xds200与pga970连接的问题
Other Parts Discussed in Thread: PGA970
编译环境是ccs6.2,使用仿真器xds200与pga970板进行连接,按照pga970 software quick start guide中的步骤一步步完成配置,在点击test connection后显示下面情况。
an error occured while hard opening the controller.
an error has occured and this utility has aborted.
this error is generated by TI's USCIF driver or utilities.
the value is '-183'(0xffffff49). the title is 'SC_ERR_CTL_CBL_BREAK_FAR'.
the explanation is:the controller has detected a cable break far-from itself.
the user must connect the cable/pod to the target.
原先仿真器左侧灯常亮,点击test connection后,右侧灯闪烁两下,然后左右两侧灯全部熄灭。而且,在板子不上电的情况下点击test connection显示的情况与上面一样。想询问下这个问题可能出在哪里,谢谢!
