想請教一下for 1642的 vital sign lab
在dss_data_path.c 中有看到
// Output Values
obj->VitalSigns_Output.unwrapPhasePeak_mm = obj->unwrapPhasePeak;
obj->VitalSigns_Output.outputFilterBreathOut = outputFilterBreathOut;
obj->VitalSigns_Output.outputFilterHeartOut = outputFilterHeartOut;
obj->VitalSigns_Output.rangeBinIndexPhase = rangeBinIndexPhase; //frameCountLocal;
obj->VitalSigns_Output.maxVal = maxVal;
obj->VitalSigns_Output.sumEnergyHeartWfm = sumEnergyHeartWfm;
obj->VitalSigns_Output.sumEnergyBreathWfm = sumEnergyBreathWfm*peakValueBreathSpect;
obj->VitalSigns_Output.confidenceMetricBreathOut = confidenceMetricBreathOut;
obj->VitalSigns_Output.confidenceMetricHeartOut = confidenceMetricHeartOut; // Confidence Metric associated with the estimates
obj->VitalSigns_Output.confidenceMetricHeartOut_4Hz = confidenceMetricHeartOut_4Hz;
obj->VitalSigns_Output.confidenceMetricHeartOut_xCorr = confidenceMetricHeartOut_xCorr;
obj->VitalSigns_Output.breathingRateEst_FFT = breathingRateEst_FFT;
obj->VitalSigns_Output.breathingRateEst_peakCount = breathingRateEst_peakCount;
obj->VitalSigns_Output.heartRateEst_peakCount_filtered = heartRateEst_peakCount_filtered;
obj->VitalSigns_Output.heartRateEst_xCorr = heartRateEst_xCorr;
obj->VitalSigns_Output.heartRateEst_FFT_4Hz = heartRateEst_FFT_4Hz;
obj->VitalSigns_Output.heartRateEst_FFT = heartRateEst_FFT;
另外再 UI qt的code中有看到
processData()中陸續有在處理這些資料的code如下
float BreathingRate_FFT = parseValueFloat(data, INDEX_IN_DATA_BREATHING_RATE_FFT, 8); // Breathing Rate
float BreathingRatePK_Out = parseValueFloat(data, INDEX_IN_DATA_BREATHING_RATE_PEAK, 8);
float heartRate_FFT = parseValueFloat(data, INDEX_IN_DATA_HEART_RATE_EST_FFT, 8); // Heart Rate
我現在想做的事情是,我想要從1642處裡的資料 增加一組全新的資料並透過com port傳送,假定這組資料就是
heartRateEst_FFT+100;
我該修改那些地方才能達到我想做的事情呢??
謝謝
