Other Parts Discussed in Thread: DRV8840
drv8840老是出现ocp问题请教。drv8840运行几秒或者其它秒之后,fault引脚出现0电平,且不可回复,看资料应该是出现ocp保护。另外一种板子外围参数一样,负载也是一样,基本不出现这个ocp。
请教下,drv8840的ocp出现的原理是咋回事?在drv8840的资料上,没有看到ocp相关的是详细说明
An analog current limit circuit on each FET limits the current through the FET by removing the gate drive. If this analog current limit persists for longer than the OCP time, all FETs in the H-bridge will be disabled and the nFAULT pin will be driven low. The device will remain disabled until either nRESET pin is applied, or VM is removed and re-applied.
你可以从PCB layout的区别上看是否有过电流情况发生。
