请问AWR1642可以使用XDS100V2仿真器吗?我只能connect,但是不能下载程序?
下载了 xwr16xx_ccsdebug.bin后,能connect,但是没法下载?有什么注意事项?
  • 没法下载具体是什么表现?
    SOP模式改了吗?
    www.ti.com/.../swru508c.pdf
  • 改为Functional Mode,然后复位,但是也不能下载
    报错: a data verification error occurred, file load failed.
    而且有时候连接也不行
    Error connecting to the target:
    (Error -154 @ 0xFFFFFF66)
    One of the FTDI driver functions used to
    write data returned bad status or an error.
    (Emulation package 8.2.0.00004)
    测试如下:
    [Start: Texas Instruments XDS100v2 USB Debug Probe_0]
    Execute the command:
    %ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
    [Result]
    -----[Print the board config pathname(s)]------------------------------------
    C:\Users\gao\AppData\Local\TEXASI~1\CCS\
    ccs910\0\0\BrdDat\testBoard.dat
    -----[Print the reset-command software log-file]-----------------------------
    This utility has selected a 100- or 510-class product.
    This utility will load the adapter 'jioserdesusb.dll'.
    The library build date was 'Jun 3 2019'.
    The library build time was '15:24:38'.
    The library package version is '8.2.0.00004'.
    The library component version is '35.35.0.0'.
    The controller does not use a programmable FPGA.
    The controller has a version number of '4' (0x00000004).
    The controller has an insertion length of '0' (0x00000000).
    This utility will attempt to reset the controller.
    This utility has successfully reset the controller.
    -----[Print the reset-command hardware log-file]-----------------------------
    The scan-path will be reset by toggling the JTAG TRST signal.
    The controller is the FTDI FT2232 with USB interface.
    The link from controller to target is direct (without cable).
    The software is configured for FTDI FT2232 features.
    The controller cannot monitor the value on the EMU[0] pin.
    The controller cannot monitor the value on the EMU[1] pin.
    The controller cannot control the timing on output pins.
    The controller cannot control the timing on input pins.
    The scan-path link-delay has been set to exactly '0' (0x0000).
    -----[The log-file for the JTAG TCLK output generated from the PLL]----------
    There is no hardware for programming the JTAG TCLK frequency.
    -----[Measure the source and frequency of the final JTAG TCLKR input]--------
    There is no hardware for measuring the JTAG TCLK frequency.
    -----[Perform the standard path-length test on the JTAG IR and DR]-----------
    This path-length test uses blocks of 64 32-bit words.
    The test for the JTAG IR instruction path-length succeeded.
    The JTAG IR instruction path-length is 4 bits.
    The test for the JTAG DR bypass path-length succeeded.
    The JTAG DR bypass path-length is 1 bits.
    -----[Perform the Integrity scan-test on the JTAG IR]------------------------
    This test will use blocks of 64 32-bit words.
    This test will be applied just once.
    Do a test using 0xFFFFFFFF.
    Scan tests: 1, skipped: 0, failed: 0
    Do a test using 0x00000000.
    Scan tests: 2, skipped: 0, failed: 0
    Do a test using 0xFE03E0E2.
    Scan tests: 3, skipped: 0, failed: 0
    Do a test using 0x01FC1F1D.
    Scan tests: 4, skipped: 0, failed: 0
    Do a test using 0x5533CCAA.
    Scan tests: 5, skipped: 0, failed: 0
    Do a test using 0xAACC3355.
    Scan tests: 6, skipped: 0, failed: 0
    All of the values were scanned correctly.
    The JTAG IR Integrity scan-test has succeeded.
    -----[Perform the Integrity scan-test on the JTAG DR]------------------------
    The JTAG DR Integrity scan-test has succeeded.
    [End: Texas Instruments XDS100v2 USB Debug Probe_0]
