Other Parts Discussed in Thread: DCA1000EVM
按照mmWave Studio User's Guide进行到点击DCA1000 ARM 和Trigger Frame时出现了LVDS buffer full等问题
GM: Constructor
GM: Wed Oct 28 09:17:02 2020
RSTD.Transmit("/Settings")
[09:17:02]
[09:17:02] ### Running Startup script: "D:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ###
[09:17:02] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[09:17:02] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[09:17:02] Scripter ignored: Attempt to UnBuild() again or before Build.
[09:17:02] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "D:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[09:17:02] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[09:17:02] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[09:17:02] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[09:17:02] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[09:17:02] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[09:17:02] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "D:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll")
[09:17:02] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[09:17:02] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[09:17:02] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[09:17:02] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[09:17:02] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[09:17:02] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[09:17:02] RSTD.Transmit("/")
[09:17:02] RSTD.SaveSettings(): Settings saved to "C:\Users\86134\AppData\Roaming\RSTD\config.xml"
[09:17:02] RSTD.Build()
[09:17:02] RSTD.AL_Build()
[09:17:02] RSTD.AL_LoadXml()
[09:17:02] RSTD.AL_Init()
[09:17:02] RSTD.Clients_Build()
[09:17:02] GM: Init
[09:17:02] GM: Loaded 'D:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll'
[09:17:02] GM: 1 Guest (s) init
[09:17:02] GM: 1 Module(s) init
[09:17:02] GM: 2 Tab (s) init
[09:17:02] RSTD.Client_LoadXml()
[09:17:03] [RadarAPI]: ar1.selectRadarMode(0)
[09:17:03] [RadarAPI]: Status: Passed
[09:17:03] Matlab Runtime Engine is installed
[09:17:03] [RadarAPI]: Starting Matlab Engine..
[09:17:08] [RadarAPI]: Matlab Engine Started!
[09:17:10] [RadarAPI]: ar1.selectCascadeMode(0)
[09:17:10] [RadarAPI]: Status: Passed
[09:17:10] [RadarAPI]: ar1.LoadSettings('C:\Users\86134\AppData\Roaming\RSTD\ar1gui.ini')
[09:17:10] TESTING = false
[09:17:10] RstdNet: Port 2777: Listening..
[09:17:10]
[09:17:10] ***Script completed successfully.***
[09:17:12] [RadarAPI]: Opening Gpio Control Port()
[09:17:12] [RadarAPI]: Status: Passed
[09:17:13] [RadarAPI]: Opening Board Control Port()
[09:17:13] [RadarAPI]: Status: Passed
[09:17:14] [RadarAPI]: ar1.FullReset()
[09:17:14] [RadarAPI]: Status: Passed
[09:17:15] [RadarAPI]: Closing Board Control Port()
[09:17:15] [RadarAPI]: Status: Passed
[09:17:15] [RadarAPI]: Closing Gpio Control Port()
[09:17:15] [RadarAPI]: ar1.SOPControl(2)
[09:17:18] [RadarAPI]: ar1.Connect(4,921600,1000)
[09:17:21] [RadarAPI]: Warning: Connected with baudrate 115200
[09:17:22] [RadarAPI]: Warning: Disconnected existing BaudRate
[09:17:22] [RadarAPI]: Warning: Trying to connect with baudrate 921600
[09:17:23] [RadarAPI]: ar1.Calling_IsConnected()
[09:17:25] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[09:17:25] [RadarAPI]: Status: Passed
[09:17:25] [RadarAPI]: ar1.deviceVariantSelection("XWR1642")
[09:17:25] [RadarAPI]: ar1.frequencyBandSelection("77G")
[09:17:25] [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[09:17:25] Device Status : XWR1642/QM/SOP:2/ES:2
[09:17:25] [RadarAPI]: ar1.SaveSettings('C:\Users\86134\AppData\Roaming\RSTD\ar1gui.ini')
[09:17:27] [RadarAPI]: ar1.DownloadBSSFw("D:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\radarss\\xwr16xx_radarss.bin")
[09:17:27] [RadarAPI]: Downloading BSS Patch RPRC Binary..
[09:17:29] [RadarAPI]: ar1.GetBSSFwVersion()
[09:17:29] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[09:17:30] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[09:17:30] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[09:17:30] [RadarAPI]: ar1.DownloadMSSFw("D:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\masterss\\xwr16xx_masterss.bin")
[09:17:30] [RadarAPI]: Downloading MSS RPRC Binary..
[09:17:32] [RadarAPI]: ar1.GetMSSFwVersion()
[09:17:32] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[09:17:40] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[09:17:40] [RadarAPI]: Status: Passed
[09:17:40] MSS power up done async event received!
[09:17:45] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[09:17:45] [RadarAPI]: Status: Passed
[09:17:45] [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[09:17:45] Device Status : XWR1642/QM/SOP:2/ES:2
[09:17:45] [RadarAPI]: ar1.RfEnable()
[09:17:45] BSS power up done async event received!
[09:17:46] [RadarAPI]: ar1.GetMSSFwVersion()
[09:17:46] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[09:17:46] [RadarAPI]: ar1.GetBSSFwVersion()
[09:17:46] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[09:17:47] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[09:17:47] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[09:17:55] [RadarAPI]: ar1.ChanNAdcConfig(1, 0, 0, 1, 1, 1, 1, 2, 1, 0)
[09:17:55] [RadarAPI]: Status: Passed
[09:18:01] [RadarAPI]: ar1.LPModConfig(0, 1)
[09:18:01] [RadarAPI]: Status: Passed
[09:18:04] [RadarAPI]: ar1.RfInit()
[09:18:04] RF Init async event received!
[09:18:04] [RadarAPI]: Time stamp, Temperture: 18897,38; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 0, 0; RxIQMM Status, Update: 1, 1;
[09:18:04] [RadarAPI]: Status: Passed
[09:18:20] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[09:18:20] [RadarAPI]: Status: Passed
[09:18:22] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[09:18:22] [RadarAPI]: Status: Passed
[09:18:25] [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
[09:18:25] [RadarAPI]: Status: Passed
[09:18:39] [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 5120, 0, 0, 30)
[09:18:39] [RadarAPI]: Status: Passed
[09:18:50] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[09:18:51] [RadarAPI]: Status: Passed
[09:18:58] Test Source Already Disabled...!!!
[09:18:58] [RadarAPI]: ar1.DisableTestSource(0)
[09:18:58] [RadarAPI]: Status: Passed
[09:18:58] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1)
[09:19:04] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[09:19:04] [RadarAPI]: Sending dll_version command to DCA1000
[09:19:05] [RadarAPI]:
[09:19:05] DLL Version : 1.0
[09:19:05] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[09:19:05] [RadarAPI]: Status: Passed
[09:19:07] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[09:19:07] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[09:19:07] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[09:19:07] [RadarAPI]: Sending fpga command to DCA1000
[09:19:07] FPGA Configuration command : Success
[09:19:07] [RadarAPI]: Sending record command to DCA1000
[09:19:07] Configure Record command : Success
[09:19:07] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[09:19:07] [RadarAPI]: Sending fpga_version command to DCA1000
[09:19:07]
[09:19:07] FPGA Version : 2.7 [Record]
[09:19:07]
[09:19:15] [RadarAPI]: ar1.CaptureCardConfig_StartRecord("D:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\PostProc\\adc_data.bin", 1)
[09:19:15] [RadarAPI]: Sending start_record command to DCA1000
[09:19:20] [RadarAPI]: ar1.StartFrame()
[09:19:20] [RadarAPI]: Status: Passed
[09:19:20] Frame start async event received!
[09:19:21] Frame End async event received!
[09:19:21] [RadarAPI]: Frame Ended
[09:20:35] [RadarAPI]:
[09:20:35] Start Record command : Success
[09:20:35]
[09:20:35] LVDS buffer full
[09:20:35]
[09:20:35] Record Process :
[09:20:35] Timeout Error! System disconnected
[09:20:35]
[09:20:35] Record stop is done successfully
