AWR1642 :关于1642复位问题
Other Parts Discussed in Thread: AWR1642
 感谢各位百忙之中抽空解惑,AWR1642我按照官方资料来进行软件复位,复位后不会从flash里加载我的程序,我怎样才能重新从Flash加载起来呢,有具体的过程或代码吗  谢谢各位
  • 你好,
    请问你是怎么操作复位的呢?
  • 你好 ,我是将1642的dss关闭后再往 地址 0xFFFFFF04里面写入 0xAD
    具体代码如下:
    #define READ_REG(reg, regVal)       regVal = *((uint32_t*)reg)
    #define WRITE_REG(reg, regVal)      *((uint32_t*)reg) = regVal;
    #define CORE_RST_REG                (0xFFFFFF04)
    void softReset(void)
        uint32_t rstRegVal = 0;
        /* MSS core reset */
        READ_REG(CORE_RST_REG, rstRegVal);
        /* Write 0xAD in 0-7 bits to perform MSS core reset */
        rstRegVal &= ~0xFF;
        rstRegVal |= 0xAD;
        WRITE_REG(CORE_RST_REG, rstRegVal);
        return;
  • 你好,
    你可以直接使用#define CORE_RST_REG                (0xFFFFE100+0x1c)
    Warm Reset Soft Reset, Watch Dog
    Reset, Device Pin
    WARM_RESET pin
    This is an active low warm reset internally generated by
    the device, or triggered by device pin WARM_RESET.
    A write to the TOP_RCM.SOFTSYSRST register or
    watch dog module can generate this reset; additionally,
    the external pin WARM_RESET can also be used to
    trigger this reset. Selection is controlled through the
    TOP_RCM.MISCTL1 register.
    The WARM_RESET pin is an open-drain failsafe IO
    which can be used to reset the device from the external
    world or to report the reset to the external world if it is
    generated by an internal source such as watchdog.
    A write to the TOP_RCM.SOFTSYSRST, as explained
    in register description, can create this reset.
    The watch dog module in the master subsystem can be
    configured to trigger this reset. Check the watch dog
    module description for details. This feature is enabled by
    the TOP_RCM. WDRSTEN register.
  • 等我确认下是否能成功,谢谢您
  • 你好 我将上面函数的寄存器地址改了 还是不行呢 现在程序直接死掉了,请问还有什么方法吗
  • 你好,
    你这段代码在我这里测试复位是可行的。在MSS中直接调用,没有其他的操作。谢谢
        rstRegVal &= ~0xFF;
        rstRegVal |= 0xAD;
        return;
  • 谢谢您 我再确认一下
