.560880] autorun-usecase.sh[113]: queue id:98307
[ 29.574491] autorun-usecase.sh[113]: queue id:32769
[ 29.610396] autorun-usecase.sh[113]: [host] Attached to slave procId 1.
[ 31.451304] autorun-usecase.sh[113]: [host] Attached to slave procId 0.
[ 31.453710] autorun-usecase.sh[113]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[ 32.470416] autorun-usecase.sh[113]: [host] Started slave procId 1.
[ 32.516998] autorun-usecase.sh[113]: [host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[ 32.554333] autorun-usecase.sh[113]: [host] Started slave procId 0.
[ 32.556354] autorun-usecase.sh[113]: [host] After Ipc_loadcallback status [0x00000000]
[ 32.558409] autorun-usecase.sh[113]: [host] After Ipc_loadcallback status [0x00000000]
[ 32.640600] autorun-usecase.sh[113]: [host] After Ipc_startcallback status [0x00000000]
[ 32.665684] autorun-usecase.sh[113]: [host] After Ipc_startcallback status [0x00000000]
[ 32.734184] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 32.736175] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 32.738623] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 32.740340] autorun-usecase.sh[113]: [m3vpss ] Received character 's'
[ 33.438078] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 33.439859] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 33.446309] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 33.450446] autorun-usecase.sh[113]: [m3video] Received character 's'
[ 33.452587] autorun-usecase.sh[113]: queue id:65538
[ 33.454332] autorun-usecase.sh[113]: Creat queue id:131076
[ 33.455859] autorun-usecase.sh[113]: queue id:131076
[ 33.457369] autorun-usecase.sh[113]: CPU is TI812x
[ 33.458803] autorun-usecase.sh[113]: vsenable : 0
[ 33.564493] autorun-usecase.sh[113]: Creat queue id:163845
[ 33.568449] autorun-usecase.sh[113]: queue id:163845
[ 33.574378] autorun-usecase.sh[113]: queue id:65538
[ 33.602869] autorun-usecase.sh[113]: ApproDrvInit: 7
[ 33.604649] autorun-usecase.sh[113]: queue id:163845
[ 34.337501] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 34.339248] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 34.348557] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 34.485531] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 34.487358] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 34.488890] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 34.490404] autorun-usecase.sh[113]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 34.491928] autorun-usecase.sh[113]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 34.493456] autorun-usecase.sh[113]: [m3video]
[ 34.494892] autorun-usecase.sh[113]: [m3vpss ] notify_attach rtnVal 0
[ 34.496423] autorun-usecase.sh[113]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 34.497855] autorun-usecase.sh[113]: [m3video]
[ 34.499317] autorun-usecase.sh[113]: [m3video] 36: SYSTEM : System Common Init in progress !!!
[ 34.500840] autorun-usecase.sh[113]: [m3video] 36: SYSTEM: IPC init in progress !!!
[ 34.502273] autorun-usecase.sh[113]: [m3video] 36: SYSTEM: Attaching to [HOST] ...
[ 34.503729] autorun-usecase.sh[113]: [m3video] 86: SYSTEM: Attaching to [HOST] ...
[ 34.505204] autorun-usecase.sh[113]: [m3vpss ] initProxyServer rtnVal 0
[ 34.506726] autorun-usecase.sh[113]: [m3vpss ]
[ 34.508158] autorun-usecase.sh[113]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 34.509610] autorun-usecase.sh[113]: [m3vpss ]
[ 34.511122] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 34.512569] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM: IPC init in progress !!!
[ 34.514016] autorun-usecase.sh[113]: [m3vpss ] 67: SYSTEM: Attaching to [HOST] ...
[ 34.515531] autorun-usecase.sh[113]: [m3video] 94: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 34.517022] autorun-usecase.sh[113]: [m3video] 94: SYSTEM: Attaching to [VPSS-M3] ...
[ 34.518468] autorun-usecase.sh[113]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ...
[ 34.519888] autorun-usecase.sh[113]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 34.521445] autorun-usecase.sh[113]: [m3vpss ] 119: SYSTEM: Attaching to [VIDEO-M3] ...
[ 34.522899] autorun-usecase.sh[113]: [m3video] 144: SYSTEM: Attaching to [VPSS-M3] ...
[ 34.524340] autorun-usecase.sh[113]: [m3vpss ] 169: SYSTEM: Attaching to [VIDEO-M3] ...
[ 34.525840] autorun-usecase.sh[113]: [m3video] 169: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 34.527338] autorun-usecase.sh[113]: [m3vpss ] 169: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 34.528779] autorun-usecase.sh[113]: [m3video] 169: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 34.530307] autorun-usecase.sh[113]: [m3vpss ] 169: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 34.531812] autorun-usecase.sh[113]: [m3vpss ] 170: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 34.533270] autorun-usecase.sh[113]: [m3vpss ] 170: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 34.534710] autorun-usecase.sh[113]: [m3vpss ] 172: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 34.536229] autorun-usecase.sh[113]: [m3vpss ] 172: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 34.537723] autorun-usecase.sh[113]: [m3vpss ] 173: SYSTEM: IPC init DONE !!!
[ 34.539223] autorun-usecase.sh[113]: [m3vpss ] 183: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 34.540778] autorun-usecase.sh[113]: [m3vpss ] 184: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 34.542353] autorun-usecase.sh[113]: [m3vpss ] 186: SYSTEM : System Common Init Done !!!
[ 34.543908] autorun-usecase.sh[113]: [m3video] 269: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 34.545374] autorun-usecase.sh[113]: [m3video] 270: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 34.546921] autorun-usecase.sh[113]: [m3video] 270: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 34.548367] autorun-usecase.sh[113]: [m3video] 272: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 34.549838] autorun-usecase.sh[113]: [m3video] 272: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 34.551409] autorun-usecase.sh[113]: [m3video] 272: SYSTEM: IPC init DONE !!!
[ 34.552905] autorun-usecase.sh[113]: [m3video] 283: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 34.554374] autorun-usecase.sh[113]: [m3video] 283: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 34.555853] autorun-usecase.sh[113]: [m3video] 285: SYSTEM : System Common Init Done !!!
[ 34.557441] autorun-usecase.sh[113]: [m3vpss ] 1886: SYSTEM : System VPSS Init in progress !!!
[ 34.558894] autorun-usecase.sh[113]: [m3vpss ] === I2C0/2 Clk is active ===
[ 34.560420] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 34.562128] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 34.896787] autorun-usecase.sh[113]: [m3vpss ] 1905: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 34.898449] autorun-usecase.sh[113]: [m3vpss ] 1905: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 34.900106] autorun-usecase.sh[113]: [m3vpss ] 1905: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 34.901653] autorun-usecase.sh[113]: [m3vpss ] 1908: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 34.903139] autorun-usecase.sh[113]: [m3vpss ] 1908: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 34.904602] autorun-usecase.sh[113]: [m3vpss ] 1908: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 34.906037] autorun-usecase.sh[113]: [m3vpss ] 1921: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 34.907526] autorun-usecase.sh[113]: [m3vpss ] 1922: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 34.909043] autorun-usecase.sh[113]: [m3vpss ] 1922: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 34.910562] autorun-usecase.sh[113]: [m3vpss ] 1924: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 34.912067] autorun-usecase.sh[113]: [m3vpss ] 1925: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 34.913557] autorun-usecase.sh[113]: [m3vpss ] 1925: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[ 34.915017] autorun-usecase.sh[113]: [m3vpss ] 1928: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 34.916469] autorun-usecase.sh[113]: [m3vpss ] 1928: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 34.917956] autorun-usecase.sh[113]: [m3vpss ] 1928: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[ 38.742072] autorun-usecase.sh[113]: [m3vpss ] 1934: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUqueue id:0
[ 38.749630] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 38.751839] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 38.760163] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 39.624338] autorun-usecase.sh[113]: ApproDrvInit: 3
[ 39.637551] autorun-usecase.sh[113]: queue id:163845
[ 39.997684] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 39.999662] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 40.003057] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 40.006166] autorun-usecase.sh[113]: [m3vpss ] Received character 't'
[ 40.024842] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 40.026563] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 40.027989] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 40.029288] autorun-usecase.sh[113]: [m3video] Received character 't'
[ 40.059352] autorun-usecase.sh[113]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 40.135854] DMA: Module install successful, device major num = 244
[ 40.142247] DRV: Module install successful
[ 40.146365] DRV: Module built on Feb 13 2017 19:26:20
[ 40.210759]
[ 40.210759] soc_is_dm38x
[ 40.280187] HDMI W1 rev 4.0
[ 40.283041] HDMI CEC Spec version 1.2
[ 40.657135] I2C No Ack
[ 40.659640] HDMI failed to read E-EDID
[ 41.145269] autorun-usecase.sh[113]: [host]
[ 41.147314] autorun-usecase.sh[113]: [host] ORG 0x46c00524: 0
[ 41.149014] autorun-usecase.sh[113]: [host] NEW 0x46c00524: 2
[ 41.150872] autorun-usecase.sh[113]: [host]
[ 41.152621] autorun-usecase.sh[113]: [host] Application Start Completed
[ 41.248819] autorun-usecase.sh[113]: [host] 0: SYSTEM: System Common Init in progress !!!
[ 41.254481] autorun-usecase.sh[113]: [host] 0: SYSTEM: IPC init in progress !!!
[ 41.258884] autorun-usecase.sh[113]: [host] 10: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 41.264205] autorun-usecase.sh[113]: [ 41.294605] DMA: ChannelID allocated:4
[host] 11: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!! [ 41.304051] DMA: ChannelID allocated:5
[ 41.269015] autorun-usecase.sh[113]: [host] 11: SYSTEM: CPU [VPSS-M3] syslink proc ID is [1] !!!
[ 41.275904] autorun-usecase.sh[113]: [host] 11: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
[ 41.283105] autorun-usecase.sh[113]: [host] 11: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 41.284931] autorun-usecase.sh[113]: [host] 12: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[ 41.296100] autorun-usecase.sh[113]: [host] 12: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[ 41.299879] autorun-usecase.sh[113]: [host] 12: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 41.305143] autorun-usecase.sh[113]: [host] 12: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 41.312705] autorun-usecase.sh[113]: [host] 15: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 41.320601] autorun-usecase.sh[113]: [host] 15: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 41.322513] autorun-usecase.sh[113]: [host] 15: SYSTEM: IPC init DONE !!!
[ 41.324198] autorun-usecase.sh[113]: [host] 16: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[ 41.325901] autorun-usecase.sh[113]: [host] 16: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[ 41.327651] autorun-usecase.sh[113]: [host] 16: SYSTEM: ListElem Shared Addr = 0xb563f580
[ 41.329239] autorun-usecase.sh[113]: [host] 17: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[ 41.330972] autorun-usecase.sh[113]: [host] 17: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[ 41.332572] autorun-usecase.sh[113]: [host] 17: SYSTEM: ListElem Shared Addr = 0xb5659200
[ 41.334178] autorun-usecase.sh[113]: [host] 20: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[ 41.335803] autorun-usecase.sh[113]: [host] 21: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[ 41.337500] autorun-usecase.sh[113]: [host] 21: SYSTEM: ListElem Shared Addr = 0xb5672e80
[ 41.339134] autorun-usecase.sh[113]: [host] 23: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[ 41.340787] autorun-usecase.sh[113]: [host] 23: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[ 41.342452] autorun-usecase.sh[113]: [host] 23: SYSTEM: ListElem Shared Addr = 0xb5692880
[ 41.344050] autorun-usecase.sh[113]: [host] 25: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[ 41.345669] autorun-usecase.sh[113]: [host] 25: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[ 41.347308] autorun-usecase.sh[113]: [host] 25: SYSTEM: ListElem Shared Addr = 0xb56b2280
[ 41.348962] autorun-usecase.sh[113]: [host] 27: SYSTEM: System Common Init Done !!!
[ 41.350643] autorun-usecase.sh[113]: [host] Vsys_allocBuf - addr = 0xa73e8000,size = 65011712
[ 41.352291] autorun-usecase.sh[113]: ##########pInfo->totalsize 63897600
[ 41.353910] autorun-usecase.sh[113]: [host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[ 41.356091] autorun-usecase.sh[113]: queue id:0
[ 41.357840] autorun-usecase.sh[113]: queue id:32769
[ 41.359547] autorun-usecase.sh[113]: [host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[ 41.361282] autorun-usecase.sh[113]: [host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[ 41.362960] autorun-usecase.sh[113]: [host] Vsys_allocBuf - addr = 0xb6f7b000,size = 33603
[ 41.364804] autorun-usecase.sh[113]: [host] DCC buffer allocated for size 33603
[ 41.366547] autorun-usecase.sh[113]: [host] DCC Default File Intialization Done
[ 41.368253] autorun-usecase.sh[113]: [host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[ 41.389740] autorun-usecase.sh[113]: [host]
[ 41.391818] autorun-usecase.sh[113]: ********** FULL FEATURE USECASE ********
[ 41.393600] autorun-usecase.sh[113]: [host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[ 41.395347] autorun-usecase.sh[113]: [host] 143: MCFW : CPU Revision [ES1.0] !!!
[ 41.397248] autorun-usecase.sh[113]: [host] 143: MCFW : Detected [UNKNOWN] Board !!!
[ 41.398933] autorun-usecase.sh[113]: [host] 143: MCFW : Base Board Revision [REV A] !!!
[ 41.417781] autorun-usecase.sh[113]: T_29] in region 0 ...
[ 41.419627] autorun-usecase.sh[113]: [m3vpss ] 1935: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 41.421416] autorun-usecase.sh[113]: [m3vpss ] 1935: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[ 41.423128] autorun-usecase.sh[113]: [m3vpss ] 1937: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 41.424770] autorun-usecase.sh[113]: [m3vpss ] 1938: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 41.426478] autorun-usecase.sh[113]: [m3vpss ] 1938: SYSTEM: ListElem Shared Addr = 0xbea03600
[ 41.428196] autorun-usecase.sh[113]: [m3vpss ] 1940: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 41.429873] autorun-usecase.sh[113]: [m3vpss ] 1940: SYSTEM : FVID2 Init in progress !!!
[ 41.431603] autorun-usecase.sh[113]: [m3vpss ] 2010: SYSTEM : FVID2 Init in progress DONE !!!
[ 41.433327] autorun-usecase.sh[113]: [m3vpss ] 2011: SYSTEM : Device Init in progress !!!
[ 41.434968] autorun-usecase.sh[113]: [m3vpss ] Iss_init called !!!!!!
[ 41.436626] autorun-usecase.sh[113]: [m3vpss ] CPIS_init DONE !!!!!!
[ 41.438640] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 41.440411] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 41.442156] autorun-usecase.sh[113]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 41.443833] autorun-usecase.sh[113]: [m3vpss ] 2205: SYSTEM : Device Init in progress DONE !!!
[ 41.445502] autorun-usecase.sh[113]: [m3video] 6285: SYSTEM : System Video Init in progress !!!
[ 41.778695] autorun-usecase.sh[113]: [m3video] 6286: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 41.779375] autorun-usecase.sh[113]: [m3video] 6286: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 41.779866] autorun-usecase.sh[113]: [m3video] 6286: SYSTEM: ListElem Shared Addr = 0xbea1d280
[ 41.780847] autorun-usecase.sh[113]: [m3video] 6289: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 41.781508] autorun-usecase.sh[113]: [m3video] 6289: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 41.782103] autorun-usecase.sh[113]: [m3video] 6289: SYSTEM: ListElem Shared Addr = 0xbea20780
[ 41.782733] autorun-usecase.sh[113]: [m3video] 6299: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 41.783313] autorun-usecase.sh[113]: [m3video] 6299: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 41.783977] autorun-usecase.sh[113]: [m3video] 6300: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 41.784539] autorun-usecase.sh[113]: [m3video] 6302: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 41.785173] autorun-usecase.sh[113]: [m3video] 6302: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 41.785776] autorun-usecase.sh[113]: [m3video] 6303: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 41.786406] autorun-usecase.sh[113]: [m3video] 6304: HDVICP: Doing PRCM for IVAHD[0] ...
[ 41.787009] autorun-usecase.sh[113]: [m3video] 6305: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 41.787582] autorun-usecase.sh[113]: [m3video] 6306: SYSTEM : Initializing Links !!!
[ 41.788402] autorun-usecase.sh[113]: [m3video] 6306: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 41.789028] autorun-usecase.sh[113]: [m3video] 6306: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 41.789696] autorun-usecase.sh[113]: [m3video] 6306: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 41.790358] autorun-usecase.sh[113]: [m3video] 6307: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 41.791183] autorun-usecase.sh[113]: [m3video] 6307: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 41.791853] autorun-usecase.sh[113]: [m3video] 6308: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 41.792510] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_init()
[ 41.793099] autorun-usecase.sh[113]: [m3video] 6367: SYSTEM : Initializing Links ... DONE !!!
[ 41.793727] autorun-usecase.sh[113]: [m3video] 6367: SYSTEM : System Video Init Done !!!
[ 41.794299] autorun-usecase.sh[113]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 41.794948] autorun-usecase.sh[113]: [m3vpss ] 7314: SYSTEM : System VPSS Init Done !!!
[ 41.795518] autorun-usecase.sh[113]: [m3vpss ] 7314: UTILS: DMA: HWI Create for INT62 !!!
[ 41.796155] autorun-usecase.sh[113]: [m3vpss ] 7315: SYSTEM : Initializing Links !!!
[ 41.796709] autorun-usecase.sh[113]: [m3vpss ] 7315: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 41.797336] autorun-usecase.sh[113]: [m3vpss ] 7315: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 41.797898] autorun-usecase.sh[113]: [m3vpss ] 7315: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 41.798542] autorun-usecase.sh[113]: [m3vpss ] 7316: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 41.799147] autorun-usecase.sh[113]: [m3vpss ] 7316: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 41.799711] autorun-usecase.sh[113]: [m3vpss ] 7446: SYSTEM : Initializing Links ... DONE !!!
[ 41.800380] autorun-usecase.sh[113]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 41.801010] autorun-usecase.sh[113]: [m3vpss ] VPS_DCTRL_INST_0
[ 41.801649] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 41.802212] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 42.136381] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 42.137036] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 42.137630] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 42.138226] autorun-usecase.sh[113]: [m3vpss ] HDCOMPCLK
[ 42.138853] autorun-usecase.sh[113]: [m3vpss ] 8782: CAMERA: Create in progress !!!
[ 42.139504] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 42.140126] autorun-usecase.sh[113]: [m3vpss ] Channel Num St[ 42.238663] DMA: ChannelID allocated:6
[ 42.140947] autorun-usecase.sh[113][ 42.246399] DMA: ChannelID allocated:7
: [m3vpss ] 8782: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 42.141732] autorun-usecase.sh[113]: [m3vpss ] 8783: CAMERA: VIP 0: VID DEC 268436737 (0x10): 00queue id:0
[ 42.240254] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[ 42.241088] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[ 42.324646] DMA: ChannelID allocated:12
[ 42.311977] autorun-usecase.sh[113]: [host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[ 42.553930] autorun-usecase.sh[113]: 02:20202020:20202020, AUD_STATUS 538976288
[ 42.554819] autorun-usecase.sh[113]: [m3vpss ] Iss_captCreate:1661
[ 42.555501] autorun-usecase.sh[113]: [m3vpss ] 8996: CAMERA: Create Done !!!
[ 42.556168] autorun-usecase.sh[113]: [m3vpss ] 9086: CAMERA: Detect video in progress !!!
[ 42.556762] autorun-usecase.sh[113]: [m3vpss ] 9086: CAMERA: Detect video Done !!!
[ 42.557412] autorun-usecase.sh[113]: [m3video] 9161: IPC_IN_M3 : Create in progress !!!
[ 42.557981] autorun-usecase.sh[113]: [m3vpss ] 9159: DUP : Create Done !!!
[ 42.558594] autorun-usecase.sh[113]: [m3video] 9161: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 42.559192] autorun-usecase.sh[113]: [m3vpss ] 9159: IPC_OUT_M3 : Create in progress !!!
[ 42.559753] autorun-usecase.sh[113]: [m3video] 9162: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 42.560444] autorun-usecase.sh[113]: [m3vpss ] 9160: IPC_OUT_M3 : Create Done !!!
[ 42.561053] autorun-usecase.sh[113]: [m3video] 9165: IPC_IN_M3 : Create Done !!!
[ 42.561684] autorun-usecase.sh[113]: [m3vpss ] DCC server task running
[ 42.562254] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_tskMain()
[ 42.562887] autorun-usecase.sh[113]: [m3video] inChInfo->width = 1920
[ 42.563438] autorun-usecase.sh[113]: [m3video] inChInfo->height = 1080
[ 42.564121] autorun-usecase.sh[113]: [m3video] inChInfo->pitch[0] = 1984
[ 42.564728] autorun-usecase.sh[113]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 42.565291] autorun-usecase.sh[113]: [m3video] [MCTNF] startX = 0
[ 42.565892] autorun-usecase.sh[113]: [m3vpss ] 9348: IPC_IN_M3 : Create in progress !!!
[ 42.566455] autorun-usecase.sh[113]: [m3video] [MCTNF] startY = 0
[ 42.567126] autorun-usecase.sh[113]: [m3vpss ] 9348: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 42.567689] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->width = 1920
[ 42.568322] autorun-usecase.sh[113]: [m3vpss ] 9348: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 42.568880] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->height = 1080
[ 42.569500] autorun-usecase.sh[113]: [m3vpss ] 9349: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 42.570120] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 42.570711] autorun-usecase.sh[113]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 42.571400] autorun-usecase.sh[113]: [m3video] 9346: IPC_OUT_M3 : Create in progress !!!
[ 42.571998] autorun-usecase.sh[113]: [m3video] 9347: IPC_OUT_M3 : Create Done !!!
[ 42.572689] autorun-usecase.sh[113]: [m3vpss ] 9352: IPC_IN_M3 : Create Done !!!
[ 42.573258] autorun-usecase.sh[113]: [m3vpss ] 9286: VNF:
[ 42.573912] autorun-usecase.sh[113]: [m3vpss ] Create in progress ... !!!
[ 42.574515] autorun-usecase.sh[113]: [m3vpss ] 9287: VNF:
[ 42.575080] autorun-usecase.sh[113]: [m3vpss ] Input Channel CH0 of 1920 x 1080, pitch = (1984, 1984) [0,0][PROGRESSIVE] [7] ...
[ 42.575673] autorun-usecase.sh[113]: [m3vpss ] 9287: VNF:
[ 42.576230] autorun-usecase.sh[113]: [m3vpss ] [VNF] eOperateMode=7 [6-TNF3,7-NSF2]chVnfCreateParams->ulStartX = -16 chVnfCreateParams->ulStartY = -18 chVnfCreateParams->ulInputStride = 1984 chVnfCreateParams->ulInputWidth=1952,chVnfCreateParams->ulInputHeight=1112
[ 42.576868] autorun-usecase.sh[113]: [m3vpss ] 9456: VNF:
[ 42.577529] autorun-usecase.sh[113]: [m3vpss ] [VNF] outChInfo->StartX = 0 outChInfo->startY = 0 outChInfo->pitch[0] = 1920 outChInfo->width=1920,outChInfo->height=1080
[ 42.578235] autorun-usecase.sh[113]: [m3vpss ] 9458: VNF:
[ 42.578814] autorun-usecase.sh[113]: [m3vpss ] Create ... DONE !!!
[ 42.579461] autorun-usecase.sh[113]: [m3vpss ] 9525: NSF: Create in progress !!!
[ 42.580106] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 42.580694] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 42.581320] autorun-usecase.sh[113]: [m3vpss ] 9650: NSF: Create Done !!!
[ 42.581886] autorun-usecase.sh[113]: [m3vpss ] 9651: Mux : Creating... !!!
[ 42.582499] autorun-usecase.sh[113]: [m3vpss ] 9652: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[ 42.583055] aut
reading u-boot.img
reading u-boot.img
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
cpsw
