· Spansion S25FL132K0XNFB010 32Mbit
· Spansion S25FL256S 256Mbit
· Macronix MX25L3233F 32Mbit
· Macronix MX25R1635FZNIH0 (Wide voltage part variant) 16Mbit
如果是来自其他供应商的flash型号,有两点要求:
· The SFDP response by the SFLASH variant
· If the Quad Enable bit is set in the SFLASH. This is required for the “Boot and test” step to work. That why our recommendation is to select a flash variant that has this bit set from the vendor itself.
