IWR1642和DCA1000的问题
Other Parts Discussed in Thread: IWR1642
GM: Constructor
GM: Sun Dec 30 16:29:19 2018
RSTD.Transmit("/Settings")
[16:29:19]
[16:29:19]  ### Running Startup script: "C:\ti\mmwave_sdk_02_00_00_04\mmwave_studio_02_00_00_02\mmWaveStudio\Scripts\Startup.lua" ###
[16:29:19]  RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[16:29:19]  RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[16:29:19]  Scripter ignored: Attempt to UnBuild() again or before Build.
[16:29:19]  RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_sdk_02_00_00_04\\mmwave_studio_02_00_00_02\\mmWaveStudio\\Clients\\\\LabClient.dll")
[16:29:19]  RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[16:29:19]  RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[16:29:19]  RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[16:29:19]  RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[16:29:19]  RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[16:29:19]  RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_sdk_02_00_00_04\\mmwave_studio_02_00_00_02\\mmWaveStudio\\RunTime\\SAL.dll")
[16:29:19]  RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[16:29:19]  RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[16:29:19]  RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[16:29:19]  RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[16:29:19]  RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[16:29:19]  RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[16:29:19]  RSTD.Transmit("/")
[16:29:19]  RSTD.SaveSettings(): Settings saved to "C:\Users\Administrator.SC-201812191706\AppData\Roaming\RSTD\config.xml"
[16:29:19]  RSTD.Build()
[16:29:19]  RSTD.AL_Build()
[16:29:19]  RSTD.AL_LoadXml()
[16:29:19]  RSTD.AL_Init()
[16:29:19]  RSTD.Clients_Build()
[16:29:19]  GM: Init
[16:29:19]  GM: Loaded 'C:\ti\mmwave_sdk_02_00_00_04\mmwave_studio_02_00_00_02\mmWaveStudio\Clients\\LabClient.dll'
[16:29:19]  GM: 1 Guest (s) init
[16:29:19]  GM: 1 Module(s) init
[16:29:19]  GM: 2 Tab   (s) init
[16:29:19]  RSTD.Client_LoadXml()
[16:29:20]  [RadarAPI]: Starting Matlab Engine..
[16:29:20]  [RadarAPI]: Error: “MatlabPostProcGui.MatlabPostProcGUIClass”的类型初始值设定项引发异常。
[16:29:20]  Trace:
[16:29:20]     在 MatlabPostProcGui.MatlabPostProcGUIClass..ctor()
[16:29:20]     在 AR1xController.frmAR1Main.InitMatlabPostProcEngine(String PostProcesspath)
[16:29:20]  [RadarAPI]: Error: Error occured in Matlab Initialization
[16:29:20]  [RadarAPI]: Matlab Engine couldn't be Started..
[16:29:24]  [RadarAPI]: ar1.LoadSettings('C:\Users\Administrator.SC-201812191706\AppData\Roaming\RSTD\ar1gui.ini')
[16:29:24]  [RadarAPI]: Error: 未将对象引用设置到对象的实例。
[16:29:24]  Trace:
[16:29:24]     在 AR1xController.ScriptOps.getMatlabPostProcVersion()
通过mmwave studio配置IWR1642时,提示出现错误,请问是哪里配置出错了呢
