xwr1642 如何配置512个独立chirp?
Other Parts Discussed in Thread: AWR1642, MMWAVE-DFP
 请教大家,应用xwr1642,SDK1.2版本,想配置512个各不相同的chirp,该如何配置呢?是否在SDK版本中有些chirp配置数目的限制呢?
  • 你好,
    The AWR1642 supports Advanced Frame Configuration that can be for your purpose of sending 3 different frames in a sequence.
    You will need to configure different SUB-FRAME using the advanced frame configuration sub-block.
    Please refer to Section "5.4.6 Sub block 0x0105 – AR_ADVANCED_FRAME_CONF_SB" in the "AWR1xx_Radar_Interface_Control.pdf" which is available in the MMWAVE-DFP for the message description .
    具体的细节可查看e2e.ti.com/.../619167
